[GRASS-SVN] r29611 - grass/branches/releasebranch_6_3/lib/init
svn_grass at osgeo.org
Tue Jan 8 08:40:40 EST 2008
Author: neteler
Date: 2008-01-08 08:40:40 -0500 (Tue, 08 Jan 2008)
New Revision: 29611
grass/branches/releasebranch_6_3/lib/init/file_option.tcl
grass/branches/releasebranch_6_3/lib/init/gis_set.tcl
fix button wrapping (merge from HEAD)
Modified: grass/branches/releasebranch_6_3/lib/init/file_option.tcl
--- grass/branches/releasebranch_6_3/lib/init/file_option.tcl 2008-01-08 13:39:13 UTC (rev 29610)
+++ grass/branches/releasebranch_6_3/lib/init/file_option.tcl 2008-01-08 13:40:40 UTC (rev 29611)
@@ -102,16 +102,16 @@
-helptext [G_msg "Path to georeferenced file (format must be readable by GDAL/OGR)"]
#browse for georeferenced file
- Button $row2.browsefile -justify center -width 10 -bd 1 -text [G_msg "Browse..."] \
+ Button $row2.browsefile -justify center -padx 10 -bd 1 -text [G_msg "Browse..."] \
-helptext [G_msg "Browse to locate georeferenced file"] \
-command "fileOpt::browse_file"
pack $row2.filepath $row2.browsefile -side left -expand 0 -fill x -padx 2
- Button $row3.submit -justify center -width 15 -text [G_msg "Define location"] \
+ Button $row3.submit -justify center -padx 10 -text [G_msg "Define location"] \
-command "fileOpt::def_loc" -bd 1
- Button $row3.cancel -justify center -width 15 -text [G_msg "Cancel"] \
+ Button $row3.cancel -justify center -padx 10 -text [G_msg "Cancel"] \
-command {destroy .fileloc} -bd 1
pack $row3.submit -side left -fill x -expand 0
Modified: grass/branches/releasebranch_6_3/lib/init/gis_set.tcl
--- grass/branches/releasebranch_6_3/lib/init/gis_set.tcl 2008-01-08 13:39:13 UTC (rev 29610)
+++ grass/branches/releasebranch_6_3/lib/init/gis_set.tcl 2008-01-08 13:40:40 UTC (rev 29611)
@@ -222,9 +222,8 @@
-borderwidth {2}
label .frame0.frameDB.left.label \
- -anchor {n} \
-justify right \
- -wraplength 110 \
+ -wraplength 200 \
-text [G_msg "GIS Data Directory: "]
entry .frame0.frameDB.mid.entry \
@@ -236,11 +235,10 @@
scrollbar .frame0.frameDB.mid.hscrollbar \
-command { .frame0.frameDB.mid.entry xview} \
-relief {sunken} \
- -width 12 \
-orient {horizontal}
button .frame0.frameDB.right.button \
- -text [G_msg "Browse..."] -bd 1 \
+ -text [G_msg "Browse..."] -padx 10 -bd 1 \
-command { set tmp [tk_chooseDirectory -initialdir $database \
-parent .frame0 -title [G_msg "New GIS data directory"] -mustexist true]
if {$tmp != ""} {
@@ -250,12 +248,12 @@
pack .frame0.frameDB.left.label -side top
- pack .frame0.frameDB.mid.entry -side top -fill x
+ pack .frame0.frameDB.mid.entry -side top
pack .frame0.frameDB.mid.hscrollbar -side bottom -fill x
- pack .frame0.frameDB.right.button -side left -fill x
- pack .frame0.frameDB.left -side left -anchor n -fill x
- pack .frame0.frameDB.mid -side left -fill x
- pack .frame0.frameDB.right -side left -anchor n -fill x
+ pack .frame0.frameDB.right.button -side left
+ pack .frame0.frameDB.left -side left -anchor n
+ pack .frame0.frameDB.mid -side left -anchor n
+ pack .frame0.frameDB.right -side left -anchor n -padx 10
# build .frame0.frameLOC - middle, left section for location selection listbox
@@ -264,9 +262,8 @@
-borderwidth {2}
label .frame0.frameLOC.label \
- -anchor {w} \
-wraplength 170 \
- -text [G_msg "Project Location\n(projection/coordinate system)"]
+ -text [G_msg "Project Location (projection/coordinate system)"]
listbox .frame0.frameLOC.listbox \
-relief {sunken} \
@@ -275,11 +272,11 @@
-xscrollcommand {.frame0.frameLOC.hscrollbar set} \
-selectmode single
- scrollbar .frame0.frameLOC.vscrollbar -width 12 \
+ scrollbar .frame0.frameLOC.vscrollbar \
-command {.frame0.frameLOC.listbox yview} \
-relief {sunken}
- scrollbar .frame0.frameLOC.hscrollbar -width 12 \
+ scrollbar .frame0.frameLOC.hscrollbar \
-command {.frame0.frameLOC.listbox xview} \
-orient {horizontal} \
-relief {sunken}
@@ -298,9 +295,8 @@
-borderwidth {2}
label .frame0.frameMS.label \
- -anchor {w} \
- -wraplength 150 \
- -text [G_msg "Accessible Mapsets\n(directories of GIS files)"]
+ -wraplength 170 \
+ -text [G_msg "Accessible Mapsets (directories of GIS files)"]
listbox .frame0.frameMS.listbox \
-relief {sunken} \
@@ -309,11 +305,11 @@
-xscrollcommand {.frame0.frameMS.hscrollbar set} \
-selectmode single
- scrollbar .frame0.frameMS.vscrollbar -width 12 \
+ scrollbar .frame0.frameMS.vscrollbar \
-command {.frame0.frameMS.listbox yview} \
-relief {sunken}
- scrollbar .frame0.frameMS.hscrollbar -width 12 \
+ scrollbar .frame0.frameMS.hscrollbar \
-command {.frame0.frameMS.listbox xview} \
-relief {sunken}
@@ -340,6 +336,9 @@
frame .frame0.frameNMS.third \
-borderwidth {2}
+ frame .frame0.frameNMS.spacer \
+ -borderwidth {2} -height {10}
frame .frame0.frameNMS.fourth \
-borderwidth {2}
@@ -353,9 +352,8 @@
-borderwidth {2}
label .frame0.frameNMS.first.label \
- -anchor {n} \
- -wraplength 160 \
- -text [G_msg "Create new mapset\nin selected location"]
+ -wraplength 200 \
+ -text [G_msg "Create new mapset in selected location"]
entry .frame0.frameNMS.second.entry \
-relief {sunken} \
@@ -364,7 +362,7 @@
button .frame0.frameNMS.third.button \
-text [G_msg "Create new mapset"] \
- -width 20 -bd 1 -wraplength 160 \
+ -padx 10 -bd 1 -wraplength 150 \
-command {
set mymapset [ string trim $mymapset ]
if { [file exists $mymapset] } {
@@ -409,14 +407,13 @@
label .frame0.frameNMS.fourth.label \
- -anchor {n} \
- -wraplength 160 \
+ -wraplength 200 \
-text [G_msg "Define new location with..."]
button .frame0.frameNMS.fifth.button \
-text [G_msg "Georeferenced file"] \
- -width 20 -bd 1 -wraplength 160\
+ -width 22 -bd 1 -wraplength 150\
-relief raised \
-command {putGRASSRC $gisrc_name
fileOpt::fileLocCom
@@ -429,7 +426,7 @@
button .frame0.frameNMS.sixth.button \
-text [G_msg "EPSG codes"] \
-relief raised \
-command { putGRASSRC $gisrc_name
if { [epsgOpt::epsgLocCom] } {
@@ -442,7 +439,7 @@
button .frame0.frameNMS.seventh.button \
-text [G_msg "Projection values"] \
-relief raised \
-command {
if { $mingw == "1" } {
@@ -455,20 +452,21 @@
pack append .frame0.frameNMS
- pack .frame0.frameNMS.first.label -side top
- pack .frame0.frameNMS.second.entry -side top -fill x
- pack .frame0.frameNMS.third.button -side top -fill x
- pack .frame0.frameNMS.fifth.button -side bottom -fill x
- pack .frame0.frameNMS.sixth.button -side bottom -fill x
- pack .frame0.frameNMS.seventh.button -side bottom -fill x
- pack .frame0.frameNMS.fourth.label -side bottom
- pack .frame0.frameNMS.first -side top -anchor n
- pack .frame0.frameNMS.second -side top -expand yes
- pack .frame0.frameNMS.third -side top -anchor n -expand yes
- pack .frame0.frameNMS.seventh -side bottom -anchor s -expand yes
- pack .frame0.frameNMS.sixth -side bottom -anchor s -expand yes
- pack .frame0.frameNMS.fifth -side bottom -anchor s -expand yes
- pack .frame0.frameNMS.fourth -side bottom -anchor s -expand yes
+ pack .frame0.frameNMS.first.label
+ pack .frame0.frameNMS.second.entry
+ pack .frame0.frameNMS.third.button
+ pack .frame0.frameNMS.fourth.label
+ pack .frame0.frameNMS.fifth.button
+ pack .frame0.frameNMS.sixth.button
+ pack .frame0.frameNMS.seventh.button
+ pack .frame0.frameNMS.spacer
# build .frame0.frameBUTTONS
@@ -479,7 +477,7 @@
button .frame0.frameBUTTONS.ok \
-text [G_msg "Enter GRASS"] \
- -width 10 -bd 1 -fg green4 -default active -wraplength 100 \
+ -padx 10 -bd 1 -fg green4 -default active -wraplength 100 \
-command {
if {[CheckLocation] == 0} {
DialogGen .wrnDlg [G_msg "WARNING: invalid location"] warning \
@@ -506,7 +504,7 @@
button .frame0.frameBUTTONS.help \
-text [G_msg "Help"] \
- -width 10 -bd 1 -wraplength 100 \
+ -padx 10 -bd 1 -wraplength 100 \
-bg honeydew2 \
-command {
if { [winfo exists .help] } {
@@ -524,7 +522,7 @@
button .frame0.frameBUTTONS.cancel \
-text [G_msg "Exit"] \
-command { exit 2 }
@@ -539,10 +537,14 @@
# packed it all
+ frame .frame0.frameSpacer \
+ -borderwidth {2} -height {5}
# pack widget .frame0
pack append .frame0 \
- .frame0.frameDB { top expand fill } \
+ .frame0.frameDB { top } \
.frame0.frameBUTTONS { bottom expand fill } \
+ .frame0.frameSpacer { bottom } \
.frame0.frameLOC { left expand } \
.frame0.frameMS { left expand } \
.frame0.frameNMS { left expand fill }
