[GRASS-SVN] r30368 - in grass/trunk/gui/wxpython: . gui_modules
Tue Feb 26 17:56:40 EST 2008
Author: martinl
Date: 2008-02-26 17:56:40 -0500 (Tue, 26 Feb 2008)
New Revision: 30368
   grass/trunk/gui/wxpython/gui_modules/menuform.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI: define i18N (grasswxpy) package
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-02-26 22:41:21 UTC (rev 30367)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2008-02-26 22:56:40 UTC (rev 30368)
@@ -50,7 +50,13 @@
 import re
 import string
 import textwrap
+import os
+from os import system
+### i18N
+import gettext
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
 import utils
 utils.CheckForWx()
 import wx
@@ -66,11 +72,6 @@
 HandlerBase=xml.sax.handler.ContentHandler
 from xml.sax import make_parser
-import os
-from os import system
-import gettext
-gettext.install("grasswx")
 gisbase = os.getenv("GISBASE")
 import globalvar
 if gisbase is None:
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2008-02-26 22:41:21 UTC (rev 30367)
+++ grass/trunk/gui/wxpython/wxgui.py	2008-02-26 22:56:40 UTC (rev 30368)
@@ -29,6 +29,7 @@
 import types
 import re
 import string
+import getopt
 ### for GRC (workspace file) parsering
 # xmlproc not available on Mac OS
 # from xml.parsers.xmlproc import xmlproc
@@ -38,6 +39,9 @@
 import xml.sax.handler
+### i18N
+import gettext
 import gui_modules
 gmpath = gui_modules.__path__[0]
@@ -1450,17 +1454,14 @@
     workspaceFile = process_opt(opts, args)[0]
-    # replace with the appropriate catalog name
-    gettext.install("GMApp")
     # run application
     app = GMApp(workspaceFile)
-    q=wx.LogNull()
+    # suppress wxPython logs
+    q = wx.LogNull()
     app.MainLoop()
 if __name__ == "__main__":
-    import getopt
-    import gettext
     sys.exit(main())
