[GRASS-SVN] r30262 - grass/branches/releasebranch_6_3
svn_grass at osgeo.org
Tue Feb 19 15:45:53 EST 2008
Author: neteler
Date: 2008-02-19 15:45:53 -0500 (Tue, 19 Feb 2008)
New Revision: 30262
Added:
grass/branches/releasebranch_6_3/SUBMITTING_PYTHON
now also needed here
Added: grass/branches/releasebranch_6_3/SUBMITTING_PYTHON
--- grass/branches/releasebranch_6_3/SUBMITTING_PYTHON (rev 0)
+++ grass/branches/releasebranch_6_3/SUBMITTING_PYTHON 2008-02-19 20:45:53 UTC (rev 30262)
@@ -0,0 +1,109 @@
+$Date: 2008-01-06 12:42:32 +0100 (Sun, 06 Jan 2008) $
+NOTE: Please improve this list!
+Dear (new) GRASS Developer,
+When submitting Python code to GRASS SVN repository, please take
+care of following rules:
+[ see SUBMITTING for C hints ]
+[ see SUBMITTING_SCRIPTS for shell script hints ]
+[ see SUBMITTING_TCLTK for tcl and tk hints ]
+[ see SUBMITTING_DOCS for documentation ]
+1. Indentation
+ As Python determines nesting based upon indentation, it
+ isn't just a stylistic issue.
+ Please use 4-space indentation (GNU Emacs python-mode default).
+ See also "Python Style Guide" by Guido van Rossum
+ http://www.python.org/doc/essays/styleguide.html
+2. Add a header section to the script you submit and make sure you
+ include the copyright. The purpose section is meant to contain a
+ general over view of the code in the file to assist other
+ programmers that will need to make changes to your code. For this
+ purpose use Python Docstring, see
+ http://epydoc.sourceforge.net/docstrings.html
+ Example (fictitious header for a script called r.myscript):
+MODULE: r.myscript
+AUTHOR(S): Me <email AT some domain>
+PURPOSE: Calculates univariate statistics from a GRASS raster map
+COPYRIGHT: (C) 2007 by the GRASS Development Team
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ The copyright protects your rights according to GNU General Public
+ License (www.gnu.org).
+3. - deleted.
+ We don't want the $ ID $ in source code any more as it causes problems
+ for the branches.
+4. PLEASE take the time to add comments throughout your code explaining what
+ the code is doing. It will save a HUGE amount of time and frustration for
+ other programmers that may have to change your code in the future.
+5. Make sure a new line is at the end of each file.
+6. For consistency, use README rather than README.txt for any README files.
+7. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository).
+ You can re-check before submission with 'svn diff':
+ Be sure to create unified ("diff -u") format. "Plain" diffs (the default
+ format) are risky, because they will apply without warning to code which
+ has been substantially changed; they are also harder to read than unified.
+ Such diffs should be made from the top-level directory, e.g.
+ "svn diff gui/wxpython/wxgui.py"; that way, the diff will
+ include the pathname rather than just "wxgui.py".
+8. When submitting new files to the repository set SVN properties,
+ usually for directory
+ svn:ignore : *.pyc
+ or e.g. for Python file
+ svn:mime-type : text/python
+ svn:keywords : Author Date Id
+ svn:eol-style : native
+ See
+ http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
+8. Tell the other developers about the new code using the following e-mail:
+ grass-dev at lists.osgeo.org
+ To subscribe to this mailing list, see
+ http://lists.osgeo.org/mailman/listinfo/grass-dev
+9. In case of questions feel free to contact the developers at the above
+ mailing list.
+ http://www.grass-gis.org/devel/index.php#submission
+[please add further hints if required]
