[GRASS-SVN] r29735 - grass-web/trunk/grass62/binary/mswindows
Wed Jan 16 22:55:17 EST 2008
Author: hamish
Date: 2008-01-16 22:55:17 -0500 (Wed, 16 Jan 2008)
New Revision: 29735
   grass-web/trunk/grass62/binary/mswindows/README.html
update for 6.2.3
Modified: grass-web/trunk/grass62/binary/mswindows/README.html
--- grass-web/trunk/grass62/binary/mswindows/README.html	2008-01-17 03:49:41 UTC (rev 29734)
+++ grass-web/trunk/grass62/binary/mswindows/README.html	2008-01-17 03:55:17 UTC (rev 29735)
@@ -37,7 +37,7 @@
 (or a <a href="http://grass.ibiblio.org/mirrors.php">local mirror</a>)
 instead of <tt>http://geni.ath.cx/grass</tt>.
-Also, in step #5 the version is 6.2.2-1 instead of 6.0.cvs-1, and there's no
+Also, in step #5 the version is 6.2.3-1 instead of 6.0.cvs-1, and there's no
 grass.bat script.
 <h5>Required packages:</h5>
@@ -169,7 +169,7 @@
 From outside of GRASS you can run <tt>cygcheck</tt> to check for missing
 DLL libraries by first changing to GRASS's library directory:
 <pre>
-  cd /usr/local/grass-6.2.2/lib
+  cd /usr/local/grass-6.2.3/lib
   cygcheck ../bin/g.region
 </pre>
@@ -191,11 +191,11 @@
 <DD>
 <pre>
 $ cd /
-$ tar xjf /path/to/grass-6.2.2-1.cygwin.tar.bz2
+$ tar xjf /path/to/grass-6.2.3-1.cygwin.tar.bz2
 </pre>
 </DD>
-Everything will be /usr/local/grass-6.2.2, except for the grass62
+Everything will be /usr/local/grass-6.2.3, except for the grass62
 script which is in /usr/local/bin.
 <p>
 Regarding external dependencies: the only dependencies which aren't
