[GRASS-SVN] r29670 - grass/trunk/lib/gis
svn_grass at osgeo.org
Fri Jan 11 15:45:31 EST 2008
Author: neteler
Date: 2008-01-11 15:45:31 -0500 (Fri, 11 Jan 2008)
New Revision: 29670
grass/trunk/lib/gis/ask.c
grass/trunk/lib/gis/closecell.c
grass/trunk/lib/gis/color_read.c
grass/trunk/lib/gis/color_write.c
grass/trunk/lib/gis/get_ellipse.c
grass/trunk/lib/gis/get_projinfo.c
grass/trunk/lib/gis/get_projname.c
grass/trunk/lib/gis/get_window.c
grass/trunk/lib/gis/make_loc.c
grass/trunk/lib/gis/make_mapset.c
grass/trunk/lib/gis/myname.c
grass/trunk/lib/gis/open.c
grass/trunk/lib/gis/opencell.c
grass/trunk/lib/gis/remove.c
grass/trunk/lib/gis/rename.c
changed to use GPATH_MAX, GMAPSET_MAX, GNAME_MAX
Modified: grass/trunk/lib/gis/ask.c
--- grass/trunk/lib/gis/ask.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/ask.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -349,8 +349,8 @@
int (*lister)(),
int type)
- char tmapset[256];
- char xname[512], xmapset[512];
+ char tmapset[GMAPSET_MAX];
+ char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
int name_is_qualified;
int ok;
char tprompt[256];
Modified: grass/trunk/lib/gis/closecell.c
--- grass/trunk/lib/gis/closecell.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/closecell.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -162,7 +162,7 @@
int stat;
struct Categories cats;
struct History hist;
- char path[4096];
+ char path[GPATH_MAX];
CELL cell_min, cell_max;
int row, i, open_mode;
Modified: grass/trunk/lib/gis/color_read.c
--- grass/trunk/lib/gis/color_read.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/color_read.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -63,9 +63,9 @@
struct Colors *colors )
int fp;
- char buf[512];
+ char buf[GNAME_MAX];
char *err;
struct Range range;
struct FPRange drange;
CELL min, max;
Modified: grass/trunk/lib/gis/color_write.c
--- grass/trunk/lib/gis/color_write.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/color_write.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -76,7 +76,7 @@
int G_write_colors (const char *name, const char *mapset, struct Colors *colors)
char element[512];
FILE *fd;
int stat;
Modified: grass/trunk/lib/gis/get_ellipse.c
--- grass/trunk/lib/gis/get_ellipse.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/get_ellipse.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -63,7 +63,7 @@
G_get_ellipsoid_parameters (double *a, double *e2)
int in_stat;
- char ipath[1024], *str, *str1;
+ char ipath[GPATH_MAX], *str, *str1;
struct Key_Value *proj_keys;
static char *PERMANENT = "PERMANENT";
Modified: grass/trunk/lib/gis/get_projinfo.c
--- grass/trunk/lib/gis/get_projinfo.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/get_projinfo.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -28,7 +28,7 @@
int stat;
struct Key_Value *in_units_keys;
- char path[1024];
G__file_name (path, "", UNIT_FILE, PERMANENT);
if (access(path,0) != 0)
@@ -59,7 +59,7 @@
int stat;
struct Key_Value *in_proj_keys;
- char path[1024];
G__file_name (path, "", PROJECTION_FILE, PERMANENT);
Modified: grass/trunk/lib/gis/get_projname.c
--- grass/trunk/lib/gis/get_projname.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/get_projname.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -1,6 +1,4 @@
- * $Id$
* MODULE: GRASS 5 gis library, get_projname.c
@@ -23,7 +21,7 @@
int G_ask_proj_name (char *proj_id, char *proj_name)
- char path[1024], buff[1024], answer[50], *a;
+ char path[GPATH_MAX], buff[GPATH_MAX], answer[50], *a;
char *Tmp_file;
FILE *Tmp_fd = NULL;
@@ -31,16 +29,10 @@
sprintf(path,"%s/etc/projections",G_gisbase());
while (access(path,0) !=0)
- sprintf(buff,_("%s not found"),path);
- G_fatal_error(buff);
+ G_fatal_error(_("%s not found"),path);
in_proj_keys = G_read_key_value_file(path,&in_stat);
if (in_stat != 0)
- sprintf(buff,_("ERROR in reading %s"),path);
+ G_fatal_error(_("ERROR in reading %s"),path);
npr = in_proj_keys->nitems;
Tmp_file = G_tempfile ();
if (NULL == (Tmp_fd = fopen (Tmp_file, "w"))) {
Modified: grass/trunk/lib/gis/get_window.c
--- grass/trunk/lib/gis/get_window.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/get_window.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -1,24 +1,24 @@
- * G_get_window (window)
- * struct Cell_head *window
- * read the current mapset window
- * dies if error
- * G_get_default_window (window)
- * read the default window for the location
- * dies if error
- * char *
- * G__get_window (window, element, name, mapset)
- * read the window 'name' in 'element' in 'mapset'
- * returns NULL if ok, error message if not
+* G_get_window (window)
+* struct Cell_head *window
+* read the current mapset window
+* dies if error
+* G_get_default_window (window)
+* read the default window for the location
+* dies if error
+* char *
+* G__get_window (window, element, name, mapset)
+* read the window 'name' in 'element' in 'mapset'
+* returns NULL if ok, error message if not
#include <stdlib.h>
#include "G.h"
@@ -27,119 +27,119 @@
- * \brief read the database region
- * Reads the database region as stored in the WIND file in the user's
- * current mapset <b>into region.</b>
- * 3D values are set to defaults if not available in WIND file.
- * An error message is printed and exit( ) is called if there is a problem reading
- * the region.
- * <b>Note.</b> GRASS applications that read or write raster maps should not
- * use this routine since its use implies that the active module region will not
- * be used. Programs that read or write raster map data (or vector data) can
- * query the active module region <i>using G_window_rows and
- * G_window_cols..</i>
- * \param region
- * \return int
+* \brief read the database region
+* Reads the database region as stored in the WIND file in the user's
+* current mapset <b>into region.</b>
+* 3D values are set to defaults if not available in WIND file.
+* An error message is printed and exit( ) is called if there is a problem reading
+* the region.
+* <b>Note.</b> GRASS applications that read or write raster maps should not
+* use this routine since its use implies that the active module region will not
+* be used. Programs that read or write raster map data (or vector data) can
+* query the active module region <i>using G_window_rows and
+* G_window_cols..</i>
+* \param region
+* \return int
int G_get_window (struct Cell_head *window )
- static int first = 1;
- static struct Cell_head dbwindow ;
- char *regvar;
+static int first = 1;
+static struct Cell_head dbwindow ;
+char *regvar;
- /* Optionaly read the region from enviroment variable */
- regvar = getenv("GRASS_REGION");
+/* Optionaly read the region from enviroment variable */
+regvar = getenv("GRASS_REGION");
- if ( regvar )
- char **tokens, *delm = ";";
- char *err;
- tokens = G_tokenize ( regvar, delm );
+if ( regvar )
+ char **tokens, *delm = ";";
+ char *err;
+ tokens = G_tokenize ( regvar, delm );
- err = G__read_Cell_head_array ( tokens, window, 0);
- G_free_tokens ( tokens );
+ err = G__read_Cell_head_array ( tokens, window, 0);
+ G_free_tokens ( tokens );
- if (err)
- G_fatal_error (_("region for current mapset %s\nrun \"g.region\""), err);
- G_free (err);
- return 1;
+ if (err)
+ G_fatal_error (_("region for current mapset %s\nrun \"g.region\""), err);
+ G_free (err);
- if (first)
- char *wind, *err;
+ return 1;
- wind = getenv("WIND_OVERRIDE");
- if (wind)
- err = G__get_window (&dbwindow,"windows",wind,G_mapset());
- else
- err = G__get_window (&dbwindow,"","WIND",G_mapset());
+if (first)
+ char *wind, *err;
- if (err)
- G_free (err);
+ wind = getenv("WIND_OVERRIDE");
+ if (wind)
+ err = G__get_window (&dbwindow,"windows",wind,G_mapset());
+ else
+ err = G__get_window (&dbwindow,"","WIND",G_mapset());
- first = 0;
- G_copy (window, &dbwindow, sizeof(dbwindow) ) ;
- if (!G__.window_set)
+ if (err)
- G__.window_set = 1;
- G_copy(&G__.window, &dbwindow, sizeof(dbwindow) ) ;
+ G_free (err);
- return 1;
+first = 0;
+G_copy (window, &dbwindow, sizeof(dbwindow) ) ;
+if (!G__.window_set)
+ G__.window_set = 1;
+ G_copy(&G__.window, &dbwindow, sizeof(dbwindow) ) ;
+return 1;
- * \brief read the default region
- * Reads the default region for the location into <b>region.</b>
- * reading the default region.
- * \param region
- * \return int
+* \brief read the default region
+* Reads the default region for the location into <b>region.</b>
+* reading the default region.
+* \param region
+* \return int
int G_get_default_window ( struct Cell_head *window )
- char *err;
+char *err;
- if ((err = G__get_window (window,"","DEFAULT_WIND","PERMANENT")))
- G_fatal_error (_("default region %s"), err);
- G_free (err);
- return 1;
+if ((err = G__get_window (window,"","DEFAULT_WIND","PERMANENT")))
+ G_fatal_error (_("default region %s"), err);
+ G_free (err);
+return 1;
char *G__get_window ( struct Cell_head *window,
- const char *element, const char *name, const char *mapset)
+ const char *element, const char *name, const char *mapset)
- FILE *fd ;
- char *err;
+FILE *fd ;
+char *err;
- G_zero ((char *) window, sizeof (struct Cell_head));
+G_zero ((char *) window, sizeof (struct Cell_head));
- /* Read from file */
- if (!(fd = G_fopen_old (element, name, mapset) ))
+/* Read from file */
+if (!(fd = G_fopen_old (element, name, mapset) ))
-char path[1024];
+char path[GPATH_MAX];
G__file_name (path,element,name,mapset);
fprintf (stderr, "G__get_window(%s)\n",path);
Modified: grass/trunk/lib/gis/make_loc.c
--- grass/trunk/lib/gis/make_loc.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/make_loc.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -48,7 +48,7 @@
FILE *report_file )
- char path[2048];
int out_stat;
/* Try to create the location directory, under the gisdbase. */
Modified: grass/trunk/lib/gis/make_mapset.c
--- grass/trunk/lib/gis/make_mapset.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/make_mapset.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -40,7 +40,7 @@
int G__make_mapset( const char *gisdbase_name, const char *location_name, const char *mapset_name )
- char path[2048];
struct Cell_head default_window;
/* Get location */
Modified: grass/trunk/lib/gis/myname.c
--- grass/trunk/lib/gis/myname.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/myname.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -35,7 +35,7 @@
G_myname(void)
static char name[GNAME_MAX];
- char path[500];
FILE *fd;
int ok;
Modified: grass/trunk/lib/gis/open.c
--- grass/trunk/lib/gis/open.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/open.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -89,8 +89,8 @@
const char *mapset,
int mode)
- char path[1024];
- char xname[512], xmapset[512], *dummy;
+ char xname[GNAME_MAX], xmapset[GMAPSET_MAX], *dummy;
G__check_gisinit();
Modified: grass/trunk/lib/gis/opencell.c
--- grass/trunk/lib/gis/opencell.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/opencell.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -363,7 +363,7 @@
/* save name and mapset */
if (G__name_is_fully_qualified(name, xname, xmapset))
fcb->name = G_store (xname);
else
Modified: grass/trunk/lib/gis/remove.c
--- grass/trunk/lib/gis/remove.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/remove.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -92,7 +92,7 @@
DIR *dirp;
struct dirent *dp;
struct stat sb;
- char path2[4096];
+ char path2[GPATH_MAX];
if(G_lstat(path, &sb))
return 1;
Modified: grass/trunk/lib/gis/rename.c
--- grass/trunk/lib/gis/rename.c 2008-01-11 20:44:30 UTC (rev 29669)
+++ grass/trunk/lib/gis/rename.c 2008-01-11 20:45:31 UTC (rev 29670)
@@ -65,7 +65,7 @@
const char *oldname, const char *newname)
const char *mapset;
char from[512], to[512];
/* name in mapset legal only if mapset is current mapset */
