[GRASS-SVN] r29726 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Jan 16 13:40:32 EST 2008
Author: cdavilam
Date: 2008-01-16 13:40:32 -0500 (Wed, 16 Jan 2008)
New Revision: 29726
grass/trunk/lib/vector/Vlib/build_nat.c
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/map.c
grass/trunk/lib/vector/Vlib/net.c
grass/trunk/lib/vector/Vlib/overlay.c
grass/trunk/lib/vector/Vlib/poly.c
grass/trunk/lib/vector/Vlib/read.c
grass/trunk/lib/vector/Vlib/sindex.c
grass/trunk/lib/vector/Vlib/write.c
Typos and message standardization
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -523,7 +523,7 @@
i++; j++;
- prnmsg ("\r%d %s \n", plus->n_lines, _("primitives registered"));
+ prnmsg ("\r%d %s \n", plus->n_lines, _("Primitives registered"));
plus->built = GV_BUILD_BASE;
@@ -550,7 +550,7 @@
Vect_build_line_area ( Map, i, side );
- prnmsg ("\r%d %s \n%d %s\n", plus->n_areas, _("areas built"), plus->n_isles, _("isles built"));
+ prnmsg ("\r%d %s \n%d %s\n", plus->n_areas, _("Areas built"), plus->n_isles, _("Isles built"));
plus->built = GV_BUILD_AREAS;
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/close.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -123,7 +123,7 @@
/* Close level 1 files / data sources if not head_only */
if ( !Map->head_only ) {
if ( ((*Close_array[Map->format][1]) (Map)) != 0 ) {
- G_warning (_("Unable close vector <%s>"),
+ G_warning (_("Unable to close vector <%s>"),
Vect_get_full_name(Map) );
return 1;
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/map.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -52,7 +52,7 @@
Cats = Vect_new_cats_struct ();
if ( Vect_level ( In ) < 1 )
- G_fatal_error ("Vect_copy_map_lines(): %s", _("input vector map is not open"));
+ G_fatal_error ("Vect_copy_map_lines(): %s", _("Input vector map is not open"));
ret = 0;
/* Note: sometimes is important to copy on level 2 (pseudotopo centroids)
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/net.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -152,7 +152,7 @@
else
dglInitialize(gr, (dglByte_t)1, (dglInt32_t)0, (dglInt32_t)0, opaqueset);
- if ( gr == NULL ) G_fatal_error (_("Unable build network graph"));
+ if ( gr == NULL ) G_fatal_error (_("Unable to build network graph"));
db_init_handle (&handle);
db_init_string ( &stmt);
Modified: grass/trunk/lib/vector/Vlib/overlay.c
--- grass/trunk/lib/vector/Vlib/overlay.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/overlay.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -73,7 +73,7 @@
Vect_overlay_and ( AMap, atype, AList, AAList, BMap, btype, BList, BAList, OMap );
break;
default:
- G_fatal_error ("Vect_overlay(): %s", _("unknown operator"));
+ G_fatal_error ("Vect_overlay(): %s", _("Unknown operator"));
return 0;
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/poly.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -658,7 +658,7 @@
/* should not be reached (one condition is not necessary, but it is may be better readable
* and it is a check) */
G_warning ("segments_x_ray() %s: X = %f Y = %f x1 = %f y1 = %f x2 = %f y2 = %f",
- _("conditions failed"), X, Y, x1, y1, x2, y2 );
+ _("Conditions failed"), X, Y, x1, y1, x2, y2 );
return n_intersects;
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/read.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -96,7 +96,7 @@
G_debug (3, "Vect_read_line()");
if (!VECT_OPEN (Map))
- G_fatal_error ("Vect_read_line(): %s", _("vector map is not opened"));
+ G_fatal_error ("Vect_read_line(): %s", _("Vector map is not opened"));
if (line < 1 || line > Map->plus.n_lines)
G_fatal_error (_("Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"),
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/sindex.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -94,7 +94,7 @@
G_debug(3, "Vect_spatial_index_del_item(): id = %d", id );
/* TODO */
- G_fatal_error ("Vect_spatial_index_del_item() %s", _("not implemented"));
+ G_fatal_error ("Vect_spatial_index_del_item() %s", _("Not implemented"));
/* Bounding box of item would be needed, which is not stored in si. */
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c 2008-01-16 18:38:47 UTC (rev 29725)
+++ grass/trunk/lib/vector/Vlib/write.c 2008-01-16 18:40:32 UTC (rev 29726)
@@ -204,7 +204,7 @@
if ( Map->mode != GV_MODE_RW && Map->mode != GV_MODE_WRITE ) {
G_fatal_error ( _("Unable to delete line %d, "
- "vector map <%s> is not in opened in 'write' mode"), line, Map->name );
+ "vector map <%s> is not opened in 'write' mode"), line, Map->name );
dig_line_reset_updated ( &(Map->plus) );
