[GRASS-SVN] r29642 - grass/trunk/lib/gis
Wed Jan 9 15:07:37 EST 2008
Author: martinl
Date: 2008-01-09 15:07:37 -0500 (Wed, 09 Jan 2008)
New Revision: 29642
   grass/trunk/lib/gis/get_ellipse.c
   grass/trunk/lib/gis/key_value1.c
   grass/trunk/lib/gis/key_value2.c
   grass/trunk/lib/gis/key_value3.c
   grass/trunk/lib/gis/key_value4.c
Doxygen documentation updated
Modified: grass/trunk/lib/gis/get_ellipse.c
--- grass/trunk/lib/gis/get_ellipse.c	2008-01-09 17:44:32 UTC (rev 29641)
+++ grass/trunk/lib/gis/get_ellipse.c	2008-01-09 20:07:37 UTC (rev 29642)
@@ -1,10 +1,32 @@
-#include <grass/gis.h>
-#include <grass/glocale.h>
+   \file get_ellipse.c
+   \brief Getting ellipsoid parameters from the database.
+   This routine returns the ellipsoid parameters from the database.
+   If the PROJECTION_FILE exists in the PERMANENT mapset, read info
+   from that file, otherwise return WGS 84 values.
+   Returns: 1 ok, 0 default values used.
+   Dies with diagnostic if there is an error
+   (C) 2001-2008 by the GRASS Development Team
+   This program is free software under the
+   GNU General Public License (>=v2).
+   Read the file COPYING that comes with GRASS
+   for details.
+   \author CERL
 #include <unistd.h>
 #include <ctype.h>
 #include <string.h>
 #include <stdlib.h>
 #include <math.h>  /* for sqrt() */
+#include <grass/gis.h>
+#include <grass/glocale.h>
 static struct table
@@ -23,42 +45,20 @@
 static int compare_table_names(const void *, const void *);
 static int read_ellipsoid_table(int );
- * This routine returns the ellipsoid parameters from the database.
- * If the PROJECTION_FILE exists in the PERMANENT mapset, read info from
- * that file, otherwise return WGS 84 values.
- * Returns: 1 ok, 0 default values used.
- * Dies with diagnostic if there is an error
  * \brief get ellipsoid parameters
- * This routine returns the semi-major axis <b>a</b> (in meters)
- * and the eccentricity squared <b>e2</b> for the ellipsoid associated with the
- * database. If there is no ellipsoid explicitly associated with the database, it
- * returns the values for the WGS 84 ellipsoid.
+ * This routine returns the semi-major axis <b>a</b> (in meters) and
+ * the eccentricity squared <b>e2</b> for the ellipsoid associated
+ * with the database. If there is no ellipsoid explicitly associated
+ * with the database, it returns the values for the WGS 84 ellipsoid.
- *  \param a
- *  \param e2
- *  \return int
- * \brief get ellipsoid parameters
+ * \param[out] a semi-major axis
+ * \param[out] e2 eccentricity squared
- *  \param a
- *  \param e2
- *  \return int
+ * \return 1 success
+ * \return 0 default values used
 int
 G_get_ellipsoid_parameters (double *a, double *e2)
@@ -70,40 +70,44 @@
     proj_keys = NULL;
     G__file_name (ipath, "", PROJECTION_FILE, PERMANENT);
     if (access(ipath,0) !=0)
 	*a = 6378137.0 ;
 	*e2 = .006694385 ;
 	return 0;
     proj_keys = G_read_key_value_file(ipath, &in_stat);
     if (in_stat !=0)
-	sprintf (err, _("Unable to open file %s in %s"),PROJECTION_FILE,PERMANENT);
-	G_fatal_error (err);
+	G_fatal_error (_("Unable to open file %s in <%s>"),
+		       PROJECTION_FILE, PERMANENT);
     if ((str = G_find_key_value("ellps",proj_keys))!=NULL) {
       if (strncmp(str,"sphere",6)==0) {
         str = G_find_key_value("a",proj_keys);
         if (str!=NULL)  {
           if(sscanf(str,"%lf",a)!=1) {
-	    sprintf (err, _("invalid a: field %s in file %s in %s")
-                              ,str,PROJECTION_FILE,PERMANENT);
+	    sprintf (err, );
+	    G_fatal_error (_("Invalid a: field '%s' in file %s in <%s>"),
+			   str, PROJECTION_FILE, PERMANENT);
         else {
 	  *a = 6370997.0 ;
 	*e2 = 0.0 ;
 	G_free_key_value(proj_keys);
 	return 0;
       else {
         if (G_get_ellipsoid_by_name (str, a, e2)==0) {
-	  sprintf (err, _("invalid ellipsoid %s in file %s in %s")
+	    G_fatal_error (_("Invalid ellipsoid '%s' in file %s in <%s>"),
         else {
@@ -116,15 +120,14 @@
       str1 = G_find_key_value("es",proj_keys);
       if ((str!=NULL) && (str1!=NULL)) {
         if(sscanf(str1,"%lf",e2)!=1) {
-	  sprintf (err, _("invalid es: field %s in file %s in %s")
+	    G_fatal_error(_("Invalid es: field '%s' in file %s in <%s>"),
+			  str,PROJECTION_FILE,PERMANENT);
         return 1;
@@ -137,9 +140,8 @@
 	  return 0;
         else {
- 	  sprintf (err, _("No ellipsoid info given in file %s in %s"),
-                                        PROJECTION_FILE,PERMANENT);
+	    G_fatal_error(_("No ellipsoid info given in file %s in <%s>"),
+			  PROJECTION_FILE,PERMANENT);
@@ -151,42 +153,20 @@
     return 0;
- * looks up ellipsoid in ellipsoid table and returns the
- * a, e2 parameters for the ellipsoid
- * returns 1 if ok,
- *         0 if not found in table
- * \brief get ellipsoid by name
- * meters) and eccentricity squared <b>e2</b> for the named ellipsoid.  Returns
- * 1 if <b>name</b> is a known ellipsoid, 0 otherwise.
- *  \param name
- *  \param a
- *  \param e2
- *  \return int
  * \brief get ellipsoid parameters by name
+ * eccentricity squared <b>e2</b> for the named ellipsoid.  Returns 1
+ * if <b>name</b> is a known ellipsoid, 0 otherwise.
- *  \param name
- *  \param a
- *  \param e2
- *  \return int
+ * \param[in]  name ellipsoid name
+ * \return 1 on success
+ * \return 0 if ellipsoid not found
 int
 G_get_ellipsoid_by_name (const char *name, double *a, double *e2)
@@ -206,63 +186,18 @@
     return 0;
- * returns name(s) of ellipsoid
- * for (i = 0; name = G_ellipsoid_name(i); i++)
- * \brief return ellopsoid name
+ * \brief get ellipsoid name
- * This routine
- * returns a pointer to a string containg the name for the <b>n</b><i>th</i>
- * ellipsoid in the GRASS ellipsoid table; NULL when <b>n</b> is too large. It
- * can be used as follows:
- \code
-  int n ;
-  char *name ;
-  for ( n=0 ; name=G_ellipsoid_name(n) ; n++ )
-     fprintf(stdout, "%s\n", name);
- \endcode
+ * This function returns a pointer to the short name for the
+ * <b>n</b><i>th</i> ellipsoid.  If <b>n</b> is less than 0 or greater
+ * than the number of known ellipsoids, it returns a NULL pointer.
- *  \param n
- *  \return char *
+ * \param[in] n ellipsoid identificator
- * This routine
- * ellipsoid in the GRASS ellipsoid table; NULL when <b>n</b> is below zero or
- * too large. It can be used as follows:
- \code
-  int n ;
-  char *name ;
- \endcode
- *  \param n
- *  \return char *
+ *  \return char * ellipsoid name
+ *  \return NULL if no ellipsoid found
- * \brief get ellipsoid name
- * This function
- * returns a pointer to the short name for the <b>n</b><i>th</i> ellipsoid.
- * If <b>n</b> is less than 0 or greater than the number of known ellipsoids,
- * it returns a NULL pointer.
- *  \param n
- *  \return char *
 char *
 G_ellipsoid_name (int n)
@@ -284,18 +219,19 @@
  * \brief get spheroid parameters by name
- * This function returns the
- * semi-major axis <b>a</b> (in meters), the eccentricity squared <b>e2</b>
- * and the inverse flattening <b>f</b> for the named ellipsoid. Returns 1 if
- * <b>name</b> is a known ellipsoid, 0 otherwise.
+ * This function returns the semi-major axis <b>a</b> (in meters), the
+ * eccentricity squared <b>e2</b> and the inverse flattening <b>f</b>
+ * for the named ellipsoid. Returns 1 if <b>name</b> is a known
+ * ellipsoid, 0 otherwise.
- *  \param name
- *  \param a
- *  \param e2
- *  \param f
- *  \return int
+ * \param[in] name spheroid name
+ * \param[out] f   inverse flattening
+ * \return 0 if no spheroid found
 int
 G_get_spheroid_by_name(const char *name, double *a, double *e2, double *f)
@@ -320,13 +256,14 @@
  * \brief get description for <b>n</b><i>th</i> ellipsoid
- * This function returns a pointer to the
- * description text for the <b>n</b><i>th</i> ellipsoid. If <b>n</b> is less
- * than 0 or greater than the number of known ellipsoids, it returns a NULL
- * pointer.
+ * This function returns a pointer to the description text for the
- *  \param n
- *  \return char *
+ * \return pointer to ellipsoid description
 char *
@@ -414,7 +351,7 @@
     if (fd == NULL)
 	perror (file);
-	sprintf (buf, _("unable to open ellipsoid table file: %s"), file);
+	sprintf (buf, _("Unable to open ellipsoid table file <%s>"), file);
 	fatal ? G_fatal_error(buf) : G_warning (buf);
 	return 0;
Modified: grass/trunk/lib/gis/key_value1.c
--- grass/trunk/lib/gis/key_value1.c	2008-01-09 17:44:32 UTC (rev 29641)
+++ grass/trunk/lib/gis/key_value1.c	2008-01-09 20:07:37 UTC (rev 29642)
@@ -1,3 +1,18 @@
+   \file key_value1.c
+   \brief Key_Value management.
+   for details.
+   \author CERL
 #include <string.h>
 #include <stdlib.h>
@@ -2,2 +17,7 @@
+  \brief Allocate and initialize Key_Value structure
+  \return poiter to allocated Key_Value structure
 struct Key_Value *
@@ -19,12 +39,20 @@
     return kv;
-/* if key has spaces in it, this will break the logic
- * so rule is: NO SPACES IN key
- * returns 0 - no memory
- *         1 - ok, but key was NULL or "" so ignored
- *         2 - ok
+  \brief Set value for given key
+  If key has spaces in it, this will break the logic
+  so rule is: NO SPACES IN key.
+  \param[in] key key to be set up
+  \param[in] value value for given key
+  \param[in,out] kv Key_value structure to be modified
+  \return 0 no memory
+  \return 1 ok, but key was NULL or "" so ignored
+  \return 2 ok
 int G_set_key_value (
     const char *key, const char *value,
     struct Key_Value *kv)
@@ -99,6 +127,15 @@
     return 2;
+  \brief Find given key
+  \param[in] key key to be found
+  \param[in] kv Key_value structure
+  \return poiter to value of key
+  \return NULL if no key found
 char *G_find_key_value (const char *key, const struct Key_Value *kv)
     int n;
@@ -109,6 +146,13 @@
     return NULL;
+  \brief Free allocated Key_Value structure
+  \param[in] kv Key_Value structure
+  \return 0
 int G_free_key_value(struct Key_Value *kv)
     int n;
Modified: grass/trunk/lib/gis/key_value2.c
--- grass/trunk/lib/gis/key_value2.c	2008-01-09 17:44:32 UTC (rev 29641)
+++ grass/trunk/lib/gis/key_value2.c	2008-01-09 20:07:37 UTC (rev 29642)
@@ -1,9 +1,29 @@
+   \file key_value2.c
+   \brief Read/write Key_Value from/to file.
+   for details.
+   \author CERL
-/* returns 0, ok
- * -1 error writing
+  \brief Write key/value pairs to file
+  \param[in,out] fd file to write to
+  \return 0 success
+  \return -1 error writing
 int G_fwrite_key_value (
     FILE *fd,
@@ -21,6 +41,16 @@
     return err;
+  \brief Read key/values pairs from file
+  Allocated memory must be freed G_free_key_value().
+  \param[in] fd file to read key/values from
+  \return pointer to allocated Key_Value structure
+  \return NULL on error
 struct Key_Value *
 G_fread_key_value  (FILE *fd)
Modified: grass/trunk/lib/gis/key_value3.c
--- grass/trunk/lib/gis/key_value3.c	2008-01-09 17:44:32 UTC (rev 29641)
+++ grass/trunk/lib/gis/key_value3.c	2008-01-09 20:07:37 UTC (rev 29642)
@@ -1,5 +1,31 @@
+   \file key_value3.c
+   for details.
+   \author CERL
+  \param[in]  file filename for writing
+  \param[out] stat status (0 ok, -3 cannot open file, -4 error writing key/value)
+  \return 0 success
+  \return 1 error writing
 int G_write_key_value_file (
     const char *file,
     const struct Key_Value *kv,
@@ -16,6 +42,17 @@
     return (*stat != 0);
+  \param[in]  file filename for reading
+  \param[out] stat status (0 ok, -1 cannot open file, -2 error writing key/value)
 struct Key_Value *G_read_key_value_file(const char *file, int *stat)
     FILE *fd;
Modified: grass/trunk/lib/gis/key_value4.c
--- grass/trunk/lib/gis/key_value4.c	2008-01-09 17:44:32 UTC (rev 29641)
+++ grass/trunk/lib/gis/key_value4.c	2008-01-09 20:07:37 UTC (rev 29642)
@@ -1,11 +1,33 @@
+   \file key_value4.c
+   for details.
+   \author CERL
 #include <string.h>
-/* -1 can't open file for reading
- * -2 no memory for key,value info, file not modified
- * -3 can't open file for re-write
- * -4 error writing the file (might be damaged)
+  \brief Update file, set up value for given key
+  \param[in] file  filename to be updated
+  \param[in] key   key value
+  \param[in] value value to be updated
+  \return -1 can't open file for reading
+  \return -2 no memory for key,value info, file not modified
+  \return -3 can't open file for re-write
+  \return -4 error writing the file (might be damaged)
 int G_update_key_value_file (const char *file, const char *key, const char *value)
     struct Key_Value *kv;
@@ -27,10 +49,18 @@
     return stat;
-/* returns: <0 are file/memory errors
- *           0 not found
- *           1 ok
+  \brief Look up for key in file
+  \param[in]  key   key to be found in file
+  \param[out] value value for key
+  \param[in]  n     number of characters to be copied
+  \return <0 are file/memory errors
+  \return 0 not found
+  \return 1 ok
 int G_lookup_key_value_from_file(
     const char *file,
     const char *key,
