[GRASS-SVN] r30303 - grass/trunk/lib/vector/vedit
Sat Feb 23 12:24:10 EST 2008
Author: martinl
Date: 2008-02-23 12:24:09 -0500 (Sat, 23 Feb 2008)
New Revision: 30303
Removed:
   grass/trunk/lib/vector/vedit/vedit.h
vedit.h header already moved to include
Deleted: grass/trunk/lib/vector/vedit/vedit.h
--- grass/trunk/lib/vector/vedit/vedit.h	2008-02-23 17:16:19 UTC (rev 30302)
+++ grass/trunk/lib/vector/vedit/vedit.h	2008-02-23 17:24:09 UTC (rev 30303)
@@ -1,86 +0,0 @@
-#ifndef __VEDIT_H__
-#define __VEDIT_H__
-#include <grass/gis.h>
-#include <grass/Vect.h>
-#include <grass/glocale.h>
-#define NO_SNAP    0 /* snapping disabled */
-#define SNAP       1 /* snapping enabled for nodes */
-#define SNAPVERTEX 2 /* snapping enabled for vertex also */
-#define QUERY_UNKNOWN -1
-#define QUERY_LENGTH   0 /* select by line length */
-#define QUERY_DANGLE   1 /* select dangles */
-/* break.c */
-int Vedit_split_lines(struct Map_info *, struct ilist *,
-		      struct line_pnts *, double,
-		      struct ilist *);
-int Vedit_connect_lines (struct Map_info *, struct ilist *,
-			 double);
-/* cats.c */
-int Vedit_modify_cats (struct Map_info *, struct ilist *,
-		       int, int, struct cat_list *);
-/* copy.c */
-int Vedit_copy_lines (struct Map_info *, struct Map_info *,
-		      struct ilist *);
-/* chtype.c */
-int Vedit_chtype_lines(struct Map_info *, struct ilist *,
-		       int *, int *, int *, int *);
-/* delete.c */
-int Vedit_delete_lines(struct Map_info *, struct ilist *);
-/* distance.c */
-double Vedit_get_min_distance(struct line_pnts *, struct line_pnts *,
-			      int, int *);
-/* flip.c */
-int Vedit_flip_lines(struct Map_info *, struct ilist *);
-/* merge.c */
-int Vedit_merge_lines(struct Map_info *, struct ilist *);
-/* move.c */
-int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
-		     struct ilist *,
-		     double, double, double, int, double);
-/* select.c */
-int Vedit_select_by_query(struct Map_info *,
-			  int, int, double, int,
-			  struct ilist *);
-/* snap.c */
-int Vedit_snap_point(struct Map_info *,
-		     int, double *, double *, double *, double,
-		     int);
-int Vedit_snap_line(struct Map_info *, struct Map_info **, int,
-		    int, struct line_pnts *,
-		    double, int);
-int Vedit_snap_lines(struct Map_info *, struct Map_info **, int,
-		     struct ilist*,
-		     double, int);
-/* vertex.c */
-int Vedit_move_vertex(struct Map_info *, struct Map_info **, int,
-		      struct ilist *,
-		      struct line_pnts*, double,
-		      int, int);
-int Vedit_add_vertex(struct Map_info *Map, struct ilist *,
-		     struct line_pnts*, double);
-int Vedit_remove_vertex(struct Map_info *, struct ilist *,
-			struct line_pnts *, double);
-/* zbulk.c */
-int Vedit_bulk_labeling (struct Map_info *, struct ilist *,
-			 double, double, double, double,
-			 double, double);
-#endif /* __VEDIT_H__ */
