[GRASS-SVN] r32066 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 9 18:42:13 EDT 2008
Author: martinl
Date: 2008-07-09 18:42:12 -0400 (Wed, 09 Jul 2008)
New Revision: 32066
grass/trunk/gui/wxpython/gui_modules/nviz.py
grass/trunk/gui/wxpython/gui_modules/preferences.py
nviz2/wxGUI: settings (view) fixes
Modified: grass/trunk/gui/wxpython/gui_modules/nviz.py
--- grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-07-09 21:39:19 UTC (rev 32065)
+++ grass/trunk/gui/wxpython/gui_modules/nviz.py 2008-07-09 22:42:12 UTC (rev 32066)
@@ -415,8 +415,8 @@
style=wx.DEFAULT_FRAME_STYLE, mapWindow=None):
self.parent = parent # MapFrame
+ self.lmgr = self.parent.gismanager # GMFrame
self.mapWindow = mapWindow
- self.settings = mapWindow.view # GLWindow.view
wx.Frame.__init__(self, parent, id, title, pos, size, style)
@@ -498,7 +498,7 @@
posSizer.Add(item=wx.StaticText(panel, id=wx.ID_ANY, label=_("N")),
pos=(0, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_BOTTOM)
viewPos = ViewPositionWindow(panel, id=wx.ID_ANY, size=(175, 175),
- settings=self.settings, mapwindow=self.mapWindow)
+ mapwindow=self.mapWindow)
self.win['view']['pos'] = viewPos.GetId()
posSizer.Add(item=viewPos,
pos=(1, 1), flag=wx.ALIGN_CENTER | wx.ALIGN_CENTER_VERTICAL)
@@ -532,7 +532,7 @@
# height + z-exag
self.CreateControl(panel, dict=self.win['view'], name='height', sliderHor=False,
- range=(self.settings['height']['min'], self.settings['height']['max']),
+ range=(self.mapWindow.view['height']['min'], self.mapWindow.view['height']['max']),
bind=(self.OnViewChange, self.OnViewChanged, self.OnViewChangedSpin))
self.CreateControl(panel, dict=self.win['view'], name='z-exag', sliderHor=False,
range=(0, 1),
@@ -1244,7 +1244,7 @@
wx.SL_BOTTOM | wx.SL_INVERSE
sizeW = (-1, size)
try:
- val = self.settings[name]['value']
+ val = self.mapWindow.view[name]['value']
except KeyError:
val=-1
slider = wx.Slider(parent=parent, id=wx.ID_ANY,
@@ -1263,9 +1263,9 @@
min=range[0],
max=range[1])
# spin = wx.SpinButton(parent=parent, id=wx.ID_ANY)
- # spin.SetValue (self.settings[name]['value'])
- # spin.SetRange(self.settings[name]['min'],
- # self.settings[name]['max'])
+ # spin.SetValue (self.mapWindow.view[name]['value'])
+ # spin.SetRange(self.mapWindow.view[name]['min'],
+ # self.mapWindow.view[name]['max'])
# no 'changed' event ... (FIXME)
spin.SetName('spin')
@@ -1283,7 +1283,7 @@
value = UserSettings.Get(group='nviz', key='view',
subkey=['height', 'value'], internal=True)
else:
- value = self.settings[control]['value']
+ value = self.mapWindow.view[control]['value']
self.FindWindowById(win).SetValue(value)
self.FindWindowById(self.win['view']['pos']).Draw()
@@ -1310,9 +1310,9 @@
if not winName:
return
- self.settings[winName]['value'] = event.GetInt()
+ self.mapWindow.view[winName]['value'] = event.GetInt()
for win in self.win['view'][winName].itervalues():
- self.FindWindowById(win).SetValue(self.settings[winName]['value'])
+ self.FindWindowById(win).SetValue(self.mapWindow.view[winName]['value'])
if winName in ('pos', 'height', 'twist', 'persp'):
self.mapWindow.update['view'] = None
@@ -1342,32 +1342,32 @@
"""Look at (view page)"""
sel = event.GetSelection()
if sel == 0: # top
- self.settings['pos']['x'] = 0.5
- self.settings['pos']['y'] = 0.5
+ self.mapWindow.view['pos']['x'] = 0.5
+ self.mapWindow.view['pos']['y'] = 0.5
elif sel == 1: # north
- self.settings['pos']['y'] = 0.0
+ self.mapWindow.view['pos']['y'] = 0.0
elif sel == 2: # south
- self.settings['pos']['y'] = 1.0
+ self.mapWindow.view['pos']['y'] = 1.0
elif sel == 3: # east
- self.settings['pos']['x'] = 1.0
+ self.mapWindow.view['pos']['x'] = 1.0
elif sel == 4: # west
- self.settings['pos']['x'] = 0.0
+ self.mapWindow.view['pos']['x'] = 0.0
elif sel == 5: # north-west
elif sel == 6: # north-east
elif sel == 7: # south-east
elif sel == 8: # south-west
self.UpdateSettings()
@@ -1375,17 +1375,17 @@
def OnDefault(self, event):
"""Restore default settings"""
- self.settings = copy.deepcopy(UserSettings.GetDefaultSettings()['nviz'])
- UserSettings.Set(group='nviz', key='view',
- value=self.settings)
- for subgroup, key in self.settings.iteritems(): # view, surface, vector...
+ settings = copy.deepcopy(UserSettings.GetDefaultSettings()['nviz'])
+ UserSettings.Set(group='nviz',
+ value=settings)
+ for subgroup, key in settings.iteritems(): # view, surface, vector...
if subgroup != 'view':
continue
for subkey, value in key.iteritems():
for subvalue in value.keys():
win = self.FindWindowById(self.win['settings'][subgroup][subkey][subvalue])
- val = self.settings[subgroup][subkey][subvalue]
+ val = settings[subgroup][subkey][subvalue]
if subkey == 'pos':
val = int(val * 100)
@@ -1397,12 +1397,14 @@
"""Apply button pressed"""
if self.notebook.GetSelection() == self.page['settings']:
self.ApplySettings()
+ if event:
+ event.Skip()
- event.Skip()
def ApplySettings(self):
"""Apply Nviz settings for current session"""
+ settings = UserSettings.Get(group='nviz')
continue
@@ -1410,8 +1412,9 @@
value = self.FindWindowById(self.win['settings'][subgroup][subkey][subvalue]).GetValue()
if subkey == 'pos':
value = float(value) / 100
- self.settings[subgroup][subkey][subvalue] = int(value)
+ settings[subgroup][subkey][subvalue] = value
def OnSave(self, event):
"""OK button pressed
@@ -1422,60 +1425,67 @@
self.OnApply(None)
- # save settings
- type = self.mapWindow.GetSelectedLayer().type
- data = self.mapWindow.GetSelectedLayer(nviz=True)
- if data is None: # no settings
- data = {}
+ if self.notebook.GetSelection() == self.page['settings']:
+ fileSettings = {}
+ UserSettings.ReadSettingsFile(settings=fileSettings)
+ fileSettings['nviz'] = UserSettings.Get(group='nviz')
+ file = UserSettings.SaveToFile(fileSettings)
+ self.lmgr.goutput.WriteLog(_('Nviz settings saved to file <%s>.') % file)
+# # save settings
+# type = self.mapWindow.GetSelectedLayer().type
+# data = self.mapWindow.GetSelectedLayer(nviz=True)
+# if data is None: # no settings
+# data = {}
- if type == 'raster': # -> surface
- # surface attributes
- data['attribute'] = {}
- for attrb in ('topo', 'color', 'mask',
- 'transp', 'shine', 'emit'):
- use = self.FindWindowById(self.win['surface'][attrb]['use']).GetSelection()
- if self.win['surface'][attrb]['required']: # map, constant
- if use == 0: # map
- map = True
- elif use == 1: # constant
- map = False
- else: # unset, map, constant
- if use == 0: # unset
- map = None
- elif use == 1: # map
- map = True
- elif use == 2: # constant
- map = False
+# if type == 'raster': # -> surface
+# # surface attributes
+# data['attribute'] = {}
+# for attrb in ('topo', 'color', 'mask',
+# 'transp', 'shine', 'emit'):
+# use = self.FindWindowById(self.win['surface'][attrb]['use']).GetSelection()
+# if self.win['surface'][attrb]['required']: # map, constant
+# if use == 0: # map
+# map = True
+# elif use == 1: # constant
+# map = False
+# else: # unset, map, constant
+# if use == 0: # unset
+# map = None
+# elif use == 1: # map
+# map = True
+# elif use == 2: # constant
+# map = False
- if map is None:
- continue
+# if map is None:
+# continue
- if map:
- value = self.FindWindowById(self.win['surface'][attrb]['map']).GetValue()
- else:
- if attrb == 'color':
- value = self.FindWindowById(self.win['surface'][attrb]['map']).GetColour()
- else:
- value = self.FindWindowById(self.win['surface'][attrb]['const']).GetValue()
+# if map:
+# value = self.FindWindowById(self.win['surface'][attrb]['map']).GetValue()
+# else:
+# if attrb == 'color':
+# value = self.FindWindowById(self.win['surface'][attrb]['map']).GetColour()
+# else:
+# value = self.FindWindowById(self.win['surface'][attrb]['const']).GetValue()
- data['attribute'][attrb] = {}
- data['attribute'][attrb]['map'] = map
- data['attribute'][attrb]['value'] = value
+# data['attribute'][attrb] = {}
+# data['attribute'][attrb]['map'] = map
+# data['attribute'][attrb]['value'] = value
- # draw
- data['draw'] = {}
- for control in ('mode', 'shading', 'style'):
- data['draw'][control] = self.FindWindowById(self.win['surface']['draw'][control]).GetSelection()
- for control in ('res-coarse', 'res-fine'):
- data['draw'][control] = self.FindWindowById(self.win['surface']['draw'][control]).GetValue()
+# # draw
+# data['draw'] = {}
+# for control in ('mode', 'shading', 'style'):
+# data['draw'][control] = self.FindWindowById(self.win['surface']['draw'][control]).GetSelection()
+# for control in ('res-coarse', 'res-fine'):
+# data['draw'][control] = self.FindWindowById(self.win['surface']['draw'][control]).GetValue()
- self.mapWindow.SetLayerSettings(data)
+# self.mapWindow.SetLayerSettings(data)
def UpdateLayerProperties(self):
"""Update data layer properties"""
@@ -1860,7 +1870,7 @@
if pageId == 'view':
- max = self.settings['z-exag']['value'] * 10
+ max = self.mapWindow.view['z-exag']['value'] * 10
for control in ('spin', 'slider'):
self.FindWindowById(self.win['view']['z-exag'][control]).SetRange(0,
max)
@@ -1946,8 +1956,7 @@
"""Position control window (for NvizToolWindow)"""
def __init__(self, parent, id, mapwindow,
pos=wx.DefaultPosition,
- size=wx.DefaultSize, settings={}):
- self.settings = settings
+ size=wx.DefaultSize):
self.mapWindow = mapwindow
wx.Window.__init__(self, parent, id, pos, size)
@@ -1970,8 +1979,8 @@
w, h = self.GetClientSize()
if pos is None:
- x = self.settings['pos']['x']
- y = self.settings['pos']['y']
+ x = self.mapWindow.view['pos']['x']
+ y = self.mapWindow.view['pos']['y']
x = x * w
y = y * h
else:
@@ -1999,8 +2008,8 @@
x = float(x) / w
y = float(y) / h
- self.settings['pos']['x'] = x
- self.settings['pos']['y'] = y
+ self.mapWindow.view['pos']['x'] = x
+ self.mapWindow.view['pos']['y'] = y
self.mapWindow.render = False
Modified: grass/trunk/gui/wxpython/gui_modules/preferences.py
--- grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-07-09 21:39:19 UTC (rev 32065)
+++ grass/trunk/gui/wxpython/gui_modules/preferences.py 2008-07-09 22:42:12 UTC (rev 32066)
@@ -1389,8 +1389,8 @@
else:
value = win.GetValue()
- self.settings.Set(group, key, subkey, value)
+ self.settings.Set(group, value, key, subkey)
# update default window dimension
