[GRASS-SVN] r29717 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Jan 16 08:14:07 EST 2008
Author: martinl
Date: 2008-01-16 08:14:07 -0500 (Wed, 16 Jan 2008)
New Revision: 29717
grass/trunk/lib/vector/Vlib/open_nat.c
grass/trunk/lib/vector/Vlib/open_ogr.c
grass/trunk/lib/vector/Vlib/write_nat.c
vectlib: doxygen, i18n updated
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c 2008-01-16 04:14:45 UTC (rev 29716)
+++ grass/trunk/lib/vector/Vlib/open_nat.c 2008-01-16 13:14:07 UTC (rev 29717)
@@ -1,35 +1,45 @@
-* MODULE: Vector library
-* AUTHOR(S): Original author CERL, probably Dave Gerdes or Mike Higgins.
-* Update to GRASS 5.7 Radim Blazek and David D. Gray.
-* PURPOSE: Higher level functions for reading/writing/manipulating vectors.
-* COPYRIGHT: (C) 2001 by the GRASS Development Team
-* This program is free software under the GNU General Public
-* License (>=v2). Read the file COPYING that comes with GRASS
-* for details.
+ \file open_nat.c
+ \brief Vector library - open vector map (native format)
+ Higher level functions for reading/writing/manipulating vectors.
+ (C) 2001-2008 by the GRASS Development Team
+ This program is free software under the
+ GNU General Public License (>=v2).
+ Read the file COPYING that comes with GRASS
+ for details.
+ \author Original author CERL, probably Dave Gerdes or Mike Higgins.
+ Update to GRASS 5.7 Radim Blazek and David D. Gray.
+ \date 2001
#include <unistd.h>
+#include <sys/types.h>
+#include <sys/stat.h>
#include <grass/Vect.h>
#include <grass/gis.h>
+#include <grass/glocale.h>
-#include <sys/types.h>
-#include <sys/stat.h>
+static char name_buf[GPATH_MAX];
+static int check_coor ( struct Map_info *Map );
-static char name_buf[1024];
-int check_coor ( struct Map_info *Map );
+ \brief Open existing vector map
-/* Open old file.
-* Map->name and Map->mapset must be set before
-* Return: 0 success
-* -1 error */
+ Map->name and Map->mapset must be set before.
+ \param Map poiter to vector map
+ \param update non-zero for write mode, otherwise read-only
+ \return 0 success
+ \return -1 error
int
V1_open_old_nat ( struct Map_info *Map, int update)
@@ -59,10 +69,17 @@
return (0);
-/* Open new file.
-* -1 error */
+ \brief Open/Create new vector map.
+ \param Map pointer to vector map
+ \param name map name
+ \param with_z 2D or 3D (unused?)
+ \return 0 success
+ \return -1 error
int
V1_open_new_nat (
@@ -123,11 +140,11 @@
Map->head.size, CInfo.size);
if ( dif > 0 ) {
- G_warning ( "coor files of vector '%s@%s' is larger than it should be "
- "(%ld bytes excess).", Map->name, Map->mapset, dif);
+ G_warning (_("Coor files of vector map <%s@%s> is larger than it should be "
+ "(%ld bytes excess)"), Map->name, Map->mapset, dif);
} else if ( dif < 0 ) {
- G_warning ( "coor files of vector '%s@%s' is shorter than it should be "
- "(%ld bytes missing).", Map->name, Map->mapset, -dif);
+ G_warning (_("Coor files of vector <%s@%s> is shorter than it should be "
+ "(%ld bytes missing)."), Map->name, Map->mapset, -dif);
return 1;
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c 2008-01-16 04:14:45 UTC (rev 29716)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c 2008-01-16 13:14:07 UTC (rev 29717)
@@ -1,33 +1,46 @@
-* AUTHOR(S): Radim Blazek, Piero Cavalieri
-* for details.
+ \file open_ogr.c
+ \brief Vector library - open vector map (OGR format)
+ for details.
+ \date 2001
#include <unistd.h>
#include <string.h>
#ifdef HAVE_OGR
#include <ogr_api.h>
-/* Open old file.
-* -1 error
+ (write mode is currently not supported)
+ \return 0 success
+ \return -1 error
int
V1_open_old_ogr (struct Map_info *Map, int update)
@@ -38,7 +51,7 @@
OGRFeatureDefnH Ogr_featuredefn;
if (update) {
- G_warning ("OGR format cannot be updated.");
+ G_warning (_("OGR format cannot be updated"));
return -1;
@@ -50,7 +63,7 @@
/*Data source handle */
Ogr_ds = OGROpen (Map->fInfo.ogr.dsn, FALSE, NULL);
if (Ogr_ds == NULL)
- G_fatal_error ("Cannot open OGR data source '%s'", Map->fInfo.ogr.dsn);
+ G_fatal_error (_("Unable to open OGR data source '%s'"), Map->fInfo.ogr.dsn);
Map->fInfo.ogr.ds = Ogr_ds;
/* Layer number */
@@ -68,7 +81,7 @@
if (layer == -1) {
OGR_DS_Destroy (Ogr_ds);
- G_fatal_error ("Cannot open layer '%s'", Map->fInfo.ogr.layer_name);
+ G_fatal_error (_("Unable to open layer <%s>"), Map->fInfo.ogr.layer_name);
G_debug (2, "OGR layer %d opened", layer);
@@ -88,16 +101,19 @@
return (0);
-/* Open OGR specific level 2 files (feature index).
-* -1 error
+ \brief Open OGR specific level 2 files (feature index)
+ \return 0 success
+ \return -1 error
int
V2_open_old_ogr (struct Map_info *Map )
- char elem[1000];
- char buf[5];
+ char elem[GPATH_MAX];
+ char buf[5]; /* used for format version */
long length;
GVFILE fp;
struct Port_info port;
@@ -109,7 +125,7 @@
dig_file_init ( &fp );
fp.file = G_fopen_old ( elem, "fidx", Map->mapset);
if ( fp.file == NULL) {
- G_warning("Can't open fidx file for vector '%s@%s'.", Map->name, Map->mapset);
+ G_warning(_("Unable to open fidx file for vector map <%s@%s>"), Map->name, Map->mapset);
return -1;
@@ -125,13 +141,13 @@
/* check version numbers */
if ( Version_Major > 5 || Version_Minor > 0 ) {
if ( Back_Major > 5 || Back_Minor > 0 ) {
- G_fatal_error ( "Feature index format version %d.%d is not supported by this release."
- " Try to rebuild topology or upgrade GRASS.", Version_Major, Version_Minor);
+ G_fatal_error (_("Feature index format version %d.%d is not supported by this release."
+ " Try to rebuild topology or upgrade GRASS."), Version_Major, Version_Minor);
return (-1);
- G_warning ( "Your GRASS version does not fully support feature index format %d.%d of the vector."
- " Consider to rebuild topology or upgrade GRASS.",
- Version_Major, Version_Minor );
+ G_warning (_("Your GRASS version does not fully support feature index format %d.%d of the vector."
+ " Consider to rebuild topology or upgrade GRASS."),
+ Version_Major, Version_Minor );
dig_init_portable ( &port, byte_order );
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c 2008-01-16 04:14:45 UTC (rev 29716)
+++ grass/trunk/lib/vector/Vlib/write_nat.c 2008-01-16 13:14:07 UTC (rev 29717)
@@ -1,27 +1,32 @@
-* for details.
+ \file write_nat.c
+ \brief Vector library - write data
+ for details.
+ \date 2001
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
-void delete_area_cats_from_cidx ( struct Map_info *Map, int area )
+static void delete_area_cats_from_cidx ( struct Map_info *Map, int area )
int i;
P_AREA *Area;
@@ -30,7 +35,7 @@
G_debug ( 3, "delete_area_cats_from_cidx() area = %d", area );
Area = Map->plus.Area[area];
- if ( !Area ) G_fatal_error ("BUG (delete_area_cats_from_cidx): Area %d does not exist", area );
+ if ( !Area ) G_fatal_error (_("BUG (delete_area_cats_from_cidx): Area %d does not exist"), area);
if ( Area->centroid == 0 ) return;
@@ -43,7 +48,7 @@
-void add_area_cats_to_cidx ( struct Map_info *Map, int area )
+static void add_area_cats_to_cidx ( struct Map_info *Map, int area )
int i;
P_AREA *Area;
@@ -52,7 +57,7 @@
G_debug ( 3, "add_area_cats_to_cidx() area = %d", area );
- if ( !Area ) G_fatal_error ("BUG (add_area_cats_to_cidx): Area %d does not exist", area );
+ if ( !Area ) G_fatal_error (_("BUG (add_area_cats_to_cidx): Area %d does not exist"), area );
@@ -66,12 +71,19 @@
long V1__rewrite_line_nat ( struct Map_info *Map, long offset, int type,
- struct line_pnts *points, struct line_cats *cats);
+ struct line_pnts *points, struct line_cats *cats);
-/* Writes line to 'coor' file.
-* Returns: offset into file
-* -1 on error */
+ \brief Writes line to 'coor' file
+ \param type feature type
+ \param points line geometry
+ \param cats line cats
+ \return offset into file
+ \return -1 on error
long
V1_write_line_nat ( struct Map_info *Map,
int type,
@@ -90,10 +102,17 @@
return V1__rewrite_line_nat (Map, offset, type, points, cats);
-* Returns: number of new line
-* -1 on error */
+ \brief Writes line to 'coor' file.
+ \return number of new line
long
V2_write_line_nat ( struct Map_info *Map,
int type,
@@ -276,15 +295,25 @@
return line;
-/* Rewrites line at the given offset.
-* If the number of points or cats differs from
-* the original one or the type is changed:
-* GV_POINTS -> GV_LINES or GV_LINES -> GV_POINTS,
-* the old one is deleted and the
-* new is appended to the end of the file.
-* Returns: line offset
-* -1 on error
+ \brief Rewrites line at the given offset.
+ If the number of points or cats differs from
+ the original one or the type is changed:
+ GV_POINTS -> GV_LINES or GV_LINES -> GV_POINTS,
+ the old one is deleted and the
+ new is appended to the end of the file.
+ Old line is deleted (marked as dead), new line written.
+ \param offset line offset
+ \return line offset (rewriten line)
long
V1_rewrite_line_nat ( struct Map_info *Map,
@@ -332,10 +361,19 @@
-/* Rewrites line of given number.
-* -1 on error
+ \brief Rewrites line of given number.
+ \param line line id
int
V2_rewrite_line_nat ( struct Map_info *Map,
@@ -355,10 +393,17 @@
return ( V2_write_line_nat ( Map, type, points, cats) );
-* -1 on error
long
@@ -447,10 +492,14 @@
return offset;
-/* Deletes line at the given offset.
-* Returns: 0 ok
-* -1 on error
+ \brief Deletes line at the given offset.
+ \return 0 ok
int
V1_delete_line_nat (
@@ -486,10 +535,14 @@
return 0;
-/* Deletes line of given number.
-* Returns: 0 ok
-* -1 on error
+ \brief Deletes line of given number.
+ \param pointer to vector map
+ \return 0 ok
int
V2_delete_line_nat ( struct Map_info *Map, int line )
@@ -509,7 +562,7 @@
if ( plus->built >= GV_BUILD_BASE ) {
Line = Map->plus.Line[line];
- if ( Line == NULL ) G_fatal_error ("Attempt to delete dead line");
+ if ( Line == NULL ) G_fatal_error (_("Attempt to delete dead line"));
type = Line->type;
@@ -655,4 +708,3 @@
G_debug ( 3, "updated lines : %d , updated nodes : %d", plus->n_uplines, plus->n_upnodes );
return ret;
