[GRASS-SVN] r32006 - in grass/branches/develbranch_6: include
lib/g3d lib/ogsf
svn_grass at osgeo.org
Sun Jul 6 05:06:12 EDT 2008
Author: neteler
Date: 2008-07-06 05:06:12 -0400 (Sun, 06 Jul 2008)
New Revision: 32006
grass/branches/develbranch_6/include/G3d.h
grass/branches/develbranch_6/include/ogsf_proto.h
grass/branches/develbranch_6/lib/g3d/find_grid3.c
grass/branches/develbranch_6/lib/g3d/g3dcolor.c
grass/branches/develbranch_6/lib/g3d/g3dopen.c
grass/branches/develbranch_6/lib/g3d/g3drange.c
grass/branches/develbranch_6/lib/ogsf/GK2.c
grass/branches/develbranch_6/lib/ogsf/GP2.c
grass/branches/develbranch_6/lib/ogsf/GS2.c
grass/branches/develbranch_6/lib/ogsf/GS_util.c
grass/branches/develbranch_6/lib/ogsf/GV2.c
grass/branches/develbranch_6/lib/ogsf/GVL2.c
grass/branches/develbranch_6/lib/ogsf/Gp3.c
grass/branches/develbranch_6/lib/ogsf/Gs3.c
grass/branches/develbranch_6/lib/ogsf/Gv3.c
grass/branches/develbranch_6/lib/ogsf/Gvl3.c
grass/branches/develbranch_6/lib/ogsf/gs.c
grass/branches/develbranch_6/lib/ogsf/gsd_fonts.c
grass/branches/develbranch_6/lib/ogsf/gsd_label.c
grass/branches/develbranch_6/lib/ogsf/gsd_legend.c
grass/branches/develbranch_6/lib/ogsf/gsd_objs.c
grass/branches/develbranch_6/lib/ogsf/gsds.c
grass/branches/develbranch_6/lib/ogsf/gvl.c
grass/branches/develbranch_6/lib/ogsf/gvl_calc.c
grass/branches/develbranch_6/lib/ogsf/gvl_file.c
grass/branches/develbranch_6/lib/ogsf/gvld.c
glynn: Add 'const' to OGSF, G3D functions where appropriate (merge from trunk)
Modified: grass/branches/develbranch_6/include/G3d.h
--- grass/branches/develbranch_6/include/G3d.h 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/include/G3d.h 2008-07-06 09:06:12 UTC (rev 32006)
@@ -265,7 +265,7 @@
/* grass/src/libes/g3d/filename.c */
void G3d_filename(char *, char *, char *, char *);
/* grass/src/libes/g3d/find_grid3.c */
-char *G_find_grid3(char *, char *);
+char *G_find_grid3(const char *, const char *);
/* grass/src/libes/g3d/fpcompress.c */
void G_fpcompress_printBinary(char *, int);
void G_fpcompress_dissectXdrDouble(unsigned char *);
@@ -289,9 +289,9 @@
/* grass/src/libes/g3d/g3dclose.c */
int G3d_closeCell(G3D_Map *);
/* grass/src/libes/g3d/g3dcolor.c */
-int G3d_removeColor(char *);
-int G3d_readColors(char *, char *, struct Colors *);
-int G3d_writeColors(char *, char *, struct Colors *);
+int G3d_removeColor(const char *);
+int G3d_readColors(const char *, const char *, struct Colors *);
+int G3d_writeColors(const char *, const char *, struct Colors *);
/* grass/src/libes/g3d/g3ddefaults.c */
void G3d_setCompressionMode(int, int, int, int);
void G3d_getCompressionMode(int *, int *, int *, int *);
@@ -375,9 +375,9 @@
void G3d_setNullValue(void *, int, int);
/* grass/src/libes/g3d/g3dopen2.c */
/* grass/src/libes/g3d/g3dopen.c */
-void *G3d_openCellOldNoHeader(char *, char *);
-void * G3d_openCellOld (char *, char * , G3D_Region *, int, int);
-void * G3d_openCellNew (char *, int, int, G3D_Region * );
+void *G3d_openCellOldNoHeader(const char *, const char *);
+void * G3d_openCellOld (const char *, const char * , G3D_Region *, int, int);
+void * G3d_openCellNew (const char *, int, int, G3D_Region * );
/* grass/src/libes/g3d/g3dparam.c */
void G3d_setStandard3dInputParams(void);
int G3d_getStandard3dParams(int *, int *, int *, int *, int *, int *, int *, int *, int *, int *, int *, int *);
@@ -385,7 +385,7 @@
char *G3d_getWindowParams(void);
/* grass/src/libes/g3d/g3drange.c */
void G3d_range_updateFromTile(G3D_Map *, char *, int, int, int, int, int, int, int, int);
-int G3d_readRange(char *, char *, struct FPRange *);
+int G3d_readRange(const char *, const char *, struct FPRange *);
int G3d_range_load(G3D_Map *);
void G3d_range_min_max(G3D_Map *, double *, double *);
int G3d_range_write(G3D_Map *);
Modified: grass/branches/develbranch_6/include/ogsf_proto.h
--- grass/branches/develbranch_6/include/ogsf_proto.h 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/include/ogsf_proto.h 2008-07-06 09:06:12 UTC (rev 32006)
@@ -42,7 +42,7 @@
void GK_update_frames(void);
void GK_set_numsteps(int);
void GK_clear_keys(void);
-void GK_print_keys(char *);
+void GK_print_keys(const char *);
int GK_move_key(float, float, float);
int GK_delete_key(float, float, int);
int GK_add_key(float, unsigned long, int, float);
@@ -59,11 +59,11 @@
int GP_num_sites(void);
int *GP_get_site_list(int *);
int GP_delete_site(int);
-int GP_load_site(int, char *);
+int GP_load_site(int, const char *);
int GP_get_sitename(int, char *);
int GP_get_sitemode(int, int *, int *, int *, float *, int *);
int GP_set_sitemode(int, int, int, int, float, int);
-int GP_attmode_color(int, char *);
+int GP_attmode_color(int, const char *);
int GP_attmode_none(int);
int GP_set_zmode(int, int);
int GP_get_zmode(int, int *);
@@ -123,7 +123,7 @@
int GS_num_surfs(void);
int *GS_get_surf_list(int *);
int GS_delete_surface(int);
-int GS_load_att_map(int, char *, int);
+int GS_load_att_map(int, const char *, int);
void GS_draw_surf(int);
void GS_draw_wire(int);
void GS_alldraw_wire(void);
@@ -186,8 +186,8 @@
void GS_set_fencecolor(int);
int GS_get_fencecolor(void);
int GS_get_distance_alongsurf(int, float, float, float, float, float *, int);
-int GS_save_3dview(char *, int);
-int GS_load_3dview(char *, int);
+int GS_save_3dview(const char *, int);
+int GS_load_3dview(const char *, int);
void GS_init_view(void);
void GS_clear(int);
double GS_get_aspect(void);
@@ -196,7 +196,7 @@
int GS_write_zoom(const char *, unsigned int, unsigned int);
void GS_draw_all_list(void);
void GS_delete_list(GLuint);
-int GS_draw_legend(char *, GLuint, int, int *, float *, int *);
+int GS_draw_legend(const char *, GLuint, int, int *, float *, int *);
void GS_draw_fringe(int, unsigned long, float, int *);
void GS_getlight_position(int, float *, float *, float *, int *);
void GS_getlight_color(int, float *, float *, float *);
@@ -209,7 +209,7 @@
void GS_set_swap_func(void (*)(void));
/* From GS_util.c */
-double GS_geodistance (double *, double *, char *);
+double GS_geodistance (double *, double *, const char *);
float GS_distance (float *, float *);
float GS_P2distance (float *, float *);
void GS_v3eq(float *, float *);
@@ -232,7 +232,7 @@
int GV_num_vects(void);
int *GV_get_vect_list(int *);
int GV_delete_vector(int);
-int GV_load_vector(int, char *);
+int GV_load_vector(int, const char *);
int GV_get_vectname(int, char *);
int GV_set_vectmode(int, int, int, int, int);
int GV_get_vectmode(int, int *, int *, int *, int *);
@@ -256,7 +256,7 @@
int GVL_num_vols(void);
int *GVL_get_vol_list(int *);
int GVL_delete_vol(int);
-int GVL_load_vol(int, char *);
+int GVL_load_vol(int, const char *);
int GVL_get_volname(int, char *);
void GVL_set_trans(int, float, float, float);
int GVL_get_trans(int, float *, float *, float *);
@@ -279,7 +279,7 @@
int GVL_isosurf_get_att(int, int, int, int *, float *, char *);
int GVL_isosurf_unset_att(int, int, int);
int GVL_isosurf_set_att_const(int, int, int, float);
-int GVL_isosurf_set_att_map(int, int, int, char *);
+int GVL_isosurf_set_att_map(int, int, int, const char *);
int GVL_isosurf_get_flags(int, int, int *);
int GVL_isosurf_set_flags(int, int, int);
int GVL_isosurf_num_isosurfs(int);
@@ -301,34 +301,33 @@
int GVL_slice_set_pos(int, int, float, float, float, float, float, float, int);
/* From Gp3.c */
-int Gp_set_color(char *, geopoint *);
-geopoint *Gp_load_sites(char *, int *, int *, int *);
+int Gp_set_color(const char *, geopoint *);
+geopoint *Gp_load_sites(const char *, int *, int *, int *);
/* From Gs3.c */
-void Gs_warning(char *);
-void Gs_status(char *);
+void Gs_status(const char *);
double Gs_distance(double *, double *);
-int Gs_loadmap_as_float(struct Cell_head *, char *, float *, struct BM *,
+int Gs_loadmap_as_float(struct Cell_head *, const char *, float *, struct BM *,
int *);
-int Gs_loadmap_as_int(struct Cell_head *, char *, int *, struct BM *, int *);
-int Gs_numtype(char *, int *);
-int Gs_loadmap_as_short(struct Cell_head *, char *, short *, struct BM *,
+int Gs_loadmap_as_int(struct Cell_head *, const char *, int *, struct BM *, int *);
+int Gs_numtype(const char *, int *);
+int Gs_loadmap_as_short(struct Cell_head *, const char *, short *, struct BM *,
int *);
-int Gs_loadmap_as_char(struct Cell_head *, char *, unsigned char *,
+int Gs_loadmap_as_char(struct Cell_head *, const char *, unsigned char *,
-int Gs_loadmap_as_bitmap(struct Cell_head *, char *, struct BM *);
-int Gs_build_256lookup(char *, int *);
-void Gs_pack_colors(char *, int *, int, int);
-void Gs_pack_colors_float(char *, float *, int *, int, int);
-int Gs_get_cat_label(char *, int, int, char *);
-int Gs_save_3dview(char *, geoview *, geodisplay *, struct Cell_head *,
+int Gs_loadmap_as_bitmap(struct Cell_head *, const char *, struct BM *);
+int Gs_build_256lookup(const char *, int *);
+void Gs_pack_colors(const char *, int *, int, int);
+void Gs_pack_colors_float(const char *, float *, int *, int, int);
+int Gs_get_cat_label(const char *, int, int, char *);
+int Gs_save_3dview(const char *, geoview *, geodisplay *, struct Cell_head *,
geosurf *);
-int Gs_load_3dview(char *, geoview *, geodisplay *, struct Cell_head *,
+int Gs_load_3dview(const char *, geoview *, geodisplay *, struct Cell_head *,
geosurf *);
int Gs_update_attrange(geosurf *, int);
/* From Gv3.c */
-geoline *Gv_load_vect(char *, int *);
+geoline *Gv_load_vect(const char *, int *);
void add_Vectmem(int);
void sub_Vectmem(int);
void show_Vectmem(void);
@@ -371,7 +370,7 @@
int gpd_3dsite(geosite *, float, float, int);
/* From gs.c */
-void gs_err(char *);
+void gs_err(const char *);
void gs_init(void);
geosurf *gs_get_surf(int);
geosurf *gs_get_prev_surface(int);
@@ -454,10 +453,11 @@
/* From gsd_fonts.c */
GLuint gsd_set_font(const char *);
-int gsd_get_txtwidth(char *, int );
+int gsd_get_txtwidth(const char *, int );
int gsd_get_txtheight(int size);
-void do_label_display(GLuint, float *, char *);
-int get_txtxoffset();
+void do_label_display(GLuint, float *, const char *);
+int get_txtdescender(void);
+int get_txtxoffset(void);
/* From gsd_img_ppm.c */
int GS_write_ppm(const char *);
@@ -469,7 +469,7 @@
int GS_write_tif(const char *);
/* From gsd_label.c */
-void gs_put_label(char *, GLuint , int , unsigned long, int *);
+void gs_put_label(const char *, GLuint , int , unsigned long, int *);
void gsd_remove_curr(void);
void gsd_remove_all(void);
void gsd_call_label(void);
@@ -618,8 +618,8 @@
int V3Cross(Point3, Point3, Point3);
/* From gsds.c */
-int gsds_findh(char *, IFLAG *, IFLAG *, int);
-int gsds_newh(char *);
+int gsds_findh(const char *, IFLAG *, IFLAG *, int);
+int gsds_newh(const char *);
typbuff *gsds_get_typbuff(int, IFLAG);
char *gsds_get_name(int);
int gsds_free_datah(int);
@@ -684,7 +684,7 @@
int gvl_isosurf_get_att_src(geovol_isosurf *, int);
int gvl_isosurf_set_att_src(geovol_isosurf *, int, int);
int gvl_isosurf_set_att_const(geovol_isosurf *, int, float);
-int gvl_isosurf_set_att_map(geovol_isosurf *, int, char *);
+int gvl_isosurf_set_att_map(geovol_isosurf *, int, const char *);
int gvl_isosurf_set_att_changed(geovol_isosurf *, int);
int gvl_slice_init(geovol_slice *);
@@ -703,7 +703,7 @@
char *gvl_file_get_name(int);
int gvl_file_get_file_type(geovol_file *);
int gvl_file_get_data_type(geovol_file *);
-int gvl_file_newh(char *, IFLAG);
+int gvl_file_newh(const char *, IFLAG);
int gvl_file_free_datah(int);
int gvl_file_start_read(geovol_file *);
int gvl_file_end_read(geovol_file *);
@@ -714,7 +714,7 @@
void gvl_file_get_min_max(geovol_file *, double *, double *);
/* From Gvl3.c */
-int Gvl_load_colors_data(void **, char *);
+int Gvl_load_colors_data(void **, const char *);
int Gvl_unload_colors_data(void *);
int Gvl_get_color_for_value(void *, float *);
@@ -722,7 +722,7 @@
int gvl_isosurf_calc(geovol *);
int gvl_slices_calc(geovol *);
void gvl_write_char(int, unsigned char **, unsigned char);
-unsigned char gvl_read_char(int, unsigned char *);
+unsigned char gvl_read_char(int, const unsigned char *);
void gvl_align_data(int, unsigned char *);
/* From gvld.c */
@@ -743,7 +743,7 @@
void gsd_fringe_vert_line (float, geosurf *, int, int);
/* from gsd_legend.c */
-GLuint gsd_put_legend(char *, GLuint, int , int *, float *, int *);
+GLuint gsd_put_legend(const char *, GLuint, int , int *, float *, int *);
void gsd_bgn_legend_viewport(GLint, GLint, GLint, GLint);
void gsd_end_legend_viewport(void);
int gsd_make_nice_number(float *);
Modified: grass/branches/develbranch_6/lib/g3d/find_grid3.c
--- grass/branches/develbranch_6/lib/g3d/find_grid3.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/g3d/find_grid3.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -11,28 +11,15 @@
* if name is of the form nnn in ppp then
* name = nnn and mapset = ppp
- * \param char *name file name to look for
- * \param char *mapset mapset to search. if mapset is ""
- * will search in mapset search list
+ * \param const char *name file name to look for
+ * \param const char *mapset mapset to search. if mapset is ""
+ * will search in mapset search list
* \return char * pointer to a string with name of mapset
* where cell file was found, or NULL if not found
-char *
-G_find_grid3 (char *cell, char *mset)
+char *G_find_grid3(const char *name, const char *mapset)
- char name[256], mapset[256], element[512];
- if (cell == NULL || *cell == 0)
- return 0;
- if(G__name_is_fully_qualified (cell, name, mapset))
- sprintf (element, "grid3/%s", name);
- else
- sprintf (element, "grid3/%s", cell);
- return (G_find_file (element, "cell", mset));
- /* actually looks for the data, not the directory */
+ return G_find_file2_misc ("grid3", "cell", name, mapset);
Modified: grass/branches/develbranch_6/lib/g3d/g3dcolor.c
--- grass/branches/develbranch_6/lib/g3d/g3dcolor.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/g3d/g3dcolor.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -10,14 +10,14 @@
#include <grass/gis.h>
#include "G3d_intern.h"
-static int read_colors(char *,char *,char *,struct Colors *);
+static int read_colors(const char *,const char *,const char *,struct Colors *);
static int read_new_colors(FILE *,struct Colors *);
static int read_old_colors(FILE *,struct Colors *);
int
-G3d_removeColor (char *name)
+G3d_removeColor (const char *name)
/* adapted from G_remove_colr */
@@ -44,7 +44,7 @@
int
-G3d_readColors (char *name, char *mapset, struct Colors *colors)
+G3d_readColors (const char *name, const char *mapset, struct Colors *colors)
/* adapted from G_read_colors */
@@ -102,7 +102,7 @@
return -1;
-static int read_colors( char *element , char *name , char *mapset , struct Colors *colors)
+static int read_colors( const char *element , const char *name , const char *mapset , struct Colors *colors)
FILE *fd ;
int stat;
@@ -357,7 +357,7 @@
int
-G3d_writeColors (char *name, char *mapset, struct Colors *colors)
+G3d_writeColors (const char *name, const char *mapset, struct Colors *colors)
/* adapted from G_write_colors */
Modified: grass/branches/develbranch_6/lib/g3d/g3dopen.c
--- grass/branches/develbranch_6/lib/g3d/g3dopen.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/g3d/g3dopen.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -10,7 +10,7 @@
void *
-G3d_openCellOldNoHeader (char *name, char *mapset)
+G3d_openCellOldNoHeader (const char *name, const char *mapset)
G3D_Map *map;
@@ -84,7 +84,7 @@
void *
-G3d_openCellOld (char *name, char *mapset, G3D_Region *window, int typeIntern, int cache)
+G3d_openCellOld (const char *name, const char *mapset, G3D_Region *window, int typeIntern, int cache)
G3D_Map *map;
@@ -214,7 +214,7 @@
void *
-G3d_openCellNew (char *name, int typeIntern, int cache, G3D_Region *region)
+G3d_openCellNew (const char *name, int typeIntern, int cache, G3D_Region *region)
G3D_Map *map;
Modified: grass/branches/develbranch_6/lib/g3d/g3drange.c
--- grass/branches/develbranch_6/lib/g3d/g3drange.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/g3d/g3drange.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -48,7 +48,7 @@
int
-G3d_readRange (char *name, char *mapset, struct FPRange *drange)
+G3d_readRange (const char *name, const char *mapset, struct FPRange *drange)
/* adapted from G_read_fp_range */
int fd;
Modified: grass/branches/develbranch_6/lib/ogsf/GK2.c
--- grass/branches/develbranch_6/lib/ogsf/GK2.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/GK2.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -209,7 +209,7 @@
\param name filename
-void GK_print_keys(char *name)
+void GK_print_keys(const char *name)
Keylist *k;
FILE *fp;
Modified: grass/branches/develbranch_6/lib/ogsf/GP2.c
--- grass/branches/develbranch_6/lib/ogsf/GP2.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/GP2.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -181,7 +181,7 @@
\return -1 on error
\return 1 on success
-int GP_load_site(int id, char *filename)
+int GP_load_site(int id, const char *filename)
geosite *gp;
@@ -290,7 +290,7 @@
\return 0 for no attribute info
\return -1 for bad parameter
-int GP_attmode_color(int id, char *filename)
+int GP_attmode_color(int id, const char *filename)
geosite *gp;
Modified: grass/branches/develbranch_6/lib/ogsf/GS2.c
--- grass/branches/develbranch_6/lib/ogsf/GS2.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/GS2.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -822,7 +822,7 @@
\param range values range
\param pt ?
-int GS_draw_legend(char *name, GLuint fontbase, int size, int *flags,
+int GS_draw_legend(const char *name, GLuint fontbase, int size, int *flags,
float *range, int *pt)
int list_no;
@@ -1584,12 +1584,12 @@
\return -1 on error (invalid surface id)
\return ?
-int GS_load_att_map(int id, char *filename, int att)
+int GS_load_att_map(int id, const char *filename, int att)
geosurf *gs;
unsigned int changed;
unsigned int atty;
- char *mapset;
+ const char *mapset;
struct Cell_head rast_head;
int reuse = 0, begin, hdata, ret, neg = 0, has_null = 0;
typbuff *tbuff;
@@ -3242,7 +3242,7 @@
\return ?
-int GS_save_3dview(char *vname, int surfid)
+int GS_save_3dview(const char *vname, int surfid)
return (Gs_save_3dview(vname, &Gv, &Gd, &wind, gs_get_surf(surfid)));
@@ -3255,7 +3255,7 @@
\return ?
-int GS_load_3dview(char *vname, int surfid)
+int GS_load_3dview(const char *vname, int surfid)
return (Gs_load_3dview(vname, &Gv, &Gd, &wind, gs_get_surf(surfid)));
Modified: grass/branches/develbranch_6/lib/ogsf/GS_util.c
--- grass/branches/develbranch_6/lib/ogsf/GS_util.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/GS_util.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -52,7 +52,7 @@
\return distance between two geographic coordinates in current projection
-double GS_geodistance(double *from, double *to, char *units)
+double GS_geodistance(double *from, double *to, const char *units)
double meters;
Modified: grass/branches/develbranch_6/lib/ogsf/GV2.c
--- grass/branches/develbranch_6/lib/ogsf/GV2.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/GV2.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -171,7 +171,7 @@
\return -1 on error (invalid vector set id)
-int GV_load_vector(int id, char *filename)
+int GV_load_vector(int id, const char *filename)
geovect *gv;
Modified: grass/branches/develbranch_6/lib/ogsf/GVL2.c
--- grass/branches/develbranch_6/lib/ogsf/GVL2.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/GVL2.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -229,7 +229,7 @@
\return -1 on error
\return 0 on success
-int GVL_load_vol(int id, char *filename)
+int GVL_load_vol(int id, const char *filename)
geovol *gvl;
int handle;
@@ -843,7 +843,7 @@
\return ?
\return -1 on error
-int GVL_isosurf_set_att_map(int id, int isosurf_id, int att, char *filename)
+int GVL_isosurf_set_att_map(int id, int isosurf_id, int att, const char *filename)
geovol_isosurf *isosurf;
Modified: grass/branches/develbranch_6/lib/ogsf/Gp3.c
--- grass/branches/develbranch_6/lib/ogsf/Gp3.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/Gp3.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -38,9 +38,9 @@
\return 0 on failure
-int Gp_set_color(char *grassname, geopoint * gp)
+int Gp_set_color(const char *grassname, geopoint * gp)
- char *col_map;
+ const char *col_map;
struct Colors sc;
CELL cat;
geopoint *tp;
@@ -87,7 +87,7 @@
\return pointer to geopoint struct
\return NULL on failure
-geopoint *Gp_load_sites(char *grassname, int *nsites, int *has_z,
+geopoint *Gp_load_sites(const char *grassname, int *nsites, int *has_z,
int *has_att)
struct Map_info map;
@@ -98,13 +98,13 @@
struct Cell_head wind;
RASTER_MAP_TYPE rtype;
int ndim;
- char *mapset;
np = 0;
eof = 0;
*has_z = *has_att = 0;
- mapset = G_find_vector2((const char *) grassname, "");
+ mapset = G_find_vector2(grassname, "");
if (!mapset) {
G_warning (_("Vector map <%s> not found"),
grassname);
Modified: grass/branches/develbranch_6/lib/ogsf/Gs3.c
--- grass/branches/develbranch_6/lib/ogsf/Gs3.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/Gs3.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -76,7 +76,7 @@
* may be replaced by a user's function.
* Or else use G_set_error_routine.
-void Gs_status(char *str)
+void Gs_status(const char *str)
G_debug(3, "%s", str);
@@ -123,11 +123,12 @@
-int Gs_loadmap_as_float(struct Cell_head *wind, char *map_name, float *buff,
+int Gs_loadmap_as_float(struct Cell_head *wind, const char *map_name, float *buff,
struct BM *nullmap, int *has_null)
FILEDESC cellfile;
- char *map_set, *nullflags;
+ const char *map_set;
+ char *nullflags;
int offset, row, col;
G_debug(3, "Gs_loadmap_as_float(): name=%s", map_name);
@@ -198,11 +199,12 @@
-int Gs_loadmap_as_int(struct Cell_head *wind, char *map_name, int *buff,
+int Gs_loadmap_as_int(struct Cell_head *wind, const char *map_name, int *buff,
FILEDESC cellfile;
+ char *nullflags;
G_debug(3, "Gs_loadmap_as_int");
@@ -261,11 +263,11 @@
\return -1 if map is integer and G_read_range() fails
\return data type (ARRY_*)
-int Gs_numtype(char *filename, int *negflag)
+int Gs_numtype(const char *filename, int *negflag)
CELL max = 0, min = 0;
struct Range range;
- char *mapset;
int shortbits, charbits, bitplace;
static int max_short, max_char;
static int first = 1;
@@ -344,11 +346,12 @@
\return -2 if read ok, but 1 or more values were too large (small)
to fit into a short (in which case the max (min) short is used)
-int Gs_loadmap_as_short(struct Cell_head *wind, char *map_name, short *buff,
+int Gs_loadmap_as_short(struct Cell_head *wind, const char *map_name, short *buff,
FILEDESC cellfile;
+ char *nullflags;
int *ti, *tmp_buf;
int offset, row, col, val, max_short, overflow, shortsize, bitplace;
short *ts;
@@ -459,11 +462,12 @@
were too large (small) to fit into an unsigned char.
(in which case the max (min) char is used)
-int Gs_loadmap_as_char(struct Cell_head *wind, char *map_name,
+int Gs_loadmap_as_char(struct Cell_head *wind, const char *map_name,
unsigned char *buff, struct BM *nullmap, int *has_null)
FILEDESC cellfile;
+ char *nullflags;
int *ti, *tmp_buf;
int offset, row, col, val, max_char, overflow, charsize, bitplace;
unsigned char *tc;
@@ -569,11 +573,12 @@
\returns 1 on success
\return -1 on failure
-int Gs_loadmap_as_bitmap(struct Cell_head *wind, char *map_name,
+int Gs_loadmap_as_bitmap(struct Cell_head *wind, const char *map_name,
struct BM *buff)
FILEDESC cellfile;
+ char *nullflags;
int *tmp_buf;
int row, col;
@@ -638,9 +643,9 @@
-int Gs_build_256lookup(char *filename, int *buff)
+int Gs_build_256lookup(const char *filename, int *buff)
- char *map;
struct Colors colrules;
CELL min, max, cats[256];
int i;
@@ -648,14 +653,14 @@
G_debug(3, "building color table");
- map = G_find_cell2(filename, "");
- if (!map) {
+ mapset = G_find_cell2(filename, "");
+ if (!mapset) {
G_warning(_("Raster map <%s> not found"),
filename);
return 0;
- G_read_colors(filename, map, &colrules);
+ G_read_colors(filename, mapset, &colrules);
G_get_color_range(&min, &max, &colrules);
if (min < 0 || max > 255) {
@@ -698,15 +703,15 @@
\param rows number of rows
\param cols number of cols
-void Gs_pack_colors(char *filename, int *buff, int rows, int cols)
+void Gs_pack_colors(const char *filename, int *buff, int rows, int cols)
- char *map;
unsigned char *r, *g, *b, *set;
int *cur, i, j;
- if (!map) {
+ if (!mapset) {
filename);
return;
@@ -717,7 +722,7 @@
b = (unsigned char *) G_malloc(cols);
set = (unsigned char *) G_malloc(cols);
cur = buff;
@@ -766,17 +771,17 @@
-void Gs_pack_colors_float(char *filename, float *fbuf, int *ibuf, int rows,
+void Gs_pack_colors_float(const char *filename, float *fbuf, int *ibuf, int rows,
int cols)
- char *map;
int i, j, *icur;
FCELL *fcur;
- if (!map) {
+ if (!mapset) {
filename);
return;
@@ -787,7 +792,7 @@
fcur = fbuf;
icur = ibuf;
@@ -836,10 +841,10 @@
-int Gs_get_cat_label(char *filename, int drow, int dcol, char *catstr)
+int Gs_get_cat_label(const char *filename, int drow, int dcol, char *catstr)
struct Categories cats;
- char *mapset;
CELL *buf;
DCELL *dbuf;
RASTER_MAP_TYPE map_type;
@@ -916,10 +921,10 @@
\return -1 on error
\return ?
-int Gs_save_3dview(char *vname, geoview * gv, geodisplay * gd,
+int Gs_save_3dview(const char *vname, geoview * gv, geodisplay * gd,
struct Cell_head *w, geosurf * defsurf)
- char *mapset;
struct G_3dview v;
float zmax, zmin;
@@ -1014,10 +1019,10 @@
\return 1
-int Gs_load_3dview(char *vname, geoview * gv, geodisplay * gd,
+int Gs_load_3dview(const char *vname, geoview * gv, geodisplay * gd,
- char *mapset;
struct G_3dview v;
int ret = -1;
float pt[3];
Modified: grass/branches/develbranch_6/lib/ogsf/Gv3.c
--- grass/branches/develbranch_6/lib/ogsf/Gv3.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/Gv3.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -40,7 +40,7 @@
\return pointer to geoline struct
-geoline *Gv_load_vect(char *grassname, int *nlines)
+geoline *Gv_load_vect(const char *grassname, int *nlines)
struct line_pnts *points;
@@ -48,9 +48,9 @@
int np, i, n, nareas, nl=0, area, type, is3d;
float vect[2][3];
- char *mapset;
if (!mapset) {
G_warning(_("Vector map <%s> not found"),
grassname);
Modified: grass/branches/develbranch_6/lib/ogsf/Gvl3.c
--- grass/branches/develbranch_6/lib/ogsf/Gvl3.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/Gvl3.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -30,9 +30,9 @@
-int Gvl_load_colors_data(void **color_data, char *name)
+int Gvl_load_colors_data(void **color_data, const char *name)
- char *mapset;
struct Colors *colors;
if (NULL == (mapset = G_find_grid3(name,""))) {
Modified: grass/branches/develbranch_6/lib/ogsf/gs.c
--- grass/branches/develbranch_6/lib/ogsf/gs.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gs.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -31,7 +31,7 @@
static int Invertmask;
-void gs_err(char *msg)
+void gs_err(const char *msg)
G_warning ("%s", msg);
Modified: grass/branches/develbranch_6/lib/ogsf/gsd_fonts.c
--- grass/branches/develbranch_6/lib/ogsf/gsd_fonts.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gsd_fonts.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -34,7 +34,7 @@
\return text width
-int gsd_get_txtwidth(char *s, int size)
+int gsd_get_txtwidth(const char *s, int size)
int width, len;
@@ -70,7 +70,7 @@
\return 2
-int get_txtdescender()
return (2);
@@ -84,7 +84,7 @@
\return 0
return (0);
@@ -96,11 +96,11 @@
\param lab_pos label position
\param txt text string
-void do_label_display(GLuint fontbase, float *lab_pos, char *txt)
+void do_label_display(GLuint fontbase, float *lab_pos, const char *txt)
glRasterPos2f(lab_pos[X], lab_pos[Y]);
glListBase(fontbase);
- glCallLists(strlen(txt), GL_BYTE, (GLubyte *) txt);
+ glCallLists(strlen(txt), GL_UNSIGNED_BYTE, (const GLvoid *) txt);
return;
Modified: grass/branches/develbranch_6/lib/ogsf/gsd_label.c
--- grass/branches/develbranch_6/lib/ogsf/gsd_label.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gsd_label.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -38,7 +38,7 @@
\param color font color
\param pt
-void gs_put_label(char *text, GLuint fontbase, int size, unsigned long color,
+void gs_put_label(const char *text, GLuint fontbase, int size, unsigned long color,
int*pt)
int txt_width;
Modified: grass/branches/develbranch_6/lib/ogsf/gsd_legend.c
--- grass/branches/develbranch_6/lib/ogsf/gsd_legend.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gsd_legend.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -198,7 +198,7 @@
\return
-GLuint gsd_put_legend(char *name, GLuint fontbase, int size, int *flags,
+GLuint gsd_put_legend(const char *name, GLuint fontbase, int size, int *flags,
float *rangef, int *pt)
GLint sl, sr, sb, st;
@@ -208,7 +208,7 @@
struct Range range;
struct FPRange fp_range;
- char *mapset;
struct Colors colors;
CELL min, max;
DCELL fmin, fmax;
@@ -370,7 +370,8 @@
float *dividers;
int labw, maxlabw, numlabs;
float labpos, labpt[3];
- char *cstr, buff[80];
+ const char *cstr;
+ char buff[80];
GLint wt, wb, wl, wr; /* Whole legend area, not just box */
int xoff, yoff;
int incr; /* for do_invert */
Modified: grass/branches/develbranch_6/lib/ogsf/gsd_objs.c
--- grass/branches/develbranch_6/lib/ogsf/gsd_objs.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gsd_objs.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -825,7 +825,7 @@
int gsd_north_arrow (float *pos2, float len, GLuint fontbase,
unsigned long arw_clr, unsigned long text_clr)
- char *txt;
+ const char *txt;
float v[4][3];
float base[3][3];
float Ntop[] = { 0.0, 0.0, 1.0 };
@@ -889,7 +889,7 @@
glRasterPos3fv(base[0]);
GS_done_draw();
gsd_popmatrix();
Modified: grass/branches/develbranch_6/lib/ogsf/gsds.c
--- grass/branches/develbranch_6/lib/ogsf/gsds.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gsds.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -185,7 +185,7 @@
\return data id
\return -1 not found
-int gsds_findh(char *name, IFLAG * changes, IFLAG * types, int begin)
+int gsds_findh(const char *name, IFLAG * changes, IFLAG * types, int begin)
static int i;
int start;
@@ -216,7 +216,7 @@
\return data id
-int gsds_newh(char *name)
+int gsds_newh(const char *name)
dataset *new;
Modified: grass/branches/develbranch_6/lib/ogsf/gvl.c
--- grass/branches/develbranch_6/lib/ogsf/gvl.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gvl.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -667,7 +667,7 @@
-int gvl_isosurf_set_att_map(geovol_isosurf *isosurf, int desc, char *filename)
+int gvl_isosurf_set_att_map(geovol_isosurf *isosurf, int desc, const char *filename)
int hfile;
Modified: grass/branches/develbranch_6/lib/ogsf/gvl_calc.c
--- grass/branches/develbranch_6/lib/ogsf/gvl_calc.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gvl_calc.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -747,7 +747,7 @@
\param char
-unsigned char gvl_read_char(int pos, unsigned char *data)
+unsigned char gvl_read_char(int pos, const unsigned char *data)
return data[pos];
Modified: grass/branches/develbranch_6/lib/ogsf/gvl_file.c
--- grass/branches/develbranch_6/lib/ogsf/gvl_file.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gvl_file.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -59,7 +59,7 @@
static int Rows, Cols, Depths;
/* local functions prototypes */
-void *open_g3d_file(char *, IFLAG *, double *, double *);
+void *open_g3d_file(const char *, IFLAG *, double *, double *);
int close_g3d_file(void *);
@@ -137,7 +137,7 @@
\param data id
\param -1 not found
-int find_datah(char *name, IFLAG type, int begin)
+int find_datah(const char *name, IFLAG type, int begin)
static int i;
int start;
@@ -230,7 +230,7 @@
\return pointer to file
-void *open_volfile(char *name, IFLAG file_type, IFLAG *data_type, double *min, double *max)
+void *open_volfile(const char *name, IFLAG file_type, IFLAG *data_type, double *min, double *max)
if (file_type == VOL_FTYPE_G3D) {
return open_g3d_file(name, data_type, min, max);
@@ -266,7 +266,7 @@
\return data id
-int gvl_file_newh(char *name, IFLAG file_type)
+int gvl_file_newh(const char *name, IFLAG file_type)
geovol_file *new;
@@ -409,9 +409,9 @@
\pointer to data
-void *open_g3d_file(char *filename, IFLAG *type, double *min, double *max)
+void *open_g3d_file(const char *filename, IFLAG *type, double *min, double *max)
- char *mapset;
int itype;
void *map;
Modified: grass/branches/develbranch_6/lib/ogsf/gvld.c
--- grass/branches/develbranch_6/lib/ogsf/gvld.c 2008-07-05 21:15:29 UTC (rev 32005)
+++ grass/branches/develbranch_6/lib/ogsf/gvld.c 2008-07-06 09:06:12 UTC (rev 32006)
@@ -238,7 +238,7 @@
nz[i] = 0;
- G_debug (3, " intialize OK", gvl_file_get_name(gvl->hfile), i);
+ G_debug (3, " intialize OK");
for (z = 0; z < depths - 1; z++) {
zc = z * zres;
