[GRASS-SVN] r29587 - grass/trunk/display/d.legend
svn_grass at osgeo.org
Mon Jan 7 04:47:22 EST 2008
Author: martinl
Date: 2008-01-07 04:47:22 -0500 (Mon, 07 Jan 2008)
New Revision: 29587
grass/trunk/display/d.legend/main.c
Do not use static buffer for 'map' (reported by Ivan Shmakov).
Message cleaning, use standard options.
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c 2008-01-07 09:31:17 UTC (rev 29586)
+++ grass/trunk/display/d.legend/main.c 2008-01-07 09:47:22 UTC (rev 29587)
@@ -39,7 +39,7 @@
char *mapset ;
char buff[512];
- char map_name[64] ;
+ const char *map_name;
char window_name[64] ;
int black ;
int cats_num ;
@@ -70,7 +70,8 @@
DCELL min_dcolr, max_dcolr;
int x0, x1, y0, y1, xyTemp;
double X0, X1, Y0, Y1;
- int SigDigits, MaxLabelLen;
+ int SigDigits;
+ unsigned int MaxLabelLen;
char DispFormat[5]; /* %.Xf\0 */
int flip, horiz, UserRange;
double UserRangeMin, UserRangeMax, UserRangeTemp;
@@ -82,16 +83,12 @@
G_gisinit(argv[0]) ;
module = G_define_module();
- module->keywords = _("display");
+ module->keywords = _("display, cartography");
module->description =
_("Displays a legend for a raster map in the active frame "
"of the graphics monitor.");
- opt1 = G_define_option() ;
- opt1->key = "map" ;
- opt1->type = TYPE_STRING ;
- opt1->required = YES ;
- opt1->gisprompt = "old,cell,raster" ;
+ opt1 = G_define_standard_option(G_OPT_R_MAP) ;
opt1->description= _("Name of raster map");
opt2 = G_define_option() ;
@@ -188,7 +185,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- strcpy(map_name, opt1->answer) ;
+ map_name = opt1->answer;
hide_catstr = hidestr->answer; /* note hide_catstr gets changed and re-read below */
hide_catnum = hidenum->answer;
@@ -250,7 +247,7 @@
/* Make sure map is available */
- mapset = G_find_cell (map_name, "") ;
+ mapset = G_find_cell2 (map_name, "") ;
if (mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), map_name);
@@ -339,7 +336,7 @@
horiz = (x1-x0 > y1-y0);
if(horiz)
- fprintf(stderr, _("Drawing horizontal legend as box width exceeds height.\n"));
+ G_warning(_("Drawing horizontal legend as box width exceeds height"));
if(!fp && horiz) /* better than nothing */
do_smooth = TRUE;
@@ -421,7 +418,7 @@
maxCat=0; /* reset */
for(i=0, k=0; i<catlistCount; i++) {
if( (catlist[i] < min_ind) || (catlist[i] > max_ind) ) {
- G_fatal_error(_("use=%s out of range [%d,%d]. (extend with range= ?)"),
+ G_fatal_error(_("use=%s out of range [%d,%d] (extend with range= ?)"),
opt8->answers[i], min_ind, max_ind);
@@ -471,8 +468,7 @@
/* an alternate solution is to set dots_per_line=1 */
if ((dots_per_line == 0) && (do_smooth == 0)) {
if(!use_catlist) {
- fprintf(stderr,
- _("Forcing a smooth legend: too many categories for current window height.\n"));
+ G_warning(_("Forcing a smooth legend: too many categories for current window height"));
do_smooth = 1;
@@ -526,7 +522,7 @@
if(use_catlist) {
for(i=0; i<catlistCount; i++) {
if( (catlist[i] < dmin) || (catlist[i] > dmax) ) {
- G_fatal_error(_("use=%s out of range [%.3f, %.3f]. (extend with range= ?)"),
+ G_fatal_error(_("use=%s out of range [%.3f, %.3f] (extend with range= ?)"),
opt8->answers[i], dmin, dmax);
if( strlen(opt8->answers[i]) > MaxLabelLen )
