[GRASS-SVN] r30365 - in grass/trunk/gui/wxpython: . gui_modules
svn_grass at osgeo.org
Tue Feb 26 16:20:43 EST 2008
Author: martinl
Date: 2008-02-26 16:20:43 -0500 (Tue, 26 Feb 2008)
New Revision: 30365
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_modules/dbm.py
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/location_wizard.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: message cleaning, use named arguments
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2008-02-26 20:36:32 UTC (rev 30364)
+++ grass/trunk/gui/wxpython/gis_set.py 2008-02-26 21:20:43 UTC (rev 30365)
@@ -451,10 +451,11 @@
location = self.listOfLocations[self.lblocations.GetSelection()]
mapset = self.listOfMapsets[self.lbmapsets.GetSelection()]
- dlg = wx.MessageDialog(parent=self, message=_("Do you want to continue with deleting mapset <%s> "
- "from location <%s>?\n\n"
+ dlg = wx.MessageDialog(parent=self, message=_("Do you want to continue with deleting mapset <%(mapset)s> "
+ "from location <%(location)s>?\n\n"
"ALL MAPS included in this mapset will be "
- "PERMANENTLY DELETED!") % (mapset, location),
+ "PERMANENTLY DELETED!") % {'mapset' : mapset,
+ 'location' : location},
caption=_("Delete selected mapset"),
style=wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
Modified: grass/trunk/gui/wxpython/gui_modules/dbm.py
--- grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-02-26 20:36:32 UTC (rev 30364)
+++ grass/trunk/gui/wxpython/gui_modules/dbm.py 2008-02-26 21:20:43 UTC (rev 30365)
@@ -490,7 +490,7 @@
panel = wx.Panel(parent=self.browsePage, id=wx.ID_ANY)
self.layerPage[layer] = {'browsePage': panel.GetId()}
- self.browsePage.AddPage(page=panel, text=_(" %s %d ") % (_("Layer"), layer))
+ self.browsePage.AddPage(page=panel, text=" %s %d " % (_("Layer"), layer))
pageSizer = wx.BoxSizer(wx.VERTICAL)
@@ -630,7 +630,7 @@
panel = wx.Panel(parent=self.manageTablePage, id=wx.ID_ANY)
self.layerPage[layer]['tablePage'] = panel.GetId()
- self.manageTablePage.AddPage(page=panel, text=_(" %s %d ") % (_("Layer"), layer))
+ self.manageTablePage.AddPage(page=panel, text=" %s %d " % (_("Layer"), layer))
@@ -1073,9 +1073,9 @@
try:
values[i] = list.columns[columnName[i]]['ctype'] (values[i])
except:
- raise ValueError(_("Casting value '%s' to %s failed.") % \
- (str(values[i]),
- list.columns[columnName[i]]['type']))
+ raise ValueError(_("Casting value '%(value)s' to %(type)s failed.") %
+ {'value' : str(values[i]),
+ 'type' : list.columns[columnName[i]]['type']})
columnsString += '%s,' % columnName[i]
if list.columns[columnName[i]]['ctype'] == str:
valuesString += "'%s'," % values[i]
@@ -1084,8 +1084,8 @@
except ValueError, err:
wx.MessageBox(parent=self,
- message=_("Unable to insert new record.%s"
- "%s") % (os.linesep, err),
+ message="%s%s%s" % (_("Unable to insert new record."),
+ os.linesep, err),
caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
return
@@ -1170,9 +1170,9 @@
list.itemDataMap[item][idx] = \
except:
- (str(values[i]),
+ raise ValueError(_("Casting value '%(value)s' to %(type)s failed.") % \
updateString += "%s='%s'," % (columnName[i], values[i])
@@ -1183,8 +1183,8 @@
- message=_("Unable to update existing record.%s"
+ message="%s%s%s" % (_("Unable to update existing record."),
+ os.linesep, err),
return
@@ -1271,9 +1271,10 @@
if item > -1:
if list.FindItem(start=-1, str=nameTo) > -1:
- message=_("Unable to rename column <%s>. "
- "Column <%s> already exists in the table <%s>.") % \
- (name, nameTo, self.mapDBInfo.layers[self.layer]["table"]),
+ message=_("Unable to rename column <%(column)s>. "
+ "Column <%(columnTo)s> already exists in the table <%(table)s>.") % \
+ {'column' : name, 'columnTo' : nameTo,
+ 'table' : self.mapDBInfo.layers[self.layer]["table"]},
else:
list.SetItemText(item, nameTo)
@@ -1285,8 +1286,8 @@
else:
message=_("Unable to rename column. "
- "Column <%s> doesn't exist in the table <%s>.") % \
- (name, self.mapDBInfo.layers[self.layer]["table"]),
+ "Column <%(column)s> doesn't exist in the table <%(table)s>.") %
+ {'column' : name, 'table' : self.mapDBInfo.layers[self.layer]["table"]},
event.Skip()
@@ -1370,8 +1371,8 @@
# check for duplicate items
if list.FindItem(start=-1, str=name) > -1:
- message=_("Column <%s> already exists in table <%s>.") % \
+ message=_("Column <%(column)s> already exists in table <%(table)s>.") % \
return
index = list.InsertStringItem(sys.maxint, str(name))
@@ -2495,9 +2496,9 @@
if layer in self.mapDBInfo.layers.keys():
- message=_("Unable to add new layer to vector map <%s>.%s"
- "Layer %d already exists.") % \
- (self.mapDBInfo.map, os.linesep, layer),
+ message=_("Unable to add new layer to vector map <%(vector)s>.\n"
+ "Layer %(layer)d already exists.") %
+ {'vector' : self.mapDBInfo.map, 'layer' : layer},
return
@@ -2677,11 +2678,11 @@
wx.MessageBox(parent=self.parent,
message=_("No attribute table linked to "
- "vector map <%s> found. %s "
- "%sYou can disable this message from digitization settings. Or "
+ "vector map <%(vector)s> found. %(msg)s "
+ "\nYou can disable this message from digitization settings. Or "
"you can create and link attribute table to the vector map "
- "using Attribute Table Manager.") % \
- (self.map, label, os.linesep),
+ "using Attribute Table Manager.") %
+ {'vector' : self.map, 'msg' : label},
caption=_("Message"), style=wx.OK | wx.ICON_EXCLAMATION | wx.CENTRE)
self.mapDBInfo = None
return
@@ -2915,7 +2916,7 @@
size=(-1, 150))
panel.SetupScrolling(scroll_x=False)
- self.notebook.AddPage(page=panel, text=_(" %s %d ") % (_("Layer"), layer))
+ self.notebook.AddPage(page=panel, text=" %s %d " % (_("Layer"), layer))
# notebook body
border = wx.BoxSizer(wx.VERTICAL)
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-26 20:36:32 UTC (rev 30364)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-02-26 21:20:43 UTC (rev 30365)
@@ -1508,9 +1508,9 @@
vertexSizer.Add(item=self.snapVertex, proportion=0, flag=wx.EXPAND)
self.mapUnits = self.parent.MapWindow.Map.ProjInfo()['units']
self.snappingInfo = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label=_("Snapping threshold is %.1f %s") % \
- (self.parent.digit.driver.GetThreshold(),
- self.mapUnits))
+ label=_("Snapping threshold is %(value).1f %(units)s") % \
+ {'value' : self.parent.digit.driver.GetThreshold(),
+ 'units' : self.mapUnits})
vertexSizer.Add(item=self.snappingInfo, proportion=0,
flag=wx.ALL | wx.EXPAND, border=1)
@@ -1749,9 +1749,9 @@
else:
threshold = self.parent.digit.driver.GetThreshold(value)
- self.snappingInfo.SetLabel(_("Snapping threshold is %.1f %s") %
- (threshold,
- self.mapUnits))
+ self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(units)s") %
+ {'value' : threshold,
event.Skip()
@@ -1762,13 +1762,13 @@
threshold = self.parent.digit.driver.GetThreshold(value, units)
if units == "map units":
- self.snappingInfo.SetLabel(_("Snapping threshold is %.1f %s") % \
- (value,
- self.mapUnits))
+ self.snappingInfo.SetLabel(_("Snapping threshold is %(value).1f %(name)s") %
+ {'value' : value,
else:
- (threshold,
- self.mapUnits))
event.Skip()
@@ -2048,10 +2048,11 @@
event.Veto()
self.list.SetStringItem(itemIndex, 0, str(layerNew))
self.list.SetStringItem(itemIndex, 1, str(catNew))
- dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%s/%s>.\n"
+ dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
"Layer and category number must be integer.\n"
"Layer number must be greater then zero.") %
- (str(self.layerNew.GetValue()), str(self.catNew.GetValue())),
+ { 'layer': str(self.layerNew.GetValue()),
+ 'category' : str(self.catNew.GetValue()) },
_("Error"), wx.OK | wx.ICON_ERROR)
dlg.ShowModal()
dlg.Destroy()
@@ -2218,10 +2219,11 @@
if layer <= 0:
raise ValueError
except ValueError:
+ {'layer' : str(self.layerNew.GetValue()),
+ 'category' : str(self.catNew.GetValue())},
dlg.ShowModal()
dlg.Destroy()
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-02-26 20:36:32 UTC (rev 30364)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-02-26 21:20:43 UTC (rev 30365)
@@ -271,11 +271,13 @@
if rerr is False: # GUI dialog
try:
raise CmdError(cmd=self.cmd,
- message=_("Execution failed: '%s'%s%s"
- "Details:%s%s") % (' '.join(self.cmd),
- os.linesep, os.linesep,
- os.linesep,
- self.PrintModuleOutput()))
+ message="%s '%s'%s%s%s %s%s" %
+ (_("Execution failed:"),
+ ' '.join(self.cmd),
+ os.linesep, os.linesep,
+ _("Details:"),
+ os.linesep,
+ self.PrintModuleOutput()))
except CmdError, e:
print e
elif rerr == sys.stderr: # redirect message to sys
Modified: grass/trunk/gui/wxpython/gui_modules/location_wizard.py
--- grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2008-02-26 20:36:32 UTC (rev 30364)
+++ grass/trunk/gui/wxpython/gui_modules/location_wizard.py 2008-02-26 21:20:43 UTC (rev 30365)
@@ -208,11 +208,10 @@
error = _("Location already exists in GRASS Database.")
if error != '':
- dlg = wx.MessageDialog(parent=self, message=_("Unable to create location <%s>.%s"
- "%s" % \
- (str(self.tlocation.GetValue()),
- os.linesep,
- error)),
+ dlg = wx.MessageDialog(parent=self, message="%s <%s>.%s%s" % (_("Unable to create location"),
+ str(self.tlocation.GetValue()),
+ os.linesep,
+ error),
caption=_("Error"), style=wx.OK | wx.ICON_ERROR)
dlg.ShowModal()
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-02-26 20:36:32 UTC (rev 30364)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-02-26 21:20:43 UTC (rev 30365)
@@ -69,7 +69,7 @@
import os
from os import system
import gettext
-gettext.install("wxgui")
+gettext.install("grasswx")
gisbase = os.getenv("GISBASE")
import globalvar
@@ -258,7 +258,8 @@
cmd += [ '%s=%s' % ( p['name'], p['default'] ) ]
else:
cmd += [ '%s=%s' % ( p['name'], _('<required>') ) ]
- errStr += _("Parameter %s (%s) is missing.\n") % ( p['name'], p['description'] )
+ errStr += _("Parameter %(name)s (%(desc)s) is missing.\n") % \
+ {'name' : p['name'], 'desc' : p['description']}
errors += 1
elif p.get('value','') != '' and p['value'] != p.get('default','') :
# Output only values that have been set, and different from defaults
@@ -939,8 +940,8 @@
else:
if len(valuelist) == 1: # -> textctrl
txt = wx.StaticText(parent=which_panel,
- label = _('%s. Valid range=%s') % \
- (title, str(valuelist).strip("[]'") + ':' ) )
+ label = "%s. %s=%s" (title, _('Valid range'),
+ str(valuelist).strip("[]'") + ':'))
which_sizer.Add(item=txt, proportion=0,
flag=wx.ADJUST_MINSIZE | wx.TOP | wx.RIGHT | wx.LEFT, border=5)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-02-26 20:36:32 UTC (rev 30364)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-02-26 21:20:43 UTC (rev 30365)
@@ -97,8 +97,8 @@
'overlay']
if self.type not in layertypes:
- raise gcmd.GException(_("Type <%s> of layer <%s> is not supported yet") % \
- (self.type, self.name))
+ raise gcmd.GException(_("Type <%(type)s> of layer <%(name)s> is not supported yet") % \
+ {'type' : self.type, 'name' : self.name})
# start monitor
@@ -256,8 +256,7 @@
try:
windfile = open (windfile, "r")
except StandardError, e:
- sys.stderr.write(_("Unable to open file <%s>: %s") % \
- (windfile,e))
+ sys.stderr.write("%s %<s>: %s" % (_("Unable to open file"), windfile, e))
sys.exit(1)
for line in windfile.readlines():
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2008-02-26 20:36:32 UTC (rev 30364)
+++ grass/trunk/gui/wxpython/wxgui.py 2008-02-26 21:20:43 UTC (rev 30365)
@@ -588,8 +588,8 @@
file.close()
except IOError, err:
- message=_("Unable to read workspace file <%s>.%s%s") % \
- (filename, os.linesep, err),
+ message="%s <%s>. %s%s" % (_("Unable to read workspace file"),
+ filename, os.linesep, err),
return False
