[GRASS-SVN] r29905 - grass/trunk/raster/r.in.xyz
svn_grass at osgeo.org
Wed Jan 30 21:44:41 EST 2008
Author: hamish
Date: 2008-01-30 21:44:41 -0500 (Wed, 30 Jan 2008)
New Revision: 29905
grass/trunk/raster/r.in.xyz/main.c
guisection: don't use "Output" as a tab name, it's reserved.
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c 2008-01-30 22:49:20 UTC (rev 29904)
+++ grass/trunk/raster/r.in.xyz/main.c 2008-01-31 02:44:41 UTC (rev 29905)
@@ -164,7 +164,7 @@
method_opt->description = _("Statistic to use for raster values");
method_opt->options = "n,min,max,range,sum,mean,stddev,variance,coeff_var,median,percentile,skewness,trimmean";
method_opt->answer = "mean";
- method_opt->guisection = _("Output");
+ method_opt->guisection = _("Statistic");
type_opt = G_define_option();
type_opt->key = "type";
@@ -173,7 +173,6 @@
type_opt->options = "CELL,FCELL,DCELL";
type_opt->answer = "FCELL";
type_opt->description = _("Storage type for resultant raster map");
- type_opt->guisection = _("Output");
delim_opt = G_define_standard_option(G_OPT_F_SEP);
delim_opt->guisection = _("Input");
@@ -211,7 +210,6 @@
zrange_opt->required = NO;
zrange_opt->key_desc = "min,max";
zrange_opt->description = _("Filter range for z data (min,max)");
- zrange_opt->guisection = _("Input");
percent_opt = G_define_option();
percent_opt->key = "percent";
@@ -227,6 +225,7 @@
pth_opt->required = NO;
pth_opt->options = "1-100";
pth_opt->description = _("pth percentile of the values");
+ pth_opt->guisection = _("Statistic");
trim_opt = G_define_option();
trim_opt->key = "trim";
@@ -235,6 +234,7 @@
trim_opt->options = "0-50";
trim_opt->description =
_("Discard <trim> percent of the smallest and <trim> percent of the largest observations");
+ trim_opt->guisection = _("Statistic");
scan_flag = G_define_flag();
scan_flag->key = 's';
