[GRASS-SVN] r29750 - grass/trunk/lib/gis
svn_grass at osgeo.org
Sun Jan 20 15:12:26 EST 2008
Author: martinl
Date: 2008-01-20 15:12:26 -0500 (Sun, 20 Jan 2008)
New Revision: 29750
grass/trunk/lib/gis/get_row.c
grass/trunk/lib/gis/gislib.dox
grass/trunk/lib/gis/sample.c
gislib: doxygen strings updated in sample.c and get_row.c. Message standardization/i18n.
Modified: grass/trunk/lib/gis/get_row.c
--- grass/trunk/lib/gis/get_row.c 2008-01-20 17:53:24 UTC (rev 29749)
+++ grass/trunk/lib/gis/get_row.c 2008-01-20 20:12:26 UTC (rev 29750)
@@ -1,81 +1,18 @@
- * get_row_nomask() works for all map types and doesn't consider
- * null row corresponding to the requested row
- * G_get_map_row(fd, buf, row)
- * int fd file descriptor for the opened map
- * CELL *buf buffer for the row to be placed into
- * int row data row desired
- * G_get_raster_row(fd, buf, row, data_type)
- * void *buf buffer for the row to be placed into
- * RASTER_MAP_TYPE data_type FCELL_TYPE, DCELL_TYPE, or CELL_TYPE.
- * G_get_c_raster_row(fd, buf, row)
- * G_get_f_raster_row(fd, buf, row)
- * FCELL *buf buffer for the row to be placed into
- * G_get_d_raster_row(fd, buf, row)
- * DCELL *buf buffer for the row to be placed into
- * Reads appropriate information into the buffer "buf" associated
- * with the requested row "row". "buf" is associated with the
- * current window.
- * Note, that the type of the data in "buf" (say X) is independent of
- * the type of the data in the file described by fd (say Y).
- * Step 1: Read appropriate raw map data into a intermediate buffer.
- * Step 2: Convert the data into a CPU readable format, and subsequently
- * resample the data. the data is stored in a second intermediate
- * buffer (the type of the data in this buffer is Y).
- * Step 3: Convert this type Y data into type X data and store it in
- * buffer "buf". Conversion is performed in functions
- * "transfer_to_cell_XY". (For details of the conversion between
- * two particular types check the functions).
- * Step 4: read or simmulate null value row and zero out cells corresponding
- * to null value cells. The masked out cells are set to null when the
- * mask exists. (the MASK is taken care of by null values
- * (if the null file doesn't exist for this map, then the null row
- * is simulated by assuming that all zero are nulls *** in case
- * of G_get_raster_row() and assuming that all data is valid
- * in case of G_get_f/d_raster_row(). In case of deprecated function
- * G_get_map_row() all nulls are converted to zeros (so there are
- * no embedded nulls at all). Also all masked out cells become zeros.
- * returns: 1 if successful
- * 0 row requested not within window
- * -1 on fail
- * diagnostics: first read request (for each open cell file)
- * that fails will generate a warning message.
- * subsequent failures will be silent.
- * G_get_null_value_row(fd, buf, row)
- * char *buf buffer for the row to be placed into
- * read or simmulate null value row and set the cells corresponding
- * to null value to 1. The masked out cells are set to null when the
- * is simulated by assuming that all zeros in raster map are nulls.
- * Also all masked out cells become nulls.
+ \file get_row.c
+ \brief GIS library - get raster row
+ (C) 2003-2008 by the GRASS Development Team
+ This program is free software under the
+ GNU General Public License (>=v2).
+ Read the file COPYING that comes with GRASS
+ for details.
+ \author Original author CERL
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
@@ -107,7 +44,7 @@
/* check for row in window */
if (row < 0 || row >= G__.window.rows)
- G_warning(_("[%s in %s] - read request for row %d is outside region"),
+ G_warning(_("Reading raster map <%s@%s> request for row %d is outside region"),
fcb->name, fcb->mapset, row);
return -1;
@@ -178,7 +115,7 @@
*nbytes = fcb->nbytes;
- if (G_zlib_read(fd, readamount, data_buf, bufsize) != bufsize)
+ if ((size_t) G_zlib_read(fd, readamount, data_buf, bufsize) != bufsize)
return -1;
return 0;
@@ -293,7 +230,7 @@
CELL *c = cell;
COLUMN_MAPPING cmapold = 0;
- int big = nbytes >= sizeof(CELL);
+ int big = (size_t) nbytes >= sizeof(CELL);
int i;
for (i = 0; i < n; i++)
@@ -419,7 +356,7 @@
while (cmapold++ != cmap[i]) /* skip */
if (!xdr_double(xdrs, &c[i]))
- G_fatal_error(_("cell_values_double: xdr_double failed for index %d."), i);
+ G_fatal_error(_("cell_values_double: xdr_double failed for index %d"), i);
cmapold--;
@@ -529,7 +466,10 @@
+ * works for all map types and doesn't consider
+ * null row corresponding to the requested row
static int get_map_row_nomask(int fd, void *rast, int row, RASTER_MAP_TYPE data_type)
static void (*transfer_to_cell_FtypeOtype[3][3])() =
@@ -561,12 +501,11 @@
if (!fcb->io_error)
if (fcb->cellhd.compressed)
- G_warning(_("error reading compressed map [%s] in "
- "mapset [%s], row %d"),
- fcb->name, fcb->mapset, r);
+ G_warning(_("Error reading compressed map <%s@%s>, row %d"),
+ fcb->name, fcb->mapset, r);
else
- G_warning(_("error reading map [%s] in mapset [%s], row %d"),
+ G_warning(_("Error reading map <%s@%s>, row %d"),
fcb->io_error = 1;
@@ -651,28 +590,35 @@
- * \brief read a raster map (without masking)
+ * \brief Read raster row without masking (this routine is deprecated)
- * This routine reads the specified <b>row</b>
- * from the raster map open on file descriptor <b>fd</b> into the
- * <b>cell</b> buffer like G_get_map_row() does. The difference is that
- * masking is suppressed. If the user has a mask set, G_get_map_row( ) will
- * apply the mask but G_get_map_row_nomask() will ignore it.
- * This routine prints a diagnostic message and returns -1 if there is an error
+ * This routine reads the specified <em>row</em> from the raster map
+ * open on file descriptor <em>fd</em> into the <em>buf</em> buffer
+ * like G_get_map_row() does. The difference is that masking is
+ * suppressed. If the user has a mask set, G_get_map_row() will apply
+ * the mask but G_get_map_row_nomask() will ignore it. This routine
+ * prints a diagnostic message and returns -1 if there is an error
* reading the raster map. Otherwise a nonnegative value is returned.
- * <b>Note.</b> Ignoring the mask is not generally acceptable. Users expect
- * the mask to be applied. However, in some cases ignoring the mask is
- * justified. For example, the GRASS modules <i>r.describe</i>, which reads
- * the raster map directly to report all data values in a raster map, and
- * <i>r.slope.aspect</i>, which produces slope and aspect from elevation,
- * ignore both the mask and the region. However, the number of GRASS modules
- * which do this should be minimal. See Mask for more information
- * about the mask.
- * \param fd
- * \param cell
- * \param row
- * \return int
+ * <b>Note.</b> Ignoring the mask is not generally acceptable. Users
+ * expect the mask to be applied. However, in some cases ignoring the
+ * mask is justified. For example, the GRASS modules
+ * <i>r.describe</i>, which reads the raster map directly to report
+ * all data values in a raster map, and <i>r.slope.aspect</i>, which
+ * produces slope and aspect from elevation, ignore both the mask and
+ * the region. However, the number of GRASS modules which do this
+ * should be minimal. See Mask for more information about the mask.
+ * <b>This routine is deprecated! Use G_get_raster_row_nomask()
+ * instead.</b>
+ * \param fd file descriptor for the opened raster map
+ * \param buf buffer for the row to be placed into
+ * \param row data row desired
+ * \return 1 on success
+ * \return 0 row requested not within window
+ * \return -1 on error
int G_get_map_row_nomask(int fd, CELL *buf, int row)
@@ -681,16 +627,18 @@
- * \brief
- * Same as <tt>G_get_f_raster_row()</tt>
- * except no masking occurs.
+ * Same as G_get_raster_row() except no masking occurs.
- * \param fd
- * \param fcell
- * \param row
- * \param map_type
- * \return int
+ * \param data_type data type
int G_get_raster_row_nomask(int fd, void *buf, int row, RASTER_MAP_TYPE data_type)
@@ -699,14 +647,18 @@
- * \brief
+ * \brief Read raster row without masking (CELL type)
- * Same as <tt>G_get_c_raster_row()</tt> except no masking occurs.
+ * Same as G_get_c_raster_row() except no masking occurs.
- * \param fd
- * \param buf
- * \param row
- * \return int
int G_get_c_raster_row_nomask(int fd, CELL *buf, int row)
@@ -715,14 +667,18 @@
- * \brief
+ * \brief Read raster row without masking (FCELL type)
- * Same as <tt>G_get_f_raster_row()</tt> except no masking occurs.
+ * Same as G_get_f_raster_row() except no masking occurs.
- * \param fd
- * \param fcell
- * \param row
- * \return int
int G_get_f_raster_row_nomask(int fd, FCELL *buf, int row)
@@ -731,14 +687,18 @@
- * \brief
+ * \brief Read raster row without masking (DCELL type)
- * Same as <tt>G_get_d_raster_row()</tt> except no masking occurs.
+ * Same as G_get_d_raster_row() except no masking occurs.
- * \param fd
- * \param dcell
- * \param row
- * \return int
int G_get_d_raster_row_nomask(int fd, DCELL *buf, int row)
@@ -749,17 +709,23 @@
- * \brief
+ * \brief Get raster row (this routine is deprecated!)
- * If the map is floating-point, quantize the
- * floating-point values to integer using the quantization rules established for
- * the map when the map was opened for reading (this quantization is read from
- * cell_misc/name/f_quant file, but can be reset after opening raster map by
- * G_set_quant_rules()).
- * NULL values are converted to zeros.
- * <b>This routine is deprecated!!</b>
+ * If the map is floating-point, quantize the floating-point values to
+ * integer using the quantization rules established for the map when
+ * the map was opened for reading (this quantization is read from
+ * cell_misc/name/f_quant file, but can be reset after opening raster
+ * map by G_set_quant_rules()). NULL values are converted to zeros.
- * \return int
+ * <b>This routine is deprecated! Use G_get_raster_row() instead.</b>
int G_get_map_row(int fd, CELL *buf, int row)
@@ -768,18 +734,46 @@
- * \brief
- * If <em>data_type</em> is CELL_TYPE, calls
- * G_get_c_raster_row(fd, (CELL *) rast, row);
- * If <em>data_type</em> is FCELL_TYPE, calls G_get_f_raster_row(fd, (FCELL *) rast, row);
- * If <em>data_type</em> is DCELL_TYPE, calls G_get_d_raster_row(fd, (DCELL *) rast, row);
+ * If <em>data_type</em> is
+ * - CELL_TYPE, calls G_get_c_raster_row()
+ * - FCELL_TYPE, calls G_get_f_raster_row()
+ * - DCELL_TYPE, calls G_get_d_raster_row()
- * \param fd
- * \param rast
- * \param row
- * \param data_type
- * \return int
+ * Reads appropriate information into the buffer <em>buf</em> associated
+ * with the requested row <em>row</em>. <em>buf</em> is associated with the
+ * current window.
+ * Note, that the type of the data in <em>buf</em> (say X) is independent of
+ * the type of the data in the file described by <em>fd</em> (say Y).
+ * - Step 1: Read appropriate raw map data into a intermediate buffer.
+ * - Step 2: Convert the data into a CPU readable format, and subsequently
+ * resample the data. the data is stored in a second intermediate
+ * buffer (the type of the data in this buffer is Y).
+ * - Step 3: Convert this type Y data into type X data and store it in
+ * buffer "buf". Conversion is performed in functions
+ * "transfer_to_cell_XY". (For details of the conversion between
+ * two particular types check the functions).
+ * - Step 4: read or simmulate null value row and zero out cells corresponding
+ * to null value cells. The masked out cells are set to null when the
+ * mask exists. (the MASK is taken care of by null values
+ * (if the null file doesn't exist for this map, then the null row
+ * is simulated by assuming that all zero are nulls *** in case
+ * of G_get_raster_row() and assuming that all data is valid
+ * in case of G_get_f/d_raster_row(). In case of deprecated function
+ * G_get_map_row() all nulls are converted to zeros (so there are
+ * no embedded nulls at all). Also all masked out cells become zeros.
int G_get_raster_row(int fd, void *buf, int row, RASTER_MAP_TYPE data_type)
@@ -788,21 +782,25 @@
- * \brief
+ * \brief Get raster row (CELL type)
- * Reads a row
- * of raster data and leaves the NULL values intact. (As opposed to the
- * deprecated function <tt>G_get_map_row()</tt> which converts NULL values to
- * zero.)
- * <b>NOTE.</b> When the raster map is old and null file doesn't exist, it is
- * assumed that all 0-cells are no-data. When map is floating point, uses quant
- * rules set explicitly by G_set_quant_rules() or stored in map's quant file to
- * convert floats to integers.
+ * Reads a row of raster data and leaves the NULL values intact. (As
+ * opposed to the deprecated function G_get_map_row() which
+ * converts NULL values to zero.)
- * \param fd
- * \param buf
- * \param row
- * \return int
+ * <b>NOTE.</b> When the raster map is old and null file doesn't
+ * exist, it is assumed that all 0-cells are no-data. When map is
+ * floating point, uses quant rules set explicitly by
+ * G_set_quant_rules() or stored in map's quant file to convert floats
+ * to integers.
int G_get_c_raster_row(int fd, CELL *buf, int row)
@@ -811,18 +809,21 @@
- * \brief
+ * \brief Get raster row (FCELL type)
- * Read a row
- * from the raster map open on <em>fd</em> into the <tt>float</tt> array <em>fcell</em>
- * performing type conversions as necessary based on the actual storage type of
- * the map. Masking, resampling into the current region. NULL-values are always
+ * Read a row from the raster map open on <em>fd</em> into the
+ * <tt>float</tt> array <em>fcell</em> performing type conversions as
+ * necessary based on the actual storage type of the map. Masking,
+ * resampling into the current region. NULL-values are always
* embedded in <tt>fcell</tt> (<em>never converted to a value</em>).
- * \param fd
- * \param fcell
- * \param row
- * \return int
int G_get_f_raster_row(int fd, FCELL *buf, int row)
@@ -831,15 +832,18 @@
- * \brief
+ * \brief Get raster row (DCELL type)
- * Same as
- * <tt>G_get_f_raster_row()</tt> except that the array <em>dcell</em> is <tt>double</tt>.
+ * Same as G_get_f_raster_row() except that the array <em>dcell</em>
+ * is <tt>double</tt>.
- * \param fd
- * \param dcell
- * \param row
- * \return int
int G_get_d_raster_row(int fd, DCELL *buf, int row)
@@ -912,13 +916,13 @@
if (lseek(null_fd, offset, SEEK_SET) < 0)
- G_warning(_("error reading null row %d"), R);
+ G_warning(_("Error reading null row %d"), R);
return -1;
if (read(null_fd, flags, size) != size)
return -1;
@@ -932,7 +936,7 @@
if (row > G__.window.rows || row < 0)
@@ -999,7 +1003,7 @@
fcb->NULL_ROWS[i] = G_realloc (fcb->NULL_ROWS[i],
G__null_bitstream_size(G__.window.cols)+1);
if (fcb->NULL_ROWS[i] == NULL)
- G_fatal_error(_("Could not realloc buffer"));
+ G_fatal_error("get_null_value_row_nomask: %s", _("Unable to realloc buffer"));
G__convert_01_flags(flags, fcb->NULL_ROWS[i], G__.window.cols);
@@ -1079,6 +1083,22 @@
+ \brief Read or simmulate null value row
+ Read or simmulate null value row and set the cells corresponding
+ to null value to 1. The masked out cells are set to null when the
+ mask exists. (the MASK is taken care of by null values
+ (if the null file doesn't exist for this map, then the null row
+ is simulated by assuming that all zeros in raster map are nulls.
+ Also all masked out cells become nulls.
+ \param fd file descriptor for the opened map
+ \param buf buffer for the row to be placed into
+ \param row data row desired
+ \return 1
int G_get_null_value_row(int fd, char *flags, int row)
get_null_value_row(fd, flags, row, 1);
Modified: grass/trunk/lib/gis/gislib.dox
--- grass/trunk/lib/gis/gislib.dox 2008-01-20 17:53:24 UTC (rev 29749)
+++ grass/trunk/lib/gis/gislib.dox 2008-01-20 20:12:26 UTC (rev 29750)
@@ -1,4 +1,4 @@
-/*! \page gislib GRASS GIS Library
+/*! \mainpage gislib GRASS GIS Library
<!-- doxygenized from "GRASS 5 Programmer's Manual"
by M. Neteler 2/2004, 2005, 2006
Modified: grass/trunk/lib/gis/sample.c
--- grass/trunk/lib/gis/sample.c 2008-01-20 17:53:24 UTC (rev 29749)
+++ grass/trunk/lib/gis/sample.c 2008-01-20 20:12:26 UTC (rev 29750)
@@ -1,21 +1,29 @@
- * Copyright (C) 1994. James Darrell McCauley. (darrell at mccauley-usa.com)
- * http://mccauley-usa.com/
- * This program is free software under the GPL (>=v2)
- * Read the file GPL.TXT coming with GRASS for details.
- * 1/2006: moved to libgis from v.sample/v.drape for clone removal
+ \file sample.c
+ \brief GIS library - sampling methods (extract a cell value from
+ raster map)
+ 1/2006: moved to libgis from v.sample/v.drape for clone removal
+ (C) 2001-2008 by the GRASS Development Team
+ for details.
+ \author James Darrell McCauley <darrell mccauley-usa.com>, http://mccauley-usa.com/
+ \date 1994
#include <string.h>
#include <unistd.h>
#include <math.h>
#include <grass/gis.h>
#include <grass/glocale.h>
/* prototypes */
static double raster_sample_nearest (int fd,
const struct Cell_head *window,
@@ -34,20 +42,19 @@
- * \function double G_get_raster_sample (int fd, struct Cell_head *window,
- * struct Categories *cats, double north, double east,
- * int usedesc, INTERP_TYPE itype)
- * \brief extract a cell value from raster map at given northing and
- * easting with a sampled 3x3 window using a specified interpolation
- * method
+ * \brief Extract a cell value from raster map.
+ * Extract a cell value from raster map at given northing and easting
+ * with a sampled 3x3 window using a specified interpolation method.
- * \param window
+ * \param window region settings
* \param cats categories
* \param north northing position
* \param east easting position
* \param usedesc flag to scan category label
* \param itype interpolation method
* \return cell value at given position
@@ -71,7 +78,7 @@
retval = raster_sample_cubic(fd, window, cats, north, east, usedesc);
break;
default:
- G_fatal_error(_("unknown interpolation type"));
+ G_fatal_error("G_get_raster_sample: %s",_("Unknown interpolation type"));
return retval;
@@ -436,17 +443,9 @@
for (i = 0; i < 4; ++i)
tmp[i] = G_interp_cubic(east, grid[i][0], grid[i][1], grid[i][2], grid[i][3]);
-#ifdef DEBUG
- for (i = 0; i < 4; ++i) {
- for (j = 0; j < 4; ++j)
- fprintf(stderr, "%g ", grid[i][j]);
- fprintf(stderr, "\n");
+ G_debug(3, "raster_sample_cubic(): DIAG: (%d,%d) 1=%3.2g 2=%3.2g 3=%3.2g 4=%3.2g\te=%g n=%g",
+ row, col, tmp[0], tmp[1], tmp[2], tmp[3], east, north);
- G_message("DIAG: (%d,%d) 1=%3.2g 2=%3.2g 3=%3.2g 4=%3.2g\te=%g n=%g",
- row, col, tmp[0], tmp[1], tmp[2], tmp[3], east, north);
-#endif
G_free(arow);
G_free(brow);
G_free(crow);
@@ -479,5 +478,5 @@
window->north, window->south, window->east, window->west);
G_debug(3, " \tData point is north=%g east=%g", north, east);
- G_fatal_error(_("problem reading raster cell file"));
+ G_fatal_error(_("Problem reading raster map"));
