[GRASS-SVN] r29831 - grass/trunk/display/d.histogram
Fri Jan 25 08:15:47 EST 2008
Author: neteler
Date: 2008-01-25 08:15:47 -0500 (Fri, 25 Jan 2008)
New Revision: 29831
   grass/trunk/display/d.histogram/bar.c
get FP output for x-axis in case of 0..1.0 range
Modified: grass/trunk/display/d.histogram/bar.c
--- grass/trunk/display/d.histogram/bar.c	2008-01-25 13:06:57 UTC (rev 29830)
+++ grass/trunk/display/d.histogram/bar.c	2008-01-25 13:15:47 UTC (rev 29831)
@@ -112,7 +112,6 @@
 		   if(G_is_d_null_value(&range_dmin) || G_is_d_null_value(&range_dmax))
 		        G_fatal_error("Floating point data range is empty");
-		   G_debug(3,"range: %f",range_dmax - range_dmin);
 		   if ( (range_dmax - range_dmin) < 1.0) tics[i].every = 5;
 		   if ( (range_dmax - range_dmin) < 110) tics[i].every = 20; /* dirrty hack */
 		   while((range_dmax - range_dmin)/tics[i].every > max_tics)
@@ -125,7 +124,6 @@
 		tic_every = tics[i].every;
 		tic_unit = tics[i].unit;
-		G_debug(3,"max_tics: %d, tic_every: %d, tic_unit: %d", max_tics, tic_every, tic_unit);
 		strcpy(tic_name,tics[i].name);
 	else
@@ -318,9 +316,12 @@
 			R_cont_rel( (int)0 , (int)(BIG_TIC*(b-t)) );
 		        if(nodata && i==dist_stats->mincat)
 			   sprintf(txt, "null");
-			else if(is_fp)
-			   sprintf(txt,"%d",(int) (dmin/(double) tic_unit));
-                        else
+			else if(is_fp) {
+			   if ( (range_dmax - range_dmin) < 1.0)
+				sprintf(txt,"%.2f", dmin/(double) tic_unit);
+			   else
+				sprintf(txt,"%d",(int) (dmin/(double) tic_unit));
+			} else
 			   sprintf(txt,"%d",(int) (i/tic_unit));
 			text_height = (b-t)*TEXT_HEIGHT;
 			text_width = (r-l)*TEXT_WIDTH;
