[GRASS-SVN] r29577 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Jan 5 17:36:36 EST 2008
Author: martinl
Date: 2008-01-05 17:36:35 -0500 (Sat, 05 Jan 2008)
New Revision: 29577
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
Flags --overwrite/--verbose/--quiet included in wxPython GUI dialogs. Wrapping output messages in command log area.
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-01-05 22:33:35 UTC (rev 29576)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-01-05 22:36:35 UTC (rev 29577)
@@ -175,7 +175,7 @@
def __init__ (self, cmd, stdin=None,
- verbose=0, wait=True, log='gui',
+ verbose=None, wait=True, log='gui',
stdout=None, stderr=None):
self.cmd = cmd
@@ -184,15 +184,16 @@
# set verbosity level
verbose_orig = None
- if ('--q' not in self.cmd or '--quiet' not in self.cmd) and \
- ('--v' not in self.cmd or '--verbose' not in self.cmd):
- if verbose == 0:
- self.cmd.append('--quiet')
- elif verbose == 3:
- self.cmd.append('--verbose')
- else:
- verbose_orig = os.getenv("GRASS_VERBOSE")
- os.environ["GRASS_VERBOSE"] = str(verbose)
+ if ('--q' not in self.cmd and '--quiet' not in self.cmd) and \
+ ('--v' not in self.cmd and '--verbose' not in self.cmd):
+ if verbose is not None:
+ if verbose == 0:
+ self.cmd.append('--quiet')
+ elif verbose == 3:
+ self.cmd.append('--verbose')
+ else:
+ verbose_orig = os.getenv("GRASS_VERBOSE")
+ os.environ["GRASS_VERBOSE"] = str(verbose)
# set message formatting
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-01-05 22:33:35 UTC (rev 29576)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-01-05 22:36:35 UTC (rev 29577)
@@ -245,7 +245,10 @@
for flag in self.flags:
if 'value' in flag and flag['value']:
- cmd += [ '-' + flag['name'] ]
+ if len(flag['name']) > 1: # e.g. overwrite
+ cmd += [ '--' + flag['name'] ]
+ else:
+ cmd += [ '-' + flag['name'] ]
for p in self.params:
if p.get('value','') == '' and p.get('required','no') != 'no':
if p.get('default', '') != '':
@@ -839,6 +842,8 @@
which_sizer.Add( item=chk, proportion=0, flag=wx.EXPAND| wx.TOP | wx.LEFT, border=5)
f['wxId'] = chk.GetId()
chk.Bind(wx.EVT_CHECKBOX, self.OnSetValue)
+ if f['name'] in ('verbose', 'quiet'):
+ chk.Bind(wx.EVT_CHECKBOX, self.OnVerbosity)
# parameters
visible_params = [ p for p in self.task.params if not p.get( 'hidden', 'no' ) == 'yes' ]
@@ -1026,7 +1031,23 @@
self.SetSizer( panelsizer )
panelsizer.Fit(self)
self.hasMain = tab.has_key( _('Main') ) # publish, to enclosing Frame for instance
+ def OnVerbosity(self, event):
+ """Verbosity level changed"""
+ verbose = self.FindWindowById(self.task.get_flag('verbose')['wxId'])
+ quiet = self.FindWindowById(self.task.get_flag('quiet')['wxId'])
+ if event.IsChecked():
+ if event.GetId() == verbose.GetId():
+ if quiet.IsChecked():
+ quiet.SetValue(False)
+ self.task.get_flag('quiet')['value'] = False
+ else:
+ if verbose.IsChecked():
+ verbose.SetValue(False)
+ self.task.get_flag('verbose')['value'] = False
+ event.Skip()
def OnPageChange(self, event):
self.Layout()
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-01-05 22:33:35 UTC (rev 29576)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py 2008-01-05 22:36:35 UTC (rev 29577)
@@ -28,6 +28,7 @@
import sys
import string
import time
+import textwrap
import wx
import wx.lib.customtreectrl as CT
@@ -1167,12 +1168,7 @@
self.cmd_output.StartStyling(p1, 0xff)
self.cmd_output.SetStyling(p2 - p1, self.cmd_output.StyleCommand)
-# grassCmd = gcmd.Command(cmdlist, verbose=3, wait=False,
-# stdout=GMStdout(self.cmd_output),
-# stderr=GMStderr(self.cmd_output,
-# self.console_progressbar))
- grassCmd = gcmd.Command(cmdlist, verbose=3, wait=False,
+ grassCmd = gcmd.Command(cmdlist, wait=False,
stdout=self.cmd_stdout,
stderr=self.cmd_stderr)
@@ -1262,12 +1258,11 @@
self.gmstc = gmstc
def write(self, s):
- # if not self.gmstc.GetParent().IsShown():
- # self.mystc.GetParent().Show()
+ if len(s) == 0:
+ return
s = s.replace('\n', os.linesep)
p1 = self.gmstc.GetCurrentPos() # get caret position
- self.gmstc.AddText(s)
+ self.gmstc.AddTextWrapped(s)
self.gmstc.EnsureCaretVisible()
p2 = self.gmstc.GetCurrentPos()
self.gmstc.StartStyling(p1, 0xff)
@@ -1289,9 +1284,6 @@
self.gmgauge = gmgauge
def write(self, s):
- # if self.gmstc.GetParent().IsShown() == False:
- # self.gmstc.GetParent().Show()
message = ''
for line in s.split(os.linesep):
@@ -1317,16 +1309,21 @@
elif 'GRASS_INFO_END' in line:
message = ''
else:
- p1 = self.gmstc.GetCurrentPos()
- self.gmstc.AddText(line + os.linesep)
- self.gmstc.EnsureCaretVisible()
- p2 = self.gmstc.GetCurrentPos()
- self.gmstc.StartStyling(p1, 0xff)
- self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleUnknown)
+ if len(line) > 0:
+ p1 = self.gmstc.GetCurrentPos()
+ self.gmstc.AddTextWrapped(line)
+ self.gmstc.EnsureCaretVisible()
+ p2 = self.gmstc.GetCurrentPos()
+ self.gmstc.StartStyling(p1, 0xff)
+ self.gmstc.SetStyling(p2 - p1 + 1, self.gmstc.StyleUnknown)
- if message != '':
+ if len(message) > 0:
- self.gmstc.AddText(message + os.linesep)
+ if type == 'warning':
+ message = 'WARNING: ' + message
+ elif type == 'error':
+ message = 'ERROR: ' + message
+ self.gmstc.AddTextWrapped(message)
@@ -1415,16 +1412,11 @@
wx.TheClipboard.Flush()
evt.Skip()
- def write(self, string, style=None):
- """Add text to the text area"""
- if not style:
- style = self.StyleUnknown
- p1 = self.GetCurrentPos()
- self.AddText(string)
- self.EnsureCaretVisible()
- p2 = self.GetCurrentPos()
- self.StartStyling(p1, 0xff)
- self.SetStyling(p2 - p1 + 1, style)
+ def AddTextWrapped(self, str, wrap=80):
+ """Add string to text area.
+ String is wrapped and linesep is also added to the end
+ of the string"""
+ str = textwrap.fill(str, wrap) + os.linesep
+ self.AddText(str)
