[GRASS-SVN] r29719 - in grass/trunk/gui/wxpython: . gui_modules
vdigit
svn_grass at osgeo.org
Wed Jan 16 11:45:58 EST 2008
Author: martinl
Date: 2008-01-16 11:45:58 -0500 (Wed, 16 Jan 2008)
New Revision: 29719
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/gui_modules/render.py
grass/trunk/gui/wxpython/gui_modules/toolbars.py
grass/trunk/gui/wxpython/vdigit/cats.cpp
grass/trunk/gui/wxpython/vdigit/driver.cpp
grass/trunk/gui/wxpython/vdigit/driver.h
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI: Some updates for digitization tool, to avoid calling v.edit on the background
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2008-01-16 13:35:15 UTC (rev 29718)
+++ grass/trunk/gui/wxpython/Makefile 2008-01-16 16:45:58 UTC (rev 29719)
@@ -2,10 +2,12 @@
PGM=wxgrass
-include $(MODULE_TOPDIR)/include/Make/Script.make
+SUBDIRS=vdigit
-default: install_scripts
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: parsubdirs install_scripts
install_scripts:
$(MKDIR) $(ETC)/wx/wx $(ETC)/wx/compat $(ETC)/wx/vdigit $(ETC)/wx/gui_modules $(ETC)/wx/icons $(ETC)/wx/icons/silk $(ETC)/wx/images $(ETC)/wx/scripts
$(INSTALL_DATA) compat/* $(ETC)/wx/compat/
@@ -17,3 +19,5 @@
$(INSTALL_DATA) scripts/* $(ETC)/wx/scripts/
$(INSTALL_DATA) gis_set.py wxgui.py $(ETC)/wx/
$(INSTALL) -m 755 wxgrass $(GISBASE)/scripts/
+clean: cleansubdirs
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-01-16 13:35:15 UTC (rev 29718)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-01-16 16:45:58 UTC (rev 29719)
@@ -46,14 +46,17 @@
from debug import Debug as Debug
import gselect
try:
- digitPath = os.path.join(os.getenv("GISBASE"), "etc","wx", "vdigit")
+ digitPath = os.path.join(os.getenv("GISBASE"), "etc", "wx", "vdigit")
sys.path.append(digitPath)
- from grass6_wxvdigit import DisplayDriver
+ import grass6_wxvdigit as vdigit
except ImportError, err:
- print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s).%s" \
+ print >> sys.stderr, "%sWARNING: Digitization tool is disabled (%s). " \
"Detailed information in README file." % \
- (os.linesep, err, os.linesep)
+ (os.linesep, err)
+# Use v.edit on background or experimental C++ interface (not yet completed)
USEVEDIT = True
class DigitError(Exception):
@@ -62,9 +65,12 @@
def __str__(self):
wx.MessageBox(parent=None,
+ caption=_("Error in digitization tool"),
message=self.message,
style=wx.ICON_ERROR)
+ return ''
class AbstractDigit:
Abstract digitization class
@@ -173,9 +179,19 @@
Debug.msg (3, "AbstractDigit.SetMapName map=%s" % map)
self.map = map
- self.driver.Reset(self.map)
+ ret = self.driver.Reset(self.map)
+ if map and ret == -1:
+ raise DigitError(_('Unable to open vector map <%s> for editing. The vector map is probably broken. '
+ 'Try to run v.build for rebuilding the topology.') % map)
+ if not map and ret != 0:
+ raise DigitError(_('Closing vector map <%s> failed. The vector map is probably broken. '
if not USEVEDIT:
- self.digit.InitCats()
+ try:
+ self.digit.InitCats()
+ except:
+ pass
class VEdit(AbstractDigit):
@@ -192,7 +208,7 @@
AbstractDigit.__init__(self, mapwindow, settings)
def AddPoint (self, map, point, x, y, z=None):
- """Add point/centroid to the vector map layer
+ """Add point/centroid
@param map map name
@param point feature type (True for point, otherwise centroid)
@@ -226,7 +242,7 @@
self.__AddFeature (map=map, input=addstring)
def AddLine (self, map, line, coords):
- """Add line/boundary to the vector map layer
+ """Add line/boundary
@param map map name
@param line feature type (True for line, otherwise boundary)
@@ -267,7 +283,7 @@
self.__AddFeature (map=map, input=addstring, flags=flags)
def __AddFeature (self, map, input, flags=[]):
- """General method for adding feature to the vector map layer
+ """Generic method to add new vector feature
@param map map name
@param input feature definition in GRASS ASCII format
@@ -302,7 +318,7 @@
self.driver.ReloadMap()
def DeleteSelectedLines(self):
- """Delete selected vector features from the vector map"""
+ """Delete selected features"""
selected = self.driver.GetSelected() # grassId
if len(selected) <= 0:
@@ -327,26 +343,28 @@
return True
def MoveSelectedLines(self, move):
- """Move selected vector features
+ """Move selected features
@param move X,Y direction
return self.__MoveFeature("move", None, move)
def MoveSelectedVertex(self, coords, move):
- """Move selected vertex of the line
+ """Move selected vertex
+ Feature geometry is changed.
@param coords click coordinates
return self.__MoveFeature("vertexmove", coords, move)
def __MoveFeature(self, tool, coords, move):
- """Move selected vector feature or vertex
+ """Move selected vector feature (line, vertex)
@param tool tool for v.edit
- @param move X,Y direction
+ @param move direction (x, y)
@@ -387,40 +405,15 @@
return True
- def SplitLine(self, coords):
- """Split selected line on position 'coords'
- @param coords coordinates to split line
- try:
- line = self.driver.GetSelected()[0]
- except:
- return False
- command = ["v.edit", "--q",
- "map=%s" % self.map,
- "tool=break",
- "ids=%s" % line,
- "coords=%f,%f" % (float(coords[0]),float(coords[1])),
- "thresh=%f" % self.driver.GetThreshold()]
- # run the command
- vedit = gcmd.Command(cmd=command)
- # redraw map
- self.driver.ReloadMap()
- return True
def AddVertex(self, coords):
- """Add new vertex to the selected line on position 'coords'
+ """Add new vertex to the selected line/boundary on position 'coords'
@param coords coordinates to add vertex
return self.__ModifyVertex(coords, "vertexadd")
def RemoveVertex(self, coords):
- """Remove vertex from the selected line on position 'coords'
+ """Remove vertex from the selected line/boundary on position 'coords'
@param coords coordinates to remove vertex
@@ -452,30 +445,33 @@
return True
- def CopyCats(self, cats, ids):
- """Copy given categories to objects with id listed in ids
+ def SplitLine(self, coords):
+ """Split selected line/boundary on position 'coords'
- @param cats list of cats to be copied
- @param ids ids of lines to be modified
+ @param coords coordinates to split line
- if len(cats) == 0 or len(ids) == 0:
+ try:
+ line = self.driver.GetSelected()[0]
+ except:
return False
- # collect cats
- gcmd.Command(['v.edit',
- '--q',
- 'map=%s' % self.map,
- 'tool=catadd',
- 'cats=%s' % ",".join(["%d" % v for v in cats]),
- 'ids=%s' % ",".join(["%d" % v for v in ids])])
+ command = ["v.edit", "--q",
+ "map=%s" % self.map,
+ "tool=break",
+ "ids=%s" % line,
+ "coords=%f,%f" % (float(coords[0]),float(coords[1])),
+ "thresh=%f" % self.driver.GetThreshold()]
+ # run the command
+ vedit = gcmd.Command(cmd=command)
+ # redraw map
+ self.driver.ReloadMap()
- # reload map (needed for v.edit)
return True
def EditLine(self, line, coords):
- """Edit existing line
+ """Edit existing line/boundary
@param line id of line to be modified
@param coords list of coordinates of modified line
@@ -495,7 +491,7 @@
def __ModifyLines(self, tool):
- """Generic method to modify selected lines
+ """Generic method to modify selected lines/boundaries
@param tool operation to be performed by v.edit
@@ -521,25 +517,42 @@
return True
def FlipLine(self):
- """Flip selected lines"""
+ """Flip selected lines/boundaries"""
return self.__ModifyLines('flip')
def MergeLine(self):
- """Merge selected lines"""
+ """Merge selected lines/boundaries"""
return self.__ModifyLines('merge')
def BreakLine(self):
- """Break selected lines"""
+ """Break selected lines/boundaries"""
return self.__ModifyLines('break')
def SnapLine(self):
- """Snap selected lines"""
+ """Snap selected lines/boundaries"""
return self.__ModifyLines('snap')
def ConnectLine(self):
- """Connect selected lines"""
+ """Connect selected lines/boundaries"""
return self.__ModifyLines('connect')
+ def ZBulkLine(self, pos1, pos2, value, step):
+ """Provide z bulk-labeling (automated assigment of z coordinate
+ to 3d lines
+ @param pos1,pos2 bounding box definition for selecting lines to be labeled
+ @param value starting value
+ @param step step value
+ gcmd.Command(['v.edit',
+ '--q',
+ 'map=%s' % self.map,
+ 'tool=zbulk',
+ 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1]),
+ 'zbulk=%f,%f' % (value, step)])
def CopyLine(self, ids=None):
"""Copy features from (background) vector map
@@ -567,6 +580,28 @@
return True
+ def CopyCats(self, cats, ids):
+ """Copy given categories to objects with id listed in ids
+ @param cats list of cats to be copied
+ @param ids ids of lines to be modified
+ if len(cats) == 0 or len(ids) == 0:
+ return False
+ # collect cats
+ '--q',
+ 'tool=catadd',
+ 'cats=%s' % ",".join(["%d" % v for v in cats]),
+ 'ids=%s' % ",".join(["%d" % v for v in ids])])
+ # reload map (needed for v.edit)
+ return True
def SelectLinesFromBackgroundMap(self, pos1, pos2):
"""Select features from background map
@@ -657,21 +692,6 @@
return ids
- def ZBulkLine(self, pos1, pos2, value, step):
- """Provide z bulk-labeling (automated assigment of z coordinate
- to 3d lines
- @param pos1,pos2 bounding box definition for selecting lines to be labeled
- @param value starting value
- @param step step value
- '--q',
- 'tool=zbulk',
- 'bbox=%f,%f,%f,%f' % (pos1[0], pos1[1], pos2[0], pos2[1]),
- 'zbulk=%f,%f' % (value, step)])
class VDigit(AbstractDigit):
Prototype of digitization class based on v.digit reimplementation
@@ -687,43 +707,43 @@
try:
- from grass6_wxvdigit import Digit as DigitClass
- self.digit = DigitClass(self.driver.GetDevice())
- except ImportError, err:
- "Detailed information in README file." % \
+ self.digit = vdigit.Digit(self.driver.GetDevice())
+ except (ImportError, NameError):
self.digit = None
+ """Add new point/centroid
- @param map map name (unused)
- @param point feature type (if True -> point otherwise centroid)
+ @param map map name (unused, for compatability with VEdit)
+ @param point feature type (if true point otherwise centroid)
@param x,y,z coordinates
layer = self.settings["layer"]
cat = self.SetCategory()
if point:
- type = 0x01 # point
+ type = vdigit.GV_POINT
else:
- type = 0x08 # centroid
+ type = vdigit.GV_CENTROID
+ snap, thresh = self.__getSnapThreshold()
if z:
- ret = self.digit.AddLine(type, [x, y, z], True, layer, cat)
+ ret = self.digit.AddLine(type, [x, y, z], layer, cat,
+ self.settings["backgroundMap"], snap, thresh)
else:
- ret = self.digit.AddLine(type, [x, y], False, layer, cat)
+ ret = self.digit.AddLine(type, [x, y], layer, cat,
if ret == -1:
raise DigitError, _("Adding new feature to vector map <%s> failed") % map
- @param line feature type (True for line, otherwise boundary)
- @param list of coordinates
+ @param line feature type (if True line, otherwise boundary)
+ @param coords list of coordinates
if len(coords) < 2:
return
@@ -732,35 +752,151 @@
if line:
- type = 0x02
+ type = vdigit.GV_LINE
else:
- type = 0x04
+ type = vdigit.GV_BOUNDARY
listCoords = []
for c in coords:
for x in c:
listCoords.append(x)
- if len(coords[0]) == 3: # with_z
- ret = self.digit.AddLine(type, listCoords, True, layer, cat)
- else:
- ret = self.digit.AddLine(type, listCoords, False, layer, cat)
+ ret = self.digit.AddLine(type, listCoords, layer, cat,
if ret == -1:
@return number of deleted lines
+ nlines = self.digit.DeleteLines()
- nlines = self.digit.DeleteSelectedLines()
- #self.driver.DrawUpdatedLines()
+ return nlines
+ def MoveSelectedLines(self, move):
+ nlines = self.digit.MoveLines(move[0], move[1], 0.0, # TODO 3D
+ snap, thresh)
return nlines
+ def MoveSelectedVertex(self, coords, move):
+ """Move selected vertex of the line
+ @param coords click coordinates
+ @param move X,Y direction
+ @return 1 vertex moved
+ @return 0 vertex not moved (not found, line is not selected)
+ return self.digit.MoveVertex(coords[0], coords[1], 0.0, # TODO 3D
+ move[0], move[1], 0.0,
+ snap, thresh)
+ def AddVertex(self, coords):
+ @param coords coordinates to add vertex
+ return self.digit.ModifyLineVertex(1, coords[0], coords[1], 0.0, # TODO 3D
+ self.driver.GetThreshold())
+ def RemoveVertex(self, coords):
+ @param coords coordinates to remove vertex
+ return self.digit.ModifyLineVertex(0, coords[0], coords[1], 0.0, # TODO 3D
+ @return 1 line splitted
+ @return 0 no action
+ @return -1 error
+ return self.digit.SplitLine(coords[0], coords[1], 0.0, # TODO 3D
+ def EditLine(self, line, coords):
+ @param line id of line to be modified
+ @param coords list of coordinates of modified line
+ return self.digit.RewriteLine(line, coords)
+ def FlipLine(self):
+ return self.digit.FlipLines()
+ def MergeLine(self):
+ return self.digit.MergeLines()
+ def BreakLine(self):
+ return self.digit.BreakLines()
+ def SnapLine(self):
+ return self.digit.SnapLines()
+ def ConnectLine(self):
+ return self.digit.ConnectLines()
+ def CopyLine(self, ids=None):
+ """Copy features from (background) vector map
+ @param ids list of line ids to be copied
+ return self.digit.CopyLines(ids, self.settings['backgroundMap'])
+ return False
+ return self.digit.CopyCats(cats, ids)
+ def __getSnapThreshold(self):
+ """Get snap mode and threshold value
+ @return (snap, thresh)
+ thresh = self.driver.GetThreshold()
+ if thresh > 0.0:
+ if self.settings['snapToVertex']:
+ snap = vdigit.SNAPVERTEX
+ else:
+ else:
+ snap = v.digit.NO_SNAP
+ return (snap, thresh)
if USEVEDIT:
class Digit(VEdit):
"""Default digit class"""
@@ -830,7 +966,7 @@
# initialize wx display driver
try:
- self.__display = DisplayDriver(mapwindow.pdcVector)
+ self.__display = vdigit.DisplayDriver(mapwindow.pdcVector)
except:
self.__display = None
@@ -849,9 +985,16 @@
self.__display.SetDevice(pdc)
def Reset(self, map):
- """Close map and open new one
+ """Reset map
- map map name to be set up
+ Open or close the vector map by driver.
+ @param map map name or None to close the map
+ @return 0 on success (close map)
+ @return topo level on success (open map)
+ @return non-zero (close map)
+ @return -1 on error (open map)
if map:
name, mapset = map.split('@')
@@ -860,7 +1003,9 @@
else:
ret = self.__display.OpenMap(str(name), str(mapset), True)
else:
- self.__display.CloseMap()
+ ret = self.__display.CloseMap()
+ return ret
def ReloadMap(self):
"""Reload map (close and re-open).
@@ -1052,8 +1197,7 @@
settings['symbolVertex'][1][1],
settings['symbolVertex'][1][2],
255).GetRGB(),
- settings['lineWidth'][0],
- self.GetThreshold())
+ settings['lineWidth'][0])
class DigitSettingsDialog(wx.Dialog):
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py 2008-01-16 13:35:15 UTC (rev 29718)
+++ grass/trunk/gui/wxpython/gui_modules/render.py 2008-01-16 16:45:58 UTC (rev 29719)
@@ -128,6 +128,7 @@
return None
runcmd = gcmd.Command(cmd=self.cmdlist + ['--q']) # run quiet
if runcmd.returncode != 0:
self.mapfile = None
self.maskfile = None
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-01-16 13:35:15 UTC (rev 29718)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py 2008-01-16 16:45:58 UTC (rev 29719)
@@ -26,6 +26,7 @@
import gcmd as cmd
import grassenv
from digit import Digit as Digit
+from digit import DigitError as DigitError
from digit import DigitSettingsDialog as DigitSettingsDialog
from icon import Icons as Icons
@@ -568,7 +569,10 @@
Start editing of selected vector map layer.
- Return True on success or False if layer cannot be edited
+ @param layerSelectedId id of layer to be edited
+ @return True on success
+ @return False on error
try:
self.layerSelectedID = self.layers.index(layerSelected)
@@ -576,6 +580,13 @@
except:
return False
+ try:
+ self.parent.digit.SetMapName(mapLayer.name)
+ except DigitError, e:
+ self.layerSelectedID = None
+ print e # wxMessageBox
+ return False
# update toolbar
self.combo.SetValue (layerSelected.name)
self.parent.maptoolbar.combo.SetValue ('Digitize')
@@ -584,7 +595,6 @@
Debug.msg (4, "DigitToolbar.StartEditing(): layerSelectedID=%d layer=%s" % \
(self.layerSelectedID, mapLayer.name))
- self.parent.digit.SetMapName(mapLayer.name)
# deactive layer
self.mapcontent.ChangeLayerActive(mapLayer, False)
Modified: grass/trunk/gui/wxpython/vdigit/cats.cpp
--- grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-01-16 13:35:15 UTC (rev 29718)
+++ grass/trunk/gui/wxpython/vdigit/cats.cpp 2008-01-16 16:45:58 UTC (rev 29719)
@@ -30,7 +30,7 @@
struct lcat lc;
- G_debug(2, "vdigit.InitCats()");
+ G_debug(2, "wxDigit.InitCats()");
if (!cats.empty()) {
cats.clear();
@@ -55,7 +55,7 @@
lc.cat = max_cat;
cats.push_back(lc);
- G_debug(3, "vdigit.InitCats(): layer=%d, cat=%d", lc.layer, lc.cat);
+ G_debug(3, "wxDigit.InitCats(): layer=%d, cat=%d", lc.layer, lc.cat);
return 0;
@@ -99,7 +99,7 @@
if (layer == (*i).layer) {
old_cat = (*i).cat;
(*i).cat = cat;
- G_debug(3, "vdigit.SetCategory(): layer=%d, cat=%d", layer, cat);
+ G_debug(3, "wxDigit.SetCategory(): layer=%d, cat=%d", layer, cat);
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-01-16 13:35:15 UTC (rev 29718)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp 2008-01-16 16:45:58 UTC (rev 29719)
@@ -43,8 +43,8 @@
drawSegments = false;
- // avoid GUI crash
- // Vect_set_fatal_error(GV_FATAL_PRINT);
+ // avoid GUI crash when G_fatal_error() is called (opening the vector map)
+ Vect_set_fatal_error(GV_FATAL_PRINT);
// G_set_error_routine(print_error);
@@ -111,7 +111,7 @@
GV_POINTS | GV_LINES, // fixme
listLines);
- G_debug(3, "driver.DrawMap(): region: w=%f, e=%f, s=%f, n=%f",
+ G_debug(3, "wxDriver.DrawMap(): region: w=%f, e=%f, s=%f, n=%f",
region.box.W, region.box.E, region.box.S, region.box.N);
bool inBox;
@@ -426,22 +426,27 @@
\brief Close vector map layer
- \param
+ \param void
- \return
+ \return 0 on success
+ \return non-zero on error
-void DisplayDriver::CloseMap()
+int DisplayDriver::CloseMap()
+ int ret;
+ ret = -1;
if (mapInfo) {
if (mapInfo->mode == GV_MODE_RW) {
+ /* rebuild topology */
Vect_build(mapInfo, NULL);
- Vect_close(mapInfo);
+ ret = Vect_close(mapInfo);
G_free ((void *) mapInfo);
mapInfo = NULL;
- return;
+ return ret;
@@ -463,6 +468,9 @@
// define open level (level 2: topology)
Vect_set_open_level(2);
// open existing map
if (!update) {
ret = Vect_open_old(mapInfo, (char*) mapname, (char *) mapset);
@@ -471,6 +479,11 @@
ret = Vect_open_update(mapInfo, (char*) mapname, (char *) mapset);
+ if (ret == -1) { // error
+ G_free((void *) mapInfo);
+ mapInfo = NULL;
return ret;
@@ -1100,5 +1113,7 @@
int print_error(const char *msg, int type)
+ fprintf(stderr, "%s", msg);
return 0;
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h 2008-01-16 13:35:15 UTC (rev 29718)
+++ grass/trunk/gui/wxpython/vdigit/driver.h 2008-01-16 16:45:58 UTC (rev 29719)
@@ -167,8 +167,8 @@
std::vector<int> GetSelectedVertex(double, double, double);
/* general */
- void CloseMap();
- int OpenMap(const char *, const char *, bool);
+ int CloseMap();
+ int OpenMap(const char *, const char *, bool);
void ReloadMap();
void SetDevice(void *);
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-16 13:35:15 UTC (rev 29718)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-16 16:45:58 UTC (rev 29719)
@@ -55,7 +55,8 @@
return -1;
- G_debug(1, "Digit.AddLine(): npoints=%d", npoints);
+ G_debug(2, "wxDigit.AddLine(): npoints=%d, layer=%d, cat=%d, snap=%d",
+ npoints, layer, cat, snap);
/* TODO: 3D */
if (!(type & GV_POINTS) && !(type & GV_LINES)) {
@@ -112,16 +113,18 @@
Points->x[last] = Points->x[0];
Points->y[last] = Points->y[0];
Points->z[last] = Points->z[0];
- G_debug(3, "Digit.AddLine(): boundary closed");
+ G_debug(3, "wxDigit.AddLine(): boundary closed");
newline = Vect_write_line(display->mapInfo, type, Points, Cats);
if (snap != NO_SNAP) { /* apply snapping */
- Vedit_snap_line(display->mapInfo, BgMap, nbgmaps, /* limited only to one background map */
+ Vedit_snap_line(display->mapInfo, BgMap, nbgmaps,
newline,
- threshold, (SNAP) ? 0 : 1); /* snap to vertex ? */
+ threshold, (SNAP) ? 0 : 1);
Vect_destroy_line_struct(Points);
@@ -131,6 +134,8 @@
Vect_close(BgMap[0]);
+ G_debug(2, "wxDigit.AddLine(): line=%d written", newline);
return 1;
