[GRASS-SVN] r29710 - grass/trunk/gui/wxpython/vdigit
svn_grass at osgeo.org
Mon Jan 14 17:16:45 EST 2008
Author: martinl
Date: 2008-01-14 17:16:45 -0500 (Mon, 14 Jan 2008)
New Revision: 29710
Added:
grass/trunk/gui/wxpython/vdigit/dig_types.i
grass/trunk/gui/wxpython/vdigit/vertex.cpp
grass/trunk/gui/wxpython/vdigit/Makefile.in
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/digit.cpp
grass/trunk/gui/wxpython/vdigit/digit.h
grass/trunk/gui/wxpython/vdigit/driver.cpp
grass/trunk/gui/wxpython/vdigit/driver.h
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI: vdigit interface upgraded, some new functions added. Rules for Makefile rewriten.
Modified: grass/trunk/gui/wxpython/vdigit/Makefile.in
--- grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-01-14 15:59:28 UTC (rev 29709)
+++ grass/trunk/gui/wxpython/vdigit/Makefile.in 2008-01-14 22:16:45 UTC (rev 29710)
@@ -7,42 +7,39 @@
MODULE_TOPDIR = ../../..
include $(MODULE_TOPDIR)/include/Make/Lib.make
-include $(MODULE_TOPDIR)/include/Make/Doxygen.make
SWIG=swig
-CFLAGS=-c -fpic -I/usr/include/python$(PYTHONVERSION) -I./ -I$(ARCH_DISTDIR)/include `wx-config --cxxflags` `gdal-config --cflags`
+CXXFLAGS=-c -fpic -I$(ARCH_DISTDIR)/include -I/usr/include/python$(PYTHONVERSION) `wx-config --cxxflags`
-LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) -lgrass_vect -lgrass_gis `wx-config --libs` -L./ -lgdi
+LDFLAGS=-shared -fpic -L$(ARCH_LIBDIR) $(VECTLIB) $(GISLIB) $(GDALLIBS) $(VEDITLIB) `wx-config --libs` -lgdi
+LOCAL_HEADERS=digit.h driver.h
+SOURCES=driver.cpp digit.cpp cats.cpp line.cpp vertex.cpp
+OBJARCH=OBJ.$(ARCH)
+OBJ := $(patsubst %.cpp, $(OBJARCH)/%.o, $(SOURCES))
default: grass6_wxvdigit.so
clean:
- -rm -f *.o _grass6_wxvdigit.so grass6_wxvdigit_wrap.cxx grass6_wxvdigit.py grass6_wxvdigit.i grass6_wxvdigit.pyc
+ -rm -rf $(OBJARCH) _grass6_wxvdigit.so grass6_wxvdigit_wrap.cxx grass6_wxvdigit.py grass6_wxvdigit.i grass6_wxvdigit.pyc
grass6_wxvdigit.i:
cat ./digit.i > grass6_wxvdigit.i
- echo "/* auto-generate swig typedef file (with some GRASS functions removed) */" >> grass6_wxvdigit.i
+ cat ./dig_types.i >> grass6_wxvdigit.i
+ echo "/* auto-generate swig typedef file */" >> grass6_wxvdigit.i
cat ./driver.h >> grass6_wxvdigit.i
cat ./digit.h >> grass6_wxvdigit.i
grass6_wxvdigit_wrap.cxx: grass6_wxvdigit.i
$(SWIG) -c++ -python -shadow $<
-grass6_wxvdigit_wrap.o: grass6_wxvdigit_wrap.cxx
- $(CXX) $(CFLAGS) $(INCLUDE_DIRS) $<
+$(OBJARCH)/grass6_wxvdigit_wrap.o: grass6_wxvdigit_wrap.cxx $(OBJARCH)
+ $(CXX) -c $(CXXFLAGS) $(INCLUDE_DIRS) $< -o $@
-driver.o: driver.cpp driver.h
+$(OBJARCH)/%.o: %.cpp $(LOCAL_HEADERS)
-digit.o: digit.cpp digit.h
-cats.o: cats.cpp digit.h
-line.o: line.cpp digit.h
-grass6_wxvdigit.so: grass6_wxvdigit_wrap.o driver.o digit.o cats.o line.o
- $(CXX) $(LDFLAGS) grass6_wxvdigit_wrap.o driver.o digit.o cats.o line.o -o _grass6_wxvdigit.so
+grass6_wxvdigit.so: $(OBJARCH)/grass6_wxvdigit_wrap.o $(OBJ)
+ $(CXX) $(LDFLAGS) $(OBJARCH)/grass6_wxvdigit_wrap.o $(OBJ) -o _grass6_wxvdigit.so
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-01-14 15:59:28 UTC (rev 29709)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-01-14 22:16:45 UTC (rev 29710)
@@ -7,9 +7,10 @@
License (>=v2). Read the file COPYING that comes with GRASS
for details.
- \author (C) by The GRASS development team
- Martin Landa <landa.martin gmail.com>
+ (C) 2008 by The GRASS development team
+ \author Martin Landa <landa.martin gmail.com>
\date 2008
@@ -105,3 +106,18 @@
return old_cat;
+ \brief Copy categories from one vector feature to other
+ \param cats list of layer/category to be copied
+ \param ids list of line ids where to copy categories
+ \return number of modified features
+ \return -1 on error
+int Digit::CopyCats(std::vector<std::vector<int> > cats, std::vector<int> ids)
+ /* TODO */
+ return 0;
Added: grass/trunk/gui/wxpython/vdigit/dig_types.i
--- grass/trunk/gui/wxpython/vdigit/dig_types.i (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/dig_types.i 2008-01-14 22:16:45 UTC (rev 29710)
@@ -0,0 +1,19 @@
+/* extracted from include/vect/dig_defines.h */
+#define GV_POINT 0x01
+#define GV_LINE 0x02
+#define GV_BOUNDARY 0x04
+#define GV_CENTROID 0x08
+#define GV_FACE 0x10
+#define GV_KERNEL 0x20
+#define GV_AREA 0x40
+#define GV_VOLUME 0x80
+#define GV_POINTS (GV_POINT | GV_CENTROID )
+#define GV_LINES (GV_LINE | GV_BOUNDARY )
+/* extracted from vector/v.edit/lib/vedit.h */
+#define NO_SNAP 0 /* snapping disabled */
+#define SNAP 1 /* snapping enabled for nodes */
+#define SNAPVERTEX 2 /* snapping enabled for vertex also */
Modified: grass/trunk/gui/wxpython/vdigit/digit.cpp
--- grass/trunk/gui/wxpython/vdigit/digit.cpp 2008-01-14 15:59:28 UTC (rev 29709)
+++ grass/trunk/gui/wxpython/vdigit/digit.cpp 2008-01-14 22:16:45 UTC (rev 29710)
@@ -29,4 +29,7 @@
if (display->mapInfo) {
InitCats();
+ // avoid GUI crash
+ // Vect_set_fatal_error(GV_FATAL_PRINT);
Modified: grass/trunk/gui/wxpython/vdigit/digit.h
--- grass/trunk/gui/wxpython/vdigit/digit.h 2008-01-14 15:59:28 UTC (rev 29709)
+++ grass/trunk/gui/wxpython/vdigit/digit.h 2008-01-14 22:16:45 UTC (rev 29710)
@@ -19,9 +19,32 @@
int InitCats();
- int AddLine(int, std::vector<double>, bool, int, int);
- int DeleteSelectedLines();
+ int AddLine(int, std::vector<double>, int, int,
+ const char*, int, double);
+ int RewriteLine(int, std::vector<double>);
+ int SplitLine(double, double, double,
+ double);
+ int DeleteLines();
+ int MoveLines(double, double, double,
+ int, double);
+ int FlipLines();
+ int MergeLines();
+ int BreakLines();
+ int SnapLines(double);
+ int ConnectLines(double);
+ int ZBulkLabeling(double, double, double, double,
+ double, double);
+ int CopyLines(std::vector<int>, const char*);
+ int MoveVertex(double, double, double,
+ double, double, double,
+ int, double);
+ int ModifyLineVertex(int, double, double, double,
+ double);
+ int CopyCats(std::vector<std::vector<int> >, std::vector<int>);
int GetCategory(int);
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-01-14 15:59:28 UTC (rev 29709)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-01-14 22:16:45 UTC (rev 29710)
@@ -35,11 +35,17 @@
dc = (wxPseudoDC *) device;
- points = Vect_new_line_struct();
+ points = Vect_new_line_struct();
pointsScreen = new wxList();
- cats = Vect_new_cats_struct();
+ cats = Vect_new_cats_struct();
+ selected = Vect_new_list();
drawSegments = false;
+ // G_set_error_routine(print_error);
@@ -59,6 +65,7 @@
Vect_destroy_line_struct(points);
delete pointsScreen;
Vect_destroy_cats_struct(cats);
+ Vect_destroy_list(selected);
@@ -97,35 +104,16 @@
/* nlines = Vect_get_num_lines(mapInfo); */
- //Vect_build_partial(mapInfo, GV_BUILD_NONE, stderr);
- //Vect_build(mapInfo, stderr);
Vect_get_map_box(mapInfo, &mapBox);
// draw lines inside of current display region
nlines = Vect_select_lines_by_box(mapInfo, &(region.box),
GV_POINTS | GV_LINES, // fixme
listLines);
- nlines = Vect_select_lines_by_box(mapInfo, &mapBox,
- GV_POINTS | GV_LINES, // fixme
- listLines);
- for (int i = 0; i < listLines->n_values; i++) {
- DrawLine(listLines->value[i]);
+ G_debug(3, "driver.DrawMap(): region: w=%f, e=%f, s=%f, n=%f",
+ region.box.W, region.box.E, region.box.S, region.box.N);
-#ifdef DEBUG
- std::cerr.flags(std::ios_base::fixed);
- std::cerr << "region: W=" << region.box.W
- << "; E=" << region.box.E
- << "; S=" << region.box.S
- << "; N=" << region.box.N << std::endl;
- std::cerr << "-> nlines=" << nlines << std::endl;
-#endif
bool inBox;
dc->BeginDrawing();
@@ -133,9 +121,7 @@
dc->EndDrawing();
-#ifdef DEBUG
- PrintIds();
-#endif
+ // PrintIds();
Vect_destroy_list(listLines);
@@ -578,20 +564,6 @@
region.map_width = map_width;
region.map_height = map_height;
-#ifdef DEBUG
- std::cerr << "region: n=" << north
- << "; s=" << south
- << "; e=" << east
- << "; w=" << west
- << "; ns_res=" << ns_res
- << "; ew_res=" << ew_res
- << "; center_easting=" << center_easting
- << "; center_northing=" << center_northing
- << "; map_width=" << map_width
- << "; map_height=" << map_height
- << std::endl;
-#endif
// calculate real region
region.map_res = (region.ew_res > region.ns_res) ? region.ew_res : region.ns_res;
@@ -643,8 +615,7 @@
bool eNodeOne, unsigned long cNodeOne,
bool eNodeTwo, unsigned long cNodeTwo,
bool eVertex, unsigned long cVertex,
- int lineWidth,
- double threshold)
+ int lineWidth)
settings.highlight.Set(highlight);
@@ -678,7 +649,6 @@
settings.vertex.color.Set(cVertex);
settings.lineWidth = lineWidth;
- settings.threshold = threshold;
@@ -692,16 +662,6 @@
void DisplayDriver::PrintIds()
- for (ids_map::const_iterator i = ids.begin(), e = ids.end();
- i != e; ++i) {
- std::cerr << "line=" << i->first << ": "
- << "npoints=" << i->second.npoints
- << " startId=" << i->second.startId
- << std::endl;
std::cerr << "topology.highlight: " << topology.highlight << std::endl;
std::cerr << "topology.point: " << topology.point << std::endl;
@@ -734,9 +694,10 @@
topology.vertex * 2 << std::endl;
std::cerr << "selected: ";
- for (std::vector<int>::const_iterator i = selected.begin(), e = selected.end();
- i != e; ++i)
- std::cerr << *i << " ";
+ for (int i = 0; i < selected->n_values; i++) {
+ std::cerr << selected->value[i] << " ";
std::cerr << std::endl;
return;
@@ -785,21 +746,24 @@
for (int i = 0; i < list->n_values; i++) {
line = list->value[i];
if (!IsSelected(line)) {
- selected.push_back(line);
+ // selected.push_back(line);
+ Vect_list_append(selected, line);
else {
- selected.erase(GetSelectedIter(line));
+ // selected.erase(GetSelectedIter(line));
+ Vect_list_delete(selected, line);
// remove all duplicate ids
- sort(selected.begin(), selected.end());
- selected.erase(unique(selected.begin(), selected.end()), selected.end());
+ // sort(selected.begin(), selected.end());
+ // selected.erase(unique(selected.begin(), selected.end()), selected.end());
Vect_destroy_line_struct(bbox);
Vect_destroy_list(list);
- return selected.size();
+ // return selected.size();
+ return selected->n_values;
@@ -838,7 +802,8 @@
ftype, thresh, 0, 0);
if (line > 0) {
type = Vect_read_line (mapInfo, points, cats, line);
Vect_line_distance (points, x, y, 0.0, WITHOUT_Z,
&px, &py, &pz,
@@ -862,7 +827,8 @@
bool DisplayDriver::IsSelected(int line)
- if (GetSelectedIter(line) != selected.end())
+ // if (GetSelectedIter(line) != selected.end())
+ if (Vect_val_in_list(selected, line))
return true;
return false;
@@ -876,6 +842,7 @@
\return item iterator
\return selected.end() if object is not selected
std::vector<int>::iterator DisplayDriver::GetSelectedIter(int line)
for(std::vector<int>::iterator i = selected.begin(), e = selected.end();
@@ -886,7 +853,7 @@
return selected.end();
\brief Get ids of selected objects
@@ -898,7 +865,7 @@
std::vector<int> DisplayDriver::GetSelected(bool grassId)
if (grassId)
- return selected;
+ return ListToVector(selected);
std::vector<int> dc_ids;
long int line;
@@ -908,7 +875,7 @@
else {
int npoints;
- Vect_read_line(mapInfo, points, NULL, selected[0]);
+ Vect_read_line(mapInfo, points, NULL, selected->value[0]);
npoints = points->n_points;
for (int i = 1; i < 2 * npoints; i++) {
dc_ids.push_back(i);
@@ -955,9 +922,10 @@
int DisplayDriver::SetSelected(std::vector<int> id)
- selected = id;
+ // selected = id;
+ VectorToList(selected, id);
- if (selected.size() <= 0)
+ if (selected->n_values <= 0)
return 1;
@@ -988,11 +956,11 @@
std::vector<int> returnId;
// only one object can be selected
- if (selected.size() != 1 || !drawSegments)
+ if (selected->n_values != 1 || !drawSegments)
return returnId;
startId = 1;
- line = selected[0];
+ line = selected->value[0];
@@ -1076,3 +1044,61 @@
return;
+ \brief Convert vect list to std::vector
+ \param list vect list
+ \return std::vector
+std::vector<int> DisplayDriver::ListToVector(struct ilist *list)
+ std::vector<int> vect;
+ if (!list)
+ return vect;
+ for (int i = 0; i < list->n_values; i++) {
+ vect.push_back(list->value[i]);
+ return vect;
+ \brief Convert std::vector to vect list
+ \param vec std::vector instance
+ \return number of items
+int DisplayDriver::VectorToList(struct ilist *list, const std::vector<int>& vec)
+ if (!list)
+ return -1;
+ Vect_reset_list(list);
+ for (std::vector<int>::const_iterator i = vec.begin(), e = vec.end();
+ i != e; ++i) {
+ Vect_list_append(list, *i);
+ return list->n_values;
+ \brief Error messages handling
+ \param msg message
+ \param type type message (MSG, WARN, ERR)
+ \return 0
+int print_error(const char *msg, int type)
+ return 0;
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h 2008-01-14 15:59:28 UTC (rev 29709)
+++ grass/trunk/gui/wxpython/vdigit/driver.h 2008-01-14 22:16:45 UTC (rev 29710)
@@ -28,8 +28,6 @@
#include <grass/Vect.h>
-// #define DEBUG
class DisplayDriver
private:
@@ -56,7 +54,10 @@
ids_map ids; // gId : {dcIds, ...}
- std::vector<int> selected; // list of selected features (gId)
+ // list of selected features (gId)
+ // std::vector<int> selected;
+ struct ilist *selected;
bool drawSegments; // draw segments of selected line
struct Map_info *mapInfo;
@@ -105,8 +106,6 @@
symbol vertex;
int lineWidth; // screen units
- double threshold; // threshold value (map units)
} settings;
struct _topology {
@@ -143,7 +142,9 @@
/* select feature */
bool IsSelected(int line);
- std::vector<int>::iterator GetSelectedIter(int line);
+ // std::vector<int>::iterator GetSelectedIter(int line);
+ std::vector<int> ListToVector(struct ilist *);
+ int VectorToList(struct ilist *, const std::vector<int>&);
void ResetTopology();
@@ -189,8 +190,9 @@
bool, unsigned long,
- int,
- double);
+ int);
+int print_error(const char *, int);
#endif /* __DRIVER_H__ */
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-14 15:59:28 UTC (rev 29709)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-14 22:16:45 UTC (rev 29710)
@@ -7,75 +7,56 @@
for details.
\date 2008
+extern "C" {
+#include <grass/vedit.h>
#include "driver.h"
#include "digit.h"
- \brief Delete selected lines
+ \brief Add new vector feature
- \return number of deleted lines
- \return -1 on error
-int Digit::DeleteSelectedLines()
- int nlines = 0;
- if (!display->mapInfo) {
- return -1;
- for(std::vector<int>::iterator i = display->selected.begin(), e = display->selected.end();
- i != e; ++i) {
- Vect_delete_line(display->mapInfo, *i);
- return nlines;
- \brief Add new line
- For feature type see include/vect/dig_defines.h
- #define GV_POINT 0x01
- #define GV_LINE 0x02
- #define GV_BOUNDARY 0x04
- #define GV_CENTROID 0x08
- (unsupported)
- #define GV_FACE 0x10
-1 #define GV_KERNEL 0x20
- #define GV_AREA 0x40
- #define GV_VOLUME 0x80
\param type feature type
- \param coords pairs of coordinates list
- \param with_z 3D?
+ \param coords pairs of coordinates list (2D or 3D map)
+ \param layer layer number
+ \param cat category number
+ \param bgmap map of background map or NULL
+ \param snap snapping mode (see vedit.h)
+ \param thresh threshold value for snapping
\return 1 on success
\return -1 on failure
-int Digit::AddLine(int type, std::vector<double> coords, bool with_z, int layer, int cat)
+int Digit::AddLine(int type, std::vector<double> coords, int layer, int cat,
+ const char *bgmap, int snap, double threshold)
int i, npoints;
+ int newline;
struct line_pnts *Points;
struct line_cats *Cats;
+ struct Map_info **BgMap; /* backgroud vector maps */
+ int nbgmaps; /* number of registrated background maps */
return -1;
- npoints = coords.size() / (with_z ? 3 : 2);
- if (coords.size() != npoints * (with_z ? 3 : 2)) {
+ npoints = coords.size() / (Vect_is_3d(display->mapInfo) ? 3 : 2);
+ if (coords.size() != npoints * (Vect_is_3d(display->mapInfo) ? 3 : 2)) {
return -1;
+ G_debug(1, "Digit.AddLine(): npoints=%d", npoints);
/* TODO: 3D */
if (!(type & GV_POINTS) && !(type & GV_LINES)) {
return -1;
@@ -85,6 +66,23 @@
return -1;
+ BgMap = NULL;
+ if (bgmap) {
+ const char *mapset;
+ mapset = G_find_vector2 (bgmap, "");
+ if (mapset) {
+ if (strcmp(G_fully_qualified_name((const char*) display->mapInfo->name, (const char*) G_mapset()),
+ G_fully_qualified_name((const char*) bgmap, (const char*) mapset))) {
+ nbgmaps = 1;
+ BgMap = (struct Map_info**) G_realloc ((void *) BgMap, nbgmaps * sizeof(struct Map_info*));
+ BgMap[nbgmaps-1] = (struct Map_info *) G_malloc (sizeof(struct Map_info));
+ Vect_open_old(BgMap[nbgmaps-1], (char *) bgmap, (char*) mapset);
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -96,7 +94,7 @@
i = 0;
while (i < coords.size()) {
- if (with_z) {
+ if (Vect_is_3d(display->mapInfo)) {
Vect_append_point(Points, coords[i], coords[i+1], coords[i+2]);
i += 3;
@@ -110,17 +108,358 @@
int last = Points->n_points-1;
if (Vect_points_distance(Points->x[0], Points->x[0], Points->z[0],
Points->x[last], Points->x[last], Points->z[last],
- with_z) <= display->settings.threshold) {
+ Vect_is_3d(display->mapInfo)) <= threshold) {
Points->x[last] = Points->x[0];
Points->y[last] = Points->y[0];
Points->z[last] = Points->z[0];
+ G_debug(3, "Digit.AddLine(): boundary closed");
- Vect_write_line(display->mapInfo, type, Points, Cats);
+ newline = Vect_write_line(display->mapInfo, type, Points, Cats);
+ if (snap != NO_SNAP) { /* apply snapping */
+ Vedit_snap_line(display->mapInfo, BgMap, nbgmaps, /* limited only to one background map */
+ newline,
+ threshold, (SNAP) ? 0 : 1); /* snap to vertex ? */
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
+ if (BgMap && BgMap[0]) {
+ Vect_close(BgMap[0]);
return 1;
+ \brief Rewrite given line
+ \param line line id
+ \param coords line geometry
+ \return new line id
+ \return -1 error
+int Digit::RewriteLine(int line, std::vector<double> coords)
+ int ret, type, dim;
+ double x, y, z;
+ struct line_pnts *points;
+ struct line_cats *cats;
+ if (!display->mapInfo) {
+ return -1;
+ /* line alive ? */
+ if (!Vect_line_alive(display->mapInfo, line)) {
+ return -1;
+ ret = 0;
+ /* read line */
+ type = Vect_read_line(display->mapInfo, NULL, cats, line);
+ if (type < 0) {
+ ret = -1;
+ /* define line geometry */
+ dim = 3;
+ else {
+ dim = 2;
+ for(size_t i = dim - 1; i < coords.size(); i += dim) {
+ if (dim == 2) {
+ Vect_append_point(points, coords[i-1], coords[i], 0.0);
+ else {
+ Vect_append_point(points, coords[i-2], coords[i-1], coords[i]);
+ /* rewrite line */
+ if (ret == 0) {
+ if (Vect_rewrite_line(display->mapInfo, line, type, points, cats) < 0) {
+ ret = -1;
+ Vect_destroy_line_struct(points);
+ Vect_destroy_cats_struct(cats);
+ return ret;
+ \brief Split/break selected line
+ Shape of line is not changed.
+ \param x,y,z coordinates (z is used only if map is 3d)
+ \param thresh threshold value to find a point on line
+int Digit::SplitLine(double x, double y, double z,
+ double thresh)
+ int ret;
+ struct line_pnts *point;
+ return -1;
+ point = Vect_new_line_struct();
+ Vect_append_point(point, x, y, z);
+ ret = Vedit_split_lines(display->mapInfo, display->selected,
+ point, thresh, NULL);
+ Vect_destroy_line_struct(point);
+ return ret;
+ \brief Delete selected vector features
+ \return number of deleted lines
+int Digit::DeleteLines()
+ int ret;
+ return -1;
+ ret = Vedit_delete_lines(display->mapInfo, display->selected);
+ return ret;
+ \brief Move selected vector features
+ \param move_x,move_y,move_z move direction (move_z is used only if map is 3D)
+ \param snap snapping move (see vedit.h)
+ \return number of moved features
+int Digit::MoveLines(double move_x, double move_y, double move_z,
+ int snap, double thresh)
+ int ret;
+ return -1;
+ ret = Vedit_move_lines(display->mapInfo, display->selected,
+ move_x, move_y, move_z,
+ snap, thresh);
+ return ret;
+ \brief Flip selected lines/boundaries
+ \return number of modified lines
+int Digit::FlipLines()
+ int ret;
+ return -1;
+ ret = Vedit_flip_lines(display->mapInfo, display->selected);
+ return ret;
+ \brief Merge selected lines/boundaries
+int Digit::MergeLines()
+ int ret;
+ return -1;
+ ret = Vedit_merge_lines(display->mapInfo, display->selected);
+ return ret;
+ \brief Breaks selected lines/boundaries
+int Digit::BreakLines()
+ int ret;
+ return -1;
+ ret = Vect_break_lines_list(display->mapInfo, display->selected,
+ GV_LINES, NULL, NULL);
+ return ret;
+ \brief Snap selected lines/boundaries
+int Digit::SnapLines(double thresh)
+ int ret;
+ return -1;
+ Vect_snap_lines_list (display->mapInfo, display->selected,
+ thresh, NULL, NULL);
+ return ret;
+ \brief Connect two selected lines/boundaries
+ \return 1 lines connected
+ \return 0 lines not connected
+int Digit::ConnectLines(double thresh)
+ int ret;
+ return -1;
+ ret = Vedit_connect_lines(&Map, List,
+ thresh);
+ return ret;
+ \brief Automated labeling (z coordinate assignment) of vector lines (contours).
+ Modified vector map must be 3D.
+ \param x1,y1,x2,y2 line nodes for intersection
+ \param start starting value
+ \param step step value for labeling
+int Digit::ZBulkLabeling(double x1, double y1, double x2, double y2,
+ double start, double step)
+ int ret;
+ return -1;
+ ret = Vedit_bulk_labeling (display->mapInfo, display->selected,
+ x1, y1, x2, y2, start, step);
+ return ret;
+ \brief Copy vector features
+ \param ids line ids to be copied (if not given selected are used)
+ \param bgmap name of background map (if not given, copy features from input)
+ \return number of copied features
+int Digit::CopyLines(std::vector<int> ids, const char* bgmap_name)
+ int ret;
+ struct Map_info *bgMap;
+ struct ilist *list;
+ bgMap = NULL;
+ list = NULL;
+ return -1;
+ if (bgmap_name) {
+ bgMap = (struct Map_info *) G_malloc(sizeof (struct Map_info));
+ mapset = G_find_vector2 (bgmap_name, "");
+ Vect_open_old(bgMap, (char *) bgmap_name, (char *) mapset); /* TODO */
+ if (!ids.empty) {
+ list = Vect_new_list_struct();
+ else {
+ list = display->selected;
+ int Vedit_copy_lines (display->mapInfo, bgMap,
+ list);
+ if (list != display->selected) {
+ Vect_destroy_list_struct(list);
+ if (bgMap) {
+ Vect_close(bgMap);
+ G_free ((void *) bgMap);
+ return ret;
Added: grass/trunk/gui/wxpython/vdigit/vertex.cpp
--- grass/trunk/gui/wxpython/vdigit/vertex.cpp (rev 0)
+++ grass/trunk/gui/wxpython/vdigit/vertex.cpp 2008-01-14 22:16:45 UTC (rev 29710)
@@ -0,0 +1,97 @@
+ \file vertex.cpp
+ \brief Vertex manipulation
+ This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+ \date 2008
+extern "C" {
+#include "driver.h"
+#include "digit.h"
+ \brief Move vertex
+ \param move_x,move_y,move_z direction for moving vertex
+ \param snap snap mode (see vector/v.edit/lib/vedit.h)
+ \param thresh threshold value to identify vertex position
+ \param 1 vertex added/removed
+ \param 0 nothing changed
+ \param -1 error
+int Digit::MoveVertex(double x, double y, double z,
+ double move_x, double move_y, double move_z,
+ int snap, double thresh) {
+ int ret;
+ return -1;
+ /* move only first found vertex in bbox */
+ ret = Vedit_move_vertex(display->mapInfo, NULL, 0, /* TODO: BG */
+ display->selected,
+ point, thresh,
+ 1, (snap == SNAPVERTEX) ? 1 : 0);
+ return ret;
+ \brief Add or remove vertex
+ Shape of line/boundary is not changed when adding new vertex.
+ \param add add or remove vertex?
+ \param -1 error
+int Digit::ModifyLineVertex(int add, double x, double y, double z,
+ double thresh)
+ int ret;
+ if (!display->mapInfo || display->selected->n_values != 1)
+ return -1;
+ if (add) {
+ ret = Vedit_add_vertex(display->mapInfo, display->selected,
+ point, thresh);
+ else {
+ ret = Vedit_remove_vertex(display->mapInfo, display->selected,
+ point, thresh);
+ return ret;
