[GRASS-SVN] r29822 - grass/trunk/raster/r.cats
svn_grass at osgeo.org
Thu Jan 24 15:00:11 EST 2008
Author: epatton
Date: 2008-01-24 15:00:11 -0500 (Thu, 24 Jan 2008)
New Revision: 29822
grass/trunk/raster/r.cats/description.html
Minor formatting edits to manpage
Modified: grass/trunk/raster/r.cats/description.html
--- grass/trunk/raster/r.cats/description.html 2008-01-24 19:25:54 UTC (rev 29821)
+++ grass/trunk/raster/r.cats/description.html 2008-01-24 20:00:11 UTC (rev 29822)
@@ -10,11 +10,11 @@
program non-interactively. If the user does not specify any categories
(e.g., using the optional <B>cats=</B><EM>range</EM>[,<EM>range</EM>,...]
argument), then all the category values and labels for the named raster map
-layer that occur in the map are printed. The entire <EM>map</EM> is read,
+layer that occur in the map are printed. The entire <EM>map</EM> is read
using <EM><A HREF="r.describe.html">r.describe</A></EM>, to determine which
categories occur in the <EM>map</EM>. If a listing of categories is
specified, then the labels for those categories only are printed. The
-<EM>cats</EM> may be specified as single category values, or as ranges of
+<EM>cats</EM> may be specified as single category value, or as ranges of
values. The user may also (optionally) specify that a field separator other
than a space or tab be used to separate the category value from its
corresponding category label in the output, by using the
