[GRASS-SVN] r30312 - grass-addons/vector/v.colors
svn_grass at osgeo.org
Sat Feb 23 19:34:58 EST 2008
Author: hamish
Date: 2008-02-23 19:34:58 -0500 (Sat, 23 Feb 2008)
New Revision: 30312
grass-addons/vector/v.colors/v.colors
SQL columns names are case-insensitive
Modified: grass-addons/vector/v.colors/v.colors
--- grass-addons/vector/v.colors/v.colors 2008-02-23 20:06:53 UTC (rev 30311)
+++ grass-addons/vector/v.colors/v.colors 2008-02-24 00:34:58 UTC (rev 30312)
@@ -192,7 +192,7 @@
#### column checks
# check input data column
-NCOLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep "|$GIS_OPT_COLUMN$" | cut -f1 -d'|'`
+NCOLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep -i "|$GIS_OPT_COLUMN$" | cut -f1 -d'|'`
if [ -z "$NCOLUMN_TYPE" ] ; then
echo "ERROR: Column <$GIS_OPT_COLUMN> not found"
exit 1
@@ -204,7 +204,7 @@
# check if GRASSRGB column exists, make it if it doesn't
TABLE=`v.db.connect -g map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | cut -f2 -d' '`
-COLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep "|$GIS_OPT_RGB_COLUMN$" | cut -f1 -d'|'`
+COLUMN_TYPE=`v.info -c map="$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | grep -i "|$GIS_OPT_RGB_COLUMN$" | cut -f1 -d'|'`
if [ -z "$COLUMN_TYPE" ] ; then
# RGB Column not found, create it
echo "Creating column <$GIS_OPT_RGB_COLUMN> ..."
@@ -217,7 +217,7 @@
echo "ERROR: Column <$GIS_OPT_RGB_COLUMN> is not of compatible type"
exit 1
else
- NUM_CHARS=`db.describe -c "$TABLE" | grep " $GIS_OPT_RGB_COLUMN:" | cut -f4 -d':'`
+ NUM_CHARS=`db.describe -c "$TABLE" | grep -i " $GIS_OPT_RGB_COLUMN:" | cut -f4 -d':'`
if [ "$NUM_CHARS" -lt 11 ] ; then
echo "ERROR: Color column <$GIS_OPT_RGB_COLUMN> is not wide enough (needs 11 characters)"
exit 1
