[GRASS-SVN] r29701 - grass/trunk
svn_grass at osgeo.org
Sun Jan 13 16:24:34 EST 2008
Author: martinl
Date: 2008-01-13 16:24:33 -0500 (Sun, 13 Jan 2008)
New Revision: 29701
grass/trunk/configure
grass/trunk/configure.in
configure: --with-wxpython option added
Modified: grass/trunk/configure
--- grass/trunk/configure 2008-01-13 19:29:42 UTC (rev 29700)
+++ grass/trunk/configure 2008-01-13 21:24:33 UTC (rev 29701)
@@ -67,6 +67,8 @@
ac_help="$ac_help
--with-python support PYTHON functionality (default: no)"
ac_help="$ac_help
+ --with-wxpython support wxPython functionality (default: no)"
+ac_help="$ac_help
--with-gdal[=path/gdal-config] enable GDAL/OGR support (gdal-config with path, \
e.g. '--with-gdal=/usr/local/bin/gdal-config')"
ac_help="$ac_help
@@ -715,7 +717,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:719: checking host system type" >&5
+echo "configure:721: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -738,7 +740,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:742: checking for $ac_word" >&5
+echo "configure:744: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -765,7 +767,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:769: checking for $ac_word" >&5
+echo "configure:771: checking for $ac_word" >&5
@@ -813,7 +815,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:817: checking for $ac_word" >&5
+echo "configure:819: checking for $ac_word" >&5
@@ -842,7 +844,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:846: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:848: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -853,12 +855,12 @@
cat > conftest.$ac_ext << EOF
-#line 857 "configure"
+#line 859 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -884,19 +886,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:888: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:890: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:893: checking whether we are using GNU C" >&5
+echo "configure:895: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:902: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -914,7 +916,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:918: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:920: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -943,10 +945,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:947: checking for Cygwin environment" >&5
+echo "configure:949: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 950 "configure"
+#line 952 "configure"
int main() {
@@ -957,7 +959,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:963: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -973,17 +975,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:977: checking for mingw32 environment" >&5
+echo "configure:979: checking for mingw32 environment" >&5
-#line 980 "configure"
+#line 982 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1001,7 +1003,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1005: checking for executable suffix" >&5
+echo "configure:1007: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1009,10 +1011,10 @@
rm -f conftest*
echo 'int main () { return 0; }' > conftest.$ac_ext
ac_cv_exeext=
- if { (eval echo configure:1013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
+ if { (eval echo configure:1015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; }; then
for file in conftest.*; do
case $file in
- *.c | *.o | *.obj) ;;
+ *.$ac_ext | *.c | *.o | *.obj) ;;
*) ac_cv_exeext=`echo $file | sed -e s/conftest//` ;;
esac
done
@@ -1034,23 +1036,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1038: checking for full floating-point support" >&5
+echo "configure:1040: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1043: checking whether "cc -mieee" works" >&5
+echo "configure:1045: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1047 "configure"
+#line 1049 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1066,7 +1068,7 @@
else
-#line 1070 "configure"
+#line 1072 "configure"
#include <float.h>
@@ -1080,7 +1082,7 @@
EOF
-if { (eval echo configure:1084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1093,14 +1095,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1097: checking for full floating-point support with -mieee" >&5
+echo "configure:1099: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1104 "configure"
+#line 1106 "configure"
#include <float.h>
@@ -1114,7 +1116,7 @@
EOF
-if { (eval echo configure:1118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1151,7 +1153,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1155: checking for $ac_word" >&5
+echo "configure:1157: checking for $ac_word" >&5
case "$pwd" in
@@ -1189,7 +1191,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1193: checking for source directory" >&5
+echo "configure:1195: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1200,7 +1202,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1204: checking for build directory" >&5
+echo "configure:1206: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1263,7 +1265,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1267: checking for MacOSX App" >&5
+echo "configure:1269: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1286,7 +1288,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1290: checking how to build libraries" >&5
+echo "configure:1292: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1329,7 +1331,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1333: checking for $ac_word" >&5
+echo "configure:1335: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1354,7 +1356,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1358: checking how to run the C preprocessor" >&5
+echo "configure:1360: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1367,13 +1369,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1371 "configure"
+#line 1373 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1379: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1384,13 +1386,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1388 "configure"
+#line 1390 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1396: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1401,13 +1403,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1405 "configure"
+#line 1407 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1411: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1435,7 +1437,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1439: checking if 64bit support is requested" >&5
+echo "configure:1441: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1455,7 +1457,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1459: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1461: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1479,7 +1481,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1483: checking system version (for dynamic loading)" >&5
+echo "configure:1485: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1505,13 +1507,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1509: checking for dlopen in -ldl" >&5
+echo "configure:1511: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1515 "configure"
+#line 1517 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1522,7 +1524,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1569,7 +1571,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1573: checking for $ac_word" >&5
+echo "configure:1575: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1698,13 +1700,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1702: checking for gettimeofday in -lbsd" >&5
+echo "configure:1704: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1708 "configure"
+#line 1710 "configure"
@@ -1715,7 +1717,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1756,13 +1758,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1760: checking for inet_ntoa in -lbind" >&5
+echo "configure:1762: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1766 "configure"
+#line 1768 "configure"
@@ -1773,7 +1775,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1834,13 +1836,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1838: checking for shl_load in -ldld" >&5
+echo "configure:1840: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1844 "configure"
+#line 1846 "configure"
@@ -1851,7 +1853,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1916,13 +1918,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:1920: checking for shl_load in -ldld" >&5
+echo "configure:1922: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 1926 "configure"
+#line 1928 "configure"
@@ -1933,7 +1935,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:1937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2055,15 +2057,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2059: checking for dld.h" >&5
+echo "configure:2061: checking for dld.h" >&5
-#line 2062 "configure"
+#line 2064 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2123,15 +2125,15 @@
else
-echo "configure:2127: checking for dld.h" >&5
+echo "configure:2129: checking for dld.h" >&5
-#line 2130 "configure"
+#line 2132 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2135: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2137: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2228,9 +2230,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2232: checking for ELF" >&5
+echo "configure:2234: checking for ELF" >&5
-#line 2234 "configure"
+#line 2236 "configure"
#ifdef __ELF__
@@ -2260,15 +2262,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2264: checking for dlfcn.h" >&5
+echo "configure:2266: checking for dlfcn.h" >&5
-#line 2267 "configure"
+#line 2269 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2272: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2274: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2292,9 +2294,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2296: checking for ELF" >&5
+echo "configure:2298: checking for ELF" >&5
-#line 2298 "configure"
+#line 2300 "configure"
#ifdef __ELF__
@@ -2618,17 +2620,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2622: checking for ld accepts -Bexport flag" >&5
+echo "configure:2624: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2625 "configure"
+#line 2627 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -2977,6 +2979,16 @@
+# Check whether --with-wxpython or --without-wxpython was given.
+if test "${with_wxpython+set}" = set; then
+ withval="$with_wxpython"
+else
+ with_wxpython=no
+fi
# With includes and libs options
# Check whether --with-gdal or --without-gdal was given.
@@ -3357,7 +3369,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3361: checking for additional include dirs" >&5
+echo "configure:3373: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3380,7 +3392,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3384: checking for additional library dirs" >&5
+echo "configure:3396: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3414,7 +3426,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3418: checking for a BSD compatible install" >&5
+echo "configure:3430: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3467,7 +3479,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3471: checking for $ac_word" >&5
+echo "configure:3483: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3498,13 +3510,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3502: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3514: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3508 "configure"
+#line 3520 "configure"
@@ -3515,7 +3527,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3540,7 +3552,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3544: checking for $ac_word" >&5
+echo "configure:3556: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3580,7 +3592,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3584: checking for $ac_word" >&5
+echo "configure:3596: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3611,7 +3623,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3615: checking for $ac_word" >&5
+echo "configure:3627: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3649,7 +3661,7 @@
-echo "configure:3653: checking for $ac_word" >&5
+echo "configure:3665: checking for $ac_word" >&5
@@ -3678,7 +3690,7 @@
-echo "configure:3682: checking for $ac_word" >&5
+echo "configure:3694: checking for $ac_word" >&5
@@ -3709,7 +3721,7 @@
-echo "configure:3713: checking for $ac_word" >&5
+echo "configure:3725: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3738,7 +3750,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3742: checking for $ac_word" >&5
+echo "configure:3754: checking for $ac_word" >&5
case "$PERL" in
@@ -3769,10 +3781,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3773: checking for ANSI C header files" >&5
+echo "configure:3785: checking for ANSI C header files" >&5
-#line 3776 "configure"
+#line 3788 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -3780,7 +3792,7 @@
#include <float.h>
EOF
-{ (eval echo configure:3784: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3797,7 +3809,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 3801 "configure"
+#line 3813 "configure"
#include <string.h>
EOF
@@ -3815,7 +3827,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 3819 "configure"
+#line 3831 "configure"
#include <stdlib.h>
EOF
@@ -3836,7 +3848,7 @@
else
-#line 3840 "configure"
+#line 3852 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -3847,7 +3859,7 @@
exit (0); }
EOF
-if { (eval echo configure:3851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -3874,15 +3886,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:3878: checking for $ac_hdr" >&5
+echo "configure:3890: checking for $ac_hdr" >&5
-#line 3881 "configure"
+#line 3893 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3886: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3898: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3911,15 +3923,15 @@
do
-echo "configure:3915: checking for $ac_hdr" >&5
+echo "configure:3927: checking for $ac_hdr" >&5
-#line 3918 "configure"
+#line 3930 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3948,15 +3960,15 @@
do
-echo "configure:3952: checking for $ac_hdr" >&5
+echo "configure:3964: checking for $ac_hdr" >&5
-#line 3955 "configure"
+#line 3967 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3972: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3985,15 +3997,15 @@
do
-echo "configure:3989: checking for $ac_hdr" >&5
+echo "configure:4001: checking for $ac_hdr" >&5
-#line 3992 "configure"
+#line 4004 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3997: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4022,15 +4034,15 @@
do
-echo "configure:4026: checking for $ac_hdr" >&5
+echo "configure:4038: checking for $ac_hdr" >&5
-#line 4029 "configure"
+#line 4041 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4034: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4056,10 +4068,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4060: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4072: checking whether time.h and sys/time.h may both be included" >&5
-#line 4063 "configure"
+#line 4075 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4068,7 +4080,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4072: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4088,10 +4100,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4092: checking for off_t" >&5
+echo "configure:4104: checking for off_t" >&5
-#line 4095 "configure"
+#line 4107 "configure"
#if STDC_HEADERS
@@ -4118,10 +4130,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4122: checking for uid_t in sys/types.h" >&5
+echo "configure:4134: checking for uid_t in sys/types.h" >&5
-#line 4125 "configure"
+#line 4137 "configure"
EOF
@@ -4149,10 +4161,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4153: checking return type of signal handlers" >&5
+echo "configure:4165: checking return type of signal handlers" >&5
-#line 4156 "configure"
+#line 4168 "configure"
#include <signal.h>
@@ -4169,7 +4181,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4173: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4185: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4187,10 +4199,10 @@
-echo "configure:4191: checking for Cygwin environment" >&5
+echo "configure:4203: checking for Cygwin environment" >&5
-#line 4194 "configure"
+#line 4206 "configure"
int main() {
@@ -4201,7 +4213,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4205: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4217: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4219,10 +4231,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4223: checking for $ac_func" >&5
+echo "configure:4235: checking for $ac_func" >&5
-#line 4226 "configure"
+#line 4238 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4245,7 +4257,7 @@
; return 0; }
EOF
-if { (eval echo configure:4249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4271,10 +4283,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4275: checking for $ac_func" >&5
+echo "configure:4287: checking for $ac_func" >&5
-#line 4278 "configure"
+#line 4290 "configure"
@@ -4297,7 +4309,7 @@
; return 0; }
EOF
-if { (eval echo configure:4301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4323,10 +4335,10 @@
for ac_func in drand48
do
-echo "configure:4327: checking for $ac_func" >&5
+echo "configure:4339: checking for $ac_func" >&5
-#line 4330 "configure"
+#line 4342 "configure"
@@ -4349,7 +4361,7 @@
; return 0; }
EOF
-if { (eval echo configure:4353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4375,10 +4387,10 @@
for ac_func in putenv setenv
do
-echo "configure:4379: checking for $ac_func" >&5
+echo "configure:4391: checking for $ac_func" >&5
-#line 4382 "configure"
+#line 4394 "configure"
@@ -4401,7 +4413,7 @@
; return 0; }
EOF
-if { (eval echo configure:4405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4427,10 +4439,10 @@
for ac_func in nanosleep
do
-echo "configure:4431: checking for $ac_func" >&5
+echo "configure:4443: checking for $ac_func" >&5
-#line 4434 "configure"
+#line 4446 "configure"
@@ -4453,7 +4465,7 @@
; return 0; }
EOF
-if { (eval echo configure:4457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4478,13 +4490,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4482: checking whether setpgrp takes no argument" >&5
+echo "configure:4494: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4488 "configure"
+#line 4500 "configure"
#ifdef HAVE_UNISTD_H
@@ -4504,7 +4516,7 @@
EOF
-if { (eval echo configure:4508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4532,16 +4544,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4536: checking for long long int" >&5
+echo "configure:4548: checking for long long int" >&5
-#line 4538 "configure"
+#line 4550 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4545: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4557: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4561,7 +4573,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4565: checking for W11" >&5
+echo "configure:4577: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4589,7 +4601,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4593: checking for X" >&5
+echo "configure:4605: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4649,12 +4661,12 @@
# First, try using that file with no special directory specified.
-#line 4653 "configure"
+#line 4665 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4658: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4723,14 +4735,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4727 "configure"
+#line 4739 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -4835,17 +4847,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:4839: checking whether -R must be followed by a space" >&5
+echo "configure:4851: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 4842 "configure"
+#line 4854 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -4861,14 +4873,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 4865 "configure"
+#line 4877 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:4872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -4900,13 +4912,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:4904: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:4916: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 4910 "configure"
+#line 4922 "configure"
@@ -4917,7 +4929,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4938,13 +4950,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4942: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4954: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4948 "configure"
+#line 4960 "configure"
@@ -4955,7 +4967,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4983,10 +4995,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4987: checking for gethostbyname" >&5
+echo "configure:4999: checking for gethostbyname" >&5
-#line 4990 "configure"
+#line 5002 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5009,7 +5021,7 @@
; return 0; }
EOF
-if { (eval echo configure:5013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5029,13 +5041,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5033: checking for gethostbyname in -lnsl" >&5
+echo "configure:5045: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5039 "configure"
+#line 5051 "configure"
@@ -5046,7 +5058,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5075,10 +5087,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5079: checking for connect" >&5
+echo "configure:5091: checking for connect" >&5
-#line 5082 "configure"
+#line 5094 "configure"
which can conflict with char connect(); below. */
@@ -5101,7 +5113,7 @@
; return 0; }
EOF
-if { (eval echo configure:5105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5121,13 +5133,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5125: checking for connect in -lsocket" >&5
+echo "configure:5137: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5131 "configure"
+#line 5143 "configure"
@@ -5138,7 +5150,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5161,10 +5173,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5165: checking for remove" >&5
+echo "configure:5177: checking for remove" >&5
-#line 5168 "configure"
+#line 5180 "configure"
which can conflict with char remove(); below. */
@@ -5187,7 +5199,7 @@
; return 0; }
EOF
-if { (eval echo configure:5191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5207,13 +5219,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5211: checking for remove in -lposix" >&5
+echo "configure:5223: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5217 "configure"
+#line 5229 "configure"
@@ -5224,7 +5236,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5247,10 +5259,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5251: checking for shmat" >&5
+echo "configure:5263: checking for shmat" >&5
-#line 5254 "configure"
+#line 5266 "configure"
which can conflict with char shmat(); below. */
@@ -5273,7 +5285,7 @@
; return 0; }
EOF
-if { (eval echo configure:5277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5293,13 +5305,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5297: checking for shmat in -lipc" >&5
+echo "configure:5309: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5303 "configure"
+#line 5315 "configure"
@@ -5310,7 +5322,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5342,13 +5354,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5346: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5358: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5352 "configure"
+#line 5364 "configure"
@@ -5359,7 +5371,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5397,7 +5409,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5401: checking whether to use Curses" >&5
+echo "configure:5413: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5416,15 +5428,15 @@
do
-echo "configure:5420: checking for $ac_hdr" >&5
+echo "configure:5432: checking for $ac_hdr" >&5
-#line 5423 "configure"
+#line 5435 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5455,10 +5467,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5459: checking curses.h WINDOW structure component" >&5
+echo "configure:5471: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5462 "configure"
+#line 5474 "configure"
#include <curses.h>
@@ -5467,7 +5479,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5471: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5483: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5476,7 +5488,7 @@
fi
rm -f conftest*
-#line 5480 "configure"
+#line 5492 "configure"
#include <curses.h>
@@ -5485,7 +5497,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5489: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5501,13 +5513,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5505: checking for initscr in -lncurses" >&5
+echo "configure:5517: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5511 "configure"
+#line 5523 "configure"
@@ -5518,7 +5530,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5537,13 +5549,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5541: checking for initscr in -lcurses" >&5
+echo "configure:5553: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5547 "configure"
+#line 5559 "configure"
@@ -5554,7 +5566,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5583,13 +5595,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5587: checking for keypad in -lncurses" >&5
+echo "configure:5599: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5593 "configure"
+#line 5605 "configure"
@@ -5600,7 +5612,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5622,13 +5634,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5626: checking for keypad in -lcurses" >&5
+echo "configure:5638: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5632 "configure"
+#line 5644 "configure"
@@ -5639,7 +5651,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5669,13 +5681,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5673: checking for gtty in -lcompat" >&5
+echo "configure:5685: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5679 "configure"
+#line 5691 "configure"
@@ -5686,7 +5698,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5705,13 +5717,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5709: checking for gtty in -lbsd-compat" >&5
+echo "configure:5721: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5715 "configure"
+#line 5727 "configure"
@@ -5722,7 +5734,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5741,13 +5753,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5745: checking for gtty in -lbsd" >&5
+echo "configure:5757: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5751 "configure"
+#line 5763 "configure"
@@ -5758,7 +5770,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5792,12 +5804,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:5796: checking for library containing cuserid" >&5
+echo "configure:5808: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 5801 "configure"
+#line 5813 "configure"
@@ -5808,7 +5820,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -5819,7 +5831,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 5823 "configure"
+#line 5835 "configure"
@@ -5830,7 +5842,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:5834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -5856,10 +5868,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:5860: checking for xdrmem_create" >&5
+echo "configure:5872: checking for xdrmem_create" >&5
-#line 5863 "configure"
+#line 5875 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -5882,7 +5894,7 @@
; return 0; }
EOF
-if { (eval echo configure:5886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -5900,13 +5912,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:5904: checking for xdrmem_create in -lsun" >&5
+echo "configure:5916: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 5910 "configure"
+#line 5922 "configure"
@@ -5917,7 +5929,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5936,13 +5948,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:5940: checking for xdrmem_create in -lnsl" >&5
+echo "configure:5952: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5946 "configure"
+#line 5958 "configure"
@@ -5953,7 +5965,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5972,13 +5984,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:5976: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:5988: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 5982 "configure"
+#line 5994 "configure"
@@ -5989,7 +6001,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:5993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6008,13 +6020,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6012: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6024: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6018 "configure"
+#line 6030 "configure"
@@ -6025,7 +6037,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6059,10 +6071,10 @@
for ac_func in asprintf
do
-echo "configure:6063: checking for $ac_func" >&5
+echo "configure:6075: checking for $ac_func" >&5
-#line 6066 "configure"
+#line 6078 "configure"
@@ -6085,7 +6097,7 @@
; return 0; }
EOF
-if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6112,10 +6124,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6116: checking for atan" >&5
+echo "configure:6128: checking for atan" >&5
-#line 6119 "configure"
+#line 6131 "configure"
which can conflict with char atan(); below. */
@@ -6138,7 +6150,7 @@
; return 0; }
EOF
-if { (eval echo configure:6142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6156,13 +6168,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6160: checking for atan in -lm" >&5
+echo "configure:6172: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6166 "configure"
+#line 6178 "configure"
@@ -6173,7 +6185,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6200,10 +6212,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6204: checking for dlsym" >&5
+echo "configure:6216: checking for dlsym" >&5
-#line 6207 "configure"
+#line 6219 "configure"
which can conflict with char dlsym(); below. */
@@ -6226,7 +6238,7 @@
; return 0; }
EOF
-if { (eval echo configure:6230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6244,13 +6256,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6248: checking for dlsym in -ldl" >&5
+echo "configure:6260: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6254 "configure"
+#line 6266 "configure"
@@ -6261,7 +6273,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6288,10 +6300,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6292: checking for iconv" >&5
+echo "configure:6304: checking for iconv" >&5
-#line 6295 "configure"
+#line 6307 "configure"
which can conflict with char iconv(); below. */
@@ -6314,7 +6326,7 @@
; return 0; }
EOF
-if { (eval echo configure:6318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6332,13 +6344,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6336: checking for iconv in -liconv" >&5
+echo "configure:6348: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6342 "configure"
+#line 6354 "configure"
@@ -6349,7 +6361,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6368,13 +6380,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6372: checking for iconv in -lgiconv" >&5
+echo "configure:6384: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6378 "configure"
+#line 6390 "configure"
@@ -6385,7 +6397,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6404,10 +6416,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6408: checking for libiconv" >&5
+echo "configure:6420: checking for libiconv" >&5
-#line 6411 "configure"
+#line 6423 "configure"
which can conflict with char libiconv(); below. */
@@ -6430,7 +6442,7 @@
; return 0; }
EOF
-if { (eval echo configure:6434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6448,13 +6460,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6452: checking for libiconv in -liconv" >&5
+echo "configure:6464: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6458 "configure"
+#line 6470 "configure"
@@ -6465,7 +6477,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6484,13 +6496,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6488: checking for libiconv in -lgiconv" >&5
+echo "configure:6500: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6494 "configure"
+#line 6506 "configure"
@@ -6501,7 +6513,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6538,10 +6550,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6542: checking for socket" >&5
+echo "configure:6554: checking for socket" >&5
-#line 6545 "configure"
+#line 6557 "configure"
which can conflict with char socket(); below. */
@@ -6564,7 +6576,7 @@
; return 0; }
EOF
-if { (eval echo configure:6568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6582,13 +6594,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6586: checking for socket in -lsocket" >&5
+echo "configure:6598: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6592 "configure"
+#line 6604 "configure"
@@ -6599,7 +6611,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6647,7 +6659,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6651: checking for location of zlib includes" >&5
+echo "configure:6663: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6673,15 +6685,15 @@
do
-echo "configure:6677: checking for $ac_hdr" >&5
+echo "configure:6689: checking for $ac_hdr" >&5
-#line 6680 "configure"
+#line 6692 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6715,7 +6727,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6719: checking for location of zlib library" >&5
+echo "configure:6731: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6740,13 +6752,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6744: checking for deflate in -lz" >&5
+echo "configure:6756: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6750 "configure"
+#line 6762 "configure"
@@ -6757,7 +6769,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6805,7 +6817,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:6809: checking for location of External PROJ.4 includes" >&5
+echo "configure:6821: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -6831,15 +6843,15 @@
do
-echo "configure:6835: checking for $ac_hdr" >&5
+echo "configure:6847: checking for $ac_hdr" >&5
-#line 6838 "configure"
+#line 6850 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6843: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6876,7 +6888,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:6880: checking External PROJ.4 version" >&5
+echo "configure:6892: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -6884,7 +6896,7 @@
else
-#line 6888 "configure"
+#line 6900 "configure"
#include <stdio.h>
@@ -6896,7 +6908,7 @@
EOF
-if { (eval echo configure:6900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -6921,7 +6933,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:6925: checking for location of External PROJ.4 library" >&5
+echo "configure:6937: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -6946,13 +6958,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:6950: checking for pj_get_def in -lproj" >&5
+echo "configure:6962: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 6956 "configure"
+#line 6968 "configure"
@@ -6963,7 +6975,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:6967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6997,7 +7009,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7001: checking for location of External PROJ.4 data files" >&5
+echo "configure:7013: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7021,14 +7033,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7025: checking for epsg" >&5
+echo "configure:7037: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7032: checking for $PROJSHARE/epsg" >&5
+echo "configure:7044: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7060,7 +7072,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7064: checking for $ac_word" >&5
+echo "configure:7076: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7100,7 +7112,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7104: checking whether to use Readline" >&5
+echo "configure:7116: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7121,7 +7133,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7125: checking for location of Readline includes" >&5
+echo "configure:7137: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7147,15 +7159,15 @@
do
-echo "configure:7151: checking for $ac_hdr" >&5
+echo "configure:7163: checking for $ac_hdr" >&5
-#line 7154 "configure"
+#line 7166 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7171: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7191,15 +7203,15 @@
do
-echo "configure:7195: checking for $ac_hdr" >&5
+echo "configure:7207: checking for $ac_hdr" >&5
-#line 7198 "configure"
+#line 7210 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7203: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7233,7 +7245,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7237: checking for location of Readline library" >&5
+echo "configure:7249: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7258,13 +7270,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7262: checking for readline in -lreadline" >&5
+echo "configure:7274: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7268 "configure"
+#line 7280 "configure"
@@ -7275,7 +7287,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7310,13 +7322,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7314: checking for add_history in -lhistory" >&5
+echo "configure:7326: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7320 "configure"
+#line 7332 "configure"
@@ -7327,7 +7339,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7370,7 +7382,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7374: checking whether to use JPEG" >&5
+echo "configure:7386: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -7390,7 +7402,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7394: checking for location of JPEG includes" >&5
+echo "configure:7406: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -7416,15 +7428,15 @@
do
-echo "configure:7420: checking for $ac_hdr" >&5
+echo "configure:7432: checking for $ac_hdr" >&5
-#line 7423 "configure"
+#line 7435 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7440: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7458,7 +7470,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7462: checking for location of JPEG library" >&5
+echo "configure:7474: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -7485,13 +7497,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7489: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7501: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 7495 "configure"
+#line 7507 "configure"
@@ -7502,7 +7514,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:7506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7521,13 +7533,13 @@
-echo "configure:7525: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:7537: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 7531 "configure"
+#line 7543 "configure"
@@ -7538,7 +7550,7 @@
; return 0; }
EOF
-if { (eval echo configure:7542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7587,7 +7599,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7591: checking whether to use GDAL" >&5
+echo "configure:7603: checking whether to use GDAL" >&5
if test "`basename xx/$with_gdal`" = "gdal-config" ; then
GDAL_CONFIG="$with_gdal"
@@ -7597,11 +7609,10 @@
if test "$with_gdal" = "no" ; then
else
- echo "$ac_t""yes" 1>&6
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:7605: checking for $ac_word" >&5
+echo "configure:7616: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7659,10 +7670,10 @@
ac_save_libs="$LIBS"
LIBS="$LIBS $GDAL_LIBS"
echo $ac_n "checking for GDALOpen""... $ac_c" 1>&6
-echo "configure:7663: checking for GDALOpen" >&5
+echo "configure:7674: checking for GDALOpen" >&5
-#line 7666 "configure"
+#line 7677 "configure"
which can conflict with char GDALOpen(); below. */
@@ -7685,7 +7696,7 @@
; return 0; }
EOF
-if { (eval echo configure:7689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GDALOpen=yes"
else
@@ -7704,10 +7715,10 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-echo "configure:7708: checking for GDALOpen" >&5
+echo "configure:7719: checking for GDALOpen" >&5
-#line 7711 "configure"
+#line 7722 "configure"
@@ -7730,7 +7741,7 @@
; return 0; }
EOF
-if { (eval echo configure:7734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7766,7 +7777,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7770: checking whether to use TIFF" >&5
+echo "configure:7781: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7786,7 +7797,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7790: checking for location of TIFF includes" >&5
+echo "configure:7801: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7812,15 +7823,15 @@
do
-echo "configure:7816: checking for $ac_hdr" >&5
+echo "configure:7827: checking for $ac_hdr" >&5
-#line 7819 "configure"
+#line 7830 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7835: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7854,7 +7865,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7858: checking for location of TIFF library" >&5
+echo "configure:7869: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7885,13 +7896,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7889: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7900: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ltiff $LIBS"
-#line 7895 "configure"
+#line 7906 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7902,7 +7913,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7921,13 +7932,13 @@
-echo "configure:7925: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7936: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7931 "configure"
+#line 7942 "configure"
@@ -7938,7 +7949,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7957,13 +7968,13 @@
-echo "configure:7961: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7972: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7967 "configure"
+#line 7978 "configure"
@@ -7974,7 +7985,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7993,13 +8004,13 @@
-echo "configure:7997: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8008: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8003 "configure"
+#line 8014 "configure"
@@ -8010,7 +8021,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8029,13 +8040,13 @@
-echo "configure:8033: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8044: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8039 "configure"
+#line 8050 "configure"
@@ -8046,7 +8057,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8065,13 +8076,13 @@
-echo "configure:8069: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8080: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8075 "configure"
+#line 8086 "configure"
@@ -8082,7 +8093,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8101,13 +8112,13 @@
-echo "configure:8105: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8116: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8111 "configure"
+#line 8122 "configure"
@@ -8118,7 +8129,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8137,13 +8148,13 @@
-echo "configure:8141: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8152: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8147 "configure"
+#line 8158 "configure"
@@ -8154,7 +8165,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8252,7 +8263,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8256: checking whether to use PNG" >&5
+echo "configure:8267: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8271,7 +8282,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8275: checking for location of PNG includes" >&5
+echo "configure:8286: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8297,15 +8308,15 @@
do
-echo "configure:8301: checking for $ac_hdr" >&5
+echo "configure:8312: checking for $ac_hdr" >&5
-#line 8304 "configure"
+#line 8315 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8339,7 +8350,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8343: checking for location of PNG library" >&5
+echo "configure:8354: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8364,13 +8375,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8368: checking for png_read_image in -lpng" >&5
+echo "configure:8379: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8374 "configure"
+#line 8385 "configure"
@@ -8381,7 +8392,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8423,7 +8434,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:8427: checking whether to use Tcl/Tk" >&5
+echo "configure:8438: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -8443,7 +8454,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:8447: checking for location of Tcl/Tk includes" >&5
+echo "configure:8458: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -8469,15 +8480,15 @@
do
-echo "configure:8473: checking for $ac_hdr" >&5
+echo "configure:8484: checking for $ac_hdr" >&5
-#line 8476 "configure"
+#line 8487 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8481: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8514,15 +8525,15 @@
do
-echo "configure:8518: checking for $ac_hdr" >&5
+echo "configure:8529: checking for $ac_hdr" >&5
-#line 8521 "configure"
+#line 8532 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8537: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8556,7 +8567,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:8560: checking Tcl version" >&5
+echo "configure:8571: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -8564,7 +8575,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 8568 "configure"
+#line 8579 "configure"
#include <stdio.h>
@@ -8576,7 +8587,7 @@
EOF
-if { (eval echo configure:8580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -8594,7 +8605,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:8598: checking Tk version" >&5
+echo "configure:8609: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -8602,7 +8613,7 @@
else
-#line 8606 "configure"
+#line 8617 "configure"
#include <stdio.h>
@@ -8614,7 +8625,7 @@
EOF
-if { (eval echo configure:8618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:8629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -8643,7 +8654,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:8647: checking for location of Tcl/Tk library" >&5
+echo "configure:8658: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -8673,13 +8684,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:8677: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8688: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 8683 "configure"
+#line 8694 "configure"
@@ -8690,7 +8701,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8709,13 +8720,13 @@
-echo "configure:8713: checking for Tcl_Init in -ltcl" >&5
+echo "configure:8724: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 8719 "configure"
+#line 8730 "configure"
@@ -8726,7 +8737,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8753,13 +8764,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:8757: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8768: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 8763 "configure"
+#line 8774 "configure"
@@ -8770,7 +8781,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8789,13 +8800,13 @@
-echo "configure:8793: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:8804: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 8799 "configure"
+#line 8810 "configure"
@@ -8806,7 +8817,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8833,13 +8844,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:8837: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8848: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 8843 "configure"
+#line 8854 "configure"
@@ -8850,7 +8861,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8869,13 +8880,13 @@
-echo "configure:8873: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:8884: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 8879 "configure"
+#line 8890 "configure"
@@ -8886,7 +8897,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:8890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8964,13 +8975,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:8968: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:8979: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 8974 "configure"
+#line 8985 "configure"
@@ -8981,7 +8992,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:8985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9000,13 +9011,13 @@
-echo "configure:9004: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:9015: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9010 "configure"
+#line 9021 "configure"
@@ -9017,7 +9028,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9044,13 +9055,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:9048: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9059: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 9054 "configure"
+#line 9065 "configure"
@@ -9061,7 +9072,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9080,13 +9091,13 @@
-echo "configure:9084: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:9095: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9090 "configure"
+#line 9101 "configure"
@@ -9097,7 +9108,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9124,13 +9135,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:9128: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9139: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 9134 "configure"
+#line 9145 "configure"
@@ -9141,7 +9152,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9160,13 +9171,13 @@
-echo "configure:9164: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:9175: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 9170 "configure"
+#line 9181 "configure"
@@ -9177,7 +9188,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:9181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9269,7 +9280,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9273: checking whether to use PostgreSQL" >&5
+echo "configure:9284: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9296,7 +9307,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9300: checking for location of PostgreSQL includes" >&5
+echo "configure:9311: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9322,15 +9333,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9326: checking for $ac_hdr" >&5
+echo "configure:9337: checking for $ac_hdr" >&5
-#line 9329 "configure"
+#line 9340 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9345: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9368,7 +9379,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9372: checking for location of PostgreSQL library" >&5
+echo "configure:9383: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9397,13 +9408,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9401: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9412: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9407 "configure"
+#line 9418 "configure"
@@ -9414,7 +9425,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9433,13 +9444,13 @@
-echo "configure:9437: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9448: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9443 "configure"
+#line 9454 "configure"
@@ -9450,7 +9461,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9469,13 +9480,13 @@
-echo "configure:9473: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9484: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9479 "configure"
+#line 9490 "configure"
@@ -9486,7 +9497,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9505,13 +9516,13 @@
-echo "configure:9509: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9520: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9515 "configure"
+#line 9526 "configure"
@@ -9522,7 +9533,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9579,13 +9590,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9583: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9594: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9589 "configure"
+#line 9600 "configure"
@@ -9596,7 +9607,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9618,13 +9629,13 @@
-echo "configure:9622: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9633: checking for PQcmdTuples in -lpq" >&5
-#line 9628 "configure"
+#line 9639 "configure"
@@ -9635,7 +9646,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9678,7 +9689,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9682: checking whether to use MySQL" >&5
+echo "configure:9693: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9698,7 +9709,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9702: checking for location of MySQL includes" >&5
+echo "configure:9713: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9724,15 +9735,15 @@
do
-echo "configure:9728: checking for $ac_hdr" >&5
+echo "configure:9739: checking for $ac_hdr" >&5
-#line 9731 "configure"
+#line 9742 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9736: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9769,7 +9780,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9773: checking for location of MySQL library" >&5
+echo "configure:9784: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9800,13 +9811,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9804: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9815: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9810 "configure"
+#line 9821 "configure"
@@ -9817,7 +9828,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9836,13 +9847,13 @@
-echo "configure:9840: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9851: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9846 "configure"
+#line 9857 "configure"
@@ -9853,7 +9864,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9872,13 +9883,13 @@
-echo "configure:9876: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9887: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9882 "configure"
+#line 9893 "configure"
@@ -9889,7 +9900,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9908,13 +9919,13 @@
-echo "configure:9912: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9923: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9918 "configure"
+#line 9929 "configure"
@@ -9925,7 +9936,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9944,13 +9955,13 @@
-echo "configure:9948: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9959: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9954 "configure"
+#line 9965 "configure"
@@ -9961,7 +9972,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9980,13 +9991,13 @@
-echo "configure:9984: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9995: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9990 "configure"
+#line 10001 "configure"
@@ -9997,7 +10008,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10016,13 +10027,13 @@
-echo "configure:10020: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10031: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 10026 "configure"
+#line 10037 "configure"
@@ -10033,7 +10044,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10052,13 +10063,13 @@
-echo "configure:10056: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:10067: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 10062 "configure"
+#line 10073 "configure"
@@ -10069,7 +10080,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:10073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10159,7 +10170,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:10163: checking for $ac_word" >&5
+echo "configure:10174: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10200,10 +10211,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10204: checking for mysql_server_init" >&5
+echo "configure:10215: checking for mysql_server_init" >&5
-#line 10207 "configure"
+#line 10218 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10226,7 +10237,7 @@
; return 0; }
EOF
-if { (eval echo configure:10230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10264,7 +10275,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10268: checking whether to use SQLite" >&5
+echo "configure:10279: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10284,7 +10295,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10288: checking for location of SQLite includes" >&5
+echo "configure:10299: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10310,15 +10321,15 @@
do
-echo "configure:10314: checking for $ac_hdr" >&5
+echo "configure:10325: checking for $ac_hdr" >&5
-#line 10317 "configure"
+#line 10328 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10322: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10361,7 +10372,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10365: checking for location of SQLite library" >&5
+echo "configure:10376: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10388,13 +10399,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10392: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10403: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10398 "configure"
+#line 10409 "configure"
@@ -10405,7 +10416,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10420: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10424,13 +10435,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10428: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10439: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10434 "configure"
+#line 10445 "configure"
@@ -10441,7 +10452,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10494,7 +10505,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10498: checking whether to use FFMPEG" >&5
+echo "configure:10509: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10514,7 +10525,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10518: checking for location of FFMPEG includes" >&5
+echo "configure:10529: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10540,15 +10551,15 @@
do
-echo "configure:10544: checking for $ac_hdr" >&5
+echo "configure:10555: checking for $ac_hdr" >&5
-#line 10547 "configure"
+#line 10558 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10552: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10563: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10584,15 +10595,15 @@
do
-echo "configure:10588: checking for $ac_hdr" >&5
+echo "configure:10599: checking for $ac_hdr" >&5
-#line 10591 "configure"
+#line 10602 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10596: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10607: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10635,7 +10646,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10639: checking for location of FFMPEG library" >&5
+echo "configure:10650: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10662,13 +10673,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10666: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10677: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $LIBS"
-#line 10672 "configure"
+#line 10683 "configure"
@@ -10679,7 +10690,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10698,13 +10709,13 @@
-echo "configure:10702: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10713: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec -lavutil $MATHLIB $LIBS"
-#line 10708 "configure"
+#line 10719 "configure"
@@ -10715,7 +10726,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10760,13 +10771,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10764: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10775: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $LIBS"
-#line 10770 "configure"
+#line 10781 "configure"
@@ -10777,7 +10788,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10796,13 +10807,13 @@
-echo "configure:10800: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10811: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat -lavutil $MATHLIB $LIBS"
-#line 10806 "configure"
+#line 10817 "configure"
@@ -10813,7 +10824,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10873,7 +10884,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10877: checking whether to use OpenGL" >&5
+echo "configure:10888: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10907,7 +10918,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10911: checking for location of OpenGL includes" >&5
+echo "configure:10922: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10933,15 +10944,15 @@
do
-echo "configure:10937: checking for $ac_hdr" >&5
+echo "configure:10948: checking for $ac_hdr" >&5
-#line 10940 "configure"
+#line 10951 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10945: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10956: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10975,7 +10986,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10979: checking for location of OpenGL library" >&5
+echo "configure:10990: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11004,13 +11015,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11008: checking for glBegin in -lGL" >&5
+echo "configure:11019: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11014 "configure"
+#line 11025 "configure"
@@ -11021,7 +11032,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11040,13 +11051,13 @@
-echo "configure:11044: checking for glBegin in -lGL" >&5
+echo "configure:11055: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11050 "configure"
+#line 11061 "configure"
@@ -11057,7 +11068,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11076,13 +11087,13 @@
-echo "configure:11080: checking for glBegin in -lGL" >&5
+echo "configure:11091: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11086 "configure"
+#line 11097 "configure"
@@ -11093,7 +11104,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11097: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11108: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11112,13 +11123,13 @@
-echo "configure:11116: checking for glBegin in -lGL" >&5
+echo "configure:11127: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11122 "configure"
+#line 11133 "configure"
@@ -11129,7 +11140,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11191,13 +11202,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11195: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11206: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11201 "configure"
+#line 11212 "configure"
@@ -11208,7 +11219,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11227,13 +11238,13 @@
-echo "configure:11231: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11242: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11237 "configure"
+#line 11248 "configure"
@@ -11244,7 +11255,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11288,10 +11299,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11292: checking for glXCreatePbuffer" >&5
+echo "configure:11303: checking for glXCreatePbuffer" >&5
-#line 11295 "configure"
+#line 11306 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11314,7 +11325,7 @@
; return 0; }
EOF
-if { (eval echo configure:11318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11336,10 +11347,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11340: checking for glXCreateGLXPixmap" >&5
+echo "configure:11351: checking for glXCreateGLXPixmap" >&5
-#line 11343 "configure"
+#line 11354 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11362,7 +11373,7 @@
; return 0; }
EOF
-if { (eval echo configure:11366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11401,7 +11412,7 @@
-echo "configure:11405: checking for location of OpenGL includes" >&5
+echo "configure:11416: checking for location of OpenGL includes" >&5
@@ -11427,15 +11438,15 @@
do
-echo "configure:11431: checking for $ac_hdr" >&5
+echo "configure:11442: checking for $ac_hdr" >&5
-#line 11434 "configure"
+#line 11445 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11439: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11470,10 +11481,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11474: checking for glBegin" >&5
+echo "configure:11485: checking for glBegin" >&5
-#line 11477 "configure"
+#line 11488 "configure"
which can conflict with char glBegin(); below. */
@@ -11496,7 +11507,7 @@
; return 0; }
EOF
-if { (eval echo configure:11500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11511,10 +11522,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11515: checking for gluBeginCurve" >&5
+echo "configure:11526: checking for gluBeginCurve" >&5
-#line 11518 "configure"
+#line 11529 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11537,7 +11548,7 @@
; return 0; }
EOF
-if { (eval echo configure:11541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11583,7 +11594,7 @@
-echo "configure:11587: checking for location of OpenGL includes" >&5
+echo "configure:11598: checking for location of OpenGL includes" >&5
@@ -11609,15 +11620,15 @@
do
-echo "configure:11613: checking for $ac_hdr" >&5
+echo "configure:11624: checking for $ac_hdr" >&5
-#line 11616 "configure"
+#line 11627 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11621: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11632: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11651,7 +11662,7 @@
-echo "configure:11655: checking for location of OpenGL library" >&5
+echo "configure:11666: checking for location of OpenGL library" >&5
@@ -11674,33 +11685,33 @@
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11678: checking for OpenGL library" >&5
+echo "configure:11689: checking for OpenGL library" >&5
LIBS="-lopengl32"
-#line 11681 "configure"
+#line 11692 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
OPENGLLIB=-lopengl32
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11694: checking for GLU library" >&5
+echo "configure:11705: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB"
-#line 11697 "configure"
+#line 11708 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11751,7 +11762,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11755: checking whether to use ODBC" >&5
+echo "configure:11766: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11770,7 +11781,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11774: checking for location of ODBC includes" >&5
+echo "configure:11785: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11796,15 +11807,15 @@
do
-echo "configure:11800: checking for $ac_hdr" >&5
+echo "configure:11811: checking for $ac_hdr" >&5
-#line 11803 "configure"
+#line 11814 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11838,7 +11849,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11842: checking for location of ODBC library" >&5
+echo "configure:11853: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11863,13 +11874,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11867: checking for SQLConnect in -lodbc" >&5
+echo "configure:11878: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11873 "configure"
+#line 11884 "configure"
@@ -11880,7 +11891,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11905,13 +11916,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11909: checking for SQLConnect in -liodbc" >&5
+echo "configure:11920: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11915 "configure"
+#line 11926 "configure"
#include "confdefs.h"
@@ -11922,7 +11933,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11971,7 +11982,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11975: checking whether to use FFTW" >&5
+echo "configure:11986: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11990,7 +12001,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11994: checking for location of FFTW includes" >&5
+echo "configure:12005: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12016,15 +12027,15 @@
do
-echo "configure:12020: checking for $ac_hdr" >&5
+echo "configure:12031: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 12023 "configure"
+#line 12034 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12028: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12052,15 +12063,15 @@
do
-echo "configure:12056: checking for $ac_hdr" >&5
+echo "configure:12067: checking for $ac_hdr" >&5
-#line 12059 "configure"
+#line 12070 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12064: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12075: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12088,15 +12099,15 @@
do
-echo "configure:12092: checking for $ac_hdr" >&5
+echo "configure:12103: checking for $ac_hdr" >&5
-#line 12095 "configure"
+#line 12106 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12100: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12111: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12142,7 +12153,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12146: checking for location of FFTW library" >&5
+echo "configure:12157: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12167,13 +12178,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12171: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12182: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12177 "configure"
+#line 12188 "configure"
@@ -12184,7 +12195,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12209,13 +12220,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12213: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12224: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12219 "configure"
+#line 12230 "configure"
@@ -12226,7 +12237,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12251,13 +12262,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12255: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12266: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12261 "configure"
+#line 12272 "configure"
@@ -12268,7 +12279,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:12272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12325,7 +12336,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12329: checking whether to use BLAS" >&5
+echo "configure:12340: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -12346,7 +12357,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12350: checking for location of BLAS includes" >&5
+echo "configure:12361: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12366,7 +12377,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:12370: checking for location of BLAS library" >&5
+echo "configure:12381: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -12392,15 +12403,15 @@
do
-echo "configure:12396: checking for $ac_hdr" >&5
+echo "configure:12407: checking for $ac_hdr" >&5
-#line 12399 "configure"
+#line 12410 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12415: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12435,13 +12446,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:12439: checking for dnrm2_ in -lblas" >&5
+echo "configure:12450: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 12445 "configure"
+#line 12456 "configure"
@@ -12452,7 +12463,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12471,13 +12482,13 @@
-echo "configure:12475: checking for dnrm2_ in -lblas" >&5
+echo "configure:12486: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 12481 "configure"
+#line 12492 "configure"
@@ -12488,7 +12499,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12532,13 +12543,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12536: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12547: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12542 "configure"
+#line 12553 "configure"
@@ -12549,7 +12560,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12564,13 +12575,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12568: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12579: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12574 "configure"
+#line 12585 "configure"
@@ -12581,7 +12592,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12596,13 +12607,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12600: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12611: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12606 "configure"
+#line 12617 "configure"
@@ -12613,7 +12624,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12628: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12658,16 +12669,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12662: checking for sgemm in $vlib_flags" >&5
+echo "configure:12673: checking for sgemm in $vlib_flags" >&5
-#line 12664 "configure"
+#line 12675 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12685,13 +12696,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12689: checking for sgemm_ in -lblas" >&5
+echo "configure:12700: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12695 "configure"
+#line 12706 "configure"
@@ -12702,7 +12713,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12717,13 +12728,13 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12721: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12732: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12727 "configure"
+#line 12738 "configure"
@@ -12734,7 +12745,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12749,13 +12760,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12753: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12764: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12759 "configure"
+#line 12770 "configure"
@@ -12766,7 +12777,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12800,13 +12811,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12804: checking for acosp in -lsunmath" >&5
+echo "configure:12815: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lsunmath $LIBS"
-#line 12810 "configure"
+#line 12821 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12817,7 +12828,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12832,13 +12843,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12836: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12847: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12842 "configure"
+#line 12853 "configure"
@@ -12849,7 +12860,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12879,13 +12890,13 @@
# Generic BLAS library
-echo "configure:12883: checking for sgemm_ in -lblas" >&5
+echo "configure:12894: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 12889 "configure"
+#line 12900 "configure"
@@ -12896,7 +12907,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12935,7 +12946,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12939: checking whether to use LAPACK" >&5
+echo "configure:12950: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12960,7 +12971,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12964: checking for location of LAPACK includes" >&5
+echo "configure:12975: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12980,7 +12991,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12984: checking for location of LAPACK library" >&5
+echo "configure:12995: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13006,15 +13017,15 @@
do
-echo "configure:13010: checking for $ac_hdr" >&5
+echo "configure:13021: checking for $ac_hdr" >&5
-#line 13013 "configure"
+#line 13024 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13046,10 +13057,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13050: checking for dsegv_" >&5
+echo "configure:13061: checking for dsegv_" >&5
-#line 13053 "configure"
+#line 13064 "configure"
which can conflict with char dsegv_(); below. */
@@ -13072,7 +13083,7 @@
; return 0; }
EOF
-if { (eval echo configure:13076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13099,13 +13110,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13103: checking for desgv_ in -llapack" >&5
+echo "configure:13114: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13109 "configure"
+#line 13120 "configure"
@@ -13116,7 +13127,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13148,13 +13159,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13152: checking for dgesv_ in -llapack" >&5
+echo "configure:13163: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13158 "configure"
+#line 13169 "configure"
@@ -13165,7 +13176,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13184,13 +13195,13 @@
-echo "configure:13188: checking for dgesv_ in -llapack" >&5
+echo "configure:13199: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13194 "configure"
+#line 13205 "configure"
@@ -13201,7 +13212,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13257,7 +13268,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13261: checking whether to use Motif" >&5
+echo "configure:13272: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -13276,7 +13287,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13280: checking for location of Motif includes" >&5
+echo "configure:13291: checking for location of Motif includes" >&5
case "$with_motif_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13302,15 +13313,15 @@
do
-echo "configure:13306: checking for $ac_hdr" >&5
+echo "configure:13317: checking for $ac_hdr" >&5
-#line 13309 "configure"
+#line 13320 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13314: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13344,7 +13355,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13348: checking for location of Motif library" >&5
+echo "configure:13359: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -13369,13 +13380,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:13373: checking for XmStringCreate in -lXm" >&5
+echo "configure:13384: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 13379 "configure"
+#line 13390 "configure"
@@ -13386,7 +13397,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13427,7 +13438,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:13431: checking whether to use GLw" >&5
+echo "configure:13442: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -13446,7 +13457,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:13450: checking for location of GLw includes" >&5
+echo "configure:13461: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -13472,15 +13483,15 @@
do
-echo "configure:13476: checking for $ac_hdr" >&5
+echo "configure:13487: checking for $ac_hdr" >&5
-#line 13479 "configure"
+#line 13490 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13484: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13495: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13508,15 +13519,15 @@
do
-echo "configure:13512: checking for $ac_hdr" >&5
+echo "configure:13523: checking for $ac_hdr" >&5
-#line 13515 "configure"
+#line 13526 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13520: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13556,7 +13567,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:13560: checking for location of GLw library" >&5
+echo "configure:13571: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -13581,13 +13592,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13585: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:13596: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13591 "configure"
+#line 13602 "configure"
@@ -13598,7 +13609,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13623,13 +13634,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13627: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:13638: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13633 "configure"
+#line 13644 "configure"
@@ -13640,7 +13651,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13644: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13665,13 +13676,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:13669: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:13680: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13675 "configure"
+#line 13686 "configure"
@@ -13682,7 +13693,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:13686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13707,13 +13718,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13711: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:13722: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13717 "configure"
+#line 13728 "configure"
@@ -13724,7 +13735,7 @@
; return 0; }
EOF
-if { (eval echo configure:13728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13749,13 +13760,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13753: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:13764: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 13759 "configure"
+#line 13770 "configure"
@@ -13766,7 +13777,7 @@
; return 0; }
EOF
-if { (eval echo configure:13770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13791,13 +13802,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:13795: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:13806: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 13801 "configure"
+#line 13812 "configure"
@@ -13808,7 +13819,7 @@
; return 0; }
EOF
-if { (eval echo configure:13812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13835,13 +13846,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:13839: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13850: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13845 "configure"
+#line 13856 "configure"
@@ -13852,7 +13863,7 @@
; return 0; }
EOF
-if { (eval echo configure:13856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13871,13 +13882,13 @@
-echo "configure:13875: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:13886: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13881 "configure"
+#line 13892 "configure"
@@ -13888,7 +13899,7 @@
; return 0; }
EOF
-if { (eval echo configure:13892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13915,13 +13926,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:13919: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13930: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 13925 "configure"
+#line 13936 "configure"
@@ -13932,7 +13943,7 @@
; return 0; }
EOF
-if { (eval echo configure:13936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13951,13 +13962,13 @@
-echo "configure:13955: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:13966: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 13961 "configure"
+#line 13972 "configure"
@@ -13968,7 +13979,7 @@
; return 0; }
EOF
-if { (eval echo configure:13972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14081,7 +14092,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14085: checking whether to use FreeType" >&5
+echo "configure:14096: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -14100,7 +14111,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14104: checking for location of FreeType includes" >&5
+echo "configure:14115: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -14126,15 +14137,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14130: checking for $ac_hdr" >&5
+echo "configure:14141: checking for $ac_hdr" >&5
-#line 14133 "configure"
+#line 14144 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14168,7 +14179,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:14172: checking for location of FreeType library" >&5
+echo "configure:14183: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -14193,13 +14204,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:14197: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:14208: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 14203 "configure"
+#line 14214 "configure"
@@ -14210,7 +14221,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:14214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14251,7 +14262,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:14255: checking whether to use NLS" >&5
+echo "configure:14266: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -14271,10 +14282,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:14275: checking for gettext" >&5
+echo "configure:14286: checking for gettext" >&5
-#line 14278 "configure"
+#line 14289 "configure"
which can conflict with char gettext(); below. */
@@ -14297,7 +14308,7 @@
; return 0; }
EOF
-if { (eval echo configure:14301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -14315,13 +14326,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14319: checking for gettext in -lintl" >&5
+echo "configure:14330: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 14325 "configure"
+#line 14336 "configure"
@@ -14332,7 +14343,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:14336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14367,7 +14378,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14371: checking whether to use C++" >&5
+echo "configure:14382: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -14383,7 +14394,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14387: checking for $ac_word" >&5
+echo "configure:14398: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14412,7 +14423,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14416: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14427: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14423,12 +14434,12 @@
cat > conftest.$ac_ext << EOF
-#line 14427 "configure"
+#line 14438 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:14432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -14454,19 +14465,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14458: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14469: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14463: checking whether we are using GNU C++" >&5
+echo "configure:14474: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14470: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14481: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -14484,7 +14495,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14488: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14499: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14525,7 +14536,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14529: checking whether to use openDWG" >&5
+echo "configure:14540: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14545,7 +14556,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14549: checking for location of openDGW includes" >&5
+echo "configure:14560: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14571,15 +14582,15 @@
do
-echo "configure:14575: checking for $ac_hdr" >&5
+echo "configure:14586: checking for $ac_hdr" >&5
-#line 14578 "configure"
+#line 14589 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14594: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14613,7 +14624,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14617: checking for location of openDWG library" >&5
+echo "configure:14628: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14660,7 +14671,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14664: checking for special C compiler options needed for large files" >&5
+echo "configure:14675: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14668,7 +14679,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14672 "configure"
+#line 14683 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14684,7 +14695,7 @@
; return 0; }
EOF
-if { (eval echo configure:14688: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14699: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -14693,7 +14704,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14697 "configure"
+#line 14708 "configure"
@@ -14709,7 +14720,7 @@
; return 0; }
EOF
-if { (eval echo configure:14713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14724: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14729,11 +14740,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14733: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14744: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14737 "configure"
+#line 14748 "configure"
@@ -14749,14 +14760,14 @@
; return 0; }
EOF
-if { (eval echo configure:14753: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14764: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14760 "configure"
+#line 14771 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14774,7 +14785,7 @@
; return 0; }
EOF
-if { (eval echo configure:14778: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14789: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14793,11 +14804,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14797: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14808: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14801 "configure"
+#line 14812 "configure"
@@ -14813,14 +14824,14 @@
; return 0; }
EOF
-if { (eval echo configure:14817: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14824 "configure"
+#line 14835 "configure"
#define _LARGE_FILES 1
@@ -14838,7 +14849,7 @@
; return 0; }
EOF
-if { (eval echo configure:14842: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14853: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14857,25 +14868,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14861: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14872: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14865 "configure"
+#line 14876 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14872: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14883: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14879 "configure"
+#line 14890 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14884,7 +14895,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14888: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14899: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14905,10 +14916,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14909: checking if system supports Large Files at all" >&5
+echo "configure:14920: checking if system supports Large Files at all" >&5
-#line 14912 "configure"
+#line 14923 "configure"
#include <stdio.h>
@@ -14940,7 +14951,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14944: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14955: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14970,7 +14981,7 @@
echo $ac_n "checking whether to use PYTHON""... $ac_c" 1>&6
-echo "configure:14974: checking whether to use PYTHON" >&5
+echo "configure:14985: checking whether to use PYTHON" >&5
echo "$ac_t"""$with_python"" 1>&6
case "$with_python" in
"no") USE_PYTHON= ;;
@@ -14988,7 +14999,7 @@
# Extract the first word of "python", so it can be a program name with args.
set dummy python; ac_word=$2
-echo "configure:14992: checking for $ac_word" >&5
+echo "configure:15003: checking for $ac_word" >&5
case "$PYTHON_BIN" in
@@ -15021,7 +15032,7 @@
# Extract the first word of "python2.3", so it can be a program name with args.
set dummy python2.3; ac_word=$2
-echo "configure:15025: checking for $ac_word" >&5
+echo "configure:15036: checking for $ac_word" >&5
@@ -15054,7 +15065,7 @@
# Extract the first word of "python2.4", so it can be a program name with args.
set dummy python2.4; ac_word=$2
-echo "configure:15058: checking for $ac_word" >&5
+echo "configure:15069: checking for $ac_word" >&5
@@ -15098,7 +15109,7 @@
-echo "configure:15102: checking for $ac_word" >&5
+echo "configure:15113: checking for $ac_word" >&5
@@ -15134,16 +15145,16 @@
# find out python version
echo $ac_n "checking Python version""... $ac_c" 1>&6
-echo "configure:15138: checking Python version" >&5
+echo "configure:15149: checking Python version" >&5
PYVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:3]'`
PYMAJVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[:1]'`
PYMINVERSION=`$PYTHON_BIN -c 'import sys; print sys.version[2:3]'`
echo "$ac_t""$PYVERSION" 1>&6
-# make sure Python is version 2
+# make sure Python is version >= 2.3
if test "$PYMAJVERSION" -lt "2" || \
- (test "$PYMAJVERSION" -eq "2" && test "$PYMINVERSION" -lt "2"); then
+ (test "$PYMAJVERSION" -eq "2" && test "$PYMINVERSION" -lt "3"); then
{ echo "configure: error: This version of GRASS requires at least Python version 2.3.
The one you have seems to be $PYVERSION. You can specify an alternate python
by using (for example) --with-python=/usr/bin/python2.3" 1>&2; exit 1; }
@@ -15153,6 +15164,56 @@
+# wxPython check
+echo $ac_n "checking whether to use wxPython""... $ac_c" 1>&6
+echo "configure:15171: checking whether to use wxPython" >&5
+echo "$ac_t"""$with_wxpython"" 1>&6
+case "$with_wxpython" in
+ "no") USE_WXPYTHON= ;;
+ "yes") USE_WXPYTHON="1" ;;
+ *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
+esac
+if test -n "$USE_WXPYTHON"; then
+ # Python support required
+ if test -z "$USE_PYTHON"; then
+ { echo "configure: error: *** wxPython requires PYTHON functionality (--with-python)." 1>&2; exit 1; }
+ fi
+ # find out wxPython version
+ echo $ac_n "checking wxPython version""... $ac_c" 1>&6
+echo "configure:15189: checking wxPython version" >&5
+ WXVERSION=`$PYTHON_BIN -c 'import wx; print wx.__version__'`
+ if test -z "$WXVERSION"; then
+ { echo "configure: error: *** couldn't find wxPython." 1>&2; exit 1; }
+ fi
+ WXMAJVERSION=`$PYTHON_BIN -c 'import wx; print wx.__version__[:1]'`
+ WXMINVERSION=`$PYTHON_BIN -c 'import wx; print wx.__version__[2:3]'`
+ echo "$ac_t""$WXVERSION" 1>&6
+ # make sure Python is version >= 2.4
+ if test "$PYMAJVERSION" -lt "2" || \
+ (test "$PYMAJVERSION" -eq "2" && test "$PYMINVERSION" -lt "4"); then
+ { echo "configure: error: *** wxPython functionality requires at least Python version 2.4.
+ The one you have seems to be $PYVERSION. You can specify an alternate python
+ by using (for example) --with-python=/usr/bin/python2.4" 1>&2; exit 1; }
+ fi
+ # make sure wxPython is version >= 2.8
+ if test "$WXMAJVERSION" -lt "2" || \
+ (test "$WXMAJVERSION" -eq "2" && test "$WXMINVERSION" -lt "8"); then
+ { echo "configure: error: *** This version of GRASS requires at least wxPython version 2.8.
+ The one you have seems to be $WXVERSION." 1>&2; exit 1; }
+ fi
+fi
USE_TERMIO=
@@ -15413,6 +15474,8 @@
s%@PYTHON@%$PYTHON%g
s%@PYVERSION@%$PYVERSION%g
s%@USE_PYTHON@%$USE_PYTHON%g
+s%@WXVERSION@%$WXVERSION%g
+s%@USE_WXPYTHON@%$USE_WXPYTHON%g
s%@USE_TERMIO@%$USE_TERMIO%g
s%@STRIPFLAG@%$STRIPFLAG%g
s%@GRASS_HOME@%$GRASS_HOME%g
@@ -15714,7 +15777,7 @@
echo " LAPACK support: `if test -n "${USE_LAPACK}" ; then echo yes ; else echo no ; fi`"
-echo " Large File Support (LFS): `if test -n "${USE_LARGEFILES}" ; then echo yes ; else echo no ; fi`"
+echo " Large File support (LFS): `if test -n "${USE_LARGEFILES}" ; then echo yes ; else echo no ; fi`"
echo " Motif support: `if test -n "${USE_MOTIF}" ; then echo yes ; else echo no ; fi`"
@@ -15734,6 +15797,8 @@
echo " Python support: `if test -n "${USE_PYTHON}" ; then echo yes ; else echo no ; fi`"
+echo " wxPython support: `if test -n "${USE_WXPYTHON}" ; then echo yes ; else echo no ; fi`"
echo " Readline support: `if test -n "${USE_READLINE}" ; then echo yes ; else echo no ; fi`"
echo " SQLite support: `if test -n "${USE_SQLITE}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2008-01-13 19:29:42 UTC (rev 29700)
+++ grass/trunk/configure.in 2008-01-13 21:24:33 UTC (rev 29701)
@@ -8,15 +8,16 @@
# PURPOSE: This configure runs all the tests to determine what components
# are installed on the current system. It also defines certain
# configuration variables for compilation and installation.
-# COPYRIGHT: (C) 2000,2004 by the GRASS Development Team
+# COPYRIGHT: (C) 2000-2008 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
-# MANUAL: http://www.gnu.org/manual/autoconf/html_mono/autoconf.html
+# MANUAL: http://www.gnu.org/software/autoconf/manual/autoconf.html
# Website for config.guess, config.sub:
# http://savannah.gnu.org/cgi-bin/viewcvs/config/config/
+# Note: use autoconf-2.13
define([AC_CACHE_LOAD], )
@@ -192,6 +193,7 @@
LOC_ARG_WITH(opendwg, openDWG, no)
LOC_ARG_WITH(curses, Curses, yes)
LOC_ARG_WITH(python, PYTHON, no)
+LOC_ARG_WITH(wxpython, wxPython, no)
# With includes and libs options
@@ -676,7 +678,6 @@
if test "$with_gdal" = "no" ; then
AC_MSG_RESULT(no)
else
- AC_MSG_RESULT(yes)
AC_PATH_PROG(GDAL_CONFIG, gdal-config, no)
if test "$GDAL_CONFIG" = "no" ; then
@@ -1625,9 +1626,9 @@
AC_MSG_RESULT($PYVERSION)
AC_SUBST(PYVERSION)
AC_MSG_ERROR([This version of GRASS requires at least Python version 2.3.
by using (for example) --with-python=/usr/bin/python2.3])
@@ -1637,6 +1638,45 @@
AC_SUBST(USE_PYTHON)
+# wxPython check
+LOC_CHECK_USE(wxpython, wxPython, USE_WXPYTHON)
+ AC_MSG_ERROR([*** wxPython requires PYTHON functionality (--with-python).])
+ fi
+ AC_MSG_CHECKING(wxPython version)
+ WXVERSION=`$PYTHON_BIN -c ['import wx; print wx.__version__'`]
+ AC_MSG_ERROR([*** couldn't find wxPython.])
+ fi
+ WXMAJVERSION=`$PYTHON_BIN -c ['import wx; print wx.__version__[:1]'`]
+ WXMINVERSION=`$PYTHON_BIN -c ['import wx; print wx.__version__[2:3]'`]
+ AC_MSG_RESULT($WXVERSION)
+ AC_SUBST(WXVERSION)
+ AC_MSG_ERROR([*** wxPython functionality requires at least Python version 2.4.
+ by using (for example) --with-python=/usr/bin/python2.4])
+ fi
+ AC_MSG_ERROR([*** This version of GRASS requires at least wxPython version 2.8.
+ The one you have seems to be $WXVERSION.])
+ fi
+fi
+AC_SUBST(USE_WXPYTHON)
USE_TERMIO=
AC_SUBST(USE_TERMIO)
@@ -1684,7 +1724,7 @@
LOC_MSG_USE(GLw support,USE_GLW)
LOC_MSG_USE(JPEG support,USE_JPEG)
LOC_MSG_USE(LAPACK support,USE_LAPACK)
-LOC_MSG_USE(Large File Support (LFS), USE_LARGEFILES)
+LOC_MSG_USE(Large File support (LFS), USE_LARGEFILES)
LOC_MSG_USE(Motif support,USE_MOTIF)
LOC_MSG_USE(MySQL support,USE_MYSQL)
LOC_MSG_USE(NLS support,USE_NLS)
@@ -1694,6 +1734,7 @@
LOC_MSG_USE(PNG support,USE_PNG)
LOC_MSG_USE(PostgreSQL support,USE_POSTGRES)
LOC_MSG_USE(Python support,USE_PYTHON)
+LOC_MSG_USE(wxPython support,USE_WXPYTHON)
LOC_MSG_USE(Readline support,USE_READLINE)
LOC_MSG_USE(SQLite support,USE_SQLITE)
LOC_MSG_USE(Tcl/Tk support,USE_TCLTK)
