[GRASS-SVN] r29715 -
	grass/branches/releasebranch_6_2/raster/r.le/r.le.setup
    svn_grass at osgeo.org
    Tue Jan 15 21:12:47 EST 2008
Author: hamish
Date: 2008-01-15 21:12:47 -0500 (Tue, 15 Jan 2008)
New Revision: 29715
   grass/branches/releasebranch_6_2/raster/r.le/r.le.setup/sample.c
work for sample radius > 100, update site->vector points, "shape" to aspect ratio
(merge from HEAD)
Modified: grass/branches/releasebranch_6_2/raster/r.le/r.le.setup/sample.c
--- grass/branches/releasebranch_6_2/raster/r.le/r.le.setup/sample.c	2008-01-16 01:00:53 UTC (rev 29714)
+++ grass/branches/releasebranch_6_2/raster/r.le/r.le.setup/sample.c	2008-01-16 02:12:47 UTC (rev 29715)
@@ -22,10 +22,12 @@
 #include <stdlib.h>
 #include <grass/gis.h>
-#include "setup.h"
+#include <grass/Vect.h>
 #include <grass/config.h>
 #include <grass/raster.h>
 #include <grass/display.h>
+#include <grass/glocale.h>
+#include "setup.h"
 static int calc_unit_loc (double radius, int top, int bot, int left, int right,
@@ -310,11 +312,11 @@
               if (!G_yes("\n       radius (> 100 pixels)?   ",1))
                  goto getradius;
-           else {
-              ratio = 1.0;
-              u_w = (int)(2 * radius);
-              u_l = (int)(2 * radius);
+	   ratio = 1.0;
+	   u_w = (int)(2 * radius);
+	   u_l = (int)(2 * radius);
 	   if (fmask > 0) {
 	      count = 0;
 	      row_buf = G_allocate_raster_buf(CELL_TYPE);
@@ -347,7 +349,7 @@
 	  			/* get the width/length ratio */
 getratio:
-	   fprintf(stderr, "\n    Sampling unit SHAPE (#cols/#rows) expressed as real");
+	   fprintf(stderr, "\n    Sampling unit SHAPE (aspect ratio, #cols/#rows) expressed as real");
            fprintf(stderr, " number\n    (e.g., 10 cols/5 rows = 2.0) for sampling units");
            fprintf(stderr, " of scale %d? ", i+1);
@@ -727,13 +729,16 @@
 	int *sites, double startx, int starty, int fmask,
 	double nx, double x, double y)
-  char	  *sites_mapset, sites_file_name[GNAME_MAX], *desc, *cmd;
-  FILE	  *sites_fp;
+  char	  *sites_mapset, sites_file_name[GNAME_MAX], *cmd;
+  struct  Map_info Map;
   struct  Cell_head region;
-  double  east_coord, north_coord, D_u_to_a_col(), D_u_to_a_row();
+  double  D_u_to_a_col(), D_u_to_a_row();
   int     i, j, k, cnt=0, w_w = right - left, w_l = bot - top, exp1, exp2,
           dx = w_w, dy = w_l, l, t, left1 = left, top1 = top, n, tmp,
 	  ulrow, ulcol, *row_buf, lap=0;
+  static struct line_pnts *Points;
+  struct line_cats *Cats;
+  int ltype;
 /*   VARIABLES:
 	UNITS FOR ALL DIMENSION VARIABLES IN THIS ROUTINE ARE IN PIXELS
@@ -912,26 +917,34 @@
 				/* for centered over sites */
   else if (method==5){
-     sites_mapset=G_ask_sites_old("    Enter name of site map", sites_file_name) ;
+     sites_mapset = G_ask_vector_old("    Enter name of vector points map", sites_file_name);
      if (sites_mapset == NULL) {
         G_system("d.frame -e");
         exit(0);
-     if ((sites_fp = G_fopen_sites_old(sites_file_name,sites_mapset)) == NULL) {
-        fprintf(stderr, "\n    Can't open sites file %s\n",sites_file_name);
+     Vect_open_old(&Map, sites_file_name, sites_mapset);
+/*    fprintf(stderr, "\n    Can't open vector points file %s\n", sites_file_name); */
      *sites = 0;
      i = 0;
      n = 0;
-     while( G_get_site(sites_fp,&east_coord,&north_coord,&desc) > 0) {
-	ulcol = ((int)(D_u_to_a_col(east_coord))) + 1 - u_w/2;
-	ulrow = ((int)(D_u_to_a_row(north_coord))) + 1 - u_l/2;
+     Points = Vect_new_line_struct();    /* init line_pnts struct */
+     Cats = Vect_new_cats_struct();
+     while (1) {
+	ltype =  Vect_read_next_line (&Map, Points, Cats);
+	if ( ltype == -1 ) G_fatal_error(_("Cannot read vector"));
+	if ( ltype == -2 ) break;  /* EOF */
+	/* point features only. (GV_POINTS is pts AND centroids, GV_POINT is just pts) */
+	if (!(ltype & GV_POINT)) continue;
+	ulcol = ((int)(D_u_to_a_col(Points->x[0]))) + 1 - u_w/2;
+	ulrow = ((int)(D_u_to_a_row(Points->y[0]))) + 1 - u_l/2;
 	if (ulcol <= left || ulrow <= top || ulcol+u_w-1 > right || ulrow+u_l-1 > bot) {
 	   fprintf(stderr, "    No sampling unit over site %d at east=%8.1f north=%8.1f\n",
-	      n+1,east_coord,north_coord);
+	      n+1, Points->x[0], Points->y[0]);
 	   fprintf(stderr, "       as it would extend outside the map\n");
@@ -952,6 +965,10 @@
      G_system(cmd);
      G_free (cmd);
+     Vect_close(&Map);
+     G_free(Points);
+     G_free(Cats);
   return 1;
