[GRASS-SVN] r29852 - grass/trunk/general/g.region/cmd
svn_grass at osgeo.org
Sun Jan 27 03:24:07 EST 2008
Author: hamish
Date: 2008-01-27 03:24:05 -0500 (Sun, 27 Jan 2008)
New Revision: 29852
grass/trunk/general/g.region/cmd/description.html
a few fixes, eg explain zoom=. this page is still in very bad shape.
Modified: grass/trunk/general/g.region/cmd/description.html
--- grass/trunk/general/g.region/cmd/description.html 2008-01-27 06:25:32 UTC (rev 29851)
+++ grass/trunk/general/g.region/cmd/description.html 2008-01-27 08:24:05 UTC (rev 29852)
@@ -153,7 +153,7 @@
from other mapsets as well, if accessible and in the user's
mapset search path.
-<li>Set current geographic region from a raster (cell) map
+<li>Set current geographic region from a raster map
layer Allows the user to select a raster map layer, copies
the cell header for this map layer to the current
geographic region, and then lets the user edit the current
@@ -170,7 +170,7 @@
current geographic region is set directly using option 2,
or even by another GRASS program
-(e.g., <em><a HREF="d.m.html">d.m</a></em>).
+(e.g., <em><a HREF="gis.m.html">gis.m</a></em>).
This option installs an otherwise temporary geographic
region setting into the geographic region definition data
@@ -200,10 +200,12 @@
Alternately, the user can modify the settings of the current geographic region
by specifying all needed parameters on the command line.
The user enters the command <b>g.region</b> <em>parms</em>, where
<em>parms</em> are the following parameters and/or flags:
<h3>Flags:</h3>
<dl>
@@ -320,7 +322,7 @@
raster map, and align the current region to a row and
column edge in the named map. Alignment only moves the
existing region edges outward to the edges of the next
-nearest cell in the named raster map -- not to the named
+nearest cell in the named raster map - not to the named
map's edges. To perform the latter function, use the
<b>rast=</b><em>name</em> option.
@@ -407,24 +409,23 @@
<p>
-<!-- how does this work?
<dt><div class="code"><pre>
-g.region rast=soils ???
+g.region zoom=soils
</pre></div>
<dd> This form will first look up the cell header file for
the raster map layer <em>soils</em>, use this as the
current region setting, and then shrink the region down to
-the smallest region which still encompasses all non-zero
-data in the map layer <em>soils</em>. Note that if the
-parameter <em>rast=soils</em> were not specified, the
+the smallest region which still encompasses all non-NULL <!--? non-zero ? -->
+data in the map layer <em>soils</em>. <!-- Note that if the
+parameter <em>zoom=soils</em> were not specified, the
zoom would move to encompass all non-zero data values in
the soils map that were located within the current region
-setting.
+setting. -->
<p>
g.region -up rast=soils
@@ -439,11 +440,11 @@
<p>
-g.region -p rast=soils
+g.region -up zoom=soils save=soils
</pre></div>
<dd> This will zoom into the smallest region which
-encompasses all non-zero soils data values, and save the
+encompasses all non-NULL <!-- non-zero? --> soils data values, and save the
new region settings in a file to be called <em>soils</em>
and stored under the <kbd>windows</kbd> directory in the
user's current mapset. The current region settings are not
@@ -674,4 +675,5 @@
U.S.Army Construction Engineering
Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
