[GRASS-SVN] r29913 - grass/trunk/visualization/nviz/src
Thu Jan 31 06:00:59 EST 2008
Author: neteler
Date: 2008-01-31 06:00:58 -0500 (Thu, 31 Jan 2008)
New Revision: 29913
Removed:
   grass/trunk/visualization/nviz/src/tkInt.h
   grass/trunk/visualization/nviz/src/tkInt4.0.h
   grass/trunk/visualization/nviz/src/tkInt4.1.h
   grass/trunk/visualization/nviz/src/tkInt4.2.h
   grass/trunk/visualization/nviz/src/tkInt8.0.2.h
   grass/trunk/visualization/nviz/src/tkInt8.0.h
   grass/trunk/visualization/nviz/src/tkInt8.1.1.h
   grass/trunk/visualization/nviz/src/tkInt8.2.3.h
   grass/trunk/visualization/nviz/src/tkInt8.3.3.h
   grass/trunk/visualization/nviz/src/tkInt8.3.h
   grass/trunk/visualization/nviz/src/tkInt8.4.9.h
   grass/trunk/visualization/nviz/src/tkInt8.4.h
   grass/trunk/visualization/nviz/src/tkIntDecls8.1.1.h
   grass/trunk/visualization/nviz/src/tkIntDecls8.2.3.h
   grass/trunk/visualization/nviz/src/tkIntDecls8.3.3.h
   grass/trunk/visualization/nviz/src/tkIntDecls8.3.h
   grass/trunk/visualization/nviz/src/tkIntDecls8.4.9.h
   grass/trunk/visualization/nviz/src/tkIntDecls8.4.h
   grass/trunk/visualization/nviz/src/tkWinInt.h
   grass/trunk/visualization/nviz/src/README
   grass/trunk/visualization/nviz/src/togl.c
removed unused header files
Modified: grass/trunk/visualization/nviz/src/README
--- grass/trunk/visualization/nviz/src/README	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/README	2008-01-31 11:00:58 UTC (rev 29913)
@@ -24,53 +24,10 @@
  *               Eric G. Miller <egm2 jps.net>,
  *               Justin Hickey <jhickey hpcc.nectec.or.th>
  * PURPOSE:      visualization and animation tool
- * COPYRIGHT:    (C) 2002-2005 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002-2088 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
  *               for details.
-HOWTO - Adding new header files from tcl/tk:
-$Date$
-Problem: The header files tkInt.h and tkIntDecls.h differ between
-         the various TK library versions. If not updated, NVIZ
-         will just crash (or doesn't compile at all).
-Solution: We have to add the individual header files (tkInt.h and
-          tkIntDecls.h) from the tk source code. For that
-          they are renamed according to their version number.
-          The togl.c contains a set of 'if' + 'elif' to reflect
-          the various version numbers.
-Step-by-step:
-1. download TK from http://tcl.sourceforge.net
-    -> File Distributions
-       -> View All Project Files
-           -> tk8.4.9-src.tar.gz (example)
-   extract:
-    tar xvfz tk8.4.9-src.tar.gz tk8.4.9/generic/tkInt.h
-    tar xvfz tk8.4.9-src.tar.gz tk8.4.9/generic/tkIntDecls.h
-   and add here (rename!)
-     tkInt.h      -> tkInt8.x[.y].h (e.g. tkInt8.4.9.h)
-     tkIntDecls.h -> tkIntDecls8.x[.y].h (e.g. tkIntDecls8.4.9.h)
-2. change within tkInt8.x[.y].h the include statement from tkIntDecls.h
-   to tkIntDecls8.x[.y].h
-3. edit togl.c
-   add 'elif' statement with new names according to version
-   of TK
-4. complain about these stupid things to Tcl/Tk developers
-Markus
Deleted: grass/trunk/visualization/nviz/src/tkInt.h
--- grass/trunk/visualization/nviz/src/tkInt.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,988 +0,0 @@
- * tkInt.h --
- *	Declarations for things used internally by the Tk
- *	procedures but not exported outside the module.
- * Copyright (c) 1990-1994 The Regents of the University of California.
- * Copyright (c) 1994-1997 Sun Microsystems, Inc.
- * Copyright (c) 1998 by Scriptics Corporation.
- * See the file "license.terms" for information on usage and redistribution
- * of this file, and for a DISCLAIMER OF ALL WARRANTIES.
- * RCS: $Id$
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#include "tkPort.h"
-#endif
-#ifdef BUILD_tk
-# undef TCL_STORAGE_CLASS
-# define TCL_STORAGE_CLASS DLLEXPORT
-#endif
- * Opaque type declarations:
-typedef struct TkColormap TkColormap;
-typedef struct TkGrabEvent TkGrabEvent;
-typedef struct Tk_PostscriptInfo Tk_PostscriptInfo;
-typedef struct TkpCursor_ *TkpCursor;
-typedef struct TkRegion_ *TkRegion;
-typedef struct TkStressedCmap TkStressedCmap;
-typedef struct TkBindInfo_ *TkBindInfo;
- * Procedure types.
-typedef int (TkBindEvalProc) _ANSI_ARGS_((ClientData clientData,
-	Tcl_Interp *interp, XEvent *eventPtr, Tk_Window tkwin,
-	KeySym keySym));
-typedef void (TkBindFreeProc) _ANSI_ARGS_((ClientData clientData));
-typedef Window (TkClassCreateProc) _ANSI_ARGS_((Tk_Window tkwin,
-	Window parent, ClientData instanceData));
-typedef void (TkClassGeometryProc) _ANSI_ARGS_((ClientData instanceData));
-typedef void (TkClassModalProc) _ANSI_ARGS_((Tk_Window tkwin,
-	XEvent *eventPtr));
- * Widget class procedures used to implement platform specific widget
- * behavior.
-typedef struct TkClassProcs {
-    TkClassCreateProc *createProc;
-				/* Procedure to invoke when the
-                                   platform-dependent window needs to be
-                                   created. */
-    TkClassGeometryProc *geometryProc;
-				/* Procedure to invoke when the geometry of a
-				   window needs to be recalculated as a result
-				   of some change in the system. */
-    TkClassModalProc *modalProc;
-				/* Procedure to invoke after all bindings on a
-				   widget have been triggered in order to
-				   handle a modal loop. */
-} TkClassProcs;
- * One of the following structures is maintained for each cursor in
- * use in the system.  This structure is used by tkCursor.c and the
- * various system specific cursor files.
-typedef struct TkCursor {
-    Tk_Cursor cursor;		/* System specific identifier for cursor. */
-    int refCount;		/* Number of active uses of cursor. */
-    Tcl_HashTable *otherTable;	/* Second table (other than idTable) used
-				 * to index this entry. */
-    Tcl_HashEntry *hashPtr;	/* Entry in otherTable for this structure
-				 * (needed when deleting). */
-} TkCursor;
- * One of the following structures is maintained for each display
- * containing a window managed by Tk:
-typedef struct TkDisplay {
-    Display *display;		/* Xlib's info about display. */
-    struct TkDisplay *nextPtr;	/* Next in list of all displays. */
-    char *name;			/* Name of display (with any screen
-				 * identifier removed).  Malloc-ed. */
-    Time lastEventTime;		/* Time of last event received for this
-				 * display. */
-     * Information used primarily by tkBind.c:
-    int bindInfoStale;		/* Non-zero means the variables in this
-				 * part of the structure are potentially
-				 * incorrect and should be recomputed. */
-    unsigned int modeModMask;	/* Has one bit set to indicate the modifier
-				 * corresponding to "mode shift".  If no
-				 * such modifier, than this is zero. */
-    unsigned int metaModMask;	/* Has one bit set to indicate the modifier
-				 * corresponding to the "Meta" key.  If no
-				 * such modifier, then this is zero. */
-    unsigned int altModMask;	/* Has one bit set to indicate the modifier
-    enum {LU_IGNORE, LU_CAPS, LU_SHIFT} lockUsage;
-				/* Indicates how to interpret lock modifier. */
-    int numModKeyCodes;		/* Number of entries in modKeyCodes array
-				 * below. */
-    KeyCode *modKeyCodes;	/* Pointer to an array giving keycodes for
-				 * all of the keys that have modifiers
-				 * associated with them.  Malloc'ed, but
-				 * may be NULL. */
-     * Information used by tkError.c only:
-    struct TkErrorHandler *errorPtr;
-				/* First in list of error handlers
-				 * for this display.  NULL means
-				 * no handlers exist at present. */
-    int deleteCount;		/* Counts # of handlers deleted since
-				 * last time inactive handlers were
-				 * garbage-collected.  When this number
-				 * gets big, handlers get cleaned up. */
-     * Information used by tkSend.c only:
-    Tk_Window commTkwin;	/* Window used for communication
-				 * between interpreters during "send"
-				 * commands.  NULL means send info hasn't
-				 * been initialized yet. */
-    Atom commProperty;		/* X's name for comm property. */
-    Atom registryProperty;	/* X's name for property containing
-				 * registry of interpreter names. */
-    Atom appNameProperty;	/* X's name for property used to hold the
-				 * application name on each comm window. */
-     * Information used by tkSelect.c and tkClipboard.c only:
-    struct TkSelectionInfo *selectionInfoPtr;
-				/* First in list of selection information
-				 * records.  Each entry contains information
-				 * about the current owner of a particular
-				 * selection on this display. */
-    Atom multipleAtom;		/* Atom for MULTIPLE.  None means
-				 * selection stuff isn't initialized. */
-    Atom incrAtom;		/* Atom for INCR. */
-    Atom targetsAtom;		/* Atom for TARGETS. */
-    Atom timestampAtom;		/* Atom for TIMESTAMP. */
-    Atom textAtom;		/* Atom for TEXT. */
-    Atom compoundTextAtom;	/* Atom for COMPOUND_TEXT. */
-    Atom applicationAtom;	/* Atom for TK_APPLICATION. */
-    Atom windowAtom;		/* Atom for TK_WINDOW. */
-    Atom clipboardAtom;		/* Atom for CLIPBOARD. */
-    Tk_Window clipWindow;	/* Window used for clipboard ownership and to
-				 * retrieve selections between processes. NULL
-				 * means clipboard info hasn't been
-				 * initialized. */
-    int clipboardActive;	/* 1 means we currently own the clipboard
-				 * selection, 0 means we don't. */
-    struct TkMainInfo *clipboardAppPtr;
-				/* Last application that owned clipboard. */
-    struct TkClipboardTarget *clipTargetPtr;
-				/* First in list of clipboard type information
-				 * about the buffers for a given selection
-				 * target. */
-     * Information used by tkAtom.c only:
-    int atomInit;		/* 0 means stuff below hasn't been
-				 * initialized yet. */
-    Tcl_HashTable nameTable;	/* Maps from names to Atom's. */
-    Tcl_HashTable atomTable;	/* Maps from Atom's back to names. */
-     * Information used by tkCursor.c only:
-    Font cursorFont;		/* Font to use for standard cursors.
-				 * None means font not loaded yet. */
-     * Information used by tkGrab.c only:
-    struct TkWindow *grabWinPtr;
-				/* Window in which the pointer is currently
-				 * grabbed, or NULL if none. */
-    struct TkWindow *eventualGrabWinPtr;
-				/* Value that grabWinPtr will have once the
-				 * grab event queue (below) has been
-				 * completely emptied. */
-    struct TkWindow *buttonWinPtr;
-				/* Window in which first mouse button was
-				 * pressed while grab was in effect, or NULL
-				 * if no such press in effect. */
-    struct TkWindow *serverWinPtr;
-				/* If no application contains the pointer then
-				 * this is NULL.  Otherwise it contains the
-				 * last window for which we've gotten an
-				 * Enter or Leave event from the server (i.e.
-				 * the last window known to have contained
-				 * the pointer).  Doesn't reflect events
-				 * that were synthesized in tkGrab.c. */
-    TkGrabEvent *firstGrabEventPtr;
-				/* First in list of enter/leave events
-				 * synthesized by grab code.  These events
-				 * must be processed in order before any other
-				 * events are processed.  NULL means no such
-				 * events. */
-    TkGrabEvent *lastGrabEventPtr;
-				/* Last in list of synthesized events, or NULL
-				 * if list is empty. */
-    int grabFlags;		/* Miscellaneous flag values.  See definitions
-				 * in tkGrab.c. */
-     * Information used by tkXId.c only:
-    struct TkIdStack *idStackPtr;
-				/* First in list of chunks of free resource
-				 * identifiers, or NULL if there are no free
-				 * resources. */
-    XID (*defaultAllocProc) _ANSI_ARGS_((Display *display));
-				/* Default resource allocator for display. */
-    struct TkIdStack *windowStackPtr;
-				/* First in list of chunks of window
-				 * identifers that can't be reused right
-				 * now. */
-    int idCleanupScheduled;	/* 1 means a call to WindowIdCleanup has
-				 * already been scheduled, 0 means it
-				 * hasn't. */
-     * Information maintained by tkWindow.c for use later on by tkXId.c:
-    int destroyCount;		/* Number of Tk_DestroyWindow operations
-				 * in progress. */
-    unsigned long lastDestroyRequest;
-				/* Id of most recent XDestroyWindow request;
-				 * can re-use ids in windowStackPtr when
-				 * server has seen this request and event
-				 * queue is empty. */
-     * Information used by tkVisual.c only:
-    TkColormap *cmapPtr;	/* First in list of all non-default colormaps
-				 * allocated for this display. */
-     * Information used by tkFocus.c only:
-    struct TkWindow *implicitWinPtr;
-				/* If the focus arrived at a toplevel window
-				 * implicitly via an Enter event (rather
-				 * than via a FocusIn event), this points
-				 * to the toplevel window.  Otherwise it is
-				 * NULL. */
-    struct TkWindow *focusPtr;	/* Points to the window on this display that
-				 * should be receiving keyboard events.  When
-				 * multiple applications on the display have
-				 * the focus, this will refer to the
-				 * innermost window in the innermost
-				 * application.  This information isn't used
-				 * under Unix or Windows, but it's needed on
-				 * the Macintosh. */
-     * Used by tkColor.c only:
-    TkStressedCmap *stressPtr;	/* First in list of colormaps that have
-				 * filled up, so we have to pick an
-				 * approximate color. */
-     * Used by tkEvent.c only:
-    struct TkWindowEvent *delayedMotionPtr;
-				/* Points to a malloc-ed motion event
-				 * whose processing has been delayed in
-				 * the hopes that another motion event
-				 * will come along right away and we can
-				 * merge the two of them together.  NULL
-				 * means that there is no delayed motion
-				 * event. */
-     * Miscellaneous information:
-#ifdef TK_USE_INPUT_METHODS
-    XIM inputMethod;		/* Input method for this display */
-#endif /* TK_USE_INPUT_METHODS */
-    Tcl_HashTable winTable;	/* Maps from X window ids to TkWindow ptrs. */
-    int refCount;		/* Reference count of how many Tk applications
-                                 * are using this display. Used to clean up
-                                 * the display when we no longer have any
-                                 * Tk applications using it.
-} TkDisplay;
- * One of the following structures exists for each error handler
- * created by a call to Tk_CreateErrorHandler.  The structure
- * is managed by tkError.c.
-typedef struct TkErrorHandler {
-    TkDisplay *dispPtr;		/* Display to which handler applies. */
-    unsigned long firstRequest;	/* Only errors with serial numbers
-				 * >= to this are considered. */
-    unsigned long lastRequest;	/* Only errors with serial numbers
-				 * <= to this are considered.  This
-				 * field is filled in when XUnhandle
-				 * is called.  -1 means XUnhandle
-				 * hasn't been called yet. */
-    int error;			/* Consider only errors with this
-				 * error_code (-1 means consider
-				 * all errors). */
-    int request;		/* Consider only errors with this
-				 * major request code (-1 means
-				 * consider all major codes). */
-    int minorCode;		/* Consider only errors with this
-				 * minor request code (-1 means
-				 * consider all minor codes). */
-    Tk_ErrorProc *errorProc;	/* Procedure to invoke when a matching
-				 * error occurs.  NULL means just ignore
-				 * errors. */
-    ClientData clientData;	/* Arbitrary value to pass to
-				 * errorProc. */
-    struct TkErrorHandler *nextPtr;
-				/* Pointer to next older handler for
-				 * this display, or NULL for end of
-				 * list. */
-} TkErrorHandler;
- * One of the following structures exists for each event handler
- * created by calling Tk_CreateEventHandler.  This information
- * is used by tkEvent.c only.
-typedef struct TkEventHandler {
-    unsigned long mask;		/* Events for which to invoke
-				 * proc. */
-    Tk_EventProc *proc;		/* Procedure to invoke when an event
-				 * in mask occurs. */
-    ClientData clientData;	/* Argument to pass to proc. */
-    struct TkEventHandler *nextPtr;
-				/* Next in list of handlers
-				 * associated with window (NULL means
-				 * end of list). */
-} TkEventHandler;
- * Tk keeps one of the following data structures for each main
- * window (created by a call to Tk_CreateMainWindow).  It stores
- * information that is shared by all of the windows associated
- * with a particular main window.
-typedef struct TkMainInfo {
-    int refCount;		/* Number of windows whose "mainPtr" fields
-				 * point here.  When this becomes zero, can
-				 * free up the structure (the reference
-				 * count is zero because windows can get
-				 * deleted in almost any order;  the main
-				 * window isn't necessarily the last one
-				 * deleted). */
-    struct TkWindow *winPtr;	/* Pointer to main window. */
-    Tcl_Interp *interp;		/* Interpreter associated with application. */
-    Tcl_HashTable nameTable;	/* Hash table mapping path names to TkWindow
-				 * structs for all windows related to this
-				 * main window.  Managed by tkWindow.c. */
-    Tk_BindingTable bindingTable;
-				/* Used in conjunction with "bind" command
-				 * to bind events to Tcl commands. */
-    TkBindInfo bindInfo;	/* Information used by tkBind.c on a per
-				 * interpreter basis. */
-    struct TkFontInfo *fontInfoPtr;
-				/* Hold named font tables.  Used only by
-				 * tkFont.c. */
-     * Information used only by tkFocus.c and tk*Embed.c:
-    struct TkToplevelFocusInfo *tlFocusPtr;
-				/* First in list of records containing focus
-				 * information for each top-level in the
-				 * application.  Used only by tkFocus.c. */
-    struct TkDisplayFocusInfo *displayFocusPtr;
-				 * information for each display that this
-				 * application has ever used.  Used only
-				 * by tkFocus.c. */
-    struct ElArray *optionRootPtr;
-				/* Top level of option hierarchy for this
-				 * main window.  NULL means uninitialized.
-				 * Managed by tkOption.c. */
-    Tcl_HashTable imageTable;	/* Maps from image names to Tk_ImageMaster
-				 * structures.  Managed by tkImage.c. */
-    int strictMotif;		/* This is linked to the tk_strictMotif
-				 * global variable. */
-    struct TkMainInfo *nextPtr;	/* Next in list of all main windows managed by
-				 * this process. */
-} TkMainInfo;
- * Tk keeps the following data structure for each of it's builtin
- * bitmaps.  This structure is only used by tkBitmap.c and other
- * platform specific bitmap files.
-typedef struct {
-    char *source;		/* Bits for bitmap. */
-    int width, height;		/* Dimensions of bitmap. */
-    int native;			/* 0 means generic (X style) bitmap,
-    				 * 1 means native style bitmap. */
-} TkPredefBitmap;
- * Tk keeps one of the following structures for each window.
- * Some of the information (like size and location) is a shadow
- * of information managed by the X server, and some is special
- * information used here, such as event and geometry management
- * information.  This information is (mostly) managed by tkWindow.c.
- * WARNING: the declaration below must be kept consistent with the
- * Tk_FakeWin structure in tk.h.  If you change one, be sure to
- * change the other!!
-typedef struct TkWindow {
-     * Structural information:
-    Display *display;		/* Display containing window. */
-    TkDisplay *dispPtr;		/* Tk's information about display
-				 * for window. */
-    int screenNum;		/* Index of screen for window, among all
-				 * those for dispPtr. */
-    Visual *visual;		/* Visual to use for window.  If not default,
-				 * MUST be set before X window is created. */
-    int depth;			/* Number of bits/pixel. */
-    Window window;		/* X's id for window.   NULL means window
-				 * hasn't actually been created yet, or it's
-				 * been deleted. */
-    struct TkWindow *childList;	/* First in list of child windows,
-				 * or NULL if no children.  List is in
-				 * stacking order, lowest window first.*/
-    struct TkWindow *lastChildPtr;
-				/* Last in list of child windows (highest
-				 * in stacking order), or NULL if no
-				 * children. */
-    struct TkWindow *parentPtr;	/* Pointer to parent window (logical
-				 * parent, not necessarily X parent).  NULL
-				 * means either this is the main window, or
-				 * the window's parent has already been
-				 * deleted. */
-    struct TkWindow *nextPtr;	/* Next higher sibling (in stacking order)
-				 * in list of children with same parent.  NULL
-				 * means end of list. */
-    TkMainInfo *mainPtr;	/* Information shared by all windows
-				 * associated with a particular main
-				 * window.  NULL means this window is
-				 * a rogue that isn't associated with
-				 * any application (at present, this
-				 * only happens for the dummy windows
-				 * used for "send" communication).  */
-     * Name and type information for the window:
-    char *pathName;		/* Path name of window (concatenation
-				 * of all names between this window and
-				 * its top-level ancestor).  This is a
-				 * pointer into an entry in
-				 * mainPtr->nameTable.  NULL means that
-				 * the window hasn't been completely
-				 * created yet. */
-    Tk_Uid nameUid;		/* Name of the window within its parent
-				 * (unique within the parent). */
-    Tk_Uid classUid;		/* Class of the window.  NULL means window
-				 * hasn't been given a class yet. */
-     * Geometry and other attributes of window.  This information
-     * may not be updated on the server immediately;  stuff that
-     * hasn't been reflected in the server yet is called "dirty".
-     * At present, information can be dirty only if the window
-     * hasn't yet been created.
-    XWindowChanges changes;	/* Geometry and other info about
-				 * window. */
-    unsigned int dirtyChanges;	/* Bits indicate fields of "changes"
-				 * that are dirty. */
-    XSetWindowAttributes atts;	/* Current attributes of window. */
-    unsigned long dirtyAtts;	/* Bits indicate fields of "atts"
-    unsigned int flags;		/* Various flag values:  these are all
-				 * defined in tk.h (confusing, but they're
-				 * needed there for some query macros). */
-     * Information kept by the event manager (tkEvent.c):
-    TkEventHandler *handlerList;/* First in list of event handlers
-				 * declared for this window, or
-				 * NULL if none. */
-    XIC inputContext;		/* Input context (for input methods). */
-     * Information used for event bindings (see "bind" and "bindtags"
-     * commands in tkCmds.c):
-    ClientData *tagPtr;		/* Points to array of tags used for bindings
-				 * on this window.  Each tag is a Tk_Uid.
-				 * Malloc'ed.  NULL means no tags. */
-    int numTags;		/* Number of tags at *tagPtr. */
-     * Information used by tkOption.c to manage options for the
-     * window.
-    int optionLevel;		/* -1 means no option information is
-				 * currently cached for this window.
-				 * Otherwise this gives the level in
-				 * the option stack at which info is
-				 * cached. */
-     * Information used by tkSelect.c to manage the selection.
-    struct TkSelHandler *selHandlerList;
-				/* First in list of handlers for
-				 * returning the selection in various
-				 * forms. */
-     * Information used by tkGeometry.c for geometry management.
-    Tk_GeomMgr *geomMgrPtr;	/* Information about geometry manager for
-				 * this window. */
-    ClientData geomData;	/* Argument for geometry manager procedures. */
-    int reqWidth, reqHeight;	/* Arguments from last call to
-				 * Tk_GeometryRequest, or 0's if
-				 * Tk_GeometryRequest hasn't been
-				 * called. */
-    int internalBorderWidth;	/* Width of internal border of window
-				 * (0 means no internal border).  Geometry
-				 * managers should not normally place children
-				 * on top of the border. */
-     * Information maintained by tkWm.c for window manager communication.
-    struct TkWmInfo *wmInfoPtr;	/* For top-level windows (and also
-				 * for special Unix menubar and wrapper
-				 * windows), points to structure with
-				 * wm-related info (see tkWm.c).  For
-				 * other windows, this is NULL. */
-     * Information used by widget classes.
-    TkClassProcs *classProcsPtr;
-    ClientData instanceData;
-     * Platform specific information private to each port.
-    struct TkWindowPrivate *privatePtr;
-} TkWindow;
- * The following structure is used as a two way map between integers
- * and strings, usually to map between an internal C representation
- * and the strings used in Tcl.
-typedef struct TkStateMap {
-    int numKey;			/* Integer representation of a value. */
-    char *strKey;		/* String representation of a value. */
-} TkStateMap;
- * This structure is used by the Mac and Window porting layers as
- * the internal representation of a clip_mask in a GC.
-typedef struct TkpClipMask {
-    int type;			/* One of TKP_CLIP_PIXMAP or TKP_CLIP_REGION */
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
-#define TKP_CLIP_PIXMAP 0
-#define TKP_CLIP_REGION 1
- * Pointer to first entry in list of all displays currently known.
-extern TkDisplay *tkDisplayList;
- * Return values from TkGrabState:
-#define TK_GRAB_NONE		0
-#define TK_GRAB_IN_TREE		1
-#define TK_GRAB_ANCESTOR	2
-#define TK_GRAB_EXCLUDED	3
- * The macro below is used to modify a "char" value (e.g. by casting
- * it to an unsigned character) so that it can be used safely with
- * macros such as isspace.
-#define UCHAR(c) ((unsigned char) (c))
- * The following symbol is used in the mode field of FocusIn events
- * generated by an embedded application to request the input focus from
- * its container.
-#define EMBEDDED_APP_WANTS_FOCUS (NotifyNormal + 20)
- * Miscellaneous variables shared among Tk modules but not exported
- * to the outside world:
-extern Tk_Uid			tkActiveUid;
-extern Tk_ImageType		tkBitmapImageType;
-extern Tk_Uid			tkDisabledUid;
-extern Tk_PhotoImageFormat	tkImgFmtGIF;
-extern void			(*tkHandleEventProc) _ANSI_ARGS_((
-    				    XEvent* eventPtr));
-extern Tk_PhotoImageFormat	tkImgFmtPPM;
-extern TkMainInfo		*tkMainWindowList;
-extern Tk_Uid			tkNormalUid;
-extern Tk_ImageType		tkPhotoImageType;
-extern Tcl_HashTable		tkPredefBitmapTable;
-extern int			tkSendSerial;
- * Internal procedures shared among Tk modules but not exported
-EXTERN char *		TkAlignImageData _ANSI_ARGS_((XImage *image,
-			    int alignment, int bitOrder));
-EXTERN TkWindow *	TkAllocWindow _ANSI_ARGS_((TkDisplay *dispPtr,
-			    int screenNum, TkWindow *parentPtr));
-EXTERN void		TkBezierPoints _ANSI_ARGS_((double control[],
-			    int numSteps, double *coordPtr));
-EXTERN void		TkBezierScreenPoints _ANSI_ARGS_((Tk_Canvas canvas,
-			    double control[], int numSteps,
-			    XPoint *xPointPtr));
-EXTERN void		TkBindDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkBindEventProc _ANSI_ARGS_((TkWindow *winPtr,
-EXTERN void		TkBindFree _ANSI_ARGS_((TkMainInfo *mainPtr));
-EXTERN void		TkBindInit _ANSI_ARGS_((TkMainInfo *mainPtr));
-EXTERN void		TkChangeEventWindow _ANSI_ARGS_((XEvent *eventPtr,
-			    TkWindow *winPtr));
-#ifndef TkClipBox
-EXTERN void		TkClipBox _ANSI_ARGS_((TkRegion rgn,
-			    XRectangle* rect_return));
-#endif
-EXTERN int		TkClipInit _ANSI_ARGS_((Tcl_Interp *interp,
-			    TkDisplay *dispPtr));
-EXTERN void		TkComputeAnchor _ANSI_ARGS_((Tk_Anchor anchor,
-			    Tk_Window tkwin, int padX, int padY,
-			    int innerWidth, int innerHeight, int *xPtr,
-			    int *yPtr));
-EXTERN int		TkCopyAndGlobalEval _ANSI_ARGS_((Tcl_Interp *interp,
-			    char *script));
-EXTERN unsigned long	TkCreateBindingProcedure _ANSI_ARGS_((
-			    Tcl_Interp *interp, Tk_BindingTable bindingTable,
-			    ClientData object, char *eventString,
-			    TkBindEvalProc *evalProc, TkBindFreeProc *freeProc,
-			    ClientData clientData));
-EXTERN TkCursor *	TkCreateCursorFromData _ANSI_ARGS_((Tk_Window tkwin,
-			    char *source, char *mask, int width, int height,
-			    int xHot, int yHot, XColor fg, XColor bg));
-EXTERN int		TkCreateFrame _ANSI_ARGS_((ClientData clientData,
-			    Tcl_Interp *interp, int argc, char **argv,
-			    int toplevel, char *appName));
-EXTERN Tk_Window	TkCreateMainWindow _ANSI_ARGS_((Tcl_Interp *interp,
-			    char *screenName, char *baseName));
-#ifndef TkCreateRegion
-EXTERN TkRegion		TkCreateRegion _ANSI_ARGS_((void));
-#endif
-EXTERN Time		TkCurrentTime _ANSI_ARGS_((TkDisplay *dispPtr));
-EXTERN int		TkDeadAppCmd _ANSI_ARGS_((ClientData clientData,
-			    Tcl_Interp *interp, int argc, char **argv));
-EXTERN void		TkDeleteAllImages _ANSI_ARGS_((TkMainInfo *mainPtr));
-#ifndef TkDestroyRegion
-EXTERN void		TkDestroyRegion _ANSI_ARGS_((TkRegion rgn));
-#endif
-EXTERN void		TkDoConfigureNotify _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkDrawInsetFocusHighlight _ANSI_ARGS_((
-			    Tk_Window tkwin, GC gc, int width,
-			    Drawable drawable, int padding));
-EXTERN void		TkEventDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkFillPolygon _ANSI_ARGS_((Tk_Canvas canvas,
-			    double *coordPtr, int numPoints, Display *display,
-			    Drawable drawable, GC gc, GC outlineGC));
-EXTERN int		TkFindStateNum _ANSI_ARGS_((Tcl_Interp *interp,
-			    CONST char *option, CONST TkStateMap *mapPtr,
-			    CONST char *strKey));
-EXTERN char *		TkFindStateString _ANSI_ARGS_((
-			    CONST TkStateMap *mapPtr, int numKey));
-EXTERN void		TkFocusDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN int		TkFocusFilterEvent _ANSI_ARGS_((TkWindow *winPtr,
-EXTERN TkWindow *	TkFocusKeyEvent _ANSI_ARGS_((TkWindow *winPtr,
-EXTERN void		TkFontPkgInit _ANSI_ARGS_((TkMainInfo *mainPtr));
-EXTERN void		TkFontPkgFree _ANSI_ARGS_((TkMainInfo *mainPtr));
-EXTERN void		TkFreeBindingTags _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkFreeCursor _ANSI_ARGS_((TkCursor *cursorPtr));
-EXTERN void		TkFreeWindowId _ANSI_ARGS_((TkDisplay *dispPtr,
-			    Window w));
-EXTERN void		TkGenerateActivateEvents _ANSI_ARGS_((
-			    TkWindow *winPtr, int active));
-EXTERN char *		TkGetBitmapData _ANSI_ARGS_((Tcl_Interp *interp,
-			    char *string, char *fileName, int *widthPtr,
-			    int *heightPtr, int *hotXPtr, int *hotYPtr));
-EXTERN void		TkGetButtPoints _ANSI_ARGS_((double p1[], double p2[],
-			    double width, int project, double m1[],
-			    double m2[]));
-EXTERN TkCursor *	TkGetCursorByName _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Window tkwin, Tk_Uid string));
-EXTERN char *		TkGetDefaultScreenName _ANSI_ARGS_((Tcl_Interp *interp,
-			    char *screenName));
-EXTERN TkDisplay *	TkGetDisplay _ANSI_ARGS_((Display *display));
-EXTERN int		TkGetDisplayOf _ANSI_ARGS_((Tcl_Interp *interp,
-			    int objc, Tcl_Obj *CONST objv[],
-			    Tk_Window *tkwinPtr));
-EXTERN TkWindow *	TkGetFocusWin _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN int		TkGetInterpNames _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Window tkwin));
-EXTERN int		TkGetMiterPoints _ANSI_ARGS_((double p1[], double p2[],
-			    double p3[], double width, double m1[],
-			    double m2[]));
-EXTERN void		TkGetPointerCoords _ANSI_ARGS_((Tk_Window tkwin,
-			    int *xPtr, int *yPtr));
-EXTERN int		TkGetProlog _ANSI_ARGS_((Tcl_Interp *interp));
-EXTERN void		TkGetServerInfo _ANSI_ARGS_((Tcl_Interp *interp,
-EXTERN void		TkGrabDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN int		TkGrabState _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkIncludePoint _ANSI_ARGS_((Tk_Item *itemPtr,
-			    double *pointPtr));
-EXTERN void		TkInitXId _ANSI_ARGS_((TkDisplay *dispPtr));
-EXTERN void		TkInOutEvents _ANSI_ARGS_((XEvent *eventPtr,
-			    TkWindow *sourcePtr, TkWindow *destPtr,
-			    int leaveType, int enterType,
-			    Tcl_QueuePosition position));
-EXTERN void		TkInstallFrameMenu _ANSI_ARGS_((Tk_Window tkwin));
-#ifndef TkIntersectRegion
-EXTERN void		TkIntersectRegion _ANSI_ARGS_((TkRegion sra,
-			    TkRegion srcb, TkRegion dr_return));
-#endif
-EXTERN char *		TkKeysymToString _ANSI_ARGS_((KeySym keysym));
-EXTERN int		TkLineToArea _ANSI_ARGS_((double end1Ptr[2],
-			    double end2Ptr[2], double rectPtr[4]));
-EXTERN double		TkLineToPoint _ANSI_ARGS_((double end1Ptr[2],
-			    double end2Ptr[2], double pointPtr[2]));
-EXTERN int		TkMakeBezierCurve _ANSI_ARGS_((Tk_Canvas canvas,
-			    double *pointPtr, int numPoints, int numSteps,
-			    XPoint xPoints[], double dblPoints[]));
-EXTERN void		TkMakeBezierPostscript _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Canvas canvas, double *pointPtr,
-			    int numPoints));
-EXTERN void		TkOptionClassChanged _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkOptionDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN int		TkOvalToArea _ANSI_ARGS_((double *ovalPtr,
-			    double *rectPtr));
-EXTERN double		TkOvalToPoint _ANSI_ARGS_((double ovalPtr[4],
-			    double width, int filled, double pointPtr[2]));
-EXTERN int		TkpChangeFocus _ANSI_ARGS_((TkWindow *winPtr,
-			    int force));
-EXTERN void		TkpCloseDisplay _ANSI_ARGS_((TkDisplay *dispPtr));
-EXTERN void		TkpClaimFocus _ANSI_ARGS_((TkWindow *topLevelPtr,
-			    int force));
-#ifndef TkpCmapStressed
-EXTERN int		TkpCmapStressed _ANSI_ARGS_((Tk_Window tkwin,
-			    Colormap colormap));
-#endif
-#ifndef TkpCreateNativeBitmap
-EXTERN Pixmap		TkpCreateNativeBitmap _ANSI_ARGS_((Display *display,
-			    char * source));
-#endif
-#ifndef TkpDefineNativeBitmaps
-EXTERN void		TkpDefineNativeBitmaps _ANSI_ARGS_((void));
-#endif
-EXTERN void		TkpDisplayWarning _ANSI_ARGS_((char *msg,
-			    char *title));
-EXTERN void		TkpGetAppName _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tcl_DString *name));
-EXTERN unsigned long	TkpGetMS _ANSI_ARGS_((void));
-#ifndef TkpGetNativeAppBitmap
-EXTERN Pixmap		TkpGetNativeAppBitmap _ANSI_ARGS_((Display *display,
-			    char *name, int *width, int *height));
-#endif
-EXTERN TkWindow *	TkpGetOtherWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN TkWindow *	TkpGetWrapperWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN int		TkpInit _ANSI_ARGS_((Tcl_Interp *interp));
-EXTERN void		TkpInitializeMenuBindings _ANSI_ARGS_((
-			    Tcl_Interp *interp, Tk_BindingTable bindingTable));
-EXTERN void		TkpMakeContainer _ANSI_ARGS_((Tk_Window tkwin));
-EXTERN void		TkpMakeMenuWindow _ANSI_ARGS_((Tk_Window tkwin,
-			    int transient));
-EXTERN Window		TkpMakeWindow _ANSI_ARGS_((TkWindow *winPtr,
-			    Window parent));
-EXTERN void		TkpMenuNotifyToplevelCreate _ANSI_ARGS_((
-			    Tcl_Interp *, char *menuName));
-EXTERN TkDisplay *	TkpOpenDisplay _ANSI_ARGS_((char *display_name));
-EXTERN void		TkPointerDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN int		TkPointerEvent _ANSI_ARGS_((XEvent *eventPtr,
-EXTERN int		TkPolygonToArea _ANSI_ARGS_((double *polyPtr,
-			    int numPoints, double *rectPtr));
-EXTERN double		TkPolygonToPoint _ANSI_ARGS_((double *polyPtr,
-			    int numPoints, double *pointPtr));
-EXTERN int		TkPositionInTree _ANSI_ARGS_((TkWindow *winPtr,
-			    TkWindow *treePtr));
-#ifndef TkpPrintWindowId
-EXTERN void		TkpPrintWindowId _ANSI_ARGS_((char *buf,
-			    Window window));
-#endif
-EXTERN void		TkpRedirectKeyEvent _ANSI_ARGS_((TkWindow *winPtr,
-#ifndef TkpScanWindowId
-EXTERN int		TkpScanWindowId _ANSI_ARGS_((Tcl_Interp *interp,
-			    char *string, int *idPtr));
-#endif
-EXTERN void		TkpSetCapture _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkpSetCursor _ANSI_ARGS_((TkpCursor cursor));
-EXTERN void		TkpSetMainMenubar _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Window tkwin, char *menuName));
-#ifndef TkpSync
-EXTERN void		TkpSync _ANSI_ARGS_((Display *display));
-#endif
-EXTERN int		TkpTestembedCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		TkpUseWindow _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Window tkwin, char *string));
-#ifndef TkPutImage
-EXTERN void		TkPutImage _ANSI_ARGS_((unsigned long *colors,
-			    int ncolors, Display* display, Drawable d,
-			    GC gc, XImage* image, int src_x, int src_y,
-			    int dest_x, int dest_y, unsigned int width,
-			    unsigned int height));
-#endif
-EXTERN int		TkpWindowWasRecentlyDeleted _ANSI_ARGS_((Window win,
-EXTERN void		TkpWmSetState _ANSI_ARGS_((TkWindow *winPtr,
-			    int state));
-EXTERN void		TkQueueEventForAllChildren _ANSI_ARGS_((
-			    TkWindow *winPtr, XEvent *eventPtr));
-EXTERN int		TkReadBitmapFile _ANSI_ARGS_((Display* display,
-			    Drawable d, CONST char* filename,
-			    unsigned int* width_return,
-			    unsigned int* height_return,
-			    Pixmap* bitmap_return,
-			    int* x_hot_return, int* y_hot_return));
-#ifndef TkRectInRegion
-EXTERN int		TkRectInRegion _ANSI_ARGS_((TkRegion rgn,
-			    int x, int y, unsigned int width,
-#endif
-EXTERN int		TkScrollWindow _ANSI_ARGS_((Tk_Window tkwin, GC gc,
-			    int x, int y, int width, int height, int dx,
-			    int dy, TkRegion damageRgn));
-EXTERN void		TkSelDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkSelEventProc _ANSI_ARGS_((Tk_Window tkwin,
-EXTERN void		TkSelInit _ANSI_ARGS_((Tk_Window tkwin));
-EXTERN void		TkSelPropProc _ANSI_ARGS_((XEvent *eventPtr));
-EXTERN void		TkSetClassProcs _ANSI_ARGS_((Tk_Window tkwin,
-			    TkClassProcs *procs, ClientData instanceData));
-#ifndef TkSetPixmapColormap
-EXTERN void		TkSetPixmapColormap _ANSI_ARGS_((Pixmap pixmap,
-#endif
-#ifndef TkSetRegion
-EXTERN void		TkSetRegion _ANSI_ARGS_((Display* display, GC gc,
-			    TkRegion rgn));
-#endif
-EXTERN void		TkSetWindowMenuBar _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Window tkwin, char *oldMenuName,
-			    char *menuName));
-EXTERN KeySym		TkStringToKeysym _ANSI_ARGS_((char *name));
-EXTERN int		TkThickPolyLineToArea _ANSI_ARGS_((double *coordPtr,
-			    int numPoints, double width, int capStyle,
-			    int joinStyle, double *rectPtr));
-#ifndef TkUnionRectWithRegion
-EXTERN void		TkUnionRectWithRegion _ANSI_ARGS_((XRectangle* rect,
-			    TkRegion src, TkRegion dr_return));
-#endif
-EXTERN void		TkWmAddToColormapWindows _ANSI_ARGS_((
-EXTERN void		TkWmDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN TkWindow *	TkWmFocusToplevel _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkWmMapWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkWmNewWindow _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkWmProtocolEventProc _ANSI_ARGS_((TkWindow *winPtr,
-			    XEvent *evenvPtr));
-EXTERN void		TkWmRemoveFromColormapWindows _ANSI_ARGS_((
-EXTERN void		TkWmRestackToplevel _ANSI_ARGS_((TkWindow *winPtr,
-			    int aboveBelow, TkWindow *otherPtr));
-EXTERN void		TkWmSetClass _ANSI_ARGS_((TkWindow *winPtr));
-EXTERN void		TkWmUnmapWindow _ANSI_ARGS_((TkWindow *winPtr));
- * Unsupported commands.
-EXTERN int		TkUnsupported1Cmd _ANSI_ARGS_((ClientData clientData,
-# define TCL_STORAGE_CLASS DLLIMPORT
-#endif  /* _TKINT */
Deleted: grass/trunk/visualization/nviz/src/tkInt4.0.h
--- grass/trunk/visualization/nviz/src/tkInt4.0.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt4.0.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,728 +0,0 @@
- * tkInt.h --
- * Copyright (c) 1994 Sun Microsystems, Inc.
- * @(#) tkInt.h 1.147 95/06/24 17:12:55
-#ifndef _TKINT
-#define _TKINT
-#ifndef _XLIB_H_
-#include <X11/Xlib.h>
-#endif
-#ifndef _XUTIL_H
-#include <X11/Xutil.h>
-#endif
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-				 * display. */
-				 * below. */
-				 * may be NULL. */
-				 * initialized. */
-				 * target. */
-				 * events. */
-				 * in tkGrab.c. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-				 * in progress. */
-    struct TkWindow *focusWinPtr;
-				/* Window that currently has the focus for
-				 * this display, or NULL if none. */
-				 * NULL. */
-    struct TkWindow *focusOnMapPtr;
-				/* This points to a toplevel window that is
-				 * supposed to receive the X input focus as
-				 * soon as it is mapped (needed to handle the
-				 * fact that X won't allow the focus on an
-				 * unmapped window).  NULL means no delayed
-				 * focus op in progress. */
-    int forceFocus;		/* Associated with focusOnMapPtr:  non-zero
-				 * means claim the focus even if some other
-				 * application currently has it. */
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-    TkDisplay *curDispPtr;	/* Display for last binding command invoked
-				 * in this application;  used only  by
-				 * tkBind.c. */
-    int curScreenIndex;		/* Index of screen for last binding command.
-				 * Used only by tkBind.c. */
-    int bindingDepth;		/* Number of active instances of Tk_BindEvent
-				 * in this application.  Used only by
-				 * tkBind.c. */
-    struct TkFocusInfo *focusPtr;
-    unsigned long focusSerial;	/* Serial number of last request we made to
-				 * change the focus.  Used to identify
-				 * stale focus notifications coming from the
-				 * X server. */
-    struct TkWindow *lastFocusPtr;
-				/* The most recent window that was given the
-				 * focus via "focus" command.  Used to restore
-				 * the focus when we get stale FocusIn
-				 * events. */
-} TkMainInfo;
-				 * for window. */
-				 * or NULL if no children. */
-				/* Last in list of child windows, or NULL
-				 * if no children. */
-				 * deleted. */
-    struct TkWindow *nextPtr;	/* Next in list of children with
-				 * same parent (NULL if end of
-				 * list). */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-    struct TkWmInfo *wmInfoPtr;	/* For top-level windows, points to
-				 * structure with wm-related info (see
-				 * tkWm.c).  For other windows, this
-				 * is NULL. */
-} TkWindow;
- * Flags passed to TkMeasureChars:
-#define TK_WHOLE_WORDS		 1
-#define TK_AT_LEAST_ONE		 2
-#define TK_PARTIAL_OK		 4
-#define TK_NEWLINES_NOT_SPECIAL	 8
-#define TK_IGNORE_TABS		16
- * Location of library directory containing Tk scripts.  This value
- * is put in the $tkLibrary variable for each application.
-#ifndef TK_LIBRARY
-#define TK_LIBRARY "/usr/local/lib/tk"
-#endif
- * Special flag to pass to Tk_CreateFileHandler to indicate that
- * the file descriptor is actually for a display, not a file, and
- * should be treated specially.  Make sure that this value doesn't
- * conflict with TK_READABLE, TK_WRITABLE, or TK_EXCEPTION from tk.h.
-#define TK_IS_DISPLAY	32
-extern void			(*tkDelayedEventProc) _ANSI_ARGS_((void));
-extern int		TkAreaToPolygon _ANSI_ARGS_((double *polyPtr,
-extern void		TkBezierPoints _ANSI_ARGS_((double control[],
-extern void		TkBezierScreenPoints _ANSI_ARGS_((Tk_Canvas canvas,
-extern void		TkBindEventProc _ANSI_ARGS_((TkWindow *winPtr,
-extern int		TkClipInit _ANSI_ARGS_((Tcl_Interp *interp,
-extern int		TkCmapStressed _ANSI_ARGS_((Tk_Window tkwin,
-extern void		TkComputeTextGeometry _ANSI_ARGS_((
-			    XFontStruct *fontStructPtr, char *string,
-			    int numChars, int wrapLength, int *widthPtr,
-			    int *heightPtr));
-extern int		TkCopyAndGlobalEval _ANSI_ARGS_((Tcl_Interp *interp,
-			    char *script));
-extern Time		TkCurrentTime _ANSI_ARGS_((TkDisplay *dispPtr));
-extern int		TkDeadAppCmd _ANSI_ARGS_((ClientData clientData,
-extern void		TkDeleteAllImages _ANSI_ARGS_((TkMainInfo *mainPtr));
-extern void		TkDisplayChars _ANSI_ARGS_((Display *display,
-			    int numChars, int x, int y, int tabOrigin,
-			    int flags));
-extern void		TkDisplayText _ANSI_ARGS_((Display *display,
-			    Drawable drawable, XFontStruct *fontStructPtr,
-			    char *string, int numChars, int x, int y,
-			    int length, Tk_Justify justify, int underline,
-			    GC gc));
-extern void		TkEventCleanupProc _ANSI_ARGS_((
-			    ClientData clientData, Tcl_Interp *interp));
-extern void		TkEventDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkFillPolygon _ANSI_ARGS_((Tk_Canvas canvas,
-extern void		TkFocusDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern int		TkFocusFilterEvent _ANSI_ARGS_((TkWindow *winPtr,
-extern void		TkFreeBindingTags _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkFreeWindowId _ANSI_ARGS_((TkDisplay *dispPtr,
-			    Window w));
-extern void		TkGetButtPoints _ANSI_ARGS_((double p1[], double p2[],
-			    double m2[]));
-extern TkDisplay *	TkGetDisplay _ANSI_ARGS_((Display *display));
-extern TkWindow *	TkGetFocus _ANSI_ARGS_((TkWindow *winPtr));
-extern int		TkGetInterpNames _ANSI_ARGS_((Tcl_Interp *interp,
-extern int		TkGetMiterPoints _ANSI_ARGS_((double p1[], double p2[],
-			    double m2[]));
-extern void		TkGetPointerCoords _ANSI_ARGS_((Tk_Window tkwin,
-extern void		TkGetServerInfo _ANSI_ARGS_((Tcl_Interp *interp,
-extern void		TkGrabDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern int		TkGrabState _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkGrabTriggerProc _ANSI_ARGS_((XEvent *eventPtr));
-extern void		TkIncludePoint _ANSI_ARGS_((Tk_Item *itemPtr,
-extern char *		TkInitFrame _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Window tkwin, int toplevel, int argc,
-			    char *argv[]));
-extern void		TkInitXId _ANSI_ARGS_((TkDisplay *dispPtr));
-extern void		TkInOutEvents _ANSI_ARGS_((XEvent *eventPtr,
-			    int leaveType, int EnterType));
-extern int		TkLineToArea _ANSI_ARGS_((double end1Ptr[2],
-extern double		TkLineToPoint _ANSI_ARGS_((double end1Ptr[2],
-extern int		TkMakeBezierCurve _ANSI_ARGS_((Tk_Canvas canvas,
-extern void		TkMakeBezierPostscript _ANSI_ARGS_((Tcl_Interp *interp,
-			    int numPoints));
-extern int		TkMeasureChars _ANSI_ARGS_((XFontStruct *fontStructPtr,
-			    char *source, int maxChars, int startX, int maxX,
-			    int tabOrigin, int flags, int *nextXPtr));
-extern void		TkOptionClassChanged _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkOptionDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern int		TkOvalToArea _ANSI_ARGS_((double *ovalPtr,
-extern double		TkOvalToPoint _ANSI_ARGS_((double ovalPtr[4],
-extern int		TkPointerEvent _ANSI_ARGS_((XEvent *eventPtr,
-extern int		TkPolygonToArea _ANSI_ARGS_((double *polyPtr,
-extern double		TkPolygonToPoint _ANSI_ARGS_((double *polyPtr,
-extern void		TkQueueEvent _ANSI_ARGS_((TkDisplay *dispPtr,
-extern void		TkSelDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkSelEventProc _ANSI_ARGS_((Tk_Window tkwin,
-extern void		TkSelInit _ANSI_ARGS_((Tk_Window tkwin));
-extern void		TkSelPropProc _ANSI_ARGS_((XEvent *eventPtr));
-extern int		TkThickPolyLineToArea _ANSI_ARGS_((double *coordPtr,
-extern void		TkUnderlineChars _ANSI_ARGS_((Display *display,
-			    int x, int y, int tabOrigin, int flags,
-			    int firstChar, int lastChar));
-extern void		TkWmAddToColormapWindows _ANSI_ARGS_((
-extern void		TkWmDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkWmMapWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkWmNewWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkWmProtocolEventProc _ANSI_ARGS_((TkWindow *winPtr,
-extern void		TkWmRestackToplevel _ANSI_ARGS_((TkWindow *winPtr,
-extern void		TkWmSetClass _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkWmUnmapWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern int		TkXFileProc _ANSI_ARGS_((ClientData clientData,
-			    int mask, int flags));
Deleted: grass/trunk/visualization/nviz/src/tkInt4.1.h
--- grass/trunk/visualization/nviz/src/tkInt4.1.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt4.1.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,809 +0,0 @@
- * tkInt.h --
- * Copyright (c) 1994-1996 Sun Microsystems, Inc.
- * SCCS: @(#) tkInt.h 1.165 96/03/18 13:02:25
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-} TkCursor;
-#define LU_IGNORE 0
-#define LU_CAPS 1
-#define LU_SHIFT 2
-				 * display. */
-    int lockUsage;		/* BBB: enum doesn't work with C++ here... */
-				 * below. */
-				 * may be NULL. */
-				 * initialized. */
-				 * target. */
-				 * events. */
-				 * in tkGrab.c. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-				 * in progress. */
-				 * NULL. */
-				 * event. */
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-				 * X server. */
-				 * events. */
-} TkMainInfo;
-				 * for window. */
-				 * deleted. */
-				 * list). */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-				 * is NULL. */
-} TkWindow;
-EXTERN int		TkAreaToPolygon _ANSI_ARGS_((double *polyPtr,
-#ifndef TkClipBox
-#endif
-EXTERN int		TkCmapStressed _ANSI_ARGS_((Tk_Window tkwin,
-EXTERN void		TkComputeTextGeometry _ANSI_ARGS_((
-			    int *heightPtr));
-EXTERN void		TkConsoleCreate _ANSI_ARGS_((void));
-EXTERN int		TkConsoleInit _ANSI_ARGS_((Tcl_Interp *interp));
-EXTERN void		TkConsolePrint _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tcl_File outFile, char *buffer, long size));
-			    char *script));
-#endif
-#endif
-EXTERN void		TkDisplayChars _ANSI_ARGS_((Display *display,
-			    int flags));
-EXTERN void		TkDisplayText _ANSI_ARGS_((Display *display,
-			    GC gc));
-EXTERN void		TkEventCleanupProc _ANSI_ARGS_((
-			    Window w));
-			    double m2[]));
-EXTERN TkWindow *	TkGetFocus _ANSI_ARGS_((TkWindow *winPtr));
-			    double m2[]));
-EXTERN TkWindow *      	TkIDToWindow _ANSI_ARGS_((Window window,
-			    TkDisplay *display));
-#endif
-			    int numPoints));
-EXTERN Window		TkMakeWindow _ANSI_ARGS_((TkWindow *winPtr,
-			    Window parent));
-EXTERN int		TkMeasureChars _ANSI_ARGS_((XFontStruct *fontStructPtr,
-EXTERN int		TkPlatformInit _ANSI_ARGS_((Tcl_Interp *interp));
-#ifndef TkPutImage
-#endif
-#endif
-			    Tk_Window tkwin, XEvent *eventPtr));
-#endif
-			    TkRegion rgn));
-#endif
-EXTERN void		TkUnderlineChars _ANSI_ARGS_((Display *display,
-#endif
-EXTERN int		TkXFileProc _ANSI_ARGS_((ClientData clientData,
Deleted: grass/trunk/visualization/nviz/src/tkInt4.2.h
--- grass/trunk/visualization/nviz/src/tkInt4.2.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt4.2.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,854 +0,0 @@
- * tkInt.h --
- * SCCS: @(#) tkInt.h 1.172 96/10/12 17:29:48
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#include <tkPort.h>
-#endif
-} TkCursor;
-				 * display. */
-				 * below. */
-				 * may be NULL. */
-				 * initialized. */
-				 * target. */
-				 * events. */
-				 * in tkGrab.c. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-				 * in progress. */
-				 * NULL. */
-				 * event. */
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-    struct TkVirtualEventTable *vetPtr;
-				/* Hold definitions of virtual events. */
-				 * X server. */
-				 * events. */
-} TkMainInfo;
-				 * for window. */
-				 * deleted. */
-				 * list). */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-				 * is NULL. */
-} TkWindow;
-} TkStateMap;
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
-#ifndef TkClipBox
-#endif
-			    int *heightPtr));
-			    int devId, char *buffer, long size));
-			    char *script));
-#endif
-#endif
-			    int flags));
-			    GC gc));
-			    Window w));
-			    double m2[]));
-			    double m2[]));
-#ifndef TkGetNativeProlog
-EXTERN int		TkGetNativeProlog _ANSI_ARGS_((Tcl_Interp *interp));
-#endif
-#endif
-			    int numPoints));
-			    Window parent));
-#ifndef TkPutImage
-#endif
-#endif
-#endif
-			    TkRegion rgn));
-#endif
-#endif
Deleted: grass/trunk/visualization/nviz/src/tkInt8.0.2.h
--- grass/trunk/visualization/nviz/src/tkInt8.0.2.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt8.0.2.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,990 +0,0 @@
- * tkInt.h --
- * SCCS: @(#) tkInt.h 1.204 97/10/31 09:55:20
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#endif
-	KeySym keySym));
- * behavior.
-                                   created. */
-} TkClassProcs;
-} TkCursor;
-				 * display. */
-				 * below. */
-				 * may be NULL. */
-				 * initialized. */
-				 * target. */
-				 * events. */
-				 * in tkGrab.c. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-				 * in progress. */
-				 * NULL. */
-				 * event. */
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-				 * tkFont.c. */
-} TkMainInfo;
-typedef struct {
-} TkPredefBitmap;
-				 * for window. */
-				 * children. */
-				 * deleted. */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-} TkWindow;
-} TkStateMap;
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
- * its container.
-#ifndef TkClipBox
-#endif
-			    int *yPtr));
-			    char *script));
-#endif
-#endif
-			    Window w));
-			    double m2[]));
-			    double m2[]));
-#endif
-#endif
-EXTERN int		TkListAppend _ANSI_ARGS_((void **headPtrPtr,
-			    void *itemPtr, size_t size));
-EXTERN int		TkListDelete _ANSI_ARGS_((void **headPtrPtr,
-EXTERN void *		TkListFind _ANSI_ARGS_((void *headPtr, void *itemPtr,
-			    size_t size));
-			    int numPoints));
-			    int force));
-			    int force));
-#endif
-			    char * source));
-#endif
-#endif
-			    char *title));
-#endif
-			    int transient));
-			    Window parent));
-			    Window window));
-#endif
-#endif
-#ifndef TkpSync
-#endif
-#ifndef TkPutImage
-#endif
-			    int state));
-#endif
-#endif
-			    TkRegion rgn));
-#endif
-			    char *menuName));
-#endif
Deleted: grass/trunk/visualization/nviz/src/tkInt8.0.h
--- grass/trunk/visualization/nviz/src/tkInt8.0.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt8.0.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1005 +0,0 @@
-  $Log$
-  Revision 2.0  2004-11-09 14:21:40  bernhard
-  copied within CVS repository from grass/src.contrib/GMSL/NVIZ2.2/src/tkInt8.0.h
-  Revision 1.1  2000/10/16 16:14:32  markus
-  renamed from tkInt.h to tkInt8.0.h
-  Revision 1.3  2000/02/22 19:19:38  markus
-  added definition for Tk_SendCmd
-  Revision 1.2  2000/01/12 08:52:08  markus
-  commented line 46: Tk_PostscriptInfo
-  adjusted path in line 28   8/99 MN
- * tkInt.h --
- * RCS: $Id$
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#endif
-#ifdef BUILD_tk
-#endif
-/*typedef struct Tk_PostscriptInfo Tk_PostscriptInfo;*/
-	KeySym keySym));
- * behavior.
-                                   created. */
-} TkClassProcs;
-} TkCursor;
-				 * display. */
-				 * below. */
-				 * may be NULL. */
-				 * initialized. */
-				 * target. */
-				 * events. */
-				 * in tkGrab.c. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-				 * in progress. */
-				 * NULL. */
-				 * event. */
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-				 * tkFont.c. */
-} TkMainInfo;
-typedef struct {
-} TkPredefBitmap;
-				 * for window. */
-				 * children. */
-				 * deleted. */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-} TkWindow;
-} TkStateMap;
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
- * its container.
-EXTERN int              Tk_SendCmd _ANSI_ARGS_((ClientData clientData,
-#ifndef TkClipBox
-#endif
-			    int *yPtr));
-			    char *script));
-#endif
-#endif
-			    Window w));
-			    double m2[]));
-			    double m2[]));
-#endif
-			    int numPoints));
-			    int force));
-			    int force));
-#endif
-			    char * source));
-#endif
-#endif
-			    char *title));
-#endif
-			    int transient));
-			    Window parent));
-			    Window window));
-#endif
-#endif
-#ifndef TkpSync
-#endif
-#ifndef TkPutImage
-#endif
-			    int state));
-#endif
-#endif
-			    TkRegion rgn));
-#endif
-			    char *menuName));
-#endif
Deleted: grass/trunk/visualization/nviz/src/tkInt8.1.1.h
--- grass/trunk/visualization/nviz/src/tkInt8.1.1.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt8.1.1.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1009 +0,0 @@
- * tkInt.h --
- * RCS: $Id$
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#endif
-	KeySym keySym));
- * behavior.
-                                   created. */
-} TkClassProcs;
-    Display *display;		/* Display containing cursor. Needed for
-				 * disposal and retrieval of cursors. */
-    int resourceRefCount;	/* Number of active uses of this cursor (each
-				 * active use corresponds to a call to
-				 * Tk_AllocPreserveFromObj or Tk_Preserve).
-				 * If this count is 0, then this structure
-				 * is no longer valid and it isn't present
-				 * in a hash table: it is being kept around
-				 * only because there are objects referring
-				 * to it.  The structure is freed when
-				 * resourceRefCount and objRefCount are
-				 * both 0. */
-    int objRefCount;		/* Number of Tcl objects that reference
-				 * this structure.. */
-    Tcl_HashEntry *idHashPtr;	/* Entry in idTable for this structure
-    struct TkCursor *nextPtr;	/* Points to the next TkCursor structure with
-				 * the same name.  Cursors with the same
-				 * name but different displays are chained
-				 * together off a single hash table entry. */
-} TkCursor;
- * containing a window managed by Tk.  In part, the structure is
- * used to store thread-specific data, since each thread will have
- * its own TkDisplay structure.
-				 * display. */
-     * Information used primarily by tk3d.c:
-    int borderInit;             /* 0 means borderTable needs initializing. */
-    Tcl_HashTable borderTable;  /* Maps from color name to TkBorder
-				 * structure. */
-				 * below. */
-				 * may be NULL. */
-     * Information used by tkBitmap.c only:
-    int bitmapInit;             /* 0 means tables above need initializing. */
-    int bitmapAutoNumber;       /* Used to number bitmaps. */
-    Tcl_HashTable bitmapNameTable;
-                                /* Maps from name of bitmap to the first
-				 * TkBitmap record for that name. */
-    Tcl_HashTable bitmapIdTable;/* Maps from bitmap id to the TkBitmap
-				 * structure for the bitmap. */
-    Tcl_HashTable bitmapDataTable;
-                                /* Used by Tk_GetBitmapFromData to map from
-				 * a collection of in-core data about a
-				 * bitmap to a reference giving an auto-
-				 * matically-generated name for the bitmap. */
-     * Information used by tkCanvas.c only:
-    int numIdSearches;
-    int numSlowSearches;
-    int colorInit;              /* 0 means color module needs initializing. */
-    Tcl_HashTable colorNameTable;
-                                /* Maps from color name to TkColor structure
-				 * for that color. */
-    Tcl_HashTable colorValueTable;
-                                /* Maps from integer RGB values to TkColor
-				 * structures. */
-     * Used by tkCursor.c only:
-    int cursorInit;             /* 0 means cursor module need initializing. */
-    Tcl_HashTable cursorNameTable;
-                                /* Maps from a string name to a cursor to the
-				 * TkCursor record for the cursor. */
-    Tcl_HashTable cursorDataTable;
-                                /* Maps from a collection of in-core data
-				 * about a cursor to a TkCursor structure. */
-    Tcl_HashTable cursorIdTable;
-                                /* Maps from a cursor id to the TkCursor
-				 * structure for the cursor. */
-    char cursorString[20];      /* Used to store a cursor id string. */
-				 * event. */
-    int focusDebug;             /* 1 means collect focus debugging
-				 * statistics. */
-				 * NULL. */
-     * Information used by tkGC.c only:
-    Tcl_HashTable gcValueTable; /* Maps from a GC's values to a TkGC structure
-				 * describing a GC with those values. */
-    Tcl_HashTable gcIdTable;    /* Maps from a GC to a TkGC. */
-    int gcInit;                 /* 0 means the tables below need
-				 * initializing. */
-     * Information used by tkGeometry.c only:
-    Tcl_HashTable maintainHashTable;
-                                /* Hash table that maps from a master's
-				 * Tk_Window token to a list of slaves
-				 * managed by that master. */
-    int geomInit;
-     * Information used by tkGet.c only:
-    Tcl_HashTable uidTable;     /* Stores all Tk_Uid  used in a thread. */
-    int uidInit;                /* 0 means uidTable needs initializing. */
-				 * events. */
-				 * in tkGrab.c. */
-     * Information used by tkGrid.c only:
-    int gridInit;               /* 0 means table below needs initializing. */
-    Tcl_HashTable gridHashTable;/* Maps from Tk_Window tokens to
-				 * corresponding Grid structures. */
-     * Information used by tkImage.c only:
-    int imageId;                /* Value used to number image ids. */
-     * Information used by tkMacWinMenu.c only:
-    int postCommandGeneration;
-     * Information used by tkOption.c only.
-     * Information used by tkPack.c only.
-    int packInit;              /* 0 means table below needs initializing. */
-    Tcl_HashTable packerHashTable;
-                               /* Maps from Tk_Window tokens to
-				* corresponding Packer structures. */
-     * Information used by tkPlace.c only.
-    int placeInit;              /* 0 means tables below need initializing. */
-    Tcl_HashTable masterTable;  /* Maps from Tk_Window toke to the Master
-				 * structure for the window, if it exists. */
-    Tcl_HashTable slaveTable;   /* Maps from Tk_Window toke to the Slave
-				 * initialized. */
-				 * target. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-     * Information used by tkUnixWm.c and tkWinWm.c only:
-    int wmTracing;              /* Used to enable or disable tracing in
-				 * this module.  If tracing is enabled,
-				 * then information is printed on
-				 * standard output about interesting
-				 * interactions with the window manager. */
-    struct TkWmInfo *firstWmPtr;  /* Points to first top-level window. */
-    struct TkWmInfo *foregroundWmPtr;
-                                /* Points to the foreground window. */
-				 * in progress. */
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
- * window (created by a call to TkCreateMainWindow).  It stores
-				 * deleted). */
-				 * application basis. */
-				/* Information used by tkFont.c on a per
-} TkMainInfo;
-typedef struct {
-} TkPredefBitmap;
-				 * for window. */
-				 * children. */
-				 * deleted. */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-} TkWindow;
-} TkStateMap;
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
- * its container.
-#include "tkIntDecls8.1.1.h"
-#ifdef BUILD_tk
-#endif
-EXTERN int		Tk_AfterCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_BellObjCmd _ANSI_ARGS_((ClientData clientData,
-			    Tcl_Interp *interp, int objc,
-			    Tcl_Obj *CONST objv[]));
-EXTERN int		Tk_BindCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_BindtagsCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ButtonObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_CanvasCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_CheckbuttonObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ClipboardCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int              Tk_ChooseColorObjCmd _ANSI_ARGS_((
-			    ClientData clientData, Tcl_Interp *interp,
-			    int objc, Tcl_Obj *CONST objv[]));
-EXTERN int              Tk_ChooseDirectoryObjCmd _ANSI_ARGS_((
-EXTERN int              Tk_ChooseFontObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_DestroyCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_EntryObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_EventObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_FileeventCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_FrameCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_FocusObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_FontObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int              Tk_GetOpenFileObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int              Tk_GetSaveFileObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_GrabCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_GridCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ImageCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_LabelObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ListboxCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_LowerCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_MenubuttonObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int              Tk_MessageBoxObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_MessageCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_OptionCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_PackCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_PlaceCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_RadiobuttonObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_RaiseCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ScaleObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ScrollbarCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_SelectionCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_SendObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_TextCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_TkObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_TkwaitCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ToplevelCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_UpdateObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_WinfoObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_WmCmd _ANSI_ARGS_((ClientData clientData,
-void	TkConsolePrint _ANSI_ARGS_((Tcl_Interp *interp,
-EXTERN void		TkEventInit _ANSI_ARGS_((void));
-EXTERN int		TkCreateMenuCmd _ANSI_ARGS_((Tcl_Interp *interp));
Deleted: grass/trunk/visualization/nviz/src/tkInt8.2.3.h
--- grass/trunk/visualization/nviz/src/tkInt8.2.3.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt8.2.3.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1009 +0,0 @@
- * tkInt.h --
- * RCS: $Id$
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#endif
-	KeySym keySym));
- * behavior.
-                                   created. */
-} TkClassProcs;
-				 * both 0. */
-} TkCursor;
-				 * display. */
-				 * structure. */
-				 * below. */
-				 * may be NULL. */
-				 * structures. */
-				 * event. */
-				 * statistics. */
-				 * NULL. */
-    int geomInit;
-				 * events. */
-				 * in tkGrab.c. */
-				 * initialized. */
-				 * target. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-				 * in progress. */
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-} TkMainInfo;
-typedef struct {
-} TkPredefBitmap;
-				 * for window. */
-				 * children. */
-				 * deleted. */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-} TkWindow;
-} TkStateMap;
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
- * its container.
-#include "tkIntDecls8.2.3.h"
-#ifdef BUILD_tk
-#endif
Deleted: grass/trunk/visualization/nviz/src/tkInt8.3.3.h
--- grass/trunk/visualization/nviz/src/tkInt8.3.3.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt8.3.3.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1097 +0,0 @@
- * tkInt.h --
- *	Declarations for things used internally by the Tk
- *	procedures but not exported outside the module.
- * Copyright (c) 1990-1994 The Regents of the University of California.
- * Copyright (c) 1994-1997 Sun Microsystems, Inc.
- * Copyright (c) 1998 by Scriptics Corporation.
- * See the file "license.terms" for information on usage and redistribution
- * of this file, and for a DISCLAIMER OF ALL WARRANTIES.
- * RCS: $Id$
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#endif
- * Opaque type declarations:
-typedef struct TkColormap TkColormap;
-typedef struct TkGrabEvent TkGrabEvent;
-	KeySym keySym));
- * behavior.
-                                   created. */
-} TkClassProcs;
-				 * both 0. */
-} TkCursor;
-				 * display. */
-				 * structure. */
-				 * below. */
-				 * may be NULL. */
-				 * structures. */
-				 * event. */
-				 * statistics. */
-				 * NULL. */
-    int geomInit;
-				 * events. */
-				 * in tkGrab.c. */
-				 * initialized. */
-				 * target. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-				 * in progress. */
-     * The following field were all added for Tk8.3
-    int mouseButtonState;	/* current mouse button state for this
-				 * display */
-    int warpInProgress;
-    Window warpWindow;
-    int warpX;
-    int warpY;
-    int useInputMethods;	/* Whether to use input methods */
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-} TkMainInfo;
-typedef struct {
-} TkPredefBitmap;
-				 * for window. */
-				 * children. */
-				 * deleted. */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-} TkWindow;
-} TkStateMap;
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
- * its container.
- * The following special modifier mask bits are defined, to indicate
- * logical modifiers such as Meta and Alt that may float among the
- * actual modifier bits.
-#define META_MASK	(AnyModifier<<1)
-#define ALT_MASK	(AnyModifier<<2)
-extern Tk_SmoothMethod		tkBezierSmoothMethod;
-#include "tkIntDecls8.3.3.h"
-#ifdef BUILD_tk
-# undef TCL_STORAGE_CLASS
-# define TCL_STORAGE_CLASS DLLEXPORT
-#endif
-EXTERN int		Tk_CanvasObjCmd _ANSI_ARGS_((ClientData clientData,
-			    Tcl_Interp *interp, int argc, Tcl_Obj *CONST objv[]));
-EXTERN int		Tk_DestroyObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_FrameObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ImageObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ListboxObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_LowerObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_OptionObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_RaiseObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_ToplevelObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		TkCanvasGetCoordObj _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Canvas canvas, Tcl_Obj *obj,
-			    double *doublePtr));
-EXTERN int		TkCanvasDashParseProc _ANSI_ARGS_((
-			    Tk_Window tkwin, CONST char *value, char *widgRec,
-			    int offset));
-EXTERN char *		TkCanvasDashPrintProc _ANSI_ARGS_((
-			    ClientData clientData, Tk_Window tkwin,
-			    char *widgRec, int offset,
-			    Tcl_FreeProc **freeProcPtr));
-EXTERN int		TkGetDoublePixels _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Window tkwin, CONST char *string,
-EXTERN int		TkOffsetParseProc _ANSI_ARGS_((
-			    int offset));
-EXTERN char *		TkOffsetPrintProc _ANSI_ARGS_((
-EXTERN int		TkOrientParseProc _ANSI_ARGS_((
-			    char *widgRec, int offset));
-EXTERN char *		TkOrientPrintProc _ANSI_ARGS_((
-EXTERN int		TkPixelParseProc _ANSI_ARGS_((
-			    int offset));
-EXTERN char *		TkPixelPrintProc _ANSI_ARGS_((
-EXTERN int		TkPostscriptImage _ANSI_ARGS_((Tcl_Interp *interp,
-			    Tk_Window tkwin, Tk_PostscriptInfo psInfo,
-			    XImage *ximage, int x, int y, int width,
-			    int height));
-EXTERN int		TkSmoothParseProc _ANSI_ARGS_((ClientData clientData,
-			    Tcl_Interp *interp, Tk_Window tkwin,
-			    CONST char *value, char *recordPtr, int offset));
-EXTERN char *		TkSmoothPrintProc _ANSI_ARGS_((ClientData clientData,
-			    Tk_Window tkwin, char *recordPtr, int offset,
-EXTERN int		TkStateParseProc _ANSI_ARGS_((
-EXTERN char *		TkStatePrintProc _ANSI_ARGS_((
-EXTERN int		TkTileParseProc _ANSI_ARGS_((
-			    int offset));
-EXTERN char *		TkTilePrintProc _ANSI_ARGS_((
Deleted: grass/trunk/visualization/nviz/src/tkInt8.3.h
--- grass/trunk/visualization/nviz/src/tkInt8.3.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt8.3.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1097 +0,0 @@
- * tkInt.h --
- * RCS: $Id$
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#include "tkPort.h"
-#endif
-typedef struct TkpCursor_ *TkpCursor;
-typedef struct TkRegion_ *TkRegion;
-typedef struct TkStressedCmap TkStressedCmap;
-typedef struct TkBindInfo_ *TkBindInfo;
- * Procedure types.
-typedef int (TkBindEvalProc) _ANSI_ARGS_((ClientData clientData,
-	Tcl_Interp *interp, XEvent *eventPtr, Tk_Window tkwin,
-	KeySym keySym));
-typedef void (TkBindFreeProc) _ANSI_ARGS_((ClientData clientData));
-typedef Window (TkClassCreateProc) _ANSI_ARGS_((Tk_Window tkwin,
-	Window parent, ClientData instanceData));
-typedef void (TkClassGeometryProc) _ANSI_ARGS_((ClientData instanceData));
-typedef void (TkClassModalProc) _ANSI_ARGS_((Tk_Window tkwin,
-	XEvent *eventPtr));
- * Widget class procedures used to implement platform specific widget
- * behavior.
-typedef struct TkClassProcs {
-    TkClassCreateProc *createProc;
-				/* Procedure to invoke when the
-                                   platform-dependent window needs to be
-                                   created. */
-    TkClassGeometryProc *geometryProc;
-				/* Procedure to invoke when the geometry of a
-				   window needs to be recalculated as a result
-				   of some change in the system. */
-    TkClassModalProc *modalProc;
-				/* Procedure to invoke after all bindings on a
-				   widget have been triggered in order to
-				   handle a modal loop. */
-} TkClassProcs;
- * One of the following structures is maintained for each cursor in
- * use in the system.  This structure is used by tkCursor.c and the
- * various system specific cursor files.
-typedef struct TkCursor {
-    Tk_Cursor cursor;		/* System specific identifier for cursor. */
-				 * both 0. */
-    Tcl_HashTable *otherTable;	/* Second table (other than idTable) used
-				 * to index this entry. */
-    Tcl_HashEntry *hashPtr;	/* Entry in otherTable for this structure
-				 * (needed when deleting). */
-} TkCursor;
- * One of the following structures is maintained for each display
-typedef struct TkDisplay {
-    Display *display;		/* Xlib's info about display. */
-    struct TkDisplay *nextPtr;	/* Next in list of all displays. */
-    char *name;			/* Name of display (with any screen
-				 * identifier removed).  Malloc-ed. */
-    Time lastEventTime;		/* Time of last event received for this
-				 * display. */
-				 * structure. */
-     * Information used by tkAtom.c only:
-    int atomInit;		/* 0 means stuff below hasn't been
-				 * initialized yet. */
-    Tcl_HashTable nameTable;	/* Maps from names to Atom's. */
-    Tcl_HashTable atomTable;	/* Maps from Atom's back to names. */
-     * Information used primarily by tkBind.c:
-    int bindInfoStale;		/* Non-zero means the variables in this
-				 * part of the structure are potentially
-				 * incorrect and should be recomputed. */
-    unsigned int modeModMask;	/* Has one bit set to indicate the modifier
-				 * corresponding to "mode shift".  If no
-				 * such modifier, than this is zero. */
-    unsigned int metaModMask;	/* Has one bit set to indicate the modifier
-				 * corresponding to the "Meta" key.  If no
-				 * such modifier, then this is zero. */
-    unsigned int altModMask;	/* Has one bit set to indicate the modifier
-    enum {LU_IGNORE, LU_CAPS, LU_SHIFT} lockUsage;
-				/* Indicates how to interpret lock modifier. */
-    int numModKeyCodes;		/* Number of entries in modKeyCodes array
-				 * below. */
-    KeyCode *modKeyCodes;	/* Pointer to an array giving keycodes for
-				 * all of the keys that have modifiers
-				 * associated with them.  Malloc'ed, but
-				 * may be NULL. */
-				 * structures. */
-    Font cursorFont;		/* Font to use for standard cursors.
-				 * None means font not loaded yet. */
-     * Information used by tkError.c only:
-    struct TkErrorHandler *errorPtr;
-				/* First in list of error handlers
-				 * for this display.  NULL means
-				 * no handlers exist at present. */
-    int deleteCount;		/* Counts # of handlers deleted since
-				 * last time inactive handlers were
-				 * garbage-collected.  When this number
-				 * gets big, handlers get cleaned up. */
-				 * event. */
-				 * statistics. */
-				 * NULL. */
-    int geomInit;
-     * Information used by tkGrab.c only:
-    struct TkWindow *grabWinPtr;
-				/* Window in which the pointer is currently
-				 * grabbed, or NULL if none. */
-    struct TkWindow *eventualGrabWinPtr;
-				/* Value that grabWinPtr will have once the
-				 * grab event queue (below) has been
-				 * completely emptied. */
-    struct TkWindow *buttonWinPtr;
-				/* Window in which first mouse button was
-				 * pressed while grab was in effect, or NULL
-				 * if no such press in effect. */
-    struct TkWindow *serverWinPtr;
-				/* If no application contains the pointer then
-				 * this is NULL.  Otherwise it contains the
-				 * last window for which we've gotten an
-				 * Enter or Leave event from the server (i.e.
-				 * the last window known to have contained
-				 * the pointer).  Doesn't reflect events
-				 * that were synthesized in tkGrab.c. */
-    TkGrabEvent *firstGrabEventPtr;
-				/* First in list of enter/leave events
-				 * synthesized by grab code.  These events
-				 * must be processed in order before any other
-				 * events are processed.  NULL means no such
-				 * events. */
-    TkGrabEvent *lastGrabEventPtr;
-				/* Last in list of synthesized events, or NULL
-				 * if list is empty. */
-    int grabFlags;		/* Miscellaneous flag values.  See definitions
-				 * in tkGrab.c. */
-     * Information used by tkSelect.c and tkClipboard.c only:
-    struct TkSelectionInfo *selectionInfoPtr;
-				/* First in list of selection information
-				 * records.  Each entry contains information
-				 * about the current owner of a particular
-				 * selection on this display. */
-    Atom multipleAtom;		/* Atom for MULTIPLE.  None means
-				 * selection stuff isn't initialized. */
-    Atom incrAtom;		/* Atom for INCR. */
-    Atom targetsAtom;		/* Atom for TARGETS. */
-    Atom timestampAtom;		/* Atom for TIMESTAMP. */
-    Atom textAtom;		/* Atom for TEXT. */
-    Atom compoundTextAtom;	/* Atom for COMPOUND_TEXT. */
-    Atom applicationAtom;	/* Atom for TK_APPLICATION. */
-    Atom windowAtom;		/* Atom for TK_WINDOW. */
-    Atom clipboardAtom;		/* Atom for CLIPBOARD. */
-    Tk_Window clipWindow;	/* Window used for clipboard ownership and to
-				 * retrieve selections between processes. NULL
-				 * means clipboard info hasn't been
-				 * initialized. */
-    int clipboardActive;	/* 1 means we currently own the clipboard
-				 * selection, 0 means we don't. */
-    struct TkMainInfo *clipboardAppPtr;
-				/* Last application that owned clipboard. */
-    struct TkClipboardTarget *clipTargetPtr;
-				/* First in list of clipboard type information
-				 * about the buffers for a given selection
-				 * target. */
-     * Information used by tkSend.c only:
-    Tk_Window commTkwin;	/* Window used for communication
-				 * between interpreters during "send"
-				 * commands.  NULL means send info hasn't
-				 * been initialized yet. */
-    Atom commProperty;		/* X's name for comm property. */
-    Atom registryProperty;	/* X's name for property containing
-				 * registry of interpreter names. */
-    Atom appNameProperty;	/* X's name for property used to hold the
-				 * application name on each comm window. */
-     * Information used by tkXId.c only:
-    struct TkIdStack *idStackPtr;
-				/* First in list of chunks of free resource
-				 * identifiers, or NULL if there are no free
-				 * resources. */
-    XID (*defaultAllocProc) _ANSI_ARGS_((Display *display));
-				/* Default resource allocator for display. */
-    struct TkIdStack *windowStackPtr;
-				/* First in list of chunks of window
-				 * identifers that can't be reused right
-				 * now. */
-    int idCleanupScheduled;	/* 1 means a call to WindowIdCleanup has
-				 * already been scheduled, 0 means it
-				 * hasn't. */
-     * Information maintained by tkWindow.c for use later on by tkXId.c:
-    int destroyCount;		/* Number of Tk_DestroyWindow operations
-				 * in progress. */
-    unsigned long lastDestroyRequest;
-				/* Id of most recent XDestroyWindow request;
-				 * can re-use ids in windowStackPtr when
-				 * server has seen this request and event
-				 * queue is empty. */
-     * Information used by tkVisual.c only:
-    TkColormap *cmapPtr;	/* First in list of all non-default colormaps
-				 * allocated for this display. */
-     * Miscellaneous information:
-#ifdef TK_USE_INPUT_METHODS
-    XIM inputMethod;		/* Input method for this display */
-#endif /* TK_USE_INPUT_METHODS */
-    Tcl_HashTable winTable;	/* Maps from X window ids to TkWindow ptrs. */
-    int refCount;		/* Reference count of how many Tk applications
-                                 * are using this display. Used to clean up
-                                 * the display when we no longer have any
-                                 * Tk applications using it.
-				 * display */
-    int warpX;
-    int warpY;
-} TkDisplay;
- * One of the following structures exists for each error handler
- * created by a call to Tk_CreateErrorHandler.  The structure
- * is managed by tkError.c.
-typedef struct TkErrorHandler {
-    TkDisplay *dispPtr;		/* Display to which handler applies. */
-    unsigned long firstRequest;	/* Only errors with serial numbers
-				 * >= to this are considered. */
-    unsigned long lastRequest;	/* Only errors with serial numbers
-				 * <= to this are considered.  This
-				 * field is filled in when XUnhandle
-				 * is called.  -1 means XUnhandle
-				 * hasn't been called yet. */
-    int error;			/* Consider only errors with this
-				 * error_code (-1 means consider
-				 * all errors). */
-    int request;		/* Consider only errors with this
-				 * major request code (-1 means
-				 * consider all major codes). */
-    int minorCode;		/* Consider only errors with this
-				 * minor request code (-1 means
-				 * consider all minor codes). */
-    Tk_ErrorProc *errorProc;	/* Procedure to invoke when a matching
-				 * error occurs.  NULL means just ignore
-				 * errors. */
-    ClientData clientData;	/* Arbitrary value to pass to
-				 * errorProc. */
-    struct TkErrorHandler *nextPtr;
-				/* Pointer to next older handler for
-				 * this display, or NULL for end of
-				 * list. */
-} TkErrorHandler;
- * One of the following structures exists for each event handler
- * created by calling Tk_CreateEventHandler.  This information
- * is used by tkEvent.c only.
-typedef struct TkEventHandler {
-    unsigned long mask;		/* Events for which to invoke
-				 * proc. */
-    Tk_EventProc *proc;		/* Procedure to invoke when an event
-				 * in mask occurs. */
-    ClientData clientData;	/* Argument to pass to proc. */
-    struct TkEventHandler *nextPtr;
-				/* Next in list of handlers
-				 * associated with window (NULL means
-				 * end of list). */
-} TkEventHandler;
- * Tk keeps one of the following data structures for each main
- * information that is shared by all of the windows associated
- * with a particular main window.
-typedef struct TkMainInfo {
-    int refCount;		/* Number of windows whose "mainPtr" fields
-				 * point here.  When this becomes zero, can
-				 * free up the structure (the reference
-				 * count is zero because windows can get
-				 * deleted in almost any order;  the main
-				 * window isn't necessarily the last one
-				 * deleted). */
-    struct TkWindow *winPtr;	/* Pointer to main window. */
-    Tcl_Interp *interp;		/* Interpreter associated with application. */
-    Tcl_HashTable nameTable;	/* Hash table mapping path names to TkWindow
-				 * structs for all windows related to this
-				 * main window.  Managed by tkWindow.c. */
-    Tk_BindingTable bindingTable;
-				/* Used in conjunction with "bind" command
-				 * to bind events to Tcl commands. */
-    TkBindInfo bindInfo;	/* Information used by tkBind.c on a per
-    struct TkFontInfo *fontInfoPtr;
-     * Information used only by tkFocus.c and tk*Embed.c:
-    struct TkToplevelFocusInfo *tlFocusPtr;
-				/* First in list of records containing focus
-				 * information for each top-level in the
-				 * application.  Used only by tkFocus.c. */
-    struct TkDisplayFocusInfo *displayFocusPtr;
-				 * information for each display that this
-				 * application has ever used.  Used only
-				 * by tkFocus.c. */
-    struct ElArray *optionRootPtr;
-				/* Top level of option hierarchy for this
-				 * main window.  NULL means uninitialized.
-				 * Managed by tkOption.c. */
-    Tcl_HashTable imageTable;	/* Maps from image names to Tk_ImageMaster
-				 * structures.  Managed by tkImage.c. */
-    int strictMotif;		/* This is linked to the tk_strictMotif
-				 * global variable. */
-    struct TkMainInfo *nextPtr;	/* Next in list of all main windows managed by
-				 * this process. */
-} TkMainInfo;
- * Tk keeps the following data structure for each of it's builtin
- * bitmaps.  This structure is only used by tkBitmap.c and other
- * platform specific bitmap files.
-typedef struct {
-    char *source;		/* Bits for bitmap. */
-    int width, height;		/* Dimensions of bitmap. */
-    int native;			/* 0 means generic (X style) bitmap,
-    				 * 1 means native style bitmap. */
-} TkPredefBitmap;
- * Tk keeps one of the following structures for each window.
- * Some of the information (like size and location) is a shadow
- * of information managed by the X server, and some is special
- * information used here, such as event and geometry management
- * information.  This information is (mostly) managed by tkWindow.c.
- * WARNING: the declaration below must be kept consistent with the
- * Tk_FakeWin structure in tk.h.  If you change one, be sure to
- * change the other!!
-typedef struct TkWindow {
-     * Structural information:
-    Display *display;		/* Display containing window. */
-    TkDisplay *dispPtr;		/* Tk's information about display
-				 * for window. */
-    int screenNum;		/* Index of screen for window, among all
-				 * those for dispPtr. */
-    Visual *visual;		/* Visual to use for window.  If not default,
-				 * MUST be set before X window is created. */
-    int depth;			/* Number of bits/pixel. */
-    Window window;		/* X's id for window.   NULL means window
-				 * hasn't actually been created yet, or it's
-				 * been deleted. */
-    struct TkWindow *childList;	/* First in list of child windows,
-				 * or NULL if no children.  List is in
-				 * stacking order, lowest window first.*/
-    struct TkWindow *lastChildPtr;
-				/* Last in list of child windows (highest
-				 * in stacking order), or NULL if no
-				 * children. */
-    struct TkWindow *parentPtr;	/* Pointer to parent window (logical
-				 * parent, not necessarily X parent).  NULL
-				 * means either this is the main window, or
-				 * the window's parent has already been
-				 * deleted. */
-    struct TkWindow *nextPtr;	/* Next higher sibling (in stacking order)
-				 * in list of children with same parent.  NULL
-				 * means end of list. */
-    TkMainInfo *mainPtr;	/* Information shared by all windows
-				 * associated with a particular main
-				 * window.  NULL means this window is
-				 * a rogue that isn't associated with
-				 * any application (at present, this
-				 * only happens for the dummy windows
-				 * used for "send" communication).  */
-     * Name and type information for the window:
-    char *pathName;		/* Path name of window (concatenation
-				 * of all names between this window and
-				 * its top-level ancestor).  This is a
-				 * pointer into an entry in
-				 * mainPtr->nameTable.  NULL means that
-				 * the window hasn't been completely
-				 * created yet. */
-    Tk_Uid nameUid;		/* Name of the window within its parent
-				 * (unique within the parent). */
-    Tk_Uid classUid;		/* Class of the window.  NULL means window
-				 * hasn't been given a class yet. */
-     * Geometry and other attributes of window.  This information
-     * may not be updated on the server immediately;  stuff that
-     * hasn't been reflected in the server yet is called "dirty".
-     * At present, information can be dirty only if the window
-     * hasn't yet been created.
-    XWindowChanges changes;	/* Geometry and other info about
-				 * window. */
-    unsigned int dirtyChanges;	/* Bits indicate fields of "changes"
-				 * that are dirty. */
-    XSetWindowAttributes atts;	/* Current attributes of window. */
-    unsigned long dirtyAtts;	/* Bits indicate fields of "atts"
-    unsigned int flags;		/* Various flag values:  these are all
-				 * defined in tk.h (confusing, but they're
-				 * needed there for some query macros). */
-     * Information kept by the event manager (tkEvent.c):
-    TkEventHandler *handlerList;/* First in list of event handlers
-				 * declared for this window, or
-				 * NULL if none. */
-    XIC inputContext;		/* Input context (for input methods). */
-     * Information used for event bindings (see "bind" and "bindtags"
-     * commands in tkCmds.c):
-    ClientData *tagPtr;		/* Points to array of tags used for bindings
-				 * on this window.  Each tag is a Tk_Uid.
-				 * Malloc'ed.  NULL means no tags. */
-    int numTags;		/* Number of tags at *tagPtr. */
-     * Information used by tkOption.c to manage options for the
-     * window.
-    int optionLevel;		/* -1 means no option information is
-				 * currently cached for this window.
-				 * Otherwise this gives the level in
-				 * the option stack at which info is
-				 * cached. */
-     * Information used by tkSelect.c to manage the selection.
-    struct TkSelHandler *selHandlerList;
-				/* First in list of handlers for
-				 * returning the selection in various
-				 * forms. */
-     * Information used by tkGeometry.c for geometry management.
-    Tk_GeomMgr *geomMgrPtr;	/* Information about geometry manager for
-				 * this window. */
-    ClientData geomData;	/* Argument for geometry manager procedures. */
-    int reqWidth, reqHeight;	/* Arguments from last call to
-				 * Tk_GeometryRequest, or 0's if
-				 * Tk_GeometryRequest hasn't been
-				 * called. */
-    int internalBorderWidth;	/* Width of internal border of window
-				 * (0 means no internal border).  Geometry
-				 * managers should not normally place children
-				 * on top of the border. */
-     * Information maintained by tkWm.c for window manager communication.
-    struct TkWmInfo *wmInfoPtr;	/* For top-level windows (and also
-				 * for special Unix menubar and wrapper
-				 * windows), points to structure with
-				 * wm-related info (see tkWm.c).  For
-				 * other windows, this is NULL. */
-     * Information used by widget classes.
-    TkClassProcs *classProcsPtr;
-    ClientData instanceData;
-     * Platform specific information private to each port.
-    struct TkWindowPrivate *privatePtr;
-} TkWindow;
- * The following structure is used as a two way map between integers
- * and strings, usually to map between an internal C representation
- * and the strings used in Tcl.
-typedef struct TkStateMap {
-    int numKey;			/* Integer representation of a value. */
-    char *strKey;		/* String representation of a value. */
-} TkStateMap;
- * This structure is used by the Mac and Window porting layers as
- * the internal representation of a clip_mask in a GC.
-typedef struct TkpClipMask {
-    int type;			/* One of TKP_CLIP_PIXMAP or TKP_CLIP_REGION */
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
-#define TKP_CLIP_PIXMAP 0
-#define TKP_CLIP_REGION 1
- * Pointer to first entry in list of all displays currently known.
-extern TkDisplay *tkDisplayList;
- * Return values from TkGrabState:
-#define TK_GRAB_NONE		0
-#define TK_GRAB_IN_TREE		1
-#define TK_GRAB_ANCESTOR	2
-#define TK_GRAB_EXCLUDED	3
- * The macro below is used to modify a "char" value (e.g. by casting
- * it to an unsigned character) so that it can be used safely with
- * macros such as isspace.
-#define UCHAR(c) ((unsigned char) (c))
- * The following symbol is used in the mode field of FocusIn events
- * generated by an embedded application to request the input focus from
- * its container.
-#define EMBEDDED_APP_WANTS_FOCUS (NotifyNormal + 20)
- * Miscellaneous variables shared among Tk modules but not exported
- * to the outside world:
-extern Tk_ImageType		tkBitmapImageType;
-extern Tk_PhotoImageFormat	tkImgFmtGIF;
-extern void			(*tkHandleEventProc) _ANSI_ARGS_((
-    				    XEvent* eventPtr));
-extern Tk_PhotoImageFormat	tkImgFmtPPM;
-extern TkMainInfo		*tkMainWindowList;
-extern Tk_ImageType		tkPhotoImageType;
-extern Tcl_HashTable		tkPredefBitmapTable;
-extern int			tkSendSerial;
-#include "tkIntDecls8.3.h"
-#ifdef BUILD_tk
-#endif
- * Internal procedures shared among Tk modules but not exported
-			    Tcl_Interp *interp, int argc, char **argv));
-EXTERN int		TkDeadAppCmd _ANSI_ARGS_((ClientData clientData,
-			    int offset));
-			    int offset));
-			    int offset));
-			    int height));
-			    int offset));
Deleted: grass/trunk/visualization/nviz/src/tkInt8.4.9.h
--- grass/trunk/visualization/nviz/src/tkInt8.4.9.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt8.4.9.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1184 +0,0 @@
- * tkInt.h --
- * RCS: $Id$
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#endif
-	KeySym keySym));
-				 * both 0. */
-} TkCursor;
- * This defines whether we should try to use XIM over-the-spot style
- * input.  Allow users to override it.  It is a much more elegant use
- * of XIM, but uses a bit more memory.
-#ifndef TK_XIM_SPOT
-#   define TK_XIM_SPOT	1
-#endif
- * The following structure is kept one-per-TkDisplay to maintain information
- * about the caret (cursor location) on this display.  This is used to
- * dictate global focus location (Windows Accessibility guidelines) and to
- * position the IME or XIM over-the-spot window.
-typedef struct TkCaret {
-    struct TkWindow *winPtr;	/* the window on which we requested caret
-				 * placement */
-    int x;			/* relative x coord of the caret */
-    int y;			/* relative y coord of the caret */
-    int height;			/* specified height of the window */
-} TkCaret;
-				 * display. */
-				 * structure. */
-				 * below. */
-				 * may be NULL. */
-     * Used by tkColor.c only:
-    TkStressedCmap *stressPtr;	/* First in list of colormaps that have
-				 * filled up, so we have to pick an
-				 * approximate color. */
-				 * structures. */
-     * Used by tkEvent.c only:
-    struct TkWindowEvent *delayedMotionPtr;
-				/* Points to a malloc-ed motion event
-				 * whose processing has been delayed in
-				 * the hopes that another motion event
-				 * will come along right away and we can
-				 * merge the two of them together.  NULL
-				 * means that there is no delayed motion
-				 * event. */
-     * Information used by tkFocus.c only:
-				 * statistics. */
-    struct TkWindow *implicitWinPtr;
-				/* If the focus arrived at a toplevel window
-				 * implicitly via an Enter event (rather
-				 * than via a FocusIn event), this points
-				 * to the toplevel window.  Otherwise it is
-				 * NULL. */
-    struct TkWindow *focusPtr;	/* Points to the window on this display that
-				 * should be receiving keyboard events.  When
-				 * multiple applications on the display have
-				 * the focus, this will refer to the
-				 * innermost window in the innermost
-				 * application.  This information isn't used
-				 * under Unix or Windows, but it's needed on
-				 * the Macintosh. */
-    int geomInit;
-				 * events. */
-				 * in tkGrab.c. */
-    Atom utf8Atom;		/* Atom for UTF8_STRING. */
-				 * initialized. */
-				 * target. */
-				 * resources. */
-				 * now. */
-    Tcl_TimerToken idCleanupScheduled;
-				/* If set, it means a call to WindowIdCleanup
-				 * has already been scheduled, 0 means it
-				 * hasn't. */
-				 * in progress. */
-#if TK_XIM_SPOT
-    XFontSet inputXfs;		/* XFontSet cached for over-the-spot XIM. */
-#endif
-				 * display */
-    Window mouseButtonWindow;	/* Window the button state was set in,
-				 * added in Tk 8.4. */
-    int warpX;
-    int warpY;
-     * The following field(s) were all added for Tk8.4
-				 * defined in below. */
-    TkCaret caret;		/* information about the caret for this
-				 * display.  This is not a pointer. */
-    int iconDataSize;		/* size of default iconphoto image data */
-    unsigned char *iconDataPtr;	/* default iconphoto image data, if set */
-} TkDisplay;
- * Flag values for TkDisplay flags.
- *  TK_DISPLAY_COLLAPSE_MOTION_EVENTS:	(default on)
- *	Indicates that we should collapse motion events on this display
- *  TK_DISPLAY_USE_IM:			(default on, set via tk.tcl)
- *	Whether to use input methods for this display
- *  TK_DISPLAY_XIM_SPOT:		(default off)
- *	Indicates that we should use over-the-spot XIM on this display
- *  TK_DISPLAY_WM_TRACING:		(default off)
- *	Whether we should do wm tracing on this display.
- *  TK_DISPLAY_IN_WARP:			(default off)
- *	Indicates that we are in a pointer warp
-#define TK_DISPLAY_COLLAPSE_MOTION_EVENTS	(1 << 0)
-#define TK_DISPLAY_USE_IM			(1 << 1)
-#define TK_DISPLAY_XIM_SPOT			(1 << 2)
-#define TK_DISPLAY_WM_TRACING			(1 << 3)
-#define TK_DISPLAY_IN_WARP			(1 << 4)
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-    long deletionEpoch;		/* Incremented by window deletions */
-} TkMainInfo;
-typedef struct {
-    CONST char *source;		/* Bits for bitmap. */
-} TkPredefBitmap;
-				 * for window. */
-				 * children. */
-				 * deleted. */
-				 * created yet. */
-				 * window. */
-    XIC inputContext;		/* XIM input context. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-    int internalBorderLeft;	/* Width of internal border of window
-				 * Fields for the other three sides are found
-				 * below. */
-    Tk_ClassProcs *classProcsPtr;
-     * More information used by tkGeometry.c for geometry management.
-    /* The remaining fields of internal border. */
-    int internalBorderRight;
-    int internalBorderTop;
-    int internalBorderBottom;
-    int minReqWidth;		/* Minimum requested width. */
-    int minReqHeight;		/* Minimum requested height. */
-} TkWindow;
-} TkStateMap;
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
- * its container.
- * Object types not declared in tkObj.c need to be mentioned here so
- * they can be properly registered with Tcl:
-extern Tcl_ObjType tkBorderObjType;
-extern Tcl_ObjType tkBitmapObjType;
-extern Tcl_ObjType tkColorObjType;
-extern Tcl_ObjType tkCursorObjType;
-extern Tcl_ObjType tkFontObjType;
-extern Tcl_ObjType tkOptionObjType;
-extern Tcl_ObjType tkStateKeyObjType;
-#include "tkIntDecls8.4.9.h"
-#ifdef BUILD_tk
-#endif
-EXTERN int		Tk_BindObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_BindtagsObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int              Tk_ClipboardObjCmd _ANSI_ARGS_((
-EXTERN int		Tk_GrabObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_GridObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_LabelframeObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_MessageObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_PanedWindowObjCmd _ANSI_ARGS_((
-EXTERN int		Tk_PackObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_PlaceObjCmd _ANSI_ARGS_((ClientData clientData,
-			    Tcl_Interp *interp, int argc, CONST char **argv));
-EXTERN int		Tk_SelectionObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_SpinboxObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_TkwaitObjCmd _ANSI_ARGS_((ClientData clientData,
-EXTERN int		Tk_WmObjCmd _ANSI_ARGS_((ClientData clientData,
-			    int devId, CONST char *buffer, long size));
-EXTERN void		TkRegisterObjTypes _ANSI_ARGS_((void));
-EXTERN int		TkpTestembedCmd _ANSI_ARGS_((ClientData clientData,
-			    int offset));
-			    int offset));
-			    int offset));
-			    int height));
-			    int offset));
-EXTERN void		TkCreateExitHandler _ANSI_ARGS_((Tcl_ExitProc *proc,
-			    ClientData clientData));
-EXTERN void		TkDeleteExitHandler _ANSI_ARGS_((Tcl_ExitProc *proc,
-EXTERN Tcl_ExitProc	TkFinalize;
Deleted: grass/trunk/visualization/nviz/src/tkInt8.4.h
--- grass/trunk/visualization/nviz/src/tkInt8.4.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkInt8.4.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1177 +0,0 @@
- * tkInt.h --
- * RCS: $Id$
-#ifndef _TKINT
-#define _TKINT
-#ifndef _TK
-#include "tk.h"
-#endif
-#ifndef _TCL
-#include "tcl.h"
-#endif
-#ifndef _TKPORT
-#endif
-	KeySym keySym));
-				 * both 0. */
-} TkCursor;
-#endif
-				 * placement */
-} TkCaret;
-				 * display. */
-				 * structure. */
-				 * below. */
-				 * may be NULL. */
-				 * structures. */
-				 * event. */
-				 * statistics. */
-				 * NULL. */
-    int geomInit;
-				 * events. */
-				 * in tkGrab.c. */
-				 * initialized. */
-				 * target. */
-				 * resources. */
-				 * now. */
-				 * hasn't. */
-				 * in progress. */
-#if TK_XIM_SPOT
-#endif
-				 * display */
-    int warpX;
-    int warpY;
-} TkDisplay;
-				 * all errors). */
-				 * errors. */
-				 * errorProc. */
-				 * list. */
-} TkErrorHandler;
-				 * proc. */
-} TkEventHandler;
-				 * deleted). */
-} TkMainInfo;
-typedef struct {
-} TkPredefBitmap;
-				 * for window. */
-				 * children. */
-				 * deleted. */
-				 * created yet. */
-				 * window. */
-     * window.
-				 * cached. */
-				 * forms. */
-				 * this window. */
-				 * called. */
-				 * below. */
-} TkWindow;
-} TkStateMap;
-    union {
-	Pixmap pixmap;
-	TkRegion region;
-    } value;
-} TkpClipMask;
- * its container.
-#include "tkIntDecls8.4.h"
-#ifdef BUILD_tk
-#endif
-			    int offset));
-EXTERN CONST Tk_OptionSpec *
-			TkGetOptionSpec _ANSI_ARGS_((CONST char *name,
-			    Tk_OptionTable optionTable));
-			    int offset));
-			    int offset));
-			    int height));
-			    int offset));
Deleted: grass/trunk/visualization/nviz/src/tkIntDecls8.1.1.h
--- grass/trunk/visualization/nviz/src/tkIntDecls8.1.1.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkIntDecls8.1.1.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1183 +0,0 @@
- * tkIntDecls.h --
- *	This file contains the declarations for all unsupported
- *	functions that are exported by the Tk library.  These
- *	interfaces are not guaranteed to remain the same between
- *	versions.  Use at your own risk.
- * Copyright (c) 1998-1999 by Scriptics Corporation.
- * RCS: @(#) $Id$
-#ifndef _TKINTDECLS
-#define _TKINTDECLS
-#ifdef BUILD_tk
-#undef TCL_STORAGE_CLASS
-#define TCL_STORAGE_CLASS DLLEXPORT
-#endif
- * WARNING: This file is automatically generated by the tools/genStubs.tcl
- * script.  Any modifications to the function declarations below should be made
- * in the generic/tkInt.decls script.
-/* !BEGIN!: Do not edit below this line. */
- * Exported function declarations:
-/* 0 */
-EXTERN TkWindow *	TkAllocWindow _ANSI_ARGS_((TkDisplay * dispPtr,
-				int screenNum, TkWindow * parentPtr));
-/* 1 */
-EXTERN void		TkBezierPoints _ANSI_ARGS_((double control[],
-				int numSteps, double * coordPtr));
-/* 2 */
-EXTERN void		TkBezierScreenPoints _ANSI_ARGS_((Tk_Canvas canvas,
-				double control[], int numSteps,
-				XPoint * xPointPtr));
-/* 3 */
-EXTERN void		TkBindDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 4 */
-EXTERN void		TkBindEventProc _ANSI_ARGS_((TkWindow * winPtr,
-				XEvent * eventPtr));
-/* 5 */
-EXTERN void		TkBindFree _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 6 */
-EXTERN void		TkBindInit _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 7 */
-EXTERN void		TkChangeEventWindow _ANSI_ARGS_((XEvent * eventPtr,
-				TkWindow * winPtr));
-/* 8 */
-EXTERN int		TkClipInit _ANSI_ARGS_((Tcl_Interp * interp,
-				TkDisplay * dispPtr));
-/* 9 */
-EXTERN void		TkComputeAnchor _ANSI_ARGS_((Tk_Anchor anchor,
-				Tk_Window tkwin, int padX, int padY,
-				int innerWidth, int innerHeight, int * xPtr,
-				int * yPtr));
-/* 10 */
-EXTERN int		TkCopyAndGlobalEval _ANSI_ARGS_((Tcl_Interp * interp,
-				char * script));
-/* 11 */
-EXTERN unsigned long	TkCreateBindingProcedure _ANSI_ARGS_((
-				Tcl_Interp * interp,
-				Tk_BindingTable bindingTable,
-				ClientData object, char * eventString,
-				TkBindEvalProc * evalProc,
-				TkBindFreeProc * freeProc,
-/* 12 */
-EXTERN TkCursor *	TkCreateCursorFromData _ANSI_ARGS_((Tk_Window tkwin,
-				char * source, char * mask, int width,
-				int height, int xHot, int yHot, XColor fg,
-				XColor bg));
-/* 13 */
-EXTERN int		TkCreateFrame _ANSI_ARGS_((ClientData clientData,
-				Tcl_Interp * interp, int argc, char ** argv,
-				int toplevel, char * appName));
-/* 14 */
-EXTERN Tk_Window	TkCreateMainWindow _ANSI_ARGS_((Tcl_Interp * interp,
-				char * screenName, char * baseName));
-/* 15 */
-EXTERN Time		TkCurrentTime _ANSI_ARGS_((TkDisplay * dispPtr));
-/* 16 */
-EXTERN void		TkDeleteAllImages _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 17 */
-EXTERN void		TkDoConfigureNotify _ANSI_ARGS_((TkWindow * winPtr));
-/* 18 */
-EXTERN void		TkDrawInsetFocusHighlight _ANSI_ARGS_((
-				Tk_Window tkwin, GC gc, int width,
-				Drawable drawable, int padding));
-/* 19 */
-EXTERN void		TkEventDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 20 */
-EXTERN void		TkFillPolygon _ANSI_ARGS_((Tk_Canvas canvas,
-				double * coordPtr, int numPoints,
-				Display * display, Drawable drawable, GC gc,
-				GC outlineGC));
-/* 21 */
-EXTERN int		TkFindStateNum _ANSI_ARGS_((Tcl_Interp * interp,
-				CONST char * option,
-				CONST TkStateMap * mapPtr,
-				CONST char * strKey));
-/* 22 */
-EXTERN char *		TkFindStateString _ANSI_ARGS_((
-				CONST TkStateMap * mapPtr, int numKey));
-/* 23 */
-EXTERN void		TkFocusDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 24 */
-EXTERN int		TkFocusFilterEvent _ANSI_ARGS_((TkWindow * winPtr,
-/* 25 */
-EXTERN TkWindow *	TkFocusKeyEvent _ANSI_ARGS_((TkWindow * winPtr,
-/* 26 */
-EXTERN void		TkFontPkgInit _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 27 */
-EXTERN void		TkFontPkgFree _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 28 */
-EXTERN void		TkFreeBindingTags _ANSI_ARGS_((TkWindow * winPtr));
-/* 29 */
-EXTERN void		TkpFreeCursor _ANSI_ARGS_((TkCursor * cursorPtr));
-/* 30 */
-EXTERN char *		TkGetBitmapData _ANSI_ARGS_((Tcl_Interp * interp,
-				char * string, char * fileName,
-				int * widthPtr, int * heightPtr,
-				int * hotXPtr, int * hotYPtr));
-/* 31 */
-EXTERN void		TkGetButtPoints _ANSI_ARGS_((double p1[],
-				double p2[], double width, int project,
-				double m1[], double m2[]));
-/* 32 */
-EXTERN TkCursor *	TkGetCursorByName _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, Tk_Uid string));
-/* 33 */
-EXTERN char *		TkGetDefaultScreenName _ANSI_ARGS_((
-				Tcl_Interp * interp, char * screenName));
-/* 34 */
-EXTERN TkDisplay *	TkGetDisplay _ANSI_ARGS_((Display * display));
-/* 35 */
-EXTERN int		TkGetDisplayOf _ANSI_ARGS_((Tcl_Interp * interp,
-				int objc, Tcl_Obj *CONST objv[],
-				Tk_Window * tkwinPtr));
-/* 36 */
-EXTERN TkWindow *	TkGetFocusWin _ANSI_ARGS_((TkWindow * winPtr));
-/* 37 */
-EXTERN int		TkGetInterpNames _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin));
-/* 38 */
-EXTERN int		TkGetMiterPoints _ANSI_ARGS_((double p1[],
-				double p2[], double p3[], double width,
-/* 39 */
-EXTERN void		TkGetPointerCoords _ANSI_ARGS_((Tk_Window tkwin,
-				int * xPtr, int * yPtr));
-/* 40 */
-EXTERN void		TkGetServerInfo _ANSI_ARGS_((Tcl_Interp * interp,
-/* 41 */
-EXTERN void		TkGrabDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 42 */
-EXTERN int		TkGrabState _ANSI_ARGS_((TkWindow * winPtr));
-/* 43 */
-EXTERN void		TkIncludePoint _ANSI_ARGS_((Tk_Item * itemPtr,
-				double * pointPtr));
-/* 44 */
-EXTERN void		TkInOutEvents _ANSI_ARGS_((XEvent * eventPtr,
-				TkWindow * sourcePtr, TkWindow * destPtr,
-				int leaveType, int enterType,
-				Tcl_QueuePosition position));
-/* 45 */
-EXTERN void		TkInstallFrameMenu _ANSI_ARGS_((Tk_Window tkwin));
-/* 46 */
-EXTERN char *		TkKeysymToString _ANSI_ARGS_((KeySym keysym));
-/* 47 */
-EXTERN int		TkLineToArea _ANSI_ARGS_((double end1Ptr[],
-				double end2Ptr[], double rectPtr[]));
-/* 48 */
-EXTERN double		TkLineToPoint _ANSI_ARGS_((double end1Ptr[],
-				double end2Ptr[], double pointPtr[]));
-/* 49 */
-EXTERN int		TkMakeBezierCurve _ANSI_ARGS_((Tk_Canvas canvas,
-				double * pointPtr, int numPoints,
-				int numSteps, XPoint xPoints[],
-				double dblPoints[]));
-/* 50 */
-EXTERN void		TkMakeBezierPostscript _ANSI_ARGS_((
-				Tcl_Interp * interp, Tk_Canvas canvas,
-				double * pointPtr, int numPoints));
-/* 51 */
-EXTERN void		TkOptionClassChanged _ANSI_ARGS_((TkWindow * winPtr));
-/* 52 */
-EXTERN void		TkOptionDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 53 */
-EXTERN int		TkOvalToArea _ANSI_ARGS_((double * ovalPtr,
-				double * rectPtr));
-/* 54 */
-EXTERN double		TkOvalToPoint _ANSI_ARGS_((double ovalPtr[],
-				double width, int filled, double pointPtr[]));
-/* 55 */
-EXTERN int		TkpChangeFocus _ANSI_ARGS_((TkWindow * winPtr,
-				int force));
-/* 56 */
-EXTERN void		TkpCloseDisplay _ANSI_ARGS_((TkDisplay * dispPtr));
-/* 57 */
-EXTERN void		TkpClaimFocus _ANSI_ARGS_((TkWindow * topLevelPtr,
-				int force));
-/* 58 */
-EXTERN void		TkpDisplayWarning _ANSI_ARGS_((char * msg,
-				char * title));
-/* 59 */
-EXTERN void		TkpGetAppName _ANSI_ARGS_((Tcl_Interp * interp,
-				Tcl_DString * name));
-/* 60 */
-EXTERN TkWindow *	TkpGetOtherWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 61 */
-EXTERN TkWindow *	TkpGetWrapperWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 62 */
-EXTERN int		TkpInit _ANSI_ARGS_((Tcl_Interp * interp));
-/* 63 */
-EXTERN void		TkpInitializeMenuBindings _ANSI_ARGS_((
-				Tk_BindingTable bindingTable));
-/* 64 */
-EXTERN void		TkpMakeContainer _ANSI_ARGS_((Tk_Window tkwin));
-/* 65 */
-EXTERN void		TkpMakeMenuWindow _ANSI_ARGS_((Tk_Window tkwin,
-				int transient));
-/* 66 */
-EXTERN Window		TkpMakeWindow _ANSI_ARGS_((TkWindow * winPtr,
-				Window parent));
-/* 67 */
-EXTERN void		TkpMenuNotifyToplevelCreate _ANSI_ARGS_((
-				Tcl_Interp * interp1, char * menuName));
-/* 68 */
-EXTERN TkDisplay *	TkpOpenDisplay _ANSI_ARGS_((char * display_name));
-/* 69 */
-EXTERN int		TkPointerEvent _ANSI_ARGS_((XEvent * eventPtr,
-/* 70 */
-EXTERN int		TkPolygonToArea _ANSI_ARGS_((double * polyPtr,
-				int numPoints, double * rectPtr));
-/* 71 */
-EXTERN double		TkPolygonToPoint _ANSI_ARGS_((double * polyPtr,
-				int numPoints, double * pointPtr));
-/* 72 */
-EXTERN int		TkPositionInTree _ANSI_ARGS_((TkWindow * winPtr,
-				TkWindow * treePtr));
-/* 73 */
-EXTERN void		TkpRedirectKeyEvent _ANSI_ARGS_((TkWindow * winPtr,
-/* 74 */
-EXTERN void		TkpSetMainMenubar _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, char * menuName));
-/* 75 */
-EXTERN int		TkpUseWindow _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, char * string));
-/* 76 */
-EXTERN int		TkpWindowWasRecentlyDeleted _ANSI_ARGS_((Window win,
-/* 77 */
-EXTERN void		TkQueueEventForAllChildren _ANSI_ARGS_((
-				TkWindow * winPtr, XEvent * eventPtr));
-/* 78 */
-EXTERN int		TkReadBitmapFile _ANSI_ARGS_((Display* display,
-				Drawable d, CONST char* filename,
-				unsigned int* width_return,
-				unsigned int* height_return,
-				Pixmap* bitmap_return, int* x_hot_return,
-				int* y_hot_return));
-/* 79 */
-EXTERN int		TkScrollWindow _ANSI_ARGS_((Tk_Window tkwin, GC gc,
-				int x, int y, int width, int height, int dx,
-				int dy, TkRegion damageRgn));
-/* 80 */
-EXTERN void		TkSelDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 81 */
-EXTERN void		TkSelEventProc _ANSI_ARGS_((Tk_Window tkwin,
-/* 82 */
-EXTERN void		TkSelInit _ANSI_ARGS_((Tk_Window tkwin));
-/* 83 */
-EXTERN void		TkSelPropProc _ANSI_ARGS_((XEvent * eventPtr));
-/* 84 */
-EXTERN void		TkSetClassProcs _ANSI_ARGS_((Tk_Window tkwin,
-				TkClassProcs * procs,
-				ClientData instanceData));
-/* 85 */
-EXTERN void		TkSetWindowMenuBar _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, char * oldMenuName,
-				char * menuName));
-/* 86 */
-EXTERN KeySym		TkStringToKeysym _ANSI_ARGS_((char * name));
-/* 87 */
-EXTERN int		TkThickPolyLineToArea _ANSI_ARGS_((double * coordPtr,
-				int numPoints, double width, int capStyle,
-				int joinStyle, double * rectPtr));
-/* 88 */
-EXTERN void		TkWmAddToColormapWindows _ANSI_ARGS_((
-/* 89 */
-EXTERN void		TkWmDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 90 */
-EXTERN TkWindow *	TkWmFocusToplevel _ANSI_ARGS_((TkWindow * winPtr));
-/* 91 */
-EXTERN void		TkWmMapWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 92 */
-EXTERN void		TkWmNewWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 93 */
-EXTERN void		TkWmProtocolEventProc _ANSI_ARGS_((TkWindow * winPtr,
-				XEvent * evenvPtr));
-/* 94 */
-EXTERN void		TkWmRemoveFromColormapWindows _ANSI_ARGS_((
-/* 95 */
-EXTERN void		TkWmRestackToplevel _ANSI_ARGS_((TkWindow * winPtr,
-				int aboveBelow, TkWindow * otherPtr));
-/* 96 */
-EXTERN void		TkWmSetClass _ANSI_ARGS_((TkWindow * winPtr));
-/* 97 */
-EXTERN void		TkWmUnmapWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 98 */
-EXTERN Tcl_Obj *	TkDebugBitmap _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 99 */
-EXTERN Tcl_Obj *	TkDebugBorder _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 100 */
-EXTERN Tcl_Obj *	TkDebugCursor _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 101 */
-EXTERN Tcl_Obj *	TkDebugColor _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 102 */
-EXTERN Tcl_Obj *	TkDebugConfig _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_OptionTable table));
-/* 103 */
-EXTERN Tcl_Obj *	TkDebugFont _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 104 */
-EXTERN int		TkFindStateNumObj _ANSI_ARGS_((Tcl_Interp * interp,
-				Tcl_Obj * optionPtr,
-				CONST TkStateMap * mapPtr, Tcl_Obj * keyPtr));
-/* 105 */
-EXTERN Tcl_HashTable *	TkGetBitmapPredefTable _ANSI_ARGS_((void));
-/* 106 */
-EXTERN TkDisplay *	TkGetDisplayList _ANSI_ARGS_((void));
-/* 107 */
-EXTERN TkMainInfo *	TkGetMainInfoList _ANSI_ARGS_((void));
-/* 108 */
-EXTERN int		TkGetWindowFromObj _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, Tcl_Obj * objPtr,
-				Tk_Window * windowPtr));
-/* 109 */
-EXTERN char *		TkpGetString _ANSI_ARGS_((TkWindow * winPtr,
-				XEvent * eventPtr, Tcl_DString * dsPtr));
-/* 110 */
-EXTERN void		TkpGetSubFonts _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Font tkfont));
-/* 111 */
-EXTERN Tcl_Obj *	TkpGetSystemDefault _ANSI_ARGS_((Tk_Window tkwin,
-				char * dbName, char * className));
-/* 112 */
-EXTERN void		TkpMenuThreadInit _ANSI_ARGS_((void));
-#ifdef __WIN32__
-/* 113 */
-EXTERN void		TkClipBox _ANSI_ARGS_((TkRegion rgn,
-				XRectangle* rect_return));
-#endif /* __WIN32__ */
-#ifdef MAC_TCL
-/* 113 */
-#endif /* MAC_TCL */
-#ifdef __WIN32__
-/* 114 */
-EXTERN TkRegion		TkCreateRegion _ANSI_ARGS_((void));
-#ifdef MAC_TCL
-/* 114 */
-#ifdef __WIN32__
-/* 115 */
-EXTERN void		TkDestroyRegion _ANSI_ARGS_((TkRegion rgn));
-#ifdef MAC_TCL
-/* 115 */
-#ifdef __WIN32__
-/* 116 */
-EXTERN void		TkIntersectRegion _ANSI_ARGS_((TkRegion sra,
-				TkRegion srcb, TkRegion dr_return));
-#ifdef MAC_TCL
-/* 116 */
-#ifdef __WIN32__
-/* 117 */
-EXTERN int		TkRectInRegion _ANSI_ARGS_((TkRegion rgn, int x,
-				int y, unsigned int width,
-				unsigned int height));
-#ifdef MAC_TCL
-/* 117 */
-#ifdef __WIN32__
-/* 118 */
-EXTERN void		TkSetRegion _ANSI_ARGS_((Display* display, GC gc,
-				TkRegion rgn));
-#ifdef MAC_TCL
-/* 118 */
-				TkRegion rgn));
-#ifdef __WIN32__
-/* 119 */
-EXTERN void		TkUnionRectWithRegion _ANSI_ARGS_((XRectangle* rect,
-				TkRegion src, TkRegion dr_return));
-#ifdef MAC_TCL
-/* 119 */
-typedef struct TkIntStubs {
-    int magic;
-    struct TkIntStubHooks *hooks;
-    TkWindow * (*tkAllocWindow) _ANSI_ARGS_((TkDisplay * dispPtr, int screenNum, TkWindow * parentPtr)); /* 0 */
-    void (*tkBezierPoints) _ANSI_ARGS_((double control[], int numSteps, double * coordPtr)); /* 1 */
-    void (*tkBezierScreenPoints) _ANSI_ARGS_((Tk_Canvas canvas, double control[], int numSteps, XPoint * xPointPtr)); /* 2 */
-    void (*tkBindDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 3 */
-    void (*tkBindEventProc) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 4 */
-    void (*tkBindFree) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 5 */
-    void (*tkBindInit) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 6 */
-    void (*tkChangeEventWindow) _ANSI_ARGS_((XEvent * eventPtr, TkWindow * winPtr)); /* 7 */
-    int (*tkClipInit) _ANSI_ARGS_((Tcl_Interp * interp, TkDisplay * dispPtr)); /* 8 */
-    void (*tkComputeAnchor) _ANSI_ARGS_((Tk_Anchor anchor, Tk_Window tkwin, int padX, int padY, int innerWidth, int innerHeight, int * xPtr, int * yPtr)); /* 9 */
-    int (*tkCopyAndGlobalEval) _ANSI_ARGS_((Tcl_Interp * interp, char * script)); /* 10 */
-    unsigned long (*tkCreateBindingProcedure) _ANSI_ARGS_((Tcl_Interp * interp, Tk_BindingTable bindingTable, ClientData object, char * eventString, TkBindEvalProc * evalProc, TkBindFreeProc * freeProc, ClientData clientData)); /* 11 */
-    TkCursor * (*tkCreateCursorFromData) _ANSI_ARGS_((Tk_Window tkwin, char * source, char * mask, int width, int height, int xHot, int yHot, XColor fg, XColor bg)); /* 12 */
-    int (*tkCreateFrame) _ANSI_ARGS_((ClientData clientData, Tcl_Interp * interp, int argc, char ** argv, int toplevel, char * appName)); /* 13 */
-    Tk_Window (*tkCreateMainWindow) _ANSI_ARGS_((Tcl_Interp * interp, char * screenName, char * baseName)); /* 14 */
-    Time (*tkCurrentTime) _ANSI_ARGS_((TkDisplay * dispPtr)); /* 15 */
-    void (*tkDeleteAllImages) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 16 */
-    void (*tkDoConfigureNotify) _ANSI_ARGS_((TkWindow * winPtr)); /* 17 */
-    void (*tkDrawInsetFocusHighlight) _ANSI_ARGS_((Tk_Window tkwin, GC gc, int width, Drawable drawable, int padding)); /* 18 */
-    void (*tkEventDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 19 */
-    void (*tkFillPolygon) _ANSI_ARGS_((Tk_Canvas canvas, double * coordPtr, int numPoints, Display * display, Drawable drawable, GC gc, GC outlineGC)); /* 20 */
-    int (*tkFindStateNum) _ANSI_ARGS_((Tcl_Interp * interp, CONST char * option, CONST TkStateMap * mapPtr, CONST char * strKey)); /* 21 */
-    char * (*tkFindStateString) _ANSI_ARGS_((CONST TkStateMap * mapPtr, int numKey)); /* 22 */
-    void (*tkFocusDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 23 */
-    int (*tkFocusFilterEvent) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 24 */
-    TkWindow * (*tkFocusKeyEvent) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 25 */
-    void (*tkFontPkgInit) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 26 */
-    void (*tkFontPkgFree) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 27 */
-    void (*tkFreeBindingTags) _ANSI_ARGS_((TkWindow * winPtr)); /* 28 */
-    void (*tkpFreeCursor) _ANSI_ARGS_((TkCursor * cursorPtr)); /* 29 */
-    char * (*tkGetBitmapData) _ANSI_ARGS_((Tcl_Interp * interp, char * string, char * fileName, int * widthPtr, int * heightPtr, int * hotXPtr, int * hotYPtr)); /* 30 */
-    void (*tkGetButtPoints) _ANSI_ARGS_((double p1[], double p2[], double width, int project, double m1[], double m2[])); /* 31 */
-    TkCursor * (*tkGetCursorByName) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, Tk_Uid string)); /* 32 */
-    char * (*tkGetDefaultScreenName) _ANSI_ARGS_((Tcl_Interp * interp, char * screenName)); /* 33 */
-    TkDisplay * (*tkGetDisplay) _ANSI_ARGS_((Display * display)); /* 34 */
-    int (*tkGetDisplayOf) _ANSI_ARGS_((Tcl_Interp * interp, int objc, Tcl_Obj *CONST objv[], Tk_Window * tkwinPtr)); /* 35 */
-    TkWindow * (*tkGetFocusWin) _ANSI_ARGS_((TkWindow * winPtr)); /* 36 */
-    int (*tkGetInterpNames) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin)); /* 37 */
-    int (*tkGetMiterPoints) _ANSI_ARGS_((double p1[], double p2[], double p3[], double width, double m1[], double m2[])); /* 38 */
-    void (*tkGetPointerCoords) _ANSI_ARGS_((Tk_Window tkwin, int * xPtr, int * yPtr)); /* 39 */
-    void (*tkGetServerInfo) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin)); /* 40 */
-    void (*tkGrabDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 41 */
-    int (*tkGrabState) _ANSI_ARGS_((TkWindow * winPtr)); /* 42 */
-    void (*tkIncludePoint) _ANSI_ARGS_((Tk_Item * itemPtr, double * pointPtr)); /* 43 */
-    void (*tkInOutEvents) _ANSI_ARGS_((XEvent * eventPtr, TkWindow * sourcePtr, TkWindow * destPtr, int leaveType, int enterType, Tcl_QueuePosition position)); /* 44 */
-    void (*tkInstallFrameMenu) _ANSI_ARGS_((Tk_Window tkwin)); /* 45 */
-    char * (*tkKeysymToString) _ANSI_ARGS_((KeySym keysym)); /* 46 */
-    int (*tkLineToArea) _ANSI_ARGS_((double end1Ptr[], double end2Ptr[], double rectPtr[])); /* 47 */
-    double (*tkLineToPoint) _ANSI_ARGS_((double end1Ptr[], double end2Ptr[], double pointPtr[])); /* 48 */
-    int (*tkMakeBezierCurve) _ANSI_ARGS_((Tk_Canvas canvas, double * pointPtr, int numPoints, int numSteps, XPoint xPoints[], double dblPoints[])); /* 49 */
-    void (*tkMakeBezierPostscript) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Canvas canvas, double * pointPtr, int numPoints)); /* 50 */
-    void (*tkOptionClassChanged) _ANSI_ARGS_((TkWindow * winPtr)); /* 51 */
-    void (*tkOptionDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 52 */
-    int (*tkOvalToArea) _ANSI_ARGS_((double * ovalPtr, double * rectPtr)); /* 53 */
-    double (*tkOvalToPoint) _ANSI_ARGS_((double ovalPtr[], double width, int filled, double pointPtr[])); /* 54 */
-    int (*tkpChangeFocus) _ANSI_ARGS_((TkWindow * winPtr, int force)); /* 55 */
-    void (*tkpCloseDisplay) _ANSI_ARGS_((TkDisplay * dispPtr)); /* 56 */
-    void (*tkpClaimFocus) _ANSI_ARGS_((TkWindow * topLevelPtr, int force)); /* 57 */
-    void (*tkpDisplayWarning) _ANSI_ARGS_((char * msg, char * title)); /* 58 */
-    void (*tkpGetAppName) _ANSI_ARGS_((Tcl_Interp * interp, Tcl_DString * name)); /* 59 */
-    TkWindow * (*tkpGetOtherWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 60 */
-    TkWindow * (*tkpGetWrapperWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 61 */
-    int (*tkpInit) _ANSI_ARGS_((Tcl_Interp * interp)); /* 62 */
-    void (*tkpInitializeMenuBindings) _ANSI_ARGS_((Tcl_Interp * interp, Tk_BindingTable bindingTable)); /* 63 */
-    void (*tkpMakeContainer) _ANSI_ARGS_((Tk_Window tkwin)); /* 64 */
-    void (*tkpMakeMenuWindow) _ANSI_ARGS_((Tk_Window tkwin, int transient)); /* 65 */
-    Window (*tkpMakeWindow) _ANSI_ARGS_((TkWindow * winPtr, Window parent)); /* 66 */
-    void (*tkpMenuNotifyToplevelCreate) _ANSI_ARGS_((Tcl_Interp * interp1, char * menuName)); /* 67 */
-    TkDisplay * (*tkpOpenDisplay) _ANSI_ARGS_((char * display_name)); /* 68 */
-    int (*tkPointerEvent) _ANSI_ARGS_((XEvent * eventPtr, TkWindow * winPtr)); /* 69 */
-    int (*tkPolygonToArea) _ANSI_ARGS_((double * polyPtr, int numPoints, double * rectPtr)); /* 70 */
-    double (*tkPolygonToPoint) _ANSI_ARGS_((double * polyPtr, int numPoints, double * pointPtr)); /* 71 */
-    int (*tkPositionInTree) _ANSI_ARGS_((TkWindow * winPtr, TkWindow * treePtr)); /* 72 */
-    void (*tkpRedirectKeyEvent) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 73 */
-    void (*tkpSetMainMenubar) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, char * menuName)); /* 74 */
-    int (*tkpUseWindow) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, char * string)); /* 75 */
-    int (*tkpWindowWasRecentlyDeleted) _ANSI_ARGS_((Window win, TkDisplay * dispPtr)); /* 76 */
-    void (*tkQueueEventForAllChildren) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 77 */
-    int (*tkReadBitmapFile) _ANSI_ARGS_((Display* display, Drawable d, CONST char* filename, unsigned int* width_return, unsigned int* height_return, Pixmap* bitmap_return, int* x_hot_return, int* y_hot_return)); /* 78 */
-    int (*tkScrollWindow) _ANSI_ARGS_((Tk_Window tkwin, GC gc, int x, int y, int width, int height, int dx, int dy, TkRegion damageRgn)); /* 79 */
-    void (*tkSelDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 80 */
-    void (*tkSelEventProc) _ANSI_ARGS_((Tk_Window tkwin, XEvent * eventPtr)); /* 81 */
-    void (*tkSelInit) _ANSI_ARGS_((Tk_Window tkwin)); /* 82 */
-    void (*tkSelPropProc) _ANSI_ARGS_((XEvent * eventPtr)); /* 83 */
-    void (*tkSetClassProcs) _ANSI_ARGS_((Tk_Window tkwin, TkClassProcs * procs, ClientData instanceData)); /* 84 */
-    void (*tkSetWindowMenuBar) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, char * oldMenuName, char * menuName)); /* 85 */
-    KeySym (*tkStringToKeysym) _ANSI_ARGS_((char * name)); /* 86 */
-    int (*tkThickPolyLineToArea) _ANSI_ARGS_((double * coordPtr, int numPoints, double width, int capStyle, int joinStyle, double * rectPtr)); /* 87 */
-    void (*tkWmAddToColormapWindows) _ANSI_ARGS_((TkWindow * winPtr)); /* 88 */
-    void (*tkWmDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 89 */
-    TkWindow * (*tkWmFocusToplevel) _ANSI_ARGS_((TkWindow * winPtr)); /* 90 */
-    void (*tkWmMapWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 91 */
-    void (*tkWmNewWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 92 */
-    void (*tkWmProtocolEventProc) _ANSI_ARGS_((TkWindow * winPtr, XEvent * evenvPtr)); /* 93 */
-    void (*tkWmRemoveFromColormapWindows) _ANSI_ARGS_((TkWindow * winPtr)); /* 94 */
-    void (*tkWmRestackToplevel) _ANSI_ARGS_((TkWindow * winPtr, int aboveBelow, TkWindow * otherPtr)); /* 95 */
-    void (*tkWmSetClass) _ANSI_ARGS_((TkWindow * winPtr)); /* 96 */
-    void (*tkWmUnmapWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 97 */
-    Tcl_Obj * (*tkDebugBitmap) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 98 */
-    Tcl_Obj * (*tkDebugBorder) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 99 */
-    Tcl_Obj * (*tkDebugCursor) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 100 */
-    Tcl_Obj * (*tkDebugColor) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 101 */
-    Tcl_Obj * (*tkDebugConfig) _ANSI_ARGS_((Tcl_Interp * interp, Tk_OptionTable table)); /* 102 */
-    Tcl_Obj * (*tkDebugFont) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 103 */
-    int (*tkFindStateNumObj) _ANSI_ARGS_((Tcl_Interp * interp, Tcl_Obj * optionPtr, CONST TkStateMap * mapPtr, Tcl_Obj * keyPtr)); /* 104 */
-    Tcl_HashTable * (*tkGetBitmapPredefTable) _ANSI_ARGS_((void)); /* 105 */
-    TkDisplay * (*tkGetDisplayList) _ANSI_ARGS_((void)); /* 106 */
-    TkMainInfo * (*tkGetMainInfoList) _ANSI_ARGS_((void)); /* 107 */
-    int (*tkGetWindowFromObj) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, Tcl_Obj * objPtr, Tk_Window * windowPtr)); /* 108 */
-    char * (*tkpGetString) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr, Tcl_DString * dsPtr)); /* 109 */
-    void (*tkpGetSubFonts) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Font tkfont)); /* 110 */
-    Tcl_Obj * (*tkpGetSystemDefault) _ANSI_ARGS_((Tk_Window tkwin, char * dbName, char * className)); /* 111 */
-    void (*tkpMenuThreadInit) _ANSI_ARGS_((void)); /* 112 */
-#if !defined(__WIN32__) && !defined(MAC_TCL) /* UNIX */
-    void *reserved113;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkClipBox) _ANSI_ARGS_((TkRegion rgn, XRectangle* rect_return)); /* 113 */
-#ifdef MAC_TCL
-    void *reserved114;
-#endif /* UNIX */
-#ifdef __WIN32__
-    TkRegion (*tkCreateRegion) _ANSI_ARGS_((void)); /* 114 */
-#ifdef MAC_TCL
-    void *reserved115;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkDestroyRegion) _ANSI_ARGS_((TkRegion rgn)); /* 115 */
-#ifdef MAC_TCL
-    void *reserved116;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkIntersectRegion) _ANSI_ARGS_((TkRegion sra, TkRegion srcb, TkRegion dr_return)); /* 116 */
-#ifdef MAC_TCL
-    void *reserved117;
-#endif /* UNIX */
-#ifdef __WIN32__
-    int (*tkRectInRegion) _ANSI_ARGS_((TkRegion rgn, int x, int y, unsigned int width, unsigned int height)); /* 117 */
-#ifdef MAC_TCL
-    void *reserved118;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkSetRegion) _ANSI_ARGS_((Display* display, GC gc, TkRegion rgn)); /* 118 */
-#ifdef MAC_TCL
-    void *reserved119;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkUnionRectWithRegion) _ANSI_ARGS_((XRectangle* rect, TkRegion src, TkRegion dr_return)); /* 119 */
-#ifdef MAC_TCL
-} TkIntStubs;
-#ifdef __cplusplus
-extern "C" {
-#endif
-extern TkIntStubs *tkIntStubsPtr;
-#ifdef __cplusplus
-#endif
-#if defined(USE_TK_STUBS) && !defined(USE_TK_STUB_PROCS)
- * Inline function declarations:
-#ifndef TkAllocWindow
-#define TkAllocWindow \
-	(tkIntStubsPtr->tkAllocWindow) /* 0 */
-#endif
-#ifndef TkBezierPoints
-#define TkBezierPoints \
-	(tkIntStubsPtr->tkBezierPoints) /* 1 */
-#endif
-#ifndef TkBezierScreenPoints
-#define TkBezierScreenPoints \
-	(tkIntStubsPtr->tkBezierScreenPoints) /* 2 */
-#endif
-#ifndef TkBindDeadWindow
-#define TkBindDeadWindow \
-	(tkIntStubsPtr->tkBindDeadWindow) /* 3 */
-#endif
-#ifndef TkBindEventProc
-#define TkBindEventProc \
-	(tkIntStubsPtr->tkBindEventProc) /* 4 */
-#endif
-#ifndef TkBindFree
-#define TkBindFree \
-	(tkIntStubsPtr->tkBindFree) /* 5 */
-#endif
-#ifndef TkBindInit
-#define TkBindInit \
-	(tkIntStubsPtr->tkBindInit) /* 6 */
-#endif
-#ifndef TkChangeEventWindow
-#define TkChangeEventWindow \
-	(tkIntStubsPtr->tkChangeEventWindow) /* 7 */
-#endif
-#ifndef TkClipInit
-#define TkClipInit \
-	(tkIntStubsPtr->tkClipInit) /* 8 */
-#endif
-#ifndef TkComputeAnchor
-#define TkComputeAnchor \
-	(tkIntStubsPtr->tkComputeAnchor) /* 9 */
-#endif
-#ifndef TkCopyAndGlobalEval
-#define TkCopyAndGlobalEval \
-	(tkIntStubsPtr->tkCopyAndGlobalEval) /* 10 */
-#endif
-#ifndef TkCreateBindingProcedure
-#define TkCreateBindingProcedure \
-	(tkIntStubsPtr->tkCreateBindingProcedure) /* 11 */
-#endif
-#ifndef TkCreateCursorFromData
-#define TkCreateCursorFromData \
-	(tkIntStubsPtr->tkCreateCursorFromData) /* 12 */
-#endif
-#ifndef TkCreateFrame
-#define TkCreateFrame \
-	(tkIntStubsPtr->tkCreateFrame) /* 13 */
-#endif
-#ifndef TkCreateMainWindow
-#define TkCreateMainWindow \
-	(tkIntStubsPtr->tkCreateMainWindow) /* 14 */
-#endif
-#ifndef TkCurrentTime
-#define TkCurrentTime \
-	(tkIntStubsPtr->tkCurrentTime) /* 15 */
-#endif
-#ifndef TkDeleteAllImages
-#define TkDeleteAllImages \
-	(tkIntStubsPtr->tkDeleteAllImages) /* 16 */
-#endif
-#ifndef TkDoConfigureNotify
-#define TkDoConfigureNotify \
-	(tkIntStubsPtr->tkDoConfigureNotify) /* 17 */
-#endif
-#ifndef TkDrawInsetFocusHighlight
-#define TkDrawInsetFocusHighlight \
-	(tkIntStubsPtr->tkDrawInsetFocusHighlight) /* 18 */
-#endif
-#ifndef TkEventDeadWindow
-#define TkEventDeadWindow \
-	(tkIntStubsPtr->tkEventDeadWindow) /* 19 */
-#endif
-#ifndef TkFillPolygon
-#define TkFillPolygon \
-	(tkIntStubsPtr->tkFillPolygon) /* 20 */
-#endif
-#ifndef TkFindStateNum
-#define TkFindStateNum \
-	(tkIntStubsPtr->tkFindStateNum) /* 21 */
-#endif
-#ifndef TkFindStateString
-#define TkFindStateString \
-	(tkIntStubsPtr->tkFindStateString) /* 22 */
-#endif
-#ifndef TkFocusDeadWindow
-#define TkFocusDeadWindow \
-	(tkIntStubsPtr->tkFocusDeadWindow) /* 23 */
-#endif
-#ifndef TkFocusFilterEvent
-#define TkFocusFilterEvent \
-	(tkIntStubsPtr->tkFocusFilterEvent) /* 24 */
-#endif
-#ifndef TkFocusKeyEvent
-#define TkFocusKeyEvent \
-	(tkIntStubsPtr->tkFocusKeyEvent) /* 25 */
-#endif
-#ifndef TkFontPkgInit
-#define TkFontPkgInit \
-	(tkIntStubsPtr->tkFontPkgInit) /* 26 */
-#endif
-#ifndef TkFontPkgFree
-#define TkFontPkgFree \
-	(tkIntStubsPtr->tkFontPkgFree) /* 27 */
-#endif
-#ifndef TkFreeBindingTags
-#define TkFreeBindingTags \
-	(tkIntStubsPtr->tkFreeBindingTags) /* 28 */
-#endif
-#ifndef TkpFreeCursor
-#define TkpFreeCursor \
-	(tkIntStubsPtr->tkpFreeCursor) /* 29 */
-#endif
-#ifndef TkGetBitmapData
-#define TkGetBitmapData \
-	(tkIntStubsPtr->tkGetBitmapData) /* 30 */
-#endif
-#ifndef TkGetButtPoints
-#define TkGetButtPoints \
-	(tkIntStubsPtr->tkGetButtPoints) /* 31 */
-#endif
-#ifndef TkGetCursorByName
-#define TkGetCursorByName \
-	(tkIntStubsPtr->tkGetCursorByName) /* 32 */
-#endif
-#ifndef TkGetDefaultScreenName
-#define TkGetDefaultScreenName \
-	(tkIntStubsPtr->tkGetDefaultScreenName) /* 33 */
-#endif
-#ifndef TkGetDisplay
-#define TkGetDisplay \
-	(tkIntStubsPtr->tkGetDisplay) /* 34 */
-#endif
-#ifndef TkGetDisplayOf
-#define TkGetDisplayOf \
-	(tkIntStubsPtr->tkGetDisplayOf) /* 35 */
-#endif
-#ifndef TkGetFocusWin
-#define TkGetFocusWin \
-	(tkIntStubsPtr->tkGetFocusWin) /* 36 */
-#endif
-#ifndef TkGetInterpNames
-#define TkGetInterpNames \
-	(tkIntStubsPtr->tkGetInterpNames) /* 37 */
-#endif
-#ifndef TkGetMiterPoints
-#define TkGetMiterPoints \
-	(tkIntStubsPtr->tkGetMiterPoints) /* 38 */
-#endif
-#ifndef TkGetPointerCoords
-#define TkGetPointerCoords \
-	(tkIntStubsPtr->tkGetPointerCoords) /* 39 */
-#endif
-#ifndef TkGetServerInfo
-#define TkGetServerInfo \
-	(tkIntStubsPtr->tkGetServerInfo) /* 40 */
-#endif
-#ifndef TkGrabDeadWindow
-#define TkGrabDeadWindow \
-	(tkIntStubsPtr->tkGrabDeadWindow) /* 41 */
-#endif
-#ifndef TkGrabState
-#define TkGrabState \
-	(tkIntStubsPtr->tkGrabState) /* 42 */
-#endif
-#ifndef TkIncludePoint
-#define TkIncludePoint \
-	(tkIntStubsPtr->tkIncludePoint) /* 43 */
-#endif
-#ifndef TkInOutEvents
-#define TkInOutEvents \
-	(tkIntStubsPtr->tkInOutEvents) /* 44 */
-#endif
-#ifndef TkInstallFrameMenu
-#define TkInstallFrameMenu \
-	(tkIntStubsPtr->tkInstallFrameMenu) /* 45 */
-#endif
-#ifndef TkKeysymToString
-#define TkKeysymToString \
-	(tkIntStubsPtr->tkKeysymToString) /* 46 */
-#endif
-#ifndef TkLineToArea
-#define TkLineToArea \
-	(tkIntStubsPtr->tkLineToArea) /* 47 */
-#endif
-#ifndef TkLineToPoint
-#define TkLineToPoint \
-	(tkIntStubsPtr->tkLineToPoint) /* 48 */
-#endif
-#ifndef TkMakeBezierCurve
-#define TkMakeBezierCurve \
-	(tkIntStubsPtr->tkMakeBezierCurve) /* 49 */
-#endif
-#ifndef TkMakeBezierPostscript
-#define TkMakeBezierPostscript \
-	(tkIntStubsPtr->tkMakeBezierPostscript) /* 50 */
-#endif
-#ifndef TkOptionClassChanged
-#define TkOptionClassChanged \
-	(tkIntStubsPtr->tkOptionClassChanged) /* 51 */
-#endif
-#ifndef TkOptionDeadWindow
-#define TkOptionDeadWindow \
-	(tkIntStubsPtr->tkOptionDeadWindow) /* 52 */
-#endif
-#ifndef TkOvalToArea
-#define TkOvalToArea \
-	(tkIntStubsPtr->tkOvalToArea) /* 53 */
-#endif
-#ifndef TkOvalToPoint
-#define TkOvalToPoint \
-	(tkIntStubsPtr->tkOvalToPoint) /* 54 */
-#endif
-#ifndef TkpChangeFocus
-#define TkpChangeFocus \
-	(tkIntStubsPtr->tkpChangeFocus) /* 55 */
-#endif
-#ifndef TkpCloseDisplay
-#define TkpCloseDisplay \
-	(tkIntStubsPtr->tkpCloseDisplay) /* 56 */
-#endif
-#ifndef TkpClaimFocus
-#define TkpClaimFocus \
-	(tkIntStubsPtr->tkpClaimFocus) /* 57 */
-#endif
-#ifndef TkpDisplayWarning
-#define TkpDisplayWarning \
-	(tkIntStubsPtr->tkpDisplayWarning) /* 58 */
-#endif
-#ifndef TkpGetAppName
-#define TkpGetAppName \
-	(tkIntStubsPtr->tkpGetAppName) /* 59 */
-#endif
-#ifndef TkpGetOtherWindow
-#define TkpGetOtherWindow \
-	(tkIntStubsPtr->tkpGetOtherWindow) /* 60 */
-#endif
-#ifndef TkpGetWrapperWindow
-#define TkpGetWrapperWindow \
-	(tkIntStubsPtr->tkpGetWrapperWindow) /* 61 */
-#endif
-#ifndef TkpInit
-#define TkpInit \
-	(tkIntStubsPtr->tkpInit) /* 62 */
-#endif
-#ifndef TkpInitializeMenuBindings
-#define TkpInitializeMenuBindings \
-	(tkIntStubsPtr->tkpInitializeMenuBindings) /* 63 */
-#endif
-#ifndef TkpMakeContainer
-#define TkpMakeContainer \
-	(tkIntStubsPtr->tkpMakeContainer) /* 64 */
-#endif
-#ifndef TkpMakeMenuWindow
-#define TkpMakeMenuWindow \
-	(tkIntStubsPtr->tkpMakeMenuWindow) /* 65 */
-#endif
-#ifndef TkpMakeWindow
-#define TkpMakeWindow \
-	(tkIntStubsPtr->tkpMakeWindow) /* 66 */
-#endif
-#ifndef TkpMenuNotifyToplevelCreate
-#define TkpMenuNotifyToplevelCreate \
-	(tkIntStubsPtr->tkpMenuNotifyToplevelCreate) /* 67 */
-#endif
-#ifndef TkpOpenDisplay
-#define TkpOpenDisplay \
-	(tkIntStubsPtr->tkpOpenDisplay) /* 68 */
-#endif
-#ifndef TkPointerEvent
-#define TkPointerEvent \
-	(tkIntStubsPtr->tkPointerEvent) /* 69 */
-#endif
-#ifndef TkPolygonToArea
-#define TkPolygonToArea \
-	(tkIntStubsPtr->tkPolygonToArea) /* 70 */
-#endif
-#ifndef TkPolygonToPoint
-#define TkPolygonToPoint \
-	(tkIntStubsPtr->tkPolygonToPoint) /* 71 */
-#endif
-#ifndef TkPositionInTree
-#define TkPositionInTree \
-	(tkIntStubsPtr->tkPositionInTree) /* 72 */
-#endif
-#ifndef TkpRedirectKeyEvent
-#define TkpRedirectKeyEvent \
-	(tkIntStubsPtr->tkpRedirectKeyEvent) /* 73 */
-#endif
-#ifndef TkpSetMainMenubar
-#define TkpSetMainMenubar \
-	(tkIntStubsPtr->tkpSetMainMenubar) /* 74 */
-#endif
-#ifndef TkpUseWindow
-#define TkpUseWindow \
-	(tkIntStubsPtr->tkpUseWindow) /* 75 */
-#endif
-#ifndef TkpWindowWasRecentlyDeleted
-#define TkpWindowWasRecentlyDeleted \
-	(tkIntStubsPtr->tkpWindowWasRecentlyDeleted) /* 76 */
-#endif
-#ifndef TkQueueEventForAllChildren
-#define TkQueueEventForAllChildren \
-	(tkIntStubsPtr->tkQueueEventForAllChildren) /* 77 */
-#endif
-#ifndef TkReadBitmapFile
-#define TkReadBitmapFile \
-	(tkIntStubsPtr->tkReadBitmapFile) /* 78 */
-#endif
-#ifndef TkScrollWindow
-#define TkScrollWindow \
-	(tkIntStubsPtr->tkScrollWindow) /* 79 */
-#endif
-#ifndef TkSelDeadWindow
-#define TkSelDeadWindow \
-	(tkIntStubsPtr->tkSelDeadWindow) /* 80 */
-#endif
-#ifndef TkSelEventProc
-#define TkSelEventProc \
-	(tkIntStubsPtr->tkSelEventProc) /* 81 */
-#endif
-#ifndef TkSelInit
-#define TkSelInit \
-	(tkIntStubsPtr->tkSelInit) /* 82 */
-#endif
-#ifndef TkSelPropProc
-#define TkSelPropProc \
-	(tkIntStubsPtr->tkSelPropProc) /* 83 */
-#endif
-#ifndef TkSetClassProcs
-#define TkSetClassProcs \
-	(tkIntStubsPtr->tkSetClassProcs) /* 84 */
-#endif
-#ifndef TkSetWindowMenuBar
-#define TkSetWindowMenuBar \
-	(tkIntStubsPtr->tkSetWindowMenuBar) /* 85 */
-#endif
-#ifndef TkStringToKeysym
-#define TkStringToKeysym \
-	(tkIntStubsPtr->tkStringToKeysym) /* 86 */
-#endif
-#ifndef TkThickPolyLineToArea
-#define TkThickPolyLineToArea \
-	(tkIntStubsPtr->tkThickPolyLineToArea) /* 87 */
-#endif
-#ifndef TkWmAddToColormapWindows
-#define TkWmAddToColormapWindows \
-	(tkIntStubsPtr->tkWmAddToColormapWindows) /* 88 */
-#endif
-#ifndef TkWmDeadWindow
-#define TkWmDeadWindow \
-	(tkIntStubsPtr->tkWmDeadWindow) /* 89 */
-#endif
-#ifndef TkWmFocusToplevel
-#define TkWmFocusToplevel \
-	(tkIntStubsPtr->tkWmFocusToplevel) /* 90 */
-#endif
-#ifndef TkWmMapWindow
-#define TkWmMapWindow \
-	(tkIntStubsPtr->tkWmMapWindow) /* 91 */
-#endif
-#ifndef TkWmNewWindow
-#define TkWmNewWindow \
-	(tkIntStubsPtr->tkWmNewWindow) /* 92 */
-#endif
-#ifndef TkWmProtocolEventProc
-#define TkWmProtocolEventProc \
-	(tkIntStubsPtr->tkWmProtocolEventProc) /* 93 */
-#endif
-#ifndef TkWmRemoveFromColormapWindows
-#define TkWmRemoveFromColormapWindows \
-	(tkIntStubsPtr->tkWmRemoveFromColormapWindows) /* 94 */
-#endif
-#ifndef TkWmRestackToplevel
-#define TkWmRestackToplevel \
-	(tkIntStubsPtr->tkWmRestackToplevel) /* 95 */
-#endif
-#ifndef TkWmSetClass
-#define TkWmSetClass \
-	(tkIntStubsPtr->tkWmSetClass) /* 96 */
-#endif
-#ifndef TkWmUnmapWindow
-#define TkWmUnmapWindow \
-	(tkIntStubsPtr->tkWmUnmapWindow) /* 97 */
-#endif
-#ifndef TkDebugBitmap
-#define TkDebugBitmap \
-	(tkIntStubsPtr->tkDebugBitmap) /* 98 */
-#endif
-#ifndef TkDebugBorder
-#define TkDebugBorder \
-	(tkIntStubsPtr->tkDebugBorder) /* 99 */
-#endif
-#ifndef TkDebugCursor
-#define TkDebugCursor \
-	(tkIntStubsPtr->tkDebugCursor) /* 100 */
-#endif
-#ifndef TkDebugColor
-#define TkDebugColor \
-	(tkIntStubsPtr->tkDebugColor) /* 101 */
-#endif
-#ifndef TkDebugConfig
-#define TkDebugConfig \
-	(tkIntStubsPtr->tkDebugConfig) /* 102 */
-#endif
-#ifndef TkDebugFont
-#define TkDebugFont \
-	(tkIntStubsPtr->tkDebugFont) /* 103 */
-#endif
-#ifndef TkFindStateNumObj
-#define TkFindStateNumObj \
-	(tkIntStubsPtr->tkFindStateNumObj) /* 104 */
-#endif
-#ifndef TkGetBitmapPredefTable
-#define TkGetBitmapPredefTable \
-	(tkIntStubsPtr->tkGetBitmapPredefTable) /* 105 */
-#endif
-#ifndef TkGetDisplayList
-#define TkGetDisplayList \
-	(tkIntStubsPtr->tkGetDisplayList) /* 106 */
-#endif
-#ifndef TkGetMainInfoList
-#define TkGetMainInfoList \
-	(tkIntStubsPtr->tkGetMainInfoList) /* 107 */
-#endif
-#ifndef TkGetWindowFromObj
-#define TkGetWindowFromObj \
-	(tkIntStubsPtr->tkGetWindowFromObj) /* 108 */
-#endif
-#ifndef TkpGetString
-#define TkpGetString \
-	(tkIntStubsPtr->tkpGetString) /* 109 */
-#endif
-#ifndef TkpGetSubFonts
-#define TkpGetSubFonts \
-	(tkIntStubsPtr->tkpGetSubFonts) /* 110 */
-#endif
-#ifndef TkpGetSystemDefault
-#define TkpGetSystemDefault \
-	(tkIntStubsPtr->tkpGetSystemDefault) /* 111 */
-#endif
-#ifndef TkpMenuThreadInit
-#define TkpMenuThreadInit \
-	(tkIntStubsPtr->tkpMenuThreadInit) /* 112 */
-#endif
-#ifdef __WIN32__
-#ifndef TkClipBox
-#define TkClipBox \
-	(tkIntStubsPtr->tkClipBox) /* 113 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkClipBox
-#endif
-#ifdef __WIN32__
-#ifndef TkCreateRegion
-#define TkCreateRegion \
-	(tkIntStubsPtr->tkCreateRegion) /* 114 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#ifndef TkDestroyRegion
-#define TkDestroyRegion \
-	(tkIntStubsPtr->tkDestroyRegion) /* 115 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#ifndef TkIntersectRegion
-#define TkIntersectRegion \
-	(tkIntStubsPtr->tkIntersectRegion) /* 116 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#ifndef TkRectInRegion
-#define TkRectInRegion \
-	(tkIntStubsPtr->tkRectInRegion) /* 117 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#ifndef TkSetRegion
-#define TkSetRegion \
-	(tkIntStubsPtr->tkSetRegion) /* 118 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#ifndef TkUnionRectWithRegion
-#define TkUnionRectWithRegion \
-	(tkIntStubsPtr->tkUnionRectWithRegion) /* 119 */
-#endif
-#ifdef MAC_TCL
-#endif
-#endif /* defined(USE_TK_STUBS) && !defined(USE_TK_STUB_PROCS) */
-/* !END!: Do not edit above this line. */
-#define TCL_STORAGE_CLASS DLLIMPORT
-#endif /* _TKINTDECLS */
Deleted: grass/trunk/visualization/nviz/src/tkIntDecls8.2.3.h
--- grass/trunk/visualization/nviz/src/tkIntDecls8.2.3.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkIntDecls8.2.3.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1460 +0,0 @@
- * tkIntDecls.h --
- * See the file "license.terms" for information on usage and redistribution
- * of this file, and for a DISCLAIMER OF ALL WARRANTIES.
- * RCS: @(#) $Id$
-#ifdef BUILD_tk
-#endif
-/* 0 */
-/* 1 */
-/* 2 */
-/* 3 */
-/* 4 */
-/* 5 */
-/* 6 */
-/* 7 */
-/* 8 */
-/* 9 */
-				int * yPtr));
-/* 10 */
-				char * script));
-/* 11 */
-/* 12 */
-				XColor bg));
-/* 13 */
-/* 14 */
-/* 15 */
-/* 16 */
-/* 17 */
-/* 18 */
-/* 19 */
-/* 20 */
-				GC outlineGC));
-/* 21 */
-/* 22 */
-/* 23 */
-/* 24 */
-/* 25 */
-/* 26 */
-/* 27 */
-/* 28 */
-/* 29 */
-/* 30 */
-/* 31 */
-/* 32 */
-/* 33 */
-/* 34 */
-/* 35 */
-/* 36 */
-/* 37 */
-/* 38 */
-/* 39 */
-/* 40 */
-/* 41 */
-/* 42 */
-/* 43 */
-/* 44 */
-/* 45 */
-/* 46 */
-/* 47 */
-/* 48 */
-/* 49 */
-/* 50 */
-/* 51 */
-/* 52 */
-/* 53 */
-/* 54 */
-/* 55 */
-				int force));
-/* 56 */
-/* 57 */
-				int force));
-/* 58 */
-				char * title));
-/* 59 */
-/* 60 */
-/* 61 */
-/* 62 */
-/* 63 */
-/* 64 */
-/* 65 */
-				int transient));
-/* 66 */
-				Window parent));
-/* 67 */
-/* 68 */
-/* 69 */
-/* 70 */
-/* 71 */
-/* 72 */
-/* 73 */
-/* 74 */
-/* 75 */
-/* 76 */
-/* 77 */
-/* 78 */
-/* 79 */
-/* 80 */
-/* 81 */
-/* 82 */
-/* 83 */
-/* 84 */
-/* 85 */
-/* 86 */
-/* 87 */
-/* 88 */
-/* 89 */
-/* 90 */
-/* 91 */
-/* 92 */
-/* 93 */
-/* 94 */
-/* 95 */
-/* 96 */
-/* 97 */
-/* 98 */
-				char * name));
-/* 99 */
-				char * name));
-/* 100 */
-				char * name));
-/* 101 */
-				char * name));
-/* 102 */
-/* 103 */
-				char * name));
-/* 104 */
-/* 105 */
-/* 106 */
-/* 107 */
-/* 108 */
-/* 109 */
-/* 110 */
-				Tk_Font tkfont));
-/* 111 */
-/* 112 */
-#ifdef __WIN32__
-/* 113 */
-#ifdef MAC_TCL
-/* 113 */
-#ifdef __WIN32__
-/* 114 */
-#ifdef MAC_TCL
-/* 114 */
-#ifdef __WIN32__
-/* 115 */
-#ifdef MAC_TCL
-/* 115 */
-#ifdef __WIN32__
-/* 116 */
-#ifdef MAC_TCL
-/* 116 */
-#ifdef __WIN32__
-/* 117 */
-#ifdef MAC_TCL
-/* 117 */
-#ifdef __WIN32__
-/* 118 */
-				TkRegion rgn));
-#ifdef MAC_TCL
-/* 118 */
-				TkRegion rgn));
-#ifdef __WIN32__
-/* 119 */
-#ifdef MAC_TCL
-/* 119 */
-#ifdef MAC_TCL
-/* 120 */
-EXTERN void		TkGenerateActivateEvents _ANSI_ARGS_((
-				TkWindow * winPtr, int active));
-#ifdef MAC_TCL
-/* 121 */
-EXTERN Pixmap		TkpCreateNativeBitmap _ANSI_ARGS_((Display * display,
-				char * source));
-#ifdef MAC_TCL
-/* 122 */
-EXTERN void		TkpDefineNativeBitmaps _ANSI_ARGS_((void));
-#ifdef MAC_TCL
-/* 123 */
-EXTERN unsigned long	TkpGetMS _ANSI_ARGS_((void));
-#ifdef MAC_TCL
-/* 124 */
-EXTERN Pixmap		TkpGetNativeAppBitmap _ANSI_ARGS_((Display * display,
-				CONST char * name, int * width, int * height));
-#ifdef MAC_TCL
-/* 125 */
-EXTERN void		TkPointerDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-#ifdef MAC_TCL
-/* 126 */
-EXTERN void		TkpSetCapture _ANSI_ARGS_((TkWindow * winPtr));
-#ifdef MAC_TCL
-/* 127 */
-EXTERN void		TkpSetCursor _ANSI_ARGS_((TkpCursor cursor));
-#ifdef MAC_TCL
-/* 128 */
-EXTERN void		TkpWmSetState _ANSI_ARGS_((TkWindow * winPtr,
-				int state));
-/* Slot 129 is reserved */
-#ifdef MAC_TCL
-/* 130 */
-EXTERN Window		TkGetTransientMaster _ANSI_ARGS_((TkWindow * winPtr));
-#ifdef MAC_TCL
-/* 131 */
-EXTERN int		TkGenerateButtonEvent _ANSI_ARGS_((int x, int y,
-				Window window, unsigned int state));
-/* Slot 132 is reserved */
-#ifdef MAC_TCL
-/* 133 */
-EXTERN void		TkGenWMDestroyEvent _ANSI_ARGS_((Tk_Window tkwin));
-#ifdef MAC_TCL
-/* 134 */
-EXTERN void		TkGenWMConfigureEvent _ANSI_ARGS_((Tk_Window tkwin,
-				int flags));
-/* 135 */
-EXTERN void		TkpDrawHighlightBorder _ANSI_ARGS_((Tk_Window tkwin,
-				GC fgGC, GC bgGC, int highlightWidth,
-				Drawable drawable));
-/* 136 */
-EXTERN void		TkSetFocusWin _ANSI_ARGS_((TkWindow * winPtr,
-				int force));
-    int magic;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void *reserved120;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkGenerateActivateEvents) _ANSI_ARGS_((TkWindow * winPtr, int active)); /* 120 */
-    void *reserved121;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    Pixmap (*tkpCreateNativeBitmap) _ANSI_ARGS_((Display * display, char * source)); /* 121 */
-    void *reserved122;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkpDefineNativeBitmaps) _ANSI_ARGS_((void)); /* 122 */
-    void *reserved123;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    unsigned long (*tkpGetMS) _ANSI_ARGS_((void)); /* 123 */
-    void *reserved124;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    Pixmap (*tkpGetNativeAppBitmap) _ANSI_ARGS_((Display * display, CONST char * name, int * width, int * height)); /* 124 */
-    void *reserved125;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkPointerDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 125 */
-    void *reserved126;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkpSetCapture) _ANSI_ARGS_((TkWindow * winPtr)); /* 126 */
-    void *reserved127;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkpSetCursor) _ANSI_ARGS_((TkpCursor cursor)); /* 127 */
-    void *reserved128;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkpWmSetState) _ANSI_ARGS_((TkWindow * winPtr, int state)); /* 128 */
-    void *reserved129;
-    void *reserved130;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    Window (*tkGetTransientMaster) _ANSI_ARGS_((TkWindow * winPtr)); /* 130 */
-    void *reserved131;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    int (*tkGenerateButtonEvent) _ANSI_ARGS_((int x, int y, Window window, unsigned int state)); /* 131 */
-    void *reserved132;
-    void *reserved133;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkGenWMDestroyEvent) _ANSI_ARGS_((Tk_Window tkwin)); /* 133 */
-    void *reserved134;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkGenWMConfigureEvent) _ANSI_ARGS_((Tk_Window tkwin, int x, int y, int width, int height, int flags)); /* 134 */
-    void (*tkpDrawHighlightBorder) _ANSI_ARGS_((Tk_Window tkwin, GC fgGC, GC bgGC, int highlightWidth, Drawable drawable)); /* 135 */
-    void (*tkSetFocusWin) _ANSI_ARGS_((TkWindow * winPtr, int force)); /* 136 */
-} TkIntStubs;
-#ifdef __cplusplus
-extern "C" {
-#endif
-#ifdef __cplusplus
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkBindFree
-#endif
-#ifndef TkBindInit
-#endif
-#endif
-#ifndef TkClipInit
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkpInit
-#define TkpInit \
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkSelInit
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifdef __WIN32__
-#ifndef TkClipBox
-#endif
-#ifdef MAC_TCL
-#ifndef TkClipBox
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#ifndef TkGenerateActivateEvents
-#define TkGenerateActivateEvents \
-	(tkIntStubsPtr->tkGenerateActivateEvents) /* 120 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkpCreateNativeBitmap
-#define TkpCreateNativeBitmap \
-	(tkIntStubsPtr->tkpCreateNativeBitmap) /* 121 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkpDefineNativeBitmaps
-#define TkpDefineNativeBitmaps \
-	(tkIntStubsPtr->tkpDefineNativeBitmaps) /* 122 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkpGetMS
-#define TkpGetMS \
-	(tkIntStubsPtr->tkpGetMS) /* 123 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkpGetNativeAppBitmap
-#define TkpGetNativeAppBitmap \
-	(tkIntStubsPtr->tkpGetNativeAppBitmap) /* 124 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkPointerDeadWindow
-#define TkPointerDeadWindow \
-	(tkIntStubsPtr->tkPointerDeadWindow) /* 125 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkpSetCapture
-#define TkpSetCapture \
-	(tkIntStubsPtr->tkpSetCapture) /* 126 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkpSetCursor
-#define TkpSetCursor \
-	(tkIntStubsPtr->tkpSetCursor) /* 127 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkpWmSetState
-#define TkpWmSetState \
-	(tkIntStubsPtr->tkpWmSetState) /* 128 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkGetTransientMaster
-#define TkGetTransientMaster \
-	(tkIntStubsPtr->tkGetTransientMaster) /* 130 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkGenerateButtonEvent
-#define TkGenerateButtonEvent \
-	(tkIntStubsPtr->tkGenerateButtonEvent) /* 131 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkGenWMDestroyEvent
-#define TkGenWMDestroyEvent \
-	(tkIntStubsPtr->tkGenWMDestroyEvent) /* 133 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkGenWMConfigureEvent
-#define TkGenWMConfigureEvent \
-	(tkIntStubsPtr->tkGenWMConfigureEvent) /* 134 */
-#endif
-#ifndef TkpDrawHighlightBorder
-#define TkpDrawHighlightBorder \
-	(tkIntStubsPtr->tkpDrawHighlightBorder) /* 135 */
-#endif
-#ifndef TkSetFocusWin
-#define TkSetFocusWin \
-	(tkIntStubsPtr->tkSetFocusWin) /* 136 */
-#endif
Deleted: grass/trunk/visualization/nviz/src/tkIntDecls8.3.3.h
--- grass/trunk/visualization/nviz/src/tkIntDecls8.3.3.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkIntDecls8.3.3.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1318 +0,0 @@
- * tkIntDecls.h --
- * RCS: @(#) $Id$
-#ifdef BUILD_tk
-#endif
-/* 0 */
-/* 1 */
-/* 2 */
-/* 3 */
-/* 4 */
-/* 5 */
-/* 6 */
-/* 7 */
-/* 8 */
-/* 9 */
-				int * yPtr));
-/* 10 */
-				char * script));
-/* 11 */
-/* 12 */
-				XColor bg));
-/* 13 */
-/* 14 */
-/* 15 */
-/* 16 */
-/* 17 */
-/* 18 */
-/* 19 */
-/* 20 */
-				GC outlineGC));
-/* 21 */
-/* 22 */
-/* 23 */
-/* 24 */
-/* 25 */
-/* 26 */
-/* 27 */
-/* 28 */
-/* 29 */
-/* 30 */
-/* 31 */
-/* 32 */
-/* 33 */
-/* 34 */
-/* 35 */
-/* 36 */
-/* 37 */
-/* 38 */
-/* 39 */
-/* 40 */
-/* 41 */
-/* 42 */
-/* 43 */
-/* 44 */
-/* 45 */
-/* 46 */
-/* 47 */
-/* 48 */
-/* 49 */
-/* 50 */
-/* 51 */
-/* 52 */
-/* 53 */
-/* 54 */
-/* 55 */
-				int force));
-/* 56 */
-/* 57 */
-				int force));
-/* 58 */
-				char * title));
-/* 59 */
-/* 60 */
-/* 61 */
-/* 62 */
-/* 63 */
-/* 64 */
-/* 65 */
-				int transient));
-/* 66 */
-				Window parent));
-/* 67 */
-/* 68 */
-/* 69 */
-/* 70 */
-/* 71 */
-/* 72 */
-/* 73 */
-/* 74 */
-/* 75 */
-/* 76 */
-/* 77 */
-/* 78 */
-/* 79 */
-/* 80 */
-/* 81 */
-/* 82 */
-/* 83 */
-/* 84 */
-/* 85 */
-/* 86 */
-/* 87 */
-/* 88 */
-/* 89 */
-/* 90 */
-/* 91 */
-/* 92 */
-/* 93 */
-/* 94 */
-/* 95 */
-/* 96 */
-/* 97 */
-/* 98 */
-				char * name));
-/* 99 */
-				char * name));
-/* 100 */
-				char * name));
-/* 101 */
-				char * name));
-/* 102 */
-/* 103 */
-				char * name));
-/* 104 */
-/* 105 */
-/* 106 */
-/* 107 */
-/* 108 */
-/* 109 */
-/* 110 */
-				Tk_Font tkfont));
-/* 111 */
-/* 112 */
-#ifdef __WIN32__
-/* 113 */
-#ifdef MAC_TCL
-/* 113 */
-#ifdef __WIN32__
-/* 114 */
-#ifdef MAC_TCL
-/* 114 */
-#ifdef __WIN32__
-/* 115 */
-#ifdef MAC_TCL
-/* 115 */
-#ifdef __WIN32__
-/* 116 */
-#ifdef MAC_TCL
-/* 116 */
-#ifdef __WIN32__
-/* 117 */
-#ifdef MAC_TCL
-/* 117 */
-#ifdef __WIN32__
-/* 118 */
-				TkRegion rgn));
-#ifdef MAC_TCL
-/* 118 */
-				TkRegion rgn));
-#ifdef __WIN32__
-/* 119 */
-#ifdef MAC_TCL
-/* 119 */
-/* Slot 120 is reserved */
-#ifdef MAC_TCL
-/* 121 */
-				char * source));
-#ifdef MAC_TCL
-/* 122 */
-/* Slot 123 is reserved */
-#ifdef MAC_TCL
-/* 124 */
-/* Slot 125 is reserved */
-/* Slot 126 is reserved */
-/* Slot 127 is reserved */
-/* Slot 128 is reserved */
-/* Slot 130 is reserved */
-/* Slot 131 is reserved */
-/* Slot 133 is reserved */
-/* Slot 134 is reserved */
-/* 135 */
-/* 136 */
-				int force));
-/* 137 */
-EXTERN void		TkpSetKeycodeAndState _ANSI_ARGS_((Tk_Window tkwin,
-				KeySym keySym, XEvent * eventPtr));
-/* 138 */
-EXTERN KeySym		TkpGetKeySym _ANSI_ARGS_((TkDisplay * dispPtr,
-/* 139 */
-EXTERN void		TkpInitKeymapInfo _ANSI_ARGS_((TkDisplay * dispPtr));
-    int magic;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    void (*tkpSetKeycodeAndState) _ANSI_ARGS_((Tk_Window tkwin, KeySym keySym, XEvent * eventPtr)); /* 137 */
-    KeySym (*tkpGetKeySym) _ANSI_ARGS_((TkDisplay * dispPtr, XEvent * eventPtr)); /* 138 */
-    void (*tkpInitKeymapInfo) _ANSI_ARGS_((TkDisplay * dispPtr)); /* 139 */
-} TkIntStubs;
-#ifdef __cplusplus
-extern "C" {
-#endif
-#ifdef __cplusplus
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkBindFree
-#endif
-#ifndef TkBindInit
-#endif
-#endif
-#ifndef TkClipInit
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkpInit
-#define TkpInit \
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkSelInit
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifdef __WIN32__
-#ifndef TkClipBox
-#endif
-#ifdef MAC_TCL
-#ifndef TkClipBox
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#endif
-#endif
-#ifndef TkpSetKeycodeAndState
-#define TkpSetKeycodeAndState \
-	(tkIntStubsPtr->tkpSetKeycodeAndState) /* 137 */
-#endif
-#ifndef TkpGetKeySym
-#define TkpGetKeySym \
-	(tkIntStubsPtr->tkpGetKeySym) /* 138 */
-#endif
-#ifndef TkpInitKeymapInfo
-#define TkpInitKeymapInfo \
-	(tkIntStubsPtr->tkpInitKeymapInfo) /* 139 */
-#endif
Deleted: grass/trunk/visualization/nviz/src/tkIntDecls8.3.h
--- grass/trunk/visualization/nviz/src/tkIntDecls8.3.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkIntDecls8.3.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1483 +0,0 @@
- * tkIntDecls.h --
- * RCS: @(#) $Id$
-#ifdef BUILD_tk
-#endif
-/* 0 */
-/* 1 */
-/* 2 */
-/* 3 */
-/* 4 */
-/* 5 */
-/* 6 */
-/* 7 */
-/* 8 */
-/* 9 */
-				int * yPtr));
-/* 10 */
-				char * script));
-/* 11 */
-/* 12 */
-				XColor bg));
-/* 13 */
-/* 14 */
-/* 15 */
-/* 16 */
-/* 17 */
-/* 18 */
-/* 19 */
-/* 20 */
-				GC outlineGC));
-/* 21 */
-/* 22 */
-/* 23 */
-/* 24 */
-/* 25 */
-/* 26 */
-/* 27 */
-/* 28 */
-/* 29 */
-/* 30 */
-/* 31 */
-/* 32 */
-/* 33 */
-/* 34 */
-/* 35 */
-/* 36 */
-/* 37 */
-/* 38 */
-/* 39 */
-/* 40 */
-/* 41 */
-/* 42 */
-/* 43 */
-/* 44 */
-/* 45 */
-/* 46 */
-/* 47 */
-/* 48 */
-/* 49 */
-/* 50 */
-/* 51 */
-/* 52 */
-/* 53 */
-/* 54 */
-/* 55 */
-				int force));
-/* 56 */
-/* 57 */
-				int force));
-/* 58 */
-				char * title));
-/* 59 */
-/* 60 */
-/* 61 */
-/* 62 */
-/* 63 */
-/* 64 */
-/* 65 */
-				int transient));
-/* 66 */
-				Window parent));
-/* 67 */
-/* 68 */
-/* 69 */
-/* 70 */
-/* 71 */
-/* 72 */
-/* 73 */
-/* 74 */
-/* 75 */
-/* 76 */
-/* 77 */
-/* 78 */
-/* 79 */
-/* 80 */
-/* 81 */
-/* 82 */
-/* 83 */
-/* 84 */
-/* 85 */
-/* 86 */
-/* 87 */
-/* 88 */
-/* 89 */
-/* 90 */
-/* 91 */
-/* 92 */
-/* 93 */
-/* 94 */
-/* 95 */
-/* 96 */
-/* 97 */
-/* 98 */
-				char * name));
-/* 99 */
-				char * name));
-/* 100 */
-				char * name));
-/* 101 */
-				char * name));
-/* 102 */
-/* 103 */
-				char * name));
-/* 104 */
-/* 105 */
-/* 106 */
-/* 107 */
-/* 108 */
-/* 109 */
-/* 110 */
-				Tk_Font tkfont));
-/* 111 */
-/* 112 */
-#ifdef __WIN32__
-/* 113 */
-#ifdef MAC_TCL
-/* 113 */
-#ifdef __WIN32__
-/* 114 */
-#ifdef MAC_TCL
-/* 114 */
-#ifdef __WIN32__
-/* 115 */
-#ifdef MAC_TCL
-/* 115 */
-#ifdef __WIN32__
-/* 116 */
-#ifdef MAC_TCL
-/* 116 */
-#ifdef __WIN32__
-/* 117 */
-#ifdef MAC_TCL
-/* 117 */
-#ifdef __WIN32__
-/* 118 */
-				TkRegion rgn));
-#ifdef MAC_TCL
-/* 118 */
-				TkRegion rgn));
-#ifdef __WIN32__
-/* 119 */
-#ifdef MAC_TCL
-/* 119 */
-#ifdef MAC_TCL
-/* 120 */
-#ifdef MAC_TCL
-/* 121 */
-				char * source));
-#ifdef MAC_TCL
-/* 122 */
-#ifdef MAC_TCL
-/* 123 */
-#ifdef MAC_TCL
-/* 124 */
-#ifdef MAC_TCL
-/* 125 */
-#ifdef MAC_TCL
-/* 126 */
-#ifdef MAC_TCL
-/* 127 */
-#ifdef MAC_TCL
-/* 128 */
-				int state));
-#ifdef MAC_TCL
-/* 130 */
-#ifdef MAC_TCL
-/* 131 */
-#ifdef MAC_TCL
-/* 133 */
-#ifdef MAC_TCL
-/* 134 */
-				int flags));
-/* 135 */
-/* 136 */
-				int force));
-/* 137 */
-/* 138 */
-/* 139 */
-    int magic;
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-} TkIntStubs;
-#ifdef __cplusplus
-extern "C" {
-#endif
-#ifdef __cplusplus
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkBindFree
-#endif
-#ifndef TkBindInit
-#endif
-#endif
-#ifndef TkClipInit
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkpInit
-#define TkpInit \
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkSelInit
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifdef __WIN32__
-#ifndef TkClipBox
-#endif
-#ifdef MAC_TCL
-#ifndef TkClipBox
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#ifndef TkpGetMS
-#define TkpGetMS \
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_TCL
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
Deleted: grass/trunk/visualization/nviz/src/tkIntDecls8.4.9.h
--- grass/trunk/visualization/nviz/src/tkIntDecls8.4.9.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkIntDecls8.4.9.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1563 +0,0 @@
- * tkIntDecls.h --
- *	This file contains the declarations for all unsupported
- *	functions that are exported by the Tk library.  These
- *	interfaces are not guaranteed to remain the same between
- *	versions.  Use at your own risk.
- * Copyright (c) 1998-1999 by Scriptics Corporation.
- * RCS: @(#) $Id$
-#ifndef _TKINTDECLS
-#define _TKINTDECLS
-#ifdef BUILD_tk
-#undef TCL_STORAGE_CLASS
-#define TCL_STORAGE_CLASS DLLEXPORT
-#endif
- * WARNING: This file is automatically generated by the tools/genStubs.tcl
- * script.  Any modifications to the function declarations below should be made
- * in the generic/tkInt.decls script.
-/* !BEGIN!: Do not edit below this line. */
- * Exported function declarations:
-/* 0 */
-EXTERN TkWindow *	TkAllocWindow _ANSI_ARGS_((TkDisplay * dispPtr,
-				int screenNum, TkWindow * parentPtr));
-/* 1 */
-EXTERN void		TkBezierPoints _ANSI_ARGS_((double control[],
-				int numSteps, double * coordPtr));
-/* 2 */
-EXTERN void		TkBezierScreenPoints _ANSI_ARGS_((Tk_Canvas canvas,
-				double control[], int numSteps,
-				XPoint * xPointPtr));
-/* 3 */
-EXTERN void		TkBindDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 4 */
-EXTERN void		TkBindEventProc _ANSI_ARGS_((TkWindow * winPtr,
-				XEvent * eventPtr));
-/* 5 */
-EXTERN void		TkBindFree _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 6 */
-EXTERN void		TkBindInit _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 7 */
-EXTERN void		TkChangeEventWindow _ANSI_ARGS_((XEvent * eventPtr,
-				TkWindow * winPtr));
-/* 8 */
-EXTERN int		TkClipInit _ANSI_ARGS_((Tcl_Interp * interp,
-				TkDisplay * dispPtr));
-/* 9 */
-EXTERN void		TkComputeAnchor _ANSI_ARGS_((Tk_Anchor anchor,
-				Tk_Window tkwin, int padX, int padY,
-				int innerWidth, int innerHeight, int * xPtr,
-				int * yPtr));
-/* 10 */
-EXTERN int		TkCopyAndGlobalEval _ANSI_ARGS_((Tcl_Interp * interp,
-				char * script));
-/* 11 */
-EXTERN unsigned long	TkCreateBindingProcedure _ANSI_ARGS_((
-				ClientData object, CONST char * eventString,
-				ClientData clientData));
-/* 12 */
-				CONST char * source, CONST char * mask,
-				int width, int height, int xHot, int yHot,
-				XColor fg, XColor bg));
-/* 13 */
-/* 14 */
-				CONST char * screenName, char * baseName));
-/* 15 */
-/* 16 */
-/* 17 */
-/* 18 */
-/* 19 */
-/* 20 */
-				GC outlineGC));
-/* 21 */
-/* 22 */
-/* 23 */
-/* 24 */
-/* 25 */
-/* 26 */
-/* 27 */
-/* 28 */
-/* 29 */
-/* 30 */
-/* 31 */
-/* 32 */
-/* 33 */
-EXTERN CONST84_RETURN char * TkGetDefaultScreenName _ANSI_ARGS_((
-				Tcl_Interp * interp, CONST char * screenName));
-/* 34 */
-/* 35 */
-/* 36 */
-/* 37 */
-/* 38 */
-/* 39 */
-/* 40 */
-/* 41 */
-/* 42 */
-/* 43 */
-/* 44 */
-/* 45 */
-/* 46 */
-/* 47 */
-/* 48 */
-/* 49 */
-/* 50 */
-/* 51 */
-/* 52 */
-/* 53 */
-/* 54 */
-/* 55 */
-				int force));
-/* 56 */
-/* 57 */
-				int force));
-/* 58 */
-EXTERN void		TkpDisplayWarning _ANSI_ARGS_((CONST char * msg,
-				CONST char * title));
-/* 59 */
-/* 60 */
-/* 61 */
-/* 62 */
-/* 63 */
-/* 64 */
-/* 65 */
-				int transient));
-/* 66 */
-				Window parent));
-/* 67 */
-/* 68 */
-				CONST char * display_name));
-/* 69 */
-/* 70 */
-/* 71 */
-/* 72 */
-/* 73 */
-/* 74 */
-/* 75 */
-				Tk_Window tkwin, CONST char * string));
-/* 76 */
-/* 77 */
-/* 78 */
-/* 79 */
-/* 80 */
-/* 81 */
-/* 82 */
-/* 83 */
-/* Slot 84 is reserved */
-/* 85 */
-/* 86 */
-/* 87 */
-/* 88 */
-/* 89 */
-/* 90 */
-/* 91 */
-/* 92 */
-/* 93 */
-/* 94 */
-/* 95 */
-/* 96 */
-/* 97 */
-/* 98 */
-				char * name));
-/* 99 */
-				char * name));
-/* 100 */
-				char * name));
-/* 101 */
-				char * name));
-/* 102 */
-/* 103 */
-				char * name));
-/* 104 */
-/* 105 */
-/* 106 */
-/* 107 */
-/* 108 */
-/* 109 */
-/* 110 */
-				Tk_Font tkfont));
-/* 111 */
-				CONST char * dbName, CONST char * className));
-/* 112 */
-#ifdef __WIN32__
-/* 113 */
-#ifdef MAC_TCL
-/* 113 */
-#ifdef MAC_OSX_TK
-/* 113 */
-#endif /* MAC_OSX_TK */
-#ifdef __WIN32__
-/* 114 */
-#ifdef MAC_TCL
-/* 114 */
-#ifdef MAC_OSX_TK
-/* 114 */
-#ifdef __WIN32__
-/* 115 */
-#ifdef MAC_TCL
-/* 115 */
-#ifdef MAC_OSX_TK
-/* 115 */
-#ifdef __WIN32__
-/* 116 */
-#ifdef MAC_TCL
-/* 116 */
-#ifdef MAC_OSX_TK
-/* 116 */
-#ifdef __WIN32__
-/* 117 */
-#ifdef MAC_TCL
-/* 117 */
-#ifdef MAC_OSX_TK
-/* 117 */
-#ifdef __WIN32__
-/* 118 */
-				TkRegion rgn));
-#ifdef MAC_TCL
-/* 118 */
-				TkRegion rgn));
-#ifdef MAC_OSX_TK
-/* 118 */
-				TkRegion rgn));
-#ifdef __WIN32__
-/* 119 */
-#ifdef MAC_TCL
-/* 119 */
-#ifdef MAC_OSX_TK
-/* 119 */
-#ifdef MAC_TCL
-/* 121 */
-				CONST char * source));
-#ifdef MAC_OSX_TK
-/* 121 */
-#ifdef MAC_TCL
-/* 122 */
-#ifdef MAC_OSX_TK
-/* 122 */
-#ifdef MAC_TCL
-/* 124 */
-#ifdef MAC_OSX_TK
-/* 124 */
-/* 135 */
-/* 136 */
-				int force));
-/* 137 */
-/* 138 */
-/* 139 */
-/* 140 */
-EXTERN TkRegion		TkPhotoGetValidRegion _ANSI_ARGS_((
-				Tk_PhotoHandle handle));
-/* 141 */
-EXTERN TkWindow **	TkWmStackorderToplevel _ANSI_ARGS_((
-				TkWindow * parentPtr));
-/* 142 */
-EXTERN void		TkFocusFree _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 143 */
-EXTERN void		TkClipCleanup _ANSI_ARGS_((TkDisplay * dispPtr));
-/* 144 */
-EXTERN void		TkGCCleanup _ANSI_ARGS_((TkDisplay * dispPtr));
-#ifdef __WIN32__
-/* 145 */
-EXTERN void		TkSubtractRegion _ANSI_ARGS_((TkRegion sra,
-#ifdef MAC_TCL
-/* 145 */
-#ifdef MAC_OSX_TK
-/* 145 */
-/* 146 */
-EXTERN void		TkStylePkgInit _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 147 */
-EXTERN void		TkStylePkgFree _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 148 */
-EXTERN Tk_Window	TkToplevelWindowForCommand _ANSI_ARGS_((
-				Tcl_Interp * interp, CONST char * cmdName));
-/* 149 */
-EXTERN CONST Tk_OptionSpec * TkGetOptionSpec _ANSI_ARGS_((CONST char * name,
-				Tk_OptionTable optionTable));
-    int magic;
-    unsigned long (*tkCreateBindingProcedure) _ANSI_ARGS_((Tcl_Interp * interp, Tk_BindingTable bindingTable, ClientData object, CONST char * eventString, TkBindEvalProc * evalProc, TkBindFreeProc * freeProc, ClientData clientData)); /* 11 */
-    TkCursor * (*tkCreateCursorFromData) _ANSI_ARGS_((Tk_Window tkwin, CONST char * source, CONST char * mask, int width, int height, int xHot, int yHot, XColor fg, XColor bg)); /* 12 */
-    Tk_Window (*tkCreateMainWindow) _ANSI_ARGS_((Tcl_Interp * interp, CONST char * screenName, char * baseName)); /* 14 */
-    CONST84_RETURN char * (*tkGetDefaultScreenName) _ANSI_ARGS_((Tcl_Interp * interp, CONST char * screenName)); /* 33 */
-    void (*tkpDisplayWarning) _ANSI_ARGS_((CONST char * msg, CONST char * title)); /* 58 */
-    TkDisplay * (*tkpOpenDisplay) _ANSI_ARGS_((CONST char * display_name)); /* 68 */
-    int (*tkpUseWindow) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, CONST char * string)); /* 75 */
-    void *reserved84;
-    Tcl_Obj * (*tkpGetSystemDefault) _ANSI_ARGS_((Tk_Window tkwin, CONST char * dbName, CONST char * className)); /* 111 */
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-    Pixmap (*tkpCreateNativeBitmap) _ANSI_ARGS_((Display * display, CONST char * source)); /* 121 */
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-    TkRegion (*tkPhotoGetValidRegion) _ANSI_ARGS_((Tk_PhotoHandle handle)); /* 140 */
-    TkWindow ** (*tkWmStackorderToplevel) _ANSI_ARGS_((TkWindow * parentPtr)); /* 141 */
-    void (*tkFocusFree) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 142 */
-    void (*tkClipCleanup) _ANSI_ARGS_((TkDisplay * dispPtr)); /* 143 */
-    void (*tkGCCleanup) _ANSI_ARGS_((TkDisplay * dispPtr)); /* 144 */
-    void *reserved145;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkSubtractRegion) _ANSI_ARGS_((TkRegion sra, TkRegion srcb, TkRegion dr_return)); /* 145 */
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-    void (*tkStylePkgInit) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 146 */
-    void (*tkStylePkgFree) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 147 */
-    Tk_Window (*tkToplevelWindowForCommand) _ANSI_ARGS_((Tcl_Interp * interp, CONST char * cmdName)); /* 148 */
-    CONST Tk_OptionSpec * (*tkGetOptionSpec) _ANSI_ARGS_((CONST char * name, Tk_OptionTable optionTable)); /* 149 */
-} TkIntStubs;
-#ifdef __cplusplus
-extern "C" {
-#endif
-#ifdef __cplusplus
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkBindFree
-#endif
-#ifndef TkBindInit
-#endif
-#endif
-#ifndef TkClipInit
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkpInit
-#define TkpInit \
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkSelInit
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifdef __WIN32__
-#ifndef TkClipBox
-#endif
-#ifdef MAC_TCL
-#ifndef TkClipBox
-#endif
-#ifdef MAC_OSX_TK
-#ifndef TkClipBox
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifndef TkPhotoGetValidRegion
-#define TkPhotoGetValidRegion \
-	(tkIntStubsPtr->tkPhotoGetValidRegion) /* 140 */
-#endif
-#ifndef TkWmStackorderToplevel
-#define TkWmStackorderToplevel \
-	(tkIntStubsPtr->tkWmStackorderToplevel) /* 141 */
-#endif
-#ifndef TkFocusFree
-#define TkFocusFree \
-	(tkIntStubsPtr->tkFocusFree) /* 142 */
-#endif
-#ifndef TkClipCleanup
-#define TkClipCleanup \
-	(tkIntStubsPtr->tkClipCleanup) /* 143 */
-#endif
-#ifndef TkGCCleanup
-#define TkGCCleanup \
-	(tkIntStubsPtr->tkGCCleanup) /* 144 */
-#endif
-#ifdef __WIN32__
-#ifndef TkSubtractRegion
-#define TkSubtractRegion \
-	(tkIntStubsPtr->tkSubtractRegion) /* 145 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifndef TkStylePkgInit
-#define TkStylePkgInit \
-	(tkIntStubsPtr->tkStylePkgInit) /* 146 */
-#endif
-#ifndef TkStylePkgFree
-#define TkStylePkgFree \
-	(tkIntStubsPtr->tkStylePkgFree) /* 147 */
-#endif
-#ifndef TkToplevelWindowForCommand
-#define TkToplevelWindowForCommand \
-	(tkIntStubsPtr->tkToplevelWindowForCommand) /* 148 */
-#endif
-#ifndef TkGetOptionSpec
-#define TkGetOptionSpec \
-	(tkIntStubsPtr->tkGetOptionSpec) /* 149 */
-#endif
Deleted: grass/trunk/visualization/nviz/src/tkIntDecls8.4.h
--- grass/trunk/visualization/nviz/src/tkIntDecls8.4.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkIntDecls8.4.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,1547 +0,0 @@
- * tkIntDecls.h --
- * RCS: @(#) $Id$
-#ifdef BUILD_tk
-#endif
-/* 0 */
-/* 1 */
-/* 2 */
-/* 3 */
-/* 4 */
-/* 5 */
-/* 6 */
-/* 7 */
-/* 8 */
-/* 9 */
-				int * yPtr));
-/* 10 */
-				char * script));
-/* 11 */
-				Tk_BindingTable bindingTable,
-				TkBindEvalProc * evalProc,
-				TkBindFreeProc * freeProc,
-/* 12 */
-EXTERN TkCursor *	TkCreateCursorFromData _ANSI_ARGS_((Tk_Window tkwin,
-/* 13 */
-EXTERN int		TkCreateFrame _ANSI_ARGS_((ClientData clientData,
-				Tcl_Interp * interp, int argc, char ** argv,
-				int toplevel, char * appName));
-/* 14 */
-EXTERN Tk_Window	TkCreateMainWindow _ANSI_ARGS_((Tcl_Interp * interp,
-/* 15 */
-EXTERN Time		TkCurrentTime _ANSI_ARGS_((TkDisplay * dispPtr));
-/* 16 */
-EXTERN void		TkDeleteAllImages _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 17 */
-EXTERN void		TkDoConfigureNotify _ANSI_ARGS_((TkWindow * winPtr));
-/* 18 */
-EXTERN void		TkDrawInsetFocusHighlight _ANSI_ARGS_((
-				Tk_Window tkwin, GC gc, int width,
-				Drawable drawable, int padding));
-/* 19 */
-EXTERN void		TkEventDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 20 */
-EXTERN void		TkFillPolygon _ANSI_ARGS_((Tk_Canvas canvas,
-				double * coordPtr, int numPoints,
-				Display * display, Drawable drawable, GC gc,
-				GC outlineGC));
-/* 21 */
-EXTERN int		TkFindStateNum _ANSI_ARGS_((Tcl_Interp * interp,
-				CONST char * option,
-				CONST TkStateMap * mapPtr,
-				CONST char * strKey));
-/* 22 */
-EXTERN char *		TkFindStateString _ANSI_ARGS_((
-				CONST TkStateMap * mapPtr, int numKey));
-/* 23 */
-EXTERN void		TkFocusDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 24 */
-EXTERN int		TkFocusFilterEvent _ANSI_ARGS_((TkWindow * winPtr,
-/* 25 */
-EXTERN TkWindow *	TkFocusKeyEvent _ANSI_ARGS_((TkWindow * winPtr,
-/* 26 */
-EXTERN void		TkFontPkgInit _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 27 */
-EXTERN void		TkFontPkgFree _ANSI_ARGS_((TkMainInfo * mainPtr));
-/* 28 */
-EXTERN void		TkFreeBindingTags _ANSI_ARGS_((TkWindow * winPtr));
-/* 29 */
-EXTERN void		TkpFreeCursor _ANSI_ARGS_((TkCursor * cursorPtr));
-/* 30 */
-EXTERN char *		TkGetBitmapData _ANSI_ARGS_((Tcl_Interp * interp,
-				char * string, char * fileName,
-				int * widthPtr, int * heightPtr,
-				int * hotXPtr, int * hotYPtr));
-/* 31 */
-EXTERN void		TkGetButtPoints _ANSI_ARGS_((double p1[],
-				double p2[], double width, int project,
-				double m1[], double m2[]));
-/* 32 */
-EXTERN TkCursor *	TkGetCursorByName _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, Tk_Uid string));
-/* 33 */
-/* 34 */
-EXTERN TkDisplay *	TkGetDisplay _ANSI_ARGS_((Display * display));
-/* 35 */
-EXTERN int		TkGetDisplayOf _ANSI_ARGS_((Tcl_Interp * interp,
-				int objc, Tcl_Obj *CONST objv[],
-				Tk_Window * tkwinPtr));
-/* 36 */
-EXTERN TkWindow *	TkGetFocusWin _ANSI_ARGS_((TkWindow * winPtr));
-/* 37 */
-EXTERN int		TkGetInterpNames _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin));
-/* 38 */
-EXTERN int		TkGetMiterPoints _ANSI_ARGS_((double p1[],
-				double p2[], double p3[], double width,
-/* 39 */
-EXTERN void		TkGetPointerCoords _ANSI_ARGS_((Tk_Window tkwin,
-				int * xPtr, int * yPtr));
-/* 40 */
-EXTERN void		TkGetServerInfo _ANSI_ARGS_((Tcl_Interp * interp,
-/* 41 */
-EXTERN void		TkGrabDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 42 */
-EXTERN int		TkGrabState _ANSI_ARGS_((TkWindow * winPtr));
-/* 43 */
-EXTERN void		TkIncludePoint _ANSI_ARGS_((Tk_Item * itemPtr,
-				double * pointPtr));
-/* 44 */
-EXTERN void		TkInOutEvents _ANSI_ARGS_((XEvent * eventPtr,
-				TkWindow * sourcePtr, TkWindow * destPtr,
-				int leaveType, int enterType,
-				Tcl_QueuePosition position));
-/* 45 */
-EXTERN void		TkInstallFrameMenu _ANSI_ARGS_((Tk_Window tkwin));
-/* 46 */
-EXTERN char *		TkKeysymToString _ANSI_ARGS_((KeySym keysym));
-/* 47 */
-EXTERN int		TkLineToArea _ANSI_ARGS_((double end1Ptr[],
-				double end2Ptr[], double rectPtr[]));
-/* 48 */
-EXTERN double		TkLineToPoint _ANSI_ARGS_((double end1Ptr[],
-				double end2Ptr[], double pointPtr[]));
-/* 49 */
-EXTERN int		TkMakeBezierCurve _ANSI_ARGS_((Tk_Canvas canvas,
-				double * pointPtr, int numPoints,
-				int numSteps, XPoint xPoints[],
-				double dblPoints[]));
-/* 50 */
-EXTERN void		TkMakeBezierPostscript _ANSI_ARGS_((
-				Tcl_Interp * interp, Tk_Canvas canvas,
-				double * pointPtr, int numPoints));
-/* 51 */
-EXTERN void		TkOptionClassChanged _ANSI_ARGS_((TkWindow * winPtr));
-/* 52 */
-EXTERN void		TkOptionDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 53 */
-EXTERN int		TkOvalToArea _ANSI_ARGS_((double * ovalPtr,
-				double * rectPtr));
-/* 54 */
-EXTERN double		TkOvalToPoint _ANSI_ARGS_((double ovalPtr[],
-				double width, int filled, double pointPtr[]));
-/* 55 */
-EXTERN int		TkpChangeFocus _ANSI_ARGS_((TkWindow * winPtr,
-				int force));
-/* 56 */
-EXTERN void		TkpCloseDisplay _ANSI_ARGS_((TkDisplay * dispPtr));
-/* 57 */
-EXTERN void		TkpClaimFocus _ANSI_ARGS_((TkWindow * topLevelPtr,
-				int force));
-/* 58 */
-/* 59 */
-EXTERN void		TkpGetAppName _ANSI_ARGS_((Tcl_Interp * interp,
-				Tcl_DString * name));
-/* 60 */
-EXTERN TkWindow *	TkpGetOtherWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 61 */
-EXTERN TkWindow *	TkpGetWrapperWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 62 */
-EXTERN int		TkpInit _ANSI_ARGS_((Tcl_Interp * interp));
-/* 63 */
-EXTERN void		TkpInitializeMenuBindings _ANSI_ARGS_((
-				Tk_BindingTable bindingTable));
-/* 64 */
-EXTERN void		TkpMakeContainer _ANSI_ARGS_((Tk_Window tkwin));
-/* 65 */
-EXTERN void		TkpMakeMenuWindow _ANSI_ARGS_((Tk_Window tkwin,
-				int transient));
-/* 66 */
-EXTERN Window		TkpMakeWindow _ANSI_ARGS_((TkWindow * winPtr,
-				Window parent));
-/* 67 */
-EXTERN void		TkpMenuNotifyToplevelCreate _ANSI_ARGS_((
-				Tcl_Interp * interp1, char * menuName));
-/* 68 */
-EXTERN TkDisplay *	TkpOpenDisplay _ANSI_ARGS_((
-/* 69 */
-EXTERN int		TkPointerEvent _ANSI_ARGS_((XEvent * eventPtr,
-/* 70 */
-EXTERN int		TkPolygonToArea _ANSI_ARGS_((double * polyPtr,
-				int numPoints, double * rectPtr));
-/* 71 */
-EXTERN double		TkPolygonToPoint _ANSI_ARGS_((double * polyPtr,
-				int numPoints, double * pointPtr));
-/* 72 */
-EXTERN int		TkPositionInTree _ANSI_ARGS_((TkWindow * winPtr,
-				TkWindow * treePtr));
-/* 73 */
-EXTERN void		TkpRedirectKeyEvent _ANSI_ARGS_((TkWindow * winPtr,
-/* 74 */
-EXTERN void		TkpSetMainMenubar _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, char * menuName));
-/* 75 */
-EXTERN int		TkpUseWindow _ANSI_ARGS_((Tcl_Interp * interp,
-/* 76 */
-EXTERN int		TkpWindowWasRecentlyDeleted _ANSI_ARGS_((Window win,
-/* 77 */
-EXTERN void		TkQueueEventForAllChildren _ANSI_ARGS_((
-				TkWindow * winPtr, XEvent * eventPtr));
-/* 78 */
-EXTERN int		TkReadBitmapFile _ANSI_ARGS_((Display* display,
-				Drawable d, CONST char* filename,
-				unsigned int* width_return,
-				unsigned int* height_return,
-				Pixmap* bitmap_return, int* x_hot_return,
-				int* y_hot_return));
-/* 79 */
-EXTERN int		TkScrollWindow _ANSI_ARGS_((Tk_Window tkwin, GC gc,
-				int x, int y, int width, int height, int dx,
-				int dy, TkRegion damageRgn));
-/* 80 */
-EXTERN void		TkSelDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 81 */
-EXTERN void		TkSelEventProc _ANSI_ARGS_((Tk_Window tkwin,
-/* 82 */
-EXTERN void		TkSelInit _ANSI_ARGS_((Tk_Window tkwin));
-/* 83 */
-EXTERN void		TkSelPropProc _ANSI_ARGS_((XEvent * eventPtr));
-/* 85 */
-EXTERN void		TkSetWindowMenuBar _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, char * oldMenuName,
-				char * menuName));
-/* 86 */
-EXTERN KeySym		TkStringToKeysym _ANSI_ARGS_((char * name));
-/* 87 */
-EXTERN int		TkThickPolyLineToArea _ANSI_ARGS_((double * coordPtr,
-				int numPoints, double width, int capStyle,
-				int joinStyle, double * rectPtr));
-/* 88 */
-EXTERN void		TkWmAddToColormapWindows _ANSI_ARGS_((
-/* 89 */
-EXTERN void		TkWmDeadWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 90 */
-EXTERN TkWindow *	TkWmFocusToplevel _ANSI_ARGS_((TkWindow * winPtr));
-/* 91 */
-EXTERN void		TkWmMapWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 92 */
-EXTERN void		TkWmNewWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 93 */
-EXTERN void		TkWmProtocolEventProc _ANSI_ARGS_((TkWindow * winPtr,
-				XEvent * evenvPtr));
-/* 94 */
-EXTERN void		TkWmRemoveFromColormapWindows _ANSI_ARGS_((
-/* 95 */
-EXTERN void		TkWmRestackToplevel _ANSI_ARGS_((TkWindow * winPtr,
-				int aboveBelow, TkWindow * otherPtr));
-/* 96 */
-EXTERN void		TkWmSetClass _ANSI_ARGS_((TkWindow * winPtr));
-/* 97 */
-EXTERN void		TkWmUnmapWindow _ANSI_ARGS_((TkWindow * winPtr));
-/* 98 */
-EXTERN Tcl_Obj *	TkDebugBitmap _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 99 */
-EXTERN Tcl_Obj *	TkDebugBorder _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 100 */
-EXTERN Tcl_Obj *	TkDebugCursor _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 101 */
-EXTERN Tcl_Obj *	TkDebugColor _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 102 */
-EXTERN Tcl_Obj *	TkDebugConfig _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_OptionTable table));
-/* 103 */
-EXTERN Tcl_Obj *	TkDebugFont _ANSI_ARGS_((Tk_Window tkwin,
-				char * name));
-/* 104 */
-EXTERN int		TkFindStateNumObj _ANSI_ARGS_((Tcl_Interp * interp,
-				Tcl_Obj * optionPtr,
-				CONST TkStateMap * mapPtr, Tcl_Obj * keyPtr));
-/* 105 */
-EXTERN Tcl_HashTable *	TkGetBitmapPredefTable _ANSI_ARGS_((void));
-/* 106 */
-EXTERN TkDisplay *	TkGetDisplayList _ANSI_ARGS_((void));
-/* 107 */
-EXTERN TkMainInfo *	TkGetMainInfoList _ANSI_ARGS_((void));
-/* 108 */
-EXTERN int		TkGetWindowFromObj _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Window tkwin, Tcl_Obj * objPtr,
-				Tk_Window * windowPtr));
-/* 109 */
-EXTERN char *		TkpGetString _ANSI_ARGS_((TkWindow * winPtr,
-				XEvent * eventPtr, Tcl_DString * dsPtr));
-/* 110 */
-EXTERN void		TkpGetSubFonts _ANSI_ARGS_((Tcl_Interp * interp,
-				Tk_Font tkfont));
-/* 111 */
-EXTERN Tcl_Obj *	TkpGetSystemDefault _ANSI_ARGS_((Tk_Window tkwin,
-/* 112 */
-EXTERN void		TkpMenuThreadInit _ANSI_ARGS_((void));
-#ifdef __WIN32__
-/* 113 */
-EXTERN void		TkClipBox _ANSI_ARGS_((TkRegion rgn,
-				XRectangle* rect_return));
-#endif /* __WIN32__ */
-#ifdef MAC_TCL
-/* 113 */
-#endif /* MAC_TCL */
-#ifdef MAC_OSX_TK
-/* 113 */
-#ifdef __WIN32__
-/* 114 */
-EXTERN TkRegion		TkCreateRegion _ANSI_ARGS_((void));
-#ifdef MAC_TCL
-/* 114 */
-#ifdef MAC_OSX_TK
-/* 114 */
-#ifdef __WIN32__
-/* 115 */
-EXTERN void		TkDestroyRegion _ANSI_ARGS_((TkRegion rgn));
-#ifdef MAC_TCL
-/* 115 */
-#ifdef MAC_OSX_TK
-/* 115 */
-#ifdef __WIN32__
-/* 116 */
-EXTERN void		TkIntersectRegion _ANSI_ARGS_((TkRegion sra,
-				TkRegion srcb, TkRegion dr_return));
-#ifdef MAC_TCL
-/* 116 */
-#ifdef MAC_OSX_TK
-/* 116 */
-#ifdef __WIN32__
-/* 117 */
-EXTERN int		TkRectInRegion _ANSI_ARGS_((TkRegion rgn, int x,
-				int y, unsigned int width,
-				unsigned int height));
-#ifdef MAC_TCL
-/* 117 */
-#ifdef MAC_OSX_TK
-/* 117 */
-#ifdef __WIN32__
-/* 118 */
-EXTERN void		TkSetRegion _ANSI_ARGS_((Display* display, GC gc,
-				TkRegion rgn));
-#ifdef MAC_TCL
-/* 118 */
-				TkRegion rgn));
-#ifdef MAC_OSX_TK
-/* 118 */
-				TkRegion rgn));
-#ifdef __WIN32__
-/* 119 */
-EXTERN void		TkUnionRectWithRegion _ANSI_ARGS_((XRectangle* rect,
-				TkRegion src, TkRegion dr_return));
-#ifdef MAC_TCL
-/* 119 */
-#ifdef MAC_OSX_TK
-/* 119 */
-#ifdef MAC_TCL
-/* 121 */
-#ifdef MAC_OSX_TK
-/* 121 */
-#ifdef MAC_TCL
-/* 122 */
-#ifdef MAC_OSX_TK
-/* 122 */
-#ifdef MAC_TCL
-/* 124 */
-#ifdef MAC_OSX_TK
-/* 124 */
-/* 135 */
-/* 136 */
-				int force));
-/* 137 */
-/* 138 */
-/* 139 */
-/* 140 */
-/* 141 */
-/* 142 */
-/* 143 */
-/* 144 */
-#ifdef __WIN32__
-/* 145 */
-#ifdef MAC_TCL
-/* 145 */
-#ifdef MAC_OSX_TK
-/* 145 */
-/* 146 */
-/* 147 */
-typedef struct TkIntStubs {
-    int magic;
-    struct TkIntStubHooks *hooks;
-    TkWindow * (*tkAllocWindow) _ANSI_ARGS_((TkDisplay * dispPtr, int screenNum, TkWindow * parentPtr)); /* 0 */
-    void (*tkBezierPoints) _ANSI_ARGS_((double control[], int numSteps, double * coordPtr)); /* 1 */
-    void (*tkBezierScreenPoints) _ANSI_ARGS_((Tk_Canvas canvas, double control[], int numSteps, XPoint * xPointPtr)); /* 2 */
-    void (*tkBindDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 3 */
-    void (*tkBindEventProc) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 4 */
-    void (*tkBindFree) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 5 */
-    void (*tkBindInit) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 6 */
-    void (*tkChangeEventWindow) _ANSI_ARGS_((XEvent * eventPtr, TkWindow * winPtr)); /* 7 */
-    int (*tkClipInit) _ANSI_ARGS_((Tcl_Interp * interp, TkDisplay * dispPtr)); /* 8 */
-    void (*tkComputeAnchor) _ANSI_ARGS_((Tk_Anchor anchor, Tk_Window tkwin, int padX, int padY, int innerWidth, int innerHeight, int * xPtr, int * yPtr)); /* 9 */
-    int (*tkCopyAndGlobalEval) _ANSI_ARGS_((Tcl_Interp * interp, char * script)); /* 10 */
-    int (*tkCreateFrame) _ANSI_ARGS_((ClientData clientData, Tcl_Interp * interp, int argc, char ** argv, int toplevel, char * appName)); /* 13 */
-    Time (*tkCurrentTime) _ANSI_ARGS_((TkDisplay * dispPtr)); /* 15 */
-    void (*tkDeleteAllImages) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 16 */
-    void (*tkDoConfigureNotify) _ANSI_ARGS_((TkWindow * winPtr)); /* 17 */
-    void (*tkDrawInsetFocusHighlight) _ANSI_ARGS_((Tk_Window tkwin, GC gc, int width, Drawable drawable, int padding)); /* 18 */
-    void (*tkEventDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 19 */
-    void (*tkFillPolygon) _ANSI_ARGS_((Tk_Canvas canvas, double * coordPtr, int numPoints, Display * display, Drawable drawable, GC gc, GC outlineGC)); /* 20 */
-    int (*tkFindStateNum) _ANSI_ARGS_((Tcl_Interp * interp, CONST char * option, CONST TkStateMap * mapPtr, CONST char * strKey)); /* 21 */
-    char * (*tkFindStateString) _ANSI_ARGS_((CONST TkStateMap * mapPtr, int numKey)); /* 22 */
-    void (*tkFocusDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 23 */
-    int (*tkFocusFilterEvent) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 24 */
-    TkWindow * (*tkFocusKeyEvent) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 25 */
-    void (*tkFontPkgInit) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 26 */
-    void (*tkFontPkgFree) _ANSI_ARGS_((TkMainInfo * mainPtr)); /* 27 */
-    void (*tkFreeBindingTags) _ANSI_ARGS_((TkWindow * winPtr)); /* 28 */
-    void (*tkpFreeCursor) _ANSI_ARGS_((TkCursor * cursorPtr)); /* 29 */
-    char * (*tkGetBitmapData) _ANSI_ARGS_((Tcl_Interp * interp, char * string, char * fileName, int * widthPtr, int * heightPtr, int * hotXPtr, int * hotYPtr)); /* 30 */
-    void (*tkGetButtPoints) _ANSI_ARGS_((double p1[], double p2[], double width, int project, double m1[], double m2[])); /* 31 */
-    TkCursor * (*tkGetCursorByName) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, Tk_Uid string)); /* 32 */
-    TkDisplay * (*tkGetDisplay) _ANSI_ARGS_((Display * display)); /* 34 */
-    int (*tkGetDisplayOf) _ANSI_ARGS_((Tcl_Interp * interp, int objc, Tcl_Obj *CONST objv[], Tk_Window * tkwinPtr)); /* 35 */
-    TkWindow * (*tkGetFocusWin) _ANSI_ARGS_((TkWindow * winPtr)); /* 36 */
-    int (*tkGetInterpNames) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin)); /* 37 */
-    int (*tkGetMiterPoints) _ANSI_ARGS_((double p1[], double p2[], double p3[], double width, double m1[], double m2[])); /* 38 */
-    void (*tkGetPointerCoords) _ANSI_ARGS_((Tk_Window tkwin, int * xPtr, int * yPtr)); /* 39 */
-    void (*tkGetServerInfo) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin)); /* 40 */
-    void (*tkGrabDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 41 */
-    int (*tkGrabState) _ANSI_ARGS_((TkWindow * winPtr)); /* 42 */
-    void (*tkIncludePoint) _ANSI_ARGS_((Tk_Item * itemPtr, double * pointPtr)); /* 43 */
-    void (*tkInOutEvents) _ANSI_ARGS_((XEvent * eventPtr, TkWindow * sourcePtr, TkWindow * destPtr, int leaveType, int enterType, Tcl_QueuePosition position)); /* 44 */
-    void (*tkInstallFrameMenu) _ANSI_ARGS_((Tk_Window tkwin)); /* 45 */
-    char * (*tkKeysymToString) _ANSI_ARGS_((KeySym keysym)); /* 46 */
-    int (*tkLineToArea) _ANSI_ARGS_((double end1Ptr[], double end2Ptr[], double rectPtr[])); /* 47 */
-    double (*tkLineToPoint) _ANSI_ARGS_((double end1Ptr[], double end2Ptr[], double pointPtr[])); /* 48 */
-    int (*tkMakeBezierCurve) _ANSI_ARGS_((Tk_Canvas canvas, double * pointPtr, int numPoints, int numSteps, XPoint xPoints[], double dblPoints[])); /* 49 */
-    void (*tkMakeBezierPostscript) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Canvas canvas, double * pointPtr, int numPoints)); /* 50 */
-    void (*tkOptionClassChanged) _ANSI_ARGS_((TkWindow * winPtr)); /* 51 */
-    void (*tkOptionDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 52 */
-    int (*tkOvalToArea) _ANSI_ARGS_((double * ovalPtr, double * rectPtr)); /* 53 */
-    double (*tkOvalToPoint) _ANSI_ARGS_((double ovalPtr[], double width, int filled, double pointPtr[])); /* 54 */
-    int (*tkpChangeFocus) _ANSI_ARGS_((TkWindow * winPtr, int force)); /* 55 */
-    void (*tkpCloseDisplay) _ANSI_ARGS_((TkDisplay * dispPtr)); /* 56 */
-    void (*tkpClaimFocus) _ANSI_ARGS_((TkWindow * topLevelPtr, int force)); /* 57 */
-    void (*tkpGetAppName) _ANSI_ARGS_((Tcl_Interp * interp, Tcl_DString * name)); /* 59 */
-    TkWindow * (*tkpGetOtherWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 60 */
-    TkWindow * (*tkpGetWrapperWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 61 */
-    int (*tkpInit) _ANSI_ARGS_((Tcl_Interp * interp)); /* 62 */
-    void (*tkpInitializeMenuBindings) _ANSI_ARGS_((Tcl_Interp * interp, Tk_BindingTable bindingTable)); /* 63 */
-    void (*tkpMakeContainer) _ANSI_ARGS_((Tk_Window tkwin)); /* 64 */
-    void (*tkpMakeMenuWindow) _ANSI_ARGS_((Tk_Window tkwin, int transient)); /* 65 */
-    Window (*tkpMakeWindow) _ANSI_ARGS_((TkWindow * winPtr, Window parent)); /* 66 */
-    void (*tkpMenuNotifyToplevelCreate) _ANSI_ARGS_((Tcl_Interp * interp1, char * menuName)); /* 67 */
-    int (*tkPointerEvent) _ANSI_ARGS_((XEvent * eventPtr, TkWindow * winPtr)); /* 69 */
-    int (*tkPolygonToArea) _ANSI_ARGS_((double * polyPtr, int numPoints, double * rectPtr)); /* 70 */
-    double (*tkPolygonToPoint) _ANSI_ARGS_((double * polyPtr, int numPoints, double * pointPtr)); /* 71 */
-    int (*tkPositionInTree) _ANSI_ARGS_((TkWindow * winPtr, TkWindow * treePtr)); /* 72 */
-    void (*tkpRedirectKeyEvent) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 73 */
-    void (*tkpSetMainMenubar) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, char * menuName)); /* 74 */
-    int (*tkpWindowWasRecentlyDeleted) _ANSI_ARGS_((Window win, TkDisplay * dispPtr)); /* 76 */
-    void (*tkQueueEventForAllChildren) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr)); /* 77 */
-    int (*tkReadBitmapFile) _ANSI_ARGS_((Display* display, Drawable d, CONST char* filename, unsigned int* width_return, unsigned int* height_return, Pixmap* bitmap_return, int* x_hot_return, int* y_hot_return)); /* 78 */
-    int (*tkScrollWindow) _ANSI_ARGS_((Tk_Window tkwin, GC gc, int x, int y, int width, int height, int dx, int dy, TkRegion damageRgn)); /* 79 */
-    void (*tkSelDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 80 */
-    void (*tkSelEventProc) _ANSI_ARGS_((Tk_Window tkwin, XEvent * eventPtr)); /* 81 */
-    void (*tkSelInit) _ANSI_ARGS_((Tk_Window tkwin)); /* 82 */
-    void (*tkSelPropProc) _ANSI_ARGS_((XEvent * eventPtr)); /* 83 */
-    void *reserved84;
-    void (*tkSetWindowMenuBar) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, char * oldMenuName, char * menuName)); /* 85 */
-    KeySym (*tkStringToKeysym) _ANSI_ARGS_((char * name)); /* 86 */
-    int (*tkThickPolyLineToArea) _ANSI_ARGS_((double * coordPtr, int numPoints, double width, int capStyle, int joinStyle, double * rectPtr)); /* 87 */
-    void (*tkWmAddToColormapWindows) _ANSI_ARGS_((TkWindow * winPtr)); /* 88 */
-    void (*tkWmDeadWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 89 */
-    TkWindow * (*tkWmFocusToplevel) _ANSI_ARGS_((TkWindow * winPtr)); /* 90 */
-    void (*tkWmMapWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 91 */
-    void (*tkWmNewWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 92 */
-    void (*tkWmProtocolEventProc) _ANSI_ARGS_((TkWindow * winPtr, XEvent * evenvPtr)); /* 93 */
-    void (*tkWmRemoveFromColormapWindows) _ANSI_ARGS_((TkWindow * winPtr)); /* 94 */
-    void (*tkWmRestackToplevel) _ANSI_ARGS_((TkWindow * winPtr, int aboveBelow, TkWindow * otherPtr)); /* 95 */
-    void (*tkWmSetClass) _ANSI_ARGS_((TkWindow * winPtr)); /* 96 */
-    void (*tkWmUnmapWindow) _ANSI_ARGS_((TkWindow * winPtr)); /* 97 */
-    Tcl_Obj * (*tkDebugBitmap) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 98 */
-    Tcl_Obj * (*tkDebugBorder) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 99 */
-    Tcl_Obj * (*tkDebugCursor) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 100 */
-    Tcl_Obj * (*tkDebugColor) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 101 */
-    Tcl_Obj * (*tkDebugConfig) _ANSI_ARGS_((Tcl_Interp * interp, Tk_OptionTable table)); /* 102 */
-    Tcl_Obj * (*tkDebugFont) _ANSI_ARGS_((Tk_Window tkwin, char * name)); /* 103 */
-    int (*tkFindStateNumObj) _ANSI_ARGS_((Tcl_Interp * interp, Tcl_Obj * optionPtr, CONST TkStateMap * mapPtr, Tcl_Obj * keyPtr)); /* 104 */
-    Tcl_HashTable * (*tkGetBitmapPredefTable) _ANSI_ARGS_((void)); /* 105 */
-    TkDisplay * (*tkGetDisplayList) _ANSI_ARGS_((void)); /* 106 */
-    TkMainInfo * (*tkGetMainInfoList) _ANSI_ARGS_((void)); /* 107 */
-    int (*tkGetWindowFromObj) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Window tkwin, Tcl_Obj * objPtr, Tk_Window * windowPtr)); /* 108 */
-    char * (*tkpGetString) _ANSI_ARGS_((TkWindow * winPtr, XEvent * eventPtr, Tcl_DString * dsPtr)); /* 109 */
-    void (*tkpGetSubFonts) _ANSI_ARGS_((Tcl_Interp * interp, Tk_Font tkfont)); /* 110 */
-    void (*tkpMenuThreadInit) _ANSI_ARGS_((void)); /* 112 */
-#if !defined(__WIN32__) && !defined(MAC_TCL) /* UNIX */
-    void *reserved113;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkClipBox) _ANSI_ARGS_((TkRegion rgn, XRectangle* rect_return)); /* 113 */
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-    void *reserved114;
-#endif /* UNIX */
-#ifdef __WIN32__
-    TkRegion (*tkCreateRegion) _ANSI_ARGS_((void)); /* 114 */
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-    void *reserved115;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkDestroyRegion) _ANSI_ARGS_((TkRegion rgn)); /* 115 */
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-    void *reserved116;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkIntersectRegion) _ANSI_ARGS_((TkRegion sra, TkRegion srcb, TkRegion dr_return)); /* 116 */
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-    void *reserved117;
-#endif /* UNIX */
-#ifdef __WIN32__
-    int (*tkRectInRegion) _ANSI_ARGS_((TkRegion rgn, int x, int y, unsigned int width, unsigned int height)); /* 117 */
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-    void *reserved118;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkSetRegion) _ANSI_ARGS_((Display* display, GC gc, TkRegion rgn)); /* 118 */
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-    void *reserved119;
-#endif /* UNIX */
-#ifdef __WIN32__
-    void (*tkUnionRectWithRegion) _ANSI_ARGS_((XRectangle* rect, TkRegion src, TkRegion dr_return)); /* 119 */
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-#endif /* UNIX */
-#ifdef __WIN32__
-#ifdef MAC_TCL
-#ifdef MAC_OSX_TK
-} TkIntStubs;
-#ifdef __cplusplus
-extern "C" {
-#endif
-extern TkIntStubs *tkIntStubsPtr;
-#ifdef __cplusplus
-#endif
-#if defined(USE_TK_STUBS) && !defined(USE_TK_STUB_PROCS)
- * Inline function declarations:
-#ifndef TkAllocWindow
-#define TkAllocWindow \
-	(tkIntStubsPtr->tkAllocWindow) /* 0 */
-#endif
-#ifndef TkBezierPoints
-#define TkBezierPoints \
-	(tkIntStubsPtr->tkBezierPoints) /* 1 */
-#endif
-#ifndef TkBezierScreenPoints
-#define TkBezierScreenPoints \
-	(tkIntStubsPtr->tkBezierScreenPoints) /* 2 */
-#endif
-#ifndef TkBindDeadWindow
-#define TkBindDeadWindow \
-	(tkIntStubsPtr->tkBindDeadWindow) /* 3 */
-#endif
-#ifndef TkBindEventProc
-#define TkBindEventProc \
-	(tkIntStubsPtr->tkBindEventProc) /* 4 */
-#endif
-#ifndef TkBindFree
-#define TkBindFree \
-	(tkIntStubsPtr->tkBindFree) /* 5 */
-#endif
-#ifndef TkBindInit
-#define TkBindInit \
-	(tkIntStubsPtr->tkBindInit) /* 6 */
-#endif
-#ifndef TkChangeEventWindow
-#define TkChangeEventWindow \
-	(tkIntStubsPtr->tkChangeEventWindow) /* 7 */
-#endif
-#ifndef TkClipInit
-#define TkClipInit \
-	(tkIntStubsPtr->tkClipInit) /* 8 */
-#endif
-#ifndef TkComputeAnchor
-#define TkComputeAnchor \
-	(tkIntStubsPtr->tkComputeAnchor) /* 9 */
-#endif
-#ifndef TkCopyAndGlobalEval
-#define TkCopyAndGlobalEval \
-	(tkIntStubsPtr->tkCopyAndGlobalEval) /* 10 */
-#endif
-#ifndef TkCreateBindingProcedure
-#define TkCreateBindingProcedure \
-	(tkIntStubsPtr->tkCreateBindingProcedure) /* 11 */
-#endif
-#ifndef TkCreateCursorFromData
-#define TkCreateCursorFromData \
-	(tkIntStubsPtr->tkCreateCursorFromData) /* 12 */
-#endif
-#ifndef TkCreateFrame
-#define TkCreateFrame \
-	(tkIntStubsPtr->tkCreateFrame) /* 13 */
-#endif
-#ifndef TkCreateMainWindow
-#define TkCreateMainWindow \
-	(tkIntStubsPtr->tkCreateMainWindow) /* 14 */
-#endif
-#ifndef TkCurrentTime
-#define TkCurrentTime \
-	(tkIntStubsPtr->tkCurrentTime) /* 15 */
-#endif
-#ifndef TkDeleteAllImages
-#define TkDeleteAllImages \
-	(tkIntStubsPtr->tkDeleteAllImages) /* 16 */
-#endif
-#ifndef TkDoConfigureNotify
-#define TkDoConfigureNotify \
-	(tkIntStubsPtr->tkDoConfigureNotify) /* 17 */
-#endif
-#ifndef TkDrawInsetFocusHighlight
-#define TkDrawInsetFocusHighlight \
-	(tkIntStubsPtr->tkDrawInsetFocusHighlight) /* 18 */
-#endif
-#ifndef TkEventDeadWindow
-#define TkEventDeadWindow \
-	(tkIntStubsPtr->tkEventDeadWindow) /* 19 */
-#endif
-#ifndef TkFillPolygon
-#define TkFillPolygon \
-	(tkIntStubsPtr->tkFillPolygon) /* 20 */
-#endif
-#ifndef TkFindStateNum
-#define TkFindStateNum \
-	(tkIntStubsPtr->tkFindStateNum) /* 21 */
-#endif
-#ifndef TkFindStateString
-#define TkFindStateString \
-	(tkIntStubsPtr->tkFindStateString) /* 22 */
-#endif
-#ifndef TkFocusDeadWindow
-#define TkFocusDeadWindow \
-	(tkIntStubsPtr->tkFocusDeadWindow) /* 23 */
-#endif
-#ifndef TkFocusFilterEvent
-#define TkFocusFilterEvent \
-	(tkIntStubsPtr->tkFocusFilterEvent) /* 24 */
-#endif
-#ifndef TkFocusKeyEvent
-#define TkFocusKeyEvent \
-	(tkIntStubsPtr->tkFocusKeyEvent) /* 25 */
-#endif
-#ifndef TkFontPkgInit
-#define TkFontPkgInit \
-	(tkIntStubsPtr->tkFontPkgInit) /* 26 */
-#endif
-#ifndef TkFontPkgFree
-#define TkFontPkgFree \
-	(tkIntStubsPtr->tkFontPkgFree) /* 27 */
-#endif
-#ifndef TkFreeBindingTags
-#define TkFreeBindingTags \
-	(tkIntStubsPtr->tkFreeBindingTags) /* 28 */
-#endif
-#ifndef TkpFreeCursor
-#define TkpFreeCursor \
-	(tkIntStubsPtr->tkpFreeCursor) /* 29 */
-#endif
-#ifndef TkGetBitmapData
-#define TkGetBitmapData \
-	(tkIntStubsPtr->tkGetBitmapData) /* 30 */
-#endif
-#ifndef TkGetButtPoints
-#define TkGetButtPoints \
-	(tkIntStubsPtr->tkGetButtPoints) /* 31 */
-#endif
-#ifndef TkGetCursorByName
-#define TkGetCursorByName \
-	(tkIntStubsPtr->tkGetCursorByName) /* 32 */
-#endif
-#ifndef TkGetDefaultScreenName
-#define TkGetDefaultScreenName \
-	(tkIntStubsPtr->tkGetDefaultScreenName) /* 33 */
-#endif
-#ifndef TkGetDisplay
-#define TkGetDisplay \
-	(tkIntStubsPtr->tkGetDisplay) /* 34 */
-#endif
-#ifndef TkGetDisplayOf
-#define TkGetDisplayOf \
-	(tkIntStubsPtr->tkGetDisplayOf) /* 35 */
-#endif
-#ifndef TkGetFocusWin
-#define TkGetFocusWin \
-	(tkIntStubsPtr->tkGetFocusWin) /* 36 */
-#endif
-#ifndef TkGetInterpNames
-#define TkGetInterpNames \
-	(tkIntStubsPtr->tkGetInterpNames) /* 37 */
-#endif
-#ifndef TkGetMiterPoints
-#define TkGetMiterPoints \
-	(tkIntStubsPtr->tkGetMiterPoints) /* 38 */
-#endif
-#ifndef TkGetPointerCoords
-#define TkGetPointerCoords \
-	(tkIntStubsPtr->tkGetPointerCoords) /* 39 */
-#endif
-#ifndef TkGetServerInfo
-#define TkGetServerInfo \
-	(tkIntStubsPtr->tkGetServerInfo) /* 40 */
-#endif
-#ifndef TkGrabDeadWindow
-#define TkGrabDeadWindow \
-	(tkIntStubsPtr->tkGrabDeadWindow) /* 41 */
-#endif
-#ifndef TkGrabState
-#define TkGrabState \
-	(tkIntStubsPtr->tkGrabState) /* 42 */
-#endif
-#ifndef TkIncludePoint
-#define TkIncludePoint \
-	(tkIntStubsPtr->tkIncludePoint) /* 43 */
-#endif
-#ifndef TkInOutEvents
-#define TkInOutEvents \
-	(tkIntStubsPtr->tkInOutEvents) /* 44 */
-#endif
-#ifndef TkInstallFrameMenu
-#define TkInstallFrameMenu \
-	(tkIntStubsPtr->tkInstallFrameMenu) /* 45 */
-#endif
-#ifndef TkKeysymToString
-#define TkKeysymToString \
-	(tkIntStubsPtr->tkKeysymToString) /* 46 */
-#endif
-#ifndef TkLineToArea
-#define TkLineToArea \
-	(tkIntStubsPtr->tkLineToArea) /* 47 */
-#endif
-#ifndef TkLineToPoint
-#define TkLineToPoint \
-	(tkIntStubsPtr->tkLineToPoint) /* 48 */
-#endif
-#ifndef TkMakeBezierCurve
-#define TkMakeBezierCurve \
-	(tkIntStubsPtr->tkMakeBezierCurve) /* 49 */
-#endif
-#ifndef TkMakeBezierPostscript
-#define TkMakeBezierPostscript \
-	(tkIntStubsPtr->tkMakeBezierPostscript) /* 50 */
-#endif
-#ifndef TkOptionClassChanged
-#define TkOptionClassChanged \
-	(tkIntStubsPtr->tkOptionClassChanged) /* 51 */
-#endif
-#ifndef TkOptionDeadWindow
-#define TkOptionDeadWindow \
-	(tkIntStubsPtr->tkOptionDeadWindow) /* 52 */
-#endif
-#ifndef TkOvalToArea
-#define TkOvalToArea \
-	(tkIntStubsPtr->tkOvalToArea) /* 53 */
-#endif
-#ifndef TkOvalToPoint
-#define TkOvalToPoint \
-	(tkIntStubsPtr->tkOvalToPoint) /* 54 */
-#endif
-#ifndef TkpChangeFocus
-#define TkpChangeFocus \
-	(tkIntStubsPtr->tkpChangeFocus) /* 55 */
-#endif
-#ifndef TkpCloseDisplay
-#define TkpCloseDisplay \
-	(tkIntStubsPtr->tkpCloseDisplay) /* 56 */
-#endif
-#ifndef TkpClaimFocus
-#define TkpClaimFocus \
-	(tkIntStubsPtr->tkpClaimFocus) /* 57 */
-#endif
-#ifndef TkpDisplayWarning
-#define TkpDisplayWarning \
-	(tkIntStubsPtr->tkpDisplayWarning) /* 58 */
-#endif
-#ifndef TkpGetAppName
-#define TkpGetAppName \
-	(tkIntStubsPtr->tkpGetAppName) /* 59 */
-#endif
-#ifndef TkpGetOtherWindow
-#define TkpGetOtherWindow \
-	(tkIntStubsPtr->tkpGetOtherWindow) /* 60 */
-#endif
-#ifndef TkpGetWrapperWindow
-#define TkpGetWrapperWindow \
-	(tkIntStubsPtr->tkpGetWrapperWindow) /* 61 */
-#endif
-#ifndef TkpInit
-#define TkpInit \
-	(tkIntStubsPtr->tkpInit) /* 62 */
-#endif
-#ifndef TkpInitializeMenuBindings
-#define TkpInitializeMenuBindings \
-	(tkIntStubsPtr->tkpInitializeMenuBindings) /* 63 */
-#endif
-#ifndef TkpMakeContainer
-#define TkpMakeContainer \
-	(tkIntStubsPtr->tkpMakeContainer) /* 64 */
-#endif
-#ifndef TkpMakeMenuWindow
-#define TkpMakeMenuWindow \
-	(tkIntStubsPtr->tkpMakeMenuWindow) /* 65 */
-#endif
-#ifndef TkpMakeWindow
-#define TkpMakeWindow \
-	(tkIntStubsPtr->tkpMakeWindow) /* 66 */
-#endif
-#ifndef TkpMenuNotifyToplevelCreate
-#define TkpMenuNotifyToplevelCreate \
-	(tkIntStubsPtr->tkpMenuNotifyToplevelCreate) /* 67 */
-#endif
-#ifndef TkpOpenDisplay
-#define TkpOpenDisplay \
-	(tkIntStubsPtr->tkpOpenDisplay) /* 68 */
-#endif
-#ifndef TkPointerEvent
-#define TkPointerEvent \
-	(tkIntStubsPtr->tkPointerEvent) /* 69 */
-#endif
-#ifndef TkPolygonToArea
-#define TkPolygonToArea \
-	(tkIntStubsPtr->tkPolygonToArea) /* 70 */
-#endif
-#ifndef TkPolygonToPoint
-#define TkPolygonToPoint \
-	(tkIntStubsPtr->tkPolygonToPoint) /* 71 */
-#endif
-#ifndef TkPositionInTree
-#define TkPositionInTree \
-	(tkIntStubsPtr->tkPositionInTree) /* 72 */
-#endif
-#ifndef TkpRedirectKeyEvent
-#define TkpRedirectKeyEvent \
-	(tkIntStubsPtr->tkpRedirectKeyEvent) /* 73 */
-#endif
-#ifndef TkpSetMainMenubar
-#define TkpSetMainMenubar \
-	(tkIntStubsPtr->tkpSetMainMenubar) /* 74 */
-#endif
-#ifndef TkpUseWindow
-#define TkpUseWindow \
-	(tkIntStubsPtr->tkpUseWindow) /* 75 */
-#endif
-#ifndef TkpWindowWasRecentlyDeleted
-#define TkpWindowWasRecentlyDeleted \
-	(tkIntStubsPtr->tkpWindowWasRecentlyDeleted) /* 76 */
-#endif
-#ifndef TkQueueEventForAllChildren
-#define TkQueueEventForAllChildren \
-	(tkIntStubsPtr->tkQueueEventForAllChildren) /* 77 */
-#endif
-#ifndef TkReadBitmapFile
-#define TkReadBitmapFile \
-	(tkIntStubsPtr->tkReadBitmapFile) /* 78 */
-#endif
-#ifndef TkScrollWindow
-#define TkScrollWindow \
-	(tkIntStubsPtr->tkScrollWindow) /* 79 */
-#endif
-#ifndef TkSelDeadWindow
-#define TkSelDeadWindow \
-	(tkIntStubsPtr->tkSelDeadWindow) /* 80 */
-#endif
-#ifndef TkSelEventProc
-#define TkSelEventProc \
-	(tkIntStubsPtr->tkSelEventProc) /* 81 */
-#endif
-#ifndef TkSelInit
-#define TkSelInit \
-	(tkIntStubsPtr->tkSelInit) /* 82 */
-#endif
-#ifndef TkSelPropProc
-#define TkSelPropProc \
-	(tkIntStubsPtr->tkSelPropProc) /* 83 */
-#endif
-#ifndef TkSetWindowMenuBar
-#define TkSetWindowMenuBar \
-	(tkIntStubsPtr->tkSetWindowMenuBar) /* 85 */
-#endif
-#ifndef TkStringToKeysym
-#define TkStringToKeysym \
-	(tkIntStubsPtr->tkStringToKeysym) /* 86 */
-#endif
-#ifndef TkThickPolyLineToArea
-#define TkThickPolyLineToArea \
-	(tkIntStubsPtr->tkThickPolyLineToArea) /* 87 */
-#endif
-#ifndef TkWmAddToColormapWindows
-#define TkWmAddToColormapWindows \
-	(tkIntStubsPtr->tkWmAddToColormapWindows) /* 88 */
-#endif
-#ifndef TkWmDeadWindow
-#define TkWmDeadWindow \
-	(tkIntStubsPtr->tkWmDeadWindow) /* 89 */
-#endif
-#ifndef TkWmFocusToplevel
-#define TkWmFocusToplevel \
-	(tkIntStubsPtr->tkWmFocusToplevel) /* 90 */
-#endif
-#ifndef TkWmMapWindow
-#define TkWmMapWindow \
-	(tkIntStubsPtr->tkWmMapWindow) /* 91 */
-#endif
-#ifndef TkWmNewWindow
-#define TkWmNewWindow \
-	(tkIntStubsPtr->tkWmNewWindow) /* 92 */
-#endif
-#ifndef TkWmProtocolEventProc
-#define TkWmProtocolEventProc \
-	(tkIntStubsPtr->tkWmProtocolEventProc) /* 93 */
-#endif
-#ifndef TkWmRemoveFromColormapWindows
-#define TkWmRemoveFromColormapWindows \
-	(tkIntStubsPtr->tkWmRemoveFromColormapWindows) /* 94 */
-#endif
-#ifndef TkWmRestackToplevel
-#define TkWmRestackToplevel \
-	(tkIntStubsPtr->tkWmRestackToplevel) /* 95 */
-#endif
-#ifndef TkWmSetClass
-#define TkWmSetClass \
-	(tkIntStubsPtr->tkWmSetClass) /* 96 */
-#endif
-#ifndef TkWmUnmapWindow
-#define TkWmUnmapWindow \
-	(tkIntStubsPtr->tkWmUnmapWindow) /* 97 */
-#endif
-#ifndef TkDebugBitmap
-#define TkDebugBitmap \
-	(tkIntStubsPtr->tkDebugBitmap) /* 98 */
-#endif
-#ifndef TkDebugBorder
-#define TkDebugBorder \
-	(tkIntStubsPtr->tkDebugBorder) /* 99 */
-#endif
-#ifndef TkDebugCursor
-#define TkDebugCursor \
-	(tkIntStubsPtr->tkDebugCursor) /* 100 */
-#endif
-#ifndef TkDebugColor
-#define TkDebugColor \
-	(tkIntStubsPtr->tkDebugColor) /* 101 */
-#endif
-#ifndef TkDebugConfig
-#define TkDebugConfig \
-	(tkIntStubsPtr->tkDebugConfig) /* 102 */
-#endif
-#ifndef TkDebugFont
-#define TkDebugFont \
-	(tkIntStubsPtr->tkDebugFont) /* 103 */
-#endif
-#ifndef TkFindStateNumObj
-#define TkFindStateNumObj \
-	(tkIntStubsPtr->tkFindStateNumObj) /* 104 */
-#endif
-#ifndef TkGetBitmapPredefTable
-#define TkGetBitmapPredefTable \
-	(tkIntStubsPtr->tkGetBitmapPredefTable) /* 105 */
-#endif
-#ifndef TkGetDisplayList
-#define TkGetDisplayList \
-	(tkIntStubsPtr->tkGetDisplayList) /* 106 */
-#endif
-#ifndef TkGetMainInfoList
-#define TkGetMainInfoList \
-	(tkIntStubsPtr->tkGetMainInfoList) /* 107 */
-#endif
-#ifndef TkGetWindowFromObj
-#define TkGetWindowFromObj \
-	(tkIntStubsPtr->tkGetWindowFromObj) /* 108 */
-#endif
-#ifndef TkpGetString
-#define TkpGetString \
-	(tkIntStubsPtr->tkpGetString) /* 109 */
-#endif
-#ifndef TkpGetSubFonts
-#define TkpGetSubFonts \
-	(tkIntStubsPtr->tkpGetSubFonts) /* 110 */
-#endif
-#ifndef TkpGetSystemDefault
-#define TkpGetSystemDefault \
-	(tkIntStubsPtr->tkpGetSystemDefault) /* 111 */
-#endif
-#ifndef TkpMenuThreadInit
-#define TkpMenuThreadInit \
-	(tkIntStubsPtr->tkpMenuThreadInit) /* 112 */
-#endif
-#ifdef __WIN32__
-#ifndef TkClipBox
-#define TkClipBox \
-	(tkIntStubsPtr->tkClipBox) /* 113 */
-#endif
-#ifdef MAC_TCL
-#ifndef TkClipBox
-#endif
-#ifdef MAC_OSX_TK
-#ifndef TkClipBox
-#endif
-#ifdef __WIN32__
-#ifndef TkCreateRegion
-#define TkCreateRegion \
-	(tkIntStubsPtr->tkCreateRegion) /* 114 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#ifndef TkDestroyRegion
-#define TkDestroyRegion \
-	(tkIntStubsPtr->tkDestroyRegion) /* 115 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#ifndef TkIntersectRegion
-#define TkIntersectRegion \
-	(tkIntStubsPtr->tkIntersectRegion) /* 116 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#ifndef TkRectInRegion
-#define TkRectInRegion \
-	(tkIntStubsPtr->tkRectInRegion) /* 117 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#ifndef TkSetRegion
-#define TkSetRegion \
-	(tkIntStubsPtr->tkSetRegion) /* 118 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef __WIN32__
-#ifndef TkUnionRectWithRegion
-#define TkUnionRectWithRegion \
-	(tkIntStubsPtr->tkUnionRectWithRegion) /* 119 */
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef MAC_TCL
-#ifndef TkpCreateNativeBitmap
-#define TkpCreateNativeBitmap \
-	(tkIntStubsPtr->tkpCreateNativeBitmap) /* 121 */
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef MAC_TCL
-#ifndef TkpDefineNativeBitmaps
-#define TkpDefineNativeBitmaps \
-	(tkIntStubsPtr->tkpDefineNativeBitmaps) /* 122 */
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#ifdef MAC_TCL
-#ifndef TkpGetNativeAppBitmap
-#define TkpGetNativeAppBitmap \
-	(tkIntStubsPtr->tkpGetNativeAppBitmap) /* 124 */
-#endif
-#ifdef MAC_OSX_TK
-#endif
-/* Slot 129 is reserved */
-/* Slot 132 is reserved */
-#ifndef TkpDrawHighlightBorder
-#define TkpDrawHighlightBorder \
-	(tkIntStubsPtr->tkpDrawHighlightBorder) /* 135 */
-#endif
-#ifndef TkSetFocusWin
-#define TkSetFocusWin \
-	(tkIntStubsPtr->tkSetFocusWin) /* 136 */
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#endif
-#ifdef __WIN32__
-#endif
-#ifdef MAC_TCL
-#endif
-#ifdef MAC_OSX_TK
-#endif
-#endif
-#endif
-#endif /* defined(USE_TK_STUBS) && !defined(USE_TK_STUB_PROCS) */
-/* !END!: Do not edit above this line. */
-#define TCL_STORAGE_CLASS DLLIMPORT
-#endif /* _TKINTDECLS */
Deleted: grass/trunk/visualization/nviz/src/tkWinInt.h
--- grass/trunk/visualization/nviz/src/tkWinInt.h	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/tkWinInt.h	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,196 +0,0 @@
- * tkWinInt.h --
- *	This file contains declarations that are shared among the
- *	Windows-specific parts of Tk, but aren't used by the rest of
- *	Tk.
- * Copyright (c) 1995 Sun Microsystems, Inc.
- * See the file "license.terms" for information on usage and redistribution
- * of this file, and for a DISCLAIMER OF ALL WARRANTIES.
- * SCCS: @(#) tkWinInt.h 1.33 97/05/20 17:00:35
-#ifndef _TKWININT
-#define _TKWININT
-#ifndef _TKINT
-#include "tkInt.h"
-#endif
- * Include platform specific public interfaces.
-#ifndef _TKWIN
-#include "tkWin.h"
-#endif
- * Define constants missing from older Win32 SDK header files.
-#ifndef WS_EX_TOOLWINDOW
-#define WS_EX_TOOLWINDOW	0x00000080L
-#endif
-/* MN: not needed for NVIZ 9/2001 */
-/* typedef struct TkFontAttributes TkFontAttributes; */
- * The TkWinDCState is used to save the state of a device context
- * so that it can be restored later.
-typedef struct TkWinDCState {
-    HPALETTE palette;
-} TkWinDCState;
- * The TkWinDrawable is the internal implementation of an X Drawable (either
- * a Window or a Pixmap).  The following constants define the valid Drawable
- * types.
-#define TWD_BITMAP	1
-#define TWD_WINDOW	2
-#define TWD_WINDC	3
-typedef struct {
-    int type;
-    HWND handle;
-    TkWindow *winPtr;
-} TkWinWindow;
-typedef struct {
-    int type;
-    HBITMAP handle;
-    Colormap colormap;
-    int depth;
-} TkWinBitmap;
-typedef struct {
-    int type;
-    HDC hdc;
-}TkWinDC;
-typedef union {
-    int type;
-    TkWinWindow window;
-    TkWinBitmap bitmap;
-    TkWinDC winDC;
-} TkWinDrawable;
- * The following macros are used to retrieve internal values from a Drawable.
-#define TkWinGetHWND(w) (((TkWinDrawable *) w)->window.handle)
-#define TkWinGetWinPtr(w) (((TkWinDrawable*)w)->window.winPtr)
-#define TkWinGetHBITMAP(w) (((TkWinDrawable*)w)->bitmap.handle)
-#define TkWinGetColormap(w) (((TkWinDrawable*)w)->bitmap.colormap)
-#define TkWinGetHDC(w) (((TkWinDrawable *) w)->winDC.hdc)
- * The following structure is used to encapsulate palette information.
-typedef struct {
-    HPALETTE palette;		/* Palette handle used when drawing. */
-    UINT size;			/* Number of entries in the palette. */
-    int stale;			/* 1 if palette needs to be realized,
-				 * otherwise 0.  If the palette is stale,
-				 * then an idle handler is scheduled to
-				 * realize the palette. */
-    Tcl_HashTable refCounts;	/* Hash table of palette entry reference counts
-				 * indexed by pixel value. */
-} TkWinColormap;
- * The following macro retrieves the Win32 palette from a colormap.
-#define TkWinGetPalette(colormap) (((TkWinColormap *) colormap)->palette)
- * The following macros define the class names for Tk Window types.
-#define TK_WIN_TOPLEVEL_CLASS_NAME "TkTopLevel"
-#define TK_WIN_CHILD_CLASS_NAME "TkChild"
- * The following variable indicates whether we are restricted to Win32s
- * GDI calls.
-extern int tkpIsWin32s;
- * The following variable is a translation table between X gc functions and
- * Win32 raster op modes.
-extern int tkpWinRopModes[];
- * The following defines are used with TkWinGetBorderPixels to get the
- * extra 2 border colors from a Tk_3DBorder.
-#define TK_3D_LIGHT2 TK_3D_DARK_GC+1
-#define TK_3D_DARK2 TK_3D_DARK_GC+2
- * Internal procedures used by more than one source file.
-extern LRESULT CALLBACK	TkWinChildProc _ANSI_ARGS_((HWND hwnd, UINT message,
-			    WPARAM wParam, LPARAM lParam));
-extern void		TkWinClipboardRender _ANSI_ARGS_((TkDisplay *dispPtr,
-			    UINT format));
-extern LRESULT		TkWinEmbeddedEventProc _ANSI_ARGS_((HWND hwnd,
-			    UINT message, WPARAM wParam, LPARAM lParam));
-extern void		TkWinFillRect _ANSI_ARGS_((HDC dc, int x, int y,
-			    int width, int height, int pixel));
-extern COLORREF		TkWinGetBorderPixels _ANSI_ARGS_((Tk_Window tkwin,
-			    Tk_3DBorder border, int which));
-extern HDC		TkWinGetDrawableDC _ANSI_ARGS_((Display *display,
-			    Drawable d, TkWinDCState* state));
-extern int		TkWinGetModifierState _ANSI_ARGS_((void));
-extern HPALETTE		TkWinGetSystemPalette _ANSI_ARGS_((void));
-extern HMODULE		TkWinGetTkModule _ANSI_ARGS_((void));
-extern HWND		TkWinGetWrapperWindow _ANSI_ARGS_((Tk_Window tkwin));
-extern int		TkWinHandleMenuEvent _ANSI_ARGS_((HWND *phwnd,
-			    UINT *pMessage, WPARAM *pwParam, LPARAM *plParam,
-			    LRESULT *plResult));
-extern int		TkWinIndexOfColor _ANSI_ARGS_((XColor *colorPtr));
-extern void		TkWinPointerDeadWindow _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkWinPointerEvent _ANSI_ARGS_((HWND hwnd, int x,
-			    int y));
-extern void		TkWinPointerInit _ANSI_ARGS_((void));
-extern LRESULT 		TkWinReflectMessage _ANSI_ARGS_((HWND hwnd,
-extern void		TkWinReleaseDrawableDC _ANSI_ARGS_((Drawable d,
-			    HDC hdc, TkWinDCState* state));
-extern LRESULT		TkWinResendEvent _ANSI_ARGS_((WNDPROC wndproc,
-			    HWND hwnd, XEvent *eventPtr));
-extern HPALETTE		TkWinSelectPalette _ANSI_ARGS_((HDC dc,
-			    Colormap colormap));
-extern void		TkWinSetMenu _ANSI_ARGS_((Tk_Window tkwin,
-			    HMENU hMenu));
-extern void		TkWinSetWindowPos _ANSI_ARGS_((HWND hwnd,
-			    HWND siblingHwnd, int pos));
-extern void		TkWinUpdateCursor _ANSI_ARGS_((TkWindow *winPtr));
-extern void		TkWinWmCleanup _ANSI_ARGS_((HINSTANCE hInstance));
-extern HWND		TkWinWmFindEmbedAssociation _ANSI_ARGS_((
-			    TkWindow *winPtr));
-extern void		TkWinWmStoreEmbedAssociation _ANSI_ARGS_((
-			    TkWindow *winPtr, HWND hwnd));
-extern void		TkWinXCleanup _ANSI_ARGS_((HINSTANCE hInstance));
-extern void 		TkWinXInit _ANSI_ARGS_((HINSTANCE hInstance));
-#endif /* _TKWININT */
Modified: grass/trunk/visualization/nviz/src/togl.c
--- grass/trunk/visualization/nviz/src/togl.c	2008-01-31 10:40:34 UTC (rev 29912)
+++ grass/trunk/visualization/nviz/src/togl.c	2008-01-31 11:00:58 UTC (rev 29913)
@@ -1,5 +1,3 @@
-/* $Id$ */
 /* vi:set sw=4: */
