[GRASS-SVN] r29903 - grass/trunk/display/d.paint.labels
svn_grass at osgeo.org
Wed Jan 30 17:36:14 EST 2008
Author: hamish
Date: 2008-01-30 17:36:14 -0500 (Wed, 30 Jan 2008)
New Revision: 29903
grass/trunk/display/d.paint.labels/color.c
doxygen comments
Modified: grass/trunk/display/d.paint.labels/color.c
--- grass/trunk/display/d.paint.labels/color.c 2008-01-30 21:52:43 UTC (rev 29902)
+++ grass/trunk/display/d.paint.labels/color.c 2008-01-30 22:36:14 UTC (rev 29903)
@@ -32,10 +32,21 @@
color->b = b;
-/* Parses color string and fills RGBA array
+ * \brief Parses color string and fill RGBA array
+ * If the color is valid the color's alpha value is set to RGBA_COLOR_OPAQUE.
+ * The 'none' case is handed by setting the alpha channel to RGBA_COLOR_NONE.
* Returns: 1 - OK
- * 2 - NONE
+ * 2 - NONE
* 0 - Error
+ * \param color_string
+ * \param RGBA_Color struct to be populated
+ * \return int
int set_RGBA_from_str(RGBA_Color *color, const char *clr_str)
