[GRASS-SVN] r29780 - grass/trunk/vector/v.to.rast
Mon Jan 21 09:50:10 EST 2008
Author: martinl
Date: 2008-01-21 09:50:10 -0500 (Mon, 21 Jan 2008)
New Revision: 29780
   grass/trunk/vector/v.to.rast/do_areas.c
   grass/trunk/vector/v.to.rast/main.c
   grass/trunk/vector/v.to.rast/support.c
   grass/trunk/vector/v.to.rast/vect2rast.c
v.to.rast: Use standardized options, message standardization.
Modified: grass/trunk/vector/v.to.rast/do_areas.c
--- grass/trunk/vector/v.to.rast/do_areas.c	2008-01-21 14:46:48 UTC (rev 29779)
+++ grass/trunk/vector/v.to.rast/do_areas.c	2008-01-21 14:50:10 UTC (rev 29780)
@@ -65,7 +65,7 @@
         if (Vect_get_area_points (Map, list[i].index, Points) <= 0)
-            G_warning (_("Get area [%d] failed"), list[i].index);
+            G_warning (_("Get area %d failed"), list[i].index);
             return -1;
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c	2008-01-21 14:46:48 UTC (rev 29779)
+++ grass/trunk/vector/v.to.rast/main.c	2008-01-21 14:50:10 UTC (rev 29780)
@@ -48,12 +48,12 @@
     use_opt->multiple       = NO;
     use_opt->options        = "attr,cat,val,z,dir";
     use_opt->answer         = "attr";
-    use_opt->description    = _("Source of raster values:\n"
-			"\t\tattr - read values from attribute table\n"
-			"\t\tcat  - use category values\n"
-			"\t\tval  - use value specified by value option\n"
-			"\t\tz    - use z coordinate (points or contours only)\n"
-			"\t\tdir  - output as flow direction (lines only)");
+    use_opt->description    = _("Source of raster values");
+    use_opt->descriptions   = _("attr;read values from attribute table;"
+				"cat;use category values;"
+				"val;use value specified by value option;"
+				"z;use z coordinate (points or contours only);"
+				"dir;output as flow direction (lines only)");
     type_opt = G_define_standard_option(G_OPT_V_TYPE);
     type_opt -> options = "point,line,area";
@@ -62,13 +62,9 @@
     field_opt = G_define_standard_option(G_OPT_V_FIELD);
     /* for GRASS 7, IMHO this should be changed to "attrcolumn" */
-    col = G_define_option();
-    col->key            = "column";
-    col->type           = TYPE_STRING;
-    col->key_desc       = "name";
-    col->required       = NO;
-    col->multiple       = NO;
+    col = G_define_standard_option(G_OPT_COLUMN);
     col->description    = _("Name of column for attr parameter (data type must be numeric)");
+    col->guisection = _("Attributes");
     val_opt = G_define_option();
     val_opt->key              = "value";
@@ -86,19 +82,15 @@
     rows->answer           = "4096";
     rows->description      = _("Number of rows to hold in memory");
-    rgbcol_opt = G_define_option();
+    rgbcol_opt = G_define_standard_option(G_OPT_COLUMN);
     rgbcol_opt->key        = "rgbcolumn";
-    rgbcol_opt->type       = TYPE_STRING ;
-    rgbcol_opt->required   = NO ;
-    rgbcol_opt->multiple   = NO ;
     rgbcol_opt->description= _("Name of color definition column (with RRR:GGG:BBB entries)");
+    rgbcol_opt->guisection = _("Attributes");
-    label_opt = G_define_option();
+    label_opt = G_define_standard_option(G_OPT_COLUMN);
     label_opt->key        = "labelcolumn";
-    label_opt->type       = TYPE_STRING ;
-    label_opt->required   = NO ;
-    label_opt->multiple   = NO ;
     label_opt->description= _("Name of column used as raster category labels");
+    label_opt->guisection = _("Attributes");
     if (G_parser (argc, argv))
 	exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c	2008-01-21 14:46:48 UTC (rev 29779)
+++ grass/trunk/vector/v.to.rast/support.c	2008-01-21 14:50:10 UTC (rev 29780)
@@ -123,17 +123,18 @@
     db_CatValArray_init ( &cvarr );
     if ((Fi = Vect_get_field (&Map, field)) == NULL)
-        G_fatal_error (_("Unable to get layer info for vector map"));
+	G_fatal_error (_("Database connection not defined for layer %d"),
+		       field);
     if ((Driver = db_start_driver_open_database (Fi->driver, Fi->database)) == NULL)
         G_fatal_error (_("Unable to open database <%s> by driver <%s>"), Fi->database, Fi->driver);
     /* get number of records in attr_column */
     if ((nrec = db_select_CatValArray (Driver, Fi->table, Fi->key, attr_column , NULL, &cvarr)) == -1)
-        G_fatal_error (_("Unknown column '%s' in table '%s'"), attr_column, Fi->table);
+        G_fatal_error (_("Unknown column <%s> in table <%s>"), attr_column, Fi->table);
     if (nrec < 0)
-        G_fatal_error (_("No records selected from table '%s'"), Fi->table);
+        G_fatal_error (_("No records selected from table <%s>"), Fi->table);
     G_debug (3, "nrec = %d", nrec );
@@ -257,7 +258,8 @@
         db_CatValArray_init (&cvarr);
         if (!(Fi = Vect_get_field (&Map, field)))
+			   field);
         if (!(Driver = db_start_driver_open_database (Fi->driver, Fi->database)))
@@ -265,11 +267,11 @@
         /* get number of records in label_column */
         if ((nrec = db_select_CatValArray (Driver, Fi->table, Fi->key, attr_column, NULL, &cvarr)) == -1)
         if (nrec < 0)
@@ -317,7 +319,8 @@
                 db_set_string (&my_labels_rules[i].label, db_get_value_string (&value));
             break;
             default:
-                G_warning (_("Column type [%d] not supported"), col_type);
+                G_warning (_("Column type (%s) not supported"),
+			   db_sqltype_name(col_type));
             /* add the raster category to label */
@@ -464,7 +467,7 @@
     G_close_cell (fd);
     if (G_write_cats (rast_name, &rast_cats) <= 0)
-        G_warning (_("Unable to write categories for map <%s>"), rast_name);
+        G_warning (_("Unable to write categories for raster map <%s>"), rast_name);
     G_free_cats (&rast_cats);
     return 1;
Modified: grass/trunk/vector/v.to.rast/vect2rast.c
--- grass/trunk/vector/v.to.rast/vect2rast.c	2008-01-21 14:46:48 UTC (rev 29779)
+++ grass/trunk/vector/v.to.rast/vect2rast.c	2008-01-21 14:50:10 UTC (rev 29780)
@@ -41,14 +41,15 @@
     Vect_open_old (&Map, vector_map, vector_mapset);
     if ( (use == USE_Z) && !(Vect_is_3d(&Map)) )
-	G_fatal_error (_("Vector map is not 3D"));
+	G_fatal_error (_("Vector map <%s> is not 3D"), Vect_get_full_name(&Map));
     switch (use)
     case USE_ATTR:
+			   field);
 	if ((Driver = db_start_driver_open_database ( Fi->driver, Fi->database)) == NULL)
@@ -61,11 +62,12 @@
 	ctype = cvarr.ctype;
 	if ( ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE )
-	    G_fatal_error (_("Column type [%s] not supported (did you mean 'labelcolumn'?)"),
-				db_sqltype_name(ctype));
+	    G_fatal_error (_("Column type (%s) not supported (did you mean 'labelcolumn'?)"),
+			   db_sqltype_name(ctype));
 	if ( nrec < 0 )
-            G_fatal_error (_("Cannot select data from table"));
+			   Fi->table);
 	G_debug (1, "%d records selected from table", nrec);
@@ -90,7 +92,7 @@
             format = USE_DCELL;
         break;
         default:
-            G_fatal_error (_("Unable to use column '%s'"), column);
+            G_fatal_error (_("Unable to use column <%s>"), column);
         break;
     break;
