[GRASS-SVN] r29746 - in grass/trunk/gui/wxpython: gui_modules vdigit
svn_grass at osgeo.org
Fri Jan 18 09:56:05 EST 2008
Author: martinl
Date: 2008-01-18 09:56:05 -0500 (Fri, 18 Jan 2008)
New Revision: 29746
grass/trunk/gui/wxpython/gui_modules/digit.py
grass/trunk/gui/wxpython/vdigit/line.cpp
wxGUI/vdigit: fix snapping (also for background map)
Modified: grass/trunk/gui/wxpython/gui_modules/digit.py
--- grass/trunk/gui/wxpython/gui_modules/digit.py 2008-01-18 14:45:44 UTC (rev 29745)
+++ grass/trunk/gui/wxpython/gui_modules/digit.py 2008-01-18 14:56:05 UTC (rev 29746)
@@ -730,13 +730,13 @@
if z:
ret = self.digit.AddLine(type, [x, y, z], layer, cat,
- self.settings["backgroundMap"], snap, thresh)
+ str(self.settings["backgroundMap"]), snap, thresh)
else:
ret = self.digit.AddLine(type, [x, y], layer, cat,
if ret == -1:
- raise DigitError, _("Adding new feature to vector map <%s> failed") % map
+ raise DigitError, _("Adding new feature to vector map <%s> failed.") % map
def AddLine (self, map, line, coords):
"""Add line/boundary
@@ -764,10 +764,10 @@
snap, thresh = self.__getSnapThreshold()
ret = self.digit.AddLine(type, listCoords, layer, cat,
if ret == -1:
def DeleteSelectedLines(self):
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-18 14:45:44 UTC (rev 29745)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp 2008-01-18 14:56:05 UTC (rev 29746)
@@ -31,7 +31,7 @@
\param snap snapping mode (see vedit.h)
\param thresh threshold value for snapping
- \return 1 on success
+ \return 0 on success
\return -1 on failure
int Digit::AddLine(int type, std::vector<double> coords, int layer, int cat,
@@ -68,18 +68,28 @@
BgMap = NULL;
+ nbgmaps = 0;
- if (bgmap) {
- const char *mapset;
- mapset = G_find_vector2 (bgmap, "");
- if (mapset) {
- if (strcmp(G_fully_qualified_name((const char*) display->mapInfo->name, (const char*) G_mapset()),
- G_fully_qualified_name((const char*) bgmap, (const char*) mapset))) {
- nbgmaps = 1;
- BgMap = (struct Map_info**) G_realloc ((void *) BgMap, nbgmaps * sizeof(struct Map_info*));
- BgMap[nbgmaps-1] = (struct Map_info *) G_malloc (sizeof(struct Map_info));
- Vect_open_old(BgMap[nbgmaps-1], (char *) bgmap, (char*) mapset);
+ if (bgmap && strlen(bgmap) > 0) {
+ char name[GNAME_MAX];
+ char mapset[GMAPSET_MAX];
+ if (G_find_vector2 (bgmap, "") == NULL) {
+ return -1;
+ G__name_is_fully_qualified(bgmap, name, mapset);
+ if (strcmp(G_fully_qualified_name((const char*) display->mapInfo->name, (const char*) G_mapset()),
+ G_fully_qualified_name((const char*) bgmap, (const char*) mapset))) {
+ nbgmaps = 1;
+ BgMap = (struct Map_info**) G_malloc (nbgmaps * sizeof(struct Map_info*));
+ BgMap[nbgmaps-1] = (struct Map_info *) G_malloc (sizeof(struct Map_info));
+ // avoid GUI crash
+ Vect_set_fatal_error(GV_FATAL_PRINT);
+ if (Vect_open_old(BgMap[nbgmaps-1], name, mapset) == -1) {
+ G_free ((void *) BgMap[nbgmaps-1]);
+ return -1;
@@ -117,16 +127,16 @@
- newline = Vect_write_line(display->mapInfo, type, Points, Cats);
- if (snap != NO_SNAP) { /* apply snapping */
+ if (snap != NO_SNAP) { /* apply snapping (node or vertex) */
Vedit_snap_line(display->mapInfo, BgMap, nbgmaps,
- newline,
+ -1, Points,
threshold, (SNAP) ? 0 : 1);
+ if (Vect_write_line(display->mapInfo, type, Points, Cats) < 0) {
+ return -1;
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
@@ -136,7 +146,7 @@
G_debug(2, "wxDigit.AddLine(): line=%d written", newline);
- return 1;
+ return 0;
