[GRASS-SVN] r29561 -
grass/branches/releasebranch_6_3/raster/r.in.gdal
svn_grass at osgeo.org
Fri Jan 4 14:31:32 EST 2008
Author: martinl
Date: 2008-01-04 14:31:32 -0500 (Fri, 04 Jan 2008)
New Revision: 29561
grass/branches/releasebranch_6_3/raster/r.in.gdal/main.c
Fixing bug GForge/449: r.in.gdal - output test for parameter location= fails (merged from trunk)
Modified: grass/branches/releasebranch_6_3/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_6_3/raster/r.in.gdal/main.c 2008-01-04 19:19:27 UTC (rev 29560)
+++ grass/branches/releasebranch_6_3/raster/r.in.gdal/main.c 2008-01-04 19:31:32 UTC (rev 29561)
@@ -52,6 +52,7 @@
int force_imagery = FALSE;
char error_msg[8096];
int projcomp_error=0;
+ int overwrite;
struct GModule *module;
struct
@@ -123,6 +124,11 @@
flag_k->key = 'k';
flag_k->description = _("Keep band numbers instead of using band color names");
+ /* The parser checks if the map already exists in current mapset, this is
+ * wrong if location options is used, so we switch out the check and do it
+ * in the module after the parser */
+ overwrite = G_check_overwrite(argc, argv);
if (G_parser(argc,argv))
exit(EXIT_FAILURE);
@@ -176,6 +182,18 @@
exit(EXIT_SUCCESS);
+ if (G_legal_filename(output) < 0)
+ G_fatal_error(_("<%s> is an illegal file name"), output);
+ if ( !parm.outloc->answer ) { /* Check if the map exists */
+ if ( G_find_cell2 (output, G_mapset()) ) {
+ if (overwrite)
+ G_warning ( _("Raster map <%s> already exists and will be overwritten"), output );
+ else
+ G_fatal_error ( _("Raster map <%s> already exists"), output );
/* Open the file. */
@@ -250,12 +268,15 @@
/* Convert projection information non-interactively as we can't
* assume the user has a terminal open */
if ( GPJ_wkt_to_grass( &cellhd, &proj_info,
- &proj_units, GDALGetProjectionRef(hDS), 0) < 0 )
+ &proj_units, GDALGetProjectionRef(hDS), 0) < 0 ) {
G_fatal_error(_("Unable to convert input map projection to GRASS "
"format; cannot create new location."));
- else
+ else {
G_make_location( parm.outloc->answer, &cellhd,
proj_info, proj_units, NULL );
+ G_message(_("Location <%s> created"), parm.outloc->answer);
else
