[GRASS-SVN] r29797 - grass/trunk/raster/r.circle
Tue Jan 22 09:19:40 EST 2008
Author: epatton
Date: 2008-01-22 09:19:33 -0500 (Tue, 22 Jan 2008)
New Revision: 29797
   grass/trunk/raster/r.circle/description.html
Corrected small typo
Modified: grass/trunk/raster/r.circle/description.html
--- grass/trunk/raster/r.circle/description.html	2008-01-22 13:01:44 UTC (rev 29796)
+++ grass/trunk/raster/r.circle/description.html	2008-01-22 14:19:33 UTC (rev 29797)
@@ -6,7 +6,7 @@
 and <EM>max</EM> parameters control the inner and outer output raster map radii, respectively.
 <p>
-The <EM>mult</EM>parameter can be used to multiply the output raster cells by a common factor.
+The <EM>mult</EM> parameter can be used to multiply the output raster cells by a common factor.
 Note that this parameter does not affect the output raster position or size; only the z-values
 are changed with this parameter.
 <P>
