[GRASS-SVN] r31919 - in grass-addons/visualization/nviz2: lib wxpython wxpython/nviz
Tue Jul 1 06:13:16 EDT 2008
Author: martinl
Date: 2008-07-01 06:13:16 -0400 (Tue, 01 Jul 2008)
New Revision: 31919
   grass-addons/visualization/nviz2/lib/draw.c
   grass-addons/visualization/nviz2/lib/nviz.h
   grass-addons/visualization/nviz2/wxpython/nviz.py
   grass-addons/visualization/nviz2/wxpython/nviz/dig_types.i
   grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp
   grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
   grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp
nviz2/wxGUI: draw mode fixed
Modified: grass-addons/visualization/nviz2/lib/draw.c
--- grass-addons/visualization/nviz2/lib/draw.c	2008-07-01 08:18:17 UTC (rev 31918)
+++ grass-addons/visualization/nviz2/lib/draw.c	2008-07-01 10:13:16 UTC (rev 31919)
@@ -50,7 +50,7 @@
     G_free (surf_list);
-/* re-initialize lights */
+    /* re-initialize lights */
     GS_setlight_position(num, x, y, z, w);
     num = 2;
     GS_setlight_position(num, 0., 0., 1., 0);
@@ -123,7 +123,7 @@
   blanking maps during specific frames.
   \param map_id map object id
   \return 0 not blank
   \return 1 blank
@@ -132,7 +132,13 @@
     return 0;
-int Nviz_draw_all(nv_data *data)
+  \brief Draw all
+  \param data nviz data
+  \param clear clear screen before drawing
+int Nviz_draw_all(nv_data *data, int clear)
     int draw_surf, draw_vect, draw_site, draw_vol;
     int draw_north_arrow, arrow_x, draw_label, draw_legend;
@@ -160,7 +166,8 @@
     // Tcl_SetVar(interp, "is_drawing", "1", TCL_GLOBAL_ONLY);
     GS_set_draw(GSD_BACK); /* needs to be BACK to avoid flickering */
-    GS_clear(data->bgcolor);
+    if (clear)
+	GS_clear(data->bgcolor);
     GS_ready_draw();
@@ -292,14 +299,28 @@
     return 1;
-int Nviz_draw_quick(nv_data *dc)
+  \brief Draw in coarse mode
+  \param dc nviz data
+  \return 1
+int Nviz_draw_quick(nv_data *dc, int clear)
     int i, max;
     int *surf_list, *vol_list;
-    GS_clear(dc->bgcolor);
+    if (clear)
+	GS_clear(dc->bgcolor);
     GS_ready_draw();
+    GS_alldraw_wire();
     surf_list = GS_get_surf_list(&max);
     max = GS_num_surfs();
@@ -310,7 +331,8 @@
     G_free (surf_list);
     vol_list = GVL_get_vol_list(&max);
     max = GVL_num_vols();
@@ -372,14 +394,12 @@
    - DRAW_FINE
    - DRAW_BOTH
   \param mode draw mode
 void Nviz_set_draw_mode(nv_data *data, int mode)
-    if (mode == DRAW_COARSE) {
-	data->draw_coarse = 1;
-    else {
-	data->draw_coarse = 0;
+    data->draw_mode = mode;
+    return;
Modified: grass-addons/visualization/nviz2/lib/nviz.h
--- grass-addons/visualization/nviz2/lib/nviz.h	2008-07-01 08:18:17 UTC (rev 31918)
+++ grass-addons/visualization/nviz2/lib/nviz.h	2008-07-01 10:13:16 UTC (rev 31919)
@@ -83,7 +83,7 @@
     int bgcolor;
     /* draw */
-    int draw_coarse;
+    int draw_mode;
 } nv_data;
 /* The following structure is used to associate client data with surfaces.
@@ -135,8 +135,8 @@
 /* draw.c */
 int Nviz_draw_all_surf(nv_data *);
-int Nviz_draw_all(nv_data *);
-int Nviz_draw_quick(nv_data *);
+int Nviz_draw_all(nv_data *, int);
+int Nviz_draw_quick(nv_data *, int);
 int Nviz_draw_all_vect(nv_data *);
 void Nviz_set_draw_mode(nv_data *, int);
Modified: grass-addons/visualization/nviz2/wxpython/nviz/dig_types.i
--- grass-addons/visualization/nviz2/wxpython/nviz/dig_types.i	2008-07-01 08:18:17 UTC (rev 31918)
+++ grass-addons/visualization/nviz2/wxpython/nviz/dig_types.i	2008-07-01 10:13:16 UTC (rev 31919)
@@ -25,3 +25,19 @@
 #define DRAW_COARSE 0
 #define DRAW_FINE 1
 #define DRAW_BOTH 2
+/* extracted from include/gsurf.h */
+#define DM_GOURAUD   0x00000100
+#define DM_FLAT      0x00000200
+#define DM_FRINGE    0x00000010
+#define DM_WIRE      0x00000001
+#define DM_COL_WIRE  0x00000002
+#define DM_POLY      0x00000004
+#define DM_WIRE_POLY 0x00000008
+#define DM_GRID_WIRE 0x00000400
+#define DM_GRID_SURF 0x00000800
+#define WC_COLOR_ATT 0xFF000000
Modified: grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp	2008-07-01 08:18:17 UTC (rev 31918)
+++ grass-addons/visualization/nviz2/wxpython/nviz/draw.cpp	2008-07-01 10:13:16 UTC (rev 31919)
@@ -22,31 +22,31 @@
   \brief Draw map
-  \param quick true for quick rendering
+  \param quick true for forcing coarse draw mode
 void Nviz::Draw(bool quick)
-    Nviz_draw_cplane(data, -1, -1);
-    if (data->draw_coarse) { /* coarse */
-	GS_set_draw(GSD_BACK);
-	GS_ready_draw();
-	GS_alldraw_wire();
-	GS_done_draw();
+    Nviz_draw_cplane(data, -1, -1); // ?
-	G_debug(1, "Nviz::Draw(): mode=coarse");
+    if (data->draw_mode == DRAW_COARSE ||
+	data->draw_mode == DRAW_BOTH || quick) {
+	Nviz_draw_quick(data, 1); // clear screen
-    else { /* fine / both */
-	if (!quick)
-	    Nviz_draw_all (data);
-	else
-	    Nviz_draw_quick(data); // ?
-	G_debug(1, "Nviz::Draw(): mode=fine, quick=%d", quick);
+    if (data->draw_mode == DRAW_FINE ||
+	data->draw_mode == DRAW_BOTH) {
+	if (data->draw_mode == DRAW_FINE) {
+	    Nviz_draw_all (data, 1); // clear screen
+	else {
+	    Nviz_draw_all (data, 0);
+    G_debug(1, "Nviz::Draw(): mode=%d, quick=%d",
+	    data->draw_mode, quick);
     return;
Modified: grass-addons/visualization/nviz2/wxpython/nviz/nviz.h
--- grass-addons/visualization/nviz2/wxpython/nviz/nviz.h	2008-07-01 08:18:17 UTC (rev 31918)
+++ grass-addons/visualization/nviz2/wxpython/nviz/nviz.h	2008-07-01 10:13:16 UTC (rev 31919)
@@ -80,6 +80,8 @@
     int UnsetSurfaceTransp(int);
     int UnsetSurfaceEmit(int);
     int SetSurfaceRes(int, int, int);
+    int SetSurfaceStyle(int, int);
+    int SetWireColor(int, const char *);
 #endif /* __NVIZ_H__ */
Modified: grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp
--- grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp	2008-07-01 08:18:17 UTC (rev 31918)
+++ grass-addons/visualization/nviz2/wxpython/nviz/surface.cpp	2008-07-01 10:13:16 UTC (rev 31919)
@@ -221,3 +221,49 @@
     return GS_set_drawres(id, fine, fine, coarse, coarse);
+  \brief Set draw style
+  Draw styles:
+   - DM_GOURAUD
+   - DM_FLAT
+   - DM_FRINGE
+   - DM_WIRE
+   - DM_COL_WIRE
+   - DM_POLY
+   - DM_WIRE_POLY
+   - DM_GRID_WIRE
+   - DM_GRID_SURF
+  \param id surface id (<= 0 for all)
+  \param style draw style
+  \return 0 on success
+  \return -1 on error
+int Nviz::SetSurfaceStyle(int id, int style)
+    if (id > 0) {
+	return GS_set_drawmode(id, style);
+    return GS_setall_drawmode(style);
+  \brief Set color of wire
+  \todo all
+  \param surface id
+  \param color color string (R:G:B)
+  \return 1
+int Nviz::SetWireColor(int id, const char* color)
+    GS_set_wire_color(id, Nviz_color_from_str(color));
+    return 1;
Modified: grass-addons/visualization/nviz2/wxpython/nviz.py
--- grass-addons/visualization/nviz2/wxpython/nviz.py	2008-07-01 08:18:17 UTC (rev 31918)
+++ grass-addons/visualization/nviz2/wxpython/nviz.py	2008-07-01 10:13:16 UTC (rev 31919)
@@ -243,10 +243,11 @@
             self.nvizClass.SetZExag(self.view['z-exag']['value'])
             del self.update['z-exag']
-        if render is True:
-            self.nvizClass.Draw(False)
-        elif render is False:
-            self.nvizClass.Draw(True) # quick
+        #         if render is True:
+        #             self.nvizClass.Draw(False)
+        #         elif render is False:
+        #             self.nvizClass.Draw(True) # quick
+        self.nvizClass.Draw(False)
         self.SwapBuffers()
@@ -268,8 +269,6 @@
         Debug.msg(3, "GLWindow.UpdateMap(): render=%s, -> time=%g" % \
                       (render, (stop-start)))
-        print '# %.6f' % (stop-start)
     def EraseMap(self):
         Erase the canvas
@@ -689,7 +688,7 @@
                                      _("surface")])
         style.SetName("selection")
         self.win['surface']['draw']['style'] = style.GetId()
-        style.Bind(wx.EVT_CHOICE, self.OnSurfaceStyle)
+        style.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
         gridSizer.Add(item=style, flag=wx.ALIGN_CENTER_VERTICAL,
                       pos=(1, 1))
@@ -702,7 +701,7 @@
                                       _("gouraud")])
         shade.SetName("selection")
         self.win['surface']['draw']['shading'] = shade.GetId()
-        shade.Bind(wx.EVT_CHOICE, self.OnSurfaceShade)
+        shade.Bind(wx.EVT_CHOICE, self.OnSurfaceMode)
         gridSizer.Add(item=shade, flag=wx.ALIGN_CENTER_VERTICAL,
                       pos=(1, 3))
@@ -710,9 +709,9 @@
         gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
                                          label=_("Wire color:")),
                       pos=(2, 0), flag=wx.ALIGN_CENTER_VERTICAL)
-        color = csel.ColourSelect(panel, id=wx.ID_ANY,
-                                  colour="white")
+        color = csel.ColourSelect(panel, id=wx.ID_ANY)
         color.SetName("colour")
+        color.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceWireColor)
         self.win['surface']['draw']['color'] = color.GetId()
         gridSizer.Add(item=color, flag=wx.ALIGN_CENTER_VERTICAL,
                       pos=(2, 1))
@@ -1030,11 +1029,11 @@
                 del self.mapWindow.update[attrb]
-        # drawing mode
+        # draw mode
         if self.mapWindow.update.has_key('draw-mode'):
             self.mapWindow.nvizClass.SetDrawMode(self.mapWindow.update['draw-mode'])
-        # drawing res
+        # draw res
         if self.mapWindow.update.has_key('draw-res'):
             mode, res = self.mapWindow.update['draw-res']
             if mode == 0: # coarse
@@ -1048,6 +1047,16 @@
             self.mapWindow.nvizClass.SetSurfaceRes(id, fine, coarse)
+        # draw style
+        if self.mapWindow.update.has_key('draw-style'):
+            self.mapWindow.nvizClass.SetSurfaceStyle(id, self.mapWindow.update['draw-style'])
+        # wire color
+        if self.mapWindow.update.has_key('draw-color'):
+            print self.mapWindow.update['draw-color']
+            self.mapWindow.nvizClass.SetWireColor(id, str(self.mapWindow.update['draw-color']))
         self.mapWindow.Refresh(False)
     def OnClose(self, event):
@@ -1141,42 +1150,71 @@
         if self.parent.autoRender.IsChecked():
             self.OnApply(None)
-    def OnSurfaceMode(self, event):
-        """Drawing mode changed"""
-        self.SetSurfaceMode(event.GetSelection())
-        event.Skip()
+    def OnSurfaceResolution(self, event):
+        """Draw resolution changed"""
+        value = event.GetInt()
+        mode = self.FindWindowById(self.win['surface']['draw']['mode']).GetSelection()
+        self.mapWindow.update['draw-res'] = (mode, value)
-    def SetSurfaceMode(self, selection):
-        """Set drawing mode and resolution"""
-        if selection == 0: # coarse
+        if self.parent.autoRender.IsChecked():
+            self.OnApply(None)
+    def SetSurfaceMode(self):
+        """Set draw mode"""
+        value = 0
+        if mode == 0: # coarse
+            value |= wxnviz.DM_WIRE
             self.mapWindow.update['draw-mode'] = wxnviz.DRAW_COARSE
             self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(True)
             self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(False)
-        elif selection == 1: # fine
+        elif mode == 1: # fine
+            value |= wxnviz.DM_POLY
             self.mapWindow.update['draw-mode'] = wxnviz.DRAW_FINE
             self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(False)
             self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(True)
-        elif selection == 2: # both
+        else: # both
+            value |= wxnviz.DM_WIRE_POLY
             self.mapWindow.update['draw-mode'] = wxnviz.DRAW_BOTH
-    def OnSurfaceResolution(self, event):
-        """Draw resolution changed"""
-        value = event.GetInt()
-        mode = self.FindWindowById(self.win['surface']['draw']['mode']).GetSelection()
-        self.mapWindow.update['draw-res'] = (mode, value)
+        style = self.FindWindowById(self.win['surface']['draw']['style']).GetSelection()
+        if style == 0: # wire
+            value |= wxnviz.DM_GRID_WIRE
+        else: # surface
+            value |= wxnviz.DM_GRID_SURF
+        shade = self.FindWindowById(self.win['surface']['draw']['shading']).GetSelection()
+        if shade == 0:
+            value |= wxnviz.DM_FLAT
+        else: # surface
+            value |= wxnviz.DM_GOURAUD
+        self.mapWindow.update['draw-style'] = value
             self.OnApply(None)
-    def OnSurfaceStyle(self, event):
-        pass
+    def OnSurfaceMode(self, event):
+        self.SetSurfaceMode()
-    def OnSurfaceShade(self, event):
-        pass
+    def SetSurfaceWireColor(self, color):
+        """Set wire color"""
+        value = str(color[0]) + ':' + str(color[1]) + ':' + str(color[2])
+        self.mapWindow.update['draw-color'] = value
+    def OnSurfaceWireColor(self, event):
+        self.SetSurfaceWireColor(event.GetValue())
     def UpdatePage(self, pageId):
         """Update dialog (selected page)"""
         layer = self.mapWindow.GetSelectedLayer()
@@ -1213,9 +1251,10 @@
                         win.SetColour(value)
                     else:
                         win.SetValue(value)
-                # enable/disable res widget
-                self.SetSurfaceMode(mode.GetSelection())
+                # enable/disable res widget + set draw mode
+                color = self.FindWindowById(self.win['surface']['draw']['color'])
+                self.SetSurfaceWireColor(color.GetColour())
             elif layer.type == 'raster':
                 # surface attributes
