[GRASS-SVN] r29615 -
grass/branches/releasebranch_6_3/lib/vector/Vlib
svn_grass at osgeo.org
Tue Jan 8 08:46:14 EST 2008
Author: neteler
Date: 2008-01-08 08:46:14 -0500 (Tue, 08 Jan 2008)
New Revision: 29615
grass/branches/releasebranch_6_3/lib/vector/Vlib/legal_vname.c
GForge/520: SQL parser error if output name is 'and', 'or' or 'not'. Check only for and/or/not. (merge from HEAD)
Modified: grass/branches/releasebranch_6_3/lib/vector/Vlib/legal_vname.c
--- grass/branches/releasebranch_6_3/lib/vector/Vlib/legal_vname.c 2008-01-08 13:44:30 UTC (rev 29614)
+++ grass/branches/releasebranch_6_3/lib/vector/Vlib/legal_vname.c 2008-01-08 13:46:14 UTC (rev 29615)
@@ -19,14 +19,17 @@
\fn int Vect_legal_filename (char *s)
\brief Check if output is legal vector name.
Rule: [A-Za-z][A-Za-z0-9_@]*
- \param[in] s filename to be checked
+ Check also for SQL keywords.
- \return 1 OK
- \return -1 if name does not start with letter A..Za..z or if name does not continue with A..Za..z0..9_@
+ \param[in] s filename to be checked
+ \return 1 OK
+ \return -1 if name does not start with letter A..Za..z or if name does not continue with A..Za..z0..9_@
@@ -47,11 +50,22 @@
for (s++ ; *s; s++)
- if (! ((*s >= 'A' && *s <= 'Z') || (*s >= 'a' && *s <= 'z') || (*s >= '0' && *s <= '9') || *s == '_' || *s == '@' ) ) {
+ if (! ((*s >= 'A' && *s <= 'Z') || (*s >= 'a' && *s <= 'z') ||
+ (*s >= '0' && *s <= '9') || *s == '_' || *s == '@' ) ) {
G_warning (_("Illegal vector map name <%s>. Character '%c' not allowed."), buf, *s);
return -1;
+ /* full list of SQL keywords available at
+ http://www.postgresql.org/docs/8.2/static/sql-keywords-appendix.html
+ if (G_strcasecmp(buf, "and") == 0 ||
+ G_strcasecmp(buf, "or") == 0 ||
+ G_strcasecmp(buf, "not") == 0) {
+ G_warning (_("Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."), buf);
+ return -1;
return 1;
