[GRASS-SVN] r32037 - in grass/trunk/lib: . nviz ogsf
svn_grass at osgeo.org
Mon Jul 7 04:50:30 EDT 2008
Author: martinl
Date: 2008-07-07 04:50:29 -0400 (Mon, 07 Jul 2008)
New Revision: 32037
Added:
grass/trunk/lib/nviz/nvizlib.dox
grass/trunk/lib/grasslib.dox
grass/trunk/lib/ogsf/GS2.c
ogsflib: doxygen update
nvizlib: doxygen page added (just template)
Modified: grass/trunk/lib/grasslib.dox
--- grass/trunk/lib/grasslib.dox 2008-07-06 22:26:57 UTC (rev 32036)
+++ grass/trunk/lib/grasslib.dox 2008-07-07 08:50:29 UTC (rev 32037)
@@ -95,7 +95,7 @@
<li>symbol: Drawing symbols for %point %vector data library - \ref symbol
<li>vask: Cursor management library - \ref vask
<li>%vector: \ref Vector_Library (GRASS Vector and Direct Graph Library)
-<li>nviz: Nviz library (used by wxGUI Nviz extension and CLI-based Nviz module)
+<li>nviz: \ref nvizlib (used by wxGUI Nviz extension and CLI-based Nviz module)
</ul>
<!--<li>image3: extra imagery library (mainly still unused) - \ref image3lib-->
<!--<li>D: display library - \ref d_displaylib-->
Added: grass/trunk/lib/nviz/nvizlib.dox
--- grass/trunk/lib/nviz/nvizlib.dox (rev 0)
+++ grass/trunk/lib/nviz/nvizlib.dox 2008-07-07 08:50:29 UTC (rev 32037)
@@ -0,0 +1,8 @@
+/*! \page nvizlib GRASS Nviz Library
+\section nvizintro Introduction to Nviz Library
+This library is build on \ref ogsflib and serves as the interface for
+wxGUI Nviz extension and CLI-based Nviz module.
Property changes on: grass/trunk/lib/nviz/nvizlib.dox
___________________________________________________________________
+ text/x-plain
+ Author Date Id
+ native
Modified: grass/trunk/lib/ogsf/GS2.c
--- grass/trunk/lib/ogsf/GS2.c 2008-07-06 22:26:57 UTC (rev 32036)
+++ grass/trunk/lib/ogsf/GS2.c 2008-07-07 08:50:29 UTC (rev 32037)
@@ -2382,17 +2382,15 @@
- \brief Set trans ?
+ \brief Set translation (surface position)
\param id surface id
- \param xtrans,ytrans,ztrans real trans coordinates
+ \param xtrans,ytrans,ztrans translation values
void GS_set_trans(int id, float xtrans, float ytrans, float ztrans)
geosurf *gs;
- G_debug(3, "GS_set_trans");
gs = gs_get_surf(id);
if (gs) {
@@ -2401,21 +2399,22 @@
gs->z_trans = ztrans;
+ G_debug(3, "GS_set_trans(): id=%d, x=%f, y=%f, z=%f",
+ id, xtrans, ytrans, ztrans);
return;
- \brief Get trans ?
+ \brief Get translation values (surface position)
- \param[out] xtrans,ytrans,ztrans real trans coordinates
+ \param[out] xtrans,ytrans,ztrans trans values
void GS_get_trans(int id, float *xtrans, float *ytrans, float *ztrans)
geosurf *gs;
- G_debug(3, "GS_get_trans");
if (gs) {
@@ -2424,6 +2423,9 @@
*ztrans = gs->z_trans;
+ G_debug(3, "GS_get_trans: id=%d, x=%f, y=%f, z=%f",
+ id, *xtrans, *ytrans, *ztrans);
return;
