[GRASS-SVN] r30266 - grass/trunk/gui/tcltk/gis.m
svn_grass at osgeo.org
Tue Feb 19 22:50:12 EST 2008
Author: cmbarton
Date: 2008-02-19 22:50:12 -0500 (Tue, 19 Feb 2008)
New Revision: 30266
grass/trunk/gui/tcltk/gis.m/gmmenu.tcl
Adding v.dissolve to menu
Modified: grass/trunk/gui/tcltk/gis.m/gmmenu.tcl
--- grass/trunk/gui/tcltk/gis.m/gmmenu.tcl 2008-02-19 21:05:36 UTC (rev 30265)
+++ grass/trunk/gui/tcltk/gis.m/gmmenu.tcl 2008-02-20 03:50:12 UTC (rev 30266)
@@ -453,6 +453,7 @@
{command {[G_msg "Query with another map"]} {} " v.select: Query objects using objects from a second map" {} -command {execute v.select }}
{separator}
{command {[G_msg "Buffer vectors"]} {} "v.buffer: Create vector buffers around vector objects" {} -command {execute v.buffer }}
+ {command {[G_msg "Dissolve boundaries"]} {} "v.dissolve: Dissolve common boundaries and optionally reclassify objects with common cats or attributes" {} -command {execute v.dissolve }}
{cascad {[G_msg "Lidar analysis"]} {} "" $tmenu {
{command {[G_msg "Detect edges"]} {} "v.lidar.edgedetection: Detect object edges in Lidar data" {} -command {execute v.lidar.edgedetection }}
{command {[G_msg "Detect interiors"]} {} "v.lidar.growing: Detect interiors of objects in Lidar data" {} -command {execute v.lidar.growing }}
