[GRASS-SVN] r30282 - in grass/trunk/lib: . arraystats
svn_grass at osgeo.org
Fri Feb 22 05:17:32 EST 2008
Author: mlennert
Date: 2008-02-22 05:17:32 -0500 (Fri, 22 Feb 2008)
New Revision: 30282
Added:
grass/trunk/lib/arraystats/
grass/trunk/lib/arraystats/Makefile
grass/trunk/lib/arraystats/basic.c
grass/trunk/lib/arraystats/class.c
Beginning of a library of statstics for arrays of doubles
Added: grass/trunk/lib/arraystats/Makefile
--- grass/trunk/lib/arraystats/Makefile (rev 0)
+++ grass/trunk/lib/arraystats/Makefile 2008-02-22 10:17:32 UTC (rev 30282)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+EXTRA_LIBS=$(GISLIB)
+LIB_NAME = $(ARRAYSTATS_LIBNAME)
+include $(MODULE_TOPDIR)/include/Make/Lib.make
+default: lib
Added: grass/trunk/lib/arraystats/basic.c
--- grass/trunk/lib/arraystats/basic.c (rev 0)
+++ grass/trunk/lib/arraystats/basic.c 2008-02-22 10:17:32 UTC (rev 30282)
@@ -0,0 +1,63 @@
+#include <grass/arraystats.h>
+/*provides basic univar stats */
+void basic_stats(double *data, int count, struct GASTATS *stats)
+ int i = 1;
+ double sum = 0, sumsq = 0;
+ double dev = 0, dev2 = 0;
+ stats->count = count;
+ stats->min = data[0];
+ stats->max = data[count - 1];
+ for (i = 0; i < count; i++) {
+ sum += data[i];
+ sumsq += data[i] * data[i];
+ stats->sum = sum;
+ stats->sumsq = sumsq;
+ stats->mean = stats->sum / stats->count;
+ dev2 = dev2 + (data[i] - stats->mean) * (data[i] - stats->mean);
+ dev = dev + (data[i] - stats->mean);
+ stats->var = (dev2 - (dev * dev / stats->count)) / stats->count;
+ stats->stdev = sqrt(stats->var);
+ return;
+void eqdrt(double vectx[], double vecty[], int i1, int i2, double *vabc)
+ double bn = 0, bd = 0, x1 = 0, y1 = 0;
+ vabc[0] = 0;
+ vabc[1] = 0;
+ vabc[2] = 0;
+ if (i1 == 0) {
+ x1 = 0;
+ y1 = 0;
+ else {
+ x1 = vectx[i1];
+ y1 = vecty[i1];
+ bn = y1 - vecty[i2];
+ bd = x1 - vectx[i2];
+ if (bd != 0) {
+ vabc[1] = bn / bd;
+ vabc[0] = y1 - vabc[1] * x1;
+ return;
+ if (bn != 0)
+ vabc[2] = x1;
+ else
+ G_debug(3, "Points are equal\n");
+ return;
Added: grass/trunk/lib/arraystats/class.c
--- grass/trunk/lib/arraystats/class.c (rev 0)
+++ grass/trunk/lib/arraystats/class.c 2008-02-22 10:17:32 UTC (rev 30282)
@@ -0,0 +1,428 @@
+/* functions to classify sorted arrays of doubles and fill a vector of classbreaks */
+int class_interval(double *data, int count, int nbreaks, double *classbreaks)
+ double min, max;
+ double step;
+ int i = 0;
+ min = data[0];
+ max = data[count - 1];
+ step = (max - min) / (nbreaks + 1);
+ for (i = 0; i < nbreaks; i++)
+ classbreaks[i] = min + (step * (i + 1));
+ return (1);
+double class_stdev(double *data, int count, int nbreaks, double *classbreaks)
+ struct GASTATS stats;
+ int i;
+ int nbclass;
+ double scale = 1.0;
+ basic_stats(data, count, &stats);
+ nbclass = nbreaks + 1;
+ if (nbclass % 2 == 1) { /* number of classes is uneven so we center middle class on mean */
+ /* find appropriate fraction of stdev for step */
+ i = 1;
+ while (i) {
+ if (((stats.mean + stats.stdev * scale / 2) +
+ (stats.stdev * scale * (nbclass / 2 - 1)) > stats.max) ||
+ ((stats.mean - stats.stdev * scale / 2) -
+ (stats.stdev * scale * (nbclass / 2 - 1)) < stats.min))
+ scale = scale / 2;
+ else
+ i = 0;
+ /* classbreaks below the mean */
+ for (i = 0; i < nbreaks / 2; i++)
+ classbreaks[i] =
+ (stats.mean - stats.stdev * scale / 2) -
+ stats.stdev * scale * (nbreaks / 2 - (i + 1));
+ /* classbreaks above the mean */
+ for (i = i; i < nbreaks; i++)
+ classbreaks[i] =
+ (stats.mean + stats.stdev * scale / 2) +
+ stats.stdev * scale * (i - nbreaks / 2);
+ else { /* number of classes is even so mean is a classbreak */
+ /* decide whether to use 1*stdev or 0.5*stdev as step */
+ i = 1;
+ while (i) {
+ if (((stats.mean) + (stats.stdev * scale * (nbclass / 2 - 1)) >
+ stats.max) ||
+ ((stats.mean) - (stats.stdev * scale * (nbclass / 2 - 1)) <
+ stats.min))
+ else
+ i = 0;
+ /* classbreaks below the mean and on the mean */
+ for (i = 0; i <= nbreaks / 2; i++)
+ classbreaks[i] =
+ stats.mean - stats.stdev * scale * (nbreaks / 2 - i);
+ classbreaks[i] =
+ stats.mean + stats.stdev * scale * (i - nbreaks / 2);
+ return (scale);
+int class_quant(double *data, int count, int nbreaks, double *classbreaks)
+ int i, step;
+ step = count / (nbreaks + 1);
+ classbreaks[i] = data[step * (i + 1)];
+ return (1);
+int class_equiprob(double *data, int count, int *nbreaks, double *classbreaks)
+ int i, j;
+ double *lequi; /*Vector of scale factors for probabilities of the normal distribution */
+ int nbclass;
+ nbclass = *nbreaks + 1;
+ lequi = G_malloc(*nbreaks * sizeof(double));
+ /*The following values come from the normal distribution and
+ * will be used as:
+ * classbreak[i] = (lequi[i] * stdev) + mean;
+ if (nbclass < 3) {
+ lequi[0] = 0;
+ else if (nbclass == 3) {
+ lequi[0] = -0.43076;
+ lequi[1] = 0.43076;
+ else if (nbclass == 4) {
+ lequi[0] = -0.6745;
+ lequi[1] = 0;
+ lequi[2] = 0.6745;
+ else if (nbclass == 5) {
+ lequi[0] = -0.8416;
+ lequi[1] = -0.2533;
+ lequi[2] = 0.2533;
+ lequi[3] = 0.8416;
+ else if (nbclass == 6) {
+ lequi[0] = -0.9676;
+ lequi[1] = -0.43076;
+ lequi[2] = 0;
+ lequi[3] = 0.43076;
+ lequi[4] = 0.9676;
+ else if (nbclass == 7) {
+ lequi[0] = -1.068;
+ lequi[1] = -0.566;
+ lequi[2] = -0.18;
+ lequi[3] = 0.18;
+ lequi[4] = 0.566;
+ lequi[5] = 1.068;
+ else if (nbclass == 8) {
+ lequi[0] = -1.1507;
+ lequi[1] = -0.6745;
+ lequi[2] = -0.3187;
+ lequi[3] = 0;
+ lequi[4] = 0.3187;
+ lequi[5] = 0.6745;
+ lequi[6] = 1.1507;
+ else if (nbclass == 9) {
+ lequi[0] = -1.2208;
+ lequi[1] = -0.7648;
+ lequi[2] = -0.4385;
+ lequi[3] = -0.1397;
+ lequi[4] = 0.1397;
+ lequi[5] = 0.4385;
+ lequi[6] = 0.7648;
+ lequi[7] = 1.2208;
+ else if (nbclass == 10) {
+ lequi[0] = -1.28155;
+ lequi[1] = -0.84162;
+ lequi[2] = -0.5244;
+ lequi[3] = -0.25335;
+ lequi[4] = 0;
+ lequi[5] = 0.25335;
+ lequi[6] = 0.5244;
+ lequi[7] = 0.84162;
+ lequi[8] = 1.28155;
+ else {
+ G_fatal_error
+ ("Equiprobable classbreaks currently limited to 10 classes");
+ /*check if any of the classbreaks would fall outside of the range min-max */
+ j = 0;
+ for (i = 0; i < *nbreaks; i++) {
+ if ((lequi[i] * stats.stdev + stats.mean) >= stats.min &&
+ (lequi[i] * stats.stdev) + stats.mean <= stats.max) {
+ j++;
+ if (j < (*nbreaks)) {
+ G_warning(_
+ ("There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."),
+ j + 1, *nbreaks + 1);
+ G_realloc(classbreaks, j * sizeof(double));
+ for (i = 0; i < j; i++)
+ classbreaks[i] = 0;
+ j = 0;
+ classbreaks[j] = lequi[i] * stats.stdev + stats.mean;
+ j++;
+ *nbreaks = j;
+ G_free(lequi);
+ return (1);
+double class_discont(double *data, int count, int nbreaks, double *classbreaks)
+ int *num, nbclass, maxclass = 0;
+ double *no, *zz, *nz, *xn, *co;
+ double *x; //Vecteur des observations standardisées
+ int i, j, k;
+ double min = 0, max = 0, rangemax = 0;
+ int n = 0;
+ double rangemin = 0, xlim = 0;
+ double dmax = 0.0, d2 = 0.0, dd = 0.0, p = 0.0;
+ int nf = 0, nmax = 0;
+ double *abc;
+ int nd = 0;
+ double den = 0, d = 0;
+ int im = 0, ji = 0;
+ int tmp = 0;
+ int nff = 0, jj = 0, no1 = 0, no2 = 0;
+ double f = 0, xt1 = 0, xt2 = 0, chi2 = 0, xnj_1 = 0, xj_1 = 0;
+ /*get the number of values */
+ n = count;
+ num = G_malloc((nbclass + 1) * sizeof(int));
+ no = G_malloc((nbclass + 1) * sizeof(double));
+ zz = G_malloc((nbclass + 1) * sizeof(double));
+ nz = G_malloc(3 * sizeof(double));
+ xn = G_malloc((n + 1) * sizeof(double));
+ co = G_malloc((nbclass + 1) * sizeof(double));
+ /* We copy the array of values to x, in order to be able to standardize it */
+ x = G_malloc((n + 1) * sizeof(double));
+ x[0] = n;
+ xn[0] = 0;
+ min = data[0];
+ for (i = 1; i <= n; i++)
+ x[i] = data[i - 1];
+ rangemax = max - min;
+ rangemin = rangemax;
+ for (i = 2; i <= n; i++) {
+ if (x[i] != x[i - 1] && x[i] - x[i - 1] < rangemin)
+ rangemin = x[i] - x[i - 1]; /* rangemin = minimal distance */
+ /* STANDARDIZATION
+ * and creation of the number vector (xn) */
+ for (i = 1; i <= n; i++) {
+ x[i] = (x[i] - min) / rangemax;
+ xn[i] = i / (double)n;
+ xlim = rangemin / rangemax;
+ rangemin = rangemin / 2.0;
+ /* Searching for the limits */
+ num[1] = n;
+ abc = G_malloc(3 * sizeof(double));
+ /* Loop through possible solutions */
+ for (i = 1; i <= nbclass; i++) {
+ nmax = 0;
+ dmax = 0.0;
+ d2 = 0.0;
+ nf = 0; /*End number */
+ /* Loop through classes */
+ for (j = 1; j <= i; j++) {
+ nd = nf; /*Start number */
+ nf = num[j];
+ co[j] = 10e37;
+ eqdrt(x, xn, nd, nf, abc);
+ den = sqrt(pow(abc[1], 2) + 1.0);
+ nd++;
+ /* Loop through observations */
+ for (k = nd; k <= nf; k++) {
+ if (abc[2] == 0.0)
+ d = fabs((-1.0 * abc[1] * x[k]) + xn[k] - abc[0]) / den;
+ else
+ d = fabs(x[k] - abc[2]);
+ d2 += pow(d, 2);
+ if (x[k] - x[nd] < xlim)
+ continue;
+ if (x[nf] - x[k] < xlim)
+ continue;
+ if (d <= dmax)
+ continue;
+ dmax = d;
+ nmax = k;
+ nd--; //A VERIFIER!
+ if (x[nf] != x[nd]) {
+ if (nd != 0)
+ co[j] = (xn[nf] - xn[nd]) / (x[nf] - x[nd]);
+ else
+ co[j] = (xn[nf]) / (x[nf]); //A VERIFIER!
+ if (i == 1)
+ dd = d2;
+ p = d2 / dd;
+ no[j] = num[j];
+ zz[j] = x[num[j]] * rangemax + min;
+ if (j == i)
+ continue;
+ if (co[j] > co[j + 1]) {
+ zz[j] = zz[j] + rangemin;
+ continue;
+ zz[j] = zz[j] - rangemin;
+ no[j] = no[j] - 1;
+ im = i - 1;
+ if (im != 0.0) {
+ for (j = 1; j <= im; j++) {
+ ji = i + 1 - j;
+ no[ji] -= no[ji - 1];
+ if (nmax == 0) {
+ break;
+ nff = i + 2;
+ tmp = 0;
+ jj = nff - j;
+ if (num[jj - 1] < nmax) {
+ num[jj] = nmax;
+ tmp = 1;
+ break;
+ num[jj] = num[jj - 1];
+ if (tmp == 0) {
+ num[1] = nmax;
+ jj = 1;
+ if (jj == 1) {
+ xnj_1 = 0;
+ xj_1 = 0;
+ else {
+ xnj_1 = xn[num[jj - 1]];
+ xj_1 = x[num[jj - 1]];
+ no1 = (xn[num[jj]] - xnj_1) * n;
+ no2 = (xn[num[jj + 1]] - xn[num[jj]]) * n;
+ f = (xn[num[jj + 1]] - xnj_1) / (x[num[jj + 1]] - xj_1);
+ f *= n;
+ xt1 = (x[num[jj]] - xj_1) * f;
+ xt2 = (x[num[jj + 1]] - x[num[jj]]) * f;
+ if (xt2 == 0) {
+ xt2 = rangemin / 2.0 / rangemax * f;
+ xt1 -= xt2;
+ else if (xt1 * xt2 == 0) {
+ xt1 = rangemin / 2.0 / rangemax * f;
+ xt2 -= xt1;
+ /*if new class break not statistically significant (alpha > 0.05), give warning */
+ if (maxclass == 0) {
+ chi2 = pow((double)((no1 - no2) - (xt1 - xt2)), 2) / (xt1 + xt2);
+ if (chi2 < 3.84148) {
+ G_warning(_
+ ("discontinuities algorithm: %i class breaks or more are not statistically significant at alpha=0.05"),
+ i);
+ maxclass = 1;
+ /* Fill up classbreaks of i <=nbclass classes */
+ for (j = 0; j <= (i - 1); j++)
+ classbreaks[j] = zz[j + 1];
+ return (chi2);
+int class_frequencies(double *data, int count, int nbreaks,
+ double *classbreaks, int *frequencies)
+ int i, j;
+ double min, max;
+ min = data[0];
+ /* count cases in all classes, except for last class */
+ i = 0;
+ for (j = 0; j < nbreaks; j++) {
+ while (data[i] <= classbreaks[j]) {
+ frequencies[j]++;
+ i++;
+ /*Now count cases in last class */
+ for (i = i; i < count; i++) {
+ frequencies[nbreaks]++;
+ return (1);
