[GRASS-SVN] r30318 - grass/trunk/raster/r.quantile
svn_grass at osgeo.org
Sun Feb 24 03:23:05 EST 2008
Author: glynn
Date: 2008-02-24 03:23:04 -0500 (Sun, 24 Feb 2008)
New Revision: 30318
grass/trunk/raster/r.quantile/main.c
Add percentiles= option
Modified: grass/trunk/raster/r.quantile/main.c
--- grass/trunk/raster/r.quantile/main.c 2008-02-24 05:55:36 UTC (rev 30317)
+++ grass/trunk/raster/r.quantile/main.c 2008-02-24 08:23:04 UTC (rev 30318)
@@ -25,7 +25,8 @@
static int rows, cols;
static DCELL min, max;
-static int num_quant;
+static int num_quants;
+static DCELL *quants;
static int num_slots;
static unsigned int *slots;
static DCELL slot_size;
@@ -48,7 +49,7 @@
static inline double get_quantile(int n)
- return (double) total * n / num_quant;
+ return (double) total * quants[n];
static void get_slot_counts(int infile)
@@ -90,7 +91,7 @@
double next;
int bin = 0;
unsigned long accum = 0;
- int quant = 1;
+ int quant = 0;
G_message(_("Computing bins"));
@@ -196,7 +197,7 @@
struct bin *b = &bins[0];
int quant;
- for (quant = 1; quant < num_quant; quant++)
+ for (quant = 0; quant < num_quants; quant++)
double next = get_quantile(quant);
double k, v;
@@ -213,7 +214,7 @@
? values[b->base + i0]
: values[b->base + i0] * (i1 - k) + values[b->base + i1] * (k - i0);
- printf("%2d: %f\n", quant, v);
+ printf("%d:%f:%f\n", quant, 100 * quants[quant], v);
@@ -221,7 +222,7 @@
struct GModule *module;
struct {
- struct Option *input, *quant, *slots;
+ struct Option *input, *quant, *perc, *slots;
} opt;
int infile;
struct FPRange range;
@@ -242,6 +243,13 @@
opt.quant->description = _("Number of quantiles");
opt.quant->answer = "4";
+ opt.perc = G_define_option();
+ opt.perc->key = "percentiles";
+ opt.perc->type = TYPE_DOUBLE;
+ opt.perc->required = NO;
+ opt.perc->multiple = YES;
+ opt.perc->description = _("List of percentiles");
opt.slots = G_define_option();
opt.slots->key = "bins";
opt.slots->type = TYPE_INTEGER;
@@ -252,9 +260,28 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- num_quant = atoi(opt.quant->answer);
num_slots = atoi(opt.slots->answer);
+ if (opt.perc->answer)
+ int i;
+ for (i = 0; opt.perc->answers[i]; i++)
+ num_quants = i;
+ quants = G_calloc(num_quants, sizeof(DCELL));
+ for (i = 0; i < num_quants; i++)
+ quants[i] = atof(opt.perc->answers[i]) / 100;
+ qsort(quants, num_quants, sizeof(DCELL), compare_dcell);
+ else
+ int i;
+ num_quants = atoi(opt.quant->answer) - 1;
+ quants[i] = 1.0 * (i + 1) / (num_quants + 1);
infile = G_open_cell_old(opt.input->answer, "");
if (infile < 0)
G_fatal_error(_("Unable to open raster map <%s>"), opt.input->answer);
@@ -272,7 +299,7 @@
get_slot_counts(infile);
- bins = G_calloc(num_quant, sizeof(struct bin));
+ bins = G_calloc(num_quants, sizeof(struct bin));
initialize_bins();
G_free(slots);
