[GRASS-SVN] r29659 - grass/trunk/scripts/r.mask
Thu Jan 10 13:07:46 EST 2008
Author: epatton
Date: 2008-01-10 13:07:46 -0500 (Thu, 10 Jan 2008)
New Revision: 29659
   grass/trunk/scripts/r.mask/description.html
Consolidated description; reorganized sections; new examples added
Modified: grass/trunk/scripts/r.mask/description.html
--- grass/trunk/scripts/r.mask/description.html	2008-01-10 16:18:22 UTC (rev 29658)
+++ grass/trunk/scripts/r.mask/description.html	2008-01-10 18:07:46 UTC (rev 29659)
@@ -3,67 +3,92 @@
 <em><b>r.mask</b></em> - Facilitates creation of a raster "MASK" map to
 control raster operations.
-<!-- a bit of repetition here, requires some consolidation -->
+<p>
+The MASK is only applied when <em>reading</em> an existing GRASS raster map,
+for example when used in a module as an input map.
 The MASK will block out certain areas of a raster map from analysis, by
-"hiding" them from sight of other GRASS modules. While a mask exists, most
-GRASS raster modules will operate only on data falling inside the masked
-area, and treat any data falling outside of the mask as if its value were
-NULL.
-<P>
-The mask is only applied when <em>reading</em> an existing GRASS raster map,
-for example when used in a module as an input map.
-<P>
-<em>r.mask</em> uses <em>r.reclass</em> to create a reclassification of an
-existing raster map and name it MASK. The user can select cat values to use
-in the MASK.
-<P>
-Because the mask is actually only a reclass map named "MASK", it can be
+"hiding" them from sight of other GRASS modules. Data falling within the bounaries of the MASK
+can be modified and operated upon by other GRASS raster modules; data
+falling outside the MASK is treated as if it were NULL.
+<p>
+Because the MASK is actually only a reclass map named "MASK", it can be
 copied, renamed, removed, and used in analyses, just like other GRASS
-raster map layers.  The user should be aware that a mask remains in
+raster map layers.  The user should be aware that a MASK remains in
 place until a user renames it to something other than "MASK", or removes
-it using "<tt>r.mask -r</tt>" or <EM><A HREF="g.remove.html">g.remove</A></EM>.
+it using "<tt>r.mask -r</tt>" or <em><a HREF="g.remove.html">g.remove</a></em>.
 <p>
-As long as the file named MASK exists in the current mapset, most
-raster operations will only take place in the grid cells specified by
-the MASK. Grid cells in the MASK map containing <tt>0</tt> or <tt>NULL</tt>
-will replace data with NULL, cells containing other values will allow
+Grid cells in the MASK map containing <tt>0</tt> or <tt>NULL</tt>
+will replace data with NULL, while cells containing other values will allow
 data to pass through unaltered.
 <p>
 To restore raster operations to normal (i.e., all cells of the current region),
-remove the MASK file by setting the <B>-r</B> remove MASK flag.
+remove the MASK file by setting the <b>-r</b> remove MASK flag. In this case, a
+dummy value must also be given for the input parameter.
 A MASK also can&nbsp;be removed by using <em><a href="g.remove.html">g.remove</a></em>
 or by renaming it to any other name with <em><a href="g.rename.html">g.rename</a></em>.
-<H2>NOTES</H2>
+<h2>NOTES</h2>
 The above method for specifying a "mask" may seem
-counterintuitive.  Areas inside the mask are not hidden;
-areas outside the mask will be ignored until the MASK file
+counterintuitive.  Areas inside the MASK are not hidden;
+areas outside the MASK will be ignored until the MASK file
 is removed.
+<p>
-<P>
+<em>r.mask</em> uses <em>r.reclass</em> to create a reclassification of an
+existing raster map and name it MASK. The user can select category values to use
+in the MASK with the <em>maskcats</em> parameter; if <em>r.mask</em>
+is run from the command line, the category values listed in <em>maskcats</em>
+must be quoted (see example below).
+<p>
 Somewhat similar program functions to those performed by
-<EM>r.mask</EM> can be done using
-<EM><A HREF="r.mapcalc.html">r.mapcalc</A></EM>,
-<EM><A HREF="g.region.html">g.region</A></EM>,
+<em>r.mask</em> can be done using
+<em><a HREF="r.mapcalc.html">r.mapcalc</a></em>,
+<em><a HREF="g.region.html">g.region</a></em>,
 and other programs.
 <p>
 <em>(GRASS Shell Script)</em>
+<h2>EXAMPLES</h2>
+Creating a raster mask:
+<div class="code"><pre>
+<b>r.mask input=</b>geology
+MASK created. All subsequent raster operations
+will be limited to MASK area
+Removing or renaming raster file named MASK will
+restore raster operations to normal
+[Raster MASK present]
+</pre></div>
+Removing a raster mask with the -r flag:
+<b>r.mask -r input=</b>anything_you_wish
+Removing raster <MASK>
+Raster MASK removed
+</pre></div>
+Creating a mask from categories 3 through 6 in the spearfish 'geology' raster map:
+<b>r.mask input=</b>geology <b>maskcats=</b>"3 thru 6"
 <h2>SEE ALSO</h2>
 <em>
-<A HREF="g.region.html">g.region</A>,
-<A HREF="r.mapcalc.html">r.mapcalc</A>,
+<a HREF="g.region.html">g.region</a>,
+<a HREF="r.mapcalc.html">r.mapcalc</a>,
 <a href="r.reclass.html">r.reclass</a>
+<a href="g.remove.html">g.remove</a>
+<a href="g.rename.html">g.rename</a>
 </em>
 <h2>AUTHOR</h2>
