[GRASS-SVN] r29622 - grass/trunk
Tue Jan 8 16:13:05 EST 2008
Author: martinl
Date: 2008-01-08 16:13:05 -0500 (Tue, 08 Jan 2008)
New Revision: 29622
   grass/trunk/SUBMITTING
Explain doxygen style
Modified: grass/trunk/SUBMITTING
--- grass/trunk/SUBMITTING	2008-01-08 14:12:02 UTC (rev 29621)
+++ grass/trunk/SUBMITTING	2008-01-08 21:13:05 UTC (rev 29622)
@@ -380,14 +380,58 @@
     http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
-30. Tell the other developers about the new code using the following e-mail:
+30. Use doxygen style for source code documentation. It is required
+    for GRASS libraries, but also recommended for GRASS modules.
+    Do not use structural command inside documentation block since it
+    leads to some duplication of information (e.g. do not use \fn
+    command in comment blocks). The exception is \file command for
+    documenting a file, in this case structural command is required.
+    For files
+       \file snap.c
+       \brief Vector library - Clean vector map (snap lines)
+       (C) 2001-2008 by the GRASS Development Team
+       This program is free software under the
+       GNU General Public License (>=v2).
+       Read the file COPYING that comes with GRASS
+       for details.
+       \author Radim Blazek
+       \date 2001-2008
+    For functions
+       \brief Snap lines in vector map to existing vertex in threshold
+       For details see Vect_snap_lines_list()
+       \param[in] Map input vector map
+       \param[in] type type of lines to be snap
+       \param[in] thresh threshold value for snapping
+       \param[out] Err vector map where lines representing snap are written or NULL
+       \param[out] msgout file pointer where messages will be written or NULL
+       \return
+31. Tell the other developers about the new code using the following e-mail:
     grass-dev at lists.osgeo.org
     To subscribe to this mailing list, see
     http://lists.osgeo.org/mailman/listinfo/grass-dev
-31. In case of questions feel free to contact the developers at the above
+32. In case of questions feel free to contact the developers at the above
     mailing list.
     http://www.grass-gis.org/devel/index.php#submission
