[GRASS-SVN] r29584 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sun Jan 6 10:50:37 EST 2008
Author: martinl
Date: 2008-01-06 10:50:37 -0500 (Sun, 06 Jan 2008)
New Revision: 29584
grass/trunk/gui/wxpython/gui_modules/menuform.py
wxGUI dialogs: fix tooltip (label, description), store description also for values
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-01-06 15:06:50 UTC (rev 29583)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-01-06 15:50:37 UTC (rev 29584)
@@ -52,6 +52,7 @@
import re
import string
import textwrap
import wx.lib.flatnotebook as FN
import wx.lib.colourselect as csel
import wx.lib.filebrowsebutton as filebrowse
@@ -296,6 +297,7 @@
self.param_description = ''
self.param_default = ''
self.param_values = []
+ self.param_values_description = []
self.param_gisprompt = False
self.param_age = ''
self.param_element = ''
@@ -398,6 +400,7 @@
"guisection" : self.param_guisection,
"default" : self.param_default,
"values" : self.param_values,
+ "values_desc" : self.param_values_description,
"value" : ''})
if self.inFirstParameter:
@@ -415,7 +418,9 @@
self.param_label = normalize_whitespace(self.label)
if name == 'description':
- if self.inParameter:
+ if self.inValueContent:
+ self.param_values_description.append(normalize_whitespace(self.description))
+ elif self.inParameter:
self.param_description = normalize_whitespace(self.description)
elif self.inFlag:
self.flag_description = normalize_whitespace(self.description)
@@ -429,7 +434,7 @@
if name == 'value':
v = normalize_whitespace(self.value_tmp)
- self.param_values = self.param_values + [ normalize_whitespace(self.value_tmp) ]
+ self.param_values.append(normalize_whitespace(self.value_tmp))
self.inValueContent = False
if name == 'guisection':
@@ -828,35 +833,50 @@
self.notebook.SetSelection(0)
panelsizer.Add( self.notebook, 1, flag=wx.EXPAND )
# flags
text_style = wx.FONTWEIGHT_NORMAL
visible_flags = [ f for f in self.task.flags if not f.get( 'hidden', 'no' ) == 'yes' ]
for f in visible_flags:
which_sizer = tabsizer[ f['guisection'] ]
which_panel = tab[ f['guisection'] ]
- title = text_beautify( f['description'] )
+ # if label is given -> label and description -> tooltip
+ # otherwise description -> lavel
+ if p.get('label','') != '':
+ title = text_beautify( f['label'] )
+ tooltip = text_beautify ( f['description'] )
+ else:
+ title = text_beautify( f['description'] )
+ tooltip = None
chk = wx.CheckBox(parent=which_panel, label = title, style = wx.NO_BORDER)
+ if tooltip:
+ chk.SetToolTipString(tooltip)
if 'value' in f:
chk.SetValue( f['value'] )
- chk.SetFont( wx.Font( pointSize=fontsize, family=wx.FONTFAMILY_DEFAULT, style=wx.NORMAL, weight=text_style))
- which_sizer.Add( item=chk, proportion=0, flag=wx.EXPAND| wx.TOP | wx.LEFT, border=5)
+ chk.SetFont(wx.Font(pointSize=fontsize, family=wx.FONTFAMILY_DEFAULT,
+ style=wx.NORMAL, weight=text_style))
+ which_sizer.Add( item=chk, proportion=0, flag=wx.EXPAND | wx.TOP | wx.LEFT, border=5)
f['wxId'] = chk.GetId()
chk.Bind(wx.EVT_CHECKBOX, self.OnSetValue)
if f['name'] in ('verbose', 'quiet'):
chk.Bind(wx.EVT_CHECKBOX, self.OnVerbosity)
# parameters
visible_params = [ p for p in self.task.params if not p.get( 'hidden', 'no' ) == 'yes' ]
for p in visible_params:
which_sizer = tabsizer[ p['guisection'] ]
which_panel = tab[ p['guisection'] ]
- # label <-> description
title = text_beautify( p['label'] )
tooltip = text_beautify ( p['description'] )
else:
title = text_beautify( p['description'] )
- tooltip = ''
+ tooltip = None
txt = None
# text style (required -> bold)
@@ -873,10 +893,9 @@
if ( len(p.get('values',[]) ) > 0):
valuelist=map( str, p.get('values',[]) )
- # list of values
+ # list of values (checkbox)
if p.get('multiple','no') == 'yes':
txt = wx.StaticBox (parent=which_panel, id=0, label=" " + title + ":")
- txt.SetToolTip(wx.ToolTip(tooltip))
if len(valuelist) > 6:
hSizer=wx.StaticBoxSizer ( box=txt, orient=wx.VERTICAL )
else:
@@ -894,7 +913,7 @@
hSizer.Add( item=chkbox, proportion=0, flag=wx.ADJUST_MINSIZE | wx.ALL, border=1 )
chkbox.Bind(wx.EVT_CHECKBOX, self.OnCheckBoxMulti)
which_sizer.Add( item=hSizer, proportion=0, flag=wx.ADJUST_MINSIZE | wx.ALL, border=5 )
- # one value
+ # one value (textctrl)
elif len(valuelist) == 1:
txt = wx.StaticText(parent=which_panel,
label = _('%s. Valid range=%s') % (title, str(valuelist).strip("[]'") + ':' ) )
@@ -909,14 +928,16 @@
p['wxId'] = txt2.GetId()
txt2.Bind(wx.EVT_TEXT, self.OnSetValue)
else:
- # combo
+ # list of values (combo)
txt = wx.StaticText(parent=which_panel, label = title + ':' )
which_sizer.Add(item=txt, proportion=0, flag=wx.ADJUST_MINSIZE | wx.TOP | wx.LEFT, border=5)
- cb = wx.ComboBox(which_panel, -1, p.get('default',''),
- wx.Point(-1, -1), wx.Size(STRING_ENTRY_WIDTH, -1),
- valuelist, wx.CB_DROPDOWN)
- if p.get('value','') != '': cb.SetValue(p['value']) # parameter previously set
- which_sizer.Add( item=cb, proportion=0, flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
+ cb = wx.ComboBox(parent=which_panel, id=wx.ID_ANY, value=p.get('default',''),
+ size=wx.Size(STRING_ENTRY_WIDTH, -1),
+ choices=valuelist, style=wx.CB_DROPDOWN)
+ if p.get('value','') != '':
+ cb.SetValue(p['value']) # parameter previously set
+ which_sizer.Add( item=cb, proportion=0,
+ flag=wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border=5)
p['wxId'] = cb.GetId()
cb.Bind( wx.EVT_COMBOBOX, self.OnSetValue)
@@ -1010,7 +1031,20 @@
if txt is not None:
txt.SetFont( wx.Font( fontsize, wx.FONTFAMILY_DEFAULT, wx.NORMAL, text_style, 0, ''))
+ # create tooltip if given
+ if len(p['values_desc']) > 0:
+ if tooltip:
+ tooltip += 2 * os.linesep
+ else:
+ tooltip = ''
+ for i in range(len(p['values'])):
+ tooltip += p['values'][i] + ': ' + p['values_desc'][i] + os.linesep
+ tooltip.strip(os.linesep)
+ if tooltip:
+ txt.SetToolTipString(tooltip)
maxsizes = (0,0)
for section in sections:
tabsizer[section].SetSizeHints( tab[section] )
@@ -1210,7 +1244,7 @@
self.grass_task = grassTask()
handler = processTask(self.grass_task)
xml.sax.parseString( getInterfaceDescription(cmd[0]), handler )
# if layer parameters previously set, re-insert them into dialog
if completed is not None:
if 'params' in dcmd_params:
