[GRASS-SVN] r30408 -
grass/branches/releasebranch_6_3/scripts/v.rast.stats
svn_grass at osgeo.org
Fri Feb 29 20:36:49 EST 2008
Author: hamish
Date: 2008-02-29 20:36:49 -0500 (Fri, 29 Feb 2008)
New Revision: 30408
grass/branches/releasebranch_6_3/scripts/v.rast.stats/v.rast.stats
copy over versions from trunk with latest fixes
Modified: grass/branches/releasebranch_6_3/scripts/v.rast.stats/v.rast.stats
--- grass/branches/releasebranch_6_3/scripts/v.rast.stats/v.rast.stats 2008-02-29 23:01:03 UTC (rev 30407)
+++ grass/branches/releasebranch_6_3/scripts/v.rast.stats/v.rast.stats 2008-03-01 01:36:49 UTC (rev 30408)
@@ -122,7 +122,6 @@
trap "exitprocedure" 2 3 15
-VECTOR="$GIS_OPT_VECTOR"
RASTER="$GIS_OPT_RASTER"
COLPREFIX="$GIS_OPT_COLPREFIX"
@@ -131,11 +130,18 @@
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
# does map exist in CURRENT mapset?
-eval `g.findfile element=vector file="$VECTOR" mapset="$MAPSET"`
-if [ ! "$file" ] ; then
- g.message -e "Vector map <$VECTOR> not found"
+eval `g.findfile element=vector file="$GIS_OPT_VECTOR" mapset="$MAPSET"`
+VECT_MAPSET=`echo "$GIS_OPT_VECTOR" | grep '@' | cut -f2 -d'@'`
+if [ -z "$VECT_MAPSET" ] ; then
+ VECT_MAPSET="$MAPSET"
+fi
+if [ ! "$file" ] || [ "$VECT_MAPSET" != "$MAPSET" ] ; then
+ g.message -e "Vector map <$GIS_OPT_VECTOR> not found in current mapset"
exit 1
+else
+ VECTOR=`echo "$GIS_OPT_VECTOR" | cut -f1 -d'@'`
fi
#check the input raster map
eval `g.findfile element=cell file="$RASTER"`
@@ -191,7 +197,7 @@
#check if DBF driver used, in this case cut to 10 chars col names:
DBFDRIVER=0
-v.db.connect -g "$VECTOR" | cut -d' ' -f5 | grep -i dbf --quiet
+v.db.connect -g "$VECTOR" | grep -w "$GIS_OPT_LAYER" | cut -d' ' -f5 | grep -i dbf --quiet
if [ $? -eq 0 ] ; then
DBFDRIVER=1
else
@@ -203,7 +209,7 @@
DB_DATABASE="`v.db.connect -g "$VECTOR" | cut -d' ' -f4`"
#Find out which table is linked to the vector map on the given layer
-TABLE=`v.db.connect $VECTOR -g | grep -w $GIS_OPT_LAYER | awk '{print $2}'`
+TABLE=`v.db.connect map="$VECTOR" -g | grep -w "$GIS_OPT_LAYER" | awk '{print $2}'`
if [ -z "$TABLE" ] ; then
g.message -e 'There is no table connected to this map! Run v.db.connect or v.db.addtable first.'
exit 1
