[GRASS-SVN] r31952 - grass/branches/develbranch_6/tools
Wed Jul 2 03:42:20 EDT 2008
Author: neteler
Date: 2008-07-02 03:42:20 -0400 (Wed, 02 Jul 2008)
New Revision: 31952
Removed:
   grass/branches/develbranch_6/tools/cvs.recursadd
   grass/branches/develbranch_6/tools/cvs.remove
   grass/branches/develbranch_6/tools/cvs.rename.dir
   grass/branches/develbranch_6/tools/cvs.rename.file
   grass/branches/develbranch_6/tools/cvs2cl.pl
no more needed
Deleted: grass/branches/develbranch_6/tools/cvs.recursadd
--- grass/branches/develbranch_6/tools/cvs.recursadd	2008-07-02 07:41:33 UTC (rev 31951)
+++ grass/branches/develbranch_6/tools/cvs.recursadd	2008-07-02 07:42:20 UTC (rev 31952)
@@ -1,95 +0,0 @@
-#!/bin/sh
-# recursive CVS add/commit with comment
-# written by Markus Neteler 3/2000
-# based on useful hints by Bernhard Reiter
-# $Id$
-# what to do in case of user break:
-function exitprocedure()
- echo "User break!"
- exit 1
-# shell check for user break (signal list: trap -l)
-trap "exitprocedure" 2 3 9 15
-# add files recursivly to CVS
-if [ $# = 0 -o "$1" = "" -o "$1" = "help" -o "$1" = "-h" -o "$1" = "-help" ]
-    then
-     echo "USAGE: cvs.r.add comment"
-     echo "  This command runs recursively within a directory tree"
-     echo "  'cvs add' and 'cvs commit' are called within the script."
-    else
-     comment=$1
-fi
-if [ ! "$comment" ]
-then
-   exit
-fi
-echo "Walking through the tree..., ignore CVS dirs and OBJ dirs"
-if test -d CVS
-then
- echo "CVS dir is already present. Please check that."
- exit 1
-fi
-#add the current directory
-current=`pwd |tr / ' '|wc -w`         # count the words in path
-current=`expr $current + 1`
-local_dir=`pwd| cut -d'/' -f$current` # get the name
-cd ..
-# insert the job here:
- currpwd=`pwd`
- echo "cvs add $local_dir [$currpwd]"
- cvs add $local_dir
-cd $local_dir
-echo "Adding the files in current directory to CVS (if any)..."
-files=`find . -type f -maxdepth 1`
-count=`echo $files |wc -w`
-if [ $count -gt 0 ]; then
-      cvs add $files
-      cvs ci -m"$comment" $files
-fi
-echo "Proceeding..."
-dirnames=`find . -type d |grep -v CVS |grep -v OBJ`
-for i in $dirnames ; do
-   pushd . >/dev/null
-   cd $i
-   # get the last directory name:
-   words=`echo $i |tr / ' '|wc -w`         # count the words
-   local_dir=`echo $i| cut -d'/' -f$words` # get the name
-   if [ $local_dir != "." ]; then          # don't work on current dir
-   currpwd=`pwd`
-   cd ..                                   # we were already inside
-   cd $local_dir                           # o.k. now jump into it
-   echo "Add the files in current directory to CVS (if any)..."
-   files=`find . -type f -maxdepth 1`
-   count=`echo $files |wc -w`
-   if [ $count -gt 0 ]; then
-    echo files found
-      cvs add $files
-   fi
-   cd ..
-   popd >/dev/null
-   fi
-done
-echo "The End. You may check with cvs update"
Deleted: grass/branches/develbranch_6/tools/cvs.remove
--- grass/branches/develbranch_6/tools/cvs.remove	2008-07-02 07:41:33 UTC (rev 31951)
+++ grass/branches/develbranch_6/tools/cvs.remove	2008-07-02 07:42:20 UTC (rev 31952)
@@ -1,39 +0,0 @@
-#!/bin/sh
-# cvs remove directory
-# $Id$
-if [ "$#" -lt 2 -o "$1" = "" -o "$1" = "help" -o "$1" = "-h" -o "$1" = "-help" ]
-    then
-     echo "USAGE: cvs.remove comment directory"
-     echo ""
-     echo "use command in parent directory and specify name and comment."
-    else
-      dir=$2
-      comment=$1
-fi
-if [ ! "$dir" ]
-then
-   exit
-fi
-then
-   exit
-fi
-cd $dir
-if [ $? != 0 ]; then
-  echo ""
-  echo "ERROR! You mixed the parameter order or $dir does not exist!"
-  exit
-fi
-rm -f *
-cd ..
-cvs remove -R $dir
-cvs ci -m "$comment" $dir
-cvs update -P
-echo "Finish."
Deleted: grass/branches/develbranch_6/tools/cvs.rename.dir
--- grass/branches/develbranch_6/tools/cvs.rename.dir	2008-07-02 07:41:33 UTC (rev 31951)
+++ grass/branches/develbranch_6/tools/cvs.rename.dir	2008-07-02 07:42:20 UTC (rev 31952)
@@ -1,41 +0,0 @@
-#!/bin/sh
-# cvs rename directories
-# $Id$
-if [ $# -lt 2 -o "$1" = "" -o "$1" = "help" -o "$1" = "-h" -o "$1" = "-help" ]
-    then
-     echo "USAGE: cvs.rename old_directory_name  new_directory_name"
-     echo ""
-     echo "use command in parent directory and specify old and new name."
-    else
-      olddir=$1
-      newdir=$2
-fi
-if [ ! "$newdir" ]
-then
-   exit
-fi
-# here we go...
-if [ ! -d $newdir ]; then mkdir $newdir ; fi
-cvs add $newdir
-cd $olddir
-for i in $files ; do
- mv $i ../$newdir
-done
-cvs rm *
-cd ../$newdir
-cvs add *
-cd ..
-cvs remove -R $olddir
-# work on all dirs:
-cvs ci -m "moved $olddir/ to $newdir/: renamed directory"
-cvs update -P
-echo "Finish."
Deleted: grass/branches/develbranch_6/tools/cvs.rename.file
--- grass/branches/develbranch_6/tools/cvs.rename.file	2008-07-02 07:41:33 UTC (rev 31951)
+++ grass/branches/develbranch_6/tools/cvs.rename.file	2008-07-02 07:42:20 UTC (rev 31952)
@@ -1,35 +0,0 @@
-#!/bin/sh
-# cvs rename file
-# written by Markus Neteler 5/2000
-# May 30, 2000
-if [ $# -lt 3 -o "$1" = "" -o "$1" = "help" -o "$1" = "-h" -o "$1" = "-help" ]
-    then
-     echo "USAGE: cvs.rename.file old_file_name  new_file_name  comment"
-     echo ""
-    else
-      oldfile=$1
-      newfile=$2
-      comment=$3
-fi
-if [ ! "$newfile" ]
-then
-   exit
-fi
-# here we go...
-if [ -f $newfile ]
-then
- echo "file $newfile already exists!"
- exit
-fi
-mv $oldfile $newfile
-cvs rm $oldfile
-cvs ci -m"$comment" $oldfile
-cvs add $newfile
-cvs ci -m"$comment" $newfile
-echo "Dont forget to change associated Gmakefiles"
Deleted: grass/branches/develbranch_6/tools/cvs2cl.pl
--- grass/branches/develbranch_6/tools/cvs2cl.pl	2008-07-02 07:41:33 UTC (rev 31951)
+++ grass/branches/develbranch_6/tools/cvs2cl.pl	2008-07-02 07:42:20 UTC (rev 31952)
@@ -1,3222 +0,0 @@
-#!/bin/sh
-exec perl -w -x $0 ${1+"$@"} # -*- mode: perl; perl-indent-level: 2; -*-
-#!perl -w
-### cvs2cl.pl: produce ChangeLog(s) from `cvs log` output. ###
-## $ Revision: 2.59 $
-## $ Date: 2005/05/18 05:34:34 $
-## $ Author: kfogel $
-use strict;
-use File::Basename qw( fileparse );
-use Getopt::Long   qw( GetOptions );
-use Text::Wrap     qw( );
-use Time::Local    qw( timegm );
-use User::pwent    qw( getpwnam );
-# The Plan:
-# Read in the logs for multiple files, spit out a nice ChangeLog that
-# mirrors the information entered during `cvs commit'.
-# The problem presents some challenges. In an ideal world, we could
-# detect files with the same author, log message, and checkin time --
-# each <filelist, author, time, logmessage> would be a changelog entry.
-# We'd sort them; and spit them out.  Unfortunately, CVS is *not atomic*
-# so checkins can span a range of times.  Also, the directory structure
-# could be hierarchical.
-# Another question is whether we really want to have the ChangeLog
-# exactly reflect commits. An author could issue two related commits,
-# with different log entries, reflecting a single logical change to the
-# source. GNU style ChangeLogs group these under a single author/date.
-# We try to do the same.
-# So, we parse the output of `cvs log', storing log messages in a
-# multilevel hash that stores the mapping:
-#   directory => author => time => message => filelist
-# As we go, we notice "nearby" commit times and store them together
-# (i.e., under the same timestamp), so they appear in the same log
-# entry.
-# When we've read all the logs, we twist this mapping into
-# a time => author => message => filelist mapping for each directory.
-# If we're not using the `--distributed' flag, the directory is always
-# considered to be `./', even as descend into subdirectories.
-# Call Tree
-# name                         number of lines (10.xii.03)
-# parse_options                         192
-# derive_changelog                       13
-# +-maybe_grab_accumulation_date         38
-# +-read_changelog                      277
-#   +-maybe_read_user_map_file           94
-#     +-run_ext                           9
-#   +-read_file_path                     29
-#   +-read_symbolic_name                 43
-#   +-read_revision                      49
-#   +-read_date_author_and_state         25
-#     +-parse_date_author_and_state      20
-#   +-read_branches                      36
-# +-output_changelog                    424
-#   +-pretty_file_list                  290
-#     +-common_path_prefix               35
-#   +-preprocess_msg_text                30
-#     +-min                               1
-#   +-mywrap                             16
-#   +-last_line_len                       5
-#   +-wrap_log_entry                    177
-# Utilities
-# xml_escape                              6
-# slurp_file                             11
-# debug                                   5
-# version                                 2
-# usage                                 142
-# Note about a bug-slash-opportunity:
-# There's a bug in Text::Wrap, which affects cvs2cl.  This script
-# reveals it:
-#   #!/usr/bin/perl -w
-#   use Text::Wrap;
-#   my $test_text =
-#   "This script demonstrates a bug in Text::Wrap.  The very long line
-#   following this paragraph will be relocated relative to the surrounding
-#   text:
-#   See?  When the bug happens, we'll get the line of equal signs below
-#   this paragraph, even though it should be above.";
-#   # Print out the test text with no wrapping:
-#   print "$test_text";
-#   print "\n";
-#   print "\n";
-#   # Now print it out wrapped, and see the bug:
-#   print wrap ("\t", "        ", "$test_text");
-#   print "\n";
-#   print "\n";
-# If the line of equal signs were one shorter, then the bug doesn't
-# happen.  Interesting.
-# Anyway, rather than fix this in Text::Wrap, we might as well write a
-# new wrap() which has the following much-needed features:
-# * initial indentation, like current Text::Wrap()
-# * subsequent line indentation, like current Text::Wrap()
-# * user chooses among: force-break long words, leave them alone, or die()?
-# * preserve existing indentation: chopped chunks from an indented line
-#   are indented by same (like this line, not counting the asterisk!)
-# * optional list of things to preserve on line starts, default ">"
-# Note that the last two are essentially the same concept, so unify in
-# implementation and give a good interface to controlling them.
-# And how about:
-# Optionally, when encounter a line pre-indented by same as previous
-# line, then strip the newline and refill, but indent by the same.
-# Yeah...
-# Globals --------------------------------------------------------------------
-# In case we have to print it out:
-my $VERSION = '$Revision$';
-$VERSION =~ s/\S+\s+(\S+)\s+\S+/$1/;
-## Vars set by options:
-# Print debugging messages?
-my $Debug = 0;
-# Just show version and exit?
-my $Print_Version = 0;
-# Just print usage message and exit?
-my $Print_Usage = 0;
-# What file should we generate (defaults to "ChangeLog")?
-my $Log_File_Name = "ChangeLog";
-# Grab most recent entry date from existing ChangeLog file, just add
-# to that ChangeLog.
-my $Cumulative = 0;
-# `cvs log -d`, this will repeat the last entry in the old log.  This is OK,
-# as it guarantees at least one entry in the update changelog, which means
-# that there will always be a date to extract for the next update.  The repeat
-# entry can be removed in postprocessing, if necessary.
-# MJP 2003-08-02
-# I don't think this actually does anything useful
-my $Update = 0;
-# Expand usernames to email addresses based on a map file?
-my $User_Map_File = '';
-my $User_Passwd_File;
-my $Mail_Domain;
-# Output log in chronological order? [default is reverse chronological order]
-my $Chronological_Order = 0;
-# Grab user details via gecos
-my $Gecos = 0;
-# User domain for gecos email addresses
-my $Domain;
-# Output to a file or to stdout?
-my $Output_To_Stdout = 0;
-# Eliminate empty log messages?
-my $Prune_Empty_Msgs = 0;
-# Tags of which not to output
-my %ignore_tags;
-# Show only revisions with Tags
-my %show_tags;
-# Don't call Text::Wrap on the body of the message
-my $No_Wrap = 0;
-# Indentation of log messages
-my $Indent = "\t";
-# Don't do any pretty print processing
-my $Summary = 0;
-# Separates header from log message.  Code assumes it is either " " or
-# "\n\n", so if there's ever an option to set it to something else,
-# make sure to go through all conditionals that use this var.
-my $After_Header = " ";
-# XML Encoding
-my $XML_Encoding = '';
-# Format more for programs than for humans.
-my $XML_Output = 0;
-my $No_XML_Namespace = 0;
-my $No_XML_ISO_Date = 0;
-# Do some special tweaks for log data that was written in FSF
-# ChangeLog style.
-my $FSF_Style = 0;
-# Show times in UTC instead of local time
-my $UTC_Times = 0;
-# Show times in output?
-my $Show_Times = 1;
-# Show day of week in output?
-my $Show_Day_Of_Week = 0;
-# Show revision numbers in output?
-my $Show_Revisions = 0;
-# Show dead files in output?
-my $Show_Dead = 0;
-# Hide dead trunk files which were created as a result of additions on a
-# branch?
-my $Hide_Branch_Additions = 1;
-# Show tags (symbolic names) in output?
-my $Show_Tags = 0;
-# Show tags separately in output?
-my $Show_Tag_Dates = 0;
-# Show branches by symbolic name in output?
-my $Show_Branches = 0;
-# Show only revisions on these branches or their ancestors.
-my @Follow_Branches;
-# Show only revisions on these branches or their ancestors; ignore descendent
-# branches.
-my @Follow_Only;
-# Don't bother with files matching this regexp.
-my @Ignore_Files;
-# How exactly we match entries.  We definitely want "o",
-# and user might add "i" by using --case-insensitive option.
-my $Case_Insensitive = 0;
-# Maybe only show log messages matching a certain regular expression.
-my $Regexp_Gate = '';
-# Pass this global option string along to cvs, to the left of `log':
-my $Global_Opts = '';
-# Pass this option string along to the cvs log subcommand:
-my $Command_Opts = '';
-# Read log output from stdin instead of invoking cvs log?
-my $Input_From_Stdin = 0;
-# Don't show filenames in output.
-my $Hide_Filenames = 0;
-# Don't shorten directory names from filenames.
-my $Common_Dir = 1;
-# Max checkin duration. CVS checkin is not atomic, so we may have checkin
-# times that span a range of time. We assume that checkins will last no
-# longer than $Max_Checkin_Duration seconds, and that similarly, no
-# checkins will happen from the same users with the same message less
-# than $Max_Checkin_Duration seconds apart.
-my $Max_Checkin_Duration = 180;
-# What to put at the front of [each] ChangeLog.
-my $ChangeLog_Header = '';
-# Whether to enable 'delta' mode, and for what start/end tags.
-my $Delta_Mode = 0;
-my $Delta_From = '';
-my $Delta_To = '';
-my $TestCode;
-# Whether to parse filenames from the RCS filename, and if so what
-# prefix to strip.
-my $RCS_Root;
-# Whether to output information on the # of lines added and removed
-# by each file modification.
-my $Show_Lines_Modified = 0;
-## end vars set by options.
-# latest observed times for the start/end tags in delta mode
-my $Delta_StartTime = 0;
-my $Delta_EndTime = 0;
-my $No_Ancestors = 0;
-my $No_Extra_Indent = 0;
-my $GroupWithinDate = 0;
-package CVS::Utils::ChangeLog::EntrySet;
-sub new {
-  my $class = shift;
-  my %self;
-  bless \%self, $class;
-sub output_changelog {
-  my $output_type = $XML_Output ? 'XML' : 'Text';
-  my $output_class = "CVS::Utils::ChangeLog::EntrySet::Output::${output_type}";
-  my $output = $output_class->new(follow_branches => \@Follow_Branches,
-                                  follow_only     => \@Follow_Only,
-                                  ignore_tags     => \%ignore_tags,
-                                  show_tags       => \%show_tags,
-  $output->output_changelog(@_);
-sub add_fileentry {
-  my ($self, $file_full_path, $time, $revision, $state, $lines,
-      $branch_names, $branch_roots, $branch_numbers,
-      $symbolic_names, $author, $msg_txt) = @_;
-      my $qunk =
-        CVS::Utils::ChangeLog::FileEntry->new($file_full_path, $time, $revision,
-                                              $state, $lines,
-                                              $branch_numbers,
-                                              $symbolic_names);
-      # We might be including revision numbers and/or tags and/or
-      # branch names in the output.  Most of the code from here to
-      # loop-end deals with organizing these in qunk.
-      unless ( $Hide_Branch_Additions
-               and
-               $msg_txt =~ /file .+ was initially added on branch \S+./ ) {
-        # Add this file to the list
-        # (We use many spoonfuls of autovivication magic. Hashes and arrays
-        # will spring into existence if they aren't there already.)
-        &main::debug ("(pushing log msg for ". $qunk->dir_key . $qunk->filename . ")\n");
-        # Store with the files in this commit.  Later we'll loop through
-        # again, making sure that revisions with the same log message
-        # and nearby commit times are grouped together as one commit.
-        $self->{$qunk->dir_key}{$author}{$time}{$msg_txt} =
-          CVS::Utils::ChangeLog::Message->new($msg_txt)
-              unless exists $self->{$qunk->dir_key}{$author}{$time}{$msg_txt};
-        $self->{$qunk->dir_key}{$author}{$time}{$msg_txt}->add_fileentry($qunk);
-package CVS::Utils::ChangeLog::EntrySet::Output::Text;
-use base qw( CVS::Utils::ChangeLog::EntrySet::Output );
-sub new {
-  my $self = $class->SUPER::new(@_);
-sub wday {
-  my $self = shift; my $class = ref $self;
-  my ($wday) = @_;
-  return $Show_Day_Of_Week ? ' ' . $class->weekday_en($wday) : '';
-sub header_line {
-  my $self = shift;
-  my ($time, $author, $lastdate) = @_;
-  my $header_line = '';
-  my (undef,$min,$hour,$mday,$mon,$year,$wday)
-    = $UTC_Times ? gmtime($time) : localtime($time);
-  my $date = $self->fdatetime($time);
-  if ($Show_Times) {
-    $header_line =
-      sprintf "%s  %s\n\n", $date, $author;
-  } else {
-    if ( ! defined $lastdate or $date ne $lastdate or ! $GroupWithinDate ) {
-      if ( $GroupWithinDate ) {
-        $header_line = "$date\n\n";
-      } else {
-        $header_line = "$date  $author\n\n";
-    } else {
-      $header_line = '';
-sub preprocess_msg_text {
-  my $self = shift;
-  my ($text) = @_;
-  $text = $self->SUPER::preprocess_msg_text($text);
-  unless ( $No_Wrap ) {
-    # Strip off lone newlines, but only for lines that don't begin with
-    # whitespace or a mail-quoting character, since we want to preserve
-    # that kind of formatting.  Also don't strip newlines that follow a
-    # period; we handle those specially next.  And don't strip
-    # newlines that precede an open paren.
-    1 while $text =~ s/(^|\n)([^>\s].*[^.\n])\n([^>\n])/$1$2 $3/g;
-    # If a newline follows a period, make sure that when we bring up the
-    # bottom sentence, it begins with two spaces.
-    1 while $text =~ s/(^|\n)([^>\s].*)\n([^>\n])/$1$2  $3/g;
-  return $text;
-# Here we take a bunch of qunks and convert them into printed
-# summary that will include all the information the user asked for.
-sub pretty_file_list {
-  my $self = shift;
-  return ''
-    if $Hide_Filenames;
-  my $qunksref = shift;
-  my @filenames;
-  my $beauty = '';          # The accumulating header string for this entry.
-  my %non_unanimous_tags;   # Tags found in a proper subset of qunks
-  my %unanimous_tags;       # Tags found in all qunks
-  my %all_branches;         # Branches found in any qunk
-  my $fbegun = 0;           # Did we begin printing filenames yet?
-  my ($common_dir, $qunkrefs) =
-    $self->_pretty_file_list(\(%unanimous_tags, %non_unanimous_tags, %all_branches), $qunksref);
-  my @qunkrefs = @$qunkrefs;
-  # Not XML output, so complexly compactify for chordate consumption.  At this
-  # point we have enough global information about all the qunks to organize
-  # them non-redundantly for output.
-  if ($common_dir) {
-    # Note that $common_dir still has its trailing slash
-    $beauty .= "$common_dir: ";
-  if ($Show_Branches)
-    # For trailing revision numbers.
-    my @brevisions;
-    foreach my $branch (keys (%all_branches))
-      foreach my $qunkref (@qunkrefs)
-        if ((defined ($qunkref->branch))
-            and ($qunkref->branch eq $branch))
-          if ($fbegun) {
-            # kff todo: comma-delimited in XML too?  Sure.
-            $beauty .= ", ";
-          else {
-            $fbegun = 1;
-          my $fname = substr ($qunkref->filename, length ($common_dir));
-          $beauty .= $fname;
-          $qunkref->{'printed'} = 1;  # Just setting a mark bit, basically
-          if ( $Show_Tags and defined $qunkref->tags ) {
-            my @tags = grep ($non_unanimous_tags{$_}, @{$qunkref->tags});
-            if (@tags) {
-              $beauty .= " (tags: ";
-              $beauty .= join (', ', @tags);
-              $beauty .= ")";
-          if ($Show_Revisions) {
-            # Collect the revision numbers' last components, but don't
-            # print them -- they'll get printed with the branch name
-            # later.
-            $qunkref->revision =~ /.+\.([\d]+)$/;
-            push (@brevisions, $1);
-            # todo: we're still collecting branch roots, but we're not
-            # showing them anywhere.  If we do show them, it would be
-            # nifty to just call them revision "0" on a the branch.
-            # Yeah, that's the ticket.
-      $beauty .= " ($branch";
-      if (@brevisions) {
-        if ((scalar (@brevisions)) > 1) {
-          $beauty .= ".[";
-          $beauty .= (join (',', @brevisions));
-          $beauty .= "]";
-        else {
-          # Square brackets are spurious here, since there's no range to
-          # encapsulate
-          $beauty .= ".$brevisions[0]";
-      $beauty .= ")";
-  # Okay; any qunks that were done according to branch are taken care
-  # of, and marked as printed.  Now print everyone else.
-  my %fileinfo_printed;
-    next if (defined ($qunkref->{'printed'}));   # skip if already printed
-    my $b = substr ($qunkref->filename, length ($common_dir));
-    # todo: Shlomo's change was this:
-    # $beauty .= substr ($qunkref->filename,
-    #              (($common_dir eq "./") ? '' : length ($common_dir)));
-    $qunkref->{'printed'} = 1;  # Set a mark bit.
-    if ($Show_Revisions || $Show_Tags || $Show_Dead)
-      my $started_addendum = 0;
-        $started_addendum = 1;
-        $b .= " (";
-        $b .= $qunkref->revision;
-      if ($Show_Dead && $qunkref->state =~ /dead/)
-        # Deliberately not using $started_addendum. Keeping it simple.
-        $b .= "[DEAD]";
-      if ($Show_Tags && (defined $qunkref->tags)) {
-        if ((scalar (@tags)) > 0) {
-          if ($started_addendum) {
-            $b .= ", ";
-          else {
-            $b .= " (tags: ";
-          $b .= join (', ', @tags);
-        $b .= ")";
-    unless ( exists $fileinfo_printed{$b} ) {
-      if ($fbegun) {
-        $beauty .= ", ";
-      } else {
-        $fbegun = 1;
-      $beauty .= $b, $fileinfo_printed{$b} = 1;
-  # Unanimous tags always come last.
-  if ($Show_Tags && %unanimous_tags)
-    $beauty .= " (utags: ";
-    $beauty .= join (', ', sort keys (%unanimous_tags));
-    $beauty .= ")";
-  # todo: still have to take care of branch_roots?
-  $beauty = "$beauty:";
-  return $beauty;
-sub output_tagdate {
-  my $self = shift;
-  my ($fh, $time, $tag) = @_;
-  my $fdatetime = $self->fdatetime($time);
-  print $fh "$fdatetime  tag $tag\n\n";
-  return;
-sub format_body {
-  my $self = shift;
-  my ($msg, $files, $qunklist) = @_;
-  my $body;
-  if ( $No_Wrap and ! $Summary ) {
-    $msg = $self->preprocess_msg_text($msg);
-    $files = $self->mywrap("\t", "\t  ", "* $files");
-    $msg =~ s/\n(.+)/\n$Indent$1/g;
-    unless ($After_Header eq " ") {
-      $msg =~ s/^(.+)/$Indent$1/g;
-    if ( $Hide_Filenames ) {
-      $body = $After_Header . $msg;
-    } else {
-      $body = $files . $After_Header . $msg;
-  } elsif ( $Summary ) {
-    my ($filelist, $qunk);
-    my (@DeletedQunks, @AddedQunks, @ChangedQunks);
-    #     Sort the files (qunks) according to the operation that was
-    # performed.  Files which were added have no line change
-    # indicator, whereas deleted files have state dead.
-    foreach $qunk ( @$qunklist ) {
-      if ( "dead" eq $qunk->state) {
-        push @DeletedQunks, $qunk;
-      } elsif ( ! defined $qunk->lines ) {
-        push @AddedQunks, $qunk;
-      } else {
-        push @ChangedQunks, $qunk;
-    #     The qunks list was  originally in tree search order.  Let's
-    # get that back.  The lists, if they exist, will be reversed upon
-    # processing.
-    #     Now write the three sections onto $filelist
-    if ( @DeletedQunks ) {
-      $filelist .= "\tDeleted:\n";
-      foreach $qunk ( @DeletedQunks ) {
-        $filelist .= "\t\t" . $qunk->filename;
-        $filelist .= " (" . $qunk->revision . ")";
-        $filelist .= "\n";
-      undef @DeletedQunks;
-    if ( @AddedQunks ) {
-      $filelist .= "\tAdded:\n";
-      foreach $qunk (@AddedQunks) {
-      undef @AddedQunks ;
-    if ( @ChangedQunks ) {
-      $filelist .= "\tChanged:\n";
-      foreach $qunk (@ChangedQunks) {
-        $filelist .= ", \"" . $qunk->state . "\"";
-        $filelist .= ", lines: " . $qunk->lines;
-      undef @ChangedQunks;
-    chomp $filelist;
-      $filelist = '';
-    $msg =~ s/\n(.*)/\n$Indent$1/g;
-    unless ( $After_Header eq " " or $FSF_Style ) {
-      $msg =~ s/^(.*)/$Indent$1/g;
-      if ( $FSF_Style ) {
-        $msg = $self->wrap_log_entry($msg, '', 69, 69);
-        chomp($msg);
-        chomp($msg);
-      } else {
-        $msg = $self->mywrap('', $Indent, "$msg");
-        $msg =~ s/[ \t]+\n/\n/g;
-    $body = $filelist . $After_Header . $msg;
-  } else {  # do wrapping, either FSF-style or regular
-    my $latter_wrap = $No_Extra_Indent ? $Indent : "$Indent  ";
-      $files = $self->mywrap($Indent, $latter_wrap, "* $files");
-      my $files_last_line_len = 0;
-      if ( $After_Header eq " " ) {
-        $files_last_line_len = $self->last_line_len($files);
-        $files_last_line_len += 1;  # for $After_Header
-      $msg = $self->wrap_log_entry($msg, $latter_wrap, 69-$files_last_line_len, 69);
-    } else {  # not FSF-style
-      $body = $self->mywrap($Indent, $latter_wrap, "* $body");
-      $body =~ s/[ \t]+\n/\n/g;
-  return $body;
-package CVS::Utils::ChangeLog::EntrySet::Output::XML;
-sub new {
-sub header_line {
-  my $self = shift;
-  my $isoDate;
-  my ($y, $m, $d, $H, $M, $S) = (gmtime($time))[5,4,3,2,1,0];
-  # Ideally, this would honor $UTC_Times and use +HH:MM syntax
-  $isoDate = sprintf("%04d-%02d-%02dT%02d:%02d:%02dZ",
-                     $y + 1900, $m + 1, $d, $H, $M, $S);
-  $wday = $self->wday($wday);
-  $header_line =
-    sprintf ("<date>%4u-%02u-%02u</date>\n${wday}<time>%02u:%02u</time>\n",
-             $year+1900, $mon+1, $mday, $hour, $min);
-  $header_line .= "<isoDate>$isoDate</isoDate>\n"
-    unless $No_XML_ISO_Date;
-  $header_line .= sprintf("<author>%s</author>\n" , $author);
-sub wday {
-  my ($wday) = @_;
-  return '<weekday>' . $class->weekday_en($wday) . "</weekday>\n";
-sub escape {
-  my $self = shift;
-  my $txt = shift;
-  $txt =~ s/&/&amp;/g;
-  $txt =~ s/</&lt;/g;
-  $txt =~ s/>/&gt;/g;
-  return $txt;
-sub output_header {
-  my $self = shift;
-  my ($fh) = @_;
-  my $encoding    =
-    length $XML_Encoding ? qq'encoding="$XML_Encoding"' : '';
-  my $version     = 'version="1.0"';
-  my $declaration =
-    sprintf '<?xml %s?>', join ' ', grep length, $version, $encoding;
-  my $root        =
-    $No_XML_Namespace ?
-      '<changelog>'     :
-        '<changelog xmlns="http://www.red-bean.com/xmlns/cvs2cl/">';
-  print $fh "$declaration\n\n$root\n\n";
-sub output_footer {
-  my $self = shift;
-  my ($fh) = @_;
-  print $fh "</changelog>\n";
-  my $self = shift;
-  my ($text) = @_;
-  $text = $self->escape($text);
-  chomp $text;
-  $text = "<msg>${text}</msg>\n";
-  return $text;
-# Here we take a bunch of qunks and convert them into a printed
-  my $self = shift;
-  my ($qunksref) = @_;
-      $qunksref);
-  # If outputting XML, then our task is pretty simple, because we
-  # don't have to detect common dir, common tags, branch prefixing,
-  # etc.  We just output exactly what we have, and don't worry about
-  # redundancy or readability.
-    my $filename    = $qunkref->filename;
-    my $state       = $qunkref->state;
-    my $revision    = $qunkref->revision;
-    my $tags        = $qunkref->tags;
-    my $branch      = $qunkref->branch;
-    my $branchroots = $qunkref->roots;
-    my $lines       = $qunkref->lines;
-    $filename = $self->escape($filename);   # probably paranoia
-    $revision = $self->escape($revision);   # definitely paranoia
-    $beauty .= "<file>\n";
-    $beauty .= "<name>${filename}</name>\n";
-    $beauty .= "<cvsstate>${state}</cvsstate>\n";
-    $beauty .= "<revision>${revision}</revision>\n";
-    if ($Show_Lines_Modified
-        && $lines && $lines =~ m/\+(\d+)\s+-(\d+)/) {
-        $beauty .= "<linesadded>$1</linesadded>\n";
-        $beauty .= "<linesremoved>$2</linesremoved>\n";
-    if ($branch) {
-      $branch   = $self->escape($branch);     # more paranoia
-      $beauty .= "<branch>${branch}</branch>\n";
-    foreach my $tag (@$tags) {
-      $tag = $self->escape($tag);  # by now you're used to the paranoia
-      $beauty .= "<tag>${tag}</tag>\n";
-    foreach my $root (@$branchroots) {
-      $root = $self->escape($root);  # which is good, because it will continue
-      $beauty .= "<branchroot>${root}</branchroot>\n";
-    $beauty .= "</file>\n";
-  # Theoretically, we could go home now.  But as long as we're here,
-  # let's print out the common_dir and utags, as a convenience to
-  # the receiver (after all, earlier code calculated that stuff
-  # anyway, so we might as well take advantage of it).
-  if ((scalar (keys (%unanimous_tags))) > 1) {
-    foreach my $utag ((keys (%unanimous_tags))) {
-      $utag = $self->escape($utag);   # the usual paranoia
-      $beauty .= "<utag>${utag}</utag>\n";
-    $common_dir = $self->escape($common_dir);
-    $beauty .= "<commondir>${common_dir}</commondir>\n";
-  # That's enough for XML, time to go home:
-  return $beauty;
-  my $self = shift;
-  my $isoDate = sprintf("%04d-%02d-%02dT%02d:%02d:%02dZ",
-  print $fh "<tagdate>\n";
-  print $fh "<tagisodate>$isoDate</tagisodate>\n";
-  print $fh "<tagdatetag>$tag</tagdatetag>\n";
-  print $fh "</tagdate>\n\n";
-  return;
-sub output_entry {
-  my $self = shift;
-  my ($fh, $entry) = @_;
-  print $fh "<entry>\n$entry</entry>\n\n";
-sub format_body {
-  my $self = shift;
-  return $files . $msg;
-package CVS::Utils::ChangeLog::EntrySet::Output;
-use Carp           qw( croak );
-# Class Utility Functions -------------
-{ # form closure
-my @weekdays = (qw(Sunday Monday Tuesday Wednesday Thursday Friday Saturday));
-sub weekday_en {
-  return $weekdays[$_[0]];
-sub new {
-  my ($proto, %args) = @_;
-  my $class = ref $proto || $proto;
-  my $follow_branches = delete $args{follow_branches};
-  my $follow_only     = delete $args{follow_only};
-  my $ignore_tags     = delete $args{ignore_tags};
-  my $show_tags       = delete $args{show_tags};
-  die "Unrecognized arg to EntrySet::Output::new: '$_'\n"
-    for keys %args;
-  bless +{follow_branches => $follow_branches,
-          follow_only     => $follow_only,
-          show_tags       => $show_tags,
-          ignore_tags     => $ignore_tags,
-         }, $class;
-# Abstract Subrs ----------------------
-sub wday               { croak "Whoops.  Abtract method call (wday).\n" }
-sub pretty_file_list   { croak "Whoops.  Abtract method call (pretty_file_list).\n" }
-sub output_tagdate     { croak "Whoops.  Abtract method call (output_tagdate).\n" }
-sub header_line        { croak "Whoops.  Abtract method call (header_line).\n" }
-# Instance Subrs ----------------------
-sub output_header { }
-sub output_entry {
-  my $self = shift;
-  print $fh "$entry\n";
-sub output_footer { }
-sub escape { return $_[1] }
-sub _revision_is_wanted {
-  my ($self, $qunk) = @_;
-  my ($revision, $branch_numbers) = @{$qunk}{qw( revision branch_numbers )};
-  my $follow_branches = $self->{follow_branches};
-  my $follow_only     = $self->{follow_only};
-  for my $ignore_tag (keys %{$self->{ignore_tags}}) {
-    return
-      if defined $qunk->{tags} and grep $_ eq $ignore_tag, @{$qunk->{tags}};
-  if ( keys %{$self->{show_tags}} ) {
-    for my $show_tag (keys %{$self->{show_tags}}) {
-      return
-        if ! defined $qunk->{tags} or ! grep $_ eq $show_tag, @{$qunk->{tags}};
-  return 1
-    unless @$follow_branches + @$follow_only; # no follow is follow all
-  for my $x (map([$_, 1], @$follow_branches),
-             map([$_, 0], @$follow_only    )) {
-    my ($branch, $followsub) = @$x;
-    # Special case for following trunk revisions
-    return 1
-      if $branch =~ /^trunk$/i and $revision =~ /^[0-9]+\.[0-9]+$/;
-    if ( my $branch_number = $branch_numbers->{$branch} ) {
-      # Are we on one of the follow branches or an ancestor of same?
-      # If this revision is a prefix of the branch number, or possibly is less
-      # in the minormost number, OR if this branch number is a prefix of the
-      # revision, then yes.  Otherwise, no.
-      # So below, we determine if any of those conditions are met.
-      # Trivial case: is this revision on the branch?  (Compare this way to
-      # avoid regexps that screw up Emacs indentation, argh.)
-      if ( substr($revision, 0, (length($branch_number) + 1))
-           eq
-           ($branch_number . ".") ) {
-        if ( $followsub ) {
-          return 1;
-#        } elsif ( length($revision) == length($branch_number)+2 ) {
-        } elsif ( substr($revision, length($branch_number)+1) =~ /^\d+$/ ) {
-          return 1;
-      } elsif ( length($branch_number) > length($revision)
-                and
-                ! $No_Ancestors ) {
-        # Non-trivial case: check if rev is ancestral to branch
-        # r_left still has the trailing "."
-        my ($r_left, $r_end) = ($revision =~ /^((?:\d+\.)+)(\d+)$/);
-        # b_left still has trailing "."
-        # b_mid has no trailing "."
-        my ($b_left, $b_mid) = ($branch_number =~ /^((?:\d+\.)+)(\d+)\.\d+$/);
-        return 1
-          if $r_left eq $b_left and $r_end <= $b_mid;
-  return;
-my $self = shift; my $class = ref $self;
-  my ($grand_poobah) = @_;
-  ### Process each ChangeLog
-  while (my ($dir,$authorhash) = each %$grand_poobah)
-    &main::debug ("DOING DIR: $dir\n");
-    # Here we twist our hash around, from being
-    #   author => time => message => filelist
-    # in %$authorhash to
-    #   time => author => message => filelist
-    # in %changelog.
-    # This is also where we merge entries.  The algorithm proceeds
-    # through the timeline of the changelog with a sliding window of
-    # $Max_Checkin_Duration seconds; within that window, entries that
-    # have the same log message are merged.
-    # (To save space, we zap %$authorhash after we've copied
-    # everything out of it.)
-    my %changelog;
-    while (my ($author,$timehash) = each %$authorhash)
-      my %stamptime;
-      foreach my $time (sort {$a <=> $b} (keys %$timehash))
-        my $msghash = $timehash->{$time};
-        while (my ($msg,$qunklist) = each %$msghash)
-          my $stamptime = $stamptime{$msg};
-          if ((defined $stamptime)
-              and (($time - $stamptime) < $Max_Checkin_Duration)
-              and (defined $changelog{$stamptime}{$author}{$msg}))
-            push(@{$changelog{$stamptime}{$author}{$msg}}, $qunklist->files);
-          else {
-            $changelog{$time}{$author}{$msg} = $qunklist->files;
-            $stamptime{$msg} = $time;
-    undef (%$authorhash);
-    ### Now we can write out the ChangeLog!
-    my ($logfile_here, $logfile_bak, $tmpfile);
-    my $lastdate;
-    if (! $Output_To_Stdout) {
-      $logfile_here =  $dir . $Log_File_Name;
-      $logfile_here =~ s/^\.\/\//\//;   # fix any leading ".//" problem
-      $tmpfile      = "${logfile_here}.cvs2cl$$.tmp";
-      $logfile_bak  = "${logfile_here}.bak";
-      open (LOG_OUT, ">$tmpfile") or die "Unable to open \"$tmpfile\"";
-    else {
-      open (LOG_OUT, ">-") or die "Unable to open stdout for writing";
-    print LOG_OUT $ChangeLog_Header;
-    my %tag_date_printed;
-    $self->output_header(\*LOG_OUT);
-    my @key_list = ();
-    if($Chronological_Order) {
-        @key_list = sort {$a <=> $b} (keys %changelog);
-    } else {
-        @key_list = sort {$b <=> $a} (keys %changelog);
-    foreach my $time (@key_list)
-      next if ($Delta_Mode &&
-               (($time <= $Delta_StartTime) ||
-                ($time > $Delta_EndTime && $Delta_EndTime)));
-      # Set up the date/author line.
-      # kff todo: do some more XML munging here, on the header
-      # part of the entry:
-      # XML output includes everything else, we might as well make
-      # it always include Day Of Week too, for consistency.
-      my $authorhash = $changelog{$time};
-      if ( $Show_Tag_Dates || $XML_Output ) {
-        my %tags;
-        while (my ($author,$mesghash) = each %$authorhash) {
-          while (my ($msg,$qunk) = each %$mesghash) {
-            for my $qunkref2 (@$qunk) {
-              if (defined ($qunkref2->tags)) {
-                for my $tag (@{$qunkref2->tags}) {
-                  $tags{$tag} = 1;
-        # Sort here for determinism to ease testing
-        foreach my $tag (sort keys %tags) {
-          if ( ! defined $tag_date_printed{$tag} ) {
-            $tag_date_printed{$tag} = $time;
-            $self->output_tagdate(\*LOG_OUT, $time, $tag);
-        # If XML, escape in outer loop to avoid compound quoting:
-        $author = $self->escape($author);
-      FOOBIE:
-        # We sort here to enable predictable ordering for the testing porpoises
-        for my $msg (sort keys %$mesghash)
-          my $qunklist = $mesghash->{$msg};
-          my @qunklist =
-            grep $self->_revision_is_wanted($_), @$qunklist;
-          next FOOBIE unless @qunklist;
-          my $files               = $self->pretty_file_list(\@qunklist);
-          my $header_line;          # date and author
-          my $wholething;           # $header_line + $body
-          $header_line = $self->header_line($time, $author, $lastdate);
-          $lastdate = $date;
-          $Text::Wrap::huge = 'overflow'
-            if $Text::Wrap::VERSION >= 2001.0130;
-          # Reshape the body according to user preferences.
-          my $body = $self->format_body($msg, $files, \@qunklist);
-          $wholething = $header_line . $body;
-          # One last check: make sure it passes the regexp test, if the
-          # user asked for that.  We have to do it here, so that the
-          # test can match against information in the header as well
-          # as in the text of the log message.
-          # How annoying to duplicate so much code just because I
-          # can't figure out a way to evaluate scalars on the trailing
-          # operator portion of a regular expression.  Grrr.
-          if ($Case_Insensitive) {
-            unless ( $Regexp_Gate and ( $wholething !~ /$Regexp_Gate/oi ) ) {
-              $self->output_entry(\*LOG_OUT, $wholething);
-          else {
-            unless ( $Regexp_Gate and ( $wholething !~ /$Regexp_Gate/o ) ) {
-    $self->output_footer(\*LOG_OUT);
-    close (LOG_OUT);
-    if ( ! $Output_To_Stdout ) {
-      # If accumulating, append old data to new before renaming.  But
-      # don't append the most recent entry, since it's already in the
-      # new log due to CVS's idiosyncratic interpretation of "log -d".
-      if ($Cumulative && -f $logfile_here) {
-        open NEW_LOG, ">>$tmpfile"
-          or die "trouble appending to $tmpfile ($!)";
-        open OLD_LOG, "<$logfile_here"
-          or die "trouble reading from $logfile_here ($!)";
-        my $started_first_entry = 0;
-        my $passed_first_entry = 0;
-        while (<OLD_LOG>) {
-          if ( ! $passed_first_entry ) {
-            if ( ( ! $started_first_entry )
-                and /^(\d\d\d\d-\d\d-\d\d\s+(\w+\s+)?\d\d:\d\d)/ ) {
-              $started_first_entry = 1;
-            } elsif ( /^(\d\d\d\d-\d\d-\d\d\s+(\w+\s+)?\d\d:\d\d)/ ) {
-              $passed_first_entry = 1;
-              print NEW_LOG $_;
-          } else {
-            print NEW_LOG $_;
-        close NEW_LOG;
-        close OLD_LOG;
-      if ( -f $logfile_here ) {
-        rename $logfile_here, $logfile_bak;
-      rename $tmpfile, $logfile_here;
-# Don't call this wrap, because with 5.5.3, that clashes with the
-# (unconditional :-( ) export of wrap() from Text::Wrap
-sub mywrap {
-  my $self = shift;
-  my ($indent1, $indent2, @text) = @_;
-  # If incoming text looks preformatted, don't get clever
-  my $text = Text::Wrap::wrap($indent1, $indent2, @text);
-  if ( grep /^\s+/m, @text ) {
-    return $text;
-  my @lines = split /\n/, $text;
-  $indent2 =~ s!^((?: {8})+)!"\t" x (length($1)/8)!e;
-  $lines[0] =~ s/^$indent1\s+/$indent1/;
-  s/^$indent2\s+/$indent2/
-    for @lines[1..$#lines];
-  my $newtext = join "\n", @lines;
-  $newtext .= "\n"
-    if substr($text, -1) eq "\n";
-  return $newtext;
-  my $self = shift;
-  my ($text) = @_;
-  # Strip out carriage returns (as they probably result from DOSsy editors).
-  $text =~ s/\r\n/\n/g;
-  # If it *looks* like two newlines, make it *be* two newlines:
-  $text =~ s/\n\s*\n/\n\n/g;
-  return $text;
-sub last_line_len {
-  my $self = shift;
-  my $files_list = shift;
-  my @lines = split (/\n/, $files_list);
-  my $last_line = pop (@lines);
-  return length ($last_line);
-# A custom wrap function, sensitive to some common constructs used in
-# log entries.
-sub wrap_log_entry {
-  my $self = shift;
-  my $text = shift;                  # The text to wrap.
-  my $left_pad_str = shift;          # String to pad with on the left.
-  # These do NOT take left_pad_str into account:
-  my $length_remaining = shift;      # Amount left on current line.
-  my $max_line_length  = shift;      # Amount left for a blank line.
-  my $wrapped_text = '';             # The accumulating wrapped entry.
-  my $user_indent = '';              # Inherited user_indent from prev line.
-  my $first_time = 1;                # First iteration of the loop?
-  my $suppress_line_start_match = 0; # Set to disable line start checks.
-  my @lines = split (/\n/, $text);
-  while (@lines)   # Don't use `foreach' here, it won't work.
-    my $this_line = shift (@lines);
-    chomp $this_line;
-    if ($this_line =~ /^(\s+)/) {
-      $user_indent = $1;
-    else {
-      $user_indent = '';
-    # If it matches any of the line-start regexps, print a newline now...
-    if ($suppress_line_start_match)
-      $suppress_line_start_match = 0;
-    elsif (($this_line =~ /^(\s*)\*\s+[a-zA-Z0-9]/)
-           || ($this_line =~ /^(\s*)\* [a-zA-Z0-9_\.\/\+-]+/)
-           || ($this_line =~ /^(\s*)\([a-zA-Z0-9_\.\/\+-]+(\)|,\s*)/)
-           || ($this_line =~ /^(\s+)(\S+)/)
-           || ($this_line =~ /^(\s*)- +/)
-           || ($this_line =~ /^()\s*$/)
-           || ($this_line =~ /^(\s*)\*\) +/)
-           || ($this_line =~ /^(\s*)[a-zA-Z0-9](\)|\.|\:) +/))
-      # Make a line break immediately, unless header separator is set
-      # and this line is the first line in the entry, in which case
-      # we're getting the blank line for free already and shouldn't
-      # add an extra one.
-      unless (($After_Header ne " ") and ($first_time))
-        if ($this_line =~ /^()\s*$/) {
-          $suppress_line_start_match = 1;
-          $wrapped_text .= "\n${left_pad_str}";
-      $length_remaining = $max_line_length - (length ($user_indent));
-    # Now that any user_indent has been preserved, strip off leading
-    # whitespace, so up-folding has no ugly side-effects.
-    $this_line =~ s/^\s*//;
-    # Accumulate the line, and adjust parameters for next line.
-    my $this_len = length ($this_line);
-    if ($this_len == 0)
-      # Blank lines should cancel any user_indent level.
-      $length_remaining = $max_line_length;
-    elsif ($this_len >= $length_remaining) # Line too long, try breaking it.
-      # Walk backwards from the end.  At first acceptable spot, break
-      # a new line.
-      my $idx = $length_remaining - 1;
-      if ($idx < 0) { $idx = 0 };
-      while ($idx > 0)
-        if (substr ($this_line, $idx, 1) =~ /\s/)
-          my $line_now = substr ($this_line, 0, $idx);
-          my $next_line = substr ($this_line, $idx);
-          $this_line = $line_now;
-          # Clean whitespace off the end.
-          chomp $this_line;
-          # The current line is ready to be printed.
-          $this_line .= "\n${left_pad_str}";
-          # Make sure the next line is allowed full room.
-          # Strip next_line, but then preserve any user_indent.
-          $next_line =~ s/^\s*//;
-          # Sneak a peek at the user_indent of the upcoming line, so
-          # $next_line (which will now precede it) can inherit that
-          # indent level.  Otherwise, use whatever user_indent level
-          # we currently have, which might be none.
-          my $next_next_line = shift (@lines);
-          if ((defined ($next_next_line)) && ($next_next_line =~ /^(\s+)/)) {
-            $next_line = $1 . $next_line if (defined ($1));
-            # $length_remaining = $max_line_length - (length ($1));
-            $next_next_line =~ s/^\s*//;
-          else {
-            $next_line = $user_indent . $next_line;
-          if (defined ($next_next_line)) {
-            unshift (@lines, $next_next_line);
-          unshift (@lines, $next_line);
-          # Our new next line might, coincidentally, begin with one of
-          # the line-start regexps, so we temporarily turn off
-          # sensitivity to that until we're past the line.
-          last;
-        else
-          $idx--;
-      if ($idx == 0)
-        # We bottomed out because the line is longer than the
-        # available space.  But that could be because the space is
-        # small, or because the line is longer than even the maximum
-        # possible space.  Handle both cases below.
-        if ($length_remaining == ($max_line_length - (length ($user_indent))))
-          # The line is simply too long -- there is no hope of ever
-          # breaking it nicely, so just insert it verbatim, with
-          # appropriate padding.
-          $this_line = "\n${left_pad_str}${this_line}";
-        else
-          # Can't break it here, but may be able to on the next round...
-          unshift (@lines, $this_line);
-          $this_line = "\n${left_pad_str}";
-    else  # $this_len < $length_remaining, so tack on what we can.
-      # Leave a note for the next iteration.
-      $length_remaining = $length_remaining - $this_len;
-      if ($this_line =~ /\.$/)
-        $this_line .= "  ";
-        $length_remaining -= 2;
-      else  # not a sentence end
-        $length_remaining -= 1;
-    # Unconditionally indicate that loop has run at least once.
-    $first_time = 0;
-    $wrapped_text .= "${user_indent}${this_line}";
-  # One last bit of padding.
-  $wrapped_text .= "\n";
-  return $wrapped_text;
-sub _pretty_file_list {
-  my $self = shift;
-  my ($unanimous_tags, $non_unanimous_tags, $all_branches, $qunksref) = @_;
-  my @qunkrefs =
-    grep +( ( ! $_->tags_exists
-              or
-              ! grep exists $ignore_tags{$_}, @{$_->tags})
-            and
-            ( ! keys %show_tags
-              or
-              ( $_->tags_exists
-                and
-                grep exists $show_tags{$_}, @{$_->tags} )
-    @$qunksref;
-  my $common_dir;           # Dir prefix common to all files ('' if none)
-  # First, loop over the qunks gathering all the tag/branch names.
-  # We'll put them all in non_unanimous_tags, and take out the
-  # unanimous ones later.
- QUNKREF:
-    # Keep track of whether all the files in this commit were in the
-    # same directory, and memorize it if so.  We can make the output a
-    # little more compact by mentioning the directory only once.
-    if ($Common_Dir && (scalar (@qunkrefs)) > 1)
-      if (! (defined ($common_dir)))
-        my ($base, $dir);
-        ($base, $dir, undef) = fileparse ($qunkref->filename);
-        if ((! (defined ($dir)))  # this first case is sheer paranoia
-            or ($dir eq '')
-            or ($dir eq "./")
-            or ($dir eq ".\\"))
-          $common_dir = '';
-        else
-          $common_dir = $dir;
-      elsif ($common_dir ne '')
-        # Already have a common dir prefix, so how much of it can we preserve?
-        $common_dir = &main::common_path_prefix ($qunkref->filename, $common_dir);
-    else  # only one file in this entry anyway, so common dir not an issue
-      $common_dir = '';
-    if (defined ($qunkref->branch)) {
-      $all_branches->{$qunkref->branch} = 1;
-    if (defined ($qunkref->tags)) {
-      foreach my $tag (@{$qunkref->tags}) {
-        $non_unanimous_tags->{$tag} = 1;
-  # Any tag held by all qunks will be printed specially... but only if
-  # there are multiple qunks in the first place!
-  if ((scalar (@qunkrefs)) > 1) {
-    foreach my $tag (keys (%$non_unanimous_tags)) {
-      my $everyone_has_this_tag = 1;
-      foreach my $qunkref (@qunkrefs) {
-        if ((! (defined ($qunkref->tags)))
-            or (! (grep ($_ eq $tag, @{$qunkref->tags})))) {
-          $everyone_has_this_tag = 0;
-      if ($everyone_has_this_tag) {
-        $unanimous_tags->{$tag} = 1;
-        delete $non_unanimous_tags->{$tag};
-  return $common_dir, \@qunkrefs;
-sub fdatetime {
-  my $self = shift;
-  my ($year, $mday, $mon, $wday, $hour, $min);
-  if ( @_ > 1 ) {
-    ($year, $mday, $mon, $wday, $hour, $min) = @_;
-  } else {
-    my ($time) = @_;
-    (undef, $min, $hour, $mday, $mon, $year, $wday) =
-      $UTC_Times ? gmtime($time) : localtime($time);
-    $year += 1900;
-    $mon  += 1;
-  my $fdate = $self->fdate($year, $mon, $mday, $wday);
-    my $ftime = $self->ftime($hour, $min);
-    return "$fdate $ftime";
-  } else {
-    return $fdate;
-sub fdate {
-  my $self = shift;
-  my ($year, $mday, $mon, $wday);
-  if ( @_ > 1 ) {
-    ($year, $mon, $mday, $wday) = @_;
-  } else {
-    my ($time) = @_;
-    (undef, undef, undef, $mday, $mon, $year, $wday) =
-    $year += 1900;
-    $mon  += 1;
-  return sprintf '%4u-%02u-%02u%s', $year, $mon, $mday, $wday;
-sub ftime {
-  my $self = shift;
-  my ($hour, $min);
-  if ( @_ > 1 ) {
-    ($hour, $min) = @_;
-  } else {
-    my ($time) = @_;
-    (undef, $min, $hour) = $UTC_Times ? gmtime($time) : localtime($time);
-  return sprintf '%02u:%02u', $hour, $min;
-package CVS::Utils::ChangeLog::Message;
-sub new {
-  my ($msg) = @_;
-  my %self = (msg => $msg, files => []);
-  my $self = shift;
-  my ($fileentry) = @_;
-  die "Not a fileentry: $fileentry"
-    unless $fileentry->isa('CVS::Utils::ChangeLog::FileEntry');
-  push @{$self->{files}}, $fileentry;
-sub files { wantarray ? @{$_[0]->{files}} : $_[0]->{files} }
-package CVS::Utils::ChangeLog::FileEntry;
-# Each revision of a file has a little data structure (a `qunk')
-# associated with it.  That data structure holds not only the
-# file's name, but any additional information about the file
-# that might be needed in the output, such as the revision
-# number, tags, branches, etc.  The reason to have these things
-# arranged in a data structure, instead of just appending them
-# textually to the file's name, is that we may want to do a
-# little rearranging later as we write the output.  For example,
-# all the files on a given tag/branch will go together, followed
-# by the tag in parentheses (so trunk or otherwise non-tagged
-# files would go at the end of the file list for a given log
-# message).  This rearrangement is a lot easier to do if we
-# don't have to reparse the text.
-# A qunk looks like this:
-#     filename    =>    "hello.c",
-#     revision    =>    "1.4.3.2",
-#     time        =>    a timegm() return value (moment of commit)
-#     tags        =>    [ "tag1", "tag2", ... ],
-#     branch      =>    "branchname" # There should be only one, right?
-#     roots       =>    [ "branchtag1", "branchtag2", ... ]
-#     lines       =>    "+x -y" # or undefined; x and y are integers
-# Single top-level ChangeLog, or one per subdirectory?
-my $distributed;
-sub distributed { $#_ ? ($distributed = $_[1]) : $distributed; }
-sub new {
-  my ($path, $time, $revision, $state, $lines,
-      $branch_names, $branch_roots, $branch_numbers, $symbolic_names) = @_;
-  my %self = (time     => $time,
-              revision => $revision,
-              state    => $state,
-              lines    => $lines,
-              branch_numbers => $branch_numbers,
-  if ( $distributed ) {
-    @self{qw(filename dir_key)} = fileparse($path);
-  } else {
-    @self{qw(filename dir_key)} = ($path, './');
-  { # Scope for $branch_prefix
-    (my ($branch_prefix) = ($revision =~ /((?:\d+\.)+)\d+/));
-    $branch_prefix =~ s/\.$//;
-    if ( $branch_names->{$branch_prefix} ) {
-      my $branch_name = $branch_names->{$branch_prefix};
-      $self{branch}   = $branch_name;
-      $self{branches} = [$branch_name];
-    while ( $branch_prefix =~ s/^(\d+(?:\.\d+\.\d+)+)\.\d+\.\d+$/$1/ ) {
-      push @{$self{branches}}, $branch_names->{$branch_prefix}
-        if exists $branch_names->{$branch_prefix};
-  # If there's anything in the @branch_roots array, then this
-  # revision is the root of at least one branch.  We'll display
-  # them as branch names instead of revision numbers, the
-  # substitution for which is done directly in the array:
-  $self{'roots'} = [ map { $branch_names->{$_} } @$branch_roots ]
-    if @$branch_roots;
-  if ( exists $symbolic_names->{$revision} ) {
-    $self{tags} = delete $symbolic_names->{$revision};
-    &main::delta_check($time, $self{tags});
-sub filename       { $_[0]->{filename}       }
-sub dir_key        { $_[0]->{dir_key}        }
-sub revision       { $_[0]->{revision}       }
-sub branch         { $_[0]->{branch}         }
-sub state          { $_[0]->{state}          }
-sub lines          { $_[0]->{lines}          }
-sub roots          { $_[0]->{roots}          }
-sub branch_numbers { $_[0]->{branch_numbers} }
-sub tags        { $_[0]->{tags}     }
-sub tags_exists {
-  exists $_[0]->{tags};
-# This may someday be used in a more sophisticated calculation of what other
-# files are involved in this commit.  For now, we don't use it much except for
-# delta mode, because the common-commit-detection algorithm is hypothesized to
-# be "good enough" as it stands.
-sub time     { $_[0]->{time}     }
-package CVS::Utils::ChangeLog::EntrySetBuilder;
-use constant MAILNAME => "/etc/mailname";
-# In 'cvs log' output, one long unbroken line of equal signs separates files:
-use constant FILE_SEPARATOR => '=' x 77;# . "\n";
-# In 'cvs log' output, a shorter line of dashes separates log messages within
-# a file:
-use constant REV_SEPARATOR  => '-' x 28;# . "\n";
-use constant EMPTY_LOG_MESSAGE => '*** empty log message ***';
-sub new {
-  my ($proto) = @_;
-  my $poobah  = CVS::Utils::ChangeLog::EntrySet->new;
-  my $self = bless +{ grand_poobah => $poobah }, $class;
-  $self->clear_file;
-  $self->maybe_read_user_map_file;
-  return $self;
-sub clear_msg {
-  my ($self) = @_;
-  # Make way for the next message
-  undef $self->{rev_msg};
-  undef $self->{rev_time};
-  undef $self->{rev_revision};
-  undef $self->{rev_author};
-  undef $self->{rev_state};
-  undef $self->{lines};
-  $self->{rev_branch_roots} = [];       # For showing which files are branch
-                                        # ancestors.
-  $self->{collecting_symbolic_names} = 0;
-sub clear_file {
-  my ($self) = @_;
-  $self->clear_msg;
-  undef $self->{filename};
-  $self->{branch_names}   = +{};        # We'll grab branch names while we're
-                                        # at it.
-  $self->{branch_numbers} = +{};        # Save some revisions for
-                                        # @Follow_Branches
-  $self->{symbolic_names} = +{};        # Where tag names get stored.
-sub grand_poobah { $_[0]->{grand_poobah} }
-sub read_changelog {
-  my ($self, $command) = @_;
-  local (*READER, *WRITER);
-  my $pid;
-  if (! $Input_From_Stdin) {
-    pipe(READER, WRITER)
-      or die "Couldn't form pipe: $!\n";
-    $pid = fork;
-    die "Couldn't fork: $!\n"
-      if ! defined $pid;
-    if ( ! $pid ) { # child
-      open STDOUT, '>&=' . fileno WRITER
-        or die "Couldn't dup stderr to ", fileno WRITER, "\n";
-      # strangely, some perls give spurious warnings about STDIN being opened
-      # for output only these close calls precede the STDOUT reopen above.
-      # I think they must be reusing fd 1.
-      close READER;
-      close STDIN;
-      exec @$command;
-    close WRITER;
-    &main::debug ("(run \"@$command\")\n");
-  else {
-    open READER, '-' or die "unable to open stdin for reading";
-  binmode READER;
- XX_Log_Source:
-  while (<READER>) {
-    chomp;
-    s!\r$!!;
-    # If on a new file and don't see filename, skip until we find it, and
-    # when we find it, grab it.
-    if ( ! defined $self->{filename} ) {
-      $self->read_file_path($_);
-    } elsif ( /^symbolic names:$/ ) {
-      $self->{collecting_symbolic_names} = 1;
-    } elsif ( $self->{collecting_symbolic_names} ) {
-      $self->read_symbolic_name($_);
-    } elsif ( $_ eq FILE_SEPARATOR and ! defined $self->{rev_revision} ) {
-    } elsif ( ! defined $self->{rev_revision} ) {
-        # If have file name, but not revision, and see revision, then grab
-        # it.  (We collect unconditionally, even though we may or may not
-        # ever use it.)
-      $self->read_revision($_);
-    } elsif ( ! defined $self->{rev_time} ) { # and /^date: /) {
-      $self->read_date_author_and_state($_);
-    } elsif ( /^branches:\s+(.*);$/ ) {
-      $self->read_branches($1);
-    } elsif ( ! ( $_ eq FILE_SEPARATOR or $_ eq REV_SEPARATOR ) ) {
-      # If have file name, time, and author, then we're just grabbing
-      # log message texts:
-      $self->{rev_msg} .= $_ . "\n";   # Normally, just accumulate the message...
-    } else {
-      my $noadd = 0;
-      if ( ! $self->{rev_msg}
-           or $self->{rev_msg} =~ /^\s*(\.\s*)?$/
-           or index($self->{rev_msg}, EMPTY_LOG_MESSAGE) > -1 ) {
-        # ... until a msg separator is encountered:
-        # Ensure the message contains something:
-        $self->clear_msg, $noadd = 1
-          if $Prune_Empty_Msgs;
-        $self->{rev_msg} = "[no log message]\n";
-      $self->add_file_entry
-        unless $noadd;
-      if ( $_ eq FILE_SEPARATOR ) {
-      } else {
-        $self->clear_msg;
-  close READER
-    or die "Couldn't close pipe reader: $!\n";
-  if ( defined $pid ) {
-    my $rv;
-    waitpid $pid, 0;
-    0 == $?
-      or $!=1, die sprintf("Problem reading log input (pid/exit/signal/core: %d/%d/%d/%d)\n",
-                           $pid, $? >> 8, $? & 127, $? & 128);
-  return;
-sub add_file_entry {
-  $_[0]->grand_poobah->add_fileentry(@{$_[0]}{qw(filename rev_time rev_revision
-                                                 rev_state lines branch_names
-                                                 rev_branch_roots
-                                                 branch_numbers
-                                                 symbolic_names
-                                                 rev_author rev_msg)});
-sub maybe_read_user_map_file {
-  my ($self) = @_;
-  my %expansions;
-  my $User_Map_Input;
-  if ($User_Map_File)
-    if ( $User_Map_File =~ m{^([-\w\@+=.,\/]+):([-\w\@+=.,\/:]+)} and
-         !-f $User_Map_File )
-      my $rsh = (exists $ENV{'CVS_RSH'} ? $ENV{'CVS_RSH'} : 'ssh');
-      $User_Map_Input = "$rsh $1 'cat $2' |";
-      &main::debug ("(run \"${User_Map_Input}\")\n");
-    else
-      $User_Map_Input = "<$User_Map_File";
-    open (MAPFILE, $User_Map_Input)
-        or die ("Unable to open $User_Map_File ($!)");
-    while (<MAPFILE>)
-      next if /^\s*#/;  # Skip comment lines.
-      next if not /:/;  # Skip lines without colons.
-      # It is now safe to split on ':'.
-      my ($username, $expansion) = split ':';
-      chomp $expansion;
-      $expansion =~ s/^'(.*)'$/$1/;
-      $expansion =~ s/^"(.*)"$/$1/;
-      # If it looks like the expansion has a real name already, then
-      # we toss the username we got from CVS log.  Otherwise, keep
-      # it to use in combination with the email address.
-      if ($expansion =~ /^\s*<{0,1}\S+ at .*/) {
-        # Also, add angle brackets if none present
-        if (! ($expansion =~ /<\S+@\S+>/)) {
-          $expansions{$username} = "$username <$expansion>";
-        else {
-          $expansions{$username} = "$username $expansion";
-      else {
-        $expansions{$username} = $expansion;
-    } # fi ($User_Map_File)
-    close (MAPFILE);
-  if (defined $User_Passwd_File)
-    if ( ! defined $Domain ) {
-      if ( -e MAILNAME ) {
-        chomp($Domain = slurp_file(MAILNAME));
-      } else {
-      MAILDOMAIN_CMD:
-        for ([qw(hostname -d)], 'dnsdomainname', 'domainname') {
-          my ($text, $exit, $sig, $core) = run_ext($_);
-          if ( $exit == 0 && $sig == 0 && $core == 0 ) {
-            chomp $text;
-            if ( length $text ) {
-              $Domain = $text;
-              last MAILDOMAIN_CMD;
-    die "No mail domain found\n"
-      unless defined $Domain;
-    open (MAPFILE, "<$User_Passwd_File")
-        or die ("Unable to open $User_Passwd_File ($!)");
-    while (<MAPFILE>)
-      # all lines are valid
-      my ($username, $pw, $uid, $gid, $gecos, $homedir, $shell) = split ':';
-      my $expansion = '';
-      ($expansion) = split (',', $gecos)
-        if defined $gecos && length $gecos;
-      my $mailname = $Domain eq '' ? $username : "$username\@$Domain";
-      $expansions{$username} = "$expansion <$mailname>";
-    close (MAPFILE);
- $self->{usermap} = \%expansions;
-sub read_file_path {
-  my ($self, $line) = @_;
-  my $path;
-  if ( $line =~ /^Working file: (.*)/ ) {
-    $path = $1;
-  } elsif ( defined $RCS_Root
-            and
-            $line =~ m|^RCS file: $RCS_Root[/\\](.*),v$| ) {
-    $path = $1;
-    $path =~ s!Attic/!!;
-  } else {
-    return;
-  if ( @Ignore_Files ) {
-    my $base;
-    ($base, undef, undef) = fileparse($path);
-    my $xpath = $Case_Insensitive ? lc($path) : $path;
-    return
-      if grep $path =~ /$_/, @Ignore_Files;
-  $self->{filename} = $path;
-  return;
-sub read_symbolic_name {
-  # All tag names are listed with whitespace in front in cvs log
-  # output; so if see non-whitespace, then we're done collecting.
-  if ( /^\S/ ) {
-    return;
-  } else {
-    # we're looking at a tag name, so parse & store it
-    # According to the Cederqvist manual, in node "Tags", tag names must start
-    # with an uppercase or lowercase letter and can contain uppercase and
-    # lowercase letters, digits, `-', and `_'.  However, it's not our place to
-    # enforce that, so we'll allow anything CVS hands us to be a tag:
-    my ($tag_name, $tag_rev) = ($line =~ /^\s+([^:]+): ([\d.]+)$/);
-    # A branch number either has an odd number of digit sections
-    # (and hence an even number of dots), or has ".0." as the
-    # second-to-last digit section.  Test for these conditions.
-    my $real_branch_rev = '';
-    if ( $tag_rev =~ /^(\d+\.\d+\.)+\d+$/             # Even number of dots...
-         and
-         $tag_rev !~ /^(1\.)+1$/ ) {                  # ...but not "1.[1.]1"
-      $real_branch_rev = $tag_rev;
-    } elsif ($tag_rev =~ /(\d+\.(\d+\.)+)0.(\d+)/) {  # Has ".0."
-      $real_branch_rev = $1 . $3;
-    # If we got a branch, record its number.
-    if ( $real_branch_rev ) {
-      $self->{branch_names}->{$real_branch_rev} = $tag_name;
-      $self->{branch_numbers}->{$tag_name} = $real_branch_rev;
-    } else {
-      # Else it's just a regular (non-branch) tag.
-      push @{$self->{symbolic_names}->{$tag_rev}}, $tag_name;
-  return;
-sub read_revision {
-  my ($revision) = ( $line =~ /^revision (\d+\.[\d.]+)/ );
-  return
-    unless $revision;
-  $self->{rev_revision} = $revision;
-  return;
-{ # Closure over %gecos_warned
-my %gecos_warned;
-sub read_date_author_and_state {
-  my ($time, $author, $state) = $self->parse_date_author_and_state($line);
-  if ( defined($self->{usermap}->{$author}) and $self->{usermap}->{$author} ) {
-    $author = $self->{usermap}->{$author};
-  } elsif ( defined $Domain or $Gecos == 1 ) {
-    my $email = $author;
-    $email = $author."@".$Domain
-      if defined $Domain && $Domain ne '';
-    my $pw = getpwnam($author);
-    my ($fullname, $office, $workphone, $homephone, $gcos);
-    if ( defined $pw ) {
-      $gcos = (getpwnam($author))[6];
-      ($fullname, $office, $workphone, $homephone) =
-        split /\s*,\s*/, $gcos;
-    } else {
-      warn "Couldn't find gecos info for author '$author'\n"
-        unless $gecos_warned{$author}++;
-      $fullname = '';
-    for (grep defined, $fullname, $office, $workphone, $homephone) {
-      s/&/ucfirst(lc($pw->name))/ge;
-    $author = $fullname . "  <" . $email . ">"
-      if $fullname ne '';
-  $self->{rev_state}  = $state;
-  $self->{rev_time}   = $time;
-  $self->{rev_author} = $author;
-  return;
-sub read_branches {
-  # A "branches: ..." line here indicates that one or more branches
-  # are rooted at this revision.  If we're showing branches, then we
-  # want to show that fact as well, so we collect all the branches
-  # that this is the latest ancestor of and store them in
-  # $self->[rev_branch_roots}.  Just for reference, the format of the
-  # line we're seeing at this point is:
-  #    branches:  1.5.2;  1.5.4;  ...;
-  # Okay, here goes:
-  # Ugh.  This really bothers me.  Suppose we see a log entry
-  # like this:
-  #    revision 1.1
-  #    date: 1999/10/17 03:07:38;  author: jrandom;  state: Exp;
-  #    branches:  1.1.2;
-  #    Intended first line of log message begins here.
-  # The question is, how we can tell the difference between that
-  # log message and a *two*-line log message whose first line is
-  #    "branches:  1.1.2;"
-  # See the problem?  The output of "cvs log" is inherently
-  # ambiguous.
-  # For now, we punt: we liberally assume that people don't
-  # write log messages like that, and just toss a "branches:"
-  # line if we see it but are not showing branches.  I hope no
-  # one ever loses real log data because of this.
-  if ( $Show_Branches ) {
-    $line =~ s/(1\.)+1;|(1\.)+1$//;  # ignore the trivial branch 1.1.1
-    $self->{rev_branch_roots} = [split /;\s+/, $line]
-      if length $line;
-sub parse_date_author_and_state {
-  # Parses the date/time and author out of a line like:
-  # date: 1999/02/19 23:29:05;  author: apharris;  state: Exp;
-  # or, in CVS 1.12.9:
-  # date: 2004-06-05 16:10:32 +0000; author: somebody; state: Exp;
-  my ($year, $mon, $mday, $hours, $min, $secs, $utcOffset, $author, $state, $rest) =
-    $line =~
-      m!(\d+)[-/](\d+)[-/](\d+)\s+(\d+):(\d+):(\d+)(\s+[+-]\d{4})?;\s+
-        author:\s+([^;]+);\s+state:\s+([^;]+);(.*)!x
-    or  die "Couldn't parse date ``$line''";
-  die "Bad date or Y2K issues"
-    unless $year > 1969 and $year < 2258;
-  # Kinda arbitrary, but useful as a sanity check
-  my $time = timegm($secs, $min, $hours, $mday, $mon-1, $year-1900);
-  if ( defined $utcOffset ) {
-    my ($plusminus, $hour, $minute) = ($utcOffset =~ m/([+-])(\d\d)(\d\d)/);
-    my $offset = (($hour * 60) + $minute) * 60 * ($plusminus eq '+' ? -1 : 1);
-    $time += $offset;
-  if ( $rest =~ m!\s+lines:\s+(.*)! ) {
-    $self->{lines} = $1;
-  return $time, $author, $state;
-# Subrs ----------------------------------------------------------------------
-package main;
-sub delta_check {
-  my ($time, $tags) = @_;
-  # If we're in 'delta' mode, update the latest observed times for the
-  # beginning and ending tags, and when we get around to printing output, we
-  # will simply restrict ourselves to that timeframe...
-  return
-    unless $Delta_Mode;
-  $Delta_StartTime = $time
-    if $time > $Delta_StartTime and grep { $_ eq $Delta_From } @$tags;
-  $Delta_EndTime = $time
-    if $time > $Delta_EndTime and grep { $_ eq $Delta_To } @$tags;
-sub run_ext {
-  my ($cmd) = @_;
-  $cmd = [$cmd]
-    unless ref $cmd;
-  local $" = ' ';
-  my $out = qx"@$cmd 2>&1";
-  my $rv  = $?;
-  my ($sig, $core, $exit) = ($? & 127, $? & 128, $? >> 8);
-  return $out, $exit, $sig, $core;
-# If accumulating, grab the boundary date from pre-existing ChangeLog.
-sub maybe_grab_accumulation_date {
-  if (! $Cumulative || $Update) {
-    return '';
-  # else
-  open (LOG, "$Log_File_Name")
-      or die ("trouble opening $Log_File_Name for reading ($!)");
-  my $boundary_date;
-  while (<LOG>)
-    if (/^(\d\d\d\d-\d\d-\d\d\s+(\w+\s+)?\d\d:\d\d)/)
-      $boundary_date = "$1";
-      last;
-  close (LOG);
-  # convert time from utc to local timezone if the ChangeLog has
-  # dates/times in utc
-  if ($UTC_Times && $boundary_date)
-    # convert the utc time to a time value
-    my ($year,$mon,$mday,$hour,$min) = $boundary_date =~
-      m#(\d+)-(\d+)-(\d+)\s+(\d+):(\d+)#;
-    my $time = timegm(0,$min,$hour,$mday,$mon-1,$year-1900);
-    # print the timevalue in the local timezone
-    my ($ignore,$wday);
-    ($ignore,$min,$hour,$mday,$mon,$year,$wday) = localtime($time);
-    $boundary_date=sprintf ("%4u-%02u-%02u %02u:%02u",
-                            $year+1900,$mon+1,$mday,$hour,$min);
-  return $boundary_date;
-# Fills up a ChangeLog structure in the current directory.
-sub derive_changelog {
-  my ($command) = @_;
-  # See "The Plan" above for a full explanation.
-  # Might be adding to an existing ChangeLog
-  my $accumulation_date = maybe_grab_accumulation_date;
-  if ($accumulation_date) {
-    # Insert -d immediately after 'cvs log'
-    my $Log_Date_Command = "-d>${accumulation_date}";
-    my ($log_index) = grep $command->[$_] eq 'log', 0..$#$command;
-    splice @$command, $log_index+1, 0, $Log_Date_Command;
-    &debug ("(adding log msg starting from $accumulation_date)\n");
-#  output_changelog(read_changelog($command));
-  my $builder = CVS::Utils::ChangeLog::EntrySetBuilder->new;
-  $builder->read_changelog($command);
-  $builder->grand_poobah->output_changelog;
-sub min { $_[0] < $_[1] ? $_[0] : $_[1] }
-sub common_path_prefix {
-  my ($path1, $path2) = @_;
-  # For compatibility (with older versions of cvs2cl.pl), we think in UN*X
-  # terms, and mould windoze filenames to match.  Is this really appropriate?
-  # If a file is checked in under UN*X, and cvs log run on windoze, which way
-  # do the path separators slope?  Can we use fileparse as per the local
-  # conventions?  If so, we should probably have a user option to specify an
-  # OS to emulate to handle stdin-fed logs.  If we did this, we could avoid
-  # the nasty \-/ transmogrification below.
-  my ($dir1, $dir2) = map +(fileparse($_))[1], $path1, $path2;
-  # Transmogrify Windows filenames to look like Unix.
-  # (It is far more likely that someone is running cvs2cl.pl under
-  # Windows than that they would genuinely have backslashes in their
-  # filenames.)
-  tr!\\!/!
-    for $dir1, $dir2;
-  my ($accum1, $accum2, $last_common_prefix) = ('') x 3;
-  my @path1 = grep length($_), split qr!/!, $dir1;
-  my @path2 = grep length($_), split qr!/!, $dir2;
-  my @common_path;
-  for (0..min($#path1,$#path2)) {
-    if ( $path1[$_] eq $path2[$_]) {
-      push @common_path, $path1[$_];
-    } else {
-      last;
-  return join '', map "$_/", @common_path;
-sub parse_options {
-  # Check this internally before setting the global variable.
-  my $output_file;
-  # If this gets set, we encountered unknown options and will exit at
-  # the end of this subroutine.
-  my $exit_with_admonishment = 0;
-  # command to generate the log
-  my @log_source_command = qw( cvs log );
-  my (@Global_Opts, @Local_Opts);
-  Getopt::Long::Configure(qw( bundling permute no_getopt_compat
-                              pass_through no_ignore_case ));
-  GetOptions('help|usage|h'   => \$Print_Usage,
-             'debug'          => \$Debug,        # unadvertised option, heh
-             'version'        => \$Print_Version,
-             'file|f=s'       => \$output_file,
-             'accum'          => \$Cumulative,
-             'update'         => \$Update,
-             'fsf'            => \$FSF_Style,
-             'rcs=s'          => \$RCS_Root,
-             'usermap|U=s'    => \$User_Map_File,
-             'gecos'          => \$Gecos,
-             'domain=s'       => \$Domain,
-             'passwd=s'       => \$User_Passwd_File,
-             'window|W=i'     => \$Max_Checkin_Duration,
-             'chrono'         => \$Chronological_Order,
-             'ignore|I=s'     => \@Ignore_Files,
-             'case-insensitive|C' => \$Case_Insensitive,
-             'regexp|R=s'     => \$Regexp_Gate,
-             'stdin'          => \$Input_From_Stdin,
-             'stdout'         => \$Output_To_Stdout,
-             'distributed|d'  => sub { CVS::Utils::ChangeLog::FileEntry->distributed(1) },
-             'prune|P'        => \$Prune_Empty_Msgs,
-             'no-wrap'        => \$No_Wrap,
-             'gmt|utc'        => \$UTC_Times,
-             'day-of-week|w'  => \$Show_Day_Of_Week,
-             'revisions|r'    => \$Show_Revisions,
-             'show-dead'      => \$Show_Dead,
-             'tags|t'         => \$Show_Tags,
-             'tagdates|T'     => \$Show_Tag_Dates,
-             'branches|b'     => \$Show_Branches,
-             'follow|F=s'     => \@Follow_Branches,
-             'follow-only=s'  => \@Follow_Only,
-             'xml-encoding=s' => \$XML_Encoding,
-             'xml'            => \$XML_Output,
-             'noxmlns'        => \$No_XML_Namespace,
-             'no-xml-iso-date' => \$No_XML_ISO_Date,
-             'no-ancestors'   => \$No_Ancestors,
-             'lines-modified' => \$Show_Lines_Modified,
-             'no-indent'    => sub {
-               $Indent = '';
-             'summary'      => sub {
-               $Summary = 1;
-               $After_Header = "\n\n"; # Summary implies --separate-header
-             'no-times'     => sub {
-               $Show_Times = 0;
-             'no-hide-branch-additions' => sub {
-               $Hide_Branch_Additions = 0;
-             'no-common-dir'  => sub {
-               $Common_Dir = 0;
-             'ignore-tag=s'   => sub {
-               $ignore_tags{$_[1]} = 1;
-             'show-tag=s'     => sub {
-               $show_tags{$_[1]} = 1;
-             # Deliberately undocumented.  This is not a public interface, and
-             # may change/disappear at any time.
-             'test-code=s'    => \$TestCode,
-             'delta=s'        => sub {
-               my $arg = $_[1];
-               if ( $arg =~
-                    /^([A-Za-z][A-Za-z0-9_\-\]\[]*):([A-Za-z][A-Za-z0-9_\-\]\[]*)$/ ) {
-                 $Delta_From = $1;
-                 $Delta_To = $2;
-                 $Delta_Mode = 1;
-               } else {
-                 die "--delta FROM_TAG:TO_TAG is what you meant to say.\n";
-             'FSF'             => sub {
-               $Show_Times = 0;
-               $Common_Dir = 0;
-               $No_Extra_Indent = 1;
-               $Indent = "\t";
-             'header=s'        => sub {
-               my $narg = $_[1];
-               $ChangeLog_Header = &slurp_file ($narg);
-               if (! defined ($ChangeLog_Header)) {
-                 $ChangeLog_Header = '';
-             'global-opts|g=s' => sub {
-               my $narg = $_[1];
-               push @Global_Opts, $narg;
-               splice @log_source_command, 1, 0, $narg;
-             'log-opts|l=s' => sub {
-               my $narg = $_[1];
-               push @Local_Opts, $narg;
-               push @log_source_command, $narg;
-             'mailname=s'   => sub {
-               my $narg = $_[1];
-               warn "--mailname is deprecated; please use --domain instead\n";
-               $Domain = $narg;
-             'separate-header|S' => sub {
-             'group-within-date' => sub {
-               $GroupWithinDate = 1;
-               $Show_Times = 0;
-             'hide-filenames' => sub {
-               $Hide_Filenames = 1;
-               $After_Header = '';
-    or die "options parsing failed\n";
-  push @log_source_command, map "$_", @ARGV;
-  ## Check for contradictions...
-  if ($Output_To_Stdout && CVS::Utils::ChangeLog::FileEntry->distributed) {
-    print STDERR "cannot pass both --stdout and --distributed\n";
-    $exit_with_admonishment = 1;
-  if ($Output_To_Stdout && $output_file) {
-    print STDERR "cannot pass both --stdout and --file\n";
-  if ($Input_From_Stdin && @Global_Opts) {
-    print STDERR "cannot pass both --stdin and -g\n";
-  if ($Input_From_Stdin && @Local_Opts) {
-    print STDERR "cannot pass both --stdin and -l\n";
-  if ($XML_Output && $Cumulative) {
-    print STDERR "cannot pass both --xml and --accum\n";
-  # Other consistency checks and option-driven logic
-  # Bleargh.  Compensate for a deficiency of custom wrapping.
-  if ( ($After_Header ne " ") and $FSF_Style ) {
-    $After_Header .= "\t";
-  @Ignore_Files = map lc, @Ignore_Files
-    if $Case_Insensitive;
-  # Or if any other error message has already been printed out, we
-  # just leave now:
-  if ($exit_with_admonishment) {
-    &usage ();
-    exit (1);
-  elsif ($Print_Usage) {
-    &usage ();
-    exit (0);
-  elsif ($Print_Version) {
-    &version ();
-    exit (0);
-  ## Else no problems, so proceed.
-  if ($output_file) {
-    $Log_File_Name = $output_file;
-  return \@log_source_command;
-sub slurp_file {
-  my $filename = shift || die ("no filename passed to slurp_file()");
-  my $retstr;
-  open (SLURPEE, "<${filename}") or die ("unable to open $filename ($!)");
-  local $/ = undef;
-  $retstr = <SLURPEE>;
-  close (SLURPEE);
-  return $retstr;
-sub debug {
-  if ($Debug) {
-    my $msg = shift;
-    print STDERR $msg;
-sub version {
-  print "cvs2cl.pl version ${VERSION}; distributed under the GNU GPL.\n";
-sub usage {
-  &version ();
-  eval "use Pod::Usage qw( pod2usage )";
-   if ( $@ ) {
-    print <<'END';
-* Pod::Usage was not found.  The formatting may be suboptimal.  Consider
-  upgrading your Perl --- Pod::Usage is standard from 5.6 onwards, and
-  versions of perl prior to 5.6 are getting rather rusty, now.  Alternatively,
-  install Pod::Usage direct from CPAN.
-END
-    local $/ = undef;
-    my $message = <DATA>;
-    $message =~ s/^=(head1|item) //gm;
-    $message =~ s/^=(over|back).*\n//gm;
-    $message =~ s/\n{3,}/\n\n/g;
-    print $message;
-  } else {
-    print "\n";
-    pod2usage( -exitval => 'NOEXIT',
-               -verbose => 1,
-               -output  => \*STDOUT,
-  return;
-# Main -----------------------------------------------------------------------
-my $log_source_command = parse_options;
-if ( defined $TestCode ) {
-  eval $TestCode;
-  die "Eval failed: '$@'\n"
-    if $@;
-} else {
-  derive_changelog($log_source_command);
-__DATA__
-=head1 NAME
-cvs2cl.pl - convert cvs log messages to changelogs
-=head1 SYNOPSIS
-B<cvs2cl> [I<options>] [I<FILE1> [I<FILE2> ...]]
-=head1 DESCRIPTION
-cvs2cl produces a GNU-style ChangeLog for CVS-controlled sources by
-running "cvs log" and parsing the output. Duplicate log messages get
-unified in the Right Way.
-The default output of cvs2cl is designed to be compact, formally unambiguous,
-but still easy for humans to read.  It should be largely self-explanatory; the
-one abbreviation that might not be obvious is "utags".  That stands for
-"universal tags" -- a universal tag is one held by all the files in a given
-change entry.
-If you need output that's easy for a program to parse, use the B<--xml> option.
-Note that with XML output, just about all available information is included
-with each change entry, whether you asked for it or not, on the theory that
-your parser can ignore anything it's not looking for.
-If filenames are given as arguments cvs2cl only shows log information for the
-named files.
-=head1 OPTIONS
-=over 4
-=item B<-h>, B<-help>, B<--help>, B<-?>
-Show a short help and exit.
-=item B<--version>
-Show version and exit.
-=item B<-r>, B<--revisions>
-Show revision numbers in output.
-=item B<-b>, B<--branches>
-Show branch names in revisions when possible.
-=item B<-t>, B<--tags>
-Show tags (symbolic names) in output.
-=item B<-T>, B<--tagdates>
-Show tags in output on their first occurance.
-=item B<--show-dead>
-Show dead files.
-=item B<--stdin>
-Read from stdin, don't run cvs log.
-=item B<--stdout>
-Output to stdout not to ChangeLog.
-=item B<-d>, B<--distributed>
-Put ChangeLogs in subdirs.
-=item B<-f> I<FILE>, B<--file> I<FILE>
-Write to I<FILE> instead of ChangeLog.
-=item B<--fsf>
-Use this if log data is in FSF ChangeLog style.
-=item B<--FSF>
-Attempt strict FSF-standard compatible output.
-=item B<-W> I<SECS>, B<--window> I<SECS>
-Window of time within which log entries unify.
-=item -B<U> I<UFILE>, B<--usermap> I<UFILE>
-Expand usernames to email addresses from I<UFILE>.
-=item B<--passwd> I<PASSWORDFILE>
-Use system passwd file for user name expansion.  If no mail domain is provided
-(via B<--domain>), it tries to read one from B</etc/mailname>, output of B<hostname
--d>, B<dnsdomainname>, or B<domain-name>.  cvs2cl exits with an error if none of
-those options is successful. Use a domain of '' to prevent the addition of a
-mail domain.
-=item B<--domain> I<DOMAIN>
-Domain to build email addresses from.
-=item B<--gecos>
-Get user information from GECOS data.
-=item B<-R> I<REGEXP>, B<--regexp> I<REGEXP>
-Include only entries that match I<REGEXP>.  This option may be used multiple
-times.
-=item B<-I> I<REGEXP>, B<--ignore> I<REGEXP>
-Ignore files whose names match I<REGEXP>.  This option may be used multiple
-times.  The regexp is a perl regular expression.  It is matched as is; you may
-want to prefix with a ^ or suffix with a $ to anchor the match.
-=item B<-C>, B<--case-insensitive>
-Any regexp matching is done case-insensitively.
-=item B<-F> I<BRANCH>, B<--follow> I<BRANCH>
-Show only revisions on or ancestral to I<BRANCH>.
-=item B<--follow-only> I<BRANCH>
-Like --follow, but sub-branches are not followed.
-=item B<--no-ancestors>
-When using B<-F>, only track changes since the I<BRANCH> started.
-=item B<--no-hide-branch-additions>
-By default, entries generated by cvs for a file added on a branch (a dead 1.1
-entry) are not shown.  This flag reverses that action.
-=item B<-S>, B<--separate-header>
-Blank line between each header and log message.
-=item B<--summary>
-Add CVS change summary information.
-=item B<--no-wrap>
-Don't auto-wrap log message (recommend B<-S> also).
-=item B<--no-indent>
-Don't indent log message
-=item B<--gmt>, B<--utc>
-Show times in GMT/UTC instead of local time.
-=item B<--accum>
-Add to an existing ChangeLog (incompatible with B<--xml>).
-=item B<-w>, B<--day-of-week>
-Show day of week.
-=item B<--no-times>
-Don't show times in output.
-=item B<--chrono>
-Output log in chronological order (default is reverse chronological order).
-=item B<--header> I<FILE>
-Get ChangeLog header from I<FILE> ("B<->" means stdin).
-=item B<--xml>
-Output XML instead of ChangeLog format.
-=item B<--xml-encoding> I<ENCODING.>
-Insert encoding clause in XML header.
-=item B<--noxmlns>
-Don't include xmlns= attribute in root element.
-=item B<--hide-filenames>
-Don't show filenames (ignored for XML output).
-=item B<--no-common-dir>
-Don't shorten directory names from filenames.
-=item B<--rcs> I<CVSROOT>
-Handle filenames from raw RCS, for instance those produced by "cvs rlog"
-output, stripping the prefix I<CVSROOT>.
-=item B<-P>, B<--prune>
-Don't show empty log messages.
-=item B<--lines-modified>
-Output the number of lines added and the number of lines removed for
-each checkin (if applicable). At the moment, this only affects the
-XML output mode.
-=item B<--ignore-tag> I<TAG>
-Ignore individual changes that are associated with a given tag.
-May be repeated, if so, changes that are associated with any of
-the given tags are ignored.
-=item B<--show-tag> I<TAG>
-Log only individual changes that are associated with a given
-tag.  May be repeated, if so, changes that are associated with
-any of the given tags are logged.
-=item B<--delta> I<FROM_TAG>B<:>I<TO_TAG>
-Attempt a delta between two tags (since I<FROM_TAG> up to and
-including I<TO_TAG>).  The algorithm is a simple date-based one
-(this is a hard problem) so results are imperfect.
-=item B<-g> I<OPTS>, B<--global-opts> I<OPTS>
-Pass I<OPTS> to cvs like in "cvs I<OPTS> log ...".
-=item B<-l> I<OPTS>, B<--log-opts> I<OPTS>
-Pass I<OPTS> to cvs log like in "cvs ... log I<OPTS>".
-=back
-Notes about the options and arguments:
-=over 4
-=item *
-The B<-I> and B<-F> options may appear multiple times.
-=item *
-To follow trunk revisions, use "B<-F trunk>" ("B<-F TRUNK>" also works).  This is
-okay because no would ever, ever be crazy enough to name a branch "trunk",
-right?  Right.
-=item *
-For the B<-U> option, the I<UFILE> should be formatted like CVSROOT/users. That is,
-each line of I<UFILE> looks like this:
-       jrandom:jrandom at red-bean.com
-or maybe even like this
-       jrandom:'Jesse Q. Random <jrandom at red-bean.com>'
-Don't forget to quote the portion after the colon if necessary.
-=item *
-Many people want to filter by date.  To do so, invoke cvs2cl.pl like this:
-       cvs2cl.pl -l "-d'DATESPEC'"
-where DATESPEC is any date specification valid for "cvs log -d".  (Note that
-CVS 1.10.7 and below requires there be no space between -d and its argument).
-=item *
-Dates/times are interpreted in the local time zone.
-=item *
-Remember to quote the argument to `B<-l>' so that your shell doesn't interpret
-spaces as argument separators.
-=item *
-See the 'Common Options' section of the cvs manual ('info cvs' on UNIX-like
-systems) for more information.
-=item *
-Note that the rules for quoting under windows shells are different.
-=item *
-To run in an automated environment such as CGI or PHP, suidperl may be needed
-in order to execute as the correct user to enable /cvsroot read lock files to
-be written for the 'cvs log' command.  This is likely just a case of changing
-the /usr/bin/perl command to /usr/bin/suidperl, and explicitly declaring the
-PATH variable.
-=back
-=head1 EXAMPLES
-Some examples (working on UNIX shells):
-      # logs after 6th March, 2003 (inclusive)
-      cvs2cl.pl -l "-d'>2003-03-06'"
-      # logs after 4:34PM 6th March, 2003 (inclusive)
-      cvs2cl.pl -l "-d'>2003-03-06 16:34'"
-      # logs between 4:46PM 6th March, 2003 (exclusive) and
-      # 4:34PM 6th March, 2003 (inclusive)
-      cvs2cl.pl -l "-d'2003-03-06 16:46>2003-03-06 16:34'"
-Some examples (on non-UNIX shells):
-      # Reported to work on windows xp/2000
-      cvs2cl.pl -l  "-d"">2003-10-18;today<"""
-=head1 AUTHORS
-=over 4
-=item Karl Fogel
-=item Melissa O'Neill
-=item Martyn J. Pearce
-=back
-Contributions from
-=over 4
-=item Mike Ayers
-=item Tim Bradshaw
-=item Richard Broberg
-=item Nathan Bryant
-=item Oswald Buddenhagen
-=item Neil Conway
-=item Arthur de Jong
-=item Mark W. Eichin
-=item Dave Elcock
-=item Reid Ellis
-=item Simon Josefsson
-=item Robin Hugh Johnson
-=item Terry Kane
-=item Pete Kempf
-=item Akos Kiss
-=item Claus Klein
-=item Eddie Kohler
-=item Richard Laager
-=item Kevin Lilly
-=item Karl-Heinz Marbaise
-=item Mitsuaki Masuhara
-=item Henrik Nordstrom
-=item Joe Orton
-=item Peter Palfrader
-=item Thomas Parmelan
-=item Jordan Russell
-=item Jacek Sliwerski
-=item Johannes Stezenbach
-=item Joseph Walton
-=item Ernie Zapata
-=back
-=head1 BUGS
-Please report bugs to C<bug-cvs2cl at red-bean.com>.
-=head1 PREREQUISITES
-This script requires C<Text::Wrap>, C<Time::Local>, and C<File::Basename>.  It
-also seems to require C<Perl 5.004_04> or higher.
-=head1 OPERATING SYSTEM COMPATIBILITY
-Should work on any OS.
-=head1 SCRIPT CATEGORIES
-Version_Control/CVS
-=head1 COPYRIGHT
-(C) 2001,2002,2003,2004 Martyn J. Pearce <fluffy at cpan.org>, under the GNU GPL.
-(C) 1999 Karl Fogel <kfogel at red-bean.com>, under the GNU GPL.
-cvs2cl.pl is free software; you can redistribute it and/or modify
-it under the terms of the GNU General Public License as published by
-the Free Software Foundation; either version 2, or (at your option)
-any later version.
-cvs2cl.pl is distributed in the hope that it will be useful,
-but WITHOUT ANY WARRANTY; without even the implied warranty of
-MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-GNU General Public License for more details.
-You may have received a copy of the GNU General Public License
-along with cvs2cl.pl; see the file COPYING.  If not, write to the
-Free Software Foundation, Inc., 59 Temple Place - Suite 330,
-Boston, MA 02111-1307, USA.
-=head1 SEE ALSO
-cvs(1)
