[GRASS-SVN] r29679 - in grass/trunk: imagery/i.cluster lib/gis
lib/vector/Vlib raster/r.out.mpeg vector/v.clean
svn_grass at osgeo.org
Sat Jan 12 13:45:21 EST 2008
Author: martinl
Date: 2008-01-12 13:45:21 -0500 (Sat, 12 Jan 2008)
New Revision: 29679
grass/trunk/imagery/i.cluster/open_files.c
grass/trunk/lib/gis/gisinit.c
grass/trunk/lib/vector/Vlib/build_nat.c
grass/trunk/raster/r.out.mpeg/main.c
grass/trunk/vector/v.clean/prune.c
grass/trunk/vector/v.clean/rmdac.c
Do not use \r in _() macro, suppress xgettext warnings
Modified: grass/trunk/imagery/i.cluster/open_files.c
--- grass/trunk/imagery/i.cluster/open_files.c 2008-01-12 16:49:04 UTC (rev 29678)
+++ grass/trunk/imagery/i.cluster/open_files.c 2008-01-12 18:45:21 UTC (rev 29679)
@@ -31,11 +31,9 @@
mapset = ref.file[n].mapset;
if (G_find_cell (name, mapset) == NULL)
- if (!missing)
- G_warning(_("\7\n** The following raster maps in "
- "subgroup [%s] do not exist:"), subgroup);
missing = 1;
- G_message(_(" %s"), G_fully_qualified_name(name, mapset));
+ G_warning(_("Raster map <%s> do not exists in subgroup <%s>"),
+ G_fully_qualified_name(name, mapset), subgroup);
if (missing) exit(1);
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c 2008-01-12 16:49:04 UTC (rev 29678)
+++ grass/trunk/lib/gis/gisinit.c 2008-01-12 18:45:21 UTC (rev 29679)
@@ -98,7 +98,7 @@
int G__check_gisinit(void)
if (initialized) return 1;
- fprintf (stderr, _("\7ERROR: System not initialized. Programmer forgot to call G_gisinit()\n"));
+ G_warning (_("System not initialized. Programmer forgot to call G_gisinit()."));
G_sleep(3);
exit(EXIT_FAILURE);
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2008-01-12 16:49:04 UTC (rev 29678)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2008-01-12 18:45:21 UTC (rev 29679)
@@ -504,7 +504,7 @@
i++; j++;
- prnmsg (_("\r%d primitives registered \n"), plus->n_lines);
+ prnmsg ("\r%d %s \n", plus->n_lines, _("primitives registered"));
plus->built = GV_BUILD_BASE;
@@ -531,7 +531,7 @@
Vect_build_line_area ( Map, i, side );
- prnmsg (_("\r%d areas built \n%d isles built\n"), plus->n_areas, plus->n_isles );
+ prnmsg ("\r%d %s \n%d %s\n", plus->n_areas, _("areas built"), plus->n_isles, _("isles built"));
plus->built = GV_BUILD_AREAS;
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c 2008-01-12 16:49:04 UTC (rev 29678)
+++ grass/trunk/raster/r.out.mpeg/main.c 2008-01-12 18:45:21 UTC (rev 29679)
@@ -215,7 +215,7 @@
strcpy(name, vfiles[vnum][cnt]);
if (!quiet)
- G_message(_("\rReading file '%s'"), name);
+ G_message("\r%s <%s>", _("Reading file"), name);
mapset = G_find_cell2 (name, "");
if (mapset == NULL)
Modified: grass/trunk/vector/v.clean/prune.c
--- grass/trunk/vector/v.clean/prune.c 2008-01-12 16:49:04 UTC (rev 29678)
+++ grass/trunk/vector/v.clean/prune.c 2008-01-12 18:45:21 UTC (rev 29679)
@@ -190,7 +190,7 @@
if (G_verbose() > G_verbose_min())
- fprintf (stderr, _("\rRemoved vertices: %5d"), nremoved);
+ fprintf (stderr, "\r%s: %5d", _("Removed vertices"), nremoved);
fflush ( stderr );
Modified: grass/trunk/vector/v.clean/rmdac.c
--- grass/trunk/vector/v.clean/rmdac.c 2008-01-12 16:49:04 UTC (rev 29678)
+++ grass/trunk/vector/v.clean/rmdac.c 2008-01-12 18:45:21 UTC (rev 29679)
@@ -52,7 +52,7 @@
ndupl++;
- fprintf (stderr, _("\rDuplicate area centroids: %5d"), ndupl);
+ fprintf (stderr, "\r%s: %5d", _("Duplicate area centroids"), ndupl);
if (Err) {
Vect_write_line(Err, type, Points, Cats);
