[GRASS-SVN] r31977 - in grass/branches/develbranch_6: db/base db/drivers/dbf db/drivers/odbc db/drivers/ogr db/drivers/postgres db/drivers/sqlite general/g.parser general/manage/cmd include lib/cairodriver lib/db/dbmi_base lib/db/dbmi_client lib/db/dbmi_driver lib/form lib/gis lib/init lib/sites raster/r.colors raster/r.cross raster/r.neighbors raster/r.out.gdal raster/r.transect raster/r.univar2 raster/simwe/r.sim.sediment raster/wildfire/r.ros vector/lidar/v.surf.bspline vector/v.digit vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where vector/v.out.svg
Thu Jul 3 04:18:43 EDT 2008
Author: neteler
Date: 2008-07-03 04:18:42 -0400 (Thu, 03 Jul 2008)
New Revision: 31977
   grass/branches/develbranch_6/db/base/columns.c
   grass/branches/develbranch_6/db/base/copy.c
   grass/branches/develbranch_6/db/base/describe.c
   grass/branches/develbranch_6/db/base/execute.c
   grass/branches/develbranch_6/db/base/select.c
   grass/branches/develbranch_6/db/base/tables.c
   grass/branches/develbranch_6/db/drivers/dbf/db.c
   grass/branches/develbranch_6/db/drivers/odbc/db.c
   grass/branches/develbranch_6/db/drivers/ogr/db.c
   grass/branches/develbranch_6/db/drivers/postgres/create_table.c
   grass/branches/develbranch_6/db/drivers/postgres/cursor.c
   grass/branches/develbranch_6/db/drivers/postgres/db.c
   grass/branches/develbranch_6/db/drivers/postgres/error.c
   grass/branches/develbranch_6/db/drivers/postgres/parse.c
   grass/branches/develbranch_6/db/drivers/postgres/proto.h
   grass/branches/develbranch_6/db/drivers/sqlite/create_table.c
   grass/branches/develbranch_6/db/drivers/sqlite/db.c
   grass/branches/develbranch_6/general/g.parser/main.c
   grass/branches/develbranch_6/general/manage/cmd/copy.c
   grass/branches/develbranch_6/general/manage/cmd/list.c
   grass/branches/develbranch_6/general/manage/cmd/remove.c
   grass/branches/develbranch_6/general/manage/cmd/rename.c
   grass/branches/develbranch_6/include/proto_dbmi.h
   grass/branches/develbranch_6/lib/cairodriver/read_bmp.c
   grass/branches/develbranch_6/lib/cairodriver/write_bmp.c
   grass/branches/develbranch_6/lib/db/dbmi_base/alloc.c
   grass/branches/develbranch_6/lib/db/dbmi_base/case.c
   grass/branches/develbranch_6/lib/db/dbmi_base/column.c
   grass/branches/develbranch_6/lib/db/dbmi_base/columnfmt.c
   grass/branches/develbranch_6/lib/db/dbmi_base/datetime.c
   grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c
   grass/branches/develbranch_6/lib/db/dbmi_base/default_name.c
   grass/branches/develbranch_6/lib/db/dbmi_base/dirent.c
   grass/branches/develbranch_6/lib/db/dbmi_base/error.c
   grass/branches/develbranch_6/lib/db/dbmi_base/handle.c
   grass/branches/develbranch_6/lib/db/dbmi_base/index.c
   grass/branches/develbranch_6/lib/db/dbmi_base/isdir.c
   grass/branches/develbranch_6/lib/db/dbmi_base/legal_dbname.c
   grass/branches/develbranch_6/lib/db/dbmi_base/login.c
   grass/branches/develbranch_6/lib/db/dbmi_base/sqltype.c
   grass/branches/develbranch_6/lib/db/dbmi_base/string.c
   grass/branches/develbranch_6/lib/db/dbmi_base/table.c
   grass/branches/develbranch_6/lib/db/dbmi_base/value.c
   grass/branches/develbranch_6/lib/db/dbmi_base/valuefmt.c
   grass/branches/develbranch_6/lib/db/dbmi_base/xdrstring.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_create_idx.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_list_drivers.c
   grass/branches/develbranch_6/lib/db/dbmi_client/c_priv.c
   grass/branches/develbranch_6/lib/db/dbmi_client/column.c
   grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
   grass/branches/develbranch_6/lib/db/dbmi_client/db.c
   grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c
   grass/branches/develbranch_6/lib/db/dbmi_client/select.c
   grass/branches/develbranch_6/lib/db/dbmi_client/start.c
   grass/branches/develbranch_6/lib/db/dbmi_client/table.c
   grass/branches/develbranch_6/lib/db/dbmi_driver/d_mkdir.c
   grass/branches/develbranch_6/lib/db/dbmi_driver/driver_state.c
   grass/branches/develbranch_6/lib/form/generate.c
   grass/branches/develbranch_6/lib/gis/parser.c
   grass/branches/develbranch_6/lib/init/local_proto.h
   grass/branches/develbranch_6/lib/init/mke_loc.c
   grass/branches/develbranch_6/lib/init/mke_mapset.c
   grass/branches/develbranch_6/lib/init/other.c
   grass/branches/develbranch_6/lib/init/set_data.c
   grass/branches/develbranch_6/lib/sites/sites.c
   grass/branches/develbranch_6/raster/r.colors/main.c
   grass/branches/develbranch_6/raster/r.cross/main.c
   grass/branches/develbranch_6/raster/r.neighbors/main.c
   grass/branches/develbranch_6/raster/r.out.gdal/main.c
   grass/branches/develbranch_6/raster/r.transect/local_proto.h
   grass/branches/develbranch_6/raster/r.transect/parse_line.c
   grass/branches/develbranch_6/raster/r.univar2/r.univar_main.c
   grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c
   grass/branches/develbranch_6/raster/wildfire/r.ros/main.c
   grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c
   grass/branches/develbranch_6/vector/v.digit/generate.c
   grass/branches/develbranch_6/vector/v.lrs/v.lrs.create/main.c
   grass/branches/develbranch_6/vector/v.lrs/v.lrs.label/main.c
   grass/branches/develbranch_6/vector/v.lrs/v.lrs.segment/main.c
   grass/branches/develbranch_6/vector/v.lrs/v.lrs.where/main.c
   grass/branches/develbranch_6/vector/v.out.svg/main.c
glynn: Add const where appropriate to DBMI functions; Miscellaneous clean-up (merge from trunk)
Modified: grass/branches/develbranch_6/db/base/columns.c
--- grass/branches/develbranch_6/db/base/columns.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/base/columns.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -69,7 +69,7 @@
     struct Option *driver, *database, *table;
     struct GModule *module;
-    char *drv, *db;
+    const char *drv, *db;
     /* Initialize the GIS calls */
         G_gisinit(argv[0]) ;
Modified: grass/branches/develbranch_6/db/base/copy.c
--- grass/branches/develbranch_6/db/base/copy.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/base/copy.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -27,7 +27,7 @@
     struct Option *to_driver, *to_database, *to_table;
     struct Option *where, *select;
-    char   *drv, *db;
     /* Set description */
     module              = G_define_module();
Modified: grass/branches/develbranch_6/db/base/describe.c
--- grass/branches/develbranch_6/db/base/describe.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/base/describe.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -95,7 +95,7 @@
     struct Flag *cols, *tdesc;
-    char *drv, *db;
Modified: grass/branches/develbranch_6/db/base/execute.c
--- grass/branches/develbranch_6/db/base/execute.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/base/execute.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -98,7 +98,7 @@
     struct Option *driver, *database, *input;
     struct Flag *i;
-    char *drv, *db;
Modified: grass/branches/develbranch_6/db/base/select.c
--- grass/branches/develbranch_6/db/base/select.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/base/select.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -174,7 +174,7 @@
     struct Option *driver, *database, *table, *sql, *fs, *vs, *nv, *input;
     struct Flag *c,*d,*v, *flag_test;
-    char *drv, *db;
Modified: grass/branches/develbranch_6/db/base/tables.c
--- grass/branches/develbranch_6/db/base/tables.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/base/tables.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -68,7 +68,7 @@
     struct Option *driver, *database;
     struct Flag *p, *s;
-    char *drv, *db;
Modified: grass/branches/develbranch_6/db/drivers/dbf/db.c
--- grass/branches/develbranch_6/db/drivers/dbf/db.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/dbf/db.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -27,7 +27,7 @@
 int db__driver_open_database(dbHandle * handle)
-    char *name;
+    const char *name;
     int len;
     dbConnection connection;
     char buf[1024];
Modified: grass/branches/develbranch_6/db/drivers/odbc/db.c
--- grass/branches/develbranch_6/db/drivers/odbc/db.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/odbc/db.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -9,7 +9,8 @@
 int
 db__driver_open_database (dbHandle *handle)
-    char        *name, msg[OD_MSG];
+    char        msg[OD_MSG];
+    const char  *name;
     char        *emsg = NULL;
     SQLRETURN   ret;
     SQLINTEGER  err;
Modified: grass/branches/develbranch_6/db/drivers/ogr/db.c
--- grass/branches/develbranch_6/db/drivers/ogr/db.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/ogr/db.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -23,7 +23,7 @@
 int db__driver_open_database( dbHandle *handle )
-    char *name;
+    const char *name;
     init_error();
Modified: grass/branches/develbranch_6/db/drivers/postgres/create_table.c
--- grass/branches/develbranch_6/db/drivers/postgres/create_table.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/postgres/create_table.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -7,7 +7,7 @@
     int col, ncols;
     dbColumn   *column;
-    char *colname;
+    const char *colname;
     int sqltype;
     char buf[500];
     PGresult *res;
Modified: grass/branches/develbranch_6/db/drivers/postgres/cursor.c
--- grass/branches/develbranch_6/db/drivers/postgres/cursor.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/postgres/cursor.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -24,7 +24,7 @@
-cursor * alloc_cursor()
+cursor * alloc_cursor(void)
     cursor     *c;
Modified: grass/branches/develbranch_6/db/drivers/postgres/db.c
--- grass/branches/develbranch_6/db/drivers/postgres/db.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/postgres/db.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -8,7 +8,8 @@
 int db__driver_open_database (dbHandle *handle)
-    char *name, *schema, *user, *password, buf[500];
+    char buf[500];
+    const char *name, *schema, *user, *password;
     PGCONN pgconn;
     PGresult *res;
@@ -37,9 +38,6 @@
     pg_conn = PQsetdbLogin( pgconn.host, pgconn.port, pgconn.options, pgconn.tty,
 		            pgconn.dbname, user, password );
-    G_free ( user );
-    G_free ( password );
     if (PQstatus(pg_conn) == CONNECTION_BAD) {
 	append_error ( "Cannot connect to Postgres: " );
Modified: grass/branches/develbranch_6/db/drivers/postgres/error.c
--- grass/branches/develbranch_6/db/drivers/postgres/error.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/postgres/error.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -17,7 +17,7 @@
 /* append error message */
 void
-append_error ( char *msg )
+append_error ( const char *msg )
     db_append_string ( errMsg, msg);
Modified: grass/branches/develbranch_6/db/drivers/postgres/parse.c
--- grass/branches/develbranch_6/db/drivers/postgres/parse.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/postgres/parse.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -14,7 +14,7 @@
 *  returns:  DB_OK     - OK
 *            DB_FAILED - error
-int parse_conn ( char *str, PGCONN *pgconn )
+int parse_conn ( const char *str, PGCONN *pgconn )
     int  i;
     char **tokens, delm[2];
Modified: grass/branches/develbranch_6/db/drivers/postgres/proto.h
--- grass/branches/develbranch_6/db/drivers/postgres/proto.h	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/postgres/proto.h	2008-07-03 08:18:42 UTC (rev 31977)
@@ -1,10 +1,10 @@
 /* error.c */
 void init_error ( void );
-void append_error ( char * );
+void append_error ( const char * );
 void report_error ( void );
 /* cursor.c */
-cursor * alloc_cursor ();
+cursor * alloc_cursor (void);
 void free_cursor ( cursor * );
 /* describe.c*/
@@ -13,4 +13,4 @@
 int get_gpg_type ( int );
 /* parse.c */
-int parse_conn ( char *, PGCONN *);
+int parse_conn ( const char *, PGCONN *);
Modified: grass/branches/develbranch_6/db/drivers/sqlite/create_table.c
--- grass/branches/develbranch_6/db/drivers/sqlite/create_table.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/sqlite/create_table.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -30,7 +30,7 @@
     int col, ncols;
     dbColumn   *column;
-    char *colname;
     int sqltype;
     sqlite3_stmt *statement;
     dbString sql;
Modified: grass/branches/develbranch_6/db/drivers/sqlite/db.c
--- grass/branches/develbranch_6/db/drivers/sqlite/db.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/db/drivers/sqlite/db.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -31,7 +31,8 @@
-    char *name, name2[2000];
+    char name2[2000];
+    const char *name;
     G_debug(3, "\ndb_driver_open_database()" );
Modified: grass/branches/develbranch_6/general/g.parser/main.c
--- grass/branches/develbranch_6/general/g.parser/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/general/g.parser/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -392,12 +392,13 @@
     for (option = ctx.first_option; option; option = option->next_opt)
-	char buff[1024];
+	char buff[1024], upper[1024];
 	sprintf(buff, "GIS_OPT_%s=%s", option->key, option->answer ? option->answer : "");
 	putenv(G_store(buff));
-        G_str_to_upper(option->key);
-	sprintf(buff, "GIS_OPT_%s=%s", option->key, option->answer ? option->answer : "");
+	G_strcpy(upper, option->key);
+        G_str_to_upper(upper);
+	sprintf(buff, "GIS_OPT_%s=%s", upper, option->answer ? option->answer : "");
         G_debug ( 2, "set %s", buff );
Modified: grass/branches/develbranch_6/general/manage/cmd/copy.c
--- grass/branches/develbranch_6/general/manage/cmd/copy.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/general/manage/cmd/copy.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -45,16 +45,17 @@
     for (n = 0; n < nlist; n++)
+	char *str;
         p = parm[n] = G_define_option();
         p->key = list[n].alias;
         p->key_desc="from,to";
         p->type = TYPE_STRING;
         p->required = NO;
         p->multiple = NO;
-        p->gisprompt = G_malloc (64);
-        sprintf (p->gisprompt, "old,%s,%s", list[n].mainelem, list[n].maindesc);
-        p->description = G_malloc (64);
-        sprintf (p->description, _("%s file(s) to be copied"), list[n].alias);
+        G_asprintf (&str, "old,%s,%s", list[n].mainelem, list[n].maindesc);
+        p->gisprompt = str;
+        G_asprintf (&str, _("%s file(s) to be copied"), list[n].alias);
+        p->description = str;
     if (G_parser(argc, argv))
Modified: grass/branches/develbranch_6/general/manage/cmd/list.c
--- grass/branches/develbranch_6/general/manage/cmd/list.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/general/manage/cmd/list.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -33,6 +33,7 @@
 	struct Option *mapset;
 	struct Flag *full;
+	char *str;
 	init (argv[0]);
@@ -51,18 +52,19 @@
 	element->description = "Data type";
 	for (len=0,n=0 ; n < nlist; n++)
 	    len += strlen (list[n].alias)+1;
-	element->options = G_malloc(len);
+	str = G_malloc(len);
 	for (n=0; n < nlist; n++)
 	    if (n)
-		G_strcat (element->options, ",");
-		G_strcat (element->options, list[n].alias);
+		G_strcat (str, ",");
+		G_strcat (str, list[n].alias);
 	    else
-		G_strcpy (element->options, list[n].alias);
+		G_strcpy (str, list[n].alias);
+	element->options = str;
 	mapset = G_define_option();
 	mapset->key = "mapset";
Modified: grass/branches/develbranch_6/general/manage/cmd/remove.c
--- grass/branches/develbranch_6/general/manage/cmd/remove.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/general/manage/cmd/remove.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -120,15 +120,16 @@
+	char *str;
 	p->required = NO;
 	p->multiple = YES;
-	sprintf (p->description, _("%s file(s) to be removed"), list[n].alias);
+	G_asprintf (&str, _("%s file(s) to be removed"), list[n].alias);
Modified: grass/branches/develbranch_6/general/manage/cmd/rename.c
--- grass/branches/develbranch_6/general/manage/cmd/rename.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/general/manage/cmd/rename.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -45,16 +45,17 @@
+	char *str;
 	p->key_desc="old,new";
 	p->required = NO;
 	p->multiple = NO;
-	sprintf (p->description, _("%s file(s) to be renamed"), list[n].alias);
+	G_asprintf (&str, _("%s file(s) to be renamed"), list[n].alias);
Modified: grass/branches/develbranch_6/include/proto_dbmi.h
--- grass/branches/develbranch_6/include/proto_dbmi.h	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/include/proto_dbmi.h	2008-07-03 08:18:42 UTC (rev 31977)
@@ -13,7 +13,7 @@
 int         db_alloc_index_columns    (dbIndex *index , int ncols );
 dbString *  db_alloc_string_array     (int count );
 dbTable *   db_alloc_table            (int ncols );
-int         db_append_string          (dbString *x , char *s );
+int         db_append_string          (dbString *x , const char *s );
 void        db_auto_print_errors      (int flag );
 void        db_auto_print_protocol_errors (int flag );
 int         db_bind_update            (dbCursor *cursor );
@@ -34,12 +34,12 @@
 int         db_close_cursor           (dbCursor *cursor );
 int         db_close_database         (dbDriver *driver );
 int         db_close_database_shutdown_driver (dbDriver *driver );
-int         db_column_sqltype         (dbDriver *driver, char *tab, char *col );
-int         db_column_Ctype         (dbDriver *driver, char *tab, char *col );
-int         db_convert_Cstring_to_column_default_value (char *Cstring , dbColumn *column );
-int         db_convert_Cstring_to_column_value (char *Cstring , dbColumn *column );
-int         db_convert_Cstring_to_value (char *Cstring , int sqltype , dbValue *value );
-int         db_convert_Cstring_to_value_datetime (char *buf , int sqltype , dbValue *value );
+int         db_column_sqltype         (dbDriver *driver, const char *tab, const char *col );
+int         db_column_Ctype         (dbDriver *driver, const char *tab, const char *col );
+int         db_convert_Cstring_to_column_default_value (const char *Cstring , dbColumn *column );
+int         db_convert_Cstring_to_column_value (const char *Cstring , dbColumn *column );
+int         db_convert_Cstring_to_value (const char *Cstring , int sqltype , dbValue *value );
+int         db_convert_Cstring_to_value_datetime (const char *buf , int sqltype , dbValue *value );
 int         db_convert_column_default_value_to_string (dbColumn *column , dbString *string );
 int         db_convert_column_value_to_string (dbColumn *column , dbString *string );
 int         db_convert_value_datetime_into_string (dbValue *value , int sqltype , dbString *string );
@@ -47,18 +47,18 @@
 void        db_copy_dbmscap_entry     (dbDbmscap *dst , dbDbmscap *src );
 int         db_copy_string            (dbString *dst , dbString *src );
 int         db_table_to_sql ( dbTable *, dbString *);
-int         db_copy_table ( char *, char *, char *, char *, char *, char *);
-int         db_copy_table_where ( char *, char *, char *, char *, char *, char *, char *);
-int         db_copy_table_select ( char *, char *, char *, char *, char *, char *, char *);
-int         db_copy_table_by_ints ( char *, char *, char *, char *, char *, char *, char *, int *, int);
+int         db_copy_table ( const char *, const char *, const char *, const char *, const char *, const char *);
+int         db_copy_table_where ( const char *, const char *, const char *, const char *, const char *, const char *, const char *);
+int         db_copy_table_select ( const char *, const char *, const char *, const char *, const char *, const char *, const char *);
+int         db_copy_table_by_ints ( const char *, const char *, const char *, const char *, const char *, const char *, const char *, int *, int);
 void        db_copy_value             (dbValue *dst , dbValue *src );
 int         db_create_database        (dbDriver *driver , dbHandle *handle );
 int         db_create_index           (dbDriver *driver , dbIndex *index );
-int         db_create_index2          (dbDriver *driver, char *table_name, char *column_name );
+int         db_create_index2          (dbDriver *driver, const char *table_name, const char *column_name );
 int         db_create_table           (dbDriver *driver , dbTable *table );
 int         db_d_add_column           (void );
 int         db_d_bind_update          (void );
-char *      db_dbmscap_filename       (void );
+const char *db_dbmscap_filename       (void );
 int         db_d_close_cursor         (void );
 int         db_d_close_database       (void );
 int         db_d_create_database      (void );
@@ -70,12 +70,12 @@
 int         db_d_drop_column          (void );
 int         db_d_drop_index           (void );
 int         db_d_drop_table           (void );
-void        db_debug                  (char *s );
+void        db_debug                  (const char *s );
 void        db_debug_off              (void );
 void        db_debug_on               (void );
 int         db_delete                 (dbCursor *cursor );
 int         db_delete_database        (dbDriver *driver , dbHandle *handle );
-int         db_delete_table           ( char *, char *, char *);
+int         db_delete_table           (const char *, const char *, const char *);
 int         db_describe_table         (dbDriver *driver , dbString *name , dbTable **table );
 int         db_d_execute_immediate    (void );
 int         db_d_begin_transaction    (void );
@@ -85,7 +85,7 @@
 int         db_d_get_num_rows         (void );
 int         db_d_grant_on_table       (void );
 int         db_d_insert               (void );
-dbDirent *  db_dirent                 (char *dirname , int *n );
+dbDirent *  db_dirent                 (const char *dirname , int *n );
 int         db_d_list_databases       (void );
 int         db_d_list_indexes         (void );
 int         db_d_list_tables          (void );
@@ -96,7 +96,7 @@
 void        db_double_quote_string    ( dbString *src );
 int         db_driver                 (int argc , char *argv []);
-int         db_driver_mkdir           (char *path , int mode , int parentdirs );
+int         db_driver_mkdir           (const char *path , int mode , int parentdirs );
 int         db_drop_column            (dbDriver *driver , dbString *tableName , dbString *columnName );
 void        db__drop_cursor_from_driver_state (dbCursor *cursor );
 int         db_drop_index             (dbDriver *driver , dbString *name );
@@ -105,7 +105,7 @@
 int         db_d_update               (void );
 int         db_d_version              (void );
 int         db_enlarge_string         (dbString *x , int len );
-void        db_error                  (char *s );
+void        db_error                  (const char *s );
 int         db_execute_immediate      (dbDriver *driver , dbString *SQLstatement );
 int         db_begin_transaction      (dbDriver *driver);
 int         db_commit_transaction     (dbDriver *driver);
@@ -124,12 +124,12 @@
 void        db_free_string            (dbString *x );
 void        db_free_string_array      (dbString *a , int n );
 void        db_free_table             (dbTable *table );
-int         db_get_column             ( dbDriver *Driver, char *tname, char *cname, dbColumn **Column );
+int         db_get_column             ( dbDriver *Driver, const char *tname, const char *cname, dbColumn **Column );
 dbValue *   db_get_column_default_value (dbColumn *column );
-char *      db_get_column_description (dbColumn *column );
+const char *db_get_column_description (dbColumn *column );
 int         db_get_column_host_type   (dbColumn *column );
 int         db_get_column_length      (dbColumn *column );
-char *      db_get_column_name        (dbColumn *column );
+const char *db_get_column_name        (dbColumn *column );
 int         db_get_column_precision   (dbColumn *column );
 int         db_get_column_scale       (dbColumn *column );
 int         db_get_column_select_priv (dbColumn *column );
@@ -140,27 +140,27 @@
 int         db_get_cursor_number_of_columns (dbCursor *cursor );
 dbTable *   db_get_cursor_table       (dbCursor *cursor );
 dbToken     db_get_cursor_token       (dbCursor *cursor );
-char *      db_get_default_driver_name ( void );
-char *      db_get_default_database_name ( void );
-char *      db_get_default_schema_name ( void );
-char *      db_get_default_group_name ( void );
+const char *db_get_default_driver_name ( void );
+const char *db_get_default_database_name ( void );
+const char *db_get_default_schema_name ( void );
+const char *db_get_default_group_name ( void );
 dbDriverState * db__get_driver_state      (void );
 int         db_get_error_code         (void );
-char *      db_get_error_msg          (void );
-char *      db_get_error_who          (void );
-char *      db_get_handle_dbname      (dbHandle *handle );
-char *      db_get_handle_dbschema    (dbHandle *handle );
-char *      db_get_index_column_name  (dbIndex *index , int column_num );
-char *      db_get_index_name         (dbIndex *index );
+const char *db_get_error_msg          (void );
+const char *db_get_error_who          (void );
+const char *db_get_handle_dbname      (dbHandle *handle );
+const char *db_get_handle_dbschema    (dbHandle *handle );
+const char *db_get_index_column_name  (dbIndex *index , int column_num );
+const char *db_get_index_name         (dbIndex *index );
 int         db_get_index_number_of_columns (dbIndex *index );
-char *      db_get_index_table_name   (dbIndex *index );
+const char *db_get_index_table_name   (dbIndex *index );
 int         db_get_num_rows           (dbCursor *cursor );
 char *      db_get_string             (dbString *x );
 dbColumn *  db_get_table_column       (dbTable *table , int n );
 int         db_get_table_delete_priv  (dbTable *table );
-char *      db_get_table_description  (dbTable *table );
+const char *db_get_table_description  (dbTable *table );
 int         db_get_table_insert_priv  (dbTable *table );
-char *      db_get_table_name         (dbTable *table );
+const char *db_get_table_name         (dbTable *table );
 int         db_get_table_number_of_columns (dbTable *table );
 int         db_get_table_number_of_rows (dbDriver *driver, dbString *sql);
 int         db_get_table_select_priv  (dbTable *table );
@@ -173,9 +173,9 @@
 int         db_get_value_minute       (dbValue *value );
 int         db_get_value_month        (dbValue *value );
 double      db_get_value_seconds      (dbValue *value );
-char *      db_get_value_string       (dbValue *value );
+const char *db_get_value_string       (dbValue *value );
 int         db_get_value_year         (dbValue *value );
-int         db_grant_on_table         (dbDriver *driver , char *tableName, int priv, int to );
+int         db_grant_on_table         (dbDriver *driver , const char *tableName, int priv, int to );
 int         db_has_dbms               (void );
 void        db_init_column            (dbColumn *column );
 void        db_init_cursor            (dbCursor *cursor );
@@ -186,18 +186,18 @@
 void        db_init_table             (dbTable *table );
 int         db_insert                 (dbCursor *cursor );
 void        db_interval_range         (int sqltype , int *from , int *to );
-int         db_isdir                  (char *path );
-int         db_legal_tablename        (char *s );
+int         db_isdir                  (const char *path );
+int         db_legal_tablename        (const char *s );
 int         db_list_databases         (dbDriver *driver , dbString *path , int npaths , dbHandle **handles , int *count );
-char *      db_list_drivers           (void );
+const char *db_list_drivers           (void );
 int         db_list_indexes           (dbDriver *driver , dbString *table_name , dbIndex **list , int *count );
 int         db_list_tables            (dbDriver *driver , dbString **names , int *count , int system );
 void *      db_malloc                 (int n );
 void        db__mark_database_closed  (void );
-void        db__mark_database_open    (char *dbname , char *dbpath );
+void        db__mark_database_open    (const char *dbname , const char *dbpath );
 void        db_memory_error           (void );
 dbToken     db_new_token              (dbAddress address );
-int         db_nocase_compare         (char *a , char *b );
+int         db_nocase_compare         (const char *a , const char *b );
 void        db_noproc_error           (int procnum );
 int         db_open_database          (dbDriver *driver , dbHandle *handle );
 int         db_open_insert_cursor     (dbDriver *driver , dbCursor *cursor );
@@ -207,7 +207,7 @@
 void        db_print_error            (void );
 void        db_print_index            (FILE *fd , dbIndex *index );
 void        db_print_table_definition (FILE *fd , dbTable *table );
-void        db_procedure_not_implemented (char *name );
+void        db_procedure_not_implemented (const char *name );
 void        db_protocol_error         (void );
 dbDbmscap * db_read_dbmscap           (void );
 void *      db_realloc                (void *s , int n );
@@ -235,7 +235,7 @@
 int         db__recv_table_definition (dbTable **table );
 int         db__recv_token            (dbToken *token );
 int         db__recv_value            (dbValue *value , int Ctype );
-int         db__send_Cstring          (char *s );
+int         db__send_Cstring          (const char *s );
 int         db__send_char             (int d );
 int         db__send_column_default_value (dbColumn *column );
 int         db__send_column_definition (dbColumn *column );
@@ -262,16 +262,16 @@
 int         db__send_table_definition (dbTable *table );
 int         db__send_token            (dbToken *token );
 int         db__send_value            (dbValue *value , int Ctype );
-int         db_select_CatValArray     ( dbDriver *driver, char *tab, char *key, char *col, char *where,
+int         db_select_CatValArray     ( dbDriver *driver, const char *tab, const char *key, const char *col, const char *where,
 	                                                  dbCatValArray *Cvarr );
-int         db_select_int (dbDriver *driver, char *table, char *column, char *where, int **pval);
-int         db_select_value (dbDriver *driver, char *table, char *key, int id, char *column, dbValue *value);
-int         db_set_column_description (dbColumn *column , char *description );
+int         db_select_int (dbDriver *driver, const char *table, const char *column, const char *where, int **pval);
+int         db_select_value (dbDriver *driver, const char *table, const char *key, int id, const char *column, dbValue *value);
+int         db_set_column_description (dbColumn *column , const char *description );
 void        db_set_column_has_defined_default_value (dbColumn *column );
 void        db_set_column_has_undefined_default_value (dbColumn *column );
 void        db_set_column_host_type   (dbColumn *column , int type );
 void        db_set_column_length      (dbColumn *column , int length );
-int         db_set_column_name        (dbColumn *column , char *name );
+int         db_set_column_name        (dbColumn *column , const char *name );
 void        db_set_column_null_allowed (dbColumn *column );
 void        db_set_column_precision   (dbColumn *column , int precision );
 void        db_set_column_scale       (dbColumn *column , int scale );
@@ -293,22 +293,22 @@
 void        db_set_cursor_type_readonly (dbCursor *cursor );
 void        db_set_cursor_type_update (dbCursor *cursor );
 int         db_set_default_connection (void);
-void        db_set_error_who          (char *me );
-int         db_set_handle             (dbHandle *handle , char *dbName , char *dbPath );
-int         db_set_index_column_name  (dbIndex *index , int column_num , char *name );
-int         db_set_index_name         (dbIndex *index , char *name );
-int         db_set_index_table_name   (dbIndex *index , char *name );
+void        db_set_error_who          (const char *me );
+int         db_set_handle             (dbHandle *handle , const char *dbName , const char *dbPath );
+int         db_set_index_column_name  (dbIndex *index , int column_num , const char *name );
+int         db_set_index_name         (dbIndex *index , const char *name );
+int         db_set_index_table_name   (dbIndex *index , const char *name );
 int         db_set_index_type_non_unique (dbIndex *index );
 int         db_set_index_type_unique  (dbIndex *index );
 void        db__set_protocol_fds      (FILE *send , FILE *recv );
-int         db_set_string             (dbString *x , char *s );
+int         db_set_string             (dbString *x , const char *s );
 int         db_set_string_no_copy     (dbString *x , char *s );
 void        db_set_table_delete_priv_granted (dbTable *table );
 void        db_set_table_delete_priv_not_granted (dbTable *table );
-int         db_set_table_description  (dbTable *table , char *description );
+int         db_set_table_description  (dbTable *table , const char *description );
 void        db_set_table_insert_priv_granted (dbTable *table );
 void        db_set_table_insert_priv_not_granted (dbTable *table );
-int         db_set_table_name         (dbTable *table , char *name );
+int         db_set_table_name         (dbTable *table , const char *name );
 void        db_set_table_select_priv_granted (dbTable *table );
 void        db_set_table_select_priv_not_granted (dbTable *table );
 void        db_set_table_update_priv_granted (dbTable *table );
@@ -324,18 +324,18 @@
 void        db_set_value_not_null     (dbValue *value );
 void        db_set_value_null         (dbValue *value );
 void        db_set_value_seconds      (dbValue *value , double seconds );
-int         db_set_value_string       (dbValue *value , char *s );
+int         db_set_value_string       (dbValue *value , const char *s );
 void        db_set_value_year         (dbValue *value , int year );
 int         db_shutdown_driver        (dbDriver *driver );
-char *      db_sqltype_name           (int sqltype );
+const char *db_sqltype_name           (int sqltype );
 int         db_sqltype_to_Ctype       (int sqltype );
-dbDriver *  db_start_driver           (char *name );
-dbDriver *  db_start_driver_open_database  (char *drvname, char *dbname );
+dbDriver *  db_start_driver           (const char *name );
+dbDriver *  db_start_driver_open_database  (const char *drvname, const char *dbname );
 int         db__start_procedure_call  (int procnum );
-char *      db_store                  (char *s );
+char *      db_store                  (const char *s );
 void        db_strip                  (char *buf );
-void        db_syserror               (char *s );
-int         db_table_exists (char* drvname, char *dbname, char *tabname);
+void        db_syserror               (const char *s );
+int         db_table_exists (const char * drvname, const char *dbname, const char *tabname);
 int         db_test_column_has_default_value (dbColumn *column );
 int         db_test_column_has_defined_default_value (dbColumn *column );
 int         db_test_column_has_undefined_default_value (dbColumn *column );
@@ -364,11 +364,11 @@
 void        db_unset_cursor_mode_scroll (dbCursor *cursor );
 int         db_update                 (dbCursor *cursor );
 int         db_gversion                (dbDriver *driver , dbString *client_version , dbString *driver_version );
-char *      db_whoami                 (void );
+const char *db_whoami                 (void );
 void        db_zero                   (void *s , int n );
 void         db_zero_string            (dbString *x );
 unsigned    int                       db_sizeof_string (dbString *x );
-int         db_set_login ( char *, char *, char *, char * );
-int         db_get_login ( char *, char *, char **, char ** );
+int         db_set_login ( const char *, const char *, const char *, const char * );
+int         db_get_login ( const char *, const char *, const char **, const char ** );
 #endif
Modified: grass/branches/develbranch_6/lib/cairodriver/read_bmp.c
--- grass/branches/develbranch_6/lib/cairodriver/read_bmp.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/cairodriver/read_bmp.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -66,7 +66,6 @@
 	char header[HEADER_SIZE];
 	FILE *input;
-	int x, y;
 	input = fopen(file_name, "rb");
 	if (!input)
Modified: grass/branches/develbranch_6/lib/cairodriver/write_bmp.c
--- grass/branches/develbranch_6/lib/cairodriver/write_bmp.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/cairodriver/write_bmp.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -48,7 +48,6 @@
 	FILE *output;
-	int x, y;
 	output = fopen(file_name, "wb");
 	if (!output)
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/alloc.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/alloc.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/alloc.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -9,7 +9,7 @@
  \param
 char *
-db_store (char *s)
+db_store (const char *s)
     char *a;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/case.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/case.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/case.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -59,7 +59,7 @@
  \param
 int
-db_nocase_compare (char *a, char *b)
+db_nocase_compare (const char *a, const char *b)
     char s, t;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/column.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/column.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/column.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -387,7 +387,7 @@
  \param
 int
-db_set_column_name  (dbColumn *column, char *name)
+db_set_column_name  (dbColumn *column, const char *name)
     return db_set_string (&column->columnName, name);
@@ -398,7 +398,7 @@
  \return
  \param
-char *
+const char *
 db_get_column_name  (dbColumn *column)
@@ -411,7 +411,7 @@
  \param
 int
-db_set_column_description  (dbColumn *column, char *description)
+db_set_column_description  (dbColumn *column, const char *description)
     return db_set_string (&column->description, description);
@@ -422,7 +422,7 @@
  \return
  \param
-char *
+const char *
 db_get_column_description  (dbColumn *column)
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/columnfmt.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/columnfmt.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/columnfmt.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -7,7 +7,7 @@
  \param
 int
-db_convert_Cstring_to_column_value  (char *Cstring, dbColumn *column)
+db_convert_Cstring_to_column_value  (const char *Cstring, dbColumn *column)
     dbValue *value;
@@ -25,7 +25,7 @@
  \param
 int
-db_convert_Cstring_to_column_default_value  (char *Cstring, dbColumn *column)
+db_convert_Cstring_to_column_default_value  (const char *Cstring, dbColumn *column)
     dbValue *value;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/datetime.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/datetime.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/datetime.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -184,7 +184,7 @@
  *  otherwise the to and from markings in sqltype are used.
  *  where "*" represents any non-whitespace character
-int db_convert_Cstring_to_value_datetime  (char *buf, int sqltype, dbValue *value)
+int db_convert_Cstring_to_value_datetime  (const char *buf, int sqltype, dbValue *value)
     int from, to;
     int year, month, day, hour, minute;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/dbmscap.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -44,8 +44,8 @@
  \return
  \param
-char *
-db_dbmscap_filename()
+const char *
+db_dbmscap_filename(void)
     return dbmscap_filename(1);
@@ -57,7 +57,7 @@
  \param
 int
-db_has_dbms()
+db_has_dbms(void)
     return (dbmscap_filename(0) != NULL);
@@ -91,7 +91,7 @@
  * for available dbmi drivers in $(GISBASE)/driver/db/  */
 dbDbmscap *
-db_read_dbmscap()
+db_read_dbmscap(void)
     FILE *fd;
@@ -108,29 +108,30 @@
     dbDbmscap *list = NULL;
 /* START OF OLD CODE FOR dbmscap FILE - NOT USED, BUT KEEP IT FOR FUTURE */
+#if 0
     /* get the full name of the dbmscap file */
     file = db_dbmscap_filename();
     if (file == NULL)
 	return (dbDbmscap *) NULL;
     /* open the dbmscap file */
     fd = fopen (file, "r");
     if (fd == NULL)
 	db_syserror (file);
     /* find all valid entries
      * blank lines and lines with # as first non blank char are ignored
      * format is:
      *   driver name:startup command:comment
     for (line = 1; fgets (buf, sizeof buf, fd); line++)
 	if (sscanf (buf, "%1s", comment) != 1 || *comment == '#')
@@ -148,7 +149,7 @@
 	    break;
     fclose (fd);
+#endif
 /* END OF OLD CODE FOR dbmscap FILE */
 /* START OF NEW CODE FOR SEARCH IN $(GISBASE)/driver/db/ */
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/default_name.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/default_name.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/default_name.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -4,14 +4,14 @@
 #include <grass/dbmi.h>
- \fn char * db_get_default_driver_name ( void )
+ \fn const char * db_get_default_driver_name ( void )
  \brief returns pointer to default driver name
  \return returns pointer to default driver name or NULL if not set
-char *
+const char *
-    char *drv;
+    const char *drv;
     if ( (drv = G__getenv2("DB_DRIVER", G_VAR_MAPSET))  )
        return G_store(drv);
@@ -20,14 +20,14 @@
- \fn char * db_get_default_database_name ( void )
+ \fn const char * db_get_default_database_name ( void )
  \brief returns pointer to default database name
  \return returns pointer to default database name or NULL if not set
-char *
+const char *
-    char *drv;
+    const char *drv;
     if ( (drv = G__getenv2("DB_DATABASE", G_VAR_MAPSET))  )
@@ -36,14 +36,14 @@
- \fn char * db_get_default_schema_name ( void )
+ \fn const char * db_get_default_schema_name ( void )
  \brief returns pointer to default schema name
  \return returns pointer to default schema name or NULL if not set
-char *
+const char *
-    char *sch;
+    const char *sch;
     if ( (  sch = G__getenv2("DB_SCHEMA", G_VAR_MAPSET) )  )
 	  return G_store(sch);
@@ -52,14 +52,14 @@
- \fn char * db_get_default_group_name ( void )
+ \fn const char * db_get_default_group_name ( void )
  \brief returns pointer to default group name
  \return returns pointer to default group name or NULL if not set
-char *
+const char *
-    char *gr;
+    const char *gr;
     if ( (  gr = G__getenv2("DB_GROUP", G_VAR_MAPSET) )  )
 	  return G_store(gr);
@@ -70,7 +70,7 @@
- \fn char * db_set_default_connection(void)
+ \fn int db_set_default_connection(void)
  \brief sets up database connection settings using GRASS default from dbmi.h
  \return returns DB_OK (TODO: DB_OK on success, DB_* error code on fail)
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/dirent.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/dirent.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/dirent.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -32,7 +32,7 @@
 /* read directory and build an array of dbDirent's */
 /* append one entry with name = NULL to mark end of array */
 dbDirent *
-db_dirent  (char *dirname, int *n)
+db_dirent  (const char *dirname, int *n)
     DIR  *dp;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/error.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/error.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/error.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -9,7 +9,7 @@
 static char *err_msg = 0;
 static int  auto_print_errors = 1;
 static int auto_print_protocol_errors = 1;
-static void (*user_print_function)();
+static void (*user_print_function)(const char *);
 static char *who = NULL;
@@ -20,7 +20,7 @@
  \param
 void
-db_on_error (void (*f)())
+db_on_error (void (*f)(const char *))
     user_print_function = f;
@@ -33,7 +33,7 @@
  \param
 void
-db_set_error_who (char *me)
+db_set_error_who (const char *me)
     if (who) free(who);
@@ -46,8 +46,8 @@
  \return
  \param
-char *
-db_get_error_who()
+const char *
+db_get_error_who(void)
     return who?who:"";
@@ -59,7 +59,7 @@
  \param
 void
-db_error (char *s)
+db_error (const char *s)
     if (s == NULL)
@@ -80,7 +80,7 @@
  \param
 void
-db_protocol_error()
+db_protocol_error(void)
     int flag;
@@ -98,7 +98,7 @@
  \param
 void
-db_syserror (char *s)
+db_syserror (const char *s)
     char lead[1024];
@@ -125,7 +125,7 @@
  \param
 int
-db_get_error_code()
+db_get_error_code(void)
     return err_flag ? err_code : DB_OK;
@@ -137,7 +137,7 @@
  \param
 void
-db_memory_error()
+db_memory_error(void)
     db_error ("dbmi: Out of Memory");
     err_code = DB_MEMORY_ERR;
@@ -150,7 +150,7 @@
  \param
 void
-db_procedure_not_implemented (char *name)
+db_procedure_not_implemented (const char *name)
     char msg[128];
@@ -183,7 +183,7 @@
  \param
 void
-db_clear_error()
+db_clear_error(void)
     err_flag = 0;
     err_code = DB_OK;
@@ -197,7 +197,7 @@
  \param
 void
-db_print_error()
+db_print_error(void)
     char lead[1024];
@@ -226,7 +226,7 @@
  \param
 void
-db_debug_on()
+db_debug_on(void)
     debug_on = 1;
@@ -238,7 +238,7 @@
  \param
 void
-db_debug_off()
+db_debug_off(void)
     debug_on = 0;
@@ -250,7 +250,7 @@
  \param
 void
-db_debug (char *s)
+db_debug (const char *s)
     if (debug_on)
@@ -263,10 +263,10 @@
  \return
  \param
-char *
-db_get_error_msg()
+const char *
+db_get_error_msg(void)
-    return err_flag ? err_msg : (char *)NULL;
+    return err_flag ? err_msg : (const char *)NULL;
@@ -276,7 +276,7 @@
  \param flag
 void
-db_auto_print_errors (flag)
+db_auto_print_errors (int flag)
     auto_print_errors = flag;
     auto_print_protocol_errors = flag;
@@ -289,7 +289,7 @@
  \param
 void
-db_auto_print_protocol_errors (flag)
+db_auto_print_protocol_errors (int flag)
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/handle.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/handle.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/handle.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -22,7 +22,7 @@
  \param
 int
-db_set_handle  (dbHandle *handle, char *dbName, char *dbSchema)
+db_set_handle  (dbHandle *handle, const char *dbName, const char *dbSchema)
     int stat;
@@ -40,7 +40,7 @@
  \return
  \param
-char *
+const char *
 db_get_handle_dbname (dbHandle *handle)
@@ -53,7 +53,7 @@
  \return
  \param
-char *
+const char *
 db_get_handle_dbschema (dbHandle *handle)
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/index.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/index.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/index.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -103,7 +103,7 @@
  \param
 int
-db_set_index_name  (dbIndex *index, char *name)
+db_set_index_name  (dbIndex *index, const char *name)
     return db_set_string (&index->indexName, name);
@@ -115,7 +115,7 @@
  \return
  \param
-char *
+const char *
 db_get_index_name  (dbIndex *index)
@@ -129,7 +129,7 @@
  \param
 int
-db_set_index_table_name  (dbIndex *index, char *name)
+db_set_index_table_name  (dbIndex *index, const char *name)
     return db_set_string (&index->tableName, name);
@@ -141,7 +141,7 @@
  \return
  \param
-char *
+const char *
 db_get_index_table_name  (dbIndex *index)
@@ -168,7 +168,7 @@
  \param
 int
-db_set_index_column_name  (dbIndex *index, int column_num, char *name)
+db_set_index_column_name  (dbIndex *index, int column_num, const char *name)
     if (column_num < 0 || column_num >= index->numColumns)
@@ -185,14 +185,14 @@
  \return
  \param
-char *
+const char *
 db_get_index_column_name  (dbIndex *index, int column_num)
 	db_error ("db_get_index_column_name(): invalid column number");
-	return ( (char *) NULL);
+	return ( (const char *) NULL);
     return db_get_string (&index->columnNames[column_num]);
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/isdir.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/isdir.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/isdir.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -10,7 +10,7 @@
  \param
 int
-db_isdir  (char *path)
+db_isdir  (const char *path)
     struct stat x;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/legal_dbname.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/legal_dbname.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/legal_dbname.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -14,7 +14,7 @@
  \param  name table name to be checked
-int db_legal_tablename (char *s)
+int db_legal_tablename (const char *s)
     char buf[GNAME_MAX];
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/login.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/login.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/login.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -19,7 +19,7 @@
     DATA *data;
 } LOGIN;
-static char *
+static const char *
 login_filename( void )
     static char *file;
@@ -41,7 +41,7 @@
 void
-add_login ( LOGIN *login, char *dr, char *db, char *usr, char *pwd )
+add_login ( LOGIN *login, const char *dr, const char *db, const char *usr, const char *pwd )
     if ( login->n == login->a ) {
 	login->a += 10;
@@ -64,7 +64,7 @@
 read_file ( LOGIN *login )
     int ret;
-    char *file;
+    const char *file;
     struct stat info;
     FILE *fd;
     char buf[2001], dr[500], db[500], usr[500], pwd[500];
@@ -113,7 +113,7 @@
 write_file ( LOGIN *login )
     int i;
-    char *file;
+    const char *file;
     FILE *fd;
     file = login_filename();
@@ -150,7 +150,7 @@
  \return DB_FAILED
 int
-db_set_login ( char *driver, char *database, char *user, char *password )
+db_set_login ( const char *driver, const char *database, const char *user, const char *password )
     int i, found;
     LOGIN login;
@@ -196,7 +196,7 @@
  \return DB_FAILED
 int
-db_get_login ( char *driver, char *database, char **user, char **password )
+db_get_login ( const char *driver, const char *database, const char **user, const char **password )
     int   i;
     LOGIN login;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/sqltype.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/sqltype.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/sqltype.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -6,7 +6,7 @@
  \return
  \param
-char *
+const char *
 db_sqltype_name (int sqltype)
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/string.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/string.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/string.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -30,13 +30,13 @@
  *   else 'x' is made to point to 's'
  * returns DB_OK or DB_MEMORY_ERR
-static int set_string();
+static int set_string(dbString *x, char *s, int  copy);
 int
-db_set_string  (dbString *x, char *s)
+db_set_string  (dbString *x, const char *s)
-    return set_string (x, s, 1);
+    return set_string (x, (char *) s, 1);
@@ -217,7 +217,7 @@
  \param
 int
-db_append_string  (dbString *x, char *s)
+db_append_string  (dbString *x, const char *s)
     int len;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/table.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/table.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/table.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -76,7 +76,7 @@
  \param
 int
-db_set_table_name  (dbTable *table, char *name)
+db_set_table_name  (dbTable *table, const char *name)
     return db_set_string (&table->tableName, name);
@@ -88,7 +88,7 @@
  \return
  \param
-char *
+const char *
 db_get_table_name  (dbTable *table)
@@ -102,7 +102,7 @@
  \param
 int
-db_set_table_description  (dbTable *table, char *description)
+db_set_table_description  (dbTable *table, const char *description)
     return db_set_string (&table->description, description);
@@ -114,7 +114,7 @@
  \return
  \param
-char *
+const char *
 db_get_table_description  (dbTable *table)
@@ -345,7 +345,7 @@
     int col, ncols;
     dbColumn   *column;
-    char *colname;
     int sqltype, ctype;
     char buf[500];
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/value.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/value.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/value.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -76,7 +76,7 @@
  \return
  \param
-char *
+const char *
 db_get_value_string (dbValue *value)
@@ -222,7 +222,7 @@
  \param
 int
-db_set_value_string (dbValue *value, char *s)
+db_set_value_string (dbValue *value, const char *s)
     db_set_value_not_null(value);
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/valuefmt.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/valuefmt.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/valuefmt.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -10,7 +10,7 @@
  \param
 int
-db_convert_Cstring_to_value  (char *Cstring, int sqltype, dbValue *value)
+db_convert_Cstring_to_value  (const char *Cstring, int sqltype, dbValue *value)
     int i;
@@ -50,9 +50,8 @@
     char buf[64];
-    char *bp;
+    const char *bp = buf;
-    bp = buf;
     if (db_test_value_isnull(value))
 	*buf = 0;
Modified: grass/branches/develbranch_6/lib/db/dbmi_base/xdrstring.c
--- grass/branches/develbranch_6/lib/db/dbmi_base/xdrstring.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_base/xdrstring.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -112,12 +112,12 @@
 int
-db__send_Cstring(char *s)
+db__send_Cstring(const char *s)
     dbString x;
     db_init_string (&x);
-    db_set_string_no_copy (&x, s);
+    db_set_string_no_copy (&x, (char *) s);
     return db__send_string (&x);
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_create_idx.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_create_idx.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_create_idx.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -38,12 +38,12 @@
  \param
 int
-db_create_index2 (dbDriver *driver, char *table_name, char *column_name)
+db_create_index2 (dbDriver *driver, const char *table_name, const char *column_name)
     int ret;
     dbIndex index;
     char buf[1000];
-    char *tbl;
+    const char *tbl;
     db_init_index ( &index );
     db_alloc_index_columns ( &index, 1 );
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_list_drivers.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_list_drivers.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_list_drivers.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -6,7 +6,7 @@
  \return return char
  \param void
-char *
+const char *
 db_list_drivers(void)
     dbDbmscap *list, *cur;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/c_priv.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/c_priv.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/c_priv.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -8,7 +8,7 @@
  \param to grant to : DB_GROUP | DB_PUBLIC
 int
-db_grant_on_table ( dbDriver *driver, char *tableName, int priv, int to)
+db_grant_on_table ( dbDriver *driver, const char *tableName, int priv, int to)
     int ret_code;
     dbString name;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/column.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/column.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/column.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -22,7 +22,7 @@
 #include <grass/glocale.h>
-  \fn int db_column_sqltype (dbDriver *driver, char *tab, char *col)
+  \fn int db_column_sqltype (dbDriver *driver, const char *tab, const char *col)
   \brief Get column sqltype
   See db_sqltype_name ()
@@ -32,7 +32,7 @@
   \param col column name
 int
-db_column_sqltype (dbDriver *driver, char *tab, char *col)
+db_column_sqltype (dbDriver *driver, const char *tab, const char *col)
     dbTable *table;
     dbString table_name;
@@ -59,7 +59,7 @@
-  \fn int db_column_Ctype (dbDriver *driver, char *tab, char *col)
+  \fn int db_column_Ctype (dbDriver *driver, const char *tab, const char *col)
   \brief Get column Ctype
   See db_sqltype_to_Ctype()
@@ -69,7 +69,7 @@
 int
-db_column_Ctype (dbDriver *driver, char *tab, char *col)
+db_column_Ctype (dbDriver *driver, const char *tab, const char *col)
     int type;
     if ( ( type = db_column_sqltype ( driver, tab, col ) ) >= 0 ) {
@@ -81,7 +81,7 @@
-  \fn int db_get_column ( dbDriver *Driver, char *tname, char *cname, dbColumn **Column )
+  \fn int db_get_column ( dbDriver *Driver, const char *tname, const char *cname, dbColumn **Column )
   \brief Get column structure by table and column name.
   Column is set to new dbColumn structure or NULL if column was not found
@@ -92,7 +92,7 @@
   \param Column column structure to store within
 int
-db_get_column ( dbDriver *Driver, char *tname, char *cname, dbColumn **Column )
+db_get_column ( dbDriver *Driver, const char *tname, const char *cname, dbColumn **Column )
     int   i, ncols;
     dbTable *Table;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -27,10 +27,10 @@
 /* Warning, driver opened as second must be closed as first, otherwise it hangs, not sure why */
 int
-db__copy_table ( char *from_drvname, char *from_dbname, char *from_tblname,
-                char *to_drvname, char *to_dbname, char *to_tblname,
-		char *where, char *select,
-		char *selcol, int *ivals, int nvals)
+db__copy_table ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
+                const char *to_drvname, const char *to_dbname, const char *to_tblname,
+		const char *where, const char *select,
+		const char *selcol, int *ivals, int nvals)
     int col, ncols, sqltype, ctype, more, selcol_found;
     char buf[1000];
@@ -43,7 +43,7 @@
     dbCursor cursor;
     dbColumn *column;
     dbValue *value;
-    char *colname;
     dbDriver *from_driver, *to_driver;
     int count, i;
@@ -121,7 +121,7 @@
     for (i = 0; i < count; i++) {
-        char *tblname = db_get_string(&tblnames[i]);
+        const char *tblname = db_get_string(&tblnames[i]);
         if (strcmp(to_tblname, tblname) == 0) {
 	    G_warning("Table '%s' already exists", to_dbname);
@@ -344,15 +344,15 @@
- \fn int db_copy_table (char *from_drvname, char *from_dbname, char *from_tblname,
-                char *to_drvname, char *to_dbname, char *to_tblname )
+ \fn int db_copy_table (const char *from_drvname, const char *from_dbname, const char *from_tblname,
+                const char *to_drvname, const char *to_dbname, const char *to_tblname )
  \brief Copy a table
  \return
  \param
 int
-db_copy_table ( char *from_drvname, char *from_dbname, char *from_tblname,
+db_copy_table ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
     return db__copy_table ( from_drvname, from_dbname, from_tblname,
 	                    to_drvname, to_dbname, to_tblname,
@@ -361,15 +361,15 @@
- \fn int db_copy_table_where (char *from_drvname, char *from_dbname, char *from_tblname,
-                char *to_drvname, char *to_dbname, char *to_tblname, char *where )
+ \fn int db_copy_table_where (const char *from_drvname, const char *from_dbname, const char *from_tblname,
+                const char *to_drvname, const char *to_dbname, const char *to_tblname, const char *where )
  \brief Copy a table
  \return
  \param where WHERE SQL condition (without where key word) or NULL
 int
-db_copy_table_where ( char *from_drvname, char *from_dbname, char *from_tblname,
+db_copy_table_where ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
@@ -378,15 +378,15 @@
- \fn int db_copy_table_select ( char *from_drvname, char *from_dbname, char *from_tblname,
-                char *to_drvname, char *to_dbname, char *to_tblname, char *select )
+ \fn int db_copy_table_select ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
+                const char *to_drvname, const char *to_dbname, const char *to_tblname, const char *select )
  \brief Copy a table
  \return
  \param select is full select statement or NULL
 int
-db_copy_table_select ( char *from_drvname, char *from_dbname, char *from_tblname,
+db_copy_table_select ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
@@ -395,9 +395,9 @@
- \fn int db_copy_table_by_ints ( char *from_drvname, char *from_dbname, char *from_tblname,
-                char *selcol, int *ivals, int nvals )
+ \fn int db_copy_table_by_ints ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
+                const char *selcol, int *ivals, int nvals )
  \brief Copy a table, but only records where value of column 'selcol'
         is in 'ivals'
  \return
@@ -406,9 +406,9 @@
  \param nvals number of values in ivals
 int
-db_copy_table_by_ints ( char *from_drvname, char *from_dbname, char *from_tblname,
+db_copy_table_by_ints ( const char *from_drvname, const char *from_dbname, const char *from_tblname,
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/db.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/db.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/db.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -2,13 +2,13 @@
 #include "macros.h"
- \fn dbDriver * db_start_driver_open_database ( char *drvname, char *dbname )
+ \fn dbDriver * db_start_driver_open_database ( const char *drvname, const char *dbname )
  \brief
  \return
  \param
 dbDriver *
-db_start_driver_open_database ( char *drvname, char *dbname )
+db_start_driver_open_database ( const char *drvname, const char *dbname )
     dbHandle handle;
     dbDriver *driver;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -2,13 +2,13 @@
 #include "macros.h"
- \fn int db_delete_table ( char *drvname, char *dbname, char *tblname )
+ \fn int db_delete_table ( const char *drvname, const char *dbname, const char *tblname )
  \brief
  \return
  \param
 int
-db_delete_table ( char *drvname, char *dbname, char *tblname )
+db_delete_table ( const char *drvname, const char *dbname, const char *tblname )
     dbDriver *driver;
     dbHandle handle;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/select.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/select.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/select.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -60,11 +60,11 @@
    dbCatVal * const *a = pa;
    dbCatVal * const *b = pb;
-   return strcmp( (char *) a, (char *) b );
+   return strcmp( (const char *) a, (const char *) b );
- \fn db_select_int (dbDriver *driver, char *tab, char *col, char *where, int **pval)
+ \fn db_select_int (dbDriver *driver, const char *tab, const char *col, const char *where, int **pval)
  \brief Select array of ordered integers from table/column
  \return number of selected values, -1 on error
  \param driver DB driver
@@ -74,11 +74,12 @@
  \param pval array of ordered integer values
-int db_select_int (dbDriver *driver, char *tab, char *col, char *where, int **pval)
+int db_select_int (dbDriver *driver, const char *tab, const char *col, const char *where, int **pval)
     int type, more, alloc, count;
     int *val;
-    char buf[1024], *sval;
+    char buf[1024];
+    const char *sval;
     dbString stmt;
     dbCursor cursor;
     dbColumn *column;
@@ -154,7 +155,7 @@
- \fn db_select_value (dbDriver *driver, char *tab, char *key, int id, char *col, dbValue *val)
+ \fn db_select_value (dbDriver *driver, const char *tab, const char *key, int id, const char *col, dbValue *val)
  \brief Select one (first) value from table/column for key/id
@@ -164,7 +165,7 @@
  \param col name of column to select the value from
  \param val dbValue to store within
-int db_select_value (dbDriver *driver, char *tab, char *key, int id, char *col, dbValue *val)
+int db_select_value (dbDriver *driver, const char *tab, const char *key, int id, const char *col, dbValue *val)
     int  more, count;
     char buf[1024];
@@ -202,7 +203,7 @@
- \fn int db_select_CatValArray (dbDriver *driver, char *tab, char *key, char *col, char *where, dbCatValArray *cvarr)
+ \fn int db_select_CatValArray (dbDriver *driver, const char *tab, const char *key, const char *col, const char *where, dbCatValArray *cvarr)
  \brief Select pairs key/value to array, values are sorted by key (must be integer)
@@ -211,7 +212,7 @@
  \param col value column name
  \param cvarr dbCatValArray to store within
 			    dbCatValArray *cvarr )
     int  i, type, more, nrows;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/start.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/start.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/start.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -15,24 +15,24 @@
- * \fn dbDriver *db_start_driver (char *name)
+ * \fn dbDriver *db_start_driver (const char *name)
  * \brief Initialize a new dbDriver for db transaction.
  * If <b>name</b> is NULL, the db name will be assigned
  * connection.driverName.
- * \param[in] char * driver name
+ * \param[in] const char * driver name
  * \return NULL on error
 dbDriver *
-db_start_driver (char *name)
+db_start_driver (const char *name)
     dbDriver *driver;
-    char *startup;
+    const char *startup;
     int p1[2], p2[2];
     int pid;
     int stat;
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/table.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/table.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/table.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -4,7 +4,7 @@
- \fn int db_table_exists ( char *, char *, char *)
+ \fn int db_table_exists ( const char *, const char *, const char *)
  \brief check if table exists
  \param drvname: driver name
  \param dbname: database name
@@ -13,7 +13,7 @@
  \param
 int
-db_table_exists ( char *drvname, char *dbname, char *tabname)
+db_table_exists ( const char *drvname, const char *dbname, const char *tabname)
     dbDriver *driver;
     dbString *names;
Modified: grass/branches/develbranch_6/lib/db/dbmi_driver/d_mkdir.c
--- grass/branches/develbranch_6/lib/db/dbmi_driver/d_mkdir.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_driver/d_mkdir.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -1,3 +1,4 @@
+#include <string.h>
 #include <unistd.h>
 #include <sys/stat.h>
 #include <sys/types.h>
@@ -7,7 +8,7 @@
 static char *rfind(char *string, char c);
 static int make_parent_dir(char *path, int mode);
-static int make_dir(char *path, int mode);
+static int make_dir(const char *path, int mode);
@@ -17,11 +18,13 @@
  \param
 int
-db_driver_mkdir (char *path, int mode, int parentdirs)
+db_driver_mkdir (const char *path, int mode, int parentdirs)
     if (parentdirs)
-	if (make_parent_dir (path, mode) != DB_OK)
+	char path2[GPATH_MAX];
+	strcpy(path2, path);
+	if (make_parent_dir (path2, mode) != DB_OK)
 	    return DB_FAILED;
@@ -32,7 +35,7 @@
 /* make a directory if it doesn't exist */
 /* this routine could be made more intelligent as to why it failed */
 static int
-make_dir (char *path, int mode)
+make_dir (const char *path, int mode)
     if (db_isdir(path) == DB_OK)
 	return DB_OK;
Modified: grass/branches/develbranch_6/lib/db/dbmi_driver/driver_state.c
--- grass/branches/develbranch_6/lib/db/dbmi_driver/driver_state.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/db/dbmi_driver/driver_state.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -28,10 +28,10 @@
 void
-db__mark_database_open (char *dbname, char *dbschema)
+db__mark_database_open (const char *dbname, const char *dbschema)
-    state.dbname = dbname;
-    state.dbschema = dbschema;
+    state.dbname = db_store(dbname);
+    state.dbschema = db_store(dbschema);
     state.open = 1;
Modified: grass/branches/develbranch_6/lib/form/generate.c
--- grass/branches/develbranch_6/lib/form/generate.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/form/generate.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -17,7 +17,8 @@
 	    char **form)
     int      col, ncols, ctype, sqltype, more;
-    char     buf[5000], buf1[100], *colname;
+    char     buf[5000], buf1[100];
     dbString sql, html, str;
     dbDriver *driver;
     dbHandle handle;
Modified: grass/branches/develbranch_6/lib/gis/parser.c
--- grass/branches/develbranch_6/lib/gis/parser.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/gis/parser.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -117,21 +117,21 @@
 static struct Item first_item ;
 static struct Item *current_item ;
 static int n_items = 0 ;
-static int show_options(int ,char *);
+static int show_options(int ,const char *);
 static int show(const char *,int);
 static int set_flag (int);
-static int contains (char *,int);
+static int contains (const char *,int);
 static int set_option( char *);
 static int check_opts();
-static int check_an_opt( char *, int , char *,char *);
-static int check_int(char *, char *);
-static int check_double( char *, char *);
-static int check_string( char *, char *);
-static int check_required();
-static int split_opts();
-static int check_multiple_opts();
-static int check_overwrite();
-static int interactive( char *);
+static int check_an_opt(const char *, int , const char *,const char *);
+static int check_int(const char *, const char *);
+static int check_double(const char *, const char *);
+static int check_string(const char *, const char *);
+static int check_required(void);
+static int split_opts(void);
+static int check_multiple_opts(void);
+static int check_overwrite(void);
+static int interactive(const char *);
 static int interactive_flag( struct Flag *);
 static int interactive_option( struct Option *);
 static int gis_prompt( struct Option *, char *);
@@ -762,7 +762,7 @@
 			i++;
-		    opt->opts = (char **)G_calloc( cnt+1, sizeof(char*) );
+		    opt->opts = (const char **)G_calloc( cnt+1, sizeof(const char*) );
 		    i = 0;
 		    while ( tokens[i] ) {
@@ -774,7 +774,7 @@
 		    if(opt->descriptions ) {
 		        delm[0] = ';';
-			opt->descs = (char **)G_calloc( cnt+1, sizeof(char*) );
+			opt->descs = (const char **)G_calloc( cnt+1, sizeof(const char*) );
 			tokens = G_tokenize ( opt->descriptions, delm );
 			i = 0;
@@ -1052,7 +1052,7 @@
 	struct Option *opt ;
 	struct Flag *flag ;
 	char item[256];
-	char *key_desc;
+	const char *key_desc;
 	int maxlen;
 	int len, n;
 	int new_prompt = 0;
@@ -1227,7 +1227,7 @@
- * \fn void print_escaped_for_xml (FILE * fp, char * str)
+ * \fn void print_escaped_for_xml (FILE * fp, const char * str)
  * \brief Formats text for XML.
@@ -1235,7 +1235,7 @@
  * \param[in] str string to write
-static void print_escaped_for_xml (FILE * fp, char * str) {
+static void print_escaped_for_xml (FILE * fp, const char * str) {
 	for (;*str;str++) {
 		switch (*str) {
 			case '&':
@@ -1258,8 +1258,8 @@
  * \brief Format text for HTML output
 #define do_escape(c,escaped) case c: fputs(escaped,f);break
-static void print_escaped_for_html( FILE *f, char *str ) {
-	char *s;
+static void print_escaped_for_html( FILE *f, const char *str ) {
+	const char *s;
 	for(s=str;*s;s++) {
 		switch(*s) {
 			do_escape('&',"&amp;");
@@ -1524,7 +1524,7 @@
 	struct Flag *flag ;
-	char *type;
+	const char *type;
 	int new_prompt = 0;
 	new_prompt = uses_new_gisprompt();
@@ -1872,7 +1872,7 @@
 static void generate_tcl(FILE *fp)
 	int new_prompt = uses_new_gisprompt();
-	char *type;
+	const char *type;
 	int optn;
 	fprintf(fp, "begin_dialog {%s} {\n", pgm_name);
@@ -2059,7 +2059,7 @@
-static int show_options(int maxlen,char *str)
+static int show_options(int maxlen, const char *str)
 	char *buff = G_store(str) ;
 	char *p1, *p2 ;
@@ -2138,7 +2138,7 @@
 /* contents() is used to find things strings with characters like commas and
  * dashes.
-static int contains (char *s, int c)
+static int contains (const char *s, int c)
 	while(*s)
@@ -2250,7 +2250,7 @@
 	return(error) ;
-static int check_an_opt (char *key, int type, char *options, char *answer)
+static int check_an_opt (const char *key, int type, const char *options, const char *answer)
 	int error ;
@@ -2294,7 +2294,7 @@
 	return(error) ;
-static int check_int (char *ans, char *opts)
+static int check_int (const char *ans, const char *opts)
 	int d, lo, hi;
@@ -2362,7 +2362,7 @@
-static int check_double (char *ans, char *opts)
+static int check_double (const char *ans, const char *opts)
 	double d, lo, hi;
@@ -2404,7 +2404,7 @@
-static int check_string (char *ans, char *opts)
+static int check_string (const char *ans, const char *opts)
 	if (*opts == '\0')
 		return(0) ;
@@ -2526,7 +2526,7 @@
 static int check_multiple_opts (void)
-	char *ptr ;
+	const char *ptr ;
 	int n_commas ;
 	int n ;
 	int error ;
@@ -2622,7 +2622,7 @@
 	return(error) ;
-static int interactive( char *command)
+static int interactive(const char *command)
 	struct Item *item ;
Modified: grass/branches/develbranch_6/lib/init/local_proto.h
--- grass/branches/develbranch_6/lib/init/local_proto.h	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/init/local_proto.h	2008-07-03 08:18:42 UTC (rev 31977)
@@ -3,18 +3,18 @@
 /* clean_temp.c */
 int find_process(int);
 /* set_data.c */
-int list_locations(char *);
-int list_mapsets(char *, char *);
+int list_locations(const char *);
+int list_mapsets(const char *, const char *);
 int first_word(char *);
 int hit_return(void);
 /* lock.c */
 /* mke_loc.c */
-int make_location(char *, char *);
+int make_location(const char *, const char *);
 /* mke_mapset.c */
-int make_mapset(char *, char *);
+int make_mapset(const char *, const char *);
 /* other.c */
-int mapset_permissions(char *);
-int mapset_message(char *);
-int mapset_question(char *);
-int printfile(char *);
+int mapset_permissions(const char *);
+int mapset_message(const char *);
+int mapset_question(const char *);
+int printfile(const char *);
Modified: grass/branches/develbranch_6/lib/init/mke_loc.c
--- grass/branches/develbranch_6/lib/init/mke_loc.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/init/mke_loc.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -7,10 +7,10 @@
 #include "local_proto.h"
 int
-make_location (char *gisdbase, char *location_name)
+make_location (const char *gisdbase, const char *location_name)
     struct Cell_head window;
-    char buf[1024];
+    char buf[GPATH_MAX];
     int i;
     char myname[75];
     char *mapset;
Modified: grass/branches/develbranch_6/lib/init/mke_mapset.c
--- grass/branches/develbranch_6/lib/init/mke_mapset.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/init/mke_mapset.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -10,9 +10,9 @@
 #include <grass/gis.h>
-int make_mapset (char *location, char *mapset)
+int make_mapset (const char *location, const char *mapset)
-	char buffer[2048] ;
+	char buffer[GPATH_MAX] ;
 	char *buffer2;
 	FILE *fd ;
Modified: grass/branches/develbranch_6/lib/init/other.c
--- grass/branches/develbranch_6/lib/init/other.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/init/other.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -6,14 +6,14 @@
-static char *filename (char *name, char *mapset)
+static char *filename (const char *name, const char *mapset)
-    static char path[1024];
+    static char path[GPATH_MAX];
     G__file_name (path, "", name, mapset);
     return path;
-int mapset_permissions (char *mapset)
+int mapset_permissions (const char *mapset)
     int stat;
@@ -26,7 +26,7 @@
     return stat;
-int mapset_message (char *mapset)
+int mapset_message (const char *mapset)
     if(printfile(filename (".message", mapset)))
 	hit_return();
@@ -34,14 +34,14 @@
     return 0;
-int mapset_question (char *mapset)
+int mapset_question (const char *mapset)
     if(printfile(filename(".question", mapset)))
 	return G_yes("Select this mapset? ", -1);
     return 1;
-int printfile (char *name)
+int printfile (const char *name)
     int fd;
     int n;
@@ -50,7 +50,7 @@
     fd = open (name, 0);
     if (fd < 0) return 0;
     while ((n = read (fd, buf, sizeof buf)) > 0)
-	write (1, buf, n);
+	write (STDOUT_FILENO, buf, n);
     close (fd);
     return 1;
Modified: grass/branches/develbranch_6/lib/init/set_data.c
--- grass/branches/develbranch_6/lib/init/set_data.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/init/set_data.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -272,7 +272,7 @@
 int
-list_locations (char *gisdbase)
+list_locations (const char *gisdbase)
     fprintf(stderr, "\nAvailable locations:\n") ;
     fprintf(stderr, "----------------------\n") ;
@@ -282,9 +282,9 @@
 int
-list_mapsets (char *location_name, char *location)
+list_mapsets (const char *location_name, const char *location)
-    char **mapsets;
+    const char **mapsets;
     int i, num_mapsets;
     int any, ok, any_ok;
     int len, tot_len;
@@ -328,7 +328,7 @@
 int
 first_word (char *buf)
-    char temp[80];
+    char temp[GNAME_MAX];
     *temp = 0;
     sscanf (buf, "%s", temp);
Modified: grass/branches/develbranch_6/lib/sites/sites.c
--- grass/branches/develbranch_6/lib/sites/sites.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/lib/sites/sites.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -1236,7 +1236,7 @@
     struct field_info *fi;
     int nrows, row, ncols, col, ndbl, nstr, ctype;
-    char * name;
+    const char * name;
     dbDriver *driver;
     dbString stmt;
     dbCursor cursor;
Modified: grass/branches/develbranch_6/raster/r.colors/main.c
--- grass/branches/develbranch_6/raster/r.colors/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/r.colors/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -29,7 +29,7 @@
-static char **rules;
+static const char **rules;
 static int nrules;
 static void scan_rules(void)
@@ -40,7 +40,7 @@
     rules = G__ls(path, &nrules);
-    rules = G_realloc(rules, (nrules + 4) * sizeof(char *));
+    rules = G_realloc(rules, (nrules + 4) * sizeof(const char *));
     rules[nrules++] = G_store("random");
     rules[nrules++] = G_store("grey.eq");
@@ -57,7 +57,7 @@
     for (i = 0; i < nrules; i++)
-	char *name = rules[i];
+	const char *name = rules[i];
 	int n = strlen(name);
 	if (size < len + n + 2)
Modified: grass/branches/develbranch_6/raster/r.cross/main.c
--- grass/branches/develbranch_6/raster/r.cross/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/r.cross/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -43,7 +43,6 @@
     struct Colors pcolr;
     char buf[1024];
     CELL result;
-    CELL cross();
     struct GModule *module;
     struct
@@ -73,8 +72,8 @@
     parm.input->required   = YES;
     parm.input->multiple   = YES;
     parm.input->gisprompt  = "old,cell,raster" ;
-    sprintf(parm.input->description= G_malloc(60),
-	_("Names of 2-%d input raster maps"), NFILES);
+    sprintf(buf, _("Names of 2-%d input raster maps"), NFILES);
+    parm.input->description= G_store(buf);
     parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
Modified: grass/branches/develbranch_6/raster/r.neighbors/main.c
--- grass/branches/develbranch_6/raster/r.neighbors/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/r.neighbors/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -116,7 +116,7 @@
 	parm.method->type       = TYPE_STRING ;
 	parm.method->required   = NO ;
 	parm.method->answer     = "average";
-	p = parm.method->options  = G_malloc(1024);
+	p = G_malloc(1024);
 	for (n = 0; menu[n].name; n++)
 		if (n)
@@ -125,6 +125,7 @@
 			*p = 0;
 		strcat (p, menu[n].name);
+	parm.method->options  = p;
 	parm.method->description= _("Neighborhood operation") ;
 	parm.size = G_define_option() ;
Modified: grass/branches/develbranch_6/raster/r.out.gdal/main.c
--- grass/branches/develbranch_6/raster/r.out.gdal/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/r.out.gdal/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -79,9 +79,9 @@
     return;
-int import_band(GDALDatasetH hMEMDS, int band, char *name, char *mapset,
+int import_band(GDALDatasetH hMEMDS, int band, const char *name, const char *mapset,
 		struct Cell_head *cellhead, RASTER_MAP_TYPE maptype,
-		double nodataval, char *nodatakey)
+		double nodataval, const char *nodatakey)
     struct Colors sGrassColors;
Modified: grass/branches/develbranch_6/raster/r.transect/local_proto.h
--- grass/branches/develbranch_6/raster/r.transect/local_proto.h	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/r.transect/local_proto.h	2008-07-03 08:18:42 UTC (rev 31977)
@@ -1,2 +1,2 @@
 /* parse_line.c */
-int parse_line(char *, char **, double *, double *, double *, double *, int);
+int parse_line(const char *, char **, double *, double *, double *, double *, int);
Modified: grass/branches/develbranch_6/raster/r.transect/parse_line.c
--- grass/branches/develbranch_6/raster/r.transect/parse_line.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/r.transect/parse_line.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -1,6 +1,7 @@
 #include <math.h>
-#include <string.h>
+#include "local_proto.h"
 #define PI M_PI
 #define Radians(x) ((x) * PI/180.0)
@@ -8,10 +9,9 @@
 int
-parse_line (char *key, char **s, double *e1, double *n1, double *e2, double *n2, int projection)
+parse_line (const char *key, char **s, double *e1, double *n1, double *e2, double *n2, int projection)
     int err;
-    double sin(), cos();
     double distance, azimuth;
     err = 0;
Modified: grass/branches/develbranch_6/raster/r.univar2/r.univar_main.c
--- grass/branches/develbranch_6/raster/r.univar2/r.univar_main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/r.univar2/r.univar_main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -105,7 +105,7 @@
 		 ? create_univar_stat_struct (-1, cells, 0)
 		 : 0);
-	for (p = (const char **)param.inputfile->answers; *p; p++) {
+	for (p = param.inputfile->answers; *p; p++) {
 	    int fd = open_raster (*p);
 	    if (map_type != -1) {
@@ -187,9 +187,9 @@
     const RASTER_MAP_TYPE map_type = G_get_raster_map_type (fd);
     void *nextp
 	= ((! param.extended->answer) ? 0
-	   : (map_type == DCELL_TYPE) ? stats->dcell_array
-	   : (map_type == FCELL_TYPE) ? stats->fcell_array
-	   : stats->cell_array);
+	   : (map_type == DCELL_TYPE) ? (void *) stats->dcell_array
+	   : (map_type == FCELL_TYPE) ? (void *) stats->fcell_array
+	   : (void *) stats->cell_array);
     const size_t value_sz = G_raster_size (map_type);
     unsigned int row;
     void *raster_row;
Modified: grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c
--- grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/simwe/r.sim.sediment/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -135,7 +135,7 @@
 		ymax = ymin + stepy * (float) my;
 		hhc = hhmax = 0.;
+#if 0
 		bxmi=2093113. * conv;
 		bymi=731331. * conv;
 		bxma=2093461. * conv;
@@ -147,7 +147,7 @@
 		mx2o= (int)((bxma-bxmi)/bresx);
 		my2o= (int)((byma-bymi)/bresy);
-		/* relative small box coordinates: leave 1 grid layer for overlap
+		/* relative small box coordinates: leave 1 grid layer for overlap */
 		bxmi = bxmi - mixx + stepx;
 		bymi = bymi - miyy + stepy;
@@ -155,7 +155,7 @@
 		byma = byma - miyy - stepy;
 		mx2 = mx2o - 2*((int) (stepx / bresx));
 		my2 = my2o - 2*((int) (stepy / bresy));
+#endif
 	parm.elevin = G_define_standard_option(G_OPT_R_INPUT);
 	parm.elevin->key = "elevin";
Modified: grass/branches/develbranch_6/raster/wildfire/r.ros/main.c
--- grass/branches/develbranch_6/raster/wildfire/r.ros/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/raster/wildfire/r.ros/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -76,21 +76,17 @@
 /*measurements of the 13 fuel models, input of Rothermel equation (1972)*/
-float WO[4][14] = {    0, 0.034, 0.092, 0.138, 0.230, 0.046, 0.069, 0.052, 			   0.069, 0.134, 0.138, 0.069, 0.184, 0.322,
-		       0,     0, 0.046,     0, 0.184, 0.023, 0.115, 0.086,			   0.046, 0.019, 0.092, 0.207, 0.644, 1.058,
-           	       0,     0, 0.023,     0, 0.092, 0,     0.092, 0.069, 			   0.115, 0.007, 0.230, 0.253, 0.759, 1.288,
-		       0,     0, 0.023,     0, 0.230,  0.092,    0, 0.017,          		       0,     0,    0.092,     0,     0,     0};
+float WO[4][14] = {{    0, 0.034, 0.092, 0.138, 0.230, 0.046, 0.069, 0.052, 			   0.069, 0.134, 0.138, 0.069, 0.184, 0.322},
+		   {    0,     0, 0.046,     0, 0.184, 0.023, 0.115, 0.086,			   0.046, 0.019, 0.092, 0.207, 0.644, 1.058},
+           	   {    0,     0, 0.023,     0, 0.092, 0,     0.092, 0.069, 			   0.115, 0.007, 0.230, 0.253, 0.759, 1.288},
+		   {    0,     0, 0.023,     0, 0.230,  0.092,    0, 0.017,          		       0,     0,    0.092,     0,     0}};
  					    /*ovendry fuel loading, lb./ft.^2*/
 float DELTA[] = {  0, 1.0, 1.0, 2.5, 6.0, 2.0, 2.5, 2.5,
 	       	 0.2, 0.2, 1.0, 1.0, 2.3, 3.0};     /*fuel depth, ft.*/
-float SIGMA[4][14] = {   0, 3500, 3000, 1500, 2000, 2000, 1750, 1750,
-		      2000, 2500, 2000, 1500, 1500, 1500,
-		         0,    0,  109,    0,  109,  109,  109,  109,
-		       109,  109,  109,  109,  109,  109,
-		         0,    0,   30,    0,   30,    0,   30,   30,
-		        30,   30,   30,   30,   30,   30,
-		         0,    0, 1500,    0, 1500, 1500,    0, 1500,
-		         0,    0, 1500,    0,    0,    0};
+float SIGMA[4][14] = {{   0, 3500, 3000, 1500, 2000, 2000, 1750, 1750, 		      2000, 2500, 2000, 1500, 1500, 1500},
+		      {   0,    0,  109,    0,  109,  109,  109,  109,		       109,  109,  109,  109,  109,  109},
+		      {   0,    0,   30,    0,   30,    0,   30,   30,		        30,   30,   30,   30,   30,   30},
+		      {   0,    0, 1500,    0, 1500, 1500,    0, 1500,		         0,    0, 1500,    0,    0,    0}};
 			 /*fuel particale surface-area-to-volume ratio, 1/ft.*/
 float MX[]  = {   0, 0.12, 0.15, 0.25, 0.20, 0.20, 0.25, 0.40,
 	       0.30, 0.25, 0.25, 0.15, 0.20, 0.25};	 	         		     			     /*moisture content of extinction*/
Modified: grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c
--- grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/vector/lidar/v.surf.bspline/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -191,7 +191,7 @@
 	sprintf (table_name, "%s_aux", out_opt->answer);
     /* Open driver and database */
-    if (db_table_exists (dvr, db, &table_name)){  /*Something went wrong in a
+    if (db_table_exists (dvr, db, table_name)){  /*Something went wrong in a
 						    previous v.surf.bspline execution*/
 	dbString sql;
 	char buf[1024];
Modified: grass/branches/develbranch_6/vector/v.digit/generate.c
--- grass/branches/develbranch_6/vector/v.digit/generate.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/vector/v.digit/generate.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -17,7 +17,8 @@
 	    char **form)
+    const char *colname;
     dbDriver *driver;
     dbHandle handle;
Modified: grass/branches/develbranch_6/vector/v.lrs/v.lrs.create/main.c
--- grass/branches/develbranch_6/vector/v.lrs/v.lrs.create/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/vector/v.lrs/v.lrs.create/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -96,7 +96,7 @@
     struct Option *driver_opt, *database_opt, *table_opt, *thresh_opt;
     char   *mapset, buf[2000];
-    char   *drv, *db;
+    const char *drv, *db;
     struct Map_info In, Out, PMap, EMap;
     struct line_cats *LCats, *PCats;
     struct line_pnts *LPoints, *L2Points, *PPoints;
Modified: grass/branches/develbranch_6/vector/v.lrs/v.lrs.label/main.c
--- grass/branches/develbranch_6/vector/v.lrs/v.lrs.label/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/vector/v.lrs/v.lrs.label/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -78,7 +78,7 @@
-    char   *drv, *db;
     struct Map_info In, Out;
     struct line_cats *LCats, *SCats;
     struct line_pnts *LPoints, *SPoints;
Modified: grass/branches/develbranch_6/vector/v.lrs/v.lrs.segment/main.c
--- grass/branches/develbranch_6/vector/v.lrs/v.lrs.segment/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/vector/v.lrs/v.lrs.segment/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -55,7 +55,7 @@
     struct Option *table_opt;
-    char   *drv, *db;
     struct line_pnts *LPoints, *SPoints, *PlPoints;
Modified: grass/branches/develbranch_6/vector/v.lrs/v.lrs.where/main.c
--- grass/branches/develbranch_6/vector/v.lrs/v.lrs.where/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/vector/v.lrs/v.lrs.where/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -42,7 +42,7 @@
     char   *mapset;
-    char   *drv, *db;
     struct Map_info LMap, PMap;
     struct line_pnts *LPoints, *PPoints;
Modified: grass/branches/develbranch_6/vector/v.out.svg/main.c
--- grass/branches/develbranch_6/vector/v.out.svg/main.c	2008-07-03 07:48:26 UTC (rev 31976)
+++ grass/branches/develbranch_6/vector/v.out.svg/main.c	2008-07-03 08:18:42 UTC (rev 31977)
@@ -156,8 +156,8 @@
             Column = db_get_table_column (Table, i);
             if (attr_opt->answer != NULL) {
                 for (j=0; attr_opt->answers[j] != NULL; j++) {
-                    if ( G_strcasecmp(G_tolcase(attr_opt->answers[j]),
-				      G_tolcase(db_get_column_name(Column))) == 0 ) {
+                    if ( G_strcasecmp(attr_opt->answers[j],
+				      db_get_column_name(Column)) == 0 ) {
                         attr_cols[attr_size] = i;
                         attr_size +=1;
                         break;
@@ -366,7 +366,8 @@
             Column = db_get_table_column (Table, attr_cols[i]);
             Value  = db_get_column_value(Column);
             db_convert_column_value_to_string (Column, &dbstring);
-            fprintf(fpsvg,"gg:%s=\"", G_tolcase(db_get_column_name(Column)));
+	    G_strcpy(buf, db_get_column_name(Column));
+            fprintf(fpsvg,"gg:%s=\"", G_tolcase(buf));
             print_escaped_for_xml(db_get_string (&dbstring));
             fprintf(fpsvg,"\" ");
