[GRASS-SVN] r31961 - in grass/trunk: gui/wxpython/gui_modules gui/wxpython/nviz include lib lib/nviz
Wed Jul 2 06:13:08 EDT 2008
Author: martinl
Date: 2008-07-02 06:13:08 -0400 (Wed, 02 Jul 2008)
New Revision: 31961
Added:
   grass/trunk/gui/wxpython/nviz/nviz_types.i
Removed:
   grass/trunk/gui/wxpython/nviz/dig_types.i
   grass/trunk/gui/wxpython/gui_modules/nviz.py
   grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
   grass/trunk/gui/wxpython/nviz/Makefile
   grass/trunk/gui/wxpython/nviz/draw.cpp
   grass/trunk/gui/wxpython/nviz/nviz.h
   grass/trunk/gui/wxpython/nviz/surface.cpp
   grass/trunk/include/nviz.h
   grass/trunk/lib/grasslib.dox
   grass/trunk/lib/nviz/Makefile
   grass/trunk/lib/nviz/draw.c
nviz2: wxGUI fixes (surface draw mode), initial doxygen updates
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py	2008-07-02 10:13:08 UTC (rev 31961)
@@ -79,6 +79,7 @@
         #             None])
         self.init = False
+        self.render = True # render in full resolution
         # create nviz instance
@@ -192,16 +193,11 @@
     def OnLeftUp(self, event):
         self.ReleaseMouse()
-    def UpdateMap(self, render=False):
+    def UpdateMap(self):
         Updates the canvas anytime there is a change to the
         underlaying images or to the geometry of the canvas.
-        render:
-         - None do not render (todo)
-         - True render
-         - False quick render
         @param render re-render map composition
         start = time.clock()
@@ -225,12 +221,11 @@
         #glRotatef((self.y - self.lastY) * yScale, 1.0, 0.0, 0.0);
         #glRotatef((self.x - self.lastX) * xScale, 0.0, 1.0, 0.0);
-        if render is not None:
-            self.parent.onRenderGauge.Show()
-            if self.parent.onRenderGauge.GetRange() > 0:
-                self.parent.onRenderGauge.SetValue(1)
-                self.parent.onRenderTimer.Start(100)
-            self.parent.onRenderCounter = 0
+        self.parent.onRenderGauge.Show()
+        if self.parent.onRenderGauge.GetRange() > 0:
+            self.parent.onRenderGauge.SetValue(1)
+            self.parent.onRenderTimer.Start(100)
+        self.parent.onRenderCounter = 0
         if 'view' in self.update.keys():
             self.nvizClass.SetView(self.view['pos']['x'], self.view['pos']['y'],
@@ -243,11 +238,10 @@
             self.nvizClass.SetZExag(self.view['z-exag']['value'])
             del self.update['z-exag']
-        #         if render is True:
-        #             self.nvizClass.Draw(False)
-        #         elif render is False:
-        #             self.nvizClass.Draw(True) # quick
-        self.nvizClass.Draw(False)
+        if self.render is True:
+            self.nvizClass.Draw(False)
+        else:
+            self.nvizClass.Draw(True) # quick
         self.SwapBuffers()
@@ -267,7 +261,7 @@
         # self.parent.StatusbarUpdate()
         Debug.msg(3, "GLWindow.UpdateMap(): render=%s, -> time=%g" % \
-                      (render, (stop-start)))
+                      (self.render, (stop-start)))
     def EraseMap(self):
@@ -583,15 +577,18 @@
                                  # size=globalvar.DIALOG_GSELECT_SIZE,
                                  size=(200, -1),
                                  type="raster")
-            self.win['surface'][code]['map'] = map.GetId() - 1 # FIXME !
+            self.win['surface'][code]['map'] = map.GetId() - 1 # FIXME
             map.Bind(wx.EVT_TEXT, self.OnSurfaceMap)
+            # changing map topography not allowed
+            if code == 'topo':
+                map.Enable(False)
             gridSizer.Add(item=map, flag=wx.ALIGN_CENTER_VERTICAL,
                           pos=(row, 2))
             if code == 'color':
                 value = csel.ColourSelect(panel, id=wx.ID_ANY,
                                           colour=UserSettings.Get(group='nviz', key='surface',
-        subkey=['color', 'value']))
+        subkey=['color', 'value']))
                 value.Bind(csel.EVT_COLOURSELECT, self.OnSurfaceMap)
             elif code == 'mask':
                 value = None
@@ -817,7 +814,8 @@
                            style=style,
                            size=size)
-        slider.Bind(wx.EVT_SCROLL, self.OnChangeValue)
+        slider.Bind(wx.EVT_SCROLL, self.OnViewChange)
+        slider.Bind(wx.EVT_SCROLL_CHANGED, self.OnViewChanged)
         self.win['view'][name]['slider'] = slider.GetId()
         spin = wx.SpinCtrl(parent=parent, id=wx.ID_ANY, size=(65, -1),
@@ -829,7 +827,7 @@
         #         spin.SetRange(self.settings[name]['min'],
         #                      self.settings[name]['max'])
-        spin.Bind(wx.EVT_SPINCTRL, self.OnChangeValue)
+        spin.Bind(wx.EVT_SPINCTRL, self.OnViewChange)
         self.win['view'][name]['spin'] = spin.GetId()
     def UpdateSettings(self):
@@ -858,7 +856,8 @@
         return None
-    def OnChangeValue(self, event):
+    def OnViewChange(self, event):
+        """Change view, render in quick mode"""
         # find control
         winName = self.__GetWindowName(self.win['view'], event.GetId())
         if not winName:
@@ -873,8 +872,15 @@
         else:
             self.mapWindow.update[winName] = None
+        self.mapWindow.render = False
         self.mapWindow.Refresh(False)
+    def OnViewChanged(self, event):
+        """View changed, render in full resolution"""
+        print '#'
+        self.mapWindow.render = True
+        self.mapWindow.Refresh(False)
     def OnResetView(self, event):
         """Reset to default view (view page)"""
         self.mapWindow.ResetView()
@@ -989,6 +995,8 @@
         layer = self.mapWindow.GetSelectedLayer()
         id = self.mapWindow.GetMapObjId(layer)
+        print self.mapWindow.update
         # surface
@@ -1027,10 +1035,6 @@
                 del self.mapWindow.update[attrb]
-        # draw mode
-        if self.mapWindow.update.has_key('draw-mode'):
-            self.mapWindow.nvizClass.SetDrawMode(self.mapWindow.update['draw-mode'])
         # draw res
         if self.mapWindow.update.has_key('draw-res'):
             coarse, fine = self.mapWindow.update['draw-res']
@@ -1094,17 +1098,18 @@
             incSel = 0
         if map is True: # map
-            self.FindWindowById(self.win['surface'][attrb]['map']).Enable(True)
+            if attrb != 'topo': # changing map topography not allowed
+                self.FindWindowById(self.win['surface'][attrb]['map'] + 1).Enable(True) # FIXME
             if self.win['surface'][attrb]['const']:
                 self.FindWindowById(self.win['surface'][attrb]['const']).Enable(False)
             self.FindWindowById(self.win['surface'][attrb]['use']).SetSelection(1 + incSel)
         elif map is False: # const
-            self.FindWindowById(self.win['surface'][attrb]['map']).Enable(False)
+            self.FindWindowById(self.win['surface'][attrb]['map'] + 1).Enable(False)
                 self.FindWindowById(self.win['surface'][attrb]['const']).Enable(True)
             self.FindWindowById(self.win['surface'][attrb]['use']).SetSelection(2 + incSel)
         else: # unset
             self.FindWindowById(self.win['surface'][attrb]['use']).SetSelection(0)
@@ -1114,11 +1119,14 @@
         if not self.mapWindow.init:
             return
-        attrb = self.__GetWindowName(self.win['surface'], event.GetId())
+        attrb = self.__GetWindowName(self.win['surface'], event.GetId())
         if not attrb:
             return
         selection = self.FindWindowById(self.win['surface'][attrb]['use']).GetSelection()
+        if self.win['surface'][attrb]['required']:
+            selection += 1
         if selection == 0: # unset
             map = None
             value = ''
@@ -1155,17 +1163,14 @@
         mode = self.FindWindowById(self.win['surface']['draw']['mode']).GetSelection()
         if mode == 0: # coarse
             value |= wxnviz.DM_WIRE
-            self.mapWindow.update['draw-mode'] = wxnviz.DRAW_COARSE
             self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(True)
             self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(False)
         elif mode == 1: # fine
             value |= wxnviz.DM_POLY
-            self.mapWindow.update['draw-mode'] = wxnviz.DRAW_FINE
             self.FindWindowById(self.win['surface']['draw']['res-coarse']).Enable(False)
             self.FindWindowById(self.win['surface']['draw']['res-fine']).Enable(True)
         else: # both
             value |= wxnviz.DM_WIRE_POLY
-            self.mapWindow.update['draw-mode'] = wxnviz.DRAW_BOTH
@@ -1220,7 +1225,10 @@
                 for attr in ('topo', 'color'):
                     self.SetSurfaceUseMap(attr, True) # -> map
-                    self.FindWindowById(self.win['surface'][attr]['map']).SetValue(layer.name)
+                    if layer.type == 'raster':
+                        self.FindWindowById(self.win['surface'][attr]['map']).SetValue(layer.name)
+                    else:
+                        self.FindWindowById(self.win['surface'][attr]['map']).SetValue('')
                 if UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'map']) is False:
                     self.SetSurfaceUseMap('shine', False)
                     value = UserSettings.Get(group='nviz', key='surface', subkey=['shine', 'value'])
@@ -1254,6 +1262,11 @@
                     win.SetValue(data['value'])
+    def SetPage(self, name):
+        """Get named page"""
+        if name == 'surface':
+            self.notebook.SetSelection(1)
 class ViewPositionWindow(wx.Window):
     """Position control window (for NvizToolWindow)"""
     def __init__(self, parent, id, mapwindow,
@@ -1275,6 +1288,7 @@
         self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x: None)
         self.Bind(wx.EVT_PAINT, self.OnPaint)
+        # self.Bind(wx.EVT_MOTION,       self.OnMouse)
         self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouse)
     def Draw(self, pos=None):
@@ -1303,6 +1317,7 @@
         self.pdc.DrawToDC(dc)
     def OnMouse(self, event):
+        print event.LeftIsDown(), event.LeftUp()
         if event.LeftIsDown():
             x, y = event.GetPosition()
             self.Draw(pos=(x, y))
@@ -1314,6 +1329,9 @@
             self.settings['pos']['y'] = y
             self.mapWindow.update['view'] = None
-            self.mapWindow.Refresh(eraseBackground=False)
-            # self.mapWindow.UpdateMap()
-            # self.mapWindow.OnPaint(None)
+        if event.LeftUp():
+        self.mapWindow.Refresh(eraseBackground=False)
Modified: grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/gui/wxpython/gui_modules/wxgui_utils.py	2008-07-02 10:13:08 UTC (rev 31961)
@@ -458,11 +458,11 @@
         @todo vector/volume
-        import nviz
-        dlg = nviz.RasterPropertiesDialog(parent=self,
-                                          map=self.GetPyData(self.layer_selected)[0]['maplayer'].name)
-        dlg.Show()
+        if not self.mapdisplay.nvizToolWin.IsShown():
+            self.mapdisplay.nvizToolWin.Show()
+        self.mapdisplay.nvizToolWin.SetPage('surface')
     def RenameLayer (self, event):
         """Rename layer"""
         self.EditLabel(self.layer_selected)
Modified: grass/trunk/gui/wxpython/nviz/Makefile
--- grass/trunk/gui/wxpython/nviz/Makefile	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/gui/wxpython/nviz/Makefile	2008-07-02 10:13:08 UTC (rev 31961)
@@ -19,8 +19,8 @@
 default: install_nviz
-$(LIB_NAME).i: nviz.i dig_types.i nviz.h
-	cat nviz.i dig_types.i > $(LIB_NAME).i
+$(LIB_NAME).i: nviz.i nviz_types.i nviz.h
+	cat nviz.i nviz_types.i > $(LIB_NAME).i
 	echo "/* auto-generated swig typedef file */" >> $(LIB_NAME).i
 	cat nviz.h >> $(LIB_NAME).i
Deleted: grass/trunk/gui/wxpython/nviz/dig_types.i
--- grass/trunk/gui/wxpython/nviz/dig_types.i	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/gui/wxpython/nviz/dig_types.i	2008-07-02 10:13:08 UTC (rev 31961)
@@ -1,43 +0,0 @@
-/* extracted from include/vect/dig_defines.h */
-#define GV_POINT      0x01
-#define GV_LINE       0x02
-#define GV_BOUNDARY   0x04
-#define GV_CENTROID   0x08
-#define GV_FACE       0x10
-#define GV_KERNEL     0x20
-#define GV_AREA       0x40
-#define GV_VOLUME     0x80
-#define GV_POINTS (GV_POINT | GV_CENTROID )
-#define GV_LINES (GV_LINE | GV_BOUNDARY )
-#define PORT_DOUBLE_MAX 1.7976931348623157e+308
-/* extracted from gui/wxpython/nviz/nviz.h */
-#define VIEW_DEFAULT_POS_X 0.85
-#define VIEW_DEFAULT_POS_Y 0.85
-#define VIEW_DEFAULT_PERSP 40.0
-#define VIEW_DEFAULT_TWIST 0.0
-#define VIEW_DEFAULT_ZEXAG 1.0
-#define DRAW_COARSE 0
-#define DRAW_FINE 1
-#define DRAW_BOTH 2
-/* extracted from include/gsurf.h */
-#define DM_GOURAUD   0x00000100
-#define DM_FLAT      0x00000200
-#define DM_FRINGE    0x00000010
-#define DM_WIRE      0x00000001
-#define DM_COL_WIRE  0x00000002
-#define DM_POLY      0x00000004
-#define DM_WIRE_POLY 0x00000008
-#define DM_GRID_WIRE 0x00000400
-#define DM_GRID_SURF 0x00000800
-#define WC_COLOR_ATT 0xFF000000
Modified: grass/trunk/gui/wxpython/nviz/draw.cpp
--- grass/trunk/gui/wxpython/nviz/draw.cpp	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/gui/wxpython/nviz/draw.cpp	2008-07-02 10:13:08 UTC (rev 31961)
@@ -29,23 +29,15 @@
     Nviz_draw_cplane(data, -1, -1); // ?
-    if (data->draw_mode == DRAW_COARSE ||
-	data->draw_mode == DRAW_BOTH || quick) {
+    if (quick) {
 	Nviz_draw_quick(data, 1); // clear screen
-    if (data->draw_mode == DRAW_FINE ||
-	data->draw_mode == DRAW_BOTH) {
-	if (data->draw_mode == DRAW_FINE) {
-	    Nviz_draw_all (data, 1); // clear screen
-	else {
-	    Nviz_draw_all (data, 0);
+    else {
+      Nviz_draw_all (data, 1); // clear screen
-    G_debug(1, "Nviz::Draw(): mode=%d, quick=%d",
-	    data->draw_mode, quick);
+    G_debug(1, "Nviz::Draw(): quick=%d",
+	    quick);
     return;
@@ -61,22 +53,3 @@
     return;
-  \brief Set draw mode
-  Draw modes:
-   - DRAW_COARSE
-   - DRAW_FINE
-   - DRAW_BOTH
-  \param mode draw mode
-void Nviz::SetDrawMode(int mode)
-    Nviz_set_draw_mode(data, mode);
-    G_debug(1, "Nviz::SetDrawMode(): mode=%d",
-	    mode);
-    return;
Modified: grass/trunk/gui/wxpython/nviz/nviz.h
--- grass/trunk/gui/wxpython/nviz/nviz.h	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/gui/wxpython/nviz/nviz.h	2008-07-02 10:13:08 UTC (rev 31961)
@@ -67,7 +67,6 @@
     /* draw.cpp */
     void Draw(bool);
     void EraseMap();
-    void SetDrawMode(int);
     /* surface.cpp */
     int SetSurfaceTopo(int, bool, const char *);
Copied: grass/trunk/gui/wxpython/nviz/nviz_types.i (from rev 31946, grass/trunk/gui/wxpython/nviz/dig_types.i)
--- grass/trunk/gui/wxpython/nviz/nviz_types.i	                        (rev 0)
+++ grass/trunk/gui/wxpython/nviz/nviz_types.i	2008-07-02 10:13:08 UTC (rev 31961)
@@ -0,0 +1,39 @@
+/* extracted from include/vect/dig_defines.h */
+#define GV_POINT      0x01
+#define GV_LINE       0x02
+#define GV_BOUNDARY   0x04
+#define GV_CENTROID   0x08
+#define GV_FACE       0x10
+#define GV_KERNEL     0x20
+#define GV_AREA       0x40
+#define GV_VOLUME     0x80
+#define GV_POINTS (GV_POINT | GV_CENTROID )
+#define GV_LINES (GV_LINE | GV_BOUNDARY )
+#define PORT_DOUBLE_MAX 1.7976931348623157e+308
+/* extracted from gui/wxpython/nviz/nviz.h */
+#define VIEW_DEFAULT_POS_X 0.85
+#define VIEW_DEFAULT_POS_Y 0.85
+#define VIEW_DEFAULT_PERSP 40.0
+#define VIEW_DEFAULT_TWIST 0.0
+#define VIEW_DEFAULT_ZEXAG 1.0
+/* extracted from include/gsurf.h */
+#define DM_GOURAUD   0x00000100
+#define DM_FLAT      0x00000200
+#define DM_FRINGE    0x00000010
+#define DM_WIRE      0x00000001
+#define DM_COL_WIRE  0x00000002
+#define DM_POLY      0x00000004
+#define DM_WIRE_POLY 0x00000008
+#define DM_GRID_WIRE 0x00000400
+#define DM_GRID_SURF 0x00000800
+#define WC_COLOR_ATT 0xFF000000
Modified: grass/trunk/gui/wxpython/nviz/surface.cpp
--- grass/trunk/gui/wxpython/nviz/surface.cpp	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/gui/wxpython/nviz/surface.cpp	2008-07-02 10:13:08 UTC (rev 31961)
@@ -127,6 +127,10 @@
     int ret;
+    if (!GS_surf_exists(id)) {
+	return 0;
     if (map) {
 	ret = Nviz_set_attr(id, MAP_OBJ_SURF, attr, MAP_ATT,
 			    value, -1.0,
@@ -204,6 +208,10 @@
 int Nviz::UnsetSurfaceAttr(int id, int attr)
+	return 0;
     return Nviz_unset_attr(id, MAP_OBJ_SURF, attr);
@@ -214,12 +222,20 @@
   \param fine x/y fine resolution
   \param coarse x/y coarse resolution
-  \return -1 on error
-  \return 0 on success
+  \return 0 on error
+  \return 1 on success
 int Nviz::SetSurfaceRes(int id, int fine, int coarse)
-    return GS_set_drawres(id, fine, fine, coarse, coarse);
+	return 0;
+    if (GS_set_drawres(id, fine, fine, coarse, coarse) < 0) {
+	return 0;
+    return 1;
@@ -239,16 +255,27 @@
   \param id surface id (<= 0 for all)
   \param style draw style
 int Nviz::SetSurfaceStyle(int id, int style)
     if (id > 0) {
-	return GS_set_drawmode(id, style);
+	    return 0;
+	if (GS_set_drawmode(id, style) < 0) {
+	    return 0;
+	return 1;
-    return GS_setall_drawmode(style);
+    if (GS_setall_drawmode(style) < 0) {
+	return 0;
+    return 1;
@@ -259,10 +286,15 @@
   \param surface id
   \param color color string (R:G:B)
-  \return 1
+  \return 0 on failure
 int Nviz::SetWireColor(int id, const char* color)
+	return 0;
     GS_set_wire_color(id, Nviz_color_from_str(color));
     return 1;
Modified: grass/trunk/include/nviz.h
--- grass/trunk/include/nviz.h	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/include/nviz.h	2008-07-02 10:13:08 UTC (rev 31961)
@@ -82,8 +82,6 @@
     /* background color */
     int bgcolor;
-    /* draw */
-    int draw_mode;
 } nv_data;
 /* The following structure is used to associate client data with surfaces.
@@ -138,7 +136,6 @@
 int Nviz_draw_all(nv_data *, int);
 int Nviz_draw_quick(nv_data *, int);
 int Nviz_draw_all_vect(nv_data *);
-void Nviz_set_draw_mode(nv_data *, int);
 /* exag.c */
 int Nviz_get_exag_height(float *, float *, float *);
Modified: grass/trunk/lib/grasslib.dox
--- grass/trunk/lib/grasslib.dox	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/lib/grasslib.dox	2008-07-02 10:13:08 UTC (rev 31961)
@@ -95,6 +95,7 @@
 <li>symbol:	Drawing symbols for %point %vector data library - \ref symbol
 <li>vask:	Cursor management library - \ref vask
 <li>%vector:	\ref Vector_Library (GRASS Vector and Direct Graph Library)
+<li>nviz:       Nviz library (used by wxGUI Nviz extension and CLI-based Nviz module)
 </ul>
 <!--<li>image3:	extra imagery library (mainly still unused) - \ref image3lib-->
 <!--<li>D:		display library - \ref d_displaylib-->
Modified: grass/trunk/lib/nviz/Makefile
--- grass/trunk/lib/nviz/Makefile	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/lib/nviz/Makefile	2008-07-02 10:13:08 UTC (rev 31961)
@@ -11,5 +11,9 @@
 EXTRA_LIBS = $(GISLIB) $(XLIBPATH) $(XMLIB) $(XTLIB) $(XLIB) $(XEXTRALIBS) $(OGSFLIB)
 include $(MODULE_TOPDIR)/include/Make/Lib.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+# doxygen
+DOXNAME=nviz
 default: lib
Modified: grass/trunk/lib/nviz/draw.c
--- grass/trunk/lib/nviz/draw.c	2008-07-02 10:04:26 UTC (rev 31960)
+++ grass/trunk/lib/nviz/draw.c	2008-07-02 10:13:08 UTC (rev 31961)
@@ -189,36 +189,38 @@
     if (draw_vect)
 	Nviz_draw_all_vect (data);
     if (draw_site)
-	; // site_draw_all_together(data, interp);
+	site_draw_all_together(data, interp);
     if (draw_vol)
-	; // vol_draw_all_cmd(data, interp, argc, argv);
+	vol_draw_all_cmd(data, interp, argc, argv);
     GS_done_draw();
     GS_set_draw(GSD_BACK);
     if (!draw_north_arrow)
-	; // draw_north_arrow = EMPTYSTRING;
+	draw_north_arrow = EMPTYSTRING;
     if (!arrow_x)
-	; // arrow_x = EMPTYSTRING;
+	arrow_x = EMPTYSTRING;
     if (!draw_scalebar)
-	; // draw_scalebar = EMPTYSTRING;
+	draw_scalebar = EMPTYSTRING;
     if (!draw_bar_x)
-	; // bar_x = EMPTYSTRING;
+	bar_x = EMPTYSTRING;
     if (!draw_fringe)
-	; // draw_fringe = EMPTYSTRING;
+	draw_fringe = EMPTYSTRING;
     if (!draw_label)
-	; // draw_label = EMPTYSTRING;
+	draw_label = EMPTYSTRING;
     if (!draw_legend)
-	; // draw_legend = EMPTYSTRING;
+	draw_legend = EMPTYSTRING;
     /* Draw decorations */
     /* North Arrow
@@ -308,9 +310,6 @@
 int Nviz_draw_quick(nv_data *dc, int clear)
-    int i, max;
-    int *surf_list, *vol_list;
     if (clear)
@@ -321,19 +320,6 @@
     GS_alldraw_wire();
-    surf_list = GS_get_surf_list(&max);
-    max = GS_num_surfs();
-    for (i = 0; i < max; i++) {
-	if (!check_blank(surf_list[i])) {
-	    GS_draw_wire(surf_list[i]);
-    G_free (surf_list);
     vol_list = GVL_get_vol_list(&max);
     max = GVL_num_vols();
@@ -386,20 +372,3 @@
     return 1;
-  Draw modes:
-   - DRAW_COARSE
-   - DRAW_FINE
-   - DRAW_BOTH
-  \param data nviz data
-void Nviz_set_draw_mode(nv_data *data, int mode)
-    data->draw_mode = mode;
-    return;
