[GRASS-SVN] r30323 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Sun Feb 24 07:33:47 EST 2008
Author: martinl
Date: 2008-02-24 07:33:47 -0500 (Sun, 24 Feb 2008)
New Revision: 30323
grass/trunk/gui/wxpython/gui_modules/rules.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: fixing #59 (r.colors in wxpython gui fails)
Modified: grass/trunk/gui/wxpython/gui_modules/rules.py
--- grass/trunk/gui/wxpython/gui_modules/rules.py 2008-02-24 12:32:57 UTC (rev 30322)
+++ grass/trunk/gui/wxpython/gui_modules/rules.py 2008-02-24 12:33:47 UTC (rev 30323)
@@ -17,14 +17,16 @@
-import wx
import os
import sys
+import wx
+import gcmd
import gselect
class RulesText(wx.Dialog):
- def __init__(self, parent, id=wx.ID_ANY, title="Enter rules",
+ def __init__(self, parent, id=wx.ID_ANY, title=_("Enter rules"),
pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.DEFAULT_DIALOG_STYLE,
cmd=None):
@@ -33,6 +35,8 @@
Dialog for interactively entering rules
for map management commands
+ @param cmd command (given as list)
self.parent = parent
self.cmd = cmd # map management command
@@ -41,97 +45,89 @@
self.rules = '' # rules for changing
self.overwrite = False
- if self.cmd == 'r.colors':
- label1 = 'Create new color table using color rules'
- label2 = 'Raster map:'
+ if self.cmd[0] == 'r.colors':
+ label1 = _('Create new color table using color rules')
+ label2 = _('Raster map:')
label3 = None
- label4 = 'Enter color rules'
+ label4 = _('Enter color rules')
seltype = 'cell'
- elif self.cmd == 'r.reclass':
- label1 = 'Reclassify raster map using rules'
- label2 = 'Map to reclassify:'
- label3 = 'Reclassified map:'
- label4 = 'Enter reclassification rules'
+ elif self.cmd[0] == 'r.reclass':
+ label1 = _('Reclassify raster map using rules')
+ label2 = _('Map to reclassify:')
+ label3 = _('Reclassified map:')
+ label4 = _('Enter reclassification rules')
seltype = 'cell'
- elif self.cmd == 'r.recode':
- label1 = 'Recode raster map using rules'
- label2 = 'Map to recode:'
- label3 = 'Recoded map:'
- label4 = 'Enter recoding rules'
+ elif self.cmd[0] == 'r.recode':
+ label1 = _('Recode raster map using rules')
+ label2 = _('Map to recode:')
+ label3 = _('Recoded map:')
+ label4 = _('Enter recoding rules')
seltype = 'cell'
- elif self.cmd == 'v.reclass':
- label1 = 'Reclassify vector map using SQL rules'
+ elif self.cmd[0] == 'v.reclass':
+ label1 = _('Reclassify vector map using SQL rules')
seltype = 'vector'
+ # set window frame title
+ self.SetTitle(label1)
sizer = wx.BoxSizer(wx.VERTICAL)
+ boxSizer = wx.GridBagSizer(hgap=5, vgap=5)
+ boxSizer.AddGrowableCol(0)
- box = wx.BoxSizer(wx.HORIZONTAL)
- label = wx.StaticText(self, wx.ID_ANY, label1)
- box.Add(label, 0, wx.ALIGN_CENTRE|wx.ALL, 5)
- sizer.Add(item=box, proportion=0,
- flag=wx.ALIGN_CENTER|
- wx.ALL,border=5)
+ row = 0
+ boxSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=label2),
+ flag=wx.ALIGN_CENTER_VERTICAL,
+ pos=(row,0))
- label = wx.StaticText(self, wx.ID_ANY, label2)
- box.Add(label, 0, wx.ALIGN_RIGHT|wx.ALL, 5)
- self.selection = gselect.Select(self, id=wx.ID_ANY, size=(300,-1),
- type=seltype)
- box.Add(self.selection, 0, wx.ALIGN_RIGHT|wx.ALL, 5)
- flag=wx.ALIGN_CENTER_VERTICAL|
- wx.ALIGN_RIGHT|
- wx.ALL,border=5)
+ self.selectionInput = gselect.Select(parent=self, id=wx.ID_ANY, size=(300,-1),
+ type=seltype)
+ boxSizer.Add(item=self.selectionInput,
+ pos=(row,1))
+ row += 1
- if cmd != 'r.colors':
- label = wx.StaticText(self, wx.ID_ANY, label3)
- self.textentry = wx.TextCtrl(self, wx.ID_ANY, "", size=(300,-1))
- box.Add(self.textentry, 0, wx.ALIGN_RIGHT|wx.ALL, 5)
- self.textentry.Bind(wx.EVT_TEXT, self.OnText)
- wx.ALIGN_RIGHT|
- wx.ALL,border=5)
+ if self.cmd[0] != 'r.colors':
+ boxSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=label3),
+ pos=(row, 0))
+ self.selectionOutput = gselect.Select(parent=self, id=wx.ID_ANY, size=(300,-1),
+ type=seltype)
+ self.selectionOutput.Bind(wx.EVT_TEXT, self.OnSelectionOutput)
+ boxSizer.Add(item=self.selectionOutput,
+ pos=(row,1))
+ row += 1
- self.ovrwrtcheck = wx.CheckBox(self, wx.ID_ANY, 'overwrite existing file')
+ self.ovrwrtcheck = wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('overwrite existing file'))
self.ovrwrtcheck.SetValue(self.overwrite)
- box.Add(self.ovrwrtcheck, 0, wx.ALIGN_CENTRE|wx.ALL, 5)
- wx.ALIGN_RIGHT|
- wx.ALL,border=5)
+ boxSizer.Add(item=self.ovrwrtcheck,
+ pos=(row, 1))
self.Bind(wx.EVT_CHECKBOX, self.OnOverwrite, self.ovrwrtcheck)
+ row += 1
- label = wx.StaticText(self, wx.ID_ANY, label4)
- helpbtn = wx.Button(self, wx.ID_ANY, "Help")
- box.Add(helpbtn, 0, wx.ALIGN_CENTRE|wx.ALL, 5)
- wx.ALL,border=5)
+ boxSizer.Add(item=wx.StaticText(parent=self, id=wx.ID_ANY, label=label4),
+ pos=(row, 0))
+ helpbtn = wx.Button(parent=self, id=wx.ID_HELP)
+ boxSizer.Add(item=helpbtn, flag=wx.ALIGN_RIGHT, pos=(row, 1))
+ row += 1
- self.rulestxt = wx.TextCtrl(self, id=wx.ID_ANY, value='',
+ self.rulestxt = wx.TextCtrl(parent=self, id=wx.ID_ANY, value='',
pos=wx.DefaultPosition, size=(400,150),
- style=wx.TE_MULTILINE|
- wx.HSCROLL|
+ style=wx.TE_MULTILINE |
+ wx.HSCROLL |
wx.TE_NOHIDESEL)
self.rulestxt.SetFont(wx.Font(10, wx.FONTFAMILY_MODERN, wx.NORMAL, wx.NORMAL, 0, ''))
- box.Add(self.rulestxt, 0, wx.ALIGN_CENTRE|wx.ALL, 5)
- wx.ALL,border=5)
+ boxSizer.Add(item=self.rulestxt, pos=(row, 0), flag=wx.EXPAND, span=(1, 2))
- line = wx.StaticLine(self, -1, size=(20,-1), style=wx.LI_HORIZONTAL)
- sizer.Add(line, 0, wx.GROW|wx.ALIGN_CENTER_VERTICAL|wx.RIGHT|wx.TOP, 5)
+ sizer.Add(item=boxSizer, proportion=1,
+ flag=wx.ALL ,border=10)
+ line = wx.StaticLine(parent=self, id=wx.ID_ANY, size=(20,-1), style=wx.LI_HORIZONTAL)
+ sizer.Add(item=line, proportion=0,
+ flag=wx.GROW | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=5)
btnsizer = wx.StdDialogButtonSizer()
btn = wx.Button(self, wx.ID_OK)
@@ -142,28 +138,32 @@
btnsizer.AddButton(btn)
btnsizer.Realize()
- sizer.Add(btnsizer, 0, wx.ALIGN_CENTER_VERTICAL|wx.ALL, 5)
+ sizer.Add(item=btnsizer, proportion=0,
+ flag=wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border=5)
self.SetSizer(sizer)
sizer.Fit(self)
+ # bindings
self.Bind(wx.EVT_BUTTON, self.OnHelp, helpbtn)
- self.selection.Bind(wx.EVT_TEXT, self.OnSelection)
+ self.selectionInput.Bind(wx.EVT_TEXT, self.OnSelectionInput)
self.Bind(wx.EVT_TEXT, self.OnRules, self.rulestxt)
- def OnSelection(self, event):
+ def OnSelectionInput(self, event):
self.inmap = event.GetString()
- def OnText(self, event):
+ def OnSelectionOutput(self, event):
self.outmap = event.GetString()
def OnRules(self, event):
self.rules = event.GetString().strip()
- if self.cmd == 'r.recode':
- self.rules = self.rules+'\n'
+ if self.cmd[0] == 'r.recode':
+ self.rules = self.rules + '%s' % os.linesep
def OnHelp(self, event):
- os.popen('g.manual --quiet %s ' % self.cmd)
+ gcmd.Command(['g.manual',
+ '--quiet',
+ '%s' % self.cmd[0]])
def OnOverwrite(self, event):
self.overwrite = event.IsChecked()
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-02-24 12:32:57 UTC (rev 30322)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-02-24 12:33:47 UTC (rev 30323)
@@ -789,26 +789,32 @@
input and processes rules
command = self.GetMenuCmd(event)
dlg = rules.RulesText(self, cmd=command)
if dlg.ShowModal() == wx.ID_OK:
gtemp = utils.GetTempfile()
- output = open(gtemp,"w")
+ output = open(gtemp, "w")
try:
output.write(dlg.rules)
finally:
output.close()
- if command == 'r.colors':
- cmdlist = [command,'map=%s' % dlg.inmap,'rules=%s' % gtemp,'--verbose']
+ if command[0] == 'r.colors':
+ cmdlist = [command[0],
+ 'map=%s' % dlg.inmap,
+ 'rules=%s' % gtemp]
else:
- cmdlist = [command,'input=%s' % dlg.inmap,'output=%s' % dlg.outmap,'rules=%s' % gtemp]
+ 'input=%s' % dlg.inmap,
+ 'output=%s' % dlg.outmap,
if dlg.overwrite == True:
cmdlist.append('--o')
- gcmd.Command(cmdlist, verbose=3)
+ dlg.Destroy()
- dlg.Destroy()
+ self.goutput.RunCmd(cmdlist)
def OnXTerm(self, event):
