[GRASS-SVN] r29757 - grass/branches/releasebranch_6_3/display/d.vect
Sun Jan 20 20:21:25 EST 2008
Author: hamish
Date: 2008-01-20 20:21:25 -0500 (Sun, 20 Jan 2008)
New Revision: 29757
   grass/branches/releasebranch_6_3/display/d.vect/main.c
change default render mode to 'c'
 http://lists.osgeo.org/pipermail/grass-dev/2008-January/034922.html
Modified: grass/branches/releasebranch_6_3/display/d.vect/main.c
--- grass/branches/releasebranch_6_3/display/d.vect/main.c	2008-01-20 22:57:20 UTC (rev 29756)
+++ grass/branches/releasebranch_6_3/display/d.vect/main.c	2008-01-21 01:21:25 UTC (rev 29757)
@@ -303,7 +303,7 @@
 	render_opt->type       = TYPE_STRING ;
 	render_opt->required   = NO;
 	render_opt->multiple   = NO;
-	render_opt->answer     = "l" ;
+	render_opt->answer     = "c" ;
 	render_opt->options    = "g,r,d,c,l";
 	render_opt->description= _("Rendering method for filled polygons");
 	render_opt->descriptions= _(
