[GRASS-SVN] r30269 - grass/trunk/raster/simwe/r.sim.sediment
Wed Feb 20 11:25:56 EST 2008
Author: helena
Date: 2008-02-20 11:25:56 -0500 (Wed, 20 Feb 2008)
New Revision: 30269
   grass/trunk/raster/simwe/r.sim.sediment/main.c
cleanup - units, module name, parser macros
Modified: grass/trunk/raster/simwe/r.sim.sediment/main.c
--- grass/trunk/raster/simwe/r.sim.sediment/main.c	2008-02-20 16:24:57 UTC (rev 30268)
+++ grass/trunk/raster/simwe/r.sim.sediment/main.c	2008-02-20 16:25:56 UTC (rev 30269)
@@ -1,10 +1,10 @@
- * MODULE:       r.simwe.erosion: main program for hydrologic and sediment transport
+ * MODULE:       r.sim.sediment: main program for sediment transport
  *               simulation (SIMWE)
  * AUTHOR(S):    L. Mitas,  H. Mitasova, J. Hofierka
- * PURPOSE:      Hydrologic and sediment transport simulation (SIMWE)
+ * PURPOSE:      Sediment transport simulation (SIMWE)
  * COPYRIGHT:    (C) 2002 by the GRASS Development Team
@@ -15,7 +15,7 @@
- * r.simwe.erosion: main program for hydrologic and sediment transport
+ * r.sim.sediment: main program for hydrologic and sediment transport
  * Original program (2002) and various modifications:
@@ -46,12 +46,19 @@
+/* DEFINE GLOB VAR              */
 #define NWALK	"2000000"
 #define DIFFC	"0.8"
 #define NITER   "1200"
 #define ITEROUT "300"
 #define DENSITY "200"
+#define MANINVAL "0.1"
+/* INCLUDES                     */
 #include <stdio.h>
 #include <stdlib.h>
 #include <math.h>
@@ -67,6 +74,9 @@
 #include <grass/site.h>
 #include <grass/glocale.h>
+/* Specific stuff               */
 #define MAIN
 #include <grass/waterglobs.h>
@@ -80,366 +90,344 @@
 char msg[1024];
+/* MAIN                                 */
 int main ( int argc, char *argv[])
-  int i,ii,j,l;
-  int ret_val;
-  double x_orig, y_orig;
-  static int rand1 = 12345;
-  static int rand2 = 67891;
+	int i,ii,j,l;
+	int ret_val;
+	double x_orig, y_orig;
+	static int rand1 = 12345;
+	static int rand2 = 67891;
+	G_gisinit (argv[0]);
+	module = G_define_module();
+	module->keywords = _("raster, sediment flow, erosion, deposition");
+	module->description =
+	_("Sediment transport and erosion/deposition simulation "
+	  "using path sampling method (SIMWE)");
-  G_gisinit (argv[0]);
+	if (G_get_set_window (&cellhd) == -1)
+		exit (EXIT_FAILURE);
-  module = G_define_module();
-  module->keywords = _("raster");
-  module->description =
-	_("Overland flow hydrologic model based on duality "
-	  "particle-field concept (SIMWE)");
-  if (G_get_set_window (&cellhd) == -1)
-    exit (EXIT_FAILURE);
+	conv = G_database_units_to_meters_factor();
-  conv = G_database_units_to_meters_factor();
+	mixx = cellhd.west * conv;
+	maxx = cellhd.east * conv;
+	miyy = cellhd.south * conv;
+	mayy = cellhd.north * conv;
+	stepx = cellhd.ew_res * conv;
+	stepy = cellhd.ns_res * conv;
+	/*  step = amin1(stepx,stepy);*/
+	step = (stepx + stepy) / 2.;
+	mx = cellhd.cols;
+	my = cellhd.rows;
+	x_orig = cellhd.west * conv;
+	y_orig = cellhd.south * conv;/* do we need this? */
+		xmin = 0.;
+		ymin = 0.;
+		xp0 = xmin + stepx / 2.;
+		yp0 = ymin + stepy / 2.;
+		xmax = xmin + stepx * (float) mx;
+		ymax = ymin + stepy * (float) my;
+		bxmi=2093113. * conv;
+		bymi=731331. * conv;
+		bxma=2093461. * conv;
+		byma=731529. * conv;
+		bresx=2. * conv;
+		bresy=2. * conv;
+		maxwab=100000;
+		hhc = hhmax = 0.;
+		mx2o= (int)((bxma-bxmi)/bresx);
+		my2o= (int)((byma-bymi)/bresy);
+		/* relative small box coordinates: leave 1 grid layer for overlap */
+		bxmi = bxmi - mixx + stepx;
+		bymi = bymi - miyy + stepy;
+		bxma = bxma - mixx - stepx;
+		byma = byma - miyy - stepy;
+		mx2 = mx2o - 2*((int) (stepx / bresx));
+		my2 = my2o - 2*((int) (stepy / bresy));
-  mixx = cellhd.west * conv;
-  maxx = cellhd.east * conv;
-  miyy = cellhd.south * conv;
-  mayy = cellhd.north * conv;
-  stepx = cellhd.ew_res * conv;
-  stepy = cellhd.ns_res * conv;
-/*  step = amin1(stepx,stepy);*/
-  step = (stepx + stepy) / 2.;
-  mx = cellhd.cols;
-  my = cellhd.rows;
-  x_orig = cellhd.west * conv;
-  y_orig = cellhd.south * conv;/* do we need this? */
-    xmin = 0.;
-    ymin = 0.;
-    xp0 = xmin + stepx / 2.;
-    yp0 = ymin + stepy / 2.;
-    xmax = xmin + stepx * (float) mx;
-    ymax = ymin + stepy * (float) my;
+	parm.elevin = G_define_standard_option(G_OPT_R_INPUT);
+	parm.elevin->key = "elevin";
+	parm.elevin->description = _("Name of the elevation raster map [m]");
+	parm.elevin->guisection  = _("Input_options");
-    bxmi=2093113. * conv;
-    bymi=731331. * conv;
-    bxma=2093461. * conv;
-    byma=731529. * conv;
-    bresx=2. * conv;
-    bresy=2. * conv;
-    maxwab=100000;
+	parm.wdepth = G_define_standard_option(G_OPT_R_INPUT);
+	parm.wdepth->key = "wdepth";
+	parm.wdepth->description = _("Name of the water depth raster map [m]");
+	parm.wdepth->guisection  = _("Input_options");
+	parm.dxin = G_define_standard_option(G_OPT_R_INPUT);
+	parm.dxin->key = "dxin";
+	parm.dxin->description = _("Name of the x-derivatives raster map [m/m]");
+	parm.dxin->guisection  = _("Input_options");
+	parm.dyin = G_define_standard_option(G_OPT_R_INPUT);
+	parm.dyin->key = "dyin";
+	parm.dyin->description = _("Name of the y-derivatives raster map [m/m]");
+	parm.dyin->guisection  = _("Input_options");
+	parm.detin = G_define_standard_option(G_OPT_R_INPUT);
+	parm.detin->key = "detin";
+	parm.detin->description =
+		_("Name of the detachment capacity coefficient raster map [s/m]");
+	parm.detin->guisection  = _("Input_options");
+	parm.tranin = G_define_standard_option(G_OPT_R_INPUT);
+	parm.tranin->key = "tranin";
+	parm.tranin->description =
+		_("Name of the transport capacity coefficient raster map [s]");
+	parm.tranin->guisection  = _("Input_options");
+	parm.tauin = G_define_standard_option(G_OPT_R_INPUT);
+	parm.tauin->key = "tauin";
+	parm.tauin->description = _("Name of the critical shear stress raster map [Pa]");
+	parm.tauin->guisection  = _("Input_options");
+	parm.manin = G_define_standard_option(G_OPT_R_INPUT);
+	parm.manin->key = "manin";
+	parm.manin->required = NO;
+	parm.manin->description = _("Name of the Mannings n raster map");
+	parm.manin->guisection  = _("Input_options");
+	parm.maninval = G_define_option();
+	parm.maninval->key = "maninval";
+	parm.maninval->type = TYPE_DOUBLE;
+	parm.maninval->answer = MANINVAL;
+	parm.maninval->required = NO;
+	parm.maninval->description = _("Name of the Mannings n value");
+	parm.maninval->guisection  = _("Input_options");
+	/* needs to be updated to GRASS 6 vector format !! */
+	parm.sfile = G_define_standard_option(G_OPT_V_INPUT);
+	parm.sfile->key = "vector";
+	parm.sfile->required = NO;
+	parm.sfile->description = _("Name of the sampling locations vector points map");
+	parm.sfile->guisection  = _("Input_options");
+	parm.tc = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.tc->key = "tc";
+	parm.tc->required = NO;
+	parm.tc->description = _("Output transport capacity raster map [kg/ms]");
+	parm.tc->guisection  = _("Output_options");
+	parm.et = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.et->key = "et";
+	parm.et->required = NO;
+	parm.et->description =
+		_("Output transp.limited erosion-deposition raster map [kg/m2s]");
+	parm.et->guisection  = _("Output_options");
+	parm.conc = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.conc->key = "conc";
+	parm.conc->required = NO;
+	parm.conc->description = _("Output sediment concentration raster map [particle/m3]");
+	parm.conc->guisection  = _("Output_options");
+	parm.flux = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.flux->key = "flux";
+	parm.flux->required = NO;
+	parm.flux->description = _("Output sediment flux raster map [kg/ms]");
+	parm.flux->guisection  = _("Output_options");
+	parm.erdep = G_define_standard_option(G_OPT_R_OUTPUT);
+	parm.erdep->key = "erdep";
+	parm.erdep->required = NO;
+	parm.erdep->description = _("Output erosion-deposition raster map [kg/m2s]");
+	parm.erdep->guisection  = _("Output_options");
+	parm.nwalk = G_define_option();
+	parm.nwalk->key = "nwalk";
+	parm.nwalk->type = TYPE_INTEGER;
+	parm.nwalk->answer = NWALK;
+	parm.nwalk->required = NO;
+	parm.nwalk->description = _("Number of walkers");
+	parm.nwalk->guisection  = _("Parameters");
+	parm.niter = G_define_option();
+	parm.niter->key = "niter";
+	parm.niter->type = TYPE_INTEGER;
+	parm.niter->answer = NITER;
+	parm.niter->required = NO;
+	parm.niter->description = _("Time used for iterations [minutes]");
+	parm.niter->guisection  = _("Parameters");
+	parm.outiter = G_define_option();
+	parm.outiter->key = "outiter";
+	parm.outiter->type = TYPE_INTEGER;
+	parm.outiter->answer = ITEROUT;
+	parm.outiter->required = NO;
+	parm.outiter->description = _("Time interval for creating output maps [minutes]");
+	parm.outiter->guisection  = _("Parameters");
+	parm.density = G_define_option();
+	parm.density->key = "density";
+	parm.density->type = TYPE_INTEGER;
+	parm.density->answer = DENSITY;
+	parm.density->required = NO;
+	parm.density->description = _("Density of output walkers");
+	parm.density->guisection  = _("Parameters");
+	parm.diffc = G_define_option();
+	parm.diffc->key = "diffc";
+	parm.diffc->type = TYPE_DOUBLE;
+	parm.diffc->answer = DIFFC;
+	parm.diffc->required = NO;
+	parm.diffc->description = _("Water diffusion constant");
+	parm.diffc->guisection  = _("Parameters");
+	flag.mscale = G_define_flag ();
+	flag.mscale->key = 'm';
+	flag.mscale->description = _("Multiscale simulation");
+	flag.tserie = G_define_flag ();
+	flag.tserie->key = 't';
+	flag.tserie->description = _("Time-series output");
-    hhc = hhmax = 0.;
+	if (G_parser (argc, argv))
-    mx2o= (int)((bxma-bxmi)/bresx);
-    my2o= (int)((byma-bymi)/bresy);
+	mscale=flag.mscale->answer ? "m" : NULL;
+	tserie=flag.tserie->answer ? "t" : NULL;
+	elevin = parm.elevin->answer;
+	wdepth = parm.wdepth->answer;
+	dxin = parm.dxin->answer;
+	dyin = parm.dyin->answer;
+	/*  maskmap = parm.maskmap->answer;*/
+	detin = parm.detin->answer;
+	tranin = parm.tranin->answer;
+	tauin = parm.tauin->answer;
+	manin = parm.manin->answer;
+	tc = parm.tc->answer;
+	et = parm.et->answer;
+	conc = parm.conc->answer;
+	flux = parm.flux->answer;
+	erdep = parm.erdep->answer;
+	sfile = parm.sfile->answer;
+	sscanf(parm.nwalk->answer, "%d", &maxwa);
+	sscanf(parm.niter->answer, "%d", &timesec);
+	sscanf(parm.outiter->answer, "%d", &iterout);
+	sscanf(parm.density->answer, "%d", &ldemo);
+	sscanf(parm.diffc->answer, "%lf", &frac);
+	sscanf(parm.maninval->answer, "%lf", &manin_val);
-/* relative small box coordinates: leave 1 grid layer for overlap */
+        /* Recompute timesec from user input in minutes
+         * to real timesec in seconds */
+	timesec = timesec * 60.0;
+	iterout = iterout * 60.0;
+	if ((timesec/iterout) > 100.0)
+		G_message(_("More than 100 files are going to be created !!!!!"));
-    bxmi = bxmi - mixx + stepx;
-    bymi = bymi - miyy + stepy;
-    bxma = bxma - mixx - stepx;
-    byma = byma - miyy - stepy;
-    mx2 = mx2o - 2*((int) (stepx / bresx));
-    my2 = my2o - 2*((int) (stepy / bresy));
+	/* compute how big the raster is and set this to appr 2 walkers per cell */
+	if(parm.nwalk->answer==NULL){
+		maxwa = mx*my*2;
+		rwalk = (double) (mx*my*2.);
+		G_message(_("default nwalk=%d, rwalk=%f"), maxwa, rwalk);
+	} else {
+		rwalk = (double) maxwa;
+	/*rwalk = (double) maxwa;*/
-  parm.elevin = G_define_option();
-  parm.elevin->key = "elevin";
-  parm.elevin->type = TYPE_STRING;
-  parm.elevin->required = YES;
-  parm.elevin->gisprompt = "old,cell,raster";
-  parm.elevin->description = _("Name of the elevation raster map");
-  parm.elevin->guisection  = _("Input_options");
+	if (conv != 1.0)
+		G_message(_("Using metric conversion factor %f, step=%f"), conv, step);
-  parm.wdepth = G_define_option();
-  parm.wdepth->key = "wdepth";
-  parm.wdepth->type = TYPE_STRING;
-  parm.wdepth->required = YES;
-  parm.wdepth->gisprompt = "old,cell,raster";
-  parm.wdepth->description = _("Name of the water height raster map");
-  parm.wdepth->guisection  = _("Input_options");
+	* G_set_embedded_null_value_mode(1);
+	if ((tc == NULL) && (et == NULL) && (conc == NULL) && (flux == NULL) && (erdep == NULL))
+		G_warning(_("You are not outputing any raster or site files"));
+	ret_val = input_data();
+	if (ret_val != 1)
+		G_fatal_error(_("Input failed"));
-  parm.dxin = G_define_option();
-  parm.dxin->key = "dxin";
-  parm.dxin->type = TYPE_STRING;
-  parm.dxin->required = YES;
-  parm.dxin->gisprompt = "old,cell,raster";
-  parm.dxin->description = _("Name of the x-derivatives raster map");
-  parm.dxin->guisection  = _("Input_options");
+	/* mandatory for si,sigma */
-  parm.dyin = G_define_option();
-  parm.dyin->key = "dyin";
-  parm.dyin->type = TYPE_STRING;
-  parm.dyin->required = YES;
-  parm.dyin->gisprompt = "old,cell,raster";
-  parm.dyin->description = _("Name of the y-derivatives raster map");
-  parm.dyin->guisection  = _("Input_options");
+	si = (double **)G_malloc (sizeof(double *)*(my));
+	for(l=0;l<my;l++)
+		si[l]   = (double*)G_malloc (sizeof(double)*(mx));
+	for (j = 0; j < my; j++)
+		for (i = 0; i < mx; i++)
+			si[j][i] = 0.;
-  parm.detin = G_define_option();
-  parm.detin->key = "detin";
-  parm.detin->type = TYPE_STRING;
-  parm.detin->required = YES;
-  parm.detin->gisprompt = "old,cell,raster";
-  parm.detin->description =
-	_("Name of the detachment capacity coefficient raster map");
-  parm.detin->guisection  = _("Input_options");
+	sigma = (double **)G_malloc (sizeof(double *)*(my));
+	for(l=0;l<my;l++)
+		sigma[l]   = (double*)G_malloc (sizeof(double)*(mx));
+			sigma[j][i] = 0.;
-  parm.tranin = G_define_option();
-  parm.tranin->key = "tranin";
-  parm.tranin->type = TYPE_STRING;
-  parm.tranin->required = YES;
-  parm.tranin->gisprompt = "old,cell,raster";
-  parm.tranin->description =
-	_("Name of the transport capacity coefficient raster map");
-  parm.tranin->guisection  = _("Input_options");
+	/* memory allocation for output grids */
-  parm.tauin = G_define_option();
-  parm.tauin->key = "tauin";
-  parm.tauin->type = TYPE_STRING;
-  parm.tauin->required = YES;
-  parm.tauin->gisprompt = "old,cell,raster";
-  parm.tauin->description = _("Name of the critical shear stress raster map");
-  parm.tauin->guisection  = _("Input_options");
+	dif = (float **)G_malloc (sizeof(float *)*(my));
+	for(l=0;l<my;l++)
+		dif[l]   = (float*)G_malloc (sizeof(float)*(mx));
+			dif[j][i] = 0.;
-  parm.manin = G_define_option();
-  parm.manin->key = "manin";
-  parm.manin->type = TYPE_STRING;
-  parm.manin->required = YES;
-  parm.manin->gisprompt = "old,cell,raster";
-  parm.manin->description = _("Name of the Mannings n raster map");
-  parm.manin->guisection  = _("Input_options");
+	if (erdep != NULL || et != NULL)
+		er = (float **)G_malloc (sizeof(float *)*(my));
+		for(l=0;l<my;l++)
+			er[l]   = (float*)G_malloc (sizeof(float)*(mx));
+			er[j][i] = 0.;
-/* needs to be updated to GRASS 6 vector format !! */
-  parm.sfile = G_define_option ();
-  parm.sfile->key = "vector";
-  parm.sfile->type = TYPE_STRING;
-  parm.sfile->required = NO;
-  parm.sfile->gisprompt = "old,vector,vector";
-  parm.sfile->description = _("Name of the vector points map with x,y locations");
-  parm.sfile->guisection  = _("Input_options");
+	/*  if (maskmap != NULL)
+	bitmask = BM_create (cols, rows);
+	IL_create_bitmask (&params, bitmask);
+	seeds(rand1,rand2);
+	grad_check();
-  parm.tc = G_define_option();
-  parm.tc->key = "tc";
-  parm.tc->type = TYPE_STRING;
-  parm.tc->required = NO;
-  parm.tc->gisprompt = "new,cell,raster";
-  parm.tc->description = _("Output transport capacity raster map");
-  parm.tc->guisection  = _("Output_options");
+	if (et != NULL)
+		erod(si);
+	/* treba dat output pre topoerdep */
+	main_loop();
-  parm.et = G_define_option();
-  parm.et->key = "et";
-  parm.et->type = TYPE_STRING;
-  parm.et->required = NO;
-  parm.et->gisprompt = "new,cell,raster";
-  parm.et->description =
-	_("Output transp.limited erosion-deposition raster map");
-  parm.et->guisection  = _("Output_options");
+	if (tserie == NULL) {
+		ii=output_data (0,1.);
+		if (ii != 1)
+			G_fatal_error (_("Cannot write raster maps"));
-  parm.conc = G_define_option();
-  parm.conc->key = "conc";
-  parm.conc->type = TYPE_STRING;
-  parm.conc->required = NO;
-  parm.conc->gisprompt = "new,cell,raster";
-  parm.conc->description = _("Output sediment concentration raster map");
-  parm.conc->guisection  = _("Output_options");
+	if (fdwalkers != NULL)
+		fclose (fdwalkers);
-  parm.flux = G_define_option();
-  parm.flux->key = "flux";
-  parm.flux->type = TYPE_STRING;
-  parm.flux->required = NO;
-  parm.flux->gisprompt = "new,cell,raster";
-  parm.flux->description = _("Output sediment flux raster map");
-  parm.flux->guisection  = _("Output_options");
-  parm.erdep = G_define_option();
-  parm.erdep->key = "erdep";
-  parm.erdep->type = TYPE_STRING;
-  parm.erdep->required = NO;
-  parm.erdep->gisprompt = "new,cell,raster";
-  parm.erdep->description = _("Output erosion-deposition raster map");
-  parm.erdep->guisection  = _("Output_options");
-  parm.nwalk = G_define_option();
-  parm.nwalk->key = "nwalk";
-  parm.nwalk->type = TYPE_INTEGER;
-  parm.nwalk->answer = NWALK;
-  parm.nwalk->required = NO;
-  parm.nwalk->description = _("Number of walkers");
-  parm.nwalk->guisection  = _("Parameters");
-  parm.niter = G_define_option();
-  parm.niter->key = "niter";
-  parm.niter->type = TYPE_INTEGER;
-  parm.niter->answer = NITER;
-  parm.niter->required = NO;
-  parm.niter->description = _("Number of time iterations (sec.)");
-  parm.niter->guisection  = _("Parameters");
-  parm.outiter = G_define_option();
-  parm.outiter->key = "outiter";
-  parm.outiter->type = TYPE_INTEGER;
-  parm.outiter->answer = ITEROUT;
-  parm.outiter->required = NO;
-  parm.outiter->description = _("Time step for saving output maps (sec.)");
-  parm.outiter->guisection  = _("Parameters");
-  parm.density = G_define_option();
-  parm.density->key = "density";
-  parm.density->type = TYPE_INTEGER;
-  parm.density->answer = DENSITY;
-  parm.density->required = NO;
-  parm.density->description = _("Density of output walkers");
-  parm.density->guisection  = _("Parameters");
-  parm.diffc = G_define_option();
-  parm.diffc->key = "diffc";
-  parm.diffc->type = TYPE_DOUBLE;
-  parm.diffc->answer = DIFFC;
-  parm.diffc->required = NO;
-  parm.diffc->description = _("Water diffusion constant");
-  parm.diffc->guisection  = _("Parameters");
-  flag.mscale = G_define_flag ();
-  flag.mscale->key = 'm';
-  flag.mscale->description = _("Multiscale simulation");
-  flag.tserie = G_define_flag ();
-  flag.tserie->key = 't';
-  flag.tserie->description = _("Time-series (dynamic) output");
-  if (G_parser (argc, argv))
-  mscale=flag.mscale->answer ? "m" : NULL;
-  tserie=flag.tserie->answer ? "t" : NULL;
-  elevin = parm.elevin->answer;
-  wdepth = parm.wdepth->answer;
-  dxin = parm.dxin->answer;
-  dyin = parm.dyin->answer;
-/*  maskmap = parm.maskmap->answer;*/
-  detin = parm.detin->answer;
-  tranin = parm.tranin->answer;
-  tauin = parm.tauin->answer;
-  manin = parm.manin->answer;
-  tc = parm.tc->answer;
-  et = parm.et->answer;
-  conc = parm.conc->answer;
-  flux = parm.flux->answer;
-  erdep = parm.erdep->answer;
-  sfile = parm.sfile->answer;
-  sscanf(parm.nwalk->answer, "%d", &maxwa);
-  sscanf(parm.niter->answer, "%d", &timesec);
-  sscanf(parm.outiter->answer, "%d", &iterout);
-  sscanf(parm.density->answer, "%d", &ldemo);
-  sscanf(parm.diffc->answer, "%lf", &frac);
-    rwalk = (double) maxwa;
-  if (conv != 1.0)
-    G_message(_("Using metric conversion factor %f, step=%f"), conv, step);
-   * G_set_embedded_null_value_mode(1);
-  if ((tc == NULL) && (et == NULL) && (conc == NULL) && (flux == NULL) && (erdep == NULL))
-    G_warning(_("You are not outputing any raster or site files"));
-  ret_val = input_data();
-  if (ret_val != 1)
-    G_fatal_error(_("Input failed"));
-/* mandatory for si,sigma */
-   si = (double **)G_malloc (sizeof(double *)*(my));
-       for(l=0;l<my;l++)
-            si[l]   = (double*)G_malloc (sizeof(double)*(mx));
-       for (j = 0; j < my; j++)
-            for (i = 0; i < mx; i++)
-              si[j][i] = 0.;
-   sigma = (double **)G_malloc (sizeof(double *)*(my));
-       for(l=0;l<my;l++)
-            sigma[l]   = (double*)G_malloc (sizeof(double)*(mx));
-              sigma[j][i] = 0.;
-/* memory allocation for output grids */
-        dif = (float **)G_malloc (sizeof(float *)*(my));
-           for(l=0;l<my;l++)
-                dif[l]   = (float*)G_malloc (sizeof(float)*(mx));
-                   dif[j][i] = 0.;
-   if (erdep != NULL || et != NULL)
-        er = (float **)G_malloc (sizeof(float *)*(my));
-           for(l=0;l<my;l++)
-                er[l]   = (float*)G_malloc (sizeof(float)*(mx));
-                   er[j][i] = 0.;
-/*  if (maskmap != NULL)
-    bitmask = BM_create (cols, rows);
-  IL_create_bitmask (&params, bitmask);
-  seeds(rand1,rand2);
-  grad_check();
-  if (et != NULL)
-	erod(si);
-/* treba dat output pre topoerdep */
-/*  fprintf (stdout, "\n Percent complete: ");*/
-  main_loop();
-  if (tserie == NULL) {
-  ii=output_data (0,1.);
-  if (ii != 1)
-    G_fatal_error (_("Cannot write raster maps"));
-  if (fdwalkers != NULL)
-    fclose (fdwalkers);
-  if (sfile != NULL)
-                G_sites_close(fw);
-  exit (EXIT_SUCCESS);
+	if (sfile != NULL)
+		G_sites_close(fw);
+	/* Exit with Success */
+	exit (EXIT_SUCCESS);
