[GRASS-SVN] r30405 -
grass/branches/releasebranch_6_3/scripts/v.db.join
svn_grass at osgeo.org
Fri Feb 29 17:02:58 EST 2008
Author: hamish
Date: 2008-02-29 17:02:58 -0500 (Fri, 29 Feb 2008)
New Revision: 30405
grass/branches/releasebranch_6_3/scripts/v.db.join/v.db.join
merge fixes from head (trac bug #75)
Modified: grass/branches/releasebranch_6_3/scripts/v.db.join/v.db.join
--- grass/branches/releasebranch_6_3/scripts/v.db.join/v.db.join 2008-02-29 21:53:27 UTC (rev 30404)
+++ grass/branches/releasebranch_6_3/scripts/v.db.join/v.db.join 2008-02-29 22:02:58 UTC (rev 30405)
@@ -73,32 +73,37 @@
PROG=`basename $0`
-driver="`v.db.connect -g $GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d' ' -f5`"
-database="`v.db.connect -g $GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d' ' -f4`"
+driver=`v.db.connect -g map="$GIS_OPT_MAP" | grep "^$GIS_OPT_LAYER " | cut -d' ' -f5`
+database=`v.db.connect -g map="$GIS_OPT_MAP" | grep "^$GIS_OPT_LAYER " | cut -d' ' -f4`
if [ "$driver" = "dbf" ] ; then
g.message -e "JOIN is not supported for tables stored in DBF format."
exit 1
fi
-maptable="`v.db.connect -g $GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d' ' -f2`"
+maptable=`v.db.connect -g map="$GIS_OPT_MAP" | grep "^$GIS_OPT_LAYER " | cut -d' ' -f2`
if [ -z "$maptable" ] ; then
g.message 'There is no table connected to this map! Cannot join any column.'
cleanup
exit 1
fi
-v.info --q -c $GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut -d'|' -f1,2 | grep "|${GIS_OPT_column}$" 2>&1 >/dev/null
+v.info --quiet -c "$GIS_OPT_MAP" layer="$GIS_OPT_LAYER" | \
+ cut -d'|' -f1,2 | grep "|${GIS_OPT_column}$" 2>&1 >/dev/null
if [ $? -ne 0 ] ; then
- g.message -e "Column <$GIS_OPT_column> not found in table <$GIS_OPT_MAP> at layer $GIS_OPT_LAYER"
- exit 1
+ g.message -e "Column <$GIS_OPT_column> not found in table <$GIS_OPT_MAP> at layer $GIS_OPT_LAYER"
+ exit 1
fi
# we use map DBMI settings
-COLLIST=`db.describe -c driver=$driver database=$database table=$GIS_OPT_otable | grep '^Column ' | cut -d':' -f2`
+COLLIST=`db.describe -c driver="$driver" database="$database" table="$GIS_OPT_otable" | grep '^Column ' | cut -d':' -f2`
# heck, types may have white space
-COLTYPES="`db.describe -c driver=$driver database=$database table=$GIS_OPT_otable | grep '^Column ' | cut -d':' -f3 | tr -s ' ' '_'`"
+COLTYPES=`db.describe -c driver="$driver" database="$database" table="$GIS_OPT_otable" | grep '^Column ' | cut -d':' -f3 | tr -s ' ' '_'`
i=1
for col in $COLLIST ; do
- v.db.addcol $GIS_OPT_MAP col="$col `echo $COLTYPES | cut -d' ' -f$i | tr -s '_' ' '`"
+ v.db.addcol "$GIS_OPT_MAP" col="$col `echo $COLTYPES | cut -d' ' -f$i | tr -s '_' ' '`"
g.message -e "Cannot continue."
exit 1
@@ -109,6 +114,6 @@
done
# write cmd history:
-v.support ${GIS_OPT_MAP} cmdhist="${CMDLINE}"
+v.support "${GIS_OPT_MAP}" cmdhist="${CMDLINE}"
exit 0
