[GRASS-SVN] r30381 - grass/trunk/vector/v.edit
Wed Feb 27 16:51:37 EST 2008
Author: martinl
Date: 2008-02-27 16:51:37 -0500 (Wed, 27 Feb 2008)
New Revision: 30381
   grass/trunk/vector/v.edit/args.c
   grass/trunk/vector/v.edit/description.html
   grass/trunk/vector/v.edit/global.h
   grass/trunk/vector/v.edit/main.c
   grass/trunk/vector/v.edit/max_distance.c
   grass/trunk/vector/v.edit/proto.h
   grass/trunk/vector/v.edit/select.c
v.edit: threshold value can be different for 'coords', 'snap' and 'query'
Modified: grass/trunk/vector/v.edit/args.c
--- grass/trunk/vector/v.edit/args.c	2008-02-27 20:15:18 UTC (rev 30380)
+++ grass/trunk/vector/v.edit/args.c	2008-02-27 21:51:37 UTC (rev 30381)
@@ -111,10 +111,10 @@
     params -> maxdist->key         = "thresh";
     params -> maxdist->type        = TYPE_DOUBLE;
     params -> maxdist->required    = NO;
-    params -> maxdist->multiple    = NO;
-    params -> maxdist->label       = _("Threshold distance");
+    params -> maxdist->multiple    = YES;
+    params -> maxdist->label       = _("Threshold distance (coords,snap,query)");
     params -> maxdist->description = _("'-1' for threshold based on the current resolution settings");
-    params -> maxdist->answer      = "-1";
+    params -> maxdist->answer      = "-1,0,0";
     params -> id = G_define_standard_option(G_OPT_V_CATS);
     params -> id->required    = NO;
Modified: grass/trunk/vector/v.edit/description.html
--- grass/trunk/vector/v.edit/description.html	2008-02-27 20:15:18 UTC (rev 30380)
+++ grass/trunk/vector/v.edit/description.html	2008-02-27 21:51:37 UTC (rev 30381)
@@ -13,14 +13,13 @@
 vector map are not modified at all.
 <p>
-Vector features can be selected either by internal <b>id</b>,
-category number <b>cats</b>, coordinates <b>coords</b>, bounding
+Vector features can be selected either by internal <b>id</b>, category
+number <b>cats</b>, coordinates <b>coords</b>, bounding
 box <b>bbox</b>, <b>polygon</b>, <b>where</b> statement (attribute
-data) or by <b>query</b>. Selecting features by
-coordinates is affected by the current 2D resolution. It can be
-changed using threshold distance <b>thresh</b>. The options
-are <em>orthogonal</em>, i.e. can be used in various combinations. For
-example:
+data) or by <b>query</b>. Selecting features by coordinates is
+affected by the current 2D resolution or by the threshold distance
+given by <b>thresh</b>. The options are <em>orthogonal</em>, i.e. can
+be used in various combinations. For example:
 <div class="code"><pre>
 v.edit map=roads tool=select \
@@ -75,8 +74,9 @@
     standard format) to existing vector map. Features can be read from
     standard input or from the given text file (<b>input</b>
     option). If no header is given, the <b>-n</b> flag must be
-    used. Added features can be snapped (based on <b>snap</b>
-    parameter) using threshold distance <b>thresh</b>.</li>
+    used. Added features can be snapped (defined by <b>snap</b>
+    parameter) to nodes or vertices based on threshold
+    distance <b>thresh</b>.</li>
     <li><b>delete</b> - Delete selected vector features from existing
     vector map.</li>
@@ -88,8 +88,9 @@
     <li><b>move</b> - Move selected features of existing vector map
     relatively to their current location. This tool requires
     <b>move</b> option. The option defines coordinates of the movement
-    direction. Moved features can be snapped (based on <b>snap</b>
+    direction. Moved features can be snapped (defined by <b>snap</b>
     <li><b>flip</b> - Flip direction of selected vector lines
     (lines or boundaries).</li>
@@ -119,8 +120,9 @@
     <li><b>connect</b> - Connect selected lines or boundaries, the
     first given line is connected to the second one. The second line
-    is broken if necessary. The lines are connected regarding
-    threshold distance <b>thresh</b>.</li>
+    is broken if necessary. The lines are connected only if distance
+    between them is not greater than snapping threshold
     <li><b>chtype</b> - Change feature type of selected geometry
     objects. Points are converted to centroids, centroids to points,
@@ -137,10 +139,10 @@
     <li><b>vertexmove</b> - Move vertex(ces) specified
     by <b>coords</b> option. Direction of the movement is specified by
-    the <b>move</b> option. If <b>-1</b> is given only first found line or
-    boundary in bounding box is modified. Moved vertex can be snapped
-    (based on <b>snap</b> parameter) using threshold
-    distance <b>thresh</b>.</li>
+    the <b>move</b> option. If <b>-1</b> is given only first found
+    line or boundary in bounding box is modified. Moved vertex can be
+    snapped (defined <b>snap</b>) to nodes or vertices based on
+    threshold distance <b>thresh</b>.</li>
     <li><b>zbulk</b> - Assign z coordinate to 3D vector lines in given
     bounding box. The first found line will get z coordinate based on
@@ -247,7 +249,7 @@
 distance 10 map units:
-v.edit tool=move map=roads cat=1 move=1000,-1000 snap=node thresh=10
+v.edit tool=move map=roads cat=1 move=1000,-1000 snap=node thresh=-1,10
 </pre></div>
 Move all features defined by bounding box
@@ -311,7 +313,7 @@
 Snap all lines using threshold distance 20 map units:
-v.edit map=roads id=1-9999 tool=snap thresh=20 type=line
+v.edit map=roads id=1-9999 tool=snap thresh=-1,20 type=line
 </pre></div>
 <h3>Connect lines</h3>
@@ -326,7 +328,7 @@
 50. Maximum threshold distance is 700 map units:
-v.edit map=roads tool=connect id=48,565,60,50 thresh=1000
+v.edit map=roads tool=connect id=48,565,60,50 thresh=-1,700
 </pre></div>
 <h3>Add vertex</h3>
@@ -380,13 +382,13 @@
 Select all lines shorter (or equal) than 10 map units:
-v.edit map=roads tool=select query=length thresh=-10
+v.edit map=roads tool=select query=length thresh=-1,0,-10
 </pre></div>
 Select from given bounding box all lines longer then 200 map units:
-v.edit map=roads tool=select bbox=598260,4919730,605100,4926240 query=length thresh=1000
+v.edit map=roads tool=select bbox=598260,4919730,605100,4926240 query=length thresh=-1,0,1000
 </pre></div>
 <h3>Fix height of contours</h3>
Modified: grass/trunk/vector/v.edit/global.h
--- grass/trunk/vector/v.edit/global.h	2008-02-27 20:15:18 UTC (rev 30380)
+++ grass/trunk/vector/v.edit/global.h	2008-02-27 21:51:37 UTC (rev 30381)
@@ -10,6 +10,10 @@
 # define SEP "----------------------------------"
+#define THRESH_COORDS 0
+#define THRESH_SNAP   1
+#define THRESH_QUERY  2
 enum mode {
     /* geometry of features is not changed */
     MODE_CREATE,         /* create new vector map */
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c	2008-02-27 20:15:18 UTC (rev 30380)
+++ grass/trunk/vector/v.edit/main.c	2008-02-27 21:51:37 UTC (rev 30381)
@@ -33,7 +33,7 @@
     int i;
     int move_first, snap;
     int ret, print, layer;
-    double move_x, move_y, thresh;
+    double move_x, move_y, thresh[3];
     struct line_pnts *coord;
@@ -145,12 +145,24 @@
     layer = atoi (params.fld -> answer);
-    if (params.query->answer) { /* allow negative threshold value (shorter / longer) */
-	thresh = atof (params.maxdist -> answer);
+    i = 0;
+    while(params.maxdist->answers[i]) {
+	switch(i) {
+	case THRESH_COORDS:
+	    thresh[THRESH_COORDS] = max_distance(atof (params.maxdist -> answers[THRESH_COORDS]));
+	    thresh[THRESH_SNAP] = thresh[THRESH_QUERY] = thresh[THRESH_COORDS];
+	    break;
+	case THRESH_SNAP:
+	    thresh[THRESH_SNAP] = max_distance(atof (params.maxdist -> answers[THRESH_SNAP]));
+	    break;
+	case THRESH_QUERY:
+	    thresh[THRESH_QUERY] = atof (params.maxdist -> answers[THRESH_QUERY]);
+	    break;
+	default: break;
+	i++;
-    else {
-	thresh = max_distance(atof (params.maxdist -> answer));
     move_first = params.move_first->answer ? 1 : 0;
     snap = NO_SNAP;
     if (strcmp(params.snap->answer, "node") == 0)
@@ -163,12 +175,12 @@
 	List = Vect_new_list();
 	if (action_mode == MODE_COPY && BgMap && BgMap[0]) {
 	    List = select_lines(BgMap[0], action_mode,
-				&params,
+				&params, thresh,
 				List);
 	else {
 	    List = select_lines(&Map, action_mode,
-				&params,
+				&params, thresh,
 				List);
@@ -222,16 +234,17 @@
 	ret = asc_to_bin(ascii, &Map, List_added);
 	G_message(_("%d features added"), ret);
 	if (ret > 0) {
+	    G_verbose_message(_("Threshold value for snapping is %.2f"), thresh[THRESH_SNAP]);
 	    if (snap != NO_SNAP) { /* apply snapping */
 		Vedit_snap_lines(&Map, BgMap, nbgmaps,
 				 List_added,
-				 thresh,
+				 thresh[THRESH_SNAP],
 				 snap == SNAP ? 0 : 1); /* snap to vertex ? */
 	    if (params.close -> answer) { /* close boundaries */
 		int nclosed;
-		nclosed = close_lines(&Map, GV_BOUNDARY, thresh);
-		G_message (_("%d lines closed"), nclosed);
+		nclosed = close_lines(&Map, GV_BOUNDARY, thresh[THRESH_SNAP]);
+		G_message (_("%d boundaries closed"), nclosed);
 	Vect_destroy_list (List_added);
@@ -243,35 +256,37 @@
     case MODE_MOVE:
 	move_x = atof(params.move -> answers[0]);
 	move_y = atof(params.move -> answers[1]);
 	ret = Vedit_move_lines(&Map, BgMap, nbgmaps,
 			       List,
-			       move_x, move_y, 0.0, snap, thresh); /* TODO: 3D */
+			       move_x, move_y, 0.0, snap, thresh[THRESH_SNAP]); /* TODO: 3D */
 	G_message(_("%d features moved"), ret);
 	break;
     case MODE_VERTEX_MOVE:
 	ret = Vedit_move_vertex(&Map, BgMap, nbgmaps,
 				List,
-				coord, thresh,
+				coord, thresh[THRESH_COORDS], thresh[THRESH_SNAP],
 				move_x, move_y, 0.0, /* TODO: 3D */
 				move_first, snap);
 	G_message(_("%d vertices moved"), ret);
 	break;
     case MODE_VERTEX_ADD:
 	ret = Vedit_add_vertex(&Map, List,
-			       coord, thresh);
+			       coord, thresh[THRESH_COORDS]);
 	G_message(_("%d vertices added"), ret);
 	break;
     case MODE_VERTEX_DELETE:
 	ret = Vedit_remove_vertex(&Map, List,
-				  coord, thresh);
 	G_message(_("%d vertices removed"), ret);
 	break;
     case MODE_BREAK:
 	if (params.coord->answer) {
 	    ret = Vedit_split_lines(&Map, List,
-				    coord, thresh, NULL);
+				    coord, thresh[THRESH_COORDS], NULL);
 	else {
 	    ret = Vect_break_lines_list(&Map, List,
@@ -280,8 +295,9 @@
 	G_message(_("%d lines broken"), ret);
 	break;
     case MODE_CONNECT:
 	ret = Vedit_connect_lines(&Map, List,
-				  thresh);
+				  thresh[THRESH_SNAP]);
 	G_message(_("%d lines connected"), ret);
       	break;
     case MODE_MERGE:
@@ -318,7 +334,8 @@
 	G_message (_("%d features copied"), ret);
 	break;
     case MODE_SNAP:
-	ret = snap_lines(&Map, List, thresh);
+	ret = snap_lines(&Map, List, thresh[THRESH_SNAP]);
 	break;
     case MODE_FLIP:
 	ret = Vedit_flip_lines(&Map, List);
Modified: grass/trunk/vector/v.edit/max_distance.c
--- grass/trunk/vector/v.edit/max_distance.c	2008-02-27 20:15:18 UTC (rev 30380)
+++ grass/trunk/vector/v.edit/max_distance.c	2008-02-27 21:51:37 UTC (rev 30381)
@@ -54,7 +54,9 @@
 	else
 	    maxd = yres;
-	G_important_message (_("Threshold distance set to %g map units (based on 2D resolution)"), maxd);
+	  G_important_message (_("Threshold distance set to %g map units (based on 2D resolution)"), maxd);
     else {
         maxd = maxdistance;
Modified: grass/trunk/vector/v.edit/proto.h
--- grass/trunk/vector/v.edit/proto.h	2008-02-27 20:15:18 UTC (rev 30380)
+++ grass/trunk/vector/v.edit/proto.h	2008-02-27 21:51:37 UTC (rev 30381)
@@ -12,7 +12,7 @@
 /* select.c */
 int print_selected(struct ilist *);
 struct ilist* select_lines(struct Map_info *, enum mode,
-			   struct GParams *,
+			   struct GParams *, double *,
 			   struct ilist *);
 int sel_by_cat(struct Map_info *, struct cat_list*,
 	       int, int, char *,
Modified: grass/trunk/vector/v.edit/select.c
--- grass/trunk/vector/v.edit/select.c	2008-02-27 20:15:18 UTC (rev 30380)
+++ grass/trunk/vector/v.edit/select.c	2008-02-27 21:51:37 UTC (rev 30381)
@@ -34,15 +34,13 @@
    \return list of newly selected features
 struct ilist *select_lines(struct Map_info *Map, enum mode action_mode,
-			   struct GParams *params,
+			   struct GParams *params, double *thresh,
 			   struct ilist *List)
     int layer, type;
-    double thresh;
     layer  = atoi (params -> fld -> answer);
     type   = Vect_option_to_types (params -> type);
-    thresh = atof (params -> maxdist -> answer);
     /* select by id's */
     if (params -> id -> answer != NULL) {
@@ -74,8 +72,9 @@
 	    i += 2;
+	G_verbose_message(_("Threshold value for coordinates is %.2f"), thresh[THRESH_COORDS]);
         sel_by_coordinates(Map,
-			   type, coords, thresh,
+			   type, coords, thresh[THRESH_COORDS],
 			   List);
 	Vect_destroy_line_struct(coords);
@@ -168,8 +167,9 @@
 	    query_type = QUERY_DANGLE;
+	G_verbose_message(_("Threshold value for querying is %.2f"), thresh[THRESH_QUERY]);
 	Vedit_select_by_query(Map,
-			      type, layer, thresh, query_type,
+			      type, layer, thresh[THRESH_QUERY], query_type,
 			      List_tmp);
 	/* merge lists (only duplicate items) */
