[GRASS-SVN] r29593 - in grass/trunk/gui: . wxpython/gui_modules xml
svn_grass at osgeo.org
Mon Jan 7 07:38:19 EST 2008
Author: martinl
Date: 2008-01-07 07:38:19 -0500 (Mon, 07 Jan 2008)
New Revision: 29593
Added:
grass/trunk/gui/xml/Makefile
Removed:
grass/trunk/gui/wxpython/gui_modules/grass-interface.dtd
grass/trunk/gui/Makefile
grass/trunk/gui/wxpython/gui_modules/gcmd.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
Redundant grass-interface.dtd file removed from gui/wxpython/gui_modules, install gui/xml/grass-interface.dtd to $ETC.
Modified: grass/trunk/gui/Makefile
--- grass/trunk/gui/Makefile 2008-01-07 12:29:56 UTC (rev 29592)
+++ grass/trunk/gui/Makefile 2008-01-07 12:38:19 UTC (rev 29593)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ..
-SUBDIRS = icons scripts
+SUBDIRS = icons scripts xml
TCLTKBASED = tcltk
PYTHONBASED = wxpython
Modified: grass/trunk/gui/wxpython/gui_modules/gcmd.py
--- grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-01-07 12:29:56 UTC (rev 29592)
+++ grass/trunk/gui/wxpython/gui_modules/gcmd.py 2008-01-07 12:38:19 UTC (rev 29593)
@@ -46,7 +46,7 @@
from debug import Debug as Debug
class Popen(subprocess.Popen):
- """Subclass Popen..."""
+ """Subclass subprocess.Popen"""
def recv(self, maxsize=None):
return self._recv('stdout', maxsize)
@@ -152,17 +152,8 @@
Run GRASS command in separate thread
- Parameters:
- cmd - command given as list
- stdin - standard input stream
- verbose - verbose mode [0, 3]
- wait - wait for child execution terminated
- dlgMsg - type of error message (None, gui, txt), only if wait is True
- stdout - redirect standard output or None
- stderr - redirect standard error output or None
+ If stdout/err is redirected, write() method is required for the given classes
- If stdout/err is redirected, write() method is required for the given classes.
Usage:
cmd = Command(cmd=['d.rast', 'elevation.dem'], verbose=3, wait=True)
@@ -173,6 +164,13 @@
else:
print 'FAILURE (%d)' % cmd.returncode
+ @param cmd command given as list
+ @param stdin standard input stream
+ @param verbose verbose level [0, 3] (--q, --v)
+ @param wait wait for child execution terminated
+ @param log logging type (None, gui, txt), only if wait is True
+ @param stdout redirect standard output or None
+ @param stderr redirect standard error output or None
def __init__ (self, cmd, stdin=None,
verbose=None, wait=True, log='gui',
Deleted: grass/trunk/gui/wxpython/gui_modules/grass-interface.dtd
--- grass/trunk/gui/wxpython/gui_modules/grass-interface.dtd 2008-01-07 12:29:56 UTC (rev 29592)
+++ grass/trunk/gui/wxpython/gui_modules/grass-interface.dtd 2008-01-07 12:38:19 UTC (rev 29593)
@@ -1,156 +0,0 @@
-<!-- grass-interface.dtd
- Copyright (C) 2000-2007 by the GRASS Development Team
- Author: Jan-Oliver Wagner <jan intevation.de>
- Changes:
- 2007-10 by Martin Landa <landa.martin gmail.com>
- * added keywords element
- * added name element (fix for value element)
- 2007-04 by Daniel Calvelo <dca.gis gmail.com>
- * added guisection element
- * added name-description pair for value sets
- 2001-06-07 by Eric G. Miller <egm2 jps.net>
- * make <parameter-group> optional
- * move descriptions first, always optional
- * make <default> optional // Should it reference <value> ?
- 2001-07-09:
- * Make an explicit flag element
- * make keydesc and gispropmpt elements
- * move elements directly under "task"
- This program is free software under the GPL (>=v2)
- Read the file COPYING coming with GRASS for details.
-<!-- a grass-interface collect several tasks to
- customize a grass application.
-<!ELEMENT grass-interface (description? , task+)>
-<!ATTLIST grass-interface name CDATA #REQUIRED>
-<!-- a task describes the interface of a single
- GRASS command. It may consist of several
- groups of parameters. Grouping is only for
- semantic purposes in the (G)UI.
- The task may optionally have a description.
- The name of the task is the identifier
- for the GRASS command and is used
- to execute the task.
-<!ELEMENT task (description?, keywords?, parameter*, flag*, parameter-group*)>
-<!ATTLIST task name CDATA #REQUIRED>
-<!-- a parameter-group may be associated with a name,
- but the name is not necessary for running a
- GRASS command.
- The group consists of a number of parameters
- and may optionally have a description.
-<!ELEMENT parameter-group (description?, parameter*, flag*)>
-<!ATTLIST parameter-group name CDATA #IMPLIED>
-<!-- a parameter must have a name and a description.
- the name is the parameter identifier when calling
- the command.
- A default may be provided. values can be given
- as parameter options.
- Parameters can be optional and in that case can be
- ignored executing the task when not entered in the (G)UI.
- Any parameter has one of these (default is string):
- string : a string parameter.
- integer : a numeric integer parameter.
- float : a numeric float parameter.
- If multiple is "yes", then many values for the
- parameter may be given in a comma-seperated list
-<!ELEMENT parameter (description?, keydesc?, gisprompt?, default?, values?, guisection?)>
-<!ATTLIST parameter name CDATA #REQUIRED
- type (string | integer | float) "string"
- required (yes | no) "no"
- multiple (yes | no) "no">
-<!-- The "keydesc" defines a tuple for input, such as "x,y".
- The program expects a comma separated list with matching
- count of items (or multiples thereof, if multiple is true).
-<!ELEMENT keydesc (item+)>
-<!-- An "item" is a value for a tuple of keydesc.
- It must have an "order" attribute, to insure sort ordering
-<!ELEMENT item (#PCDATA)>
-<!ATTLIST item order CDATA #REQUIRED>
-<!-- The "gisprompt" is a three part description, used for map elements
- and files. It consists of a comma separated list of
- "age,element,prompt". "Age" is "new | old | any"; "element" is
- a grass map element such as "dig", and "prompt" is what to present
- to the user in a prompt, such as "vector"
-<!ELEMENT gisprompt EMPTY>
-<!ATTLIST gisprompt age (any | old | new | mapset) #REQUIRED
- element (cell | fcell | cellhd | cats | colr |
- colr2 | cell_misc | hist | dig | dig_ascii |
- dig_att | dig_cats | dig_plus | reg | arc |
- bldg | dlg | dxf | camera | icons | paint |
- group | site_lists | windows | CDATA) #REQUIRED
- prompt CDATA #REQUIRED>
-<!-- A flag must have a name and should have a description.
- It's a toggle that is off by default
-<!ELEMENT flag (description?)>
-<!ATTLIST flag name CDATA #REQUIRED>
-<!-- a default of a parameter. Hopefully it does correspond
- with the parameter type. How to set up rules for that
- (same problem for <value>)?
-<!ELEMENT default (#PCDATA)>
-<!-- the GUI section where the parameter would appear
-<!ELEMENT guisection (#PCDATA)>
-<!-- contains a number of single values. Values may have name and description.
-<!ELEMENT values (value+)>
-<!-- a potential value for a parameter. Hopefully
- it does correpond to the parameter type.
- How to set up rules for that (same problem for
- <default>)?
-<!ELEMENT value (name, description?)>
-<!ELEMENT name (#PCDATA)>
-<!-- common elements -->
-<!-- text that describes a grass-interface, task,
- parameter-group or parameter.
-<!ELEMENT description (#PCDATA)>
-<!-- list of keywords that describes a task
-<!ELEMENT keywords (#PCDATA)>
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-01-07 12:29:56 UTC (rev 29592)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2008-01-07 12:38:19 UTC (rev 29593)
@@ -1178,12 +1178,12 @@
Returns the XML description for the GRASS cmd.
- The DTD must be located in $GISBASE/etx/wx/gui_modules/grass-interface.dtd,
+ The DTD must be located in $GISBASE/etc/grass-interface.dtd,
otherwise the parser will not succeed.
Note: 'cmd' is given as string
- gmpath = os.path.join(wxbase,"gui_modules")
+ gmpath = os.path.join(gisbase, "etc")
cmdout = os.popen(cmd + r' --interface-description', "r").read()
if not len(cmdout) > 0 :
raise IOError, _("Couldn't fetch interface description for command <%s>.") % cmd
Added: grass/trunk/gui/xml/Makefile
--- grass/trunk/gui/xml/Makefile (rev 0)
+++ grass/trunk/gui/xml/Makefile 2008-01-07 12:38:19 UTC (rev 29593)
@@ -0,0 +1,8 @@
+MODULE_TOPDIR = ../..
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: $(ETC)/grass-interface.dtd
+$/$(ETC)/grass-interface.dtd : grass-interface.dtd
+ $(INSTALL_DATA) grass-interface.dtd $(ETC)/grass-interface.dtd
